path: root/drivers/watchdog/tegra_wdt.c
2019-07-08watchdog: tegra_wdt: drop warning after registering deviceWolfram Sang
The core will print out details now. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
2019-05-05watchdog: tegra_wdt: Use watchdog_stop_on_unregister and other improvementsGuenter Roeck
Use watchdog_stop_on_unregister() in probe instead of calling tegra_wdt_stop() in the remove function. Also introduce local variable 'struct device *dev' and use it instead of dereferencing it repeatedly. Finally, drop the now empty remove function. The conversion was done automatically with coccinelle using the following semantic patches. The semantic patches and the scripts used to generate this commit log are available at https://github.com/groeck/coccinelle-patches Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Jonathan Hunter <jonathanh@nvidia.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
2019-05-05watchdog: Convert to use devm_platform_ioremap_resourceGuenter Roeck
Use devm_platform_ioremap_resource to reduce source code size, improve readability, and reduce the likelyhood of bugs. The conversion was done automatically with coccinelle using the following semantic patch. @r@ identifier res, pdev; expression a; expression index; expression e; @@ <+... - res = platform_get_resource(pdev, IORESOURCE_MEM, index); - a = devm_ioremap_resource(e, res); + a = devm_platform_ioremap_resource(pdev, index); ...+> @depends on r@ identifier r.res; @@ - struct resource *res; ... when != res @@ identifier res, pdev; expression index; expression a; @@ - struct resource *res = platform_get_resource(pdev, IORESOURCE_MEM, index); - a = devm_ioremap_resource(&pdev->dev, res); + a = devm_platform_ioremap_resource(pdev, index); Cc: Joel Stanley <joel@jms.id.au> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Alexandre Belloni <alexandre.belloni@bootlin.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Baruch Siach <baruch@tkos.co.il> Cc: Keguang Zhang <keguang.zhang@gmail.com> Cc: Vladimir Zapolskiy <vz@mleia.com> Cc: Kevin Hilman <khilman@baylibre.com> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Avi Fishman <avifishman70@gmail.com> Cc: Nancy Yuen <yuenn@google.com> Cc: Brendan Higgins <brendanhiggins@google.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Sylvain Lemieux <slemieux.tyco@gmail.com> Cc: Kukjin Kim <kgene@kernel.org> Cc: Barry Song <baohua@kernel.org> Cc: Orson Zhai <orsonzhai@gmail.com> Cc: Patrice Chotard <patrice.chotard@st.com> Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com> Cc: Maxime Ripard <maxime.ripard@bootlin.com> Cc: Chen-Yu Tsai <wens@csie.org> Cc: Marc Gonzalez <marc.w.gonzalez@free.fr> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Tested-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Acked-by: Joel Stanley <joel@jms.id.au> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Michal Simek <michal.simek@xilinx.com> (cadence/xilinx wdts) Acked-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
2018-03-24watchdog: add SPDX identifiers for watchdog subsystemMarcus Folkesson
- Add SPDX identifier - Remove boiler plate license text - If MODULE_LICENSE and boiler plate does not match, go for boiler plate license Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com> Acked-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com> Acked-by: Keiji Hayashibara <hayashibara.keiji@socionext.com> Acked-by: Johannes Thumshirn <jth@kernel.org> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Mans Rullgard <mans@mansr.com> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: William Breathitt Gray <vilhelm.gray@gmail.com> Reviewed-by: Eric Anholt <eric@anholt.net> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2017-02-24watchdog: tegra_wdt: Convert to use device managed functionsGuenter Roeck
Use device managed functions to simplify error handling, reduce source code size, improve readability, and reduce the likelyhood of bugs. The conversion was done automatically with coccinelle using the following semantic patches. The semantic patches and the scripts used to generate this commit log are available at https://github.com/groeck/coccinelle-patches - Use devm_watchdog_register_driver() to register watchdog device Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-24watchdog: tegra: constify watchdog_ops structuresJulia Lawall
Check for watchdog_ops structures that are only stored in the ops field of a watchdog_device structure. This field is declared const, so watchdog_ops structures that have this property can be declared as const also. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct watchdog_ops i@p = { ... }; @ok@ identifier r.i; struct watchdog_device e; position p; @@ e.ops = &i@p; @bad@ position p != {r.p,ok.p}; identifier r.i; struct watchdog_ops e; @@ e@i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct watchdog_ops i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-11-23watchdog: tegra: Stop watchdog first if restartingAndrew Chew
If we need to restart the watchdog due to someone changing the timeout interval, stop the watchdog before restarting it. Otherwise, the new timeout doesn't seem to take. Signed-off-by: Andrew Chew <achew@nvidia.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-09-09Watchdog: Fix parent of watchdog_devicesPratyush Anand
/sys/class/watchdog/watchdogn/device/modalias can help to identify the driver/module for a given watchdog node. However, many wdt devices do not set their parent and so, we do not see an entry for device in sysfs for such devices. This patch fixes parent of watchdog_device so that /sys/class/watchdog/watchdogn/device is populated. Exceptions: booke, diag288, octeon, softdog and w83627hf -- They do not have any parent. Not sure, how we can identify driver for these devices. Signed-off-by: Pratyush Anand <panand@redhat.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Maxime Coquelin <maxime.coquelin@st.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-10-20watchdog: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-03-31watchdog: Add tegra watchdogAndrew Chew
Add a driver for the hardware watchdogs in NVIDIA Tegra SoCs (Tegra30 and later). This driver will configure one watchdog timer that will reset the system in the case of a watchdog timeout. This driver binds to the nvidia,tegra30-timer device node and gets its register base from there. Signed-off-by: Andrew Chew <achew@nvidia.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
