run simultaneously without deadlock
commit 10dce8af34226d90fa56746a934f8da5dcdba3df upstream.
Commit 9c225f2655e3 ("vfs: atomic f_pos accesses as per POSIX") added
locking for file.f_pos access and in particular made concurrent read and
write not possible - now both those functions take f_pos lock for the
whole run, and so if e.g. a read is blocked waiting for data, write will
deadlock waiting for that read to complete.
This caused regression for stream-like files where previously read and
write could run simultaneously, but after that patch could not do so
anymore. See e.g. commit 581d21a2d02a ("xenbus: fix deadlock on writes
to /proc/xen/xenbus") which fixes such regression for particular case of
/proc/xen/xenbus.
The patch that added f_pos lock in 2014 did so to guarantee POSIX thread
safety for read/write/lseek and added the locking to file descriptors of
all regular files. In 2014 that thread-safety problem was not new as it
was already discussed earlier in 2006.
However even though 2006'th version of Linus's patch was adding f_pos
locking "only for files that are marked seekable with FMODE_LSEEK (thus
avoiding the stream-like objects like pipes and sockets)", the 2014
version - the one that actually made it into the tree as 9c225f2655e3 -
is doing so irregardless of whether a file is seekable or not.
See
https://lore.kernel.org/lkml/53022DB1.4070805@gmail.com/
https://lwn.net/Articles/180387
https://lwn.net/Articles/180396
for historic context.
The reason that it did so is, probably, that there are many files that
are marked non-seekable, but e.g. their read implementation actually
depends on knowing current position to correctly handle the read. Some
examples:
kernel/power/user.c snapshot_read
fs/debugfs/file.c u32_array_read
fs/fuse/control.c fuse_conn_waiting_read + ...
drivers/hwmon/asus_atk0110.c atk_debugfs_ggrp_read
arch/s390/hypfs/inode.c hypfs_read_iter
Despite that, many nonseekable_open users implement read and write with
pure stream semantics - they don't depend on passed ppos at all. And for
those cases where read could wait for something inside, it creates a
situation similar to xenbus - the write could be never made to go until
read is done, and read is waiting for some, potentially external, event,
for potentially unbounded time -> deadlock.
Besides xenbus, there are 14 such places in the kernel that I've found
with semantic patch (see below):
drivers/xen/evtchn.c:667:8-24: ERROR: evtchn_fops: .read() can deadlock .write()
drivers/isdn/capi/capi.c:963:8-24: ERROR: capi_fops: .read() can deadlock .write()
drivers/input/evdev.c:527:1-17: ERROR: evdev_fops: .read() can deadlock .write()
drivers/char/pcmcia/cm4000_cs.c:1685:7-23: ERROR: cm4000_fops: .read() can deadlock .write()
net/rfkill/core.c:1146:8-24: ERROR: rfkill_fops: .read() can deadlock .write()
drivers/s390/char/fs3270.c:488:1-17: ERROR: fs3270_fops: .read() can deadlock .write()
drivers/usb/misc/ldusb.c:310:1-17: ERROR: ld_usb_fops: .read() can deadlock .write()
drivers/hid/uhid.c:635:1-17: ERROR: uhid_fops: .read() can deadlock .write()
net/batman-adv/icmp_socket.c:80:1-17: ERROR: batadv_fops: .read() can deadlock .write()
drivers/media/rc/lirc_dev.c:198:1-17: ERROR: lirc_fops: .read() can deadlock .write()
drivers/leds/uleds.c:77:1-17: ERROR: uleds_fops: .read() can deadlock .write()
drivers/input/misc/uinput.c:400:1-17: ERROR: uinput_fops: .read() can deadlock .write()
drivers/infiniband/core/user_mad.c:985:7-23: ERROR: umad_fops: .read() can deadlock .write()
drivers/gnss/core.c:45:1-17: ERROR: gnss_fops: .read() can deadlock .write()
In addition to the cases above another regression caused by f_pos
locking is that now FUSE filesystems that implement open with
FOPEN_NONSEEKABLE flag, can no longer implement bidirectional
stream-like files - for the same reason as above e.g. read can deadlock
write locking on file.f_pos in the kernel.
FUSE's FOPEN_NONSEEKABLE was added in 2008 in a7c1b990f715 ("fuse:
implement nonseekable open") to support OSSPD. OSSPD implements /dev/dsp
in userspace with FOPEN_NONSEEKABLE flag, with corresponding read and
write routines not depending on current position at all, and with both
read and write being potentially blocking operations:
See
https://github.com/libfuse/osspd
https://lwn.net/Articles/308445
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1406
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1438-L1477
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1479-L1510
Corresponding libfuse example/test also describes FOPEN_NONSEEKABLE as
"somewhat pipe-like files ..." with read handler not using offset.
However that test implements only read without write and cannot exercise
the deadlock scenario:
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L124-L131
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L146-L163
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L209-L216
I've actually hit the read vs write deadlock for real while implementing
my FUSE filesystem where there is /head/watch file, for which open
creates separate bidirectional socket-like stream in between filesystem
and its user with both read and write being later performed
simultaneously. And there it is semantically not easy to split the
stream into two separate read-only and write-only channels:
https://lab.nexedi.com/kirr/wendelin.core/blob/f13aa600/wcfs/wcfs.go#L88-169
Let's fix this regression. The plan is:
1. We can't change nonseekable_open to include &~FMODE_ATOMIC_POS -
doing so would break many in-kernel nonseekable_open users which
actually use ppos in read/write handlers.
2. Add stream_open() to kernel to open stream-like non-seekable file
descriptors. Read and write on such file descriptors would never use
nor change ppos. And with that property on stream-like files read and
write will be running without taking f_pos lock - i.e. read and write
could be running simultaneously.
3. With semantic patch search and convert to stream_open all in-kernel
nonseekable_open users for which read and write actually do not
depend on ppos and where there is no other methods in file_operations
which assume @offset access.
4. Add FOPEN_STREAM to fs/fuse/ and open in-kernel file-descriptors via
steam_open if that bit is present in filesystem open reply.
It was tempting to change fs/fuse/ open handler to use stream_open
instead of nonseekable_open on just FOPEN_NONSEEKABLE flags, but
grepping through Debian codesearch shows users of FOPEN_NONSEEKABLE,
and in particular GVFS which actually uses offset in its read and
write handlers
https://codesearch.debian.net/search?q=-%3Enonseekable+%3D
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1080
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1247-1346
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1399-1481
so if we would do such a change it will break a real user.
5. Add stream_open and FOPEN_STREAM handling to stable kernels starting
from v3.14+ (the kernel where 9c225f2655 first appeared).
This will allow to patch OSSPD and other FUSE filesystems that
provide stream-like files to return FOPEN_STREAM | FOPEN_NONSEEKABLE
in their open handler and this way avoid the deadlock on all kernel
versions. This should work because fs/fuse/ ignores unknown open
flags returned from a filesystem and so passing FOPEN_STREAM to a
kernel that is not aware of this flag cannot hurt. In turn the kernel
that is not aware of FOPEN_STREAM will be < v3.14 where just
FOPEN_NONSEEKABLE is sufficient to implement streams without read vs
write deadlock.
This patch adds stream_open, converts /proc/xen/xenbus to it and adds
semantic patch to automatically locate in-kernel places that are either
required to be converted due to read vs write deadlock, or that are just
safe to be converted because read and write do not use ppos and there
are no other funky methods in file_operations.
Regarding semantic patch I've verified each generated change manually -
that it is correct to convert - and each other nonseekable_open instance
left - that it is either not correct to convert there, or that it is not
converted due to current stream_open.cocci limitations.
The script also does not convert files that should be valid to convert,
but that currently have .llseek = noop_llseek or generic_file_llseek for
unknown reason despite file being opened with nonseekable_open (e.g.
drivers/input/mousedev.c)
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Yongzhi Pan <panyongzhi@gmail.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Tejun Heo <tj@kernel.org>
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Nikolaus Rath <Nikolaus@rath.org>
Cc: Han-Wen Nienhuys <hanwen@google.com>
Signed-off-by: Kirill Smelkov <kirr@nexedi.com>
[ Upstream commit 351b2bccede1cb673ec7957b35ea997ea24c8884 ]
Never directly free @dev after calling device_register(), even
if it returned an error! Always use put_device() to give up the
reference initialized.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
[ Upstream commit 639b08810d6ad74ded2c5f6e233c4fcb9d147168 ]
When accessing Xenstore in a transaction the user is specifying a
transaction id which he normally obtained from Xenstore when starting
the transaction. Xenstore is validating a transaction id against all
known transaction ids of the connection the request came in. As all
requests of a domain not being the one where Xenstore lives share
one connection, validation of transaction ids of different users of
Xenstore in that domain should be done by the kernel of that domain
being the multiplexer between the Xenstore users in that domain and
Xenstore.
In order to prohibit one Xenstore user "hijacking" a transaction from
another user the xenbus driver has to verify a given transaction id
against all known transaction ids of the user before forwarding it to
Xenstore.
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from David Vrabel:
- advertise control feature flags in xenstore
- fix x86 build when XEN_PVHVM is disabled
* tag 'for-linus-4.9-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xenbus: check return value of xenbus_scanf()
xenbus: prefer list_for_each()
x86: xen: move cpu_up functions out of ifdef
xenbus: advertise control feature flags
Don't ignore errors here: Set backend state to unknown when
unsuccessful.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
This is more efficient than list_for_each_safe() when list modification
is accompanied by breaking out of the loop.
This should really only be done for XS_TRANSACTION_END messages, or
else at least some of the xenstore-* tools don't work anymore.
Fixes: 0beef634b8 ("xenbus: don't BUG() on user mode induced condition")
Reported-by: Richard Schütz <rschuetz@uni-koblenz.de>
Cc: <stable@vger.kernel.org>
Tested-by: Richard Schütz <rschuetz@uni-koblenz.de>
Pull xen updates from David Vrabel:
"Features and fixes for 4.8-rc0:
- ACPI support for guests on ARM platforms.
- Generic steal time support for arm and x86.
- Support cases where kernel cpu is not Xen VCPU number (e.g., if
in-guest kexec is used).
- Use the system workqueue instead of a custom workqueue in various
places"
* tag 'for-linus-4.8-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (47 commits)
xen: add static initialization of steal_clock op to xen_time_ops
xen/pvhvm: run xen_vcpu_setup() for the boot CPU
xen/evtchn: use xen_vcpu_id mapping
xen/events: fifo: use xen_vcpu_id mapping
xen/events: use xen_vcpu_id mapping in events_base
x86/xen: use xen_vcpu_id mapping when pointing vcpu_info to shared_info
x86/xen: use xen_vcpu_id mapping for HYPERVISOR_vcpu_op
xen: introduce xen_vcpu_id mapping
x86/acpi: store ACPI ids from MADT for future usage
x86/xen: update cpuid.h from Xen-4.7
xen/evtchn: add IOCTL_EVTCHN_RESTRICT
xen-blkback: really don't leak mode property
xen-blkback: constify instance of "struct attribute_group"
xen-blkfront: prefer xenbus_scanf() over xenbus_gather()
xen-blkback: prefer xenbus_scanf() over xenbus_gather()
xen: support runqueue steal time on xen
arm/xen: add support for vm_assist hypercall
xen: update xen headers
xen-pciback: drop superfluous variables
xen-pciback: short-circuit read path used for merging write values
No need to retain a local copy of the full request message, only the
type is really needed.
xenbus_dev_request_and_reply() needs to track whether a transaction is
open. For XS_TRANSACTION_START messages it calls transaction_start()
and for XS_TRANSACTION_END messages it calls transaction_end().
If sending an XS_TRANSACTION_START message fails or responds with an
an error, the transaction is not open and transaction_end() must be
called.
If sending an XS_TRANSACTION_END message fails, the transaction is
still open, but if an error response is returned the transaction is
closed.
Commit 027bd7e89906 ("xen/xenbus: Avoid synchronous wait on XenBus
stalling shutdown/restart") introduced a regression where failed
XS_TRANSACTION_START messages were leaving the transaction open. This
can cause problems with suspend (and migration) as all transactions
must be closed before suspending.
It appears that the problematic change was added accidentally, so just
remove it.
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Inability to locate a user mode specified transaction ID should not
lead to a kernel crash. For other than XS_TRANSACTION_START also
don't issue anything to xenbus if the specified ID doesn't match that
of any active transaction.
System workqueues have been able to handle high level of concurrency
for a long time now and there's no reason to use dedicated workqueues
just to gain concurrency. Replace dedicated xenbus_frontend_wq with the
use of system_wq.
Unlike a dedicated per-cpu workqueue created with create_workqueue(),
system_wq allows multiple work items to overlap executions even on
the same CPU; however, a per-cpu workqueue doesn't have any CPU
locality or global ordering guarantees unless the target CPU is
explicitly specified and the increase of local concurrency shouldn't
make any difference.
In this case, there is only a single work item, increase of concurrency
level by switching to system_wq should not make any difference.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
"Features and fixes for 4.6:
- Make earlyprintk=xen work for HVM guests
- Remove module support for things never built as modules"
* tag 'for-linus-4.6-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
drivers/xen: make platform-pci.c explicitly non-modular
drivers/xen: make sys-hypervisor.c explicitly non-modular
drivers/xen: make xenbus_dev_[front/back]end explicitly non-modular
drivers/xen: make [xen-]ballon explicitly non-modular
xen: audit usages of module.h ; remove unnecessary instances
xen/x86: Drop mode-selecting ifdefs in startup_xen()
xen/x86: Zero out .bss for PV guests
hvc_xen: make early_printk work with HVM guests
hvc_xen: fix xenboot for DomUs
hvc_xen: add earlycon support
The Makefile / Kconfig currently controlling compilation here is:
obj-y += xenbus_dev_frontend.o
obj-$(CONFIG_XEN_BACKEND) += xenbus_dev_backend.o
...with:
drivers/xen/Kconfig:config XEN_BACKEND
drivers/xen/Kconfig: bool "Backend driver support"
...meaning that they currently are not being built as modules by anyone.
Lets remove the modular code that is essentially orphaned, so that
when reading the driver there is no doubt it is builtin-only.
Since module_init translates to device_initcall in the non-modular
case, the init ordering remains unchanged with this commit.
We also delete the MODULE_LICENSE tag since all that information
is already contained at the top of the file in the comments.
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Code that uses no modular facilities whatsoever should not be
sourcing module.h at all, since that header drags in a bunch
of other headers with it.
Similarly, code that is not explicitly using modular facilities
like module_init() but only is declaring module_param setup
variables should be using moduleparam.h and not the larger
module.h file for that.
In making this change, we also uncover an implicit use of BUG()
in inline fcns within arch/arm/include/asm/xen/hypercall.h so
we explicitly source <linux/bug.h> for that file now.
Pull xen bug fixes from David Vrabel:
- Two scsiback fixes (resource leak and spurious warning).
- Fix DMA mapping of compound pages on arm/arm64.
- Fix some pciback regressions in MSI-X handling.
- Fix a pcifront crash due to some uninitialize state.
* tag 'for-linus-4.5-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/pcifront: Fix mysterious crashes when NUMA locality information was extracted.
xen/pcifront: Report the errors better.
xen/pciback: Save the number of MSI-X entries to be copied later.
xen/pciback: Check PF instead of VF for PCI_COMMAND_MEMORY
xen: fix potential integer overflow in queue_reply
xen/arm: correctly handle DMA mapping of compound pages
xen/scsiback: avoid warnings when adding multiple LUNs to a domain
xen/scsiback: correct frontend counting
When len is greater than UINT_MAX - sizeof(*rb), in next allocation,
it can overflow integer range and allocates small size of heap.
After that, memcpy will overflow the allocated heap.
Therefore, it needs to check the size of given length.
Signed-off-by: Insu Yun <wuninsu@gmail.com>
drivers/xen/xenbus/xenbus_comms.c uses
full memory barriers to communicate with the other side.
For guests compiled with CONFIG_SMP, smp_wmb and smp_mb
would be sufficient, so mb() and wmb() here are only needed if
a non-SMP guest runs on an SMP host.
Switch to virt_xxx barriers which serve this exact purpose.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
The PV ring may use multiple grants and expect them to be mapped
contiguously in the virtual memory.
Although, the current code is relying on a Linux page will be mapped to
a single grant. On build where Linux is using a different page size than
the grant (i.e other than 4KB), the grant will always be mapped on the
first 4KB of each Linux page which make the final ring not contiguous in
the memory.
This can be fixed by mapping multiple grant in a same Linux page.
Signed-off-by: Julien Grall <julien.grall@citrix.com>
Linux may use a different page size than the size of grant. So make
clear that the order is actually in number of grant.
All the ring (xenstore, and PV rings) are always based on the page
granularity of Xen.
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
All users of alloc_xenballoon_pages() wanted low memory pages, so
remove the option for high memory.
Reviewed-by: Daniel Kiper <daniel.kiper@oracle.com>
The variable xen_store_mfn is effectively storing a GFN and not an MFN.
Based on include/xen/mm.h [1], Linux is mistakenly using MFN when GFN
is meant, I suspect this is because the first support for Xen was for
PV. This resulted in some misimplementation of helpers on ARM and
confused developers about the expected behavior.
For instance, with pfn_to_mfn, we expect to get an MFN based on the name.
Although, if we look at the implementation on x86, it's returning a GFN.
For clarity and avoid new confusion, replace any reference to mfn with
gfn in any helpers used by PV drivers. The x86 code will still keep some
reference of pfn_to_mfn which may be used by all kind of guests
No changes as been made in the hypercall field, even
though they may be invalid, in order to keep the same as the defintion
in xen repo.
Note that page_to_mfn has been renamed to xen_page_to_gfn to avoid a
name to close to the KVM function gfn_to_page.
Take also the opportunity to simplify simple construction such
as pfn_to_mfn(page_to_pfn(page)) into xen_page_to_gfn. More complex clean up
will come in follow-up patches.
[1] http://xenbits.xen.org/gitweb/?p=xen.git;a=commitdiff;h=e758ed14f390342513405dd766e874934573e6cb
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
The commit ccc9d90a9a8b5c4ad7e9708ec41f75ff9e98d61d "xenbus_client:
Extend interface to support multi-page ring" removes the call to
free_xenballooned_pages() in xenbus_unmap_ring_vfree_hvm(), leaking a
page for every shared ring.
Only with backends running in HVM domains were affected.
Reviewed-by: Wei Liu <wei.liu2@citrix.com>
virt_to_mfn should take a void* rather an unsigned long. While it
doesn't really matter now, it would throw a compiler warning later when
virt_to_mfn will enforce the type.
At the same time, avoid to compute new virtual address every time in the
loop and directly increment the parameter as we don't use it later.
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Using xen/page.h will be necessary later for using common xen page
helpers.
As xen/page.h already include asm/xen/page.h, always use the later.
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: netdev@vger.kernel.org
Older compilers don't recognize that "v" can't be used uninitialized;
other code using hvm_get_parameter() zeros the value too, so follow
suit here.
After a resume the hypervisor/tools may change xenbus event
channel number. We should re-query it.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Originally Xen PV drivers only use single-page ring to pass along
information. This might limit the throughput between frontend and
backend.
The patch extends Xenbus driver to support multi-page ring, which in
general should improve throughput if ring is the bottleneck. Changes to
various frontend / backend to adapt to the new interface are also
included.
Affected Xen drivers:
* blkfront/back
* netfront/back
* pcifront/back
* scsifront/back
* vtpmfront
The interface is documented, as before, in xenbus_client.c.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Signed-off-by: Bob Liu <bob.liu@oracle.com>
Cc: Konrad Wilk <konrad.wilk@oracle.com>
If Xenstore sends back a XS_ERROR for TRANSACTION_END, the driver BUGs
because it cannot find the matching transaction in the list. For
TRANSACTION_START, it leaks memory.
Check the message as returned from xenbus_dev_request_and_reply(), and
clean up for TRANSACTION_START or discard the error for
TRANSACTION_END.
Signed-off-by: Jennifer Herbert <Jennifer.Herbert@citrix.com>
The DEFINE_XENBUS_DRIVER() macro looks a bit weird and causes sparse
errors.
Replace the uses with standard structure definitions instead. This is
similar to pci and usb device registration.
xenbus_va_dev_error() is for printing error, so when error string is
too long to be truncated, need not BUG_ON(), still return truncation
string is OK.
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
A grant reference (which is a positive number) can indicate success, so
the original comments need be improved.
The 'read_reply' works with 'process_msg' to read of a reply in XenBus.
'process_msg' is running from within the 'xenbus' thread. Whenever
a message shows up in XenBus it is put on a xs_state.reply_list list
and 'read_reply' picks it up.
The problem is if the backend domain or the xenstored process is killed.
In which case 'xenbus' is still awaiting - and 'read_reply' if called -
stuck forever waiting for the reply_list to have some contents.
This is normally not a problem - as the backend domain can come back
or the xenstored process can be restarted. However if the domain
is in process of being powered off/restarted/halted - there is no
point of waiting on it coming back - as we are effectively being
terminated and should not impede the progress.
This patch solves this problem by checking whether the guest is the
right domain. If it is an initial domain and hurtling towards death -
there is no point of continuing the wait. All other type of guests
continue with their behavior (as Xenstore is expected to still be
running in another domain).
Fixes-Bug: http://bugs.xenproject.org/xen/bug/8
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
xenbus_bind_evtchn() has no callers so remove it.
PVH is a PV guest with a twist - there are certain things
that work in it like HVM and some like PV. For the XenBus
mechanism we want to use the PVHVM mechanism.
Signed-off-by: Mukesh Rathor <mukesh.rathor@oracle.com>
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
The user has the option of disabling the platform driver:
00:02.0 Unassigned class [ff80]: XenSource, Inc. Xen Platform Device (rev 01)
which is used to unplug the emulated drivers (IDE, Realtek 8169, etc)
and allow the PV drivers to take over. If the user wishes
to disable that they can set:
xen_platform_pci=0
(in the guest config file)
or
xen_emul_unplug=never
(on the Linux command line)
except it does not work properly. The PV drivers still try to
load and since the Xen platform driver is not run - and it
has not initialized the grant tables, most of the PV drivers
stumble upon:
input: Xen Virtual Keyboard as /devices/virtual/input/input5
input: Xen Virtual Pointer as /devices/virtual/input/input6M
kernel BUG at /home/konrad/ssd/konrad/linux/drivers/xen/grant-table.c:1206!
invalid opcode: 0000 [#1] SMP
Modules linked in: xen_kbdfront(+) xenfs xen_privcmd
CPU: 6 PID: 1389 Comm: modprobe Not tainted 3.13.0-rc1upstream-00021-ga6c892b-dirty #1
Hardware name: Xen HVM domU, BIOS 4.4-unstable 11/26/2013
RIP: 0010:[<ffffffff813ddc40>] [<ffffffff813ddc40>] get_free_entries+0x2e0/0x300
Call Trace:
[<ffffffff8150d9a3>] ? evdev_connect+0x1e3/0x240
[<ffffffff813ddd0e>] gnttab_grant_foreign_access+0x2e/0x70
[<ffffffffa0010081>] xenkbd_connect_backend+0x41/0x290 [xen_kbdfront]
[<ffffffffa0010a12>] xenkbd_probe+0x2f2/0x324 [xen_kbdfront]
[<ffffffff813e5757>] xenbus_dev_probe+0x77/0x130
[<ffffffff813e7217>] xenbus_frontend_dev_probe+0x47/0x50
[<ffffffff8145e9a9>] driver_probe_device+0x89/0x230
[<ffffffff8145ebeb>] __driver_attach+0x9b/0xa0
[<ffffffff8145eb50>] ? driver_probe_device+0x230/0x230
[<ffffffff8145cf1c>] bus_for_each_dev+0x8c/0xb0
[<ffffffff8145e7d9>] driver_attach+0x19/0x20
[<ffffffff8145e260>] bus_add_driver+0x1a0/0x220
[<ffffffff8145f1ff>] driver_register+0x5f/0xf0
[<ffffffff813e55c5>] xenbus_register_driver_common+0x15/0x20
[<ffffffff813e76b3>] xenbus_register_frontend+0x23/0x40
[<ffffffffa0015000>] ? 0xffffffffa0014fff
[<ffffffffa001502b>] xenkbd_init+0x2b/0x1000 [xen_kbdfront]
[<ffffffff81002049>] do_one_initcall+0x49/0x170
.. snip..
which is hardly nice. This patch fixes this by having each
PV driver check for:
- if running in PV, then it is fine to execute (as that is their
native environment).
- if running in HVM, check if user wanted 'xen_emul_unplug=never',
in which case bail out and don't load any PV drivers.
- if running in HVM, and if PCI device 5853:0001 (xen_platform_pci)
does not exist, then bail out and not load PV drivers.
- (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=ide-disks',
then bail out for all PV devices _except_ the block one.
Ditto for the network one ('nics').
- (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=unnecessary'
then load block PV driver, and also setup the legacy IDE paths.
In (v3) make it actually load PV drivers.
Reported-by: Sander Eikelenboom <linux@eikelenboom.it
Reported-by: Anthony PERARD <anthony.perard@citrix.com>
Reported-and-Tested-by: Fabio Fantoni <fabio.fantoni@m2r.biz>
[v2: Add extra logic to handle the myrid ways 'xen_emul_unplug'
can be used per Ian and Stefano suggestion]
[v3: Make the unnecessary case work properly]
[v4: s/disks/ide-disks/ spotted by Fabio]
Acked-by: Bjorn Helgaas <bhelgaas@google.com> [for PCI parts]
CC: stable@vger.kernel.org
The dev_attrs field of struct bus_type is going away soon, dev_groups
should be used instead. This converts the xenbus code to use the
correct field.
Acked-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: <xen-devel@lists.xenproject.org>
Pull Xen fixes from Konrad Rzeszutek Wilk:
- Three fixes for ARM/ARM64 to either compile or not certain generic
drivers
- Fix for avoiding a potential deadlock when an user space event
channel is destroyed.
- Fix a workqueue resuming multiple times.
* tag 'stable/for-linus-3.11-rc3-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/tmem: do not allow XEN_TMEM on ARM64
xen/evtchn: avoid a deadlock when unbinding an event channel
xen/arm: enable PV control for ARM
xen/arm64: Don't compile cpu hotplug
xenbus: frontend resume cleanup
Only create the delayed resume workqueue if we are running in the same domain
as xenstored and issue a warning if the workqueue creation fails.
Move the work initialization to the device probe so it is done only once.
Signed-off-by: Aurelien Chartier <aurelien.chartier@citrix.com>
Merge first patch-bomb from Andrew Morton:
- various misc bits
- I'm been patchmonkeying ocfs2 for a while, as Joel and Mark have been
distracted. There has been quite a bit of activity.
- About half the MM queue
- Some backlight bits
- Various lib/ updates
- checkpatch updates
- zillions more little rtc patches
- ptrace
- signals
- exec
- procfs
- rapidio
- nbd
- aoe
- pps
- memstick
- tools/testing/selftests updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (445 commits)
tools/testing/selftests: don't assume the x bit is set on scripts
selftests: add .gitignore for kcmp
selftests: fix clean target in kcmp Makefile
selftests: add .gitignore for vm
selftests: add hugetlbfstest
self-test: fix make clean
selftests: exit 1 on failure
kernel/resource.c: remove the unneeded assignment in function __find_resource
aio: fix wrong comment in aio_complete()
drivers/w1/slaves/w1_ds2408.c: add magic sequence to disable P0 test mode
drivers/memstick/host/r592.c: convert to module_pci_driver
drivers/memstick/host/jmb38x_ms: convert to module_pci_driver
pps-gpio: add device-tree binding and support
drivers/pps/clients/pps-gpio.c: convert to module_platform_driver
drivers/pps/clients/pps-gpio.c: convert to devm_* helpers
drivers/parport/share.c: use kzalloc
Documentation/accounting/getdelays.c: avoid strncpy in accounting tool
aoe: update internal version number to v83
aoe: update copyright date
aoe: perform I/O completions in parallel
Calling dev_set_name with a single paramter causes it to be handled as a
format string. Many callers are passing potentially dynamic string
content, so use "%s" in those cases to avoid any potential accidents,
including wrappers like device_create*() and bdi_register().
Convert printks to pr_<level> (excludes printk(KERN_DEBUG...)
to be more consistent throughout the xen subsystem.
Add pr_fmt with KBUILD_MODNAME or "xen:" KBUILD_MODNAME
Coalesce formats and add missing word spaces
Add missing newlines
Align arguments and reflow to 80 columns
Remove DRV_NAME from formats as pr_fmt adds the same content
This does change some of the prefixes of these messages
but it also does make them more consistent.
Apparently we should not free page that has not been allocated.
This is b/c alloc_xenballooned_pages will take care of freeing
the page on its own.
Save the xenstore local status computed in xenbus_init. It can then be used
later to check if xenstored is running in this domain.
[Changes in v4:
- Change variable name to xen_store_domain_type]
If the xenbus frontend is located in a domain running xenstored, the device
resume is hanging because it is happening before the process resume. This
patch adds extra logic to the resume code to check if we are the domain
running xenstored and delay the resume if needed.
[Changes in v2:
- Instead of bypassing the resume, process it in a workqueue]
[Changes in v3:
- Add a struct work in xenbus_device to avoid dynamic allocation
- Several small code fixes]
[Changes in v4:
- Use a dedicated workqueue]
[Changes in v5:
- Move create_workqueue error handling to xenbus_frontend_dev_resume]
Acked-by: Jan Beulich <jbeulich@suse.com>
Fixed the format length of the xenbus_backend_ioctl()
function to meet the 80 character limit in
xenbus_dev_backend.c
Signed-off-by: Lisa Nguyen <lisa@xenapiadmin.com>
Fixed the indentation error in the switch case in
Adding an include of linux/mm.h resolves this:
drivers/xen/xenbus/xenbus_client.c: In function ‘xenbus_map_ring_valloc_hvm’:
drivers/xen/xenbus/xenbus_client.c:532:66: error: implicit declaration of function ‘page_to_section’ [-Werror=implicit-function-declaration]
Signed-off-by: Steven Noonan <steven@uplinklabs.net>
