path: root/drivers/xen/events.c
2011-01-10Merge branch 'stable/bug-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/event: validate irq before get evtchn by irq xen/fb: fix potential memory leak xen/fb: fix xenfb suspend/resume race. xen: disable ACPI NUMA for PV guests xen/irq: Cleanup the find_unbound_irq
2011-01-10xen/event: validate irq before get evtchn by irqJoe Jin
When retrieving the event channel number from irq, the irq number may not be valid under some conditions. So far that can be when we suspend/resume and irq ends with -1. Validate and return sanitized irq and provide diagnostics information. [v3: added unlikely on the WARN path] [v2: reworded the commit message] Signed-off-by: Joe Jin <joe.jin@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2010-12-17xen: Use this_cpu_inc_returnChristoph Lameter
__this_cpu_inc_return reduces code and simplifies code. Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com>
2010-12-17xen: Use this_cpu_opsChristoph Lameter
Use this_cpu_ops to reduce code size and simplify things in various places. V3->V4: Move instance of this_cpu_inc_return to a later patchset so that this patch can be applied without infrastructure changes. Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-09xen/irq: Cleanup the find_unbound_irqKonrad Rzeszutek Wilk
The "find_unbound_irq" is a bit unusual - it allocates virtual IRQ (event channels) in reverse order. This means starting at the "top" of the available IRQs (nr_irqs) down to the GSI/MSI IRQs (nr_irqs_gsi). Lets document this and also make the variables easier to understand. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-12-03Merge branch '2.6.37-rc4-pvhvm-fixes' of ↵Linus Torvalds
git://xenbits.xen.org/people/sstabellini/linux-pvhvm * '2.6.37-rc4-pvhvm-fixes' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: unplug the emulated devices at resume time xen: fix save/restore for PV on HVM guests with pirq remapping xen: resume the pv console for hvm guests too xen: fix MSI setup and teardown for PV on HVM guests xen: use PHYSDEVOP_get_free_pirq to implement find_unbound_pirq
2010-12-02xen: allocate irq descs on any NUMA nodeJeremy Fitzhardinge
Allocate irq descs on any NUMA node (we don't care) rather than specifically node 0, which may not exist. (At the moment NUMA is meaningless within a domain, so any info the kernel has is just from an SRAT table we haven't suppressed/disabled.) Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-12-02xen: fix save/restore for PV on HVM guests with pirq remappingStefano Stabellini
Re-map and re-bind all the pirqs at resume time. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2010-12-02xen: fix MSI setup and teardown for PV on HVM guestsStefano Stabellini
When remapping MSIs into pirqs for PV on HVM guests, qemu is responsible for doing the actual mapping and unmapping. We only give qemu the desired pirq number when we ask to do the mapping the first time, after that we should be reading back the pirq number from qemu every time we want to re-enable the MSI. This fixes a bug in xen_hvm_setup_msi_irqs that manifests itself when trying to enable the same MSI for the second time: the old MSI to pirq mapping is still valid at this point but xen_hvm_setup_msi_irqs would try to assign a new pirq anyway. A simple way to reproduce this bug is to assign an MSI capable network card to a PV on HVM guest, if the user brings down the corresponding ethernet interface and up again, Linux would fail to enable MSIs on the device. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2010-12-02xen: use PHYSDEVOP_get_free_pirq to implement find_unbound_pirqStefano Stabellini
Use the new hypercall PHYSDEVOP_get_free_pirq to ask Xen to allocate a pirq. Remove the unsupported PHYSDEVOP_get_nr_pirqs hypercall to get the amount of pirq available. This fixes find_unbound_pirq that otherwise would return a number starting from nr_irqs that might very well be out of range in Xen. The symptom of this bug is that when you passthrough an MSI capable pci device to a PV on HVM guest, Linux would fail to enable MSIs on the device. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2010-11-22xen/events: Use PIRQ instead of GSI value when unmapping MSI/MSI-X irqs.Konrad Rzeszutek Wilk
When we allocate a vector for MSI/MSI-X we save away the PIRQ, and the vector value. When we unmap (de-allocate) the MSI/MSI-X vector(s) we need to provide the PIRQ and the vector value. What we did instead was to provide the GSI (which was zero) and the vector value, and we got these unhappy error messages: (XEN) irq.c:1575: dom0: pirq 0 not mapped [ 7.733415] unmap irq failed -22 This patches fixes this and we use the PIRQ value instead of the GSI value. CC: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-11-16xen/events: use locked set|clear_bit() for cpu_evtchn_maskJeremy Fitzhardinge
The per-cpu event channel masks can be updated unlocked from multiple CPUs, so use the locked variant. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-11-16xen/evtchn: clear secondary CPUs' cpu_evtchn_mask[] after restoreJan Beulich
To bind all event channels to CPU#0, it is not sufficient to set all of its cpu_evtchn_mask[] bits; all other CPUs also need to get their bits cleared. Otherwise, evtchn_do_upcall() will start handling interrupts on CPUs they're not intended to run on, which can be particularly bad for per-CPU ones. [ linux-2.6.18-xen.hg 7de7453dee36 ] Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-11-10xen: events: do not unmask event channels on resumeIan Campbell
The IRQ core code will take care of disabling and reenabling interrupts over suspend resume automatically, therefore we do not need to do this in the Xen event channel code. The only exception is those event channels marked IRQF_NO_SUSPEND which the IRQ core ignores. We must unmask these ourselves, taking care to obey the current IRQ_DISABLED status. Failure check for IRQ_DISABLED leads to enabling polled only event channels, such as that associated with the pv spinlocks, which must never be enabled: [ 21.970432] ------------[ cut here ]------------ [ 21.970432] kernel BUG at arch/x86/xen/spinlock.c:343! [ 21.970432] invalid opcode: 0000 [#1] SMP [ 21.970432] last sysfs file: /sys/devices/virtual/net/lo/operstate [ 21.970432] Modules linked in: [ 21.970432] [ 21.970432] Pid: 0, comm: swapper Not tainted (2.6.32.24-x86_32p-xen-01034-g787c727 #34) [ 21.970432] EIP: 0061:[<c102e209>] EFLAGS: 00010046 CPU: 3 [ 21.970432] EIP is at dummy_handler+0x3/0x7 [ 21.970432] EAX: 0000021c EBX: dfc16880 ECX: 0000001a EDX: 00000000 [ 21.970432] ESI: dfc02c00 EDI: 00000001 EBP: dfc47e10 ESP: dfc47e10 [ 21.970432] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0069 [ 21.970432] Process swapper (pid: 0, ti=dfc46000 task=dfc39440 task.ti=dfc46000) [ 21.970432] Stack: [ 21.970432] dfc47e30 c10a39f0 0000021c 00000000 00000000 dfc16880 0000021c 00000001 [ 21.970432] <0> dfc47e40 c10a4f08 0000021c 00000000 dfc47e78 c12240a7 c1839284 c1839284 [ 21.970432] <0> 00000200 00000000 00000000 f5720000 c1f3d028 c1f3d02c 00000180 dfc47e90 [ 21.970432] Call Trace: [ 21.970432] [<c10a39f0>] ? handle_IRQ_event+0x5f/0x122 [ 21.970432] [<c10a4f08>] ? handle_percpu_irq+0x2f/0x55 [ 21.970432] [<c12240a7>] ? __xen_evtchn_do_upcall+0xdb/0x15f [ 21.970432] [<c122481e>] ? xen_evtchn_do_upcall+0x20/0x30 [ 21.970432] [<c1030d47>] ? xen_do_upcall+0x7/0xc [ 21.970432] [<c102007b>] ? apic_reg_read+0xd3/0x22d [ 21.970432] [<c1002227>] ? hypercall_page+0x227/0x1005 [ 21.970432] [<c102d30b>] ? xen_force_evtchn_callback+0xf/0x14 [ 21.970432] [<c102da7c>] ? check_events+0x8/0xc [ 21.970432] [<c102da3b>] ? xen_irq_enable_direct_end+0x0/0x1 [ 21.970432] [<c105e485>] ? finish_task_switch+0x62/0xba [ 21.970432] [<c14e3f84>] ? schedule+0x808/0x89d [ 21.970432] [<c1084dc5>] ? hrtimer_start_expires+0x1a/0x22 [ 21.970432] [<c1085154>] ? tick_nohz_restart_sched_tick+0x15a/0x162 [ 21.970432] [<c102f43a>] ? cpu_idle+0x6d/0x6f [ 21.970432] [<c14db29e>] ? cpu_bringup_and_idle+0xd/0xf [ 21.970432] Code: 5d 0f 95 c0 0f b6 c0 c3 55 66 83 78 02 00 89 e5 5d 0f 95 \ c0 0f b6 c0 c3 55 b2 01 86 10 31 c0 84 d2 89 e5 0f 94 c0 5d c3 55 89 e5 <0f> 0b \ eb fe 55 80 3d 4c ce 84 c1 00 89 e5 57 56 89 c6 53 74 15 [ 21.970432] EIP: [<c102e209>] dummy_handler+0x3/0x7 SS:ESP 0069:dfc47e10 [ 21.970432] ---[ end trace c0b71f7e12cf3011 ]--- Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-10-28Merge branch 'stable/xen-pcifront-0.8.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen and branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm * 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: register xen pci notifier xen: initialize cpu masks for pv guests in xen_smp_init xen: add a missing #include to arch/x86/pci/xen.c xen: mask the MTRR feature from the cpuid xen: make hvc_xen console work for dom0. xen: add the direct mapping area for ISA bus access xen: Initialize xenbus for dom0. xen: use vcpu_ops to setup cpu masks xen: map a dummy page for local apic and ioapic in xen_set_fixmap xen: remap MSIs into pirqs when running as initial domain xen: remap GSIs as pirqs when running as initial domain xen: introduce XEN_DOM0 as a silent option xen: map MSIs into pirqs xen: support GSI -> pirq remapping in PV on HVM guests xen: add xen hvm acpi_register_gsi variant acpi: use indirect call to register gsi in different modes xen: implement xen_hvm_register_pirq xen: get the maximum number of pirqs from xen xen: support pirq != irq * 'stable/xen-pcifront-0.8.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (27 commits) X86/PCI: Remove the dependency on isapnp_disable. xen: Update Makefile with CONFIG_BLOCK dependency for biomerge.c MAINTAINERS: Add myself to the Xen Hypervisor Interface and remove Chris Wright. x86: xen: Sanitse irq handling (part two) swiotlb-xen: On x86-32 builts, select SWIOTLB instead of depending on it. MAINTAINERS: Add myself for Xen PCI and Xen SWIOTLB maintainer. xen/pci: Request ACS when Xen-SWIOTLB is activated. xen-pcifront: Xen PCI frontend driver. xenbus: prevent warnings on unhandled enumeration values xenbus: Xen paravirtualised PCI hotplug support. xen/x86/PCI: Add support for the Xen PCI subsystem x86: Introduce x86_msi_ops msi: Introduce default_[teardown|setup]_msi_irqs with fallback. x86/PCI: Export pci_walk_bus function. x86/PCI: make sure _PAGE_IOMAP it set on pci mappings x86/PCI: Clean up pci_cache_line_size xen: fix shared irq device passthrough xen: Provide a variant of xen_poll_irq with timeout. xen: Find an unbound irq number in reverse order (high to low). xen: statically initialize cpu_evtchn_mask_p ... Fix up trivial conflicts in drivers/pci/Makefile
2010-10-26Merge branches 'upstream/xenfs' and 'upstream/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/xenfs' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen/privcmd: make privcmd visible in domU xen/privcmd: move remap_domain_mfn_range() to core xen code and export. privcmd: MMAPBATCH: Fix error handling/reporting xenbus: export xen_store_interface for xenfs xen/privcmd: make sure vma is ours before doing anything to it xen/privcmd: print SIGBUS faults xen/xenfs: set_page_dirty is supposed to return true if it dirties xen/privcmd: create address space to allow writable mmaps xen: add privcmd driver xen: add variable hypercall caller xen: add xen_set_domain_pte() xen: add /proc/xen/xsd_{kva,port} to xenfs * 'upstream/core' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: (29 commits) xen: include xen/xen.h for definition of xen_initial_domain() xen: use host E820 map for dom0 xen: correctly rebuild mfn list list after migration. xen: improvements to VIRQ_DEBUG output xen: set up IRQ before binding virq to evtchn xen: ensure that all event channels start off bound to VCPU 0 xen/hvc: only notify if we actually sent something xen: don't add extra_pages for RAM after mem_end xen: add support for PAT xen: make sure xen_max_p2m_pfn is up to date xen: limit extra memory to a certain ratio of base xen: add extra pages for E820 RAM regions, even if beyond mem_end xen: make sure xen_extra_mem_start is beyond all non-RAM e820 xen: implement "extra" memory to reserve space for pages not present at boot xen: Use host-provided E820 map xen: don't map missing memory xen: defer building p2m mfn structures until kernel is mapped xen: add return value to set_phys_to_machine() xen: convert p2m to a 3 level tree xen: make install_p2mtop_page() static ... Fix up trivial conflict in arch/x86/xen/mmu.c, and fix the use of 'reserve_early()' - in the new memblock world order it is now 'memblock_x86_reserve_range()' instead. Pointed out by Jeremy.
2010-10-22xen: make hvc_xen console work for dom0.Jeremy Fitzhardinge
Use the console hypercalls for dom0 console. [ Impact: Add Xen dom0 console ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Juan Quintela <quintela@redhat.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: remap MSIs into pirqs when running as initial domainQing He
Implement xen_create_msi_irq to create an msi and remap it as pirq. Use xen_create_msi_irq to implement an initial domain specific version of setup_msi_irqs. Signed-off-by: Qing He <qing.he@intel.com> Signed-off-by: Yunhong Jiang <yunhong.jiang@intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: remap GSIs as pirqs when running as initial domainJeremy Fitzhardinge
Implement xen_register_gsi to setup the correct triggering and polarity properties of a gsi. Implement xen_register_pirq to register a particular gsi as pirq and receive interrupts as events. Call xen_setup_pirqs to register all the legacy ISA irqs as pirqs. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: map MSIs into pirqsStefano Stabellini
Map MSIs into pirqs, writing 0 in the MSI vector data field and the pirq number in the MSI destination id field. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: support GSI -> pirq remapping in PV on HVM guestsStefano Stabellini
Disable pcifront when running on HVM: it is meant to be used with pv guests that don't have PCI bus. Use acpi_register_gsi_xen_hvm to remap GSIs into pirqs. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: implement xen_hvm_register_pirqStefano Stabellini
xen_hvm_register_pirq allows the kernel to map a GSI into a Xen pirq and receive the interrupt as an event channel from that point on. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: get the maximum number of pirqs from xenStefano Stabellini
Use PHYSDEVOP_get_nr_pirqs to get the maximum number of pirqs from xen. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: support pirq != irqStefano Stabellini
PHYSDEVOP_map_pirq might return a pirq different from what we asked if we are running as an HVM guest, so we need to be able to support pirqs that are different from linux irqs. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-22xen: improvements to VIRQ_DEBUG outputIan Campbell
* Fix bitmask formatting on 64 bit by specifying correct field widths. * Output both global and local masked and pending information. * Indicate in list of pending interrupts whether they are pending in the L2, masked globally and/or masked locally. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-10-22xen: set up IRQ before binding virq to evtchnJeremy Fitzhardinge
Make sure the irq is set up before binding a virq event channel to it. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-10-22xen: ensure that all event channels start off bound to VCPU 0Ian Campbell
All event channels startbound to VCPU 0 so ensure that cpu_evtchn_mask is initialised to reflect this. Otherwise there is a race after registering an event channel but before the affinity is explicitly set where the event channel can be delivered. If this happens then the event channel remains pending in the L1 (evtchn_pending) array but is cleared in L2 (evtchn_pending_sel), this means the event channel cannot be reraised until another event channel happens to trigger the same L2 entry on that VCPU. sizeof(cpu_evtchn_mask(0))==sizeof(unsigned long*) which is not correct, and causes only the first 32 or 64 event channels (depending on architecture) to be initially bound to VCPU0. Use sizeof(struct cpu_evtchn_s) instead. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: stable@kernel.org
2010-10-22xen/events: change to using fasteoiJeremy Fitzhardinge
Change event delivery to: - mask+clear event in the upcall function - use handle_fasteoi_irq as the handler - unmask in the eoi function (and handle migration) Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-10-18x86: xen: Sanitse irq handling (part two)Konrad Rzeszutek Wilk
Thomas Gleixner cleaned up event handling to use the sparse_irq handling, but the xen-pcifront patches utilized the old mechanism. This fixes them to work with sparse_irq handling. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18xen/x86/PCI: Add support for the Xen PCI subsystemAlex Nixon
The frontend stub lives in arch/x86/pci/xen.c, alongside other sub-arch PCI init code (e.g. olpc.c). It provides a mechanism for Xen PCI frontend to setup/destroy legacy interrupts, MSI/MSI-X, and PCI configuration operations. [ Impact: add core of Xen PCI support ] [ v2: Removed the IOMMU code and only focusing on PCI.] [ v3: removed usage of pci_scan_all_fns as that does not exist] [ v4: introduced pci_xen value to fix compile warnings] [ v5: squished fixes+features in one patch, changed Reviewed-by to Ccs] [ v7: added Acked-by] Signed-off-by: Alex Nixon <alex.nixon@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Qing He <qing.he@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: x86@kernel.org
2010-10-18xen: fix shared irq device passthroughKonrad Rzeszutek Wilk
In driver/xen/events.c, whether bind_pirq is shareable or not is determined by desc->action is NULL or not. But in __setup_irq, startup(irq) is invoked before desc->action is assigned with new action. So desc->action in startup_irq is always NULL, and bind_pirq is always not shareable. This results in pt_irq_create_bind failure when passthrough a device which shares irq to other devices. This patch doesn't use probing_irq to determine if pirq is shareable or not, instead set shareable flag in irq_info according to trigger mode in xen_allocate_pirq. Set level triggered interrupts shareable. Thus use this flag to set bind_pirq flag accordingly. [v2: arch/x86/xen/pci.c no more, so file skipped] Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18xen: Provide a variant of xen_poll_irq with timeout.Konrad Rzeszutek Wilk
The 'xen_poll_irq_timeout' provides a method to pass in the poll timeout for IRQs if requested. We also export those two poll functions as Xen PCI fronted uses them. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-10-18xen: Find an unbound irq number in reverse order (high to low).Konrad Rzeszutek Wilk
In earlier Xen Linux kernels, the IRQ mapping was a straight 1:1 and the find_unbound_irq started looking around 256 for open IRQs and up. IRQs from 0 to 255 were reserved for PCI devices. Previous to this patch, the 'find_unbound_irq' started looking at get_nr_hw_irqs() number. For privileged domain where the ACPI information is available that returns the upper-bound of what the GSIs. For non-privileged PV domains, where ACPI is no-existent the get_nr_hw_irqs() reports the IRQ_LEGACY (16). With PCI passthrough enabled, and with PCI cards that have IRQs pinned to a higher number than 16 we collide with previously allocated IRQs. Specifically the PCI IRQs collide with the IPI's for Xen functions (as they are allocated earlier). For example: 00:00.11 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller (prog-if 10 [OHCI]) ... Interrupt: pin A routed to IRQ 18 [root@localhost ~]# cat /proc/interrupts | head CPU0 CPU1 CPU2 16: 38186 0 0 xen-dyn-virq timer0 17: 149 0 0 xen-dyn-ipi spinlock0 18: 962 0 0 xen-dyn-ipi resched0 and when the USB controller is loaded, the kernel reports: IRQ handler type mismatch for IRQ 18 current handler: resched0 One way to fix this is to reverse the logic when looking for un-used IRQ numbers and start with the highest available number. With that, we would get: CPU0 CPU1 CPU2 ... snip .. 292: 35 0 0 xen-dyn-ipi callfunc0 293: 3992 0 0 xen-dyn-ipi resched0 294: 224 0 0 xen-dyn-ipi spinlock0 295: 57183 0 0 xen-dyn-virq timer0 NMI: 0 0 0 Non-maskable interrupts .. snip .. And interrupts for PCI cards are now accessible. This patch also includes the fix, found by Ian Campbell, titled "xen: fix off-by-one error in find_unbound_irq." [v2: Added an explanation in the code] [v3: Rebased on top of tip/irq/core] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-10-18xen: statically initialize cpu_evtchn_mask_pJeremy Fitzhardinge
Sometimes cpu_evtchn_mask_p can get used early, before it has been allocated. Statically initialize it with an initdata version to catch any early references. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18xen: set pirq name to something useful.Gerd Hoffmann
Impact: cleanup Make pirq show useful information in /proc/interrupts [v2: Removed the parts for arch/x86/xen/pci.c ] Signed-off-by: Gerd Hoffmann <kraxel@xeni.home.kraxel.org> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18xen: dynamically allocate irq & event structuresJeremy Fitzhardinge
Dynamically allocate the irq_info and evtchn_to_irq arrays, so that 1) the irq_info array scales to the actual number of possible irqs, and 2) we don't needlessly increase the static size of the kernel when we aren't running under Xen. Derived on patch from Mike Travis <travis@sgi.com>. [Impact: reduce memory usage ] [v2: Conflict in drivers/xen/events.c: Replaced alloc_bootmen with kcalloc ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18xen: identity map gsi->irqsKonrad Rzeszutek Wilk
Impact: preserve compat with native Reserve the lower irq range for use for hardware interrupts so we can identity-map them. [v2: Rebased on top tip/irq/core] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-18xen: implement pirq type event channelsJeremy Fitzhardinge
A privileged PV Xen domain can get direct access to hardware. In order for this to be useful, it must be able to get hardware interrupts. Being a PV Xen domain, all interrupts are delivered as event channels. PIRQ event channels are bound to a pirq number and an interrupt vector. When a IO APIC raises a hardware interrupt on that vector, it is delivered as an event channel, which we can deliver to the appropriate device driver(s). This patch simply implements the infrastructure for dealing with pirq event channels. [ Impact: integrate hardware interrupts into Xen's event scheme ] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2010-10-12x86: xen: Sanitise sparse_irq handlingThomas Gleixner
There seems to be more cleanups possible, but that's left to the xen experts :) Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu> Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
2010-08-24xen: handle events as edge-triggeredJeremy Fitzhardinge
Xen events are logically edge triggered, as Xen only calls the event upcall when an event is newly set, but not continuously as it remains set. As a result, use handle_edge_irq rather than handle_level_irq. This has the important side-effect of fixing a long-standing bug of events getting lost if: - an event's interrupt handler is running - the event is migrated to a different vcpu - the event is re-triggered The most noticable symptom of these lost events is occasional lockups of blkfront. Many thanks to Tom Kopec and Daniel Stodden in tracking this down. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Tom Kopec <tek@acm.org> Cc: Daniel Stodden <daniel.stodden@citrix.com> Cc: Stable Kernel <stable@kernel.org>
2010-08-24xen: use percpu interrupts for IPIs and VIRQsJeremy Fitzhardinge
IPIs and VIRQs are inherently per-cpu event types, so treat them as such: - use a specific percpu irq_chip implementation, and - handle them with handle_percpu_irq This makes the path for delivering these interrupts more efficient (no masking/unmasking, no locks), and it avoid problems with attempts to migrate them. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stable Kernel <stable@kernel.org>
2010-08-06Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: xen: Do not suspend IPI IRQs. powerpc: Use IRQF_NO_SUSPEND not IRQF_TIMER for non-timer interrupts ixp4xx-beeper: Use IRQF_NO_SUSPEND not IRQF_TIMER for non-timer interrupt irq: Add new IRQ flag IRQF_NO_SUSPEND
2010-07-29Introduce CONFIG_XEN_PVHVM compile optionStefano Stabellini
This patch introduce a CONFIG_XEN_PVHVM compile time option to enable/disable Xen PV on HVM support. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2010-07-29xen: Do not suspend IPI IRQs.Ian Campbell
In general the semantics of IPIs are that they are are expected to continue functioning after dpm_suspend_noirq(). Specifically I have seen a deadlock between the callfunc IPI and the stop machine used by xen's do_suspend() routine. If one CPU has already called dpm_suspend_noirq() then there is a window where it can be sent a callfunc IPI before all the other CPUs have entered stop_cpu(). If this happens then the first CPU ends up spinning in stop_cpu() waiting for the other to rendezvous in state STOPMACHINE_PREPARE while the other is spinning in csd_lock_wait(). Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: xen-devel@lists.xensource.com LKML-Reference: <1280398595-29708-4-git-send-email-ian.campbell@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-07-22xen: Fix find_unbound_irq in presence of ioapic irqs.Stefano Stabellini
Don't break the assumption that the first 16 irqs are ISA irqs; make sure that the irq is actually free before using it. Use dynamic_irq_init_keep_chip_data instead of dynamic_irq_init so that chip_data is not NULL (a NULL chip_data breaks setup_vector_irq). Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-07-22xen: Xen PCI platform device driver.Stefano Stabellini
Add the xen pci platform device driver that is responsible for initializing the grant table and xenbus in PV on HVM mode. Few changes to xenbus and grant table are necessary to allow the delayed initialization in HVM mode. Grant table needs few additional modifications to work in HVM mode. The Xen PCI platform device raises an irq every time an event has been delivered to us. However these interrupts are only delivered to vcpu 0. The Xen PCI platform interrupt handler calls xen_hvm_evtchn_do_upcall that is a little wrapper around __xen_evtchn_do_upcall, the traditional Xen upcall handler, the very same used with traditional PV guests. When running on HVM the event channel upcall is never called while in progress because it is a normal Linux irq handler (and we cannot switch the irq chip wholesale to the Xen PV ones as we are running QEMU and might have passed in PCI devices), therefore we cannot be sure that evtchn_upcall_pending is 0 when returning. For this reason if evtchn_upcall_pending is set by Xen we need to loop again on the event channels set pending otherwise we might loose some event channel deliveries. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2010-07-22x86/xen: event channels delivery on HVM.Sheng Yang
Set the callback to receive evtchns from Xen, using the callback vector delivery mechanism. The traditional way for receiving event channel notifications from Xen is via the interrupts from the platform PCI device. The callback vector is a newer alternative that allow us to receive notifications on any vcpu and doesn't need any PCI support: we allocate a vector exclusively to receive events, in the vector handler we don't need to interact with the vlapic, therefore we avoid a VMEXIT. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-18xen: Remove unnecessary arch specific xen irq functions.Eric W. Biederman
Right now xen's use of the x86 and ia64 handle_irq is just bizarre and very fragile as it is very non-obvious the function exists and is is used by code out in drivers/.... Luckily using handle_irq is completely unnecessary, and we can just use the generic irq apis instead. This still leaves drivers/xen/events.c as a problematic user of the generic irq apis it has "static struct irq_info irq_info[NR_IRQS]" but that can be fixed some other time. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> LKML-Reference: <4B7CAAD2.10803@kernel.org> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Ian Campbell <Ian.Campbell@citrix.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-03xen: don't leak IRQs over suspend/resume.Ian Campbell
On resume irq_info[*].evtchn is reset to 0 since event channel mappings are not preserved over suspend/resume. The other contents of irq_info is preserved to allow rebind_evtchn_irq() to function. However when a device resumes it will try to unbind from the previous IRQ (e.g. blkfront goes blkfront_resume() -> blkif_free() -> unbind_from_irqhandler() -> unbind_from_irq()). This will fail due to the check for VALID_EVTCHN in unbind_from_irq() and the IRQ is leaked. The device will then continue to resume and allocate a new IRQ, eventually leading to find_unbound_irq() panic()ing. Fix this by changing unbind_from_irq() to handle teardown of interrupts which have type!=IRQT_UNBOUND but are not currently bound to a specific event channel. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stable Kernel <stable@kernel.org>
