path: root/drivers/watchdog
2009-04-23[ARM] 5460/1: Orion: reduce namespace pollutionNicolas Pitre
Symbols like SOFT_RESET are way too generic to be exported at large. To avoid this, let's move the mbus bridge register defines into a separate file and include it where needed. This affects mach-kirkwood, mach-loki, mach-mv78xx0 and mach-orion5x simultaneously as they all share code in plat-orion which relies on those defines. Some other defines have been moved to narrower scopes, or simply deleted when they had no user. This fixes compilation problem with mpt2sas on the above listed platforms. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-04-08[WATCHDOG] omap_wdt.c: move probe function to .devinit.textUwe Kleine-König
A pointer to omap_wdt_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Alan Cox <alan@redhat.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: George G. Davis <gdavis@mvista.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] ks8695_wdt.c: move probe function to .devinit.textUwe Kleine-König
A pointer to ks8695wdt_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] at91rm9200_wdt.c: move probe function to .devinit.textUwe Kleine-König
A pointer to at91wdt_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Ilpo Jarvinen <ilpo.jarvinen@helsinki.fi> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] remove ARM26 sectionsPaulius Zaleckas
Removes ARM26 sections from Kconfig and Makefile, because ARM26 is long gone. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] orion5x_wdt: Add shutdown callback, use watchdog ping functionThomas Reitmayr
* Added a callback to disable the watchdog on shutdown. * Use a separate ping function to reduce the number of register accesses if the watchdog is already enabled and just needs to be reloaded. * Minor cleanup of function names. Signed-off-by: Thomas Reitmayr <treitmayr@devbase.at> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] i6300esb.c: Restructure initialization of the deviceWim Van Sebroeck
The i6300ESB watchdog should be stopped before userspace has access to the watchdog. So fix this and restructure the initialization sequence into: * See if we have a i6300 device * make sure that we have valid module parameters * Initialize the device * register the /dev/watchdog device so that userspace has access Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] i6300esb.c: Fix the GETSTATUS and GETBOOTSTATUS ioctls.Wim Van Sebroeck
The WDIOC_GETSTATUS and WDIOC_GETBOOTSTATUS should return WDIOF_* flags (and not counter values, ...) Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-08[WATCHDOG] i6300esb.c: CleanupWim Van Sebroeck
Cleanup to keep checkpatch.pl happy. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-04-07powerpc/wdrtas: Update wdrtas_get_interval to use rtas_data_bufMark Nelson
The buffer passed to the ibm,get-system-parameter RTAS call must be in the RMA. To ensure we pass an address in the RMA use rtas_data_buf for the actual RTAS call and then copy the result to value. We can't just make it static because this can be compiled in as a module. Also add the WDRTAS_SP_SPI_LEN so we don't litter '4' throughout the function. Signed-off-by: Mark Nelson <markn@au1.ibm.com> Tested-by: Adrian Reber <adrian@lisas.de> Acked-by: Utz Bacher <utz.bacher@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-03-30Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (fschmd) Add support for the FSC Hades IC hwmon: (fschmd) Add support for the FSC Syleus IC i2c-i801: Instantiate FSC hardware montioring chips dmi: Let dmi_walk() users pass private data hwmon: Define a standard interface for chassis intrusion detection Move the pcf8591 driver to hwmon hwmon: (w83627ehf) Only expose in6 or temp3 on the W83667HG hwmon: (w83627ehf) Add support for W83667HG hwmon: (w83627ehf) Invert fan pin variables logic hwmon: (hdaps) Fix Thinkpad X41 axis inversion hwmon: (hdaps) Allow inversion of separate axis hwmon: (ds1621) Clean up documentation hwmon: (ds1621) Avoid unneeded register access hwmon: (ds1621) Clean up register access hwmon: (ds1621) Reorder code statements
2009-03-30dmi: Let dmi_walk() users pass private dataJean Delvare
At the moment, dmi_walk() lacks flexibility, users can't pass data to the callback function. Add a pointer for private data to make this function more flexible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Roland Dreier <rolandd@cisco.com>
2009-03-30Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/elf.h drivers/i2c/busses/i2c-mpc.c
2009-03-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (422 commits) [ARM] 5435/1: fix compile warning in sanity_check_meminfo() [ARM] 5434/1: ARM: OMAP: Fix mailbox compile for 24xx [ARM] pxa: fix the bad assumption that PCMCIA sockets always start with 0 [ARM] pxa: fix Colibri PXA300 and PXA320 LCD backlight pins imxfb: Fix TFT mode i.MX21/27: remove ifdef CONFIG_FB_IMX imxfb: add clock support mxc: add arch_reset() function clkdev: add possibility to get a clock based on the device name i.MX1: remove fb support from mach-imx [ARM] pxa: build arch/arm/plat-pxa/mfp.c only when PXA3xx or ARCH_MMP defined Gemini: Add support for Teltonika RUT100 Gemini: gpiolib based GPIO support v2 MAINTAINERS: add myself as Gemini architecture maintainer ARM: Add Gemini architecture v3 [ARM] OMAP: Fix compile for omap2_init_common_hw() MAINTAINERS: Add myself as Faraday ARM core variant maintainer ARM: Add support for FA526 v2 [ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.h [ARM] collie: fix two minor formatting nits ...
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] i6300esb.c: start locking [WATCHDOG] i6300esb.c: convert to platform device driver [WATCHDOG] wdt.c: remove #ifdef CONFIG_WDT_501 [WATCHDOG] Fix io.h & uaccess.h includes. [WATCHDOG] More coding-style and trivial clean-up [WATCHDOG] struct file_operations should be const [WATCHDOG] cpwd.c: Coding style - Clean-up [WATCHDOG] hpwdt.c: Add new HP BMC controller. [PATCH 13/13] drivers/watchdog: use USB API functions rather than constants [WATCHDOG] orion5x_wdt: fix compile issue by providing tclk as platform data [WATCHDOG] rc32434_wdt: make sure watchdog is not running at startup [WATCHDOG] rc32434_wdt: add spin_locking [WATCHDOG] rc32434_wdt: add shutdown method [WATCHDOG] rc32434_wdt: add timeout module parameter [WATCHDOG] rc32434_wdt: clean-up driver [WATCHDOG] davinci: convert to ioremap() + io[read|write] [WATCHDOG] w83697ug: add error checking [WATCHDOG] cpwd.c & riowd.c - unlocked_ioctl
2009-03-25[WATCHDOG] i6300esb.c: start lockingWim Van Sebroeck
Change the start function in preparation of the generic watchdog code. Also make sure that locking of the start function is OK. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] i6300esb.c: convert to platform device driverWim Van Sebroeck
Convert the Intel 6300ESB watchdog timer to a platform device driver. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] wdt.c: remove #ifdef CONFIG_WDT_501Alan Cox
Change the wdt.c watchdog driver so that the code is the same for both the WDT500 as the WDT501-P card. The selection of the card is now being done via the module parameter: 'type' instead of the config option CONFIG_WDT_501. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] Fix io.h & uaccess.h includes.Wim Van Sebroeck
Fix following includes: * #include <asm/io.h> should be #include <linux/io.h> * #include <asm/uaccess.h> should be #include <linux/uaccess.h> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] More coding-style and trivial clean-upWim Van Sebroeck
Some more cleaning-up of the watchdog drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] struct file_operations should be constWim Van Sebroeck
Fix following warnings: WARNING: struct file_operations should normally be const Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] cpwd.c: Coding style - Clean-upWim Van Sebroeck
This brings the cpwd.c watchdog driver in line with the kernel's coding style. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] hpwdt.c: Add new HP BMC controller. Thomas Mingarelli
Add the PCI-ID for the upcoming new BMC controller for HP hardware. Signed-off-by: Thomas Mingarelli <Thomas.Mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[PATCH 13/13] drivers/watchdog: use USB API functions rather than constantsJulia Lawall
This set of patches introduces calls to the following set of functions: usb_endpoint_dir_in(epd) usb_endpoint_dir_out(epd) usb_endpoint_is_bulk_in(epd) usb_endpoint_is_bulk_out(epd) usb_endpoint_is_int_in(epd) usb_endpoint_is_int_out(epd) usb_endpoint_num(epd) usb_endpoint_type(epd) usb_endpoint_xfer_bulk(epd) usb_endpoint_xfer_control(epd) usb_endpoint_xfer_int(epd) usb_endpoint_xfer_isoc(epd) In some cases, introducing one of these functions is not possible, and it just replaces an explicit integer value by one of the following constants: USB_ENDPOINT_XFER_BULK USB_ENDPOINT_XFER_CONTROL USB_ENDPOINT_XFER_INT USB_ENDPOINT_XFER_ISOC An extract of the semantic patch that makes these changes is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r1@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) == - \(USB_ENDPOINT_XFER_CONTROL\|0\)) + usb_endpoint_xfer_control(epd) @r5@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) == - \(USB_DIR_IN\|0x80\)) + usb_endpoint_dir_in(epd) @inc@ @@ #include <linux/usb.h> @depends on !inc && (r1||r5)@ @@ + #include <linux/usb.h> #include <linux/usb/...> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] orion5x_wdt: fix compile issue by providing tclk as platform dataThomas Reitmayr
The orion5x-wdt driver is now registered as a platform device and receives the tclk value as platform data. This fixes a compile issue cause by a previously removed define "ORION5X_TCLK". Signed-off-by: Thomas Reitmayr <treitmayr@devbase.at> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Kristof Provost <kristof@sigsegv.be> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Sylver Bruneau <sylver.bruneau@googlemail.com> Cc: Kunihiko IMAI <bak@d2.dion.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-03-25[WATCHDOG] rc32434_wdt: make sure watchdog is not running at startupWim Van Sebroeck
Make sure that the watchdog is not running after loading and before it is started by opening /dev/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] rc32434_wdt: add spin_lockingWim Van Sebroeck
Add spin_locks to prevent races. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] rc32434_wdt: add shutdown methodWim Van Sebroeck
Add shutdown method to the platform driver. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] rc32434_wdt: add timeout module parameterPhil Sutter
The WDT timer ticks quite fast (half of the CPU clock speed, which may be between 198MHz and 330MHz (or 400MHz on newer boards)). Given it's size of 32Bit, the maximum timeout value ranges from about 21s to 43s, depending on the configured CPU clock speed. This patch add's the timeout module parameter and checks that it's not bigger then the maximum timeout for the given clock speed. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] rc32434_wdt: clean-up driverPhil Sutter
Clean-up the rc32434 driver code: - name the platform driver rc32434_wdt_driver - Replace KBUILD_MODNAME ": " with PFX define. - Cleanup include files - Order the ioctl's Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] davinci: convert to ioremap() + io[read|write]Kevin Hilman
Remove davinci platform-specific IO accessor macros in favor of standard ioremap + io[read|write]* functions. Also, convert printk(KERN_ERR ....) into dev_err(...) Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] w83697ug: add error checkingEric Lammerts
I noticed the W83697UG driver tries to register a watchdog even though it already noticed the chip isn't there. WDT driver for the Winbond(TM) W83697UG/UF Super I/O chip initialising. w83697ug/uf WDT: No W83697UG/UF could be found w83697ug/uf WDT: Watchdog already running. Resetting timeout to 60 sec w83697ug/uf WDT: cannot register miscdev on minor=130 (err=-16) Patch propagates the error back to wdt_init(). Signed-off-by: Eric Lammerts <eric@lammerts.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] cpwd.c & riowd.c - unlocked_ioctlWim Van Sebroeck
Switch to unlocked_ioctl Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-24platform driver: fix incorrect use of 'platform_bus_type' with 'struct ↵Ming Lei
device_driver' This patch fixes the bug reported in http://bugzilla.kernel.org/show_bug.cgi?id=11681. "Lots of device drivers register a 'struct device_driver' with the '.bus' member set to '&platform_bus_type'. This is wrong, since the platform_bus functions expect the 'struct device_driver' to be wrapped up in a 'struct platform_driver' which provides some additional callbacks (like suspend_late, resume_early). The effect may be that platform_suspend_late() uses bogus data outside the device_driver struct as a pointer pointer to the device driver's suspend_late() function or other hard to reproduce failures."(Lothar Wassmann) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-19Merge branch 'omap-clks3' into develRussell King
Conflicts: arch/arm/mach-omap2/clock.c
2009-03-19powerpc/86xx: Board support for GE Fanuc's PPC9AMartyn Welch
Support for the PPC9A VME Single Board Computer from GE Fanuc (PowerPC MPC8641D). This is the basic board support for GE Fanuc's PPC9A, a 6U single board computer, based on Freescale's MPC8641D. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-13Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into develRussell King
Conflicts: arch/arm/mach-at91/gpio.c
2009-03-11Merge commit 'origin/master' into nextBenjamin Herrenschmidt
2009-03-09[ARM] pxa: separate definitions from pxa-regs.h and remove it finallyEric Miao
The remaining registers are separated into: - <mach/regs-ost.h> - <mach/regs-rtc.h> - <mach/regs-intc.h> and then we can remove pxa-regs.h completely. Instead of #include this file, let's: 1. include the specific <mach/regs-*.h> with care (if that's absolutely necessary) 2. define the registers in the driver, make cleanly defined API to expose the register access to external with sufficient reason Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-05[WATCHDOG] orion5x_wdt.c: 'ORION5X_TCLK' undeclaredWim Van Sebroeck
orion5x_wdt no longer compiled after the changes in commit ebe35aff883496c07248df82c8576c3b6e84bbbe ("Orion: prepare for runtime-determined timer tick rate"). The tick rate define (ORION5X_TCLK) was removed in favor of a runtime detection. The quick fix is to add the define in the watchdog driver. The fix is not correct for all supported orion5x platforms, but since the supported platforms right now are 133 Mhz and 166 Mhz, it won't be _that_ far off. ;-) A fix that uses the runtime-determined timer tick rate will be applied later. Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Kristof Provost <kristof@sigsegv.be> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Nicolas Pitre <nico@cam.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2009-03-05[WATCHDOG] gef_wdt.c: fsl_get_sys_freq() failure not noticedRoel Kluin
fsl_get_sys_freq() may return -1 when 'soc' isn't found, but in gef_wdt_probe() 'freq' is unsigned, so the test doesn't catch that. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-03-05[WATCHDOG] ks8695_wdt.c: 'CLOCK_TICK_RATE' undeclaredAlexey Dobriyan
On arm-acs5k_tiny: drivers/watchdog/ks8695_wdt.c:68: error: 'CLOCK_TICK_RATE' undeclared (first use in this function) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2009-02-24[WATCHDOG] rc32434_wdt: fix sectionsPhil Sutter
Fix init and exit sections. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2009-02-24[WATCHDOG] rc32434_wdt: fix watchdog driverPhil Sutter
The existing driver code wasn't working. Neither the timeout was set correctly, nor system reset was being triggered, as the driver seemed to keep the WDT alive himself. There was also some unnecessary code. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2009-02-22Merge branch 'linus' into x86/apicIngo Molnar
Conflicts: arch/x86/mach-default/setup.c Semantic conflict resolution: arch/x86/kernel/setup.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-19Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5405/1: ep93xx: remove unused gesbc9312.h header [ARM] 5404/1: Fix condition in arm_elf_read_implies_exec() to set READ_IMPLIES_EXEC [ARM] omap: fix clock reparenting in omap2_clk_set_parent() [ARM] 5403/1: pxa25x_ep_fifo_flush() *ep->reg_udccs always set to 0 [ARM] 5402/1: fix a case of wrap-around in sanity_check_meminfo() [ARM] 5401/1: Orion: fix edge triggered GPIO interrupt support [ARM] 5400/1: Add support for inverted rdy_busy pin for Atmel nand device controller [ARM] 5391/1: AT91: Enable GPIO clocks earlier [ARM] 5390/1: AT91: Watchdog fixes [ARM] 5398/1: Add Wan ZongShun to MAINTAINERS for W90P910 [ARM] omap: fix _omap2_clksel_get_src_field() [ARM] omap: fix omap2_divisor_to_clksel() error return value
2009-02-18Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: arch/powerpc/include/asm/pgtable-ppc32.h
2009-02-14[ARM] 5390/1: AT91: Watchdog fixesAndrew Victor
The recently merged AT91SAM9 watchdog driver uses the AT91SAM9X_WATCHDOG config variable, whereas the original version of the driver (and the platform support code) used AT91SAM9_WATCHDOG. This causes the watchdog platform_device to never be registered, and therefore the driver not to be initialized. This patch: - updates the platform support code to use AT91SAM9X_WATCHDOG. - includes <linux/io.h> to fix compile error (same fix as was applied to at91rm9200_wdt.c) - fixes comment regarding watchdog clock-rates in at91rm9200. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
