path: root/drivers/xen/Kconfig
2014-01-22Merge tag 'stable/for-linus-3.14-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from Konrad Rzeszutek Wilk: "Two major features that Xen community is excited about: The first is event channel scalability by David Vrabel - we switch over from an two-level per-cpu bitmap of events (IRQs) - to an FIFO queue with priorities. This lets us be able to handle more events, have lower latency, and better scalability. Good stuff. The other is PVH by Mukesh Rathor. In short, PV is a mode where the kernel lets the hypervisor program page-tables, segments, etc. With EPT/NPT capabilities in current processors, the overhead of doing this in an HVM (Hardware Virtual Machine) container is much lower than the hypervisor doing it for us. In short we let a PV guest run without doing page-table, segment, syscall, etc updates through the hypervisor - instead it is all done within the guest container. It is a "hybrid" PV - hence the 'PVH' name - a PV guest within an HVM container. The major benefits are less code to deal with - for example we only use one function from the the pv_mmu_ops (which has 39 function calls); faster performance for syscall (no context switches into the hypervisor); less traps on various operations; etc. It is still being baked - the ABI is not yet set in stone. But it is pretty awesome and we are excited about it. Lastly, there are some changes to ARM code - you should get a simple conflict which has been resolved in #linux-next. In short, this pull has awesome features. Features: - FIFO event channels. Key advantages: support for over 100,000 events (2^17), 16 different event priorities, improved fairness in event latency through the use of FIFOs. - Xen PVH support. "It’s a fully PV kernel mode, running with paravirtualized disk and network, paravirtualized interrupts and timers, no emulated devices of any kind (and thus no qemu), no BIOS or legacy boot — but instead of requiring PV MMU, it uses the HVM hardware extensions to virtualize the pagetables, as well as system calls and other privileged operations." (from "The Paravirtualization Spectrum, Part 2: From poles to a spectrum") Bug-fixes: - Fixes in balloon driver (refactor and make it work under ARM) - Allow xenfb to be used in HVM guests. - Allow xen_platform_pci=0 to work properly. - Refactors in event channels" * tag 'stable/for-linus-3.14-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (52 commits) xen/pvh: Set X86_CR0_WP and others in CR0 (v2) MAINTAINERS: add git repository for Xen xen/pvh: Use 'depend' instead of 'select'. xen: delete new instances of __cpuinit usage xen/fb: allow xenfb initialization for hvm guests xen/evtchn_fifo: fix error return code in evtchn_fifo_setup() xen-platform: fix error return code in platform_pci_init() xen/pvh: remove duplicated include from enlighten.c xen/pvh: Fix compile issues with xen_pvh_domain() xen: Use dev_is_pci() to check whether it is pci device xen/grant-table: Force to use v1 of grants. xen/pvh: Support ParaVirtualized Hardware extensions (v3). xen/pvh: Piggyback on PVHVM XenBus. xen/pvh: Piggyback on PVHVM for grant driver (v4) xen/grant: Implement an grant frame array struct (v3). xen/grant-table: Refactor gnttab_init xen/grants: Remove gnttab_max_grant_frames dependency on gnttab_init. xen/pvh: Piggyback on PVHVM for event channels (v2) xen/pvh: Update E820 to work with PVH (v2) xen/pvh: Secondary VCPU bringup (non-bootup CPUs) ...
2014-01-06xen: balloon: enable for ARMIan Campbell
Since c275a57f5ec3 "xen/balloon: Set balloon's initial state to number of existing RAM pages" the balloon driver appears to work fine on ARM as far as I can tell. Prior to that commit it was broken because on ARM RAM doesn't typically start at zero, effectively leaving a big MMIO hole at the start. This would cause the balloon driver to give away all of RAM at start of day, which is rather inconvenient. It was already enabled (or rather not excluded) on ARM64. The c1d15f5c8bc1170dafe16e988e55437245966dfe "xen/balloon: Seperate the auto-translate logic properly (v2)" added in the proper plumbing to work with ARM and PVH type guests. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> [v2: Added the bit about PVH] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-12-19Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply fixes on top of newer things in tree (efi-stub). Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-12-02treewide: Fix typo in KconfigMasanari Iida
Correct spelling typo in Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-10-10xen/arm,arm64: enable SWIOTLB_XENStefano Stabellini
Xen on arm and arm64 needs SWIOTLB_XEN: when running on Xen we need to program the hardware with mfns rather than pfns for dma addresses. Remove SWIOTLB_XEN dependency on X86 and PCI and make XEN select SWIOTLB_XEN on arm and arm64. At the moment always rely on swiotlb-xen, but when Xen starts supporting hardware IOMMUs we'll be able to avoid it conditionally on the presence of an IOMMU on the platform. Implement xen_create_contiguous_region on arm and arm64: for the moment we assume that dom0 has been mapped 1:1 (physical addresses == machine addresses) therefore we don't need to call XENMEM_exchange. Simply return the physical address as dma address. Initialize the xen-swiotlb from xen_early_init (before the native dma_ops are initialized), set xen_dma_ops to &xen_swiotlb_dma_ops. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Changes in v8: - assume dom0 is mapped 1:1, no need to call XENMEM_exchange. Changes in v7: - call __set_phys_to_machine_multi from xen_create_contiguous_region and xen_destroy_contiguous_region to update the P2M; - don't call XENMEM_unpin, it has been removed; - call XENMEM_exchange instead of XENMEM_exchange_and_pin; - set nr_exchanged to 0 before calling the hypercall. Changes in v6: - introduce and export xen_dma_ops; - call xen_mm_init from as arch_initcall. Changes in v4: - remove redefinition of DMA_ERROR_CODE; - update the code to use XENMEM_exchange_and_pin and XENMEM_unpin; - add a note about hardware IOMMU in the commit message. Changes in v3: - code style changes; - warn on XENMEM_put_dma_buf failures.
2013-07-30xen/tmem: do not allow XEN_TMEM on ARM64Stefano Stabellini
tmem is not supported on arm or arm64 yet. Will revert this once the Xen hypervisor supports it. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-05-15xen/tmem: Remove the usage of '[no|]selfballoon' and use ↵Konrad Rzeszutek Wilk
'tmem.selfballooning' bool instead. As the 'tmem' driver is the one that actually sets whether it will use it (or not) so might as well make tmem responsible for this knob. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-05-15xen/tmem: Remove the usage of 'noselfshrink' and use 'tmem.selfshrink' bool ↵Konrad Rzeszutek Wilk
instead. As the 'tmem' driver is the one that actually sets whether it will use it or not so might as well make tmem responsible for this knob. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-05-11Merge tag 'stable/for-linus-3.10-rc0-tag-two' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bug-fixes from Konrad Rzeszutek Wilk: - More fixes in the vCPU PVHVM hotplug path. - Add more documentation. - Fix various ARM related issues in the Xen generic drivers. - Updates in the xen-pciback driver per Bjorn's updates. - Mask the x2APIC feature for PV guests. * tag 'stable/for-linus-3.10-rc0-tag-two' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pci: Used cached MSI-X capability offset xen/pci: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK xen: clear IRQ_NOAUTOEN and IRQ_NOREQUEST xen: mask x2APIC feature in PV xen: SWIOTLB is only used on x86 xen/spinlock: Fix check from greater than to be also be greater or equal to. xen/smp/pvhvm: Don't point per_cpu(xen_vpcu, 33 and larger) to shared_info xen/vcpu: Document the xen_vcpu_info and xen_vcpu xen/vcpu/pvhvm: Fix vcpu hotplugging hanging.
2013-05-08xen: SWIOTLB is only used on x86Arnd Bergmann
Enabling SWIOTLB_XEN on ARM results in build errors because the underlying SWIOTLB is only available on X86: drivers/xen/swiotlb-xen.c: In function 'is_xen_swiotlb_buffer': drivers/xen/swiotlb-xen.c:105:2: error: implicit declaration of function 'mfn_to_local_pfn Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-04-30xen: tmem: enable Xen tmem shim to be built/loaded as a moduleDan Magenheimer
Allow Xen tmem shim to be built/loaded as a module. Xen self-ballooning and frontswap-selfshrinking are now also "lazily" initialized when the Xen tmem shim is loaded as a module, unless explicitly disabled by module parameters. Note runtime dependency disallows loading if cleancache/frontswap lazy initialization patches are not present. If built-in (not built as a module), the original mechanism of enabling via a kernel boot parameter is retained, but this should be considered deprecated. Note that module unload is explicitly not yet supported. [v1: Removed the [CLEANCACHE|FRONTSWAP]_HAS_LAZY_INIT ifdef] [v2: Squashed the xen/tmem: Remove the subsys call patch in] [akpm@linux-foundation.org: fix build (disable_frontswap_selfshrinking undeclared)] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-27xen/acpi-stub: Disable it b/c the acpi_processor_add is no longer called.Konrad Rzeszutek Wilk
With the Xen ACPI stub code (CONFIG_XEN_STUB=y) enabled, the power C and P states are no longer uploaded to the hypervisor. The reason is that the Xen CPU hotplug code: xen-acpi-cpuhotplug.c and the xen-acpi-stub.c register themselves as the "processor" type object. That means the generic processor (processor_driver.c) stops working and it does not call (acpi_processor_add) which populates the per_cpu(processors, pr->id) = pr; structure. The 'pr' is gathered from the acpi_processor_get_info function which does the job of finding the C-states and figuring out PBLK address. The 'processors->pr' is then later used by xen-acpi-processor.c (the one that uploads C and P states to the hypervisor). Since it is NULL, we end skip the gathering of _PSD, _PSS, _PCT, etc and never upload the power management data. The end result is that enabling the CONFIG_XEN_STUB in the build means that xen-acpi-processor is not working anymore. This temporary patch fixes it by marking the XEN_STUB driver as BROKEN until this can be properly fixed. CC: jinsong.liu@intel.com Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-02-19xen/acpi: ACPI cpu hotplugLiu Jinsong
This patch implement real Xen ACPI cpu hotplug driver as module. When loaded, it replaces Xen stub driver. For booting existed cpus, the driver enumerates them. For hotadded cpus, which added at runtime and notify OS via device or container event, the driver is invoked to add them, parsing cpu information, hypercalling to Xen hypervisor to add them, and finally setting up new /sys interface for them. Signed-off-by: Liu Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-02-19xen/acpi: ACPI memory hotplugLiu Jinsong
This patch implements real Xen acpi memory hotplug driver as module. When loaded, it replaces Xen stub driver. When an acpi memory device hotadd event occurs, it notifies OS and invokes notification callback, adding related memory device and parsing memory information, finally hypercall to xen hypervisor to add memory. Signed-off-by: Liu Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-02-19xen/stub: driver for memory hotplugLiu Jinsong
This patch create a file (xen-stub.c) for Xen stub drivers. Xen stub drivers are used to reserve space for Xen drivers, i.e. memory hotplug and cpu hotplug, and to block native drivers loaded, so that real Xen drivers can be modular and loaded on demand. This patch is specific for Xen memory hotplug (other Xen logic can add stub drivers on their own). The xen stub driver will occupied earlier via subsys_initcall (than native memory hotplug driver via module_init and so blocking native). Later real Xen memory hotplug logic will unregister the stub driver and register itself to take effect on demand. Signed-off-by: Liu Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-11-29xen: balloon: allow PVMMU interfaces to be compiled outIan Campbell
The ARM platform has no concept of PVMMU and therefor no HYPERVISOR_update_va_mapping et al. Allow this code to be compiled out when not required. In some similar situations (e.g. P2M) we have defined dummy functions to avoid this, however I think we can/should draw the line at dummying out actual hypercalls. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-10-09ARM: Xen: fix initial build problemsArnd Bergmann
* The XEN_BALLOON code requires the balloon infrastructure that is not getting built on ARM. * The tmem hypercall is not available on ARM * ARMv6 does not support cmpxchg on 16-bit words that are used in the Xen grant table code, so we must ensure that Xen support is only built on ARMv7-only kernels not combined ARMv6/v7 kernels. * sys-hypervisor.c needs to include linux/err.h in order to use the IS_ERR/PTR_ERR/ERR_PTR family of functions. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ian Campbell <ian.campbell@citrix.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: xen-devel@lists.xensource.com
2012-07-19xen/mce: Add mcelog support for Xen platformLiu, Jinsong
When MCA error occurs, it would be handled by Xen hypervisor first, and then the error information would be sent to initial domain for logging. This patch gets error information from Xen hypervisor and convert Xen format error into Linux format mcelog. This logic is basically self-contained, not touching other kernel components. By using tools like mcelog tool users could read specific error information, like what they did under native Linux. To test follow directions outlined in Documentation/acpi/apei/einj.txt Acked-and-tested-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Ke, Liping <liping.ke@intel.com> Signed-off-by: Jiang, Yunhong <yunhong.jiang@intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-07xen/Kconfig: fix Kconfig layoutAndrew Morton
Fit it into 80 columns so that it is readable in menuconfig. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-16Fix typo in various Kconfig fileMasanari Iida
Correct spelling typo in various Kconfig file. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-24xen/acpi: Fix Kconfig dependency on CPU_FREQKonrad Rzeszutek Wilk
The functions: "acpi_processor_*" sound like they depend on CONFIG_ACPI_PROCESSOR but in reality they are exposed when CONFIG_CPU_FREQ=[y|m]. As such update the Kconfig to have this dependency and fix compile issues: ERROR: "acpi_processor_unregister_performance" [drivers/xen/xen-acpi-processor.ko] undefined! ERROR: "acpi_processor_notify_smm" [drivers/xen/xen-acpi-processor.ko] undefined! ERROR: "acpi_processor_register_performance" [drivers/xen/xen-acpi-processor.ko] undefined! ERROR: "acpi_processor_preregister_performance" [drivers/xen/xen-acpi-processor.ko] undefined! Note: We still need the CONFIG_ACPI Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-20xen/acpi-processor: Do not depend on CPU frequency scaling drivers.Konrad Rzeszutek Wilk
With patch "xen/cpufreq: Disable the cpu frequency scaling drivers from loading." we do not have to worry about said drivers loading themselves before the xen-acpi-processor driver. Hence we can remove the default selection (=y if CPU frequency drivers were built-in, or =m if CPU frequency drivers were built as modules), and just select =m for the default case. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-03-14xen/acpi-processor: C and P-state driver that uploads said data to hypervisor.Konrad Rzeszutek Wilk
This driver solves three problems: 1). Parse and upload ACPI0007 (or PROCESSOR_TYPE) information to the hypervisor - aka P-states (cpufreq data). 2). Upload the the Cx state information (cpuidle data). 3). Inhibit CPU frequency scaling drivers from loading. The reason for wanting to solve 1) and 2) is such that the Xen hypervisor is the only one that knows the CPU usage of different guests and can make the proper decision of when to put CPUs and packages in proper states. Unfortunately the hypervisor has no support to parse ACPI DSDT tables, hence it needs help from the initial domain to provide this information. The reason for 3) is that we do not want the initial domain to change P-states while the hypervisor is doing it as well - it causes rather some funny cases of P-states transitions. For this to work, the driver parses the Power Management data and uploads said information to the Xen hypervisor. It also calls acpi_processor_notify_smm() to inhibit the other CPU frequency scaling drivers from being loaded. Everything revolves around the 'struct acpi_processor' structure which gets updated during the bootup cycle in different stages. At the startup, when the ACPI parser starts, the C-state information is processed (processor_idle) and saved in said structure as 'power' element. Later on, the CPU frequency scaling driver (powernow-k8 or acpi_cpufreq), would call the the acpi_processor_* (processor_perflib functions) to parse P-states information and populate in the said structure the 'performance' element. Since we do not want the CPU frequency scaling drivers from loading we have to call the acpi_processor_* functions to parse the P-states and call "acpi_processor_notify_smm" to stop them from loading. There is also one oddity in this driver which is that under Xen, the physical online CPU count can be different from the virtual online CPU count. Meaning that the macros 'for_[online|possible]_cpu' would process only up to virtual online CPU count. We on the other hand want to process the full amount of physical CPUs. For that, the driver checks if the ACPI IDs count is different from the APIC ID count - which can happen if the user choose to use dom0_max_vcpu argument. In such a case a backup of the PM structure is used and uploaded to the hypervisor. [v1-v2: Initial RFC implementations that were posted] [v3: Changed the name to passthru suggested by Pasi Kärkkäinen <pasik@iki.fi>] [v4: Added vCPU != pCPU support - aka dom0_max_vcpus support] [v5: Cleaned up the driver, fix bug under Athlon XP] [v6: Changed the driver to a CPU frequency governor] [v7: Jan Beulich <jbeulich@suse.com> suggestion to make it a cpufreq scaling driver made me rework it as driver that inhibits cpufreq scaling driver] [v8: Per Jan's review comments, fixed up the driver] [v9: Allow to continue even if acpi_processor_preregister_perf.. fails] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-12-16xen: Add privcmd device driverBastian Blank
Access to arbitrary hypercalls is currently provided via xenfs. This adds a standard character device to handle this. The support in xenfs remains for backward compatibility and uses the device driver code. Signed-off-by: Bastian Blank <waldi@debian.org> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-09-29xen: remove XEN_PLATFORM_PCI config optionStefano Stabellini
Xen PVHVM needs xen-platform-pci, on the other hand xen-platform-pci is useless in any other cases. Therefore remove the XEN_PLATFORM_PCI config option and compile xen-platform-pci built-in if XEN_PVHVM is selected. Changes to v1: - remove xen-platform-pci.o and just use platform-pci.o since it is not externally visible anymore. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-08-03xen/self-balloon: Add dependency on tmem.Konrad Rzeszutek Wilk
Without enabling CONFIG_XEN_TMEM we get this: drivers/xen/xen-selfballoon.c:461: undefined reference to `tmem_enabled' Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-25xen/balloon: memory hotplug support for Xen balloon driverDaniel Kiper
Memory hotplug support for Xen balloon driver. It should be mentioned that hotplugged memory is not onlined automatically. It should be onlined by user through standard sysfs interface. Memory could be hotplugged in following steps: 1) dom0: xl mem-max <domU> <maxmem> where <maxmem> is >= requested memory size, 2) dom0: xl mem-set <domU> <memory> where <memory> is requested memory size; alternatively memory could be added by writing proper value to /sys/devices/system/xen_memory/xen_memory0/target or /sys/devices/system/xen_memory/xen_memory0/target_kb on dumU, 3) domU: for i in /sys/devices/system/memory/memory*/state; do \ [ "`cat "$i"`" = offline ] && echo online > "$i"; done Memory could be onlined automatically on domU by adding following line to udev rules: SUBSYSTEM=="memory", ACTION=="add", RUN+="/bin/sh -c '[ -f /sys$devpath/state ] && echo online > /sys$devpath/state'" In that case step 3 should be omitted. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20Merge branch 'stable/xen-pciback-0.6.3' into stable/driversKonrad Rzeszutek Wilk
* stable/xen-pciback-0.6.3: xen/pciback: Have 'passthrough' option instead of XEN_PCIDEV_BACKEND_PASS and XEN_PCIDEV_BACKEND_VPCI xen/pciback: Remove the DEBUG option. xen/pciback: Drop two backends, squash and cleanup some code. xen/pciback: Print out the MSI/MSI-X (PIRQ) values xen/pciback: Don't setup an fake IRQ handler for SR-IOV devices. xen: rename pciback module to xen-pciback. xen/pciback: Fine-grain the spinlocks and fix BUG: scheduling while atomic cases. xen/pciback: Allocate IRQ handler for device that is shared with guest. xen/pciback: Disable MSI/MSI-X when reseting a device xen/pciback: guest SR-IOV support for PV guest xen/pciback: Register the owner (domain) of the PCI device. xen/pciback: Cleanup the driver based on checkpatch warnings and errors. xen/pciback: xen pci backend driver. Conflicts: drivers/xen/Kconfig
2011-07-19xen/pciback: Have 'passthrough' option instead of XEN_PCIDEV_BACKEND_PASS ↵Konrad Rzeszutek Wilk
and XEN_PCIDEV_BACKEND_VPCI .. compile options. This way the user can decide during runtime whether they want the default 'vpci' (virtual pci passthrough) or where the PCI devices are passed in without any BDF renumbering. The option 'passthrough' allows the user to toggle the it from 0 (vpci) to 1 (passthrough). Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: Remove the DEBUG option.Konrad Rzeszutek Wilk
The latter is easily fixed - by the developer compiling the module with -DDEBUG. And during runtime - the loglvl provides quite a lot of useful data. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-19xen/pciback: xen pci backend driver.Konrad Rzeszutek Wilk
This is the host side counterpart to the frontend driver in drivers/pci/xen-pcifront.c. The PV protocol is also implemented by frontend drivers in other OSes too, such as the BSDs. The PV protocol is rather simple. There is page shared with the guest, which has the 'struct xen_pci_sharedinfo' embossed in it. The backend has a thread that is kicked every-time the structure is changed and based on the operation field it performs specific tasks: XEN_PCI_OP_conf_[read|write]: Read/Write 0xCF8/0xCFC filtered data. (conf_space*.c) Based on which field is probed, we either enable/disable the PCI device, change power state, read VPD, etc. The major goal of this call is to provide a Physical IRQ (PIRQ) to the guest. The PIRQ is Xen hypervisor global IRQ value irrespective of the IRQ is tied in to the IO-APIC, or is a vector. For GSI type interrupts, the PIRQ==GSI holds. For MSI/MSI-X the PIRQ value != Linux IRQ number (thought PIRQ==vector). Please note, that with Xen, all interrupts (except those level shared ones) are injected directly to the guest - there is no host interaction. XEN_PCI_OP_[enable|disable]_msi[|x] (pciback_ops.c) Enables/disables the MSI/MSI-X capability of the device. These operations setup the MSI/MSI-X vectors for the guest and pass them to the frontend. When the device is activated, the interrupts are directly injected in the guest without involving the host. XEN_PCI_OP_aer_[detected|resume|mmio|slotreset]: In case of failure, perform the appropriate AER commands on the guest. Right now that is a cop-out - we just kill the guest. Besides implementing those commands, it can also - hide a PCI device from the host. When booting up, the user can specify xen-pciback.hide=(1:0:0)(BDF..) so that host does not try to use the device. The driver was lifted from linux-2.6.18.hg tree and fixed up so that it could compile under v3.0. Per suggestion from Jesse Barnes moved the driver to drivers/xen/xen-pciback. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2011-07-08Merge branch 'xen-tmem-selfballoon-v8' of ↵Konrad Rzeszutek Wilk
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem into stable/drivers * 'xen-tmem-selfballoon-v8' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: tmem: self-ballooning and frontswap-selfshrinking
2011-07-08xen: tmem: self-ballooning and frontswap-selfshrinkingDan Magenheimer
This patch introduces two in-kernel drivers for Xen transcendent memory ("tmem") functionality that complement cleancache and frontswap. Both use control theory to dynamically adjust and optimize memory utilization. Selfballooning controls the in-kernel Xen balloon driver, targeting a goal value (vm_committed_as), thus pushing less frequently used clean page cache pages (through the cleancache code) into Xen tmem where Xen can balance needs across all VMs residing on the physical machine. Frontswap-selfshrinking controls the number of pages in frontswap, driving it towards zero (effectively doing a partial swapoff) when in-kernel memory pressure subsides, freeing up RAM for other VMs. More detail is provided in the header comment of xen-selfballooning.c. Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> [v8: konrad.wilk@oracle.com: set default enablement depending on frontswap] [v7: konrad.wilk@oracle.com: fix capitalization and punctuation in comments] [v6: fix frontswap-selfshrinking initialization] [v6: konrad.wilk@oracle.com: fix init pr_infos; add comments about swap] [v5: konrad.wilk@oracle.com: add NULL to attr list; move inits up to decls] [v4: dkiper@net-space.pl: use strict_strtoul plus a few syntactic nits] [v3: konrad.wilk@oracle.com: fix potential divides-by-zero] [v3: konrad.wilk@oracle.com: add many more comments, fix nits] [v2: rebased to linux-3.0-rc1] [v2: Ian.Campbell@citrix.com: reorganize as new file (xen-selfballoon.c)] [v2: dkiper@net-space.pl: proper access to vm_committed_as] [v2: dkiper@net-space.pl: accounting fixes] Cc: Jan Beulich <JBeulich@novell.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: <xen-devel@lists.xensource.com>
2011-06-17xen: prepare tmem shim to handle frontswapDan Magenheimer
Provide the shim code for frontswap for Xen tmem even if the frontswap patchset is not present yet. (The egg is before the chicken.) Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Konrad Wilk <konrad.wilk@oracle.com>
2011-02-16xen: change xen/[gntdev/gntalloc] to default mStefano Stabellini
When CONFIG_XEN is enabled the gntdev and gntalloc driver will be compiled as a module by default. [v2: Added the fix for the gntalloc driver as well] Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-14xen-gntalloc: Userspace grant allocation driverDaniel De Graaf
This allows a userspace application to allocate a shared page for implementing inter-domain communication or device drivers. These shared pages can be mapped using the gntdev device or by the kernel in another domain. Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-13Merge branch 'stable/gntdev' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/gntdev' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/p2m: Fix module linking error. xen p2m: clear the old pte when adding a page to m2p_override xen gntdev: use gnttab_map_refs and gnttab_unmap_refs xen: introduce gnttab_map_refs and gnttab_unmap_refs xen p2m: transparently change the p2m mappings in the m2p override xen/gntdev: Fix circular locking dependency xen/gntdev: stop using "token" argument xen: gntdev: move use of GNTMAP_contains_pte next to the map_op xen: add m2p override mechanism xen: move p2m handling to separate file xen/gntdev: add VM_PFNMAP to vma xen/gntdev: allow usermode to map granted pages xen: define gnttab_set_map_op/unmap_op Fix up trivial conflict in drivers/xen/Kconfig
2011-01-13Merge branch 'stable/platform-pci-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/platform-pci-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen-platform: Fix compile errors if CONFIG_PCI is not enabled. xen: rename platform-pci module to xen-platform-pci. xen-platform: use PCI interfaces to request IO and MEM resources.
2011-01-12xen-platform: Fix compile errors if CONFIG_PCI is not enabled.Konrad Rzeszutek Wilk
drivers/xen/platform-pci.c:127: error: implicit declaration of function 'pci_request_region' drivers/xen/platform-pci.c:165: error: implicit declaration of function 'pci_release_region' Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-11xen/gntdev: allow usermode to map granted pagesGerd Hoffmann
The gntdev driver allows usermode to map granted pages from other domains. This is typically used to implement a Xen backend driver in user mode. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Signed-off-by: Stefano Stabellini <Stefano.Stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-05xen/xenbus: making backend support modular is too complexJeremy Fitzhardinge
Impact: build fix Making the xenbus backend support a separate module is needlessly complex and causes build failures. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-05xen/xenbus: fixup checkpatch issues in xenbus_probe*Ian Campbell
2011-01-05xen: add backend driver supportIan Campbell
Impact: backend device support Add the basic machinery to support backend drivers. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> [corresponds to 79727b851bac in git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen.git] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-01-05xen: separate out frontend xenbusIan Campbell
Impact: refactor Make a distinct frontend xenbus, in preparation for adding a backend xenbus. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> [corresponds to 2fd433a4188f in git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen.git with adjustments to reflect changes in the code which is moved] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it.Konrad Rzeszutek Wilk
We used to depend on CONFIG_SWIOTLB, but that is disabled by default. So when compiling we get this compile error: arch/x86/xen/pci-swiotlb-xen.c: In function 'pci_xen_swiotlb_detect': arch/x86/xen/pci-swiotlb-xen.c:48: error: lvalue required as left operand of assignment Fix it by actually activating the SWIOTLB library. Reported-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18xen/pci: Request ACS when Xen-SWIOTLB is activated.Konrad Rzeszutek Wilk
It used to done in the Xen startup code but that is not really appropiate. [v2: Update Kconfig with PCI requirement] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-08-12Merge branch 'stable/xen-swiotlb-0.8.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xen-swiotlb-0.8.6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: x86: Detect whether we should use Xen SWIOTLB. pci-swiotlb-xen: Add glue code to setup dma_ops utilizing xen_swiotlb_* functions. swiotlb-xen: SWIOTLB library for Xen PV guest with PCI passthrough. xen/mmu: inhibit vmap aliases rather than trying to clear them out vmap: add flag to allow lazy unmap to be disabled at runtime xen: Add xen_create_contiguous_region xen: Rename the balloon lock xen: Allow unprivileged Xen domains to create iomap pages xen: use _PAGE_IOMAP in ioremap to do machine mappings Fix up trivial conflicts (adding both xen swiotlb and xen pci platform driver setup close to each other) in drivers/xen/{Kconfig,Makefile} and include/xen/xen-ops.h
2010-07-29Introduce CONFIG_XEN_PVHVM compile optionStefano Stabellini
This patch introduce a CONFIG_XEN_PVHVM compile time option to enable/disable Xen PV on HVM support. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2010-07-27swiotlb-xen: SWIOTLB library for Xen PV guest with PCI passthrough.Konrad Rzeszutek Wilk
This patchset: PV guests under Xen are running in an non-contiguous memory architecture. When PCI pass-through is utilized, this necessitates an IOMMU for translating bus (DMA) to virtual and vice-versa and also providing a mechanism to have contiguous pages for device drivers operations (say DMA operations). Specifically, under Xen the Linux idea of pages is an illusion. It assumes that pages start at zero and go up to the available memory. To help with that, the Linux Xen MMU provides a lookup mechanism to translate the page frame numbers (PFN) to machine frame numbers (MFN) and vice-versa. The MFN are the "real" frame numbers. Furthermore memory is not contiguous. Xen hypervisor stitches memory for guests from different pools, which means there is no guarantee that PFN==MFN and PFN+1==MFN+1. Lastly with Xen 4.0, pages (in debug mode) are allocated in descending order (high to low), meaning the guest might never get any MFN's under the 4GB mark. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Albert Herranz <albert_herranz@yahoo.es> Cc: Ian Campbell <Ian.Campbell@citrix.com>
