path: root/drivers/watchdog
2014-07-06watchdog: kempld-wdt: Use the correct value when configuring the prescaler ↵gundberg
with the watchdog commit a9e0436b303e94ba57d3bd4b1fcbeaa744b7ebeb upstream. Use the prescaler index, rather than its value, to configure the watchdog. This will prevent a mismatch with the prescaler used to calculate the cycles. Signed-off-by: Per Gundberg <per.gundberg@icomera.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Michael Brunner <michael.brunner@kontron.com> Tested-by: Michael Brunner <michael.brunner@kontron.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06watchdog: ath79_wdt: avoid spurious restarts on AR934xGabor Juhos
commit 23afeb613ec0e10aecfae7838a14d485db62ac52 upstream. On some AR934x based systems, where the frequency of the AHB bus is relatively high, the built-in watchdog causes a spurious restart when it gets enabled. The possible cause of these restarts is that the timeout value written into the TIMER register does not reaches the hardware in time. Add an explicit delay into the ath79_wdt_enable function to avoid the spurious restarts. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06watchdog: sp805: Set watchdog_device->timeout from ->set_timeout()Viresh Kumar
commit 938626d96a3ffb9eb54552bb0d3a4f2b30ffdeb0 upstream. Implementation of ->set_timeout() is supposed to set 'timeout' field of 'struct watchdog_device' passed to it. sp805 was rather setting this in a local variable. Fix it. Reported-by: Arun Ramamurthy <arun.ramamurthy@broadcom.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-21watchdog: w83697hf_wdt: return ENODEV if no device was foundStanislav Kholmanskikh
Most WDT driver modules return ENODEV during modprobe if no valid device was found, but w83697hf_wdt returns EIO. Let w83697hf_wdt return ENODEV. Signed-off-by: Stanislav Kholmanskikh <stanislav.kholmanskikh@oracle.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-02-08watchdog: dw_wdt: Add dependency on HAS_IOMEMRichard Weinberger
On archs like S390 or um this driver cannot build nor work. Make it depend on HAS_IOMEM to bypass build failures. drivers/built-in.o: In function `dw_wdt_drv_probe': drivers/watchdog/dw_wdt.c:302: undefined reference to `devm_ioremap_resource' Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: w83627hf_wdt: Reset watchdog trigger during initializationGuenter Roeck
If the watchdog has already triggered for whatever reason, it won't restart unless the trigger is reset. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: w83627hf: Add support for W83697HF and W83697UGGuenter Roeck
Major difference is that the watchdog control and counter registers are different on both chips. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: w83627hf: Auto-detect IO address and supported chipsGuenter Roeck
Instead of requiring the user to provide an IO address per module parameter, auto-detect it as well as supported chips. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: at91sam9_wdt: increase security margin on watchdog counter resetBoris BREZILLON
Try to reset the watchdog counter 4 or 2 times more often than actually requested, to avoid spurious watchdog reset. If this is not possible because of the min_heartbeat value, reset it at the min_heartbeat period. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: at91sam9_wdt: avoid spurious watchdog reset during initBoris BREZILLON
Use the min_heartbeat value instead of the calculated heartbeat value for the first watchdog reset to avoid spurious watchdog reset. Resetting the watchdog counter during init might lead to a watchdog fault reset because the watchdog counter has to be running for at least min_heartbeat. Resetting the watchdog counter after heartbeat might lead to a watchdog timeout reset because the watchdog counter is running for more than max_heartbeat time. Using min_heartbeat instead of heartbeat does not guarantee that the watchdog won't trigger a reset, but at least it reduces the chances to be in such a case. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: at91sam9_wdt: fix secs_to_ticksBoris BREZILLON
Fix the secs_to_ticks macro in case 0 is passed as an argument. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: at91sam9_wdt: better watchdog supportBoris BREZILLON
The at91sam9 watchdog timer can only be configured once, and the current implementation tries to configure it in a static way: - 2 seconds timeout - wdt restart every 500ms If the timer has already been configured with different values, it returns an error and do not create any watchdog device. This is not critical if the watchdog is disabled, but if it has been enabled with different timeout values it will lead to a SoC reset. This patch series tries to address this issue by adapting the heartbeat value according the WDT timer config: - it first tries to configure the timer as requested. - if it fails it fallbacks to the current config, adapting its heartbeat timer to the needs This patch series also move to a dynamically allocated at91wdt device instead of the static instance. It adds a new at91 wdt type: software. This new type make use of the at91 wdt interrupt to trigger a software reboot. Finally it adds several properties to the device tree bindings. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: sp805_wdt depends also on ARM64Naresh Bhat
Add sp805_wdt depends on ARM64. Signed-off-by: Naresh Bhat <naresh.bhat@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: mach-moxart: add restart handlerJonas Jensen
mach-moxart lacks a separate register for reset; as a workaround, add a function that can be hooked to arm_pm_restart. Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: mpc8xxx_wdt convert to watchdog coreChristophe Leroy
Convert mpc8xxx_wdt.c to the new watchdog API. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: sirf: Remove redundant of_match_ptr helperSachin Kamat
'sirfsoc_wdt_of_match' is always compiled in. Hence the helper macro is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: hpwdt patch to display informative stringThomas Mingarelli
This patch is being submitted to output a general string when the panic comes in that informs the user of the possible places to look for the source of the NMI. Because various systems log the message in different places this would give a single display of where to go look instead of code that acts on all these different server names or IDs. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: dw_wdt: remove build dependenciesBaruch Siach
There is nothing ARM specific in this driver, and we intend to use it on the Xtensa architecture. Also, clk.h now includes stubs for !CONFIG_HAVE_CLK, so the driver should build anyway. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: imx2_wdt: disable watchdog timer during low power modeAnson Huang
We should set watchdog timer to be disabled in low power mode, as there is no service running in background, otherwise, system will reset unexpected. Signed-off-by: Anson Huang <b20788@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: s3c2410_wdt: Report when the watchdog reset the systemDoug Anderson
A good watchdog driver is supposed to report when it was responsible for resetting the system. Implement this for the s3c2410, at least on exynos5250 and exynos5420 where we already have a pointer to the PMU registers to read the information. Note that exynos4 SoCs also provide the reset status, but providing that is left as an exercise for future changes and is not plumbed up in this patch series. Also note the exynos4 SoCs don't appear to need any PMU config, which is why this patch separates the concepts of having PMU Registers vs. needing PMU Config. Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: s3c2410_wdt: use syscon regmap interface to configure pmu registerLeela Krishna Amudala
Add device tree support for exynos5250 and 5420 SoCs and use syscon regmap interface to configure AUTOMATIC_WDT_RESET_DISABLE and MASK_WDT_RESET_REQUEST registers of PMU to mask/unmask enable/disable of watchdog in probe and s2r scenarios. Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com> Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: s3c2410_wdt: Handle rounding a little better for timeoutDoug Anderson
The existing watchdog timeout worked OK but didn't deal with rounding in an ideal way when dividing out all of its clocks. Specifically if you had a timeout of 32 seconds and an input clock of 66666666, you'd end up setting a timeout of 31.9998 seconds and reporting a timeout of 31 seconds. Specifically DBG printouts showed: s3c2410wdt_set_heartbeat: count=16666656, timeout=32, freq=520833 s3c2410wdt_set_heartbeat: timeout=32, divisor=255, count=16666656 (0000ff4f) and the final timeout reported to the user was: ((count / divisor) * divisor) / freq (0xff4f * 255) / 520833 = 31 (truncated from 31.9998) the technically "correct" value is: (0xff4f * 255) / (66666666.0 / 128) = 31.9998 By using "DIV_ROUND_UP" we can be a little more correct. s3c2410wdt_set_heartbeat: count=16666688, timeout=32, freq=520834 s3c2410wdt_set_heartbeat: timeout=32, divisor=255, count=16666688 (0000ff50) and the final timeout reported to the user: (0xff50 * 255) / 520834 = 32 the technically "correct" value is: (0xff50 * 255) / (66666666.0 / 128) = 32.0003 We'll use a DIV_ROUND_UP to solve this, generally erroring on the side of reporting shorter values to the user and setting the watchdog to slightly longer than requested: * Round input frequency up to assume watchdog is counting faster. * Round divisions by divisor up to give us extra time. At the same time we can avoid a for loop by just doing the right math. Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: s3c2410_wdt: Only register for cpufreq on ARM_S3C24XX_CPUFREQDoug Anderson
On modern SoCs the watchdog timer is parented on a clock that doesn't change every time we have a cpufreq change. That means we don't need to constantly adjust the watchdog timer, so avoid registering for and dealing with cpufreq transitions unless we've actually got CONFIG_ARM_S3C24XX_CPUFREQ defined. Note that this is more than just an optimization. The s3c2410 watchdog driver actually pats the watchdog on every CPU frequency change. On modern systems these happen many times per second (even in a system where "nothing" is happening). That effectively makes any userspace watchdog program useless (the watchdog is constantly patted by the kernel). If we need ARM_S3C24XX_CPUFREQ defined on a multiplatform kernel we'll need to make sure that kernel supports common clock and change this to user common clock framework. Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: GPIO-controlled watchdogAlexander Shiyan
This patch adds a watchdog driver for devices controlled through GPIO, (Analog Devices ADM706, Maxim MAX823, National NE555 etc). Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: davinci: reuse driver for keystone archIvan Khoronzhuk
The keystone arch uses the same IP watchdog, so add "ti,keystone-wdt" compatible and correct identity. The Keystone arch is using clocks in DT and source clock for watchdog has to be specified, so add this to binding. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: davinci: add GET_TIMELEFT option supportIvan Khoronzhuk
Currently, the davinci watchdog can be read while counting, so we can add ability to report the remaining time before the system will reboot. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: davinci: use davinci_wdt_device structure to hold device dataIvan Khoronzhuk
Some SoCs, like Keystone 2, can support more than one WDT and each watchdog device has to use it's own base address, clock source, watchdog device, so add new davinci_wdt_device structure to hold device data. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Guenter roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: davinci: change driver to use WDT coreIvan Khoronzhuk
To reduce code duplicate and increase code readability use WDT core code to handle WDT interface. Remove io_lock as the WDT core uses mutex to lock each wdt device. Remove wdt_state as the WDT core tracks state with its own variable. The watchdog_init_timeout() can read timeout value from timeout-sec property if the passed value is out of bounds. The heartbeat is initialized in next way. If heartbeat is not set thought module parameter, try to read it's value from WDT node timeout-sec property. If node has no one, use default value. The heartbeat is hold in wdd->timeout by WDT core, so use it in order to set timeout period. Davinci WDT can't be stopped and once it's expired - it can be rearmed only after hardware reset, that's why nowayout feature is enforced. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: bcm281xx: Debugfs supportMarkus Mayer
This change introduces debugfs support for the BCM281xx watchdog driver. Signed-off-by: Markus Mayer <markus.mayer@linaro.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: bcm281xx: Watchdog DriverMarkus Mayer
This commit adds support for the watchdog timer used on the BCM281xx family of SoCs. Signed-off-by: Markus Mayer <markus.mayer@linaro.org> Reviewed-by: Matt Porter <matt.porter@linaro.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: core: Make dt "timeout-sec" property work on drivers w/out min/maxDoug Anderson
It is valid for a watchdog driver to have 0 for a "min" and "max" timeout if the driver doesn't need the core to enforce the concepts of min and max. The s3c2410_wdt driver is one such driver. Specifically it can be hard for that driver to come up with a static "max" on all platforms without a lot more information since the input clock on S3C2410 and S3C2440 can change with DVFS. As written, watchdog_init_timeout() will not ever read "timeout-sec" on these drivers since watchdog_timeout_invalid() will _never_ return true. Change to not consider a timeout_parm of 0 as valid even if min/max aren't specified by the driver. Also handle the case when there is no min/max and no "timeout-sec" property. Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-28watchdog: remove DEFINE_PCI_DEVICE_TABLE macroJingoo Han
Don't use DEFINE_PCI_DEVICE_TABLE macro, because this macro is not preferred. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-01-23Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM driver updates from Olof Johansson: "Updates of SoC-near drivers and other driver updates that makes more sense to take through our tree. The largest part of this is a conversion of device registration for some renesas shmobile/sh devices over to use resources. This has required coordination with the corresponding arch/sh changes, and we've agreed to merge the arch/sh changes through our tree. Added in this branch is support for Trusted Foundations secure firmware, which is what is used on many of the commercial Nvidia Tegra products that are in the market, including the Nvidia Shield. The code is local to arch/arm at this time since it's uncertain whether it will be shared with arm64 longer-term, if needed we will refactor later. A couple of new RTC drivers used on ARM boards, merged through our tree on request by the RTC maintainer. ... plus a bunch of smaller updates across the board, gpio conversions for davinci, etc" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (45 commits) watchdog: davinci: rename platform driver to davinci-wdt tty: serial: Limit msm_serial_hs driver to platforms that use it mmc: msm_sdcc: Limit driver to platforms that use it usb: phy: msm: Move mach dependent code to platform data clk: versatile: fixup IM-PD1 clock implementation clk: versatile: pass a name to ICST clock provider ARM: integrator: pass parent IRQ to the SIC irqchip: versatile FPGA: support cascaded interrupts from DT gpio: davinci: don't create irq_domain in case of unbanked irqs gpio: davinci: use chained_irq_enter/chained_irq_exit API gpio: davinci: add OF support gpio: davinci: remove unused variable intc_irq_num gpio: davinci: convert to use irqdomain support. gpio: introduce GPIO_DAVINCI kconfig option gpio: davinci: get rid of DAVINCI_N_GPIO gpio: davinci: use {readl|writel}_relaxed() instead of __raw_* serial: sh-sci: Add OF support serial: sh-sci: Add device tree bindings documentation serial: sh-sci: Remove platform data mapbase and irqs fields serial: sh-sci: Remove platform data scbrr_algo_id field ...
2014-01-16Merge tag 'davinci-for-v3.14/watchdog' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/drivers From Sekhar Nori: This patch updates the davinci watchdog platform device name from generic "watchdog" to something more specific. * tag 'davinci-for-v3.14/watchdog' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci: watchdog: davinci: rename platform driver to davinci-wdt Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-01-09watchdog: davinci: rename platform driver to davinci-wdtIvan Khoronzhuk
As we switch to use the watchdog core which permits more than one active watchdog in the system, rename platform driver to "davinci-wdt" to be identifiable. Acked-by: Wim Van Sebroeck <wim@iguana.be> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2014-01-07Watchdog: pcwd_usb: remove CONFIG_USB_DEBUG usageGreg Kroah-Hartman
CONFIG_USB_DEBUG is going away, and all of the other USB drivers no longer rely on "debug" module parameters for debugging lines, so move the pcwd_usb driver to use the dynamic debug infrastructure to be more in line with the rest of the kernel. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Wim Van Sebroeck <wim@iguana.be> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
2013-12-10sc1200_wdt: Fix oopsAlan
If loaded with isapnp = 0 the driver explodes. This is catching people out now and then. What should happen in the working case is a complete mystery and the code appears terminally confused, but we can at least make the error path work properly. Signed-off-by: Alan Cox <alan@linux.intel.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Partially-Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=53991
2013-12-10watchdog: Drop unnecessary include of miscdevice.hGuenter Roeck
After commit 487722cf2 (watchdog: Get rid of MODULE_ALIAS_MISCDEV statements) the affected drivers no longer need to include miscdevice.h. Only exception is rt2880_wdt.c which never needed it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-18watchdog: w83627hf: Use helper functions to access superio registersGuenter Roeck
Use helper functions named similar to other drivers to access superio registers. Request memory region only when needed, and use request_muxed_region(). This lets other devices (hwmon, gpio) use the same region. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-18watchdog: w83627hf: Enable watchdog device only if not already enabledGuenter Roeck
There is no need to enable the watchdog device if it is already enabled. Also, when enabling the watchdog device, only set the watchdog device enable bit and do not touch other bits; depending on the chip type, those bits may enable other functionality. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-18watchdog: w83627hf: Enable watchdog only onceGuenter Roeck
It is unnecessary to enable the logical device and WDT0 each time the watchdog is accessed. Do it only once during initialization. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-18watchdog: w83627hf: Convert to watchdog infrastructureGuenter Roeck
2013-11-17watchdog: omap_wdt: raw read and write endian fixVictor Kamensky
All OMAP IP blocks expect LE data, but CPU may operate in BE mode. Need to use endian neutral functions to read/write h/w registers. I.e instead of __raw_read[lw] and __raw_write[lw] functions code need to use read[lw]_relaxed and write[lw]_relaxed functions. If the first simply reads/writes register, the second will byteswap it if host operates in BE mode. Changes are trivial sed like replacement of __raw_xxx functions with xxx_relaxed variant. Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org> Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-17watchdog: sirf: don't depend on dummy value of CLOCK_TICK_RATEUwe Kleine-König
As CSR SiRF is converted to multi platform CLOCK_TICK_RATE is a dummy value that seems to match the right value is used. (arch/arm/mach-prima2/include/mach/timex.h which defined CLOCK_TICK_RATE to 1000000 was removed in commit cf82e0e (ARM: sirf: enable multiplatform support); marco used the same file.) To not depend on that dummy value use a local #define instead. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-17watchdog: pcwd_usb: overflow in usb_pcwd_send_command()Dan Carpenter
We changed "buf" from being an array of 6 chars to being a pointer this sizeof(buf) needs to be updated as well. Fixes: 2ddb8089a7e5 ('watchdog: pcwd_usb: Use allocated buffer for usb_control_msg') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-17watchdog: rt2880_wdt: fix return value check in rt288x_wdt_probe()Wei Yongjun
In case of error, the function devm_request_and_ioremap() returns NULL pointer not ERR_PTR(). Fix it by using devm_ioremap_resource() instead of devm_request_and_ioremap(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-17watchdog: watchdog_core: Fix a trivial typoSachin Kamat
Fixed a trivial typo. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-11-17watchdog: dw: Enable OF support for DW watchdog timerDinh Nguyen
Add device tree support to the DW watchdog timer. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Pavel Machek <pavel@denx.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Viresh Kumar <viresh.linux@gmail.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: devicetree@vger.kernel.org Cc: linux-watchdog@vger.kernel.org
2013-11-17watchdog: Get rid of MODULE_ALIAS_MISCDEV statementsJean Delvare
I just can't find any value in MODULE_ALIAS_MISCDEV(WATCHDOG_MINOR) and MODULE_ALIAS_MISCDEV(TEMP_MINOR) statements. Either the device is enumerated and the driver already has a module alias (e.g. PCI, USB etc.) that will get the right driver loaded automatically. Or the device is not enumerated and loading its driver will lead to more or less intrusive hardware poking. Such hardware poking should be limited to a bare minimum, so the user should really decide which drivers should be tried and in what order. Trying them all in arbitrary order can't do any good. On top of that, loading that many drivers at once bloats the kernel log. Also many drivers will stay loaded afterward, bloating the output of "lsmod" and wasting memory. Some modules (cs5535_mfgpt which gets loaded as a dependency) can't even be unloaded! If defining char-major-10-130 is needed then it should happen in user-space. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Zwane Mwaikambo <zwane@arm.linux.org.uk> Cc: Jim Cromie <jim.cromie@gmail.com>
2013-11-17watchdog: ts72xx_wdt: Propagate return value from timeout_to_regvalGuenter Roeck
timeout_to_regval() returns a valid error code. Might as well use it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
