path: root/drivers/xen/xenbus
2008-04-24xen: Module autoprobing support for frontend driversMark McLoughlin
Add module aliases to support autoprobing modules for xen frontend devices. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen blkfront: Delay wait for block devices until after the disk is addedChristian Limpach
When the xen block frontend driver is built as a module the module load is only synchronous up to the point where the frontend and the backend become connected rather than when the disk is added. This means that there can be a race on boot between loading the module and loading the dm-* modules and doing the scan for LVM physical volumes (all in the initrd). In the failure case the disk is not present until after the scan for physical volumes is complete. Taken from: http://xenbits.xensource.com/linux-2.6.18-xen.hg?rev/11483a00c017 Signed-off-by: Christian Limpach <Christian.Limpach@xensource.com> Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24xen: replace callers of alloc_vm_area()/free_vm_area() with xen_ prefixed oneIsaku Yamahata
Don't use alloc_vm_area()/free_vm_area() directly, instead define xen_alloc_vm_area()/xen_free_vm_area() and use them. alloc_vm_area()/free_vm_area() are used to allocate/free area which are for grant table mapping. Xen/x86 grant table is based on virtual address so that alloc_vm_area()/free_vm_area() are suitable. On the other hand Xen/ia64 (and Xen/powerpc) grant table is based on pseudo physical address (guest physical address) so that allocation should be done differently. The original version of xenified Linux/IA64 have its own allocate_vm_area()/free_vm_area() definitions which don't allocate vm area contradictory to those names. Now vanilla Linux already has its definitions so that it's impossible to have IA64 definitions of allocate_vm_area()/free_vm_area(). Instead introduce xen_allocate_vm_area()/xen_free_vm_area() and use them. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26xenbus_xs.c: fix a use-after-freeAdrian Bunk
This patch fixes an obvious use-after-free spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18xen: add the Xenbus sysfs and virtual device hotplug driverJeremy Fitzhardinge
This communicates with the machine control software via a registry residing in a controlling virtual machine. This allows dynamic creation, destruction and modification of virtual device configurations (network devices, block devices and CPUS, to name some examples). [ Greg, would you mind giving this a review? Thanks -J ] Signed-off-by: Ian Pratt <ian.pratt@xensource.com> Signed-off-by: Christian Limpach <Christian.Limpach@cl.cam.ac.uk> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Greg KH <greg@kroah.com>
