path: root/drivers/xen
2014-06-04Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core irq updates from Thomas Gleixner: "The irq department delivers: - Another tree wide update to get rid of the horrible create_irq interface along with its even more horrible variants. That also gets rid of the last leftovers of the initial sparse irq hackery. arch/driver specific changes have been either acked or ignored. - A fix for the spurious interrupt detection logic with threaded interrupts. - A new ARM SoC interrupt controller - The usual pile of fixes and improvements all over the place" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) Documentation: brcmstb-l2: Add Broadcom STB Level-2 interrupt controller binding irqchip: brcmstb-l2: Add Broadcom Set Top Box Level-2 interrupt controller genirq: Improve documentation to match current implementation ARM: iop13xx: fix msi support with sparse IRQ genirq: Provide !SMP stub for irq_set_affinity_notifier() irqchip: armada-370-xp: Move the devicetree binding documentation irqchip: gic: Use mask field in GICC_IAR genirq: Remove dynamic_irq mess ia64: Use irq_init_desc genirq: Replace dynamic_irq_init/cleanup genirq: Remove irq_reserve_irq[s] genirq: Replace reserve_irqs in core code s390: Avoid call to irq_reserve_irqs() s390: Remove pointless arch_show_interrupts() s390: pci: Check return value of alloc_irq_desc() proper sh: intc: Remove pointless irq_reserve_irqs() invocation x86, irq: Remove pointless irq_reserve_irqs() call genirq: Make create/destroy_irq() ia64 private tile: Use SPARSE_IRQ tile: pci: Use irq_alloc/free_hwirq() ...
2014-06-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core locking updates from Ingo Molnar: "The main changes in this cycle were: - reduced/streamlined smp_mb__*() interface that allows more usecases and makes the existing ones less buggy, especially in rarer architectures - add rwsem implementation comments - bump up lockdep limits" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) rwsem: Add comments to explain the meaning of the rwsem's count field lockdep: Increase static allocations arch: Mass conversion of smp_mb__*() arch,doc: Convert smp_mb__*() arch,xtensa: Convert smp_mb__*() arch,x86: Convert smp_mb__*() arch,tile: Convert smp_mb__*() arch,sparc: Convert smp_mb__*() arch,sh: Convert smp_mb__*() arch,score: Convert smp_mb__*() arch,s390: Convert smp_mb__*() arch,powerpc: Convert smp_mb__*() arch,parisc: Convert smp_mb__*() arch,openrisc: Convert smp_mb__*() arch,mn10300: Convert smp_mb__*() arch,mips: Convert smp_mb__*() arch,metag: Convert smp_mb__*() arch,m68k: Convert smp_mb__*() arch,m32r: Convert smp_mb__*() arch,ia64: Convert smp_mb__*() ...
2014-06-02Merge tag 'stable/for-linus-3.16-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip into next Pull Xen updates from David Vrabel: "xen: features and fixes for 3.16-rc0 - support foreign mappings in PVH domains (needed when dom0 is PVH) - fix mapping high MMIO regions in x86 PV guests (this is also the first half of removing the PAGE_IOMAP PTE flag). - ARM suspend/resume support. - ARM multicall support" * tag 'stable/for-linus-3.16-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: x86/xen: map foreign pfns for autotranslated guests xen-acpi-processor: Don't display errors when we get -ENOSYS xen/pciback: Document the entry points for 'pcistub_put_pci_dev' xen/pciback: Document when the 'unbind' and 'bind' functions are called. xen-pciback: Document when we FLR an PCI device. xen-pciback: First reset, then free. xen-pciback: Cleanup up pcistub_put_pci_dev x86/xen: do not use _PAGE_IOMAP in xen_remap_domain_mfn_range() x86/xen: set regions above the end of RAM as 1:1 x86/xen: only warn once if bad MFNs are found during setup x86/xen: compactly store large identity ranges in the p2m x86/xen: fix set_phys_range_identity() if pfn_e > MAX_P2M_PFN x86/xen: rename early_p2m_alloc() and early_p2m_alloc_middle() xen/x86: set panic notifier priority to minimum arm,arm64/xen: introduce HYPERVISOR_suspend() xen: refactor suspend pre/post hooks arm: xen: export HYPERVISOR_multicall to modules. arm64: introduce virt_to_pfn arm/xen: Remove definiition of virt_to_pfn in asm/xen/page.h arm: xen: implement multicall hypercall support.
2014-05-23xen-acpi-processor: Don't display errors when we get -ENOSYSKonrad Rzeszutek Wilk
which is a perfectly legal error. This can be triggered if the user has booted Xen with the no-cpuidle parameter. Reported-by-and-Tested-by: Don Slutz <dslutz@verizon.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-05-23xen/pciback: Document the entry points for 'pcistub_put_pci_dev'Konrad Rzeszutek Wilk
which are quite a few. It should be evident that dealing with that many options is a bit complex. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-05-23xen/pciback: Document when the 'unbind' and 'bind' functions are called.Konrad Rzeszutek Wilk
And also mention that you cannot do any pci_reset_function, pci_reset_slot, or such calls. This is because they take the same lock as SysFS does - and we would end up with a dead-lock if we call those functions. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-05-23xen-pciback: Document when we FLR an PCI device.Konrad Rzeszutek Wilk
When the toolstack wants us to drop or add an PCI device it changes the XenBus state to Configuring - and as result of that we find out which devices we should still be exporting out and which ones not. For the ones we don't need anymore we need to do an PCI reset so that it is ready for the next guest. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-05-23xen-pciback: First reset, then free.Konrad Rzeszutek Wilk
We were doing the operations of freeing and reset in the wrong order. Granted nothing broke because the reset functions just set bar->which = 0. But nonethless this was incorrect. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Jan Beulich <jbeulich@suse.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-05-23xen-pciback: Cleanup up pcistub_put_pci_devKonrad Rzeszutek Wilk
We are using 'psdev->dev','found_psdev->dev', and 'dev' at the same time - and they all point to the same structure. To keep it straight lets just use one - 'dev'. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Jan Beulich <jbeulich@suse.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-05-16x86: Get rid of get_nr_irqs_gsi()Thomas Gleixner
No need to expose this outside of the ioapic code. The dynamic allocations are guaranteed not to happen in the gsi space. See commit 62a08ae2a. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Grant Likely <grant.likely@linaro.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: x86@kernel.org Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/20140507154335.959870037@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-05-13Merge tag 'stable/for-linus-3.15-rc5-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen bug fixes from David Vrabel: - Fix arm64 crash on boot. - Quiet a noisy arm build warning (virt_to_pfn() redefined). * tag 'stable/for-linus-3.15-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: arm64: introduce virt_to_pfn xen/events/fifo: correctly align bitops arm/xen: Remove definiition of virt_to_pfn in asm/xen/page.h
2014-05-12xen: refactor suspend pre/post hooksDavid Vrabel
New architectures currently have to provide implementations of 5 different functions: xen_arch_pre_suspend(), xen_arch_post_suspend(), xen_arch_hvm_post_suspend(), xen_mm_pin_all(), and xen_mm_unpin_all(). Refactor the suspend code to only require xen_arch_pre_suspend() and xen_arch_post_suspend(). Signed-off-by: David Vrabel <david.vrabel@citrix.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
2014-04-28xen/events/fifo: correctly align bitopsVladimir Murzin
FIFO event channels require bitops on 32-bit aligned values (the event words). Linux's bitops require unsigned long alignment which may be 64-bits. On arm64 an incorrectly unaligned access will fault. Fix this by aligning the bitops along with an adjustment for bit position and using an unsigned long for the local copy of the ready word. Cc: stable@vger.kernel.org Signed-off-by: Vladimir Murzin <murzin.v@gmail.com> Tested-by: Pranavkumar Sawargaonkar <pranavkumar@linaro.org> Reviewed-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2014-04-18arch: Mass conversion of smp_mb__*()Peter Zijlstra
Mostly scripted conversion of the smp_mb__* barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-17Merge tag 'stable/for-linus-3.15-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen fixes from David Vrabel: "Xen regression and bug fixes for 3.15-rc1: - fix completely broken 32-bit PV guests caused by x86 refactoring 32-bit thread_info. - only enable ticketlock slow path on Xen (not bare metal) - fix two bugs with PV guests not shutting down when requested - fix a minor memory leak in xen-pciback error path" * tag 'stable/for-linus-3.15-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/manage: Poweroff forcefully if user-space is not yet up. xen/xenbus: Avoid synchronous wait on XenBus stalling shutdown/restart. xen/spinlock: Don't enable them unconditionally. xen-pciback: silence an unwanted debug printk xen: fix memory leak in __xen_pcibk_add_pci_dev() x86/xen: Fix 32-bit PV guests's usage of kernel_stack
2014-04-15xen/manage: Poweroff forcefully if user-space is not yet up.Konrad Rzeszutek Wilk
The user can launch the guest in this sequence: xl create -p /vm.cfg [launch, but pause it] xl shutdown latest [sets control/shutdown=poweroff] xl unpause latest xl console latest [and see that the guest has completely ignored the shutdown request] In reality the guest hasn't ignored it. It registers a watch and gets a notification that there is value. It then calls the shutdown_handler which ends up calling orderly_shutdown. Unfortunately that is so early in the bootup that there are no user-space. Which means that the orderly_shutdown fails. But since the force flag was set to false it continues on without reporting. What we really want to is to use the force when we are in the SYSTEM_BOOTING state and not use the 'force' when SYSTEM_RUNNING. However, if we are in the running state - and the shutdown command has been given before the user-space has been setup, there is nothing we can do. Worst yet, we stop ignoring the 'xl shutdown' requests! As such, the other part of this patch is to only stop ignoring the 'xl shutdown' when we are truly in the power off sequence. That means the user can do multiple 'xl shutdown' and we will try to act on them instead of ignoring them. Fixes-Bug: http://bugs.xenproject.org/xen/bug/6 Reported-by: Alex Bligh <alex@alex.org.uk> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2014-04-15xen/xenbus: Avoid synchronous wait on XenBus stalling shutdown/restart.Konrad Rzeszutek Wilk
The 'read_reply' works with 'process_msg' to read of a reply in XenBus. 'process_msg' is running from within the 'xenbus' thread. Whenever a message shows up in XenBus it is put on a xs_state.reply_list list and 'read_reply' picks it up. The problem is if the backend domain or the xenstored process is killed. In which case 'xenbus' is still awaiting - and 'read_reply' if called - stuck forever waiting for the reply_list to have some contents. This is normally not a problem - as the backend domain can come back or the xenstored process can be restarted. However if the domain is in process of being powered off/restarted/halted - there is no point of waiting on it coming back - as we are effectively being terminated and should not impede the progress. This patch solves this problem by checking whether the guest is the right domain. If it is an initial domain and hurtling towards death - there is no point of continuing the wait. All other type of guests continue with their behavior (as Xenstore is expected to still be running in another domain). Fixes-Bug: http://bugs.xenproject.org/xen/bug/8 Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2014-04-15xen-pciback: silence an unwanted debug printkDan Carpenter
There is a missing curly brace here so we might print some extra debug information. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2014-04-15xen: fix memory leak in __xen_pcibk_add_pci_dev()Daeseok Youn
It need to free dev_entry when it failed to assign to a new slot on the virtual PCI bus. smatch says: drivers/xen/xen-pciback/vpci.c:142 __xen_pcibk_add_pci_dev() warn: possible memory leak of 'dev_entry' Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2014-04-07Merge tag 'stable/for-linus-3.15-tag2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen build fix from David Vrabel: "Fix arm build of drivers/xen/events/ The merge of irq-core-for-linus branch broke it" * tag 'stable/for-linus-3.15-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: Xen: do hv callback accounting only on x86
2014-04-07Merge tag 'cpu-hotplug-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull CPU hotplug notifiers registration fixes from Rafael Wysocki: "The purpose of this single series of commits from Srivatsa S Bhat (with a small piece from Gautham R Shenoy) touching multiple subsystems that use CPU hotplug notifiers is to provide a way to register them that will not lead to deadlocks with CPU online/offline operations as described in the changelog of commit 93ae4f978ca7f ("CPU hotplug: Provide lockless versions of callback registration functions"). The first three commits in the series introduce the API and document it and the rest simply goes through the users of CPU hotplug notifiers and converts them to using the new method" * tag 'cpu-hotplug-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (52 commits) net/iucv/iucv.c: Fix CPU hotplug callback registration net/core/flow.c: Fix CPU hotplug callback registration mm, zswap: Fix CPU hotplug callback registration mm, vmstat: Fix CPU hotplug callback registration profile: Fix CPU hotplug callback registration trace, ring-buffer: Fix CPU hotplug callback registration xen, balloon: Fix CPU hotplug callback registration hwmon, via-cputemp: Fix CPU hotplug callback registration hwmon, coretemp: Fix CPU hotplug callback registration thermal, x86-pkg-temp: Fix CPU hotplug callback registration octeon, watchdog: Fix CPU hotplug callback registration oprofile, nmi-timer: Fix CPU hotplug callback registration intel-idle: Fix CPU hotplug callback registration clocksource, dummy-timer: Fix CPU hotplug callback registration drivers/base/topology.c: Fix CPU hotplug callback registration acpi-cpufreq: Fix CPU hotplug callback registration zsmalloc: Fix CPU hotplug callback registration scsi, fcoe: Fix CPU hotplug callback registration scsi, bnx2fc: Fix CPU hotplug callback registration scsi, bnx2i: Fix CPU hotplug callback registration ...
2014-04-07Xen: do hv callback accounting only on x86Arnd Bergmann
Patch 99c8b79d3c1 "xen: Add proper irq accounting for HYPERCALL vector" added a call to inc_irq_stat(irq_hv_callback_count) in common Xen code, however both the inc_irq_stat function and the irq_hv_callback_count counter are architecture specific. This makes the code build again on ARM by moving the call into the existing #ifdef CONFIG_X86. We may want to later do the same implementation on ARM that x86 has though. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Xen <xen-devel@lists.xenproject.org>
2014-04-07Merge commit '683b6c6f82a60fabf47012581c2cfbf1b037ab95' into ↵David Vrabel
stable/for-linus-3.15 This merge of the irq-core-for-linus branch broke the ARM build when Xen is enabled. Conflicts: drivers/xen/events/events_base.c
2014-04-03Merge tag 'stable/for-linus-3.15-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen features and fixes from David Vrabel: "Support PCI devices with multiple MSIs, performance improvement for kernel-based backends (by not populated m2p overrides when mapping), and assorted minor bug fixes and cleanups" * tag 'stable/for-linus-3.15-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/acpi-processor: fix enabling interrupts on syscore_resume xen/grant-table: Refactor gnttab_[un]map_refs to avoid m2p_override xen: remove XEN_PRIVILEGED_GUEST xen: add support for MSI message groups xen-pciback: Use pci_enable_msix_exact() instead of pci_enable_msix() xen/xenbus: remove unused xenbus_bind_evtchn() xen/events: remove unnecessary call to bind_evtchn_to_cpu() xen/events: remove the unused resend_irq_on_evtchn() drivers:xen-selfballoon:reset 'frontswap_inertia_counter' after frontswap_shrink drivers: xen: Include appropriate header file in pcpu.c drivers: xen: Mark function as static in platform-pci.c
2014-04-01Merge tag 'pm+acpi-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "The majority of this material spent some time in linux-next, some of it even several weeks. There are a few relatively fresh commits in it, but they are mostly fixes and simple cleanups. ACPI took the lead this time, both in terms of the number of commits and the number of modified lines of code, cpufreq follows and there are a few changes in the PM core and in cpuidle too. A new feature that already got some LWN.net's attention is the device PM QoS extension allowing latency tolerance requirements to be propagated from leaf devices to their ancestors with hardware interfaces for specifying latency tolerance. That should help systems with hardware-driven power management to avoid going too far with it in cases when there are latency tolerance constraints. There also are some significant changes in the ACPI core related to the way in which hotplug notifications are handled. They affect PCI hotplug (ACPIPHP) and the ACPI dock station code too. The bottom line is that all those notification now go through the root notify handler and are propagated to the interested subsystems by means of callbacks instead of having to install a notify handler for each device object that we can potentially get hotplug notifications for. In addition to that ACPICA will now advertise "Windows 2013" compatibility for _OSI, because some systems out there don't work correctly if that is not done (some of them don't even boot). On the system suspend side of things, all of the device suspend and resume callbacks, except for ->prepare() and ->complete(), are now going to be executed asynchronously as that turns out to speed up system suspend and resume on some platforms quite significantly and we have a few more optimizations in that area. Apart from that, there are some new device IDs and fixes and cleanups all over. In particular, the system suspend and resume handling by cpufreq should be improved and the cpuidle menu governor should be a bit more robust now. Specifics: - Device PM QoS support for latency tolerance constraints on systems with hardware interfaces allowing such constraints to be specified. That is necessary to prevent hardware-driven power management from becoming overly aggressive on some systems and to prevent power management features leading to excessive latencies from being used in some cases. - Consolidation of the handling of ACPI hotplug notifications for device objects. This causes all device hotplug notifications to go through the root notify handler (that was executed for all of them anyway before) that propagates them to individual subsystems, if necessary, by executing callbacks provided by those subsystems (those callbacks are associated with struct acpi_device objects during device enumeration). As a result, the code in question becomes both smaller in size and more straightforward and all of those changes should not affect users. - ACPICA update, including fixes related to the handling of _PRT in cases when it is broken and the addition of "Windows 2013" to the list of supported "features" for _OSI (which is necessary to support systems that work incorrectly or don't even boot without it). Changes from Bob Moore and Lv Zheng. - Consolidation of ACPI _OST handling from Jiang Liu. - ACPI battery and AC fixes allowing unusual system configurations to be handled by that code from Alexander Mezin. - New device IDs for the ACPI LPSS driver from Chiau Ee Chew. - ACPI fan and thermal optimizations related to system suspend and resume from Aaron Lu. - Cleanups related to ACPI video from Jean Delvare. - Assorted ACPI fixes and cleanups from Al Stone, Hanjun Guo, Lan Tianyu, Paul Bolle, Tomasz Nowicki. - Intel RAPL (Running Average Power Limits) driver cleanups from Jacob Pan. - intel_pstate fixes and cleanups from Dirk Brandewie. - cpufreq fixes related to system suspend/resume handling from Viresh Kumar. - cpufreq core fixes and cleanups from Viresh Kumar, Stratos Karafotis, Saravana Kannan, Rashika Kheria, Joe Perches. - cpufreq drivers updates from Viresh Kumar, Zhuoyu Zhang, Rob Herring. - cpuidle fixes related to the menu governor from Tuukka Tikkanen. - cpuidle fix related to coupled CPUs handling from Paul Burton. - Asynchronous execution of all device suspend and resume callbacks, except for ->prepare and ->complete, during system suspend and resume from Chuansheng Liu. - Delayed resuming of runtime-suspended devices during system suspend for the PCI bus type and ACPI PM domain. - New set of PM helper routines to allow device runtime PM callbacks to be used during system suspend and resume more easily from Ulf Hansson. - Assorted fixes and cleanups in the PM core from Geert Uytterhoeven, Prabhakar Lad, Philipp Zabel, Rashika Kheria, Sebastian Capella. - devfreq fix from Saravana Kannan" * tag 'pm+acpi-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits) PM / devfreq: Rewrite devfreq_update_status() to fix multiple bugs PM / sleep: Correct whitespace errors in <linux/pm.h> intel_pstate: Set core to min P state during core offline cpufreq: Add stop CPU callback to cpufreq_driver interface cpufreq: Remove unnecessary braces cpufreq: Fix checkpatch errors and warnings cpufreq: powerpc: add cpufreq transition latency for FSL e500mc SoCs MAINTAINERS: Reorder maintainer addresses for PM and ACPI PM / Runtime: Update runtime_idle() documentation for return value meaning video / output: Drop display output class support fujitsu-laptop: Drop unneeded include acer-wmi: Stop selecting VIDEO_OUTPUT_CONTROL ACPI / gpu / drm: Stop selecting VIDEO_OUTPUT_CONTROL ACPI / video: fix ACPI_VIDEO dependencies cpufreq: remove unused notifier: CPUFREQ_{SUSPENDCHANGE|RESUMECHANGE} cpufreq: Do not allow ->setpolicy drivers to provide ->target cpufreq: arm_big_little: set 'physical_cluster' for each CPU cpufreq: arm_big_little: make vexpress driver depend on bL core driver ACPI / button: Add ACPI Button event via netlink routine ACPI: Remove duplicate definitions of PREFIX ...
2014-04-01Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq code updates from Thomas Gleixner: "The irq department proudly presents: - Another tree wide sweep of irq infrastructure abuse. Clear winner of the trainwreck engineering contest was: #include "../../../kernel/irq/settings.h" - Tree wide update of irq_set_affinity() callbacks which miss a cpu online check when picking a single cpu out of the affinity mask. - Tree wide consolidation of interrupt statistics. - Updates to the threaded interrupt infrastructure to allow explicit wakeup of the interrupt thread and a variant of synchronize_irq() which synchronizes only the hard interrupt handler. Both are needed to replace the homebrewn thread handling in the mmc/sdhci code. - New irq chip callbacks to allow proper support for GPIO based irqs. The GPIO based interrupts need to request/release GPIO resources from request/free_irq. - A few new ARM interrupt chips. No revolutionary new hardware, just differently wreckaged variations of the scheme. - Small improvments, cleanups and updates all over the place" I was hoping that that trainwreck engineering contest was a April Fools' joke. But no. * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (68 commits) irqchip: sun7i/sun6i: Disable NMI before registering the handler ARM: sun7i/sun6i: dts: Fix IRQ number for sun6i NMI controller ARM: sun7i/sun6i: irqchip: Update the documentation ARM: sun7i/sun6i: dts: Add NMI irqchip support ARM: sun7i/sun6i: irqchip: Add irqchip driver for NMI controller genirq: Export symbol no_action() arm: omap: Fix typo in ams-delta-fiq.c m68k: atari: Fix the last kernel_stat.h fallout irqchip: sun4i: Simplify sun4i_irq_ack irqchip: sun4i: Use handle_fasteoi_irq for all interrupts genirq: procfs: Make smp_affinity values go+r softirq: Add linux/irq.h to make it compile again m68k: amiga: Add linux/irq.h to make it compile again irqchip: sun4i: Don't ack IRQs > 0, fix acking of IRQ 0 irqchip: sun4i: Fix a comment about mask register initialization irqchip: sun4i: Fix irq 0 not working genirq: Add a new IRQCHIP_EOI_THREADED flag genirq: Document IRQCHIP_ONESHOT_SAFE flag ARM: sunxi: dt: Convert to the new irq controller compatibles irqchip: sunxi: Change compatibles ...
2014-03-25xen/balloon: flush persistent kmaps in correct positionWei Liu
Xen balloon driver will update ballooned out pages' P2M entries to point to scratch page for PV guests. In 24f69373e2 ("xen/balloon: don't alloc page while non-preemptible", kmap_flush_unused was moved after updating P2M table. In that case for 32 bit PV guest we might end up with P2M X -----> S (S is mfn of balloon scratch page) M2P Y -----> X (Y is mfn in persistent kmap entry) kmap_flush_unused() iterates through all the PTEs in the kmap address space, using pte_to_page() to obtain the page. If the p2m and the m2p are inconsistent the incorrect page is returned. This will clear page->address on the wrong page which may cause subsequent oopses if that page is currently kmap'ed. Move the flush back between get_page and __set_phys_to_machine to fix this. Signed-off-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Cc: stable@vger.kernel.org # 3.12+
2014-03-20xen, balloon: Fix CPU hotplug callback registrationSrivatsa S. Bhat
Subsystems that want to register CPU hotplug callbacks, as well as perform initialization for the CPUs that are already online, often do it as shown below: get_online_cpus(); for_each_online_cpu(cpu) init_cpu(cpu); register_cpu_notifier(&foobar_cpu_notifier); put_online_cpus(); This is wrong, since it is prone to ABBA deadlocks involving the cpu_add_remove_lock and the cpu_hotplug.lock (when running concurrently with CPU hotplug operations). The xen balloon driver doesn't take get/put_online_cpus() around this code, but that is also buggy, since it can miss CPU hotplug events in between the initialization and callback registration: for_each_online_cpu(cpu) init_cpu(cpu); ^ | Race window; Can miss CPU hotplug events here. v register_cpu_notifier(&foobar_cpu_notifier); Interestingly, the balloon code in xen can simply be reorganized as shown below, to have a race-free method to register hotplug callbacks, without even taking get/put_online_cpus(). This is because the initialization performed for already online CPUs is exactly the same as that performed for CPUs that come online later. Moreover, the code has checks in place to avoid double initialization. register_cpu_notifier(&foobar_cpu_notifier); get_online_cpus(); for_each_online_cpu(cpu) init_cpu(cpu); put_online_cpus(); A hotplug operation that occurs between registering the notifier and calling get_online_cpus(), won't disrupt anything, because the code takes care to perform the memory allocations only once. So reorganize the balloon code in xen this way to fix the issues with CPU hotplug callback registration. Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Ingo Molnar <mingo@kernel.org> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-03-18xen/acpi-processor: fix enabling interrupts on syscore_resumeStanislaw Gruszka
syscore->resume() callback is expected to do not enable interrupts, it generates warning like below otherwise: [ 9386.365390] WARNING: CPU: 0 PID: 6733 at drivers/base/syscore.c:104 syscore_resume+0x9a/0xe0() [ 9386.365403] Interrupts enabled after xen_acpi_processor_resume+0x0/0x34 [xen_acpi_processor] ... [ 9386.365429] Call Trace: [ 9386.365434] [<ffffffff81667a8b>] dump_stack+0x45/0x56 [ 9386.365437] [<ffffffff8106921d>] warn_slowpath_common+0x7d/0xa0 [ 9386.365439] [<ffffffff8106928c>] warn_slowpath_fmt+0x4c/0x50 [ 9386.365442] [<ffffffffa0261bb0>] ? xen_upload_processor_pm_data+0x300/0x300 [xen_acpi_processor] [ 9386.365443] [<ffffffff814055fa>] syscore_resume+0x9a/0xe0 [ 9386.365445] [<ffffffff810aef42>] suspend_devices_and_enter+0x402/0x470 [ 9386.365447] [<ffffffff810af128>] pm_suspend+0x178/0x260 On xen_acpi_processor_resume() we call various procedures, which are non atomic and can enable interrupts. To prevent the issue introduce separate resume notify called after we enable interrupts on resume and before we call other drivers resume callbacks. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-03-18xen/grant-table: Refactor gnttab_[un]map_refs to avoid m2p_overrideZoltan Kiss
The grant mapping API does m2p_override unnecessarily: only gntdev needs it, for blkback and future netback patches it just cause a lock contention, as those pages never go to userspace. Therefore this series does the following: - the bulk of the original function (everything after the mapping hypercall) is moved to arch-dependent set/clear_foreign_p2m_mapping - the "if (xen_feature(XENFEAT_auto_translated_physmap))" branch goes to ARM - therefore the ARM function could be much smaller, the m2p_override stubs could be also removed - on x86 the set_phys_to_machine calls were moved up to this new funcion from m2p_override functions - and m2p_override functions are only called when there is a kmap_ops param It also removes a stray space from arch/x86/include/asm/xen/page.h. Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com> Suggested-by: Anthony Liguori <aliguori@amazon.com> Suggested-by: David Vrabel <david.vrabel@citrix.com> Suggested-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
2014-03-18xen: add support for MSI message groupsRoger Pau Monne
Add support for MSI message groups for Xen Dom0 using the MAP_PIRQ_TYPE_MULTI_MSI pirq map type. In order to keep track of which pirq is the first one in the group all pirqs in the MSI group except for the first one have the newly introduced PIRQ_MSI_GROUP flag set. This prevents calling PHYSDEVOP_unmap_pirq on them, since the unmap must be done with the first pirq in the group. Signed-off-by: Roger Pau Monné <roger.pau@citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
2014-03-12xen: Validate online cpus in set_affinityThomas Gleixner
The user space interface does not filter out offline cpus. It merily verifies that the mask contains at least one online cpu. So the selector in the irq chip implementation needs to make sure to pick only an online cpu because otherwise: Offline Core 1 Set affinity to 0xe Selector will pick first set bit, i.e. core 1 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Xen <xen-devel@lists.xenproject.org> Link: http://lkml.kernel.org/r/20140304203100.978031089@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-03-04xen: Add proper irq accounting for HYPERCALL vectorThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Xen <xen-devel@lists.xenproject.org> Link: http://lkml.kernel.org/r/20140223212738.808648133@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-03-04xen: Get rid of the last irq_desc abuseThomas Gleixner
Warn if any PIRQ cannot be bound to an event channel. Remove the check for irq_desc->action. This hypercall never fails in practice so we can emit a warning unconditionally. Remove a check for a valid irq desc. The only caller of xen_destroy_irq() will only do so if the irq was previously fully setup, which means the descriptor has been allocated as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Xen <xen-devel@lists.xenproject.org> Cc: David Vrabel <david.vrabel@citrix.com> Link: http://lkml.kernel.org/r/20140223212738.579581220@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-03-04xen: Use the proper irq functionsThomas Gleixner
generic_handler_irq() already tests for !desc so use this instead of generic_handle_irq_desc(). Use irq_get_irq_data() instead of desc->irq_data. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Xen <xen-devel@lists.xenproject.org> Link: http://lkml.kernel.org/r/20140223212738.222412125@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-28xen-pciback: Use pci_enable_msix_exact() instead of pci_enable_msix()Alexander Gordeev
As result of deprecation of MSI-X/MSI enablement functions pci_enable_msix() and pci_enable_msi_block() all drivers using these two interfaces need to be updated to use the new pci_enable_msi_range() or pci_enable_msi_exact() and pci_enable_msix_range() or pci_enable_msix_exact() interfaces. Signed-off-by: Alexander Gordeev <agordeev@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: linux-pci@vger.kernel.org Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
2014-02-28xen/xenbus: remove unused xenbus_bind_evtchn()David Vrabel
xenbus_bind_evtchn() has no callers so remove it. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
2014-02-28xen/events: remove unnecessary call to bind_evtchn_to_cpu()David Vrabel
Since bind_evtchn_to_cpu() is always called after an event channel is bound, there is no need to call it after closing an event channel. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
2014-02-28xen/events: remove the unused resend_irq_on_evtchn()David Vrabel
resend_irq_on_evtchn() was only used by ia64 (which no longer has Xen support). Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
2014-02-28drivers:xen-selfballoon:reset 'frontswap_inertia_counter' after frontswap_shrinkBob Liu
When I looked at this issue https://lkml.org/lkml/2013/11/21/158, I found that frontswap_selfshrink() doesn't work as expected sometimes. Pages are continuously added to frontswap and gotten back soon. It's a waste of cpu time and increases the memory pressue of Guest OS. Take an example. First time in frontswap_selfshrink(): 1. last_frontswap_pages = cur_frontswap_pages = 0 2. cur_frontswap_pages = frontswap_curr_pages() = 100 When 'frontswap_inertia_counter' decreased to 0: 1. last_frontswap_pages = cur_frontswap_pages = 100 2. cur_frontswap_pages = frontswap_curr_pages() = 100 3. call frontswap_shrink() and let's assumption that 10 pages are gotten back from frontswap. 4. now frontswap_curr_pages() is 90. If then memory is not enough in Guest OS and 9 more pages(smaller than gotten back) added to frontswap. Now frontswap_curr_pages() is 99 and we don't expect to get back more pages from frontswap because geust os is under memory pressure. But next time in frontswap_selfshrink(): 1. last_frontswap_pages is set to the old value of cur_frontswap_pages(still 100) 2. cur_frontswap_pages(99) is still smaller than last_frontswap_pages. 3. call frontswap_shrink() and continue to get back pages from frontswap!! Signed-off-by: Bob Liu <bob.liu@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-02-28drivers: xen: Include appropriate header file in pcpu.cRashika Kheria
Include appropriate header file in xen/pcpu.c because include/xen/acpi.h contains prototype declaration of functions defined in the file. This eliminates the following warning in xen/pcpu.c: drivers/xen/pcpu.c:336:6: warning: no previous prototype for ‘xen_pcpu_hotplug_sync’ [-Wmissing-prototypes] drivers/xen/pcpu.c:346:5: warning: no previous prototype for ‘xen_pcpu_id’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-02-28drivers: xen: Mark function as static in platform-pci.cRashika Kheria
Mark function as static in xen/platform-pci.c because it is not used outside this file. This eliminates the following warning in xen/platform-pci.c: drivers/xen/platform-pci.c:48:15: warning: no previous prototype for ‘alloc_xen_mmio’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com>
2014-02-22ACPI: Drop acpi_evaluate_hotplug_ost() and ACPI_HOTPLUG_OSTRafael J. Wysocki
Replace acpi_evaluate_hotplug_ost() with acpi_evaluate_ost() everywhere and drop the ACPI_HOTPLUG_OST symbol so that hotplug _OST is supported unconditionally. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com>
2014-02-21ACPI / PAD / xen: use acpi_evaluate_ost() to replace open-coded versionJiang Liu
Use public function acpi_evaluate_ost() to replace open-coded version of evaluating ACPI _OST method. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-12Merge tag 'stable/for-linus-3.14-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: "This has an healthy amount of code being removed - which we do not use anymore (the only user of it was ia64 Xen which had been removed already). The other bug-fixes are to make Xen ARM be able to use the new event channel mechanism and proper export of header files to user-space. Summary: - Fix ARM and Xen FIFO not working. - Remove more Xen ia64 vestigates. - Fix UAPI missing Xen files" * tag 'stable/for-linus-3.14-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: ia64/xen: Remove Xen support for ia64 even more xen: install xen/gntdev.h and xen/gntalloc.h xen/events: bind all new interdomain events to VCPU0
2014-02-11ia64/xen: Remove Xen support for ia64 even morePaul Bolle
Commit d52eefb47d4e ("ia64/xen: Remove Xen support for ia64") removed the Kconfig symbol XEN_XENCOMM. But it didn't remove the code depending on that symbol. Remove that code now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-02-11xen/events: bind all new interdomain events to VCPU0David Vrabel
Commit fc087e10734a4d3e40693fc099461ec1270b3fff (xen/events: remove unnecessary init_evtchn_cpu_bindings()) causes a regression. The kernel-side VCPU binding was not being correctly set for newly allocated or bound interdomain events. In ARM guests where 2-level events were used, this would result in no interdomain events being handled because the kernel-side VCPU masks would all be clear. x86 guests would work because the irq affinity was set during irq setup and this would set the correct kernel-side VCPU binding. Fix this by properly initializing the kernel-side VCPU binding in bind_evtchn_to_irq(). Reported-and-tested-by: Julien Grall <julien.grall@linaro.org> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-02-05Merge tag 'stable/for-linus-3.14-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen fixes from Konrad Rzeszutek Wilk: "Bug-fixes: - Revert "xen/grant-table: Avoid m2p_override during mapping" as it broke Xen ARM build. - Fix CR4 not being set on AP processors in Xen PVH mode" * tag 'stable/for-linus-3.14-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pvh: set CR4 flags for APs Revert "xen/grant-table: Avoid m2p_override during mapping"
2014-02-03Revert "xen/grant-table: Avoid m2p_override during mapping"Konrad Rzeszutek Wilk
This reverts commit 08ece5bb2312b4510b161a6ef6682f37f4eac8a1. As it breaks ARM builds and needs more attention on the ARM side. Acked-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-31Merge tag 'stable/for-linus-3.14-rc0-late-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: "Bug-fixes for the new features that were added during this cycle. There are also two fixes for long-standing issues for which we have a solution: grant-table operations extra work that was not needed causing performance issues and the self balloon code was too aggressive causing OOMs. Details: - Xen ARM couldn't use the new FIFO events - Xen ARM couldn't use the SWIOTLB if compiled as 32-bit with 64-bit PCIe devices. - Grant table were doing needless M2P operations. - Ratchet down the self-balloon code so it won't OOM. - Fix misplaced kfree in Xen PVH error code paths" * tag 'stable/for-linus-3.14-rc0-late-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pvh: Fix misplaced kfree from xlated_setup_gnttab_pages drivers: xen: deaggressive selfballoon driver xen/grant-table: Avoid m2p_override during mapping xen/gnttab: Use phys_addr_t to describe the grant frame base address xen: swiotlb: handle sizeof(dma_addr_t) != sizeof(phys_addr_t) arm/xen: Initialize event channels earlier
