This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
[ Upstream commit c04571251b3d842096f1597f5d4badb508be016d ]
The ast2600 no longer uses bit 4 in the control register to indicate a
1MHz clock (It now controls whether this watchdog is reset by a SOC
reset). This means we do not want to set it. It also does not need to be
set for the ast2500, as it is read-only on that SoC.
The comment next to the clock rate selection wandered away from where it
was set, so put it back next to the register setting it's describing.
Fixes: b3528b487448 ("watchdog: aspeed: Add support for AST2600")
Signed-off-by: Joel Stanley <joel@jms.id.au>
Reviewed-by: Cédric Le Goater <clg@kaod.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Link: https://lore.kernel.org/r/20191108032905.22463-1-joel@jms.id.au
Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
commit 8632944841d41a36d77dd1fa88d4201b5291100f upstream.
WDD value must be always set to max (0xFFF) otherwise the hardware
block will reset the board on the first ping of the watchdog.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit 2c77734642d52448aca673e889b39f981110828b ]
The left time value is wrong when we get it by sysfs. The left time value
should be equal to preset timeout value minus elapsed time value. According
to the Meson-GXB/GXL datasheets which can be found at [0], the timeout value
is saved to BIT[0-15] of the WATCHDOG_TCNT, and elapsed time value is saved
to BIT[16-31] of the WATCHDOG_TCNT.
[0]: http://linux-meson.com
Fixes: 683fa50f0e18 ("watchdog: Add Meson GXBB Watchdog Driver")
Signed-off-by: Xingyu Chen <xingyu.chen@amlogic.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
[ Upstream commit 57cbf0e3a0fd48e5ad8f3884562e8dde4827c1c8 ]
The watchdog controller on NCT6796D, NCT6797D, and NCT6798D is compatible
with the wtachdog controller on other Nuvoton chips.
Reviewed-by: Wim Van Sebroeck <wim@linux-watchdog.org>
[ Upstream commit b3528b4874480818e38e4da019d655413c233e6a ]
The ast2600 can be supported by the same code as the ast2500.
Signed-off-by: Ryan Chen <ryan_chen@aspeedtech.com>
Link: https://lore.kernel.org/r/20190819051738.17370-3-joel@jms.id.au
commit 144783a80cd2cbc45c6ce17db649140b65f203dd upstream.
Converting from ms to s requires dividing by 1000, not multiplying. So
this is currently taking the smaller of new_timeout and 1.28e8,
i.e. effectively new_timeout.
The driver knows what it set max_hw_heartbeat_ms to, so use that
value instead of doing a division at run-time.
FWIW, this can easily be tested by booting into a busybox shell and
doing "watchdog -t 5 -T 130 /dev/watchdog" - without this patch, the
watchdog fires after 130&127 == 2 seconds.
Fixes: b07e228eee69 "watchdog: imx2_wdt: Fix set_timeout for big timeout values"
Cc: stable@vger.kernel.org # 5.2 plus anything the above got backported to
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Link: https://lore.kernel.org/r/20190812131356.23039-1-linux@rasmusvillemoes.dk
scfw think 'new_pretimeout' as the time stamp from now, not
the time before watchdog timeout which is different with kernel
define. Convert it to scfw's format.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Reviewed-by: Anson Huang <anson.huang@nxp.com>
(cherry picked from commit 674332ac12ddf593d89e87517573b31be2bbead3)
[ Upstream commit 215e06f0d18d5d653d6ea269e4dfc684854d48bf ]
The commit 5e6acc3e678e ("bcm2835-pm: Move bcm2835-watchdog's DT probe
to an MFD.") broke module autoloading on Raspberry Pi. So add a
module alias this fix this.
Signed-off-by: Stefan Wahren <wahrenst@gmx.net>
[ Upstream commit a223770bfa7b6647f3a70983257bd89f9cafce46 ]
CONFIG_WATCHDOG_PRETIMEOUT_GOV build symbol adds watchdog_pretimeout.o
object to watchdog.o, the latter is compiled only if CONFIG_WATCHDOG_CORE
is selected, so it rightfully makes sense to add it as a dependency.
The change fixes the next compilation errors, if CONFIG_WATCHDOG_CORE=n
and CONFIG_WATCHDOG_PRETIMEOUT_GOV=y are selected:
drivers/watchdog/pretimeout_noop.o: In function `watchdog_gov_noop_register':
drivers/watchdog/pretimeout_noop.c:35: undefined reference to `watchdog_register_governor'
drivers/watchdog/pretimeout_noop.o: In function `watchdog_gov_noop_unregister':
drivers/watchdog/pretimeout_noop.c:40: undefined reference to `watchdog_unregister_governor'
drivers/watchdog/pretimeout_panic.o: In function `watchdog_gov_panic_register':
drivers/watchdog/pretimeout_panic.c:35: undefined reference to `watchdog_register_governor'
drivers/watchdog/pretimeout_panic.o: In function `watchdog_gov_panic_unregister':
drivers/watchdog/pretimeout_panic.c:40: undefined reference to `watchdog_unregister_governor'
Reported-by: Kuo, Hsuan-Chi <hckuo2@illinois.edu>
Fixes: ff84136cb6a4 ("watchdog: add watchdog pretimeout governor framework")
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
[ Upstream commit b07e228eee69601addba98b47b1a3850569e5013 ]
The documentated behavior is: if max_hw_heartbeat_ms is implemented, the
minimum of the set_timeout argument and max_hw_heartbeat_ms should be used.
This patch implements this behavior.
Previously only the first 7bits were used and the input argument was
returned.
Signed-off-by: Georg Hofmann <georg@hofmannsweb.com>
The default watchdog action is partition reset now, so no need kernel
to take care. Besides, scfw full test case may set other watchdog
action but kernel may set it back later to default partition reset
which scfw wouldn't expect, so avoid touching watchdog action.
Please modify scfw code in case changing watchdog action to board
reset.
(cherry picked from commit d9189e251995cc91efcac62a8d1c59ff32cdb8dc)
[ Upstream commit e990e12741877e9bfac402ca468f4007a75f6e2a ]
The datasheet says we must stop the timer before changing the clock
divider. This can happen when the restart handler is called while the
watchdog is running.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Change to partiton reset instead of board reset since SCFW is ready
now.
Align timeout value with imx2_wdt.
Since watchdog on i.mx8 is a software watchdog in scfw side, it should be
stopped while kernel enter system suspend if watchdog fired. Otherwise,
unexpected watchdog reset will happen. Restore back if watchdog fired too.
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Add pre_timeout set and notification for i.mx8qm/qxp.
BuildInfo:
- SCFW 36ff24f3, IMX-MKIMAGE 05d3d4a7, ATF 93dd1cc
- U-Boot 2017.03-00684-g28c5243
This watchdog driver is a virtual driver in Linux and call ATF interface
where call SCFW eventually. In SCFW, it's done by SCU timer tick instead
of hardware watchdog.This is why we have to call ATF because such system
resource owned by secure patition.Currently, booard reset happen if not
ping this software watchdog in time in linux side, may change to partition
reboot once SCFW support this feature in the future.
BuildInfo:
- SCFW 93c142a9, IMX-MKIMAGE 2522fd70, ATF f2547fb
- U-Boot 2017.03-00097-gd7599cf
Add wdog nodes in dtsi.
Enable wdog1 for imx8mq evk board.
Enable imx wdt in defconfig.
Correct clock, offset 0x4550 is actually for wdog3.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
If explicit reset fails fallback using the watchdog timeout. We
already have set the timeout counter to 0, but we might need to ping
the watchdog to load the new timeout, if a previous watchdog timeout
value has already been set.
We also decrease the time we spend waiting, to give a chance to log
that the explicit reset failed and that we fallback to watchdog
timeout reset.
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
For i.MX7ULP wdog, when we want to unlock the wdog with 16bit unlock command,
the two unlock command sequence must be write to WDOG_CNT register within 16 bus
clocks, otherwise, system may be reset unexpected. As writel include memory barrier,
if we use writel to send the unlock command, it may take more time than 16 bus clock,
so we should use writel_relaxed to write the unlock command to the CNT register.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Add system reboot for i.MX7ULP. As there is no other way to reboot the
system, so use wdog restart handler to trigger the system reboot.
When resuming from VLLS mode, the wdog will be reset, the first we configure
the wdog, an initial timeout value should be write into the TOVAL register,
otherwise, the wdog will not be initialized successfully.
Add watchdog driver for i.MX7ULP.
[ Upstream commit 44ee54aabfdb3b35866ed909bde3ab01e9679385 ]
The DA9063 watchdog has only one register field to store the timeout value
and to enable the watchdog. The watchdog gets enabled if the value is
not zero. There is no issue if the watchdog is already running but it
leads into problems if the watchdog is disabled.
If the watchdog is disabled and only the timeout value should be prepared
the watchdog gets enabled too. Add a check to get the current watchdog
state and update the watchdog timeout value on hw-side only if the
watchdog is already active.
Fixes: 5e9c16e37608 ("watchdog: Add DA9063 PMIC watchdog driver.")
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
[ Upstream commit 3c829f47e33eb0398a9a14e357a05199a7be0277 ]
If devm_reset_control_get_exclusive() fails, asm9260_wdt_probe()
returns immediately. But clks has been already enabled at that point,
so it is required to disable them or to move the code around.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
[ Upstream commit d2fc8db691bf3197d43b2afb553311a9bf257bff ]
Assert RESET_SYSTEM bit for any reset and set MODE field from reset
type.
The watchdog control register has a RESET_SYSTEM bit that is really
closer to activate a reset, and RESET_SYSTEM_MODE field that chooses
how much to reset.
Before this patch, a node without these optional property would do a
SOC reset, but a node with properties requesting a cpu or SOC reset
would do nothing and a node requesting a system reset would do a
SOC reset.
Fixes: b7f0b8ad25f3 ("drivers/watchdog: ASPEED reference dev tree properties for config")
Signed-off-by: Milton Miller <miltonm@us.ibm.com>
Signed-off-by: Eddie James <eajames@linux.vnet.ibm.com>
[ Upstream commit a81abbb412341e9e3b2d42ed7d310cf71fbb84a8 ]
RK3399 has rst_pulse_length in CONTROL_REG[4:2], determining the length
of pulse to issue for system reset. We shouldn't clobber this value,
because that might make the system reset ineffective. On RK3399, we're
seeing that a value of 000b (meaning 2 cycles) yields an unreliable
(partial?) reset, and so we only fully reset after the watchdog fires a
second time. If we retain the system default (010b, or 8 clock cycles),
then the watchdog reset is much more reliable.
Read-modify-write retains the system value and improves reset
reliability.
It seems we were intentionally clobbering the response mode previously,
to ensure we performed a system reset (we don't support an interrupt
notification), so retain that explicitly.
Signed-off-by: Brian Norris <briannorris@chromium.org>
[ Upstream commit 6ffa3402211acc30e47e691e14d62f3fd065a54e ]
Allow the device tree to specify a watchdog to fallover to
the alternate boot source.
The aspeeed watchdog can set a latch directing flash chip select 0 to
chip select 1, allowing boot from an alternate media if the watchdog
is not reset in time. On the ast2400 bank 1 also goes to flash bank 1,
while on the ast2500 the chip selects are swapped.
Also clear the secondary boot bit during the machine restart operation.
Otherwise, the system will switch to the alternate boot after every
reboot, which is not desired.
Reviewed-by: Joel Stanley <joel@jms.id.au>
[ Upstream commit d66e53649c18377edc08d48901e658e4fd491d46 ]
clk_disable_unprepare() was added to one error path,
but there is another one. The patch makes sure clk is
disabled at the both of them.
[ Upstream commit 93ac3deb7c220cbcec032a967220a1f109d58431 ]
According to SBSA spec v3.1 section 5.3:
All registers are 32 bits in size and should be accessed using
32-bit reads and writes. If an access size other than 32 bits
is used then the results are IMPLEMENTATION DEFINED.
The Generic Watchdog is little-endian
The current code uses readq to read the watchdog compare register
which does a 64-bit access. This fails on ThunderX2 which does not
implement 64-bit access to this register.
Fix this by using lo_hi_readq() that does two 32-bit reads.
Signed-off-by: Jayachandran C <jnair@caviumnetworks.com>
[ Upstream commit 7bd3e7b743956afbec30fb525bc3c5e22e3d475c ]
Watchdog close is "expected" when any byte is 'V' not just the last one.
Writing "V" to the device fails because the last byte is the end of string.
$ echo V > /dev/watchdog
f71808e_wdt: Unexpected close, not stopping watchdog!
Signed-off-by: Igor Pylypiv <igor.pylypiv@gmail.com>
[ Upstream commit f541c09ebfc61697b586b38c9ebaf4b70defb278 ]
According to all published information, the watchdog disable bit for SB800
compatible controllers is bit 1 of PM register 0x48, not bit 2. For the
most part that doesn't matter in practice, since the bit has to be cleared
to enable watchdog address decoding, which is the default setting, but it
still needs to be fixed.
Cc: Zoltán Böszörményi <zboszor@pr.hu>
commit 977f6f68331f94bb72ad84ee96b7b87ce737d89d upstream.
F71808FG_FLAG_WD_EN defines bit position, not a bitmask
Cc: stable <stable@vger.kernel.org>
[ Upstream commit 1bfe8889380890efe4943d125124f5a7b48571b0 ]
The only way of stopping the watchdog is by resetting it.
Add the watchdog op for stopping the device and reset if
a reset line is provided.
At same time WDOG_HW_RUNNING should be remove from dw_wdt_start.
As commented by Guenter Roeck:
dw_wdt sets WDOG_HW_RUNNING in its open function. Result is
that the kref_get() in watchdog_open() won't be executed. But then
kref_put() in close will be called since the watchdog now does stop.
This causes the imbalance.
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: linux-watchdog@vger.kernel.org
commit b1abf6fc49829d89660c961fafe3f90f3d843c55 upstream.
The resource allocation in WDAT watchdog has off-one-by error, it sets
one byte more than the actual end address. This may eventually lead
to unexpected resource conflicts.
Fixes: 058dfc767008 (ACPI / watchdog: Add support for WDAT hardware watchdog)
Cc: 4.9+ <stable@vger.kernel.org> # 4.9+
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
[ Upstream commit 914d65f3f013ba2556c7beec5d3baac7b3292504 ]
If handle_boot_enabled is set to 0, the watchdog driver module use
counter will not be increased and kref_get() will not be called when
registering the watchdog. Subsequently, on open, this does not happen
either because the code believes that it was already done because the
hardware watchdog is marked as running.
We could introduce a state variable to indicate this state, but let's
just increase the module use counter and call kref_get() unconditionally
if the hardware watchdog is running when a driver is registering itself
to keep the code simple.
Fixes: 2501b015313fe ("watchdog: core: add option to avoid early ...")
Cc: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
[ Upstream commit 4bcd615fad6adddc68b058d498b30a9e0e0db77a ]
If a watchdog driver's open function sets WDOG_HW_RUNNING with the
expectation that the watchdog can not be stopped, but then stops the
watchdog anyway in its stop function, kref_get() wil not be called in
watchdog_open(). If the watchdog then stops on close, WDOG_HW_RUNNING
will be cleared and kref_put() will be called, causing a kref imbalance.
As result the character device data structure will be released, which in
turn will cause the system to crash on the next call to watchdog_open().
Fixes: ee142889e32f5 ("watchdog: Introduce WDOG_HW_RUNNING flag")
commit 2b3d89b402b085b08498e896c65267a145bed486 upstream.
Gen8 and prior Proliant systems supported the "CRU" interface
to firmware. This interfaces allows linux to "call back" into firmware
to source the cause of an NMI. This feature isn't fully utilized
as the actual source of the NMI isn't printed, the driver only
indicates that the source couldn't be determined when the call
fails.
With the advent of Gen9, iCRU replaces the CRU. The call back
feature is no longer available in firmware. To be compatible and
not attempt to call back into firmware on system not supporting CRU,
the SMBIOS table is consulted to determine if it is safe to
make the call back or not.
This results in about half of the driver code being devoted
to either making CRU calls or determing if it is safe to make
CRU calls. As noted, the driver isn't really using the results of
the CRU calls.
Furthermore, as a consequence of the Spectre security issue, the
BIOS/EFI calls are being wrapped into Spectre-disabling section.
Removing the call back in hpwdt_pretimeout assists in this effort.
As the CRU sourcing of the NMI isn't required for handling the
NMI and there are security concerns with making the call back, remove
the legacy (pre Gen9) NMI sourcing and the DMI code to determine if
the system had the CRU interface.
Signed-off-by: Jerry Hoemann <jerry.hoemann@hpe.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit aeebc6ba88ba3758ad95467ff6191fabf2074c13 upstream.
The new hpwdt_my_nmi() function is used conditionally, which produces
a harmless warning in some configurations:
drivers/watchdog/hpwdt.c:478:12: error: 'hpwdt_my_nmi' defined but not used [-Werror=unused-function]
This moves it inside of the #ifdef that protects its caller, to silence
the warning.
Fixes: 621174a92851 ("watchdog: hpwdt: Check source of NMI")
Reviewed-by: Jerry Hoemann <jerry.hoemann@hpe.com>
commit 838534e50e2e5c1e644e30ab6cb28da88eb31368 upstream.
Do not claim the NMI (i.e. return NMI_DONE) if the source of
the NMI isn't the iLO watchdog or debug.
commit c42cbe41727a138905a28f8e0b00c147be77ee93 upstream.
This corrects:
commit cce78da76601 ("watchdog: hpwdt: Add check for UEFI bits")
The test on HPE SMBIOS extension type 219 record "Misc Features"
bits for UEFI support is incorrect. The definition of the Misc Features
bits in the HPE SMBIOS OEM Extensions specification (and related
firmware) was changed to use a different pair of bits to
represent UEFI supported. Howerver, a corresponding change
to Linux was missed.
Current code/platform work because the iCRU test is working.
But purpose of cce78da766 is to ensure correct functionality
on future systems where iCRU isn't supported.
commit 0be267255cef64e1c58475baa7b25568355a3816 upstream.
When the watchdog device is suspended, its timeout is set to the maximum
value. During resume, the previously set timeout should be restored.
This does not work at the moment.
The suspend function calls
imx2_wdt_set_timeout(wdog, IMX2_WDT_MAX_TIME);
and resume reverts this by calling
imx2_wdt_set_timeout(wdog, wdog->timeout);
However, imx2_wdt_set_timeout() updates wdog->timeout. Therefore,
wdog->timeout is set to IMX2_WDT_MAX_TIME when we enter the resume
function.
Fix this by adding a new function __imx2_wdt_set_timeout() which
only updates the hardware settings. imx2_wdt_set_timeout() now calls
__imx2_wdt_set_timeout() and then saves the new timeout to
wdog->timeout.
During suspend, we call __imx2_wdt_set_timeout() directly so that
wdog->timeout won't be updated and we can restore the previous value
during resume. This approach makes wdog->timeout different from the
actual setting in the hardware which is usually not a good thing.
However, the two differ only while we're suspended and no kernel code is
running, so it should be ok in this case.
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
commit bc137dfdbec27c0ec5731a89002daded4a4aa1ea upstream.
The first patch above (https://patchwork.kernel.org/patch/9970181/)
makes the oops go away, but it just papers over the problem. The real
problem is that the watchdog core clears WDOG_HW_RUNNING in
watchdog_stop, and the gpio driver fails to set it in its stop
function when it doesn't actually stop it. This means that the core
doesn't know that it now has responsibility for petting the device, in
turn causing the device to reset the system (I hadn't noticed this
because the board I'm working on has that reset logic disabled).
How about this (other drivers may of course have the same problem, I
haven't checked). One might say that ->stop should return an error
when the device can't be stopped, but OTOH this brings parity between
a device without a ->stop method and a GPIO wd that has always-running
set. IOW, I think ->stop should only return an error when an actual
attempt to stop the hardware failed.
From: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
The watchdog framework clears WDOG_HW_RUNNING before calling
->stop. If the driver is unable to stop the device, it is supposed to
set that bit again so that the watchdog core takes care of sending
heart-beats while the device is not open from user-space. Update the
gpio_wdt driver to honour that contract (and get rid of the redundant
clearing of WDOG_HW_RUNNING).
Fixes: 3c10bbde10 ("watchdog: core: Clear WDOG_HW_RUNNING before calling the stop function")
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
commit 24f8d233074badd4c18e4dafd2fb97d65838afed upstream.
Commit da2a68b3eb47 ("watchdog: Enable COMPILE_TEST where possible")
enabled building the Indy watchdog driver when COMPILE_TEST is enabled.
However, the driver makes reference to symbols that are only defined for
certain platforms are selected in the config. These platforms select
SGI_HAS_INDYDOG. Without this, link time errors result, for example
when building a MIPS allyesconfig.
drivers/watchdog/indydog.o: In function `indydog_write':
indydog.c:(.text+0x18): undefined reference to `sgimc'
indydog.c:(.text+0x1c): undefined reference to `sgimc'
drivers/watchdog/indydog.o: In function `indydog_start':
indydog.c:(.text+0x54): undefined reference to `sgimc'
indydog.c:(.text+0x58): undefined reference to `sgimc'
drivers/watchdog/indydog.o: In function `indydog_stop':
indydog.c:(.text+0xa4): undefined reference to `sgimc'
drivers/watchdog/indydog.o:indydog.c:(.text+0xa8): more undefined
references to `sgimc' follow
make: *** [Makefile:1005: vmlinux] Error 1
Fix this by ensuring that CONFIG_INDIDOG can only be selected when the
necessary dependent platform symbols are built in.
Fixes: da2a68b3eb47 ("watchdog: Enable COMPILE_TEST where possible")
Signed-off-by: Matt Redfearn <matt.redfearn@mips.com>
Suggested-by: James Hogan <james.hogan@mips.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.linux-mips.org/pub/scm/ralf/upstream-linus
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for 4.14 for MIPS; below a summary of
the non-merge commits:
CM:
- Rename mips_cm_base to mips_gcr_base
- Specify register size when generating accessors
- Use BIT/GENMASK for register fields, order & drop shifts
- Add cluster & block args to mips_cm_lock_other()
CPC:
- Use common CPS accessor generation macros
- Introduce register modify (set/clear/change) accessors
- Use change_*, set_* & clear_* where appropriate
- Add CM/CPC 3.5 register definitions
- Use GlobalNumber macros rather than magic numbers
- Have asm/mips-cps.h include CM & CPC headers
- Cluster support for topology functions
- Detect CPUs in secondary clusters
CPS:
- Read GIC_VL_IDENT directly, not via irqchip driver
DMA:
- Consolidate coherent and non-coherent dma_alloc code
- Don't use dma_cache_sync to implement fd_cacheflush
FPU emulation / FP assist code:
- Another series of 14 commits fixing corner cases such as NaN
propgagation and other special input values.
- Zero bits 32-63 of the result for a CLASS.D instruction.
- Enhanced statics via debugfs
- Do not use bools for arithmetic. GCC 7.1 moans about this.
- Correct user fault_addr type
Generic MIPS:
- Enhancement of stack backtraces
- Cleanup from non-existing options
- Handle non word sized instructions when examining frame
- Fix detection and decoding of ADDIUSP instruction
- Fix decoding of SWSP16 instruction
- Refactor handling of stack pointer in get_frame_info
- Remove unreachable code from force_fcr31_sig()
- Convert to using %pOF instead of full_name
- Remove the R6000 support.
- Move FP code from *_switch.S to *_fpu.S
- Remove unused ST_OFF from r2300_switch.S
- Allow platform to specify multiple its.S files
- Add #includes to various files to ensure code builds reliable and
without warning..
- Remove __invalidate_kernel_vmap_range
- Remove plat_timer_setup
- Declare various variables & functions static
- Abstract CPU core & VP(E) ID access through accessor functions
- Store core & VP IDs in GlobalNumber-style variable
- Unify checks for sibling CPUs
- Add CPU cluster number accessors
- Prevent direct use of generic_defconfig
- Make CONFIG_MIPS_MT_SMP default y
- Add __ioread64_copy
- Remove unnecessary inclusions of linux/irqchip/mips-gic.h
GIC:
- Introduce asm/mips-gic.h with accessor functions
- Use new GIC accessor functions in mips-gic-timer
- Remove counter access functions from irq-mips-gic.c
- Remove gic_read_local_vp_id() from irq-mips-gic.c
- Simplify shared interrupt pending/mask reads in irq-mips-gic.c
- Simplify gic_local_irq_domain_map() in irq-mips-gic.c
- Drop gic_(re)set_mask() functions in irq-mips-gic.c
- Remove gic_set_polarity(), gic_set_trigger(), gic_set_dual_edge(),
gic_map_to_pin() and gic_map_to_vpe() from irq-mips-gic.c.
- Convert remaining shared reg access, local int mask access and
remaining local reg access to new accessors
- Move GIC_LOCAL_INT_* to asm/mips-gic.h
- Remove GIC_CPU_INT* macros from irq-mips-gic.c
- Move various definitions to the driver
- Remove gic_get_usm_range()
- Remove __gic_irq_dispatch() forward declaration
- Remove gic_init()
- Use mips_gic_present() in place of gic_present and remove
gic_present
- Move gic_get_c0_*_int() to asm/mips-gic.h
- Remove linux/irqchip/mips-gic.h
- Inline __gic_init()
- Inline gic_basic_init()
- Make pcpu_masks a per-cpu variable
- Use pcpu_masks to avoid reading GIC_SH_MASK*
- Clean up mti, reserved-cpu-vectors handling
- Use cpumask_first_and() in gic_set_affinity()
- Let the core set struct irq_common_data affinity
microMIPS:
- Fix microMIPS stack unwinding on big endian systems
MIPS-GIC:
- SYNC after enabling GIC region
NUMA:
- Remove the unused parent_node() macro
R6:
- Constify r2_decoder_tables
- Add accessor & bit definitions for GlobalNumber
SMP:
- Constify smp ops
- Allow boot_secondary SMP op to return errors
VDSO:
- Drop gic_get_usm_range() usage
- Avoid use of linux/irqchip/mips-gic.h
Platform changes:
Alchemy:
- Add devboard machine type to cpuinfo
- update cpu feature overrides
- Threaded carddetect irqs for devboards
AR7:
- allow NULL clock for clk_get_rate
BCM63xx:
- Fix ENETDMA_6345_MAXBURST_REG offset
- Allow NULL clock for clk_get_rate
CI20:
- Enable GPIO and RTC drivers in defconfig
- Add ethernet and fixed-regulator nodes to DTS
Generic platform:
- Move Boston and NI 169445 FIT image source to their own files
- Include asm/bootinfo.h for plat_fdt_relocated()
- Include asm/time.h for get_c0_*_int()
- Allow filtering enabled boards by requirements
- Don't explicitly disable CONFIG_USB_SUPPORT
- Bump default NR_CPUS to 16
JZ4700:
- Probe the jz4740-rtc driver from devicetree
Lantiq:
- Drop check of boot select from the spi-falcon driver.
- Drop check of boot select from the lantiq-flash MTD driver.
- Access boot cause register in the watchdog driver through regmap
- Add device tree binding documentation for the watchdog driver
- Add docs for the RCU DT bindings.
- Convert the fpi bus driver to a platform_driver
- Remove ltq_reset_cause() and ltq_boot_select(
- Switch to a proper reset driver
- Switch to a new drivers/soc GPHY driver
- Add an USB PHY driver for the Lantiq SoCs using the RCU module
- Use of_platform_default_populate instead of __dt_register_buses
- Enable MFD_SYSCON to be able to use it for the RCU MFD
- Replace ltq_boot_select() with dummy implementation.
Loongson 2F:
Malta:
NI 169445:
- Add support for NI 169445 board.
- Only include in 32r2el kernels
Octeon:
- Add support for watchdog of 78XX SOCs.
- Add support for watchdog of CN68XX SOCs.
- Expose support for mips32r1, mips32r2 and mips64r1
- Enable more drivers in config file
- Add support for accessing the boot vector.
- Remove old boot vector code from watchdog driver
- Define watchdog registers for 70xx, 73xx, 78xx, F75xx.
- Make CSR functions node aware.
- Allow access to CIU3 IRQ domains.
- Misc cleanups in the watchdog driver
Omega2+:
- New board, add support and defconfig
Pistachio:
- Enable Root FS on NFS in defconfig
Ralink:
- Add Mediatek MT7628A SoC
- Explicitly request exclusive reset control in the pci-mt7620 PCI driver.
SEAD3:
- Only include in 32 bit kernels by default
VoCore:
- Add VoCore as a vendor t0 dt-bindings
- Add defconfig file"
* '4.14-features' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (167 commits)
MIPS: Refactor handling of stack pointer in get_frame_info
MIPS: Stacktrace: Fix microMIPS stack unwinding on big endian systems
MIPS: microMIPS: Fix decoding of swsp16 instruction
MIPS: microMIPS: Fix decoding of addiusp instruction
MIPS: microMIPS: Fix detection of addiusp instruction
MIPS: Handle non word sized instructions when examining frame
MIPS: ralink: allow NULL clock for clk_get_rate
MIPS: Loongson 2F: allow NULL clock for clk_get_rate
MIPS: BCM63XX: allow NULL clock for clk_get_rate
MIPS: AR7: allow NULL clock for clk_get_rate
MIPS: BCM63XX: fix ENETDMA_6345_MAXBURST_REG offset
mips: Save all registers when saving the frame
MIPS: Add DWARF unwinding to assembly
MIPS: Make SAVE_SOME more standard
MIPS: Fix issues in backtraces
MIPS: jz4780: DTS: Probe the jz4740-rtc driver from devicetree
MIPS: Ci20: Enable RTC driver
watchdog: octeon-wdt: Add support for 78XX SOCs.
watchdog: octeon-wdt: Add support for cn68XX SOCs.
watchdog: octeon-wdt: File cleaning.
mei_cl_device_id are not supposed to change at runtime. All functions
working with mei_cl_device_id provided by <linux/mei_cl_bus.h> work
with const mei_cl_device_id. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
amba_id are not supposed to change at runtime. All functions
working with const amba_id. So mark the non-const structs as const.
i2c_device_id are not supposed to change at runtime. All functions
working with i2c_device_id provided by <linux/i2c.h> work with
const i2c_device_id. So mark the non-const structs as const.
