[ Upstream commit 3aa8b8bbc142eeaac89891de584535ceb7fce405 ]
These files need
#include <linux/mod_devicetable.h>
to compile correctly.
Fixes: ac3167257b9f ("headers: separate linux/mod_devicetable.h from linux/platform_device.h")
Signed-off-by: NeilBrown <neil@brown.name>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org>
[ Upstream commit e990e12741877e9bfac402ca468f4007a75f6e2a ]
The datasheet says we must stop the timer before changing the clock
divider. This can happen when the restart handler is called while the
watchdog is running.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Put syscon device node when it is not needed anymore.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
When the driver is built on 32 bit architectures during compile test,
the linker complains about "__udivdi3" being undefined. We have to use
do_div macro instead of the division operator when dividing u64 value.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
This adds support for the CPU watchdog found on Marvell Armada 37xx
SoCs.
There are 4 counters which can be set as CPU watchdog counters.
This driver uses the second counter (ID 1, counting from 0) as watchdog
counter, and first counter (ID 0) to implement pinging on the second
counter without the need to disable it.
Since counters IDs 2 and 3 are enabled already before even U-Boot
starts, this driver does not use them at all, for example by adding a
device tree property for counter selection.
Tested-by: Miquel Raynal <miquel.raynal@bootlin.com>
mpc8xxx watchdog driver supports the following platforms:
- mpc8xx
- mpc83xx
- mpc86xx
Those three platforms have a 32 bits register which provides the
reason of the last boot, including whether it was caused by the
watchdog.
mpc8xx: Register RSR, bit SWRS (bit 3)
mpc83xx: Register RSR, bit SWRS (bit 28)
mpc86xx: Register RSTRSCR, bit WDT_RR (bit 11)
This patch maps the register as defined in the device tree and updates
wdt.bootstatus based on the value of the watchdog related bit. Then
the information can be retrieved via the WDIOC_GETBOOTSTATUS ioctl.
Hereunder is an example of devicetree for mpc8xx,
the Reset Status Register being at offset 0x288:
WDT: watchdog@0 {
compatible = "fsl,mpc823-wdt";
reg = <0x0 0x10 0x288 0x4>;
On the mpc83xx, RSR is at offset 0x910
On the mpc86xx, RSTRSCR is at offset 0xe0094
Suggested-by: Radu Rendec <radu.rendec@gmail.com>
Tested-by: Christophe Leroy <christophe.leroy@c-s.fr> # On mpc885
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
The RZ/A2 watchdog timer extends the clock source options in order to
allow for longer timeouts.
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
During module install, disable pretimeout if the requested timeout
value is not greater than the minimal pretimeout value that is
supported by hardware.
This makes the module load handling of pretimeout consistent
with the ioctl handling of pretimeout.
Signed-off-by: Jerry Hoemann <jerry.hoemann@hpe.com>
The watchdog controller on NCT6796D, NCT6797D, and NCT6798D is compatible
with the wtachdog controller on other Nuvoton chips.
Reviewed-by: Wim Van Sebroeck <wim@linux-watchdog.org>
mpc8xxx watchdog driver is a platform device drivers, it is
therefore possible to use dev_xxx() messaging rather than pr_xxx()
This callback will provide the current time left.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Instead of doing the ioctl handling manually just use register a
watchdog_device and let the watchdog framework do the ioctl handling.
This also removes the ltq_wdt_bootstatus_set typedef and replaces it
with a structure providing the chip specific functions pointer.
The watchdog_init_timeout() function is now used and the initial timeout
can be provided in device tree.
If the watchdog was already activated it will not be stopped any more,
but the settings from the driver will be used and the watchdog subsystem
will take care.
Some of the names of the bits were confusing to me.
Now the bits share the same prefix as the register they are set on.
The LTQ_WDT_CR_PWL register (bits 26:25) is the pre warning limit and it
does not turn anything on. It has 4 possible divers 1/2, 1/4, 1/8 and
1/16, this drivers only uses 1/16.
The LTQ_WDT_CR_CLKDIV register bits(25:24) is only configuring a clock
divers and do not turn any thing on too, all possible values are valid
dividers.
Using the LTQ_WDT_SR prefix is also wrong these bits are used in the
LTQ_WDT_CR registers, SR is the status register which is read only.
This uses GENMASK where it is a mask and it uses shifts when a value is
written to some bits.
When using watchdog_init_timeout to update the default timeout value,
an error means that there is no "timeout-sec" in the relevant device
tree node.
This should not prevent binding of the driver to the device.
Fixes: 976932e40036 ("watchdog: sama5d4: make use of timeout-secs provided in devicetree")
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
Reviewed-by: Marcus Folkesson <marcus.folkesson@gmail.com>
All typos in comments, should not affect functionality.
This patch updates license to use SPDX-License-Identifier
instead of verbose license text.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
As the only user of iTCO_vendor_pre_keepalive and
iTCO_vendor_pre_set_heartbeat has just been removed, we can delete
these 2 hooks.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Martin Wilck <mwilck@suse.com>
iTCO_vendor_support's option vendorsupport=2 is a gross hack. It
claims to extend the existing iTCO_wdt driver, but in fact programs
a watchdog on a completely different device (Super-I/O) without
requesting its I/O ports and without checking the device ID. This is
an utterly dangerous thing to do.
It also turns out to be unnecessary, because as far as I can tell, the
code in question is basically duplicating what the clean w83627hf_wdt
driver is doing.
My guess is that on these SuperMicro boards which sparkled the
implementation of vendorsupport=2, the watchdog functionality of the
Intel south bridge is not used, and the watchdog feature of some
W83627HF-like Super-I/O chip is used instead. So we should point the
users to the w83627hf_wdt driver.
We want to go into a sane state when unregistering. Currently, it
happens that the watchdog stops when unbinding because of RuntimePM
stopping the core clock. When rebinding, the core clock gets reactivated
and the watchdog fires even though it hasn't been opened by userspace
yet. Strange scenario, yes, but sane state is much preferred anyhow.
watchdog_stop() calls watchdog_update_worker() which needs a valid
wdd->wd_data pointer. So, when unregistering the cdev, clear the
pointers after we call watchdog_stop(), not before.
Fixes: bb292ac1c602 ("watchdog: Introduce watchdog_stop_on_unregister helper")
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Bump version number to reflect recent bug fixes.
Add module parameter "timeout" as an alias to "soft_margin."
This aligns hpwdt usage more closely with other WDT while
retaining backwards compatibility.
Print module parameters when the driver is loaded.
The hwpdt driver is overloaded for handling both the iLO
watchdog and the explicit "Generate NMI to System" virutal
button. Hence NMI handler needs to claim NMI resulting
from the virutal button.
Claim if iLO generated accommodating firmware that might
set wrong bit.
When the pretimeout is specified as a module parameter, the
value should be reflected in hpwdt_dev.pretimeout. The default
(on) case is correct. But, when disabling pretimeout, the value
should be set to zero in hpwdt_dev.
When compiling w/o CONFIG_HPWDT_NMI_DECODING defined, the pretimeout
module parameter is ignored and the value internally will be 0.
Commit cafa0010cd51 ("Raise the minimum required gcc version to 4.6")
recently exposed a brittle part of the build for supporting non-gcc
compilers.
Both Clang and ICC define __GNUC__, __GNUC_MINOR__, and
__GNUC_PATCHLEVEL__ for quick compatibility with code bases that haven't
added compiler specific checks for __clang__ or __INTEL_COMPILER.
This is brittle, as they happened to get compatibility by posing as a
certain version of GCC. This broke when upgrading the minimal version
of GCC required to build the kernel, to a version above what ICC and
Clang claim to be.
Rather than always including compiler-gcc.h then undefining or
redefining macros in compiler-intel.h or compiler-clang.h, let's
separate out the compiler specific macro definitions into mutually
exclusive headers, do more proper compiler detection, and keep shared
definitions in compiler_types.h.
Fixes: cafa0010cd51 ("Raise the minimum required gcc version to 4.6")
Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Suggested-by: Eli Friedman <efriedma@codeaurora.org>
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
git://www.linux-watchdog.org/linux-watchdog
Pull watchdog updates from Wim Van Sebroeck:
- add MEN 16z069 IP-Core driver
- renesas-wdt: add support for the R8A77990 wdt
- stm32_iwdg: Add stm32mp1 support and pclk feature
- sp805_wdt, orion_wdt, sprd_wdt: several improvements
- imx2_wdt, stmp3xxx: switch to SPDX identifier
* tag 'linux-watchdog-4.19-rc1' of git://www.linux-watchdog.org/linux-watchdog:
watchdog: fix dependencies of menz69_wdt.o
watchdog: sp805: Add clock-frequency property
watchdog: add driver for the MEN 16z069 IP-Core
watchdog: sprd_wdt: Remove redundant dev_err call in sprd_wdt_probe()
watchdog: stmp3xxx: Switch to SPDX identifier
watchdog: imx2_wdt: Switch to SPDX identifier
watchdog: sp805: set WDOG_HW_RUNNING when appropriate
watchdog: sp805: add 'timeout-sec' DT property support
dt-bindings: watchdog: Add optional 'timeout-sec' property for sp805
dt-bindings: watchdog: Consolidate SP805 binding docs
watchdog: orion_wdt: Mark watchdog as active when running at probe
watchdog: stm32: add pclk feature for stm32mp1
dt-bindings: watchdog: add stm32mp1 support
dt-bindings: watchdog: renesas-wdt: Add support for the R8A77990 wdt
Currently menz69_wdt.ko has a dependency on MCB or COMPILE_TEST. But
it actually needs symbols exported by MCB so the || COMPILE_TEST is
wrong.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Use clock-frequency property given in _DSD object
of ACPI device to calculate Watchdog rate as binding
clock devices are not available as device tree.
Note: There is no formal review process for _DSD
properties
Signed-off-by: Srinath Mannam <srinath.mannam@broadcom.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Add a driver for the MEN 16z069 Watchdog and Reset Controller IP-Core.
Reviewed-by: Michael Moese <mmoese@suse.de>
There is a error message within devm_ioremap_resource
already, so remove the dev_err call to avoid redundant
error message.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Adopt the SPDX license identifier headers to ease license compliance
management.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
management.
If the watchdog hardware is already enabled during the boot process,
when the Linux watchdog driver loads, it should reset the watchdog and
tell the watchdog framework. As a result, ping can be generated from
the watchdog framework, until the userspace watchdog daemon takes over
control
Signed-off-by: Ray Jui <ray.jui@broadcom.com>
Reviewed-by: Vladimir Olovyannikov <vladimir.olovyannikov@broadcom.com>
Add support for optional devicetree property 'timeout-sec'.
'timeout-sec' is used in the driver if specified in devicetree.
Otherwise, fall back to driver default, i.e., 60 seconds
If the watchdog is fully enabled and running at probe,
mark it as such so the watchdog core can handle it until
the watchdog device is opened.
Signed-off-by: Maxim Kochetkov <fido_max@inbox.ru>
[groeck: Updated subject and description]
This patch adds compatible data to manage pclk clock by
compatible. Adds stm32mp1 support which requires pclk clock.
Signed-off-by: Ludovic Barre <ludovic.barre@st.com>
Acked-by: Alexandre TORGUE <alexandre.torgue@st.com>
At over 4000 #includes, <linux/platform_device.h> is the 9th most
#included header file in the Linux kernel. It does not need
<linux/mod_devicetable.h>, so drop that header and explicitly add
<linux/mod_devicetable.h> to source files that need it.
4146 #include <linux/platform_device.h>
After this patch, there are 225 files that use <linux/mod_devicetable.h>,
for a reduction of around 3900 times that <linux/mod_devicetable.h>
does not have to be read & parsed.
225 #include <linux/mod_devicetable.h>
This patch was build-tested on 20 different arch-es.
It also makes these drivers SubmitChecklist#1 compliant.
Reported-by: kbuild test robot <lkp@intel.com> # drivers/media/platform/vimc/
Reported-by: kbuild test robot <lkp@intel.com> # drivers/pinctrl/pinctrl-u300.c
git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux
Pull MIPS updates from James Hogan:
"These are the main MIPS changes for 4.18.
Rough overview:
- MAINTAINERS: Add Paul Burton as MIPS co-maintainer
- Misc: Generic compiler intrinsics, Y2038 improvements, Perf+MT fixes
- Platform support: Netgear WNR1000 V3, Microsemi Ocelot integrated
switch, Ingenic watchdog cleanups
More detailed summary:
Maintainers:
- Add Paul Burton as MIPS co-maintainer, as I soon won't have access
to much MIPS hardware, nor enough time to properly maintain MIPS on
my own.
Miscellaneous:
- Use generic GCC library routines from lib/
- Add notrace to generic ucmpdi2 implementation
- Rename compiler intrinsic selects to GENERIC_LIB_*
- vmlinuz: Use generic ashldi3
- y2038: Convert update/read_persistent_clock() to *_clock64()
- sni: Remove read_persistent_clock()
- perf: Fix perf with MT counting other threads
- Probe for per-TC perf counters in cpu-probe.c
- Use correct VPE ID for VPE tracing
Minor cleanups:
- Avoid unneeded built-in.a in DTS dirs
- sc-debugfs: Re-use kstrtobool_from_user
- memset.S: Reinstate delay slot indentation
- VPE: Fix spelling "uneeded" -> "Unneeded"
Platform support:
BCM47xx:
- Add support for Netgear WNR1000 V3
- firmware: Support small NVRAM partitions
- Use __initdata for LEDs platform data
Ingenic:
- Watchdog driver & platform code improvements:
- Disable clock after stopping counter
- Use devm_* functions
- Drop module remove function
- Move platform reset code to restart handler in driver
- JZ4740: Convert watchdog instantiation to DT
- JZ4780: Fix watchdog DT node
- qi_lb60_defconfig: Enable watchdog driver
Microsemi:
- Ocelot: Add support for integrated switch
- pcb123: Connect phys to ports"
* tag 'mips_4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux: (30 commits)
MIPS: ptrace: Make FPU context layout comments match reality
MIPS: memset.S: Reinstate delay slot indentation
MIPS: perf: Fix perf with MT counting other threads
MIPS: perf: Use correct VPE ID when setting up VPE tracing
MIPS: perf: More robustly probe for the presence of per-tc counters
MIPS: Probe for MIPS MT perf counters per TC
MIPS: mscc: Connect phys to ports on ocelot_pcb123
MIPS: mscc: Add switch to ocelot
MIPS: JZ4740: Drop old platform reset code
MIPS: qi_lb60: Enable the jz4740-wdt driver
MIPS: JZ4780: dts: Fix watchdog node
MIPS: JZ4740: dts: Add bindings for the jz4740-wdt driver
watchdog: JZ4740: Drop module remove function
watchdog: JZ4740: Register a restart handler
watchdog: JZ4740: Use devm_* functions
watchdog: JZ4740: Disable clock after stopping counter
MIPS: VPE: Fix spelling mistake: "uneeded" -> "unneeded"
MIPS: Re-use kstrtobool_from_user()
MIPS: Convert update_persistent_clock() to update_persistent_clock64()
Every time da9063_wdt_update_timeout() gets called a timeout_to_sel() is
made because the timeout argument of update_timeout() is the raw
register value. Moving the second<->raw-value translation into
da9063_wdt_update_timeout() removes duplicated code.
Signed-off-by: Marco Felsch <m.felsch@pengutronix.de>
Acked-by: Steve Twiss <stwiss.opensource@diasemi.com>
_da9063_wdt_set_timeout() is called by da9063_wdg_set_timeout(),
da9063_wdg_start() and da9063_wdg_probe() but the name expect only to be
called by da9063_wdg_set_timeout(). Rename the function to avoid
misunderstandings.
The patch "watchdog: da9062: use protection delay mechanism from core"
(fb484262) removed the only user of j_time_stamp. This turned into some
leftover functions that are removed with this patch.
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
The watchdog can be enabled in previous steps (e.g. the bootloader). Set
the driver default timeout value (8s) if the watchdog is already running
and the HW_RUNNING flag. So the watchdog core framework will ping the
watchdog till the user space activates the watchdog explicit with the
desired timeout value.
Fixes: 5e9c16e37608 ("watchdog: Add DA9063 PMIC watchdog driver.")
The DA9063 watchdog has only one register field to store the timeout value
and to enable the watchdog. The watchdog gets enabled if the value is
not zero. There is no issue if the watchdog is already running but it
leads into problems if the watchdog is disabled.
If the watchdog is disabled and only the timeout value should be prepared
the watchdog gets enabled too. Add a check to get the current watchdog
state and update the watchdog timeout value on hw-side only if the
watchdog is already active.
If the timeout value is set more than once the DA9063 watchdog triggers
a reset signal which reset the system.
To update the timeout value we have to disable the watchdog, clear the
watchdog counter value and write the new timeout value to the watchdog.
Clearing the counter value is a feature to be on the safe side because the
data sheet doesn't describe the behaviour of the watchdog counter value
after a watchdog disabling-enable-sequence.
The patch is based on Philipp Zabel's previous patch.
There is already a mutex in the watchdog core which serializes
calls to the various API functions.
So the mutex lock "drv->lock" is unnecessary and can be dropped.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Reviewed-by: Johannes Thumshirn <jth@kernel.org>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
On iLO5 going forward we want to return and not claim the NMI, if
the NMI was NOT gnerated by the iLO as a result of the watchdog
timing out or an explicit generate NMI.
The sense of the test in is inverted and prevents hpwdt_pretimeout
from claiming NMIs when it should.
Fixes: a042229a18ac ("watchdog: hpwdt: Update nmi_panic message.")
Add restart handler for SP805 watchdog so that the driver can be
used to reboot the system.
Signed-off-by: Jongsung Kim <neidhard.kim@lge.com>
System restart triggered by watchdog time-out works fine on a Koelsch
board with R-Car M2-W ES2.0.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
