commit 50f6393f9654c561df4cdcf8e6cfba7260143601 upstream.
The condition in xen_swiotlb_free_coherent() for deciding whether to
call xen_destroy_contiguous_region() is wrong: in case the region to
be freed is not contiguous calling xen_destroy_contiguous_region() is
the wrong thing to do: it would result in inconsistent mappings of
multiple PFNs to the same MFN. This will lead to various strange
crashes or data corruption.
Instead of calling xen_destroy_contiguous_region() in that case a
warning should be issued as that situation should never occur.
Cc: stable@vger.kernel.org
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Reviewed-by: Jan Beulich <jbeulich@suse.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 7250f422da0480d8512b756640f131b9b893ccda upstream.
xen_swiotlb_{alloc,free}_coherent() allocate/free memory based on the
order of the pages and not size argument (bytes). This is inconsistent with
range_straddles_page_boundary and memset which use the 'size' value,
which may lead to not exchanging memory with Xen (range_straddles_page_boundary()
returned true). And then the call to xen_swiotlb_free_coherent() would
actually try to exchange the memory with Xen, leading to the kernel
hitting an BUG (as the hypercall returned an error).
This patch fixes it by making the 'size' variable be of the same size
as the amount of memory allocated.
CC: stable@vger.kernel.org
Signed-off-by: Joe Jin <joe.jin@oracle.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Christoph Helwig <hch@lst.de>
Cc: Dongli Zhang <dongli.zhang@oracle.com>
Cc: John Sobecki <john.sobecki@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 4855c92dbb7b3b85c23e88ab7ca04f99b9677b41 upstream.
When run raidconfig from Dom0 we found that the Xen DMA heap is reduced,
but Dom Heap is increased by the same size. Tracing raidconfig we found
that the related ioctl() in megaraid_sas will call dma_alloc_coherent()
to apply memory. If the memory allocated by Dom0 is not in the DMA area,
it will exchange memory with Xen to meet the requiment. Later drivers
call dma_free_coherent() to free the memory, on xen_swiotlb_free_coherent()
the check condition (dev_addr + size - 1 <= dma_mask) is always false,
it prevents calling xen_destroy_contiguous_region() to return the memory
to the Xen DMA heap.
This issue introduced by commit 6810df88dcfc2 "xen-swiotlb: When doing
coherent alloc/dealloc check before swizzling the MFNs.".
Tested-by: John Sobecki <john.sobecki@oracle.com>
Reviewed-by: Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 7e91c7df29b5e196de3dc6f086c8937973bd0b88 upstream.
This function creates userspace mapping for the DMA-coherent memory.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Oleksandr Dmytryshyn <oleksandr.dmytryshyn@globallogic.com>
Signed-off-by: Andrii Anisov <andrii_anisov@epam.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
[ Upstream commit f1225ee4c8fcf09afaa199b8b1f0450f38b8cd11 ]
In xen_swiotlb_map_page and xen_swiotlb_map_sg_attrs, if the original
page is not suitable, we swap it for another page from the swiotlb
pool.
In these cases, we don't update the previously calculated dma address
for the page before calling xen_dma_map_page. Thus, we end up calling
xen_dma_map_page passing the wrong dev_addr, resulting in
xen_dma_map_page mistakenly assuming that the page is foreign when it is
local.
Fix the bug by updating dev_addr appropriately.
This change has no effect on x86, because xen_dma_map_page is a stub
there.
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
Signed-off-by: Pooya Keshavarzi <Pooya.Keshavarzi@de.bosch.com>
Tested-by: Pooya Keshavarzi <Pooya.Keshavarzi@de.bosch.com>
commit ae7871be189cb41184f1e05742b4a99e2c59774d upstream.
Convert the flag swiotlb_force from an int to an enum, to prepare for
the advent of more possible values.
Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
Swiotlb is used on ARM64 to support DMA on platform where devices are
not protected by an SMMU. Furthermore it's only enabled for DOM0.
While Xen is always using 4KB page granularity in the stage-2 page table,
Linux ARM64 may either use 4KB or 64KB. This means that a Linux page
can be spanned accross multiple Xen page.
The Swiotlb code has to validate that the buffer used for DMA is
physically contiguous in the memory. As a Linux page can't be shared
between local memory and foreign page by design (the balloon code always
removing entirely a Linux page), the changes in the code are very
minimal because we only need to check the first Xen PFN.
Note that it may be possible to optimize the function
check_page_physically_contiguous to avoid looping over every Xen PFN
for local memory. Although I will let this optimization for a follow-up.
Signed-off-by: Julien Grall <julien.grall@citrix.com>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
With 64KB page granularity support, the frame number will be different.
It will be easier to modify the behavior in a single place rather than
in each caller.
Merge third patch-bomb from Andrew Morton:
- even more of the rest of MM
- lib/ updates
- checkpatch updates
- small changes to a few scruffy filesystems
- kmod fixes/cleanups
- kexec updates
- a dma-mapping cleanup series from hch
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits)
dma-mapping: consolidate dma_set_mask
dma-mapping: consolidate dma_supported
dma-mapping: cosolidate dma_mapping_error
dma-mapping: consolidate dma_{alloc,free}_noncoherent
dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}
mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd()
mm: make sure all file VMAs have ->vm_ops set
mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff()
mm: mark most vm_operations_struct const
namei: fix warning while make xmldocs caused by namei.c
ipc: convert invalid scenarios to use WARN_ON
zlib_deflate/deftree: remove bi_reverse()
lib/decompress_unlzma: Do a NULL check for pointer
lib/decompressors: use real out buf size for gunzip with kernel
fs/affs: make root lookup from blkdev logical size
sysctl: fix int -> unsigned long assignments in INT_MIN case
kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo
kexec: align crash_notes allocation to make it be inside one physical page
kexec: remove unnecessary test in kimage_alloc_crash_control_pages()
kexec: split kexec_load syscall from kexec core code
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
The swiotlb is required when programming a DMA address on ARM when a
device is not protected by an IOMMU.
In this case, the DMA address should always be equal to the machine address.
For DOM0 memory, Xen ensure it by have an identity mapping between the
guest address and host address. However, when mapping a foreign grant
reference, the 1:1 model doesn't work.
For ARM guest, most of the callers of pfn_to_mfn expects to get a GFN
(Guest Frame Number), i.e a PFN (Page Frame Number) from the Linux point
of view given that all ARM guest are auto-translated.
Even though the name pfn_to_mfn is misleading, we need to ensure that
those caller get a GFN and not by mistake a MFN. In pratical, I haven't
seen error related to this but we should fix it for the sake of
correctness.
In order to fix the implementation of pfn_to_mfn on ARM in a follow-up
patch, we have to introduce new helpers to return the DMA from a PFN and
the invert.
On x86, the new helpers will be an alias of pfn_to_mfn and mfn_to_pfn.
The helpers will be used in swiotlb and xen_biovec_phys_mergeable.
This is necessary in the latter because we have to ensure that the
biovec code will not try to merge a biovec using foreign page and
another using Linux memory.
Lastly, the helper mfn_to_local_pfn has been renamed to bfn_to_local_pfn
given that the only usage was in swiotlb.
Make sure that xen_swiotlb_init allocates buffers that are DMA capable
when at least one memblock is available below 4G. Otherwise we assume
that all devices on the SoC can cope with >4G addresses. We do this on
ARM and ARM64, where dom0 is mapped 1:1, so pfn == mfn in this case.
No functional changes on x86.
Signed-off-by: Chen Baozi <baozich@gmail.com>
Tested-by: Chen Baozi <baozich@gmail.com>
This reverts commit 2c3fc8d26dd09b9d7069687eead849ee81c78e46.
This commit broke on x86 PV because entries in the generic SWIOTLB are
indexed using (pseudo-)physical address not DMA address and these are
not the same in a x86 PV guest.
Need to pass the pointer within the swiotlb internal buffer to the
swiotlb library, that in the case of xen_unmap_single is dev_addr, not
paddr.
In xen_swiotlb_sync_single we always call xen_dma_sync_single_for_cpu,
even when we should call xen_dma_sync_single_for_device. Fix that.
On x86 truncation cannot occur because config XEN depends on X86_64 ||
(X86_32 && X86_PAE).
On ARM truncation can occur without CONFIG_ARM_LPAE, when the dma
operation involves foreign grants. However in that case the physical
address returned by xen_bus_to_phys is actually invalid (there is no mfn
to pfn tracking for foreign grants on ARM) and it is not used.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
xen_dma_unmap_page and xen_dma_sync_single_for_cpu take a dma_addr_t
handle as argument, not a physical address.
Introduce an arch specific function to find out whether a particular dma
mapping operation needs to bounce on the swiotlb buffer.
On ARM and ARM64, if the page involved is a foreign page and the device
is not coherent, we need to bounce because at unmap time we cannot
execute any required cache maintenance operations (we don't know how to
find the pfn from the mfn).
No change of behaviour for x86.
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
dev_addr is the machine address of the page.
The new parameter can be used by the ARM and ARM64 implementations of
xen_dma_map_page to find out if the page is a local page (pfn == mfn) or
a foreign page (pfn != mfn).
dev_addr could be retrieved again from the physical address, using
pfn_to_mfn, but it requires accessing an rbtree. Since we already have
the dev_addr in our hands at the call site there is no need to get the
mfn twice.
The use of phys_to_machine and machine_to_phys in the phys<=>bus conversions
causes us to lose the top bits of the DMA address if the size of a DMA address is not the same as the size of the phyiscal address.
This can happen in practice on ARM where foreign pages can be above 4GB even
though the local kernel does not have LPAE page tables enabled (which is
totally reasonable if the guest does not itself have >4GB of RAM). In this
case the kernel still maps the foreign pages at a phys addr below 4G (as it
must) but the resulting DMA address (returned by the grant map operation) is
much higher.
This is analogous to a hardware device which has its view of RAM mapped up
high for some reason.
This patch makes I/O to foreign pages (specifically blkif) work on 32-bit ARM
systems with more than 4GB of RAM.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
swiotlb-xen is missing a xen_dma_map_page call in
xen_swiotlb_map_sg_attrs, in the bounce buffer path.
stable/for-linus-3.13
* stefano/swiotlb-xen-9.1:
swiotlb-xen: fix error code returned by xen_swiotlb_map_sg_attrs
swiotlb-xen: static inline xen_phys_to_bus, xen_bus_to_phys, xen_virt_to_bus and range_straddles_page_boundary
grant-table: call set_phys_to_machine after mapping grant refs
arm,arm64: do not always merge biovec if we are running on Xen
swiotlb: print a warning when the swiotlb is full
swiotlb-xen: use xen_dma_map/unmap_page, xen_dma_sync_single_for_cpu/device
xen: introduce xen_dma_map/unmap_page and xen_dma_sync_single_for_cpu/device
swiotlb-xen: use xen_alloc/free_coherent_pages
xen: introduce xen_alloc/free_coherent_pages
arm64/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
arm/xen: get_dma_ops: return xen_dma_ops if we are running as xen_initial_domain
swiotlb-xen: introduce xen_swiotlb_set_dma_mask
xen/arm,arm64: enable SWIOTLB_XEN
xen: make xen_create_contiguous_region return the dma address
xen/x86: allow __set_phys_to_machine for autotranslate guests
arm/xen,arm64/xen: introduce p2m
arm64: define DMA_ERROR_CODE
arm: make SWIOTLB available
arch/arm/include/asm/dma-mapping.h
drivers/xen/swiotlb-xen.c
[Conflicts arose b/c "arm: make SWIOTLB available" v8 was in Stefano's
branch, while I had v9 + Ack from Russel. I also fixed up white-space
issues]
map_sg returns the number of elements mapped, not a dma_addr_t.
In case of error return 0, not DMA_ERROR_CODE.
This functions are small and called frequently. Static inline them.
Changes in v7:
- use dev_warn instead of pr_warn.
Call xen_dma_map_page, xen_dma_unmap_page, xen_dma_sync_single_for_cpu,
xen_dma_sync_single_for_device from swiotlb-xen to ensure cpu/device
coherency of the pages used for DMA, including the ones belonging to the
swiotlb buffer.
Tracepoints are only created when Xen support is enabled, but they are
also referenced within lib/swiotlb.c. So unless Xen support is enabled
the tracepoints will be missing, therefore causing builds to fail. Fix
this by moving the tracepoint creation to lib/swiotlb.c, which works
nicely because the Xen swiotlb support selects the generic swiotlb
support.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Use xen_alloc_coherent_pages and xen_free_coherent_pages to allocate or
free coherent pages.
We need to be careful handling the pointer returned by
xen_alloc_coherent_pages, because on ARM the pointer is not equal to
phys_to_virt(*dma_handle). In fact virt_to_phys only works for kernel
direct mapped RAM memory.
In ARM case the pointer could be an ioremap address, therefore passing
it to virt_to_phys would give you another physical address that doesn't
correspond to it.
Make xen_create_contiguous_region take a phys_addr_t as start parameter to
avoid the virt_to_phys calls which would be incorrect.
Changes in v6:
- remove extra spaces.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Implement xen_swiotlb_set_dma_mask, use it for set_dma_mask on arm.
Xen on arm and arm64 needs SWIOTLB_XEN: when running on Xen we need to
program the hardware with mfns rather than pfns for dma addresses.
Remove SWIOTLB_XEN dependency on X86 and PCI and make XEN select
SWIOTLB_XEN on arm and arm64.
At the moment always rely on swiotlb-xen, but when Xen starts supporting
hardware IOMMUs we'll be able to avoid it conditionally on the presence
of an IOMMU on the platform.
Implement xen_create_contiguous_region on arm and arm64: for the moment
we assume that dom0 has been mapped 1:1 (physical addresses == machine
addresses) therefore we don't need to call XENMEM_exchange. Simply
return the physical address as dma address.
Initialize the xen-swiotlb from xen_early_init (before the native
dma_ops are initialized), set xen_dma_ops to &xen_swiotlb_dma_ops.
Changes in v8:
- assume dom0 is mapped 1:1, no need to call XENMEM_exchange.
Changes in v7:
- call __set_phys_to_machine_multi from xen_create_contiguous_region and
xen_destroy_contiguous_region to update the P2M;
- don't call XENMEM_unpin, it has been removed;
- call XENMEM_exchange instead of XENMEM_exchange_and_pin;
- set nr_exchanged to 0 before calling the hypercall.
Changes in v6:
- introduce and export xen_dma_ops;
- call xen_mm_init from as arch_initcall.
Changes in v4:
- remove redefinition of DMA_ERROR_CODE;
- update the code to use XENMEM_exchange_and_pin and XENMEM_unpin;
- add a note about hardware IOMMU in the commit message.
Changes in v3:
- code style changes;
- warn on XENMEM_put_dma_buf failures.
Modify xen_create_contiguous_region to return the dma address of the
newly contiguous buffer.
Changes in v4:
- use virt_to_machine instead of virt_to_bus.
Ftrace is currently not able to detect when SWIOTLB has to do double buffering.
Under Xen you can only see it indirectly in function_graph, when
xen_swiotlb_map_page() doesn't stop after range_straddles_page_boundary(), but
calls spinlock functions, memcpy() and xen_phys_to_bus() as well. This patch
introduces the swiotlb:swiotlb_bounced event, which also prints out the
following informations to help you find out why bouncing happened:
dev_name: 0000:08:00.0 dma_mask=ffffffffffffffff dev_addr=9149f000 size=32768
swiotlb_force=0
If you use Xen, and (dev_addr + size + 1) > dma_mask, the buffer is out of the
device's DMA range. If swiotlb_force == 1, you should really change the kernel
parameters. Otherwise, the buffer is not contiguous in mfn space.
Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com>
[v1: Don't print 'swiotlb_force=X', just print swiotlb_force if it is enabled]
swiotlb-xen has an implicit dependency on CONFIG_NEED_SG_DMA_LENGTH.
Remove it by replacing dma_length with sg_dma_len.
Convert printks to pr_<level> (excludes printk(KERN_DEBUG...)
to be more consistent throughout the xen subsystem.
Add pr_fmt with KBUILD_MODNAME or "xen:" KBUILD_MODNAME
Coalesce formats and add missing word spaces
Add missing newlines
Align arguments and reflow to 80 columns
Remove DRV_NAME from formats as pr_fmt adds the same content
This does change some of the prefixes of these messages
but it also does make them more consistent.
Normal boot path on system with iommu support:
swiotlb buffer will be allocated early at first and then try to initialize
iommu, if iommu for intel or AMD could setup properly, swiotlb buffer
will be freed.
The early allocating is with bootmem, and could panic when we try to use
kdump with buffer above 4G only, or with memmap to limit mem under 4G.
for example: memmap=4095M$1M to remove memory under 4G.
According to Eric, add _nopanic version and no_iotlb_memory to fail
map single later if swiotlb is still needed.
-v2: don't pass nopanic, and use -ENOMEM return value according to Eric.
panic early instead of using swiotlb_full to panic...according to Eric/Konrad.
-v3: make swiotlb_init to be notpanic, but will affect:
arm64, ia64, powerpc, tile, unicore32, x86.
-v4: cleanup swiotlb_init by removing swiotlb_init_with_default_size.
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1359058816-7615-36-git-send-email-yinghai@kernel.org
Reviewed-and-tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Cc: linux-mips@linux-mips.org
Cc: xen-devel@lists.xensource.com
Cc: virtualization@lists.linux-foundation.org
Cc: Shuah Khan <shuahkhan@gmail.com>
This change makes it so that the sync functionality also uses physical
addresses. This helps to further reduce the use of virt_to_phys and
phys_to_virt functions.
In order to clarify things since we now have 2 physical addresses in use
inside of swiotlb_tbl_sync_single I am renaming phys to orig_addr, and
dma_addr to tlb_addr. This way is should be clear that orig_addr is
contained within io_orig_addr and tlb_addr is an address within the
io_tlb_addr buffer.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
This change makes it so that the unmap functionality also uses physical
inside of swiotlb_tbl_unmap_single I am renaming phys to orig_addr, and
io_tlb_addr buffer.
This change makes it so that swiotlb_tbl_map_single will return a physical
address instead of a virtual address when called. The advantage to this once
again is that we are avoiding a number of virt_to_phys and phys_to_virt
translations by working with everything as a physical address.
One change I had to make in order to support using physical addresses is that
I could no longer trust 0 to be a invalid physical address on all platforms.
So instead I made it so that ~0 is returned on error. This should never be a
valid return value as it implies that only one byte would be available for
use.
inside of swiotlb_tbl_map_single I am renaming phys to orig_addr, and
io_tlb_addr buffer.
* stable/late-swiotlb.v3.3:
xen/swiotlb: Fix compile warnings when using plain integer instead of NULL pointer.
xen/swiotlb: Remove functions not needed anymore.
xen/pcifront: Use Xen-SWIOTLB when initting if required.
xen/swiotlb: For early initialization, return zero on success.
xen/swiotlb: Use the swiotlb_late_init_with_tbl to init Xen-SWIOTLB late when PV PCI is used.
xen/swiotlb: Move the error strings to its own function.
xen/swiotlb: Move the nr_tbl determination in its own function.
swiotlb: add the late swiotlb initialization function with iotlb memory
xen/swiotlb: With more than 4GB on 64-bit, disable the native SWIOTLB.
xen/swiotlb: Simplify the logic.
arch/x86/xen/pci-swiotlb-xen.c
Sparse warns us off:
drivers/xen/swiotlb-xen.c:506:1: warning: symbol 'xen_swiotlb_map_sg' was not declared. Should it be static?
drivers/xen/swiotlb-xen.c:534:1: warning: symbol 'xen_swiotlb_unmap_sg' was not declared. Should it be static?
and it looks like we do not need this function at all.
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
If everything is setup properly we would return -ENOMEM since
rc by default is set to that value. Lets not do that and return
a proper return code.
Note: The reason the early code needs this special treatment
is that it SWIOTLB library call does not return anything (and
had it failed it would call panic()) - but our function does.
With this patch we provide the functionality to initialize the
Xen-SWIOTLB late in the bootup cycle - specifically for
Xen PCI-frontend. We still will work if the user had
supplied 'iommu=soft' on the Linux command line.
Note: We cannot depend on after_bootmem to automatically
determine whether this is early or not. This is because
when PCI IOMMUs are initialized it is after after_bootmem but
before a lot of "other" subsystems are initialized.
CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
[v1: Fix smatch warnings]
[v2: Added check for xen_swiotlb]
[v3: Rebased with new xen-swiotlb changes]
[v4: squashed xen/swiotlb: Depending on after_bootmem is not correct in]
That way we can more easily reuse those errors when using the
late SWIOTLB init.
Moving the function out of the way to prepare for the late
SWIOTLB init.
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into stable/for-linus-3.7
* 'x86/platform' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (9690 commits)
x86: Document x86_init.paging.pagetable_init()
x86: xen: Cleanup and remove x86_init.paging.pagetable_setup_done()
x86: Move paging_init() call to x86_init.paging.pagetable_init()
x86: Rename pagetable_setup_start() to pagetable_init()
x86: Remove base argument from x86_init.paging.pagetable_setup_start
Linux 3.6-rc5
HID: tpkbd: work even if the new Lenovo Keyboard driver is not configured
Remove user-triggerable BUG from mpol_to_str
xen/pciback: Fix proper FLR steps.
uml: fix compile error in deliver_alarm()
dj: memory scribble in logi_dj
Fix order of arguments to compat_put_time[spec|val]
xen: Use correct masking in xen_swiotlb_alloc_coherent.
xen: fix logical error in tlb flushing
xen/p2m: Fix one-off error in checking the P2M tree directory.
powerpc: Don't use __put_user() in patch_instruction
powerpc: Make sure IPI handlers see data written by IPI senders
powerpc: Restore correct DSCR in context switch
powerpc: Fix DSCR inheritance in copy_thread()
powerpc: Keep thread.dscr and thread.dscr_inherit in sync
When running 32-bit pvops-dom0 and a driver tries to allocate a coherent
DMA-memory the xen swiotlb-implementation returned memory beyond 4GB.
The underlaying reason is that if the supplied driver passes in a
DMA_BIT_MASK(64) ( hwdev->coherent_dma_mask is set to 0xffffffffffffffff)
our dma_mask will be u64 set to 0xffffffffffffffff even if we set it to
DMA_BIT_MASK(32) previously. Meaning we do not reset the upper bits.
By using the dma_alloc_coherent_mask function - it does the proper casting
and we get 0xfffffffff.
This caused not working sound on a system with 4 GB and a 64-bit
compatible sound-card with sets the DMA-mask to 64bit.
On bare-metal and the forward-ported xen-dom0 patches from OpenSuse a coherent
DMA-memory is always allocated inside the 32-bit address-range by calling
dma_alloc_coherent_mask.
This patch adds the same functionality to xen swiotlb and is a rebase of the
original patch from Ronny Hegewald which never got upstream b/c the
underlaying reason was not understood until now.
The original email with the original patch is in:
http://old-list-archives.xen.org/archives/html/xen-devel/2010-02/msg00038.html
the original thread from where the discussion started is in:
http://old-list-archives.xen.org/archives/html/xen-devel/2010-01/msg00928.html
Signed-off-by: Ronny Hegewald <ronny.hegewald@online.de>
Signed-off-by: Stefano Panella <stefano.panella@citrix.com>
Acked-By: David Vrabel <david.vrabel@citrix.com>
There is no need for those functions/variables to be visible. Make them
static and also fix the compile warnings of this sort:
drivers/xen/<some file>.c: warning: symbol '<blah>' was not declared. Should it be static?
Some of them just require including the header file that
declares the functions.
Adapt core x86 and IA64 architecture code for dma_map_ops changes: replace
alloc/free_coherent with generic alloc/free methods.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
[removed swiotlb related changes and replaced it with wrappers,
merged with IA64 patch to avoid inter-patch dependences in intel-iommu code]
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Tony Luck <tony.luck@intel.com>
