path: root/drivers/watchdog/sbc_fitpc2_wdt.c
2011-03-15watchdog: cleanup spaces before tabsWim Van Sebroeck
cleanup spaces before tabs in drivers/watchdog/ Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-09watchdog: sbc_fitpc2_wdt, fix crash on systems without DMI_BOARD_NAMEJiri Slaby
Some systems don't provide DMI_BOARD_NAME in their DMI tables. Avoid crash in such situations in fitpc2_wdt_init. The fix is to check if the dmi_get_system_info return value is NULL. The oops: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81253ae6>] strstr+0x26/0xa0 PGD 3966e067 PUD 39605067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/system/cpu/cpu1/cache/index2/shared_cpu_map CPU 1 Modules linked in: ... Pid: 1748, comm: modprobe Not tainted 2.6.37-22-default #1 /Bochs RIP: 0010:[<ffffffff81253ae6>] [<ffffffff81253ae6>] strstr+0x26/0xa0 RSP: 0018:ffff88003ad73f18 EFLAGS: 00010206 RAX: 0000000000000000 RBX: 00000000ffffffed RCX: 00000000ffffffff RDX: ffffffffa003f4cc RSI: ffffffffa003f4c2 RDI: 0000000000000000 ... CR2: 0000000000000000 CR3: 000000003b7ac000 CR4: 00000000000006e0 ... Process modprobe (pid: 1748, threadinfo ffff88003ad72000, task ffff88002e6365c0) Stack: ... Call Trace: [<ffffffffa004201f>] fitpc2_wdt_init+0x1f/0x13c [sbc_fitpc2_wdt] [<ffffffff810002da>] do_one_initcall+0x3a/0x170 ... Code: f3 c3 0f 1f 00 80 3e 00 53 48 89 f8 74 1b 48 89 f2 0f 1f 40 00 48 83 c2 01 80 3a 00 75 f7 49 89 d0 48 89 f8 49 29 f0 75 02 5b c3 <80> 3f 00 74 0e 0f 1f 44 00 00 48 83 c0 01 80 38 00 75 f7 49 89 Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-26watchdog: sbc_fitpc2_wdt: fixed "scheduling while atomic" bug.Denis Turischev
spinlock need to be replaced by mutex because of sleep functions inside wdt_send_data. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-26watchdog: sbc_fitpc2_wdt: fixed I/O operations orderDenis Turischev
There are fitpc2 compatible boards that hang with existent i/o operations order. Solution is to switch between writing to data and command ports. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-01-25[WATCHDOG] sbc_fitpc2_wdt: fix I/O space access technique.Denis Turischev
The mdelay function was used between I/O access commands, that causes peak in CPU usage. Fix it by substitution mdelay to msleep. Expand usage on fitPC2 compatible boards according to DMI identification. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-11-10[WATCHDOG] SBC-FITPC2 watchdog driver registration fixDenis Turischev
This patch fixes device registration process. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-09-18[WATCHDOG] add SBC-FITPC2 watchdog driverDenis Turischev
Add support for watchdog found on SBC-FITPC2 board. Signed-off-by: Denis Turischev <denis@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
