[ Upstream commit a4098bc6eed5e31e0391bcc068e61804c98138df ]
If MCFG area is not reserved in E820, Xen by default will defer its usage
until Dom0 registers it explicitly after ACPI parser recognizes it as
a reserved resource in DSDT. Having it reserved in E820 is not
mandatory according to "PCI Firmware Specification, rev 3.2" (par. 4.1.2)
and firmware is free to keep a hole in E820 in that place. Xen doesn't know
what exactly is inside this hole since it lacks full ACPI view of the
platform therefore it's potentially harmful to access MCFG region
without additional checks as some machines are known to provide
inconsistent information on the size of the region.
Now xen_mcfg_late() runs after acpi_init() which is too late as some basic
PCI enumeration starts exactly there as well. Trying to register a device
prior to MCFG reservation causes multiple problems with PCIe extended
capability initializations in Xen (e.g. SR-IOV VF BAR sizing). There are
no convenient hooks for us to subscribe to so register MCFG areas earlier
upon the first invocation of xen_add_device(). It should be safe to do once
since all the boot time buses must have their MCFG areas in MCFG table
already and we don't support PCI bus hot-plug.
Signed-off-by: Igor Druzhinin <igor.druzhinin@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
If the device being added to Xen is not contained in the ACPI table,
walk the PCI device tree to find a parent that is contained in the ACPI
table before finding the PXM information from this device.
Previously, it would try to get a handle for the device, then the
device's bridge, then the physfn. This changes the order so that it
tries to get a handle for the device, then the physfn, the walks up the
PCI device tree.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
physdev_pci_device_add's optarr[] is a zero-sized array and therefore
reference to add.optarr[0] is accessing memory that does not belong to
the 'add' variable.
Reviewed-by: Jan Beulich <jbeulich@suse.com>
We can't include <asm/pci_x86.h> if this isn't x86, and we only need
it if CONFIG_PCI_MMCONFIG is enabled.
Fixes: 8deb3eb1461e ('xen/mcfg: Call PHYSDEVOP_pci_mmcfg_reserved for MCFG areas.')
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Pull more ACPI and power management updates from Rafael Wysocki:
- ACPI-based device hotplug fixes for issues introduced recently and a
fix for an older error code path bug in the ACPI PCI host bridge
driver
- Fix for recently broken OMAP cpufreq build from Viresh Kumar
- Fix for a recent hibernation regression related to s2disk
- Fix for a locking-related regression in the ACPI EC driver from
Puneet Kumar
- System suspend error code path fix related to runtime PM and runtime
PM documentation update from Ulf Hansson
- cpufreq's conservative governor fix from Xiaoguang Chen
- New processor IDs for intel_idle and turbostat and removal of an
obsolete Kconfig option from Len Brown
- New device IDs for the ACPI LPSS (Low-Power Subsystem) driver and
ACPI-based PCI hotplug (ACPIPHP) cleanup from Mika Westerberg
- Removal of several ACPI video DMI blacklist entries that are not
necessary any more from Aaron Lu
- Rework of the ACPI companion representation in struct device and code
cleanup related to that change from Rafael J Wysocki, Lan Tianyu and
Jarkko Nikula
- Fixes for assigning names to ACPI-enumerated I2C and SPI devices from
Jarkko Nikula
* tag 'pm+acpi-2-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (24 commits)
PCI / hotplug / ACPI: Drop unused acpiphp_debug declaration
ACPI / scan: Set flags.match_driver in acpi_bus_scan_fixed()
ACPI / PCI root: Clear driver_data before failing enumeration
ACPI / hotplug: Fix PCI host bridge hot removal
ACPI / hotplug: Fix acpi_bus_get_device() return value check
cpufreq: governor: Remove fossil comment in the cpufreq_governor_dbs()
ACPI / video: clean up DMI table for initial black screen problem
ACPI / EC: Ensure lock is acquired before accessing ec struct members
PM / Hibernate: Do not crash kernel in free_basic_memory_bitmaps()
ACPI / AC: Remove struct acpi_device pointer from struct acpi_ac
spi: Use stable dev_name for ACPI enumerated SPI slaves
i2c: Use stable dev_name for ACPI enumerated I2C slaves
ACPI: Provide acpi_dev_name accessor for struct acpi_device device name
ACPI / bind: Use (put|get)_device() on ACPI device objects too
ACPI: Eliminate the DEVICE_ACPI_HANDLE() macro
ACPI / driver core: Store an ACPI device pointer in struct acpi_dev_node
cpufreq: OMAP: Fix compilation error 'r & ret undeclared'
PM / Runtime: Fix error path for prepare
PM / Runtime: Update documentation around probe|remove|suspend
cpufreq: conservative: set requested_freq to policy max when it is over policy max
Since DEVICE_ACPI_HANDLE() is now literally identical to
ACPI_HANDLE(), replace it with the latter everywhere and drop its
definition from include/acpi.h.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
The PCI MMCONFIG area is usually reserved via the E820 so the Xen hypervisor
is aware of these regions. But they can also be enumerated in the ACPI
DSDT which means the hypervisor won't know of them until the initial
domain informs it of via PHYSDEVOP_pci_mmcfg_reserved.
This is what this patch does for all of the MCFG regions that the
initial domain is aware of (E820 enumerated and ACPI).
Reported-by: Santosh Jodh <Santosh.Jodh@citrix.com>
CC: Jan Beulich <JBeulich@suse.com>
CC: David Vrabel <david.vrabel@citrix.com>
CC: Mukesh Rathor <mukesh.rathor@oracle.com>
[v1: Redid it a bit]
[v2: Dropped the P2M 1-1 setting]
[v3: Check for Xen in-case we are running under baremetal]
[v4: Wrap with CONFIG_PCI_MMCONFIG]
Some SR-IOV devices may use more than one bus number, but there is no real bridges
because that have internal routing mechanism. So need to check whether the bridge is
existing before using it.
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/cleanups-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: use static initializers in xen-balloon.c
Xen: fix braces and tabs coding style issue in xenbus_probe.c
Xen: fix braces coding style issue in xenbus_probe.h
Xen: fix whitespaces,tabs coding style issue in drivers/xen/pci.c
Xen: fix braces coding style issue in gntdev.c and grant-table.c
Xen: fix whitespaces,tabs coding style issue in drivers/xen/events.c
Xen: fix whitespaces,tabs coding style issue in drivers/xen/balloon.c
Fix up trivial whitespace-conflicts in
drivers/xen/{balloon.c,pci.c,xenbus/xenbus_probe.c}
Now that the hypercall interface changes are in -unstable, make the
kernel side code not ignore the segment (aka domain) number anymore
(which results in pretty odd behavior on such systems). Rather, if
only the old interfaces are available, don't call them for devices on
non-zero segments at all.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
[v1: Edited git description]
Notifier functions are expected to return NOTIFY_* codes, not -E...
ones. In particular, since the respective hypercalls failing is not
fatal to the operation of the Dom0 kernel, it must be avoided to
return negative values here as those would make it appear as if
NOTIFY_STOP_MASK wa set, suppressing further notification calls to
other interested parties (which is also why we don't want to use
notifier_from_errno() here).
While at it, also notify the user of a failed hypercall.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
[v1: Added dev_err and the disable MSI/MSI-X call]
[v2: Removed the disable MSI/MSI-X call]
This is a patch to the pci.c file that fixed up whitespaces, tabs warnings found by the checkpatch.pl tools.
Signed-off-by: Ruslan Pisarev <ruslan@rpisarev.org.ua>
Register a pci notifier to add (or remove) pci devices to Xen via
hypercalls. Xen needs to know the pci devices present in the system to
handle pci passthrough and even MSI remapping in the initial domain.
Signed-off-by: Weidong Han <weidong.han@intel.com>
Signed-off-by: Qing He <qing.he@intel.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
