path: root/drivers/watchdog/sbc_epx_c3.c
2011-03-01Remove one to many n's in a wordJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-18[WATCHDOG] Correct WDIOF_MAGICCLOSE flagWim Van Sebroeck
Make sure that when the WDIOF_MAGICCLOSE flag is set we also support the magic-close feature... Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-18[WATCHDOG] Some more general cleanupWim Van Sebroeck
Clean-up the watchdog drivers so that checkpatch.pl get's happy... Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] More coding-style and trivial clean-upWim Van Sebroeck
Some more cleaning-up of the watchdog drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-28[PATCH] Switch all my contributions stuff to a single common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-06-21[WATCHDOG 40/57] sbc_epx_c3_wdt: switch to unlocked_ioctlAlan Cox
Review and switch to unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
