path: root/drivers/watchdog
2012-02-09tegra: watchdog: add enable/disable ioctlXin Xie
Signed-off-by: Xin Xie <xxie@nvidia.com> Reviewed-on: http://git-master/r/70702 (cherry picked from commit 50992cf718c37882d90e2b781fbe3f01b4997df8) Reviewed-on: http://git-master/r/77928 (cherry picked from commit a51315ad482758e53a75096be0415ca9b49b9483) Change-Id: I22389cfc7010937dc60c5b1aa4b59c4992f9906b Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Reviewed-on: http://git-master/r/80003 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-02-09tegra: watchdog: improve Kconfig descriptionXin Xie
Signed-off-by: Xin Xie <xxie@nvidia.com> Reviewed-on: http://git-master/r/70625 (cherry picked from commit 90add398c43bb111903015bb6a3cd57a8d62262f) Reviewed-on: http://git-master/r/77926 (cherry picked from commit 4a781c10f2b302f3b467b69060028f9c3b2f9774) Change-Id: Ia2b4935896a44d1717e20693e26a244c6f556c98 Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com> Reviewed-on: http://git-master/r/79999 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-01-30tegra: wdt: Add KEEPALIVE function to WDT driverKamal Kannan Balagopalan
Add KEEPALIVE functionality to Tegra WDT driver for use by user space applications. Bug 887733 Reviewed-on: http://git-master/r/77135 Change-Id: I966371bc5db34416de08c8dc2af9069b4bd34c5d Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/77750 Reviewed-by: Automatic_Commit_Validation_User
2012-01-11watchdog: hpwdt: Changes to handle NX secure bit in 32bit pathMingarelli, Thomas
commit e67d668e147c3b4fec638c9e0ace04319f5ceccd upstream. This patch makes use of the set_memory_x() kernel API in order to make necessary BIOS calls to source NMIs. This is needed for SLES11 SP2 and the latest upstream kernel as it appears the NX Execute Disable has grown in its control. Signed-off by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I118282df5d0a473c72f5609a71a5cb25e86ea416 Reviewed-on: http://git-master/r/74199 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2011-11-30gcov-kernel: Add GCOV_KERNEL := y to MakefilesJuha Tukkinen
These changes have no effect if CONFIG_GCOV_KERNEL is not set in defconfig. It is easier to trigger GCOV for kernel if this patch is in by only setting the before mentioned flag. Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-on: http://git-master/r/62999 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
2011-11-30tegra:watchdog: Change timer src to timer10 for watchdog.vdumpa
Fix wdt resource definition issue either. Bug 790458 Original-Change-Id: I7c80d6c243c42a0e632603dfcc255b70995358b2 Reviewed-on: http://git-master/r/20646 Reviewed-by: Krishna Reddy <vdumpa@nvidia.com> Tested-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> Original-Change-Id: I9897fb6614d75508bd0ffd6e866acf27a24a0cb5 Rebase-Id: R165f408464819298bdcc1f0b677c50b46071be90
2011-11-30tegra:watchdog: Use new watchdog controller.vdumpa
Use new watch dog controller for CONFIG_ARCH_TEGRA_3x_SOC. Bug 790458 Original-Change-Id: I43975a2794f44f612a5f16674cd674aeebe4e6be Reviewed-on: http://git-master/r/19715 Reviewed-by: Krishna Reddy <vdumpa@nvidia.com> Tested-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> Original-Change-Id: Ic8c9907998a2ab1777ea2b00f1acceb6d66c10e5 Rebase-Id: Ra0b9af5a0642fab2d13816f04c0c340ea42a45c8
2011-11-30watchdog: tegra_wdt: fix WDT open() kernel panicXin Xie
Opening the Tegra WDT device from user space is causing the kernel panic. It is found that the device file private data pointer is passing incorrectly in the orignal code. bug 786885 Original-Change-Id: I4646b02c5a804c07d05ba01e35034408cc8e3e4e Reviewed-on: http://git-master/r/23629 Reviewed-by: Xin Xie <xxie@nvidia.com> Tested-by: Xin Xie <xxie@nvidia.com> Reviewed-by: Varun Colbert <vcolbert@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com> Rebase-Id: Ra37e36461d02b1482bcb815dc554104cf552544d
2011-11-30watchdog: tegra_wdt: give time for spinlock lockup detection to workJP Abgrall
To allow the spinlock lockup detection to actually trigger after 60 seconds, the tegra_wdt heartbeat needs to be longer than that. Bumping it to 120sec, as at the 50% marker the watchdog takes an interrupt. Change-Id: I099fd7720d65c0e2050fa91161e30485fe84a1ed Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30watchdog: tegra_wdt: Several changes to watchdog driverDmitriy Gruzman
Fix not re-enabling watchdog resume if it was enabled in probe Add clearing watchdog interrupt in probe Remove tegra_wdt_set_timeout Change-Id: I8fdbb6da3eda64a85a73ed85ab979a5ee0261c37 Signed-off-by: Dmitriy Gruzman <dmitriy.gruzman@motorola.com>
2011-11-30watchdog: tegra_wdt: Several changes to watchdog driverRebecca Schultz Zavin
Add a config option to enable the watchdog driver from probe Reduce the default timeout to 30 seconds Read the reset reason and print a messge if the last reboot was due to watchdog reset Change-Id: I7500ef236089b06ffcff3d8e7d86a5b9060b59cb Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
2011-11-30watchdog: add tegra_wdt driverGary King
add a driver for the hardware watchdog timer embedded in NVIDIA Tegra SoCs Change-Id: I45bc829f26f350143d5a07e1f4ddc46d24f3a54c Signed-off-by: Gary King <gking@nvidia.com>
2011-09-20watchdog: Initconst section fixes for watchdogAndi Kleen
Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-09-20watchdog: lantiq: fix watchdogs timeout handlingJohn Crispin
The enable function was using the global timeout variable for local operations. This resulted in the value of the global variable being corrupted, thus breaking the code. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: linux-watchdog@vger.kernel.org Cc: linux-mips@linux-mips.org
2011-09-20watchdog: hpwdt: prevent multiple "NMI occurred" messagesNaga Chumbalkar
On platforms with no iCRU support don't print two, (possibly conflicting), "NMI occurred" messages when the firmware is unable to source the NMI. Please note that one of the enhancements to the v1.3.0 hpwdt driver is to panic and allow KDUMP to succeed even on NMIs that are unknown to the platform firmware. Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Reviewed-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-09-20watchdog: WatchDog Timer Driver Core - use passed watchdog_deviceH Hartley Sweeten
Use the passed watchdog_device instead of the static global variable when testing and setting the status in watchdog_ping, watchdog_start, and watchdog_stop. Note that the callers of these functions are actually passing the static global variable. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-08-02watchdog: Cleanup WATCHDOG_CORE help textJosh Boyer
The newly added WATCHDOG_CORE option is a bool, but the help text suggests it can be built as a module. Fix it up. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-08-02watchdog: Fix POST failure on ASUS P5N32-E SLI and similar boardsMart Gerrits
At present the module does not unset the NO_REBOOT bit upon shutdown, this causes the BIOS to fail the POST once and reset. During the next boot it displays the following error message: ***** Warning: System BOOT Fail ***** Your system last boot fail or POST interrupted. Please enter setup to load default and reboot again. Press F1 to continue, DEL to enter SETUP With this patch the NO_REBOOT flag will be unset on shutdown and thus stop this failure from occurring. Tested on 'ASUS P5N32-E SLI with BIOS revision 1801' and 'ASUS P5N32-E SLI PLUS with BIOS revision 1502'. Signed-off-by: Mart Gerrits <mart1987@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-08-02watchdog: shwdt: fix usage of mod_timerDavid Engraf
Fix the usage of mod_timer() and make the driver usable. mod_timer() must be called with an absolute timeout in jiffies. The old implementation used a relative timeout thus the hardware watchdog was never triggered. Signed-off-by: David Engraf <david.engraf@sysgo.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Wim Van sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@kernel.org>
2011-07-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-watchdog: (25 commits) watchdog: WatchDog Timer Driver Core - Add minimum and max timeout watchdog: WatchDog Timer Driver Core - Add ioctl call watchdog: WatchDog Timer Driver Core - Add nowayout feature watchdog: WatchDog Timer Driver Core - Add Magic Close feature watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctl watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctl watchdog: WatchDog Timer Driver Core - Add basic ioctl functionality watchdog: WatchDog Timer Driver Core - Add basic framework watchdog: hpwdt: add next gen HP servers watchdog: it8712f_wdt.c: improve includes watchdog: at91sam9/wdt: move register header to drivers watchdog: Add Xilinx watchdog timer driver watchdog: remove empty pm-functions watchdog: sp805: Flush posted writes in enable/disable. watchdog: sp805: Don't write 0 to the load value register. watchdog: imx2_wdt: add device tree probe support watchdog: s3c2410: Add support for device tree based probe watchdog: mpcore_wdt: Add suspend/resume support. watchdog: mtx1-wdt: use dev_{err,info} instead of printk() ...
2011-07-28watchdog: WatchDog Timer Driver Core - Add minimum and max timeoutWim Van Sebroeck
Add min_timeout (minimum timeout) and max_timeout values so that the framework can check if the new timeout value is between the minimum and maximum timeout values. If both values are 0, then the framework will leave the check for the watchdog device driver itself. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add ioctl callWim Van Sebroeck
Add support for extra ioctl calls by adding a ioctl watchdog operation. This operation will be called before we do our own handling of ioctl commands. This way we can override the internal ioctl command handling and we can also add extra ioctl commands. The ioctl watchdog operation should return the appropriate error codes or -ENOIOCTLCMD if the ioctl command should be handled through the internal ioctl handling of the framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add nowayout featureWim Van Sebroeck
Add support for the nowayout feature to the WatchDog Timer Driver Core framework. This feature prevents the watchdog timer from being stopped. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add Magic Close featureWim Van Sebroeck
Add support for the Magic Close feature to the WatchDog Timer Driver Core framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add WDIOC_SETTIMEOUT and ↵Wim Van Sebroeck
WDIOC_GETTIMEOUT ioctl This part add's the WDIOC_SETTIMEOUT and WDIOC_GETTIMEOUT ioctl functionality to the WatchDog Timer Driver Core framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add WDIOC_SETOPTIONS ioctlWim Van Sebroeck
This part add's the WDIOC_SETOPTIONS ioctl functionality to the WatchDog Timer Driver Core framework. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add WDIOC_KEEPALIVE ioctlWim Van Sebroeck
This part add's the WDIOC_KEEPALIVE ioctl functionality to the WatchDog Timer Driver Core framework. Please note that the WDIOF_KEEPALIVEPING bit has to be set in the watchdog_info options field. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add basic ioctl functionalityWim Van Sebroeck
This part add's the basic ioctl functionality to the WatchDog Timer Driver Core framework. The supported ioctl call's are: WDIOC_GETSUPPORT WDIOC_GETSTATUS WDIOC_GETBOOTSTATUS Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: WatchDog Timer Driver Core - Add basic frameworkWim Van Sebroeck
The WatchDog Timer Driver Core is a framework that contains the common code for all watchdog-driver's. It also introduces a watchdog device structure and the operations that go with it. This is the introduction of this framework. This part supports the minimal watchdog userspace API (or with other words: the functionality to use /dev/watchdog's open, release and write functionality as defined in the simplest watchdog API). Extra functionality will follow in the next set of patches. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-07-28watchdog: hpwdt: add next gen HP serversThomas Mingarelli
This patch is required to enable hpwdt to work on next generation HP servers with iLO. Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26watchdog: it8712f_wdt.c: improve includesWim Van Sebroeck
remove unneeded pci.h include. and include ioport.h to avoid build errors for the region functions. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: at91sam9/wdt: move register header to driversJean-Christophe Plagniol-Villard
move register header to drivers Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: Add Xilinx watchdog timer driverAlejandro Cabrera
Watchdog timer device driver for Xilinx xps_timebase_wdt compatible ip cores. It takes watchdog timer configuration from device tree and it needs that its parent has defined the property "clock-frecuency". It is compatible with watchdog timer kernel API, so user apps like watchdogd may talk with it. Signed-off-by: Alejandro Cabrera <aldaya@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: remove empty pm-functionsWolfram Sang
While checking what watchdog drivers usually do in suspend/resume to spot common behaviour for the watchdog framework, I found these drivers which do nothing but add some cruft. Remove it, it is superfluous. New approaches should probably be done with pm_ops anyway. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: sp805: Flush posted writes in enable/disable.Nick Bowler
There are no reads in these functions, so if MMIO writes are posted, the writes in enable/disable may not have completed by the time these functions return. If the functions run from different CPUs, it's in theory possible for the writes to be interleaved, which would be disastrous for this driver. At the very least, we need an mmiowb() before releasing the lock, but since it seems desirable for the watchdog timer to be actually stopped or reset when these functions return, read the lock register to force the writes out. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: sp805: Don't write 0 to the load value register.Nick Bowler
At least on the Versatile Express' V2M, calling wdt_disable followed by wdt_enable, for instance by running the following sequence: echo V > /dev/watchdog; echo V > /dev/watchdog results in an immediate reset. The wdt_disable function writes 0 to the load register; while the watchdog interrupts are disabled at this point, this special value is defined to trigger an interrupt immediately. It appears that in this instance, the reset happens when the interrupts are subsequently enabled by wdt_enable. Putting in a short delay after writing a new load value in wdt_enable solves the issue, but it seems cleaner to simply never write 0 to the load register at all: according to the hardware docs, writing 0 to the control register suffices to stop the counter, and the write of 0 to the load register is questionable anyway since this register resets to 0xffffffff. Signed-off-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-26watchdog: imx2_wdt: add device tree probe supportShawn Guo
Adds device tree probe support for imx2_wdt driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: s3c2410: Add support for device tree based probeThomas Abraham
This patch adds the of_match_table to enable s3c2410-wdt driver to be probed when watchdog device node is found in the device tree. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: mpcore_wdt: Add suspend/resume support.Peter Fordham
Add support for suspend and resume to the MPCore watchdog driver. Signed-off-by: Peter Fordham <peter.fordham@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: mtx1-wdt: use dev_{err,info} instead of printk()Florian Fainelli
use dev_{err,info} instead of printk(KERN_{ERR,INFO} ...) Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: i.MX: use IMX_HAVE_PLATFORM_IMX2_WDT to depend onSascha Hauer
The i.MX architecture provides IMX_HAVE_PLATFORM_* macros to signal that a selected SoC supports a certain hardware. Use them instead of depending on ARCH_* directly. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: linux-watchdog@vger.kernel.org
2011-07-22watchdog: add support for the Synopsys DesignWare WDTJamie Iles
The Synopsys DesignWare watchdog is found in several ARM based systems and provides a choice of 16 timeout periods depending on the clock input. The watchdog cannot be disabled once started. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: pc87413_wdt: Cleanup pc87413 watchdog driver to useJonathan McDowell
Inspired by Nat Gurumoorthy's recent patches for cleaning up the it87 drivers to use request_muxed_region for accessing the SuperIO area on these chips, and the fact I have a GPIO driver for the pc8741x basically ready for submission, here is a patch to cleanup the pc87413 watchdog driver to use request_muxed_region for accessing the SuperIO area. It also pulls out the details about the SWC IO area on initial driver load, and properly does a request_region for that area - there's no requirement to touch the SuperIO area after doing the initial watchdog enable and IO base retrieval. While I have hardware with a pc87413 on it it is not wired in a way that allows the watchdog to reboot the machine, so I have not been able to fully test these changes - I have checked that the driver correctly initialises itself still and requests the SWC io region ok. Signed-Off-By: Jonathan McDowell <noodles@earth.li> Signed-Off-By: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: iTCO_wdt: clean-up PCI device ID'sWim Van Sebroeck
Clean up of the iTCO_wdt PCI device ID's. Own macro is replaced by the PCI_VDEVICE macro. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-22watchdog: Use "request_muxed_region" in it87 watchdog driversNat Gurumoorthy
Changes the it87 watchdog drivers to use "request_muxed_region". Serialize access to the hardware by using "request_muxed_region" macro defined by Alan Cox. Call to this macro will hold off the requestor if the resource is currently busy. The use of the above macro makes it possible to get rid of spinlocks in it8712f_wdt.c and it87_wdt.c watchdog drivers. This also greatly simplifies the implementation of it87_wdt.c driver. "superio_enter" will return an error if call to "request_muxed_region" fails. Rest of the code change is to ripple an error return from superio_enter to the top level. Signed-off-by: Nat Gurumoorthy <natg@google.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-07-17watchdog: hpwdt depends on PCIRandy Dunlap
hpwdt is a PCI driver so it should depend on PCI. Fixes these build errors: drivers/watchdog/hpwdt.c:762: error: implicit declaration of function 'pci_iomap' drivers/watchdog/hpwdt.c:762: warning: assignment makes pointer from integer without a cast drivers/watchdog/hpwdt.c:797: error: implicit declaration of function 'pci_iounmap' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Thomas Mingarelli <thomas.mingarelli@hp.com>
2011-07-16watchdog: fix hpwdt Kconfig regression in 3.0-rcOlaf Hering
Remove Kconfig regression caused by commit a4616153deae053b29a2b7dd9ec4b2a225accfc5 "watchdog: hpwdt: build hpwdt as module by default with NMI_DECODING enabled" With the above change applied, hpwdt will be enabled unconditionally by just entering the Watchdog subscreen in menuconfig. Since this driver is not essential to boot any box it should remain disabled until it gets manually enabled, just like all other drivers. Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Tony Camuso <tcamuso@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2011-06-28watchdog: update author email for at32ap700x_wdtHans-Christian Egtvedt
This patch updates the email address of the at32ap700x_wdt driver supported by me to an email account I will use on a more regular basis in the future. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-06-28watchdog: gef_wdt: fix MODULE_ALIASAxel Lin
Remove the space between "platform:" prefix and the driver name. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
