path: root/drivers/xen
2011-03-17Merge branch 'stable/xen.pm.bug-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xen.pm.bug-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: use freeze/restore/thaw PM events for suspend/resume/chkpt xen: xenbus PM events support
2011-03-17Merge branches 'stable/irq.fairness' and 'stable/irq.ween_of_nr_irqs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.fairness' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Remove redundant clear of l2i at end of round-robin loop xen: events: Make round-robin scan fairer by snapshotting each l2 word once only xen: events: Clean up round-robin evtchn scan. xen: events: Make last processed event channel a per-cpu variable. xen: events: Process event channels notifications in round-robin order. * 'stable/irq.ween_of_nr_irqs' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Fix compile error if CONFIG_SMP is not defined. xen: events: correct locking in xen_irq_from_pirq xen: events: propagate irq allocation failure instead of panicking xen: events: do not workaround too-small nr_irqs xen: events: remove use of nr_irqs as upper bound on number of pirqs xen: events: dynamically allocate irq info structures xen: events: maintain a list of Xen interrupts xen: events: push setup of irq<->{evtchn,ipi,virq,pirq} maps into irq_info init functions xen: events: turn irq_info constructors into initialiser functions xen: events: use per-cpu variable for cpu_evtchn_mask xen: events: refactor GSI pirq bindings functions xen: events: rename restore_cpu_pirqs -> restore_pirqs xen: events: remove unused public functions xen: events: fix xen_map_pirq_gsi error return xen: events: simplify comment xen: events: separate two unrelated halves of if condition Fix up trivial conflicts in drivers/xen/events.c
2011-03-17Merge branches 'stable/hvc-console', 'stable/gntalloc.v6' and ↵Linus Torvalds
'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/hvc-console' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/hvc: Disable probe_irq_on/off from poking the hvc-console IRQ line. * 'stable/gntalloc.v6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: gntdev: fix build warning xen/p2m/m2p/gnttab: do not add failed grant maps to m2p override xen-gntdev: Add cast to pointer xen-gntdev: Fix incorrect use of zero handle xen: change xen/[gntdev/gntalloc] to default m xen-gntdev: prevent using UNMAP_NOTIFY_CLEAR_BYTE on read-only mappings xen-gntdev: Avoid double-mapping memory xen-gntdev: Avoid unmapping ranges twice xen-gntdev: Use map->vma for checking map validity xen-gntdev: Fix unmap notify on PV domains xen-gntdev: Fix memory leak when mmap fails xen/gntalloc,gntdev: Add unmap notify ioctl xen-gntalloc: Userspace grant allocation driver xen-gntdev: Support mapping in HVM domains xen-gntdev: Add reference counting to maps xen-gntdev: Use find_vma rather than iterating our vma list manually xen-gntdev: Change page limit to be global instead of per-open * 'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (24 commits) xen-gntdev: Use ballooned pages for grant mappings xen-balloon: Add interface to retrieve ballooned pages xen-balloon: Move core balloon functionality out of module xen/balloon: Remove pr_info's and don't alter retry_count xen/balloon: Protect against CPU exhaust by event/x process xen/balloon: Migration from mod_timer() to schedule_delayed_work() xen/balloon: Removal of driver_pages
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16xen: use freeze/restore/thaw PM events for suspend/resume/chkptShriram Rajagopalan
Use PM_FREEZE, PM_THAW and PM_RESTORE power events for suspend/resume/checkpoint functionality, instead of PM_SUSPEND and PM_RESUME. Use of these pm events fixes the Xen Guest hangup when taking checkpoints. When a suspend event is cancelled (while taking checkpoints once/continuously), we use PM_THAW instead of PM_RESUME. PM_RESTORE is used when suspend is not cancelled. See Documentation/power/devices.txt and linux/pm.h for more info about freeze, thaw and restore. The sequence of pm events in a suspend-resume scenario is shown below. dpm_suspend_start(PMSG_FREEZE); dpm_suspend_noirq(PMSG_FREEZE); sysdev_suspend(PMSG_FREEZE); cancelled = suspend_hypercall() sysdev_resume(); dpm_resume_noirq(cancelled ? PMSG_THAW : PMSG_RESTORE); dpm_resume_end(cancelled ? PMSG_THAW : PMSG_RESTORE); Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Shriram Rajagopalan <rshriram@cs.ubc.ca> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-16xen: xenbus PM events supportKazuhiro SUZUKI
Make xenbus frontend device subscribe to PM events to receive suspend/resume/freeze/thaw/restore notifications. Signed-off-by: Kenji Wakamiya <wkenji@jp.fujitsu.com> Signed-off-by: Kazuhiro Suzuki <kaz@jp.fujitsu.com> Signed-off-by: Shriram Rajagopalan <rshriram@cs.ubc.ca> Acked-by: Ian Campbell <ian.campbell@citrix.com> [shriram--minor mods and improved commit message] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-16xen-gntdev: Use ballooned pages for grant mappingsDaniel De Graaf
Grant mappings cause the PFN<->MFN mapping to be lost on the pages used for the mapping. Instead of leaking memory, use pages that have already been ballooned out and so have no valid mapping. This removes the need for the bad-page leak workaround as pages are repopulated by the balloon driver. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-16xen-balloon: Add interface to retrieve ballooned pagesKonrad Rzeszutek Wilk
Pages that have been ballooned are useful for other Xen drivers doing grant table actions, because these pages have valid struct page/PFNs but have no valid MFN so are available for remapping. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> [v2: Deal with rebasing on top of modified balloon code] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-16xen-balloon: Move core balloon functionality out of moduleDaniel De Graaf
The basic functionality of ballooning pages is useful for Xen drivers in general. Rather than require a dependency on the balloon module, split the functionality that is reused into the core. The balloon module is still required to follow ballooning requests from xenstore or to view balloon statistics in sysfs. Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Daniel De Graaf <dgdegra@tycho.nsa.gov> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-16xen/balloon: Remove pr_info's and don't alter retry_countKonrad Rzeszutek Wilk
In the past the retry_count (in other form of this code) was zero. Meaning retry forever. Do the same thing here without changing it to the value 16. Also remove some of the pr_info as there is no need to spam the user. Acked-by: Ian Campbell <Ian.Campbell@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-15Merge branch 'stable/backends' of ↵David S. Miller
2011-03-15Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (116 commits) x86: Enable forced interrupt threading support x86: Mark low level interrupts IRQF_NO_THREAD x86: Use generic show_interrupts x86: ioapic: Avoid redundant lookup of irq_cfg x86: ioapic: Use new move_irq functions x86: Use the proper accessors in fixup_irqs() x86: ioapic: Use irq_data->state x86: ioapic: Simplify irq chip and handler setup x86: Cleanup the genirq name space genirq: Add chip flag to force mask on suspend genirq: Add desc->irq_data accessor genirq: Add comments to Kconfig switches genirq: Fixup fasteoi handler for oneshot mode genirq: Provide forced interrupt threading sched: Switch wait_task_inactive to schedule_hrtimeout() genirq: Add IRQF_NO_THREAD genirq: Allow shared oneshot interrupts genirq: Prepare the handling of shared oneshot interrupts genirq: Make warning in handle_percpu_event useful x86: ioapic: Move trigger defines to io_apic.h ... Fix up trivial(?) conflicts in arch/x86/pci/xen.c due to genirq name space changes clashing with the Xen cleanups. The set_irq_msi() had moved to xen_bind_pirq_msi_to_irq().
2011-03-15xen: events: Fix compile error if CONFIG_SMP is not defined.Konrad Rzeszutek Wilk
drivers/xen/events.c:396: error: 'struct irq_data' has no member named 'affinity' Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-15Merge branch 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvmLinus Torvalds
* 'for-linus' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: suspend: remove xen_hvm_suspend xen: suspend: pull pre/post suspend hooks out into suspend_info xen: suspend: move arch specific pre/post suspend hooks into generic hooks xen: suspend: refactor non-arch specific pre/post suspend hooks xen: suspend: add "arch" to pre/post suspend hooks xen: suspend: pass extra hypercall argument via suspend_info struct xen: suspend: refactor cancellation flag into a structure xen: suspend: use HYPERVISOR_suspend for PVHVM case instead of open coding xen: switch to new schedop hypercall by default. xen: use new schedop interface for suspend xen: do not respond to unknown xenstore control requests xen: fix compile issue if XEN is enabled but XEN_PVHVM is disabled xen: PV on HVM: support PV spinlocks and IPIs xen: make the ballon driver work for hvm domains xen-blkfront: handle Xen major numbers other than XENVBD xen: do not use xen_info on HVM, set pv_info name to "Xen HVM" xen: no need to delay xen_setup_shutdown_event for hvm guests anymore
2011-03-15Merge branches 'stable/ia64', 'stable/blkfront-cleanup' and 'stable/cleanup' ↵Linus Torvalds
of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/ia64' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: ia64 build broken due to "xen: switch to new schedop hypercall by default." * 'stable/blkfront-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: Union the blkif_request request specific fields * 'stable/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: annotate functions which only call into __init at start of day xen p2m: annotate variable which appears unused xen: events: mark cpu_evtchn_mask_p as __refdata
2011-03-15Merge branch 'stable/irq.cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: remove dom0 specific xen_create_msi_irq xen: events: use xen_bind_pirq_msi_to_irq from xen_create_msi_irq xen: events: push set_irq_msi down into xen_create_msi_irq xen: events: update pirq_to_irq in xen_create_msi_irq xen: events: refactor xen_create_msi_irq slightly xen: events: separate MSI PIRQ allocation from PIRQ binding to IRQ xen: events: assume PHYSDEVOP_get_free_pirq exists xen: pci: collapse apic_register_gsi_xen_hvm and xen_hvm_register_pirq xen: events: return irq from xen_allocate_pirq_msi xen: events: drop XEN_ALLOC_IRQ flag to xen_allocate_pirq_msi xen: events: do not leak IRQ from xen_allocate_pirq_msi when no pirq available. xen: pci: only define xen_initdom_setup_msi_irqs if CONFIG_XEN_DOM0
2011-03-15Merge branches 'stable/irq.rework' and 'stable/pcifront-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.rework' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/irq: Cleanup up the pirq_to_irq for DomU PV PCI passthrough guests as well. xen: Use IRQF_FORCE_RESUME xen/timer: Missing IRQF_NO_SUSPEND in timer code broke suspend. xen: Fix compile error introduced by "switch to new irq_chip functions" xen: Switch to new irq_chip functions xen: Remove stale irq_chip.end xen: events: do not free legacy IRQs xen: events: allocate GSIs and dynamic IRQs from separate IRQ ranges. xen: events: add xen_allocate_irq_{dynamic, gsi} and xen_free_irq xen:events: move find_unbound_irq inside CONFIG_PCI_MSI xen: handled remapped IRQs when enabling a pcifront PCI device. genirq: Add IRQF_FORCE_RESUME * 'stable/pcifront-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: pci/xen: When free-ing MSI-X/MSI irq->desc also use generic code. pci/xen: Cleanup: convert int** to int[] pci/xen: Use xen_allocate_pirq_msi instead of xen_allocate_pirq xen-pcifront: Sanity check the MSI/MSI-X values xen-pcifront: don't use flush_scheduled_work()
2011-03-15Merge branches 'stable/p2m-identity.v4.9.1' and 'stable/e820' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/p2m-identity.v4.9.1' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/m2p: Check whether the MFN has IDENTITY_FRAME bit set.. xen/m2p: No need to catch exceptions when we know that there is no RAM xen/debug: WARN_ON when identity PFN has no _PAGE_IOMAP flag set. xen/debugfs: Add 'p2m' file for printing out the P2M layout. xen/setup: Set identity mapping for non-RAM E820 and E820 gaps. xen/mmu: WARN_ON when racing to swap middle leaf. xen/mmu: Set _PAGE_IOMAP if PFN is an identity PFN. xen/mmu: Add the notion of identity (1-1) mapping. xen: Mark all initial reserved pages for the balloon as INVALID_P2M_ENTRY. * 'stable/e820' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/e820: Don't mark balloon memory as E820_UNUSABLE when running as guest and fix overflow. xen/setup: Inhibit resource API from using System RAM E820 gaps as PCI mem gaps.
2011-03-14xen/balloon: Protect against CPU exhaust by event/x processDaniel Kiper
Protect against CPU exhaust by event/x process during errors by adding some delays in scheduling next event and retry count limit. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-14xen/balloon: Migration from mod_timer() to schedule_delayed_work()Daniel Kiper
Migration from mod_timer() to schedule_delayed_work(). Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-14xen/balloon: Removal of driver_pagesDaniel Kiper
Removal of driver_pages (I do not have seen any references to it). Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-14xen: events: correct locking in xen_irq_from_pirqIan Campbell
One of those spin_lock() calls should be an unlock... Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: propagate irq allocation failure instead of panickingIan Campbell
Running out of IRQs need not be fatal to the machine as a whole. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: do not workaround too-small nr_irqsIan Campbell
With the introduction of e7bcecb7b1d2 "genirq: Make nr_irqs runtime expandable" nr_irqs can grow as necessary to accommodate our allocation requests. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: remove use of nr_irqs as upper bound on number of pirqsIan Campbell
There isn't really much relationship between the two, other than nr_irqs often being the larger of the two. Allows us to remove a nr_irqs sized array, the only users of this array are MSI setup and restore, neither of which are particularly performance critical. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: dynamically allocate irq info structuresIan Campbell
Removes nr_irq sized array allocation at start of day. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: maintain a list of Xen interruptsIan Campbell
In a PVHVM kernel not all interrupts are Xen interrupts (APIC interrupts can also be present). Currently we get away with walking over all interrupts because the lookup in the irq_info array simply returns IRQT_UNBOUND and we ignore it. However this array will be going away in a future patch so we need to manually track which interrupts have been allocated by the Xen events infrastructure. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: push setup of irq<->{evtchn,ipi,virq,pirq} maps into irq_info ↵Ian Campbell
init functions Encapsulate setup of XXX_to_irq array in the relevant xen_irq_info_*_init function. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: turn irq_info constructors into initialiser functionsIan Campbell
2011-03-10xen: events: use per-cpu variable for cpu_evtchn_maskIan Campbell
I can't see any reason why it isn't already. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: refactor GSI pirq bindings functionsIan Campbell
Following the example set by xen_allocate_pirq_msi and xen_bind_pirq_msi_to_irq: xen_allocate_pirq becomes xen_allocate_pirq_gsi and now only allocates a pirq number and does not bind it. xen_map_pirq_gsi becomes xen_bind_pirq_gsi_to_irq and binds an existing pirq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: rename restore_cpu_pirqs -> restore_pirqsIan Campbell
There is nothing per-cpu about this function. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: remove unused public functionsIan Campbell
I was unable to find any user of these functions in either the functionality pending for 2.6.39 or the xen/next-2.6.32 branch of xen.git An exception to this was xen_gsi_from_irq which did appear to be used in xen/next-2.6.32's pciback. However in the 2.6.39 version of pciback xen_pirq_from_irq is, correctly AFAICT, used instead. Only a minority of functions in events.h use "extern" so drop it from those places for consistency. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: fix xen_map_pirq_gsi error returnIan Campbell
Fix initial value of irq so that first goto out (if pirq or gsi arguments are too large) actually returns an error. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: simplify commentIan Campbell
It is never valid assume any particular relationship between a Xen PIRQ number and and Linux IRQ number so there is no need to hedge when saying so. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: separate two unrelated halves of if conditionIan Campbell
Clarifies which bit the comment applies to. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: Remove redundant clear of l2i at end of round-robin loopKeir Fraser
Signed-off-by: Keir Fraser <keir.fraser@citrix.com> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> [ijc: forward ported from linux-2.6.18-xen.hg 991:9ba6d9f3fbc0] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: Make round-robin scan fairer by snapshotting each l2 word once onlyKeir Fraser
(except for starting l2 word, which we scan in two parts). Signed-off-by: Keir Fraser <keir.fraser@citrix.com> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> [ijc: forward ported from linux-2.6.18-xen.hg 990:427276ac595d] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: Clean up round-robin evtchn scan.Keir Fraser
Also fixes a couple of boundary cases. Signed-off-by: Keir Fraser <keir.fraser@citrix.com> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> [ijc: forward ported from linux-2.6.18-xen.hg 988:c88a02a22a05] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: Make last processed event channel a per-cpu variable.Ian Campbell
Signed-off-by: Ian Campbell <ian.campbell@citrix.com> [ijc: forward ported from linux-2.6.18-xen.hg 325:b2768401db94] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: Process event channels notifications in round-robin order.Scott Rixner
Avoids fairness issue resulting from domain 0 processing lowest numbered event channel first. Fixes bug #1115 "Event channel port scanning unfair". Bugzilla: http://bugzilla.xensource.com/bugzilla/show_bug.cgi?id=1115 Signed-off-by: Ian Campbell <ian.campbell@citrix.com> [ijc: forward ported from linux-2.6.18-xen.hg 324:7fe1c6d02a2b various variables have different names in this tree: l1 -> pending_words l2 -> pending_bits l1i -> word_idx l2i -> bit_idx] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: remove dom0 specific xen_create_msi_irqIan Campbell
The function name does not distinguish it from xen_allocate_pirq_msi (which operates on domU and pvhvm domains rather than dom0). Hoist domain 0 specific functionality up into the only caller leaving functionality common to all guest types in xen_bind_pirq_msi_to_irq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: use xen_bind_pirq_msi_to_irq from xen_create_msi_irqIan Campbell
2011-03-10xen: events: push set_irq_msi down into xen_create_msi_irqIan Campbell
Makes the tail end of this function look even more like xen_bind_pirq_msi_to_irq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: update pirq_to_irq in xen_create_msi_irqIan Campbell
I don't think this was a deliberate ommision. Makes the tail end of this function look even more like xen_bind_pirq_msi_to_irq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: refactor xen_create_msi_irq slightlyIan Campbell
Calling PHYSDEVOP_map_pirq earlier simplifies error handling and starts to make the tail end of this function look like xen_bind_pirq_msi_to_irq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: separate MSI PIRQ allocation from PIRQ binding to IRQIan Campbell
Split the binding aspect of xen_allocate_pirq_msi out into a new xen_bind_pirq_to_irq function. In xen_hvm_setup_msi_irq when allocating a pirq write the MSI message to signal the PIRQ as soon as the pirq is obtained. There is no way to free the pirq back so if the subsequent binding to an IRQ fails we want to ensure that we will reuse the PIRQ next time rather than leak it. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: assume PHYSDEVOP_get_free_pirq existsIan Campbell
The find_unbound_pirq is called only from xen_allocate_pirq_msi and only if alloc_pirq is true. The only caller which does this is xen_hvm_setup_msi_irqs. The use of this function is gated, in pci_xen_hvm_init, on XENFEAT_hvm_pirqs. The PHYSDEVOP_get_free_pirq interfaces was added to the hypervisor in 22410:be96f6058c05 while XENFEAT_hvm_pirqs was added a couple of minutes prior in 22409:6663214f06ac. Therefore we do not need to concern ourselves with hypervisors which support XENFEAT_hvm_pirqs but not PHYSDEVOP_get_free_pirq. This eliminates the fallback path in find_unbound_pirq which walks to pirq_to_irq array looking for a free pirq. Unlike the PHYSDEVOP_get_free_pirq interface this fallback only looks up a free pirq but does not reserve it. Removing this fallback will simplify locking in the future. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: return irq from xen_allocate_pirq_msiIan Campbell
consistent with other similar functions. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: drop XEN_ALLOC_IRQ flag to xen_allocate_pirq_msiIan Campbell
All callers pass this flag so it is pointless. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
