- Add compilation flag to treat warning as error
- Handle error of unused variable
- Handle error of uninitialised variable
bug 949219
Change-Id: I07437be5eaa7bf7abe5494c828690b6be3b98178
Signed-off-by: schowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/118039
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Enable FIQ on 2nd watchdog expiry to make use of FIQ debugger. FIQ
debugger can be used to dump call-stack and registers when WDT logic
triggers FIQ on 2nd timeout.
Bug 970018
Change-Id: Ia2e7f8b136499974ff51f2f0c2ef55704dfe37e1
Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com>
Reviewed-on: http://git-master/r/110953
Reviewed-by: Xin Xie <xxie@nvidia.com>
Reviewed-by: Steve Kuo <stevek@nvidia.com>
- Make all CPU watchdogs accessible except WDT0
- CPU WDT0 is reserved for suspend/resume WDT recovery
- Fix WDT enable sequence on watchdog driver probe
Bug 857748
Change-Id: Ia2d07856c32230ab8c9195fee151af09bce3ddde
Reviewed-on: http://git-master/r/99780
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/70702
(cherry picked from commit 50992cf718c37882d90e2b781fbe3f01b4997df8)
Reviewed-on: http://git-master/r/77928
(cherry picked from commit a51315ad482758e53a75096be0415ca9b49b9483)
Change-Id: I22389cfc7010937dc60c5b1aa4b59c4992f9906b
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/80003
Reviewed-on: http://git-master/r/70625
(cherry picked from commit 90add398c43bb111903015bb6a3cd57a8d62262f)
Reviewed-on: http://git-master/r/77926
(cherry picked from commit 4a781c10f2b302f3b467b69060028f9c3b2f9774)
Change-Id: Ia2b4935896a44d1717e20693e26a244c6f556c98
Reviewed-on: http://git-master/r/79999
Add KEEPALIVE functionality to Tegra WDT driver for use by user space
applications.
Bug 887733
Reviewed-on: http://git-master/r/77135
Change-Id: I966371bc5db34416de08c8dc2af9069b4bd34c5d
Reviewed-on: http://git-master/r/77750
commit e67d668e147c3b4fec638c9e0ace04319f5ceccd upstream.
This patch makes use of the set_memory_x() kernel API in order
to make necessary BIOS calls to source NMIs.
This is needed for SLES11 SP2 and the latest upstream kernel as it appears
the NX Execute Disable has grown in its control.
Signed-off by: Thomas Mingarelli <thomas.mingarelli@hp.com>
Signed-off by: Wim Van Sebroeck <wim@iguana.be>
Change-Id: I118282df5d0a473c72f5609a71a5cb25e86ea416
Reviewed-on: http://git-master/r/74199
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
Fix wdt resource definition issue either.
Bug 790458
Original-Change-Id: I7c80d6c243c42a0e632603dfcc255b70995358b2
Reviewed-on: http://git-master/r/20646
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Original-Change-Id: I9897fb6614d75508bd0ffd6e866acf27a24a0cb5
Rebase-Id: R165f408464819298bdcc1f0b677c50b46071be90
Use new watch dog controller for CONFIG_ARCH_TEGRA_3x_SOC.
Bug 790458
Original-Change-Id: I43975a2794f44f612a5f16674cd674aeebe4e6be
Reviewed-on: http://git-master/r/19715
Original-Change-Id: Ic8c9907998a2ab1777ea2b00f1acceb6d66c10e5
Rebase-Id: Ra0b9af5a0642fab2d13816f04c0c340ea42a45c8
Opening the Tegra WDT device from user space is causing the kernel
panic. It is found that the device file private data pointer is passing
incorrectly in the orignal code.
bug 786885
Original-Change-Id: I4646b02c5a804c07d05ba01e35034408cc8e3e4e
Reviewed-on: http://git-master/r/23629
Tested-by: Xin Xie <xxie@nvidia.com>
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Ra37e36461d02b1482bcb815dc554104cf552544d
To allow the spinlock lockup detection to actually trigger after
60 seconds, the tegra_wdt heartbeat needs to be longer than that.
Bumping it to 120sec, as at the 50% marker the watchdog takes an
interrupt.
Change-Id: I099fd7720d65c0e2050fa91161e30485fe84a1ed
Signed-off-by: JP Abgrall <jpa@google.com>
Fix not re-enabling watchdog resume if it was enabled in probe
Add clearing watchdog interrupt in probe
Remove tegra_wdt_set_timeout
Change-Id: I8fdbb6da3eda64a85a73ed85ab979a5ee0261c37
Signed-off-by: Dmitriy Gruzman <dmitriy.gruzman@motorola.com>
Add a config option to enable the watchdog driver from probe
Reduce the default timeout to 30 seconds
Read the reset reason and print a messge if the last reboot was
due to watchdog reset
Change-Id: I7500ef236089b06ffcff3d8e7d86a5b9060b59cb
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
add a driver for the hardware watchdog timer embedded in NVIDIA
Tegra SoCs
Change-Id: I45bc829f26f350143d5a07e1f4ddc46d24f3a54c
Signed-off-by: Gary King <gking@nvidia.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
The enable function was using the global timeout variable for local operations.
This resulted in the value of the global variable being corrupted, thus
breaking the code.
Signed-off-by: John Crispin <blogic@openwrt.org>
Signed-off-by: Thomas Langer <thomas.langer@lantiq.com>
Cc: linux-watchdog@vger.kernel.org
Cc: linux-mips@linux-mips.org
On platforms with no iCRU support don't print two, (possibly conflicting),
"NMI occurred" messages when the firmware is unable to source the NMI.
Please note that one of the enhancements to the v1.3.0 hpwdt driver is to panic and allow
KDUMP to succeed even on NMIs that are unknown to the platform firmware.
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
Reviewed-by: Thomas Mingarelli <thomas.mingarelli@hp.com>
Use the passed watchdog_device instead of the static global variable when
testing and setting the status in watchdog_ping, watchdog_start, and
watchdog_stop. Note that the callers of these functions are actually
passing the static global variable.
The newly added WATCHDOG_CORE option is a bool, but the help text suggests
it can be built as a module. Fix it up.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
At present the module does not unset the NO_REBOOT bit upon shutdown, this
causes the BIOS to fail the POST once and reset. During the next boot it
displays the following error message:
***** Warning: System BOOT Fail *****
Your system last boot fail or POST interrupted.
Please enter setup to load default and reboot again.
Press F1 to continue, DEL to enter SETUP
With this patch the NO_REBOOT flag will be unset on shutdown and thus stop
this failure from occurring.
Tested on 'ASUS P5N32-E SLI with BIOS revision 1801' and
'ASUS P5N32-E SLI PLUS with BIOS revision 1502'.
Signed-off-by: Mart Gerrits <mart1987@gmail.com>
Fix the usage of mod_timer() and make the driver usable. mod_timer() must
be called with an absolute timeout in jiffies. The old implementation
used a relative timeout thus the hardware watchdog was never triggered.
Signed-off-by: David Engraf <david.engraf@sysgo.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Wim Van sebroeck <wim@iguana.be>
Cc: stable <stable@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdog: (25 commits)
watchdog: WatchDog Timer Driver Core - Add minimum and max timeout
watchdog: WatchDog Timer Driver Core - Add ioctl call
watchdog: WatchDog Timer Driver Core - Add nowayout feature
watchdog: WatchDog Timer Driver Core - Add Magic Close feature
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctl
watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctl
watchdog: WatchDog Timer Driver Core - Add basic ioctl functionality
watchdog: WatchDog Timer Driver Core - Add basic framework
watchdog: hpwdt: add next gen HP servers
watchdog: it8712f_wdt.c: improve includes
watchdog: at91sam9/wdt: move register header to drivers
watchdog: Add Xilinx watchdog timer driver
watchdog: remove empty pm-functions
watchdog: sp805: Flush posted writes in enable/disable.
watchdog: sp805: Don't write 0 to the load value register.
watchdog: imx2_wdt: add device tree probe support
watchdog: s3c2410: Add support for device tree based probe
watchdog: mpcore_wdt: Add suspend/resume support.
watchdog: mtx1-wdt: use dev_{err,info} instead of printk()
Add min_timeout (minimum timeout) and max_timeout
values so that the framework can check if the new
timeout value is between the minimum and maximum
timeout values. If both values are 0, then the
framework will leave the check for the watchdog
device driver itself.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Add support for extra ioctl calls by adding a
ioctl watchdog operation. This operation will be
called before we do our own handling of ioctl
commands. This way we can override the internal
ioctl command handling and we can also add
extra ioctl commands. The ioctl watchdog operation
should return the appropriate error codes or
-ENOIOCTLCMD if the ioctl command should be handled
through the internal ioctl handling of the framework.
Add support for the nowayout feature to the
WatchDog Timer Driver Core framework.
This feature prevents the watchdog timer from being
stopped.
Add support for the Magic Close feature to the
This part add's the WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl
functionality to the WatchDog Timer Driver Core framework.
This part add's the WDIOC_SETOPTIONS ioctl functionality
This part add's the WDIOC_KEEPALIVE ioctl functionality to the
WatchDog Timer Driver Core framework. Please note that the
WDIOF_KEEPALIVEPING bit has to be set in the watchdog_info
options field.
This part add's the basic ioctl functionality to the
WatchDog Timer Driver Core framework. The supported
ioctl call's are:
WDIOC_GETSUPPORT
WDIOC_GETSTATUS
WDIOC_GETBOOTSTATUS
The WatchDog Timer Driver Core is a framework
that contains the common code for all watchdog-driver's.
It also introduces a watchdog device structure and the
operations that go with it.
This is the introduction of this framework. This part
supports the minimal watchdog userspace API (or with
other words: the functionality to use /dev/watchdog's
open, release and write functionality as defined in
the simplest watchdog API). Extra functionality will
follow in the next set of patches.
This patch is required to enable hpwdt to work on next generation HP servers
with iLO.
Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
remove unneeded pci.h include.
and include ioport.h to avoid build errors for the region functions.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Watchdog timer device driver for Xilinx xps_timebase_wdt compatible ip cores.
It takes watchdog timer configuration from device tree and it needs that its
parent has defined the property "clock-frecuency".
It is compatible with watchdog timer kernel API, so user apps like watchdogd
may talk with it.
Signed-off-by: Alejandro Cabrera <aldaya@gmail.com>
While checking what watchdog drivers usually do in suspend/resume to
spot common behaviour for the watchdog framework, I found these drivers
which do nothing but add some cruft. Remove it, it is superfluous. New
approaches should probably be done with pm_ops anyway.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
There are no reads in these functions, so if MMIO writes are posted,
the writes in enable/disable may not have completed by the time these
functions return. If the functions run from different CPUs, it's
in theory possible for the writes to be interleaved, which would be
disastrous for this driver.
At the very least, we need an mmiowb() before releasing the lock, but
since it seems desirable for the watchdog timer to be actually stopped
or reset when these functions return, read the lock register to force
the writes out.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
At least on the Versatile Express' V2M, calling wdt_disable followed by
wdt_enable, for instance by running the following sequence:
echo V > /dev/watchdog; echo V > /dev/watchdog
results in an immediate reset. The wdt_disable function writes 0 to the
load register; while the watchdog interrupts are disabled at this point,
this special value is defined to trigger an interrupt immediately. It
appears that in this instance, the reset happens when the interrupts
are subsequently enabled by wdt_enable.
Putting in a short delay after writing a new load value in wdt_enable
solves the issue, but it seems cleaner to simply never write 0 to the
load register at all: according to the hardware docs, writing 0 to the
control register suffices to stop the counter, and the write of 0 to
the load register is questionable anyway since this register resets to
0xffffffff.
Adds device tree probe support for imx2_wdt driver.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Wolfram Sang <w.sang@pengutronix.de>
This patch adds the of_match_table to enable s3c2410-wdt driver
to be probed when watchdog device node is found in the device tree.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Add support for suspend and resume to the MPCore watchdog driver.
Signed-off-by: Peter Fordham <peter.fordham@gmail.com>
use dev_{err,info} instead of printk(KERN_{ERR,INFO} ...)
Signed-off-by: Florian Fainelli <florian@openwrt.org>
The i.MX architecture provides IMX_HAVE_PLATFORM_* macros to signal
that a selected SoC supports a certain hardware. Use them instead of
depending on ARCH_* directly.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
The Synopsys DesignWare watchdog is found in several ARM based systems
and provides a choice of 16 timeout periods depending on the clock
input. The watchdog cannot be disabled once started.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Inspired by Nat Gurumoorthy's recent patches for cleaning up the it87
drivers to use request_muxed_region for accessing the SuperIO area on
these chips, and the fact I have a GPIO driver for the pc8741x basically
ready for submission, here is a patch to cleanup the pc87413 watchdog
driver to use request_muxed_region for accessing the SuperIO area.
It also pulls out the details about the SWC IO area on initial driver
load, and properly does a request_region for that area - there's no
requirement to touch the SuperIO area after doing the initial watchdog
enable and IO base retrieval.
While I have hardware with a pc87413 on it it is not wired in a way that
allows the watchdog to reboot the machine, so I have not been able to
fully test these changes - I have checked that the driver correctly
initialises itself still and requests the SWC io region ok.
Signed-Off-By: Jonathan McDowell <noodles@earth.li>
Signed-Off-By: Wim Van Sebroeck <wim@iguana.be>
Clean up of the iTCO_wdt PCI device ID's.
Own macro is replaced by the PCI_VDEVICE macro.
Changes the it87 watchdog drivers to use "request_muxed_region".
Serialize access to the hardware by using "request_muxed_region" macro defined
by Alan Cox. Call to this macro will hold off the requestor if the resource is
currently busy.
The use of the above macro makes it possible to get rid of
spinlocks in it8712f_wdt.c and it87_wdt.c watchdog drivers.
This also greatly simplifies the implementation of it87_wdt.c driver.
"superio_enter" will return an error if call to "request_muxed_region" fails.
Rest of the code change is to ripple an error return from superio_enter to
the top level.
Signed-off-by: Nat Gurumoorthy <natg@google.com>
hpwdt is a PCI driver so it should depend on PCI.
Fixes these build errors:
drivers/watchdog/hpwdt.c:762: error: implicit declaration of function 'pci_iomap'
drivers/watchdog/hpwdt.c:762: warning: assignment makes pointer from integer without a cast
drivers/watchdog/hpwdt.c:797: error: implicit declaration of function 'pci_iounmap'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Thomas Mingarelli <thomas.mingarelli@hp.com>
