commit 30faaafdfa0c754c91bac60f216c9f34a2bfdf7e upstream.
Commit 9c17d96500f7 ("xen/gntdev: Grant maps should not be subject to
NUMA balancing") set VM_IO flag to prevent grant maps from being
subjected to NUMA balancing.
It was discovered recently that this flag causes get_user_pages() to
always fail with -EFAULT.
check_vma_flags
__get_user_pages
__get_user_pages_locked
__get_user_pages_unlocked
get_user_pages_fast
iov_iter_get_pages
dio_refill_pages
do_direct_IO
do_blockdev_direct_IO
ext4_direct_IO_read
generic_file_read_iter
aio_run_iocb
(which can happen if guest's vdisk has direct-io-safe option).
To avoid this let's use VM_MIXEDMAP flag instead --- it prevents
NUMA balancing just as VM_IO does and has no effect on
check_vma_flags().
Reported-by: Olaf Hering <olaf@aepfle.de>
Suggested-by: Hugh Dickins <hughd@google.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Tested-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: Juergen Gross <jgross@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from David Vrabel:
- advertise control feature flags in xenstore
- fix x86 build when XEN_PVHVM is disabled
* tag 'for-linus-4.9-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xenbus: check return value of xenbus_scanf()
xenbus: prefer list_for_each()
x86: xen: move cpu_up functions out of ifdef
xenbus: advertise control feature flags
Don't ignore errors here: Set backend state to unknown when
unsuccessful.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
This is more efficient than list_for_each_safe() when list modification
is accompanied by breaking out of the loop.
Reviewed-by: Juergen Gross <jgross@suse.com>
The Xen docs specify several flags which a guest can set to advertise
which values of the xenstore control/shutdown key it will recognize.
This patch adds code to write all the relevant feature-flag keys.
Based-on-patch-by: Paul Durrant <paul.durrant@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
Pull xen updates from David Vrabel:
"xen features and fixes for 4.9:
- switch to new CPU hotplug mechanism
- support driver_override in pciback
- require vector callback for HVM guests (the alternate mechanism via
the platform device has been broken for ages)"
* tag 'for-linus-4.9-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/x86: Update topology map for PV VCPUs
xen/x86: Initialize per_cpu(xen_vcpu, 0) a little earlier
xen/pciback: support driver_override
xen/pciback: avoid multiple entries in slot list
xen/pciback: simplify pcistub device handling
xen: Remove event channel notification through Xen PCI platform device
xen/events: Convert to hotplug state machine
xen/x86: Convert to hotplug state machine
x86/xen: add missing \n at end of printk warning message
xen/grant-table: Use kmalloc_array() in arch_gnttab_valloc()
xen: Make VPMU init message look less scary
xen: rename xen_pmu_init() in sys-hypervisor.c
hotplug: Prevent alloc/free of irq descriptors during cpu up/down (again)
xen/x86: Move irq allocation from Xen smp_op.cpu_up()
Support the driver_override scheme introduced with commit 782a985d7af2
("PCI: Introduce new device binding path using pci_dev.driver_override")
As pcistub_probe() is called for all devices (it has to check for a
match based on the slot address rather than device type) it has to
check for driver_override set to "pciback" itself.
Up to now for assigning a pci device to pciback you need something like:
echo 0000:07:10.0 > /sys/bus/pci/devices/0000\:07\:10.0/driver/unbind
echo 0000:07:10.0 > /sys/bus/pci/drivers/pciback/new_slot
echo 0000:07:10.0 > /sys/bus/pci/drivers_probe
while with the patch you can use the same mechanism as for similar
drivers like pci-stub and vfio-pci:
echo pciback > /sys/bus/pci/devices/0000\:07\:10.0/driver_override
So e.g. libvirt doesn't need special handling for pciback.
The Xen pciback driver has a list of all pci devices it is ready to
seize. There is no check whether a to be added entry already exists.
While this might be no problem in the common case it might confuse
those which consume the list via sysfs.
Modify the handling of this list by not adding an entry which already
exists. As this will be needed later split out the list handling into
a separate function.
The Xen pciback driver maintains a list of all its seized devices.
There are two functions searching the list for a specific device with
basically the same semantics just returning different structures in
case of a match.
Split out the search function.
Ever since commit 254d1a3f02eb ("xen/pv-on-hvm kexec: shutdown watches
from old kernel") using the INTx interrupt from Xen PCI platform
device for event channel notification would just lockup the guest
during bootup. postcore_initcall now calls xs_reset_watches which
will eventually try to read a value from XenStore and will get stuck
on read_reply at XenBus forever since the platform driver is not
probed yet and its INTx interrupt handler is not registered yet. That
means that the guest can not be notified at this moment of any pending
event channels and none of the per-event handlers will ever be invoked
(including the XenStore one) and the reply will never be picked up by
the kernel.
The exact stack where things get stuck during xenbus_init:
-xenbus_init
-xs_init
-xs_reset_watches
-xenbus_scanf
-xenbus_read
-xs_single
-xs_single
-xs_talkv
Vector callbacks have always been the favourite event notification
mechanism since their introduction in commit 38e20b07efd5 ("x86/xen:
event channels delivery on HVM.") and the vector callback feature has
always been advertised for quite some time by Xen that's why INTx was
broken for several years now without impacting anyone.
Luckily this also means that event channel notification through INTx
is basically dead-code which can be safely removed without impacting
anybody since it has been effectively disabled for more than 4 years
with nobody complaining about it (at least as far as I'm aware of).
This commit removes event channel notification through Xen PCI
platform device.
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: x86@kernel.org
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Julien Grall <julien.grall@citrix.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Ross Lagerwall <ross.lagerwall@citrix.com>
Cc: xen-devel@lists.xenproject.org
Cc: linux-pci@vger.kernel.org
Cc: Anthony Liguori <aliguori@amazon.com>
Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Install the callbacks via the state machine.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
There are two functions with name xen_pmu_init() in the kernel. Rename
the one in drivers/xen/sys-hypervisor.c to avoid shadowing the one in
arch/x86/xen/pmu.c
To avoid the same problem in future rename some more functions.
This should really only be done for XS_TRANSACTION_END messages, or
else at least some of the xenstore-* tools don't work anymore.
Fixes: 0beef634b8 ("xenbus: don't BUG() on user mode induced condition")
Reported-by: Richard Schütz <rschuetz@uni-koblenz.de>
Cc: <stable@vger.kernel.org>
Tested-by: Richard Schütz <rschuetz@uni-koblenz.de>
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
"Features and fixes for 4.8-rc0:
- ACPI support for guests on ARM platforms.
- Generic steal time support for arm and x86.
- Support cases where kernel cpu is not Xen VCPU number (e.g., if
in-guest kexec is used).
- Use the system workqueue instead of a custom workqueue in various
places"
* tag 'for-linus-4.8-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (47 commits)
xen: add static initialization of steal_clock op to xen_time_ops
xen/pvhvm: run xen_vcpu_setup() for the boot CPU
xen/evtchn: use xen_vcpu_id mapping
xen/events: fifo: use xen_vcpu_id mapping
xen/events: use xen_vcpu_id mapping in events_base
x86/xen: use xen_vcpu_id mapping when pointing vcpu_info to shared_info
x86/xen: use xen_vcpu_id mapping for HYPERVISOR_vcpu_op
xen: introduce xen_vcpu_id mapping
x86/acpi: store ACPI ids from MADT for future usage
x86/xen: update cpuid.h from Xen-4.7
xen/evtchn: add IOCTL_EVTCHN_RESTRICT
xen-blkback: really don't leak mode property
xen-blkback: constify instance of "struct attribute_group"
xen-blkfront: prefer xenbus_scanf() over xenbus_gather()
xen-blkback: prefer xenbus_scanf() over xenbus_gather()
xen: support runqueue steal time on xen
arm/xen: add support for vm_assist hypercall
xen: update xen headers
xen-pciback: drop superfluous variables
xen-pciback: short-circuit read path used for merging write values
I have noticed that frontswap.h first declares "frontswap_enabled" as
extern bool variable, and then overrides it with "#define
frontswap_enabled (1)" for CONFIG_FRONTSWAP=Y or (0) when disabled. The
bool variable isn't actually instantiated anywhere.
This all looks like an unfinished attempt to make frontswap_enabled
reflect whether a backend is instantiated. But in the current state,
all frontswap hooks call unconditionally into frontswap.c just to check
if frontswap_ops is non-NULL. This should at least be checked inline,
but we can further eliminate the overhead when CONFIG_FRONTSWAP is
enabled and no backend registered, using a static key that is initially
disabled, and gets enabled only upon first backend registration.
Thus, checks for "frontswap_enabled" are replaced with
"frontswap_enabled()" wrapping the static key check. There are two
exceptions:
- xen's selfballoon_process() was testing frontswap_enabled in code guarded
by #ifdef CONFIG_FRONTSWAP, which was effectively always true when reachable.
The patch just removes this check. Using frontswap_enabled() does not sound
correct here, as this can be true even without xen's own backend being
registered.
- in SYSCALL_DEFINE2(swapon), change the check to IS_ENABLED(CONFIG_FRONTSWAP)
as it seems the bitmap allocation cannot currently be postponed until a
backend is registered. This means that frontswap will still have some
memory overhead by being configured, but without a backend.
After the patch, we can expect that some functions in frontswap.c are
called only when frontswap_ops is non-NULL. Change the checks there to
VM_BUG_ONs. While at it, convert other BUG_ONs to VM_BUG_ONs as
frontswap has been stable for some time.
Link: http://lkml.kernel.org/r/1463152235-9717-1-git-send-email-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
pv_time_ops might be overwritten with xen_time_ops after the
steal_clock operation has been initialized already. To prevent calling
a now uninitialized function pointer add the steal_clock static
initialization to xen_time_ops.
Use the newly introduced xen_vcpu_id mapping to get Xen's idea of vCPU
id for CPU0.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
EVTCHNOP_init_control has vCPU id as a parameter and Xen's idea of
vCPU id should be used. Use the newly introduced xen_vcpu_id mapping
to convert it from Linux's id.
EVTCHNOP_bind_ipi and EVTCHNOP_bind_virq pass vCPU id as a parameter
and Xen's idea of vCPU id should be used. Use the newly introduced
xen_vcpu_id mapping to convert it from Linux's id.
HYPERVISOR_vcpu_op() passes Linux's idea of vCPU id as a parameter
while Xen's idea is expected. In some cases these ideas diverge so we
need to do remapping.
Convert all callers of HYPERVISOR_vcpu_op() to use xen_vcpu_nr().
Leave xen_fill_possible_map() and xen_filter_cpu_maps() intact as
they're only being called by PV guests before perpu areas are
initialized. While the issue could be solved by switching to
early_percpu for xen_vcpu_id I think it's not worth it: PV guests will
probably never get to the point where their idea of vCPU id diverges
from Xen's.
IOCTL_EVTCHN_RESTRICT limits the file descriptor to being able to bind
to interdomain event channels from a specific domain. Event channels
that are already bound continue to work for sending and receiving
notifications.
This is useful as part of deprivileging a user space PV backend or
device model (QEMU). e.g., Once the device model as bound to the
ioreq server event channels it can restrict the file handle so an
exploited DM cannot use it to create or bind to arbitrary event
channels.
As of Xen 4.7 PV CPUID doesn't expose either of CPUID[1].ECX[7] and
CPUID[0x80000007].EDX[7] anymore, causing the driver to fail to load on
both Intel and AMD systems. Doing any kind of hardware capability
checks in the driver as a prerequisite was wrong anyway: With the
hypervisor being in charge, all such checking should be done by it. If
ACPI data gets uploaded despite some missing capability, the hypervisor
is free to ignore part or all of that data.
Ditch the entire check_prereq() function, and do the only valid check
(xen_initial_domain()) in the caller in its place.
No need to retain a local copy of the full request message, only the
type is really needed.
xenbus_dev_request_and_reply() needs to track whether a transaction is
open. For XS_TRANSACTION_START messages it calls transaction_start()
and for XS_TRANSACTION_END messages it calls transaction_end().
If sending an XS_TRANSACTION_START message fails or responds with an
an error, the transaction is not open and transaction_end() must be
called.
If sending an XS_TRANSACTION_END message fails, the transaction is
still open, but if an error response is returned the transaction is
closed.
Commit 027bd7e89906 ("xen/xenbus: Avoid synchronous wait on XenBus
stalling shutdown/restart") introduced a regression where failed
XS_TRANSACTION_START messages were leaving the transaction open. This
can cause problems with suspend (and migration) as all transactions
must be closed before suspending.
It appears that the problematic change was added accidentally, so just
remove it.
Inability to locate a user mode specified transaction ID should not
lead to a kernel crash. For other than XS_TRANSACTION_START also
don't issue anything to xenbus if the specified ID doesn't match that
of any active transaction.
Up to now reading the stolen time of a remote cpu was not possible in a
performant way under Xen. This made support of runqueue steal time via
paravirt_steal_rq_enabled impossible.
With the addition of an appropriate hypervisor interface this is now
possible, so add the support.
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
req_start is simply an alias of the "offset" function parameter, and
req_end is being used just once in each function. (And both variables
were loop invariant anyway, so should at least have got initialized
outside the loop.)
There's no point calling xen_pcibk_config_read() here - all it'll do is
return whatever conf_space_read() returns for the field which was found
here (and which would be found there again). Also there's no point
clearing tmp_val before the call.
Other than for raw BAR values, flags are properly separated in the
internal representation.
It is now identical to bar_init().
System workqueues have been able to handle high level of concurrency
for a long time now and there's no reason to use dedicated workqueues
just to gain concurrency. Replace dedicated xenbus_frontend_wq with the
use of system_wq.
Unlike a dedicated per-cpu workqueue created with create_workqueue(),
system_wq allows multiple work items to overlap executions even on
the same CPU; however, a per-cpu workqueue doesn't have any CPU
locality or global ordering guarantees unless the target CPU is
explicitly specified and the increase of local concurrency shouldn't
make any difference.
In this case, there is only a single work item, increase of concurrency
level by switching to system_wq should not make any difference.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Acked-by: Tejun Heo <tj@kernel.org>
just to gain concurrency. Replace dedicated xen_pcibk_wq with the
use of system_wq.
explicitly specified and thus the increase of local concurrency shouldn't
Since the work items could be pending, flush_work() has been used in
xen_pcibk_disconnect(). xen_pcibk_xenbus_remove() calls free_pdev()
which in turn calls xen_pcibk_disconnect() for every pdev to ensure that
there is no pending task while disconnecting the driver.
The pv_time_ops structure contains a function pointer for the
"steal_clock" functionality used only by KVM and Xen on ARM. Xen on x86
uses its own mechanism to account for the "stolen" time a thread wasn't
able to run due to hypervisor scheduling.
Add support in Xen arch independent time handling for this feature by
moving it out of the arm arch into drivers/xen and remove the x86 Xen
hack.
Replace explicit computation of vma page count by a call to
vma_pages().
Signed-off-by: Muhammad Falak R Wani <falakreyaz@gmail.com>
When running on Xen hypervisor, runtime services are supported through
hypercall. Add a Xen specific function to initialize runtime services.
Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Tested-by: Julien Grall <julien.grall@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Move x86 specific codes to architecture directory and export those EFI
runtime service functions. This will be useful for initializing runtime
service on ARM later.
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
Add a bus_notifier for AMBA bus device in order to map the device
mmio regions when DOM0 booting with ACPI.
Reviewed-by: Julien Grall <julien.grall@arm.com>
Add a bus_notifier for platform bus device in order to map the device
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Make xen_xlate_map_ballooned_pages work with 64K pages. In that case
Kernel pages are 64K in size but Xen pages remain 4K in size. Xen pfns
refer to 4K pages.
Move xlated_setup_gnttab_pages to common place, so it can be reused by
ARM to setup grant table.
Rename it to xen_xlate_map_ballooned_pages.
Reads following writes with all address bits set to 1 should return all
changeable address bits as one, not the BAR size (nor, as was the case
for the upper half of 64-bit BARs, the high half of the region's end
address). Presumably this didn't cause any problems so far because
consumers use the value to calculate the size (usually via val & -val),
and do nothing else with it.
But also consider the exception here: Unimplemented BARs should always
return all zeroes.
And finally, the check for whether to return the sizing address on read
for the ROM BAR should ignore all non-address bits, not just the ROM
Enable one.
Current overlap check is evaluating to false a case where a filter
field is fully contained (proper subset) of a r/w request. This
change applies classical overlap check instead to include all the
scenarios.
More specifically, for (Hilscher GmbH CIFX 50E-DP(M/S)) device driver
the logic is such that the entire confspace is read and written in 4
byte chunks. In this case as an example, CACHE_LINE_SIZE,
LATENCY_TIMER and PCI_BIST are arriving together in one call to
xen_pcibk_config_write() with offset == 0xc and size == 4. With the
exsisting overlap check the LATENCY_TIMER field (offset == 0xd, length
== 1) is fully contained in the write request and hence is excluded
from write, which is incorrect.
Signed-off-by: Andrey Grodzovsky <andrey2805@gmail.com>
Reviewed-by: Jan Beulich <JBeulich@suse.com>
Fix a declared-but-not-defined warning when building with
XEN_BALLOON_MEMORY_HOTPLUG=n. This fixes a regression introduced by
commit dfd74a1edfab ("xen/balloon: Fix crash when ballooning on x86 32
bit PAE").
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Acked-by: Juergen Gross <jgross@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the outstanding target pending updates for v4.7-rc1.
The highlights this round include:
- Allow external PR/ALUA metadata path be defined at runtime via top
level configfs attribute (Lee)
- Fix target session shutdown bug for ib_srpt multi-channel (hch)
- Make TFO close_session() and shutdown_session() optional (hch)
- Drop se_sess->sess_kref + convert tcm_qla2xxx to internal kref
(hch)
- Add tcm_qla2xxx endpoint attribute for basic FC jammer (Laurence)
- Refactor iscsi-target RX/TX PDU encode/decode into common code
(Varun)
- Extend iscsit_transport with xmit_pdu, release_cmd, get_rx_pdu,
validate_parameters, and get_r2t_ttt for generic ISO offload
(Varun)
- Initial merge of cxgb iscsi-segment offload target driver (Varun)
The bulk of the changes are Chelsio's new driver, along with a number
of iscsi-target common code improvements made by Varun + Co along the
way"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (29 commits)
iscsi-target: Fix early sk_data_ready LOGIN_FLAGS_READY race
cxgbit: Use type ISCSI_CXGBIT + cxgbit tpg_np attribute
iscsi-target: Convert transport drivers to signal rdma_shutdown
iscsi-target: Make iscsi_tpg_np driver show/store use generic code
tcm_qla2xxx Add SCSI command jammer/discard capability
iscsi-target: graceful disconnect on invalid mapping to iovec
target: need_to_release is always false, remove redundant check and kfree
target: remove sess_kref and ->shutdown_session
iscsi-target: remove usage of ->shutdown_session
tcm_qla2xxx: introduce a private sess_kref
target: make close_session optional
target: make ->shutdown_session optional
target: remove acl_stop
target: consolidate and fix session shutdown
cxgbit: add files for cxgbit.ko
iscsi-target: export symbols
iscsi-target: call complete on conn_logout_comp
iscsi-target: clear tx_thread_active
iscsi-target: add new offload transport type
iscsi-target: use conn_transport->transport_type in text rsp
Pull xen bug fixes from David Vrabel.
* tag 'for-linus-4.7-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: use same main loop for counting and remapping pages
xen/events: Don't move disabled irqs
xen/x86: actually allocate legacy interrupts on PV guests
Xen: don't warn about 2-byte wchar_t in efi
xen/gntdev: reduce copy batch size to 16
xen/x86: don't lose event interrupts
Commit ff1e22e7a638 ("xen/events: Mask a moving irq") open-coded
irq_move_irq() but left out checking if the IRQ is disabled. This broke
resuming from suspend since it tries to move a (disabled) irq without
holding the IRQ's desc->lock. Fix it by adding in a check for disabled
IRQs.
The resulting stacktrace was:
kernel BUG at /build/linux-UbQGH5/linux-4.4.0/kernel/irq/migration.c:31!
invalid opcode: 0000 [#1] SMP
Modules linked in: xenfs xen_privcmd ...
CPU: 0 PID: 9 Comm: migration/0 Not tainted 4.4.0-22-generic #39-Ubuntu
Hardware name: Xen HVM domU, BIOS 4.6.1-xs125180 05/04/2016
task: ffff88003d75ee00 ti: ffff88003d7bc000 task.ti: ffff88003d7bc000
RIP: 0010:[<ffffffff810e26e2>] [<ffffffff810e26e2>] irq_move_masked_irq+0xd2/0xe0
RSP: 0018:ffff88003d7bfc50 EFLAGS: 00010046
RAX: 0000000000000000 RBX: ffff88003d40ba00 RCX: 0000000000000001
RDX: 0000000000000001 RSI: 0000000000000100 RDI: ffff88003d40bad8
RBP: ffff88003d7bfc68 R08: 0000000000000000 R09: ffff88003d000000
R10: 0000000000000000 R11: 000000000000023c R12: ffff88003d40bad0
R13: ffffffff81f3a4a0 R14: 0000000000000010 R15: 00000000ffffffff
FS: 0000000000000000(0000) GS:ffff88003da00000(0000) knlGS:0000000000000000
CR2: 00007fd4264de624 CR3: 0000000037922000 CR4: 00000000003406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Stack:
ffff88003d40ba38 0000000000000024 0000000000000000 ffff88003d7bfca0
ffffffff814c8d92 00000010813ef89d 00000000805ea732 0000000000000009
0000000000000024 ffff88003cc39b80 ffff88003d7bfce0 ffffffff814c8f66
Call Trace:
[<ffffffff814c8d92>] eoi_pirq+0xb2/0xf0
[<ffffffff814c8f66>] __startup_pirq+0xe6/0x150
[<ffffffff814ca659>] xen_irq_resume+0x319/0x360
[<ffffffff814c7e75>] xen_suspend+0xb5/0x180
[<ffffffff81120155>] multi_cpu_stop+0xb5/0xe0
[<ffffffff811200a0>] ? cpu_stop_queue_work+0x80/0x80
[<ffffffff811203d0>] cpu_stopper_thread+0xb0/0x140
[<ffffffff810a94e6>] ? finish_task_switch+0x76/0x220
[<ffffffff810ca731>] ? __raw_callee_save___pv_queued_spin_unlock+0x11/0x20
[<ffffffff810a3935>] smpboot_thread_fn+0x105/0x160
[<ffffffff810a3830>] ? sort_range+0x30/0x30
[<ffffffff810a0588>] kthread+0xd8/0xf0
[<ffffffff810a04b0>] ? kthread_create_on_node+0x1e0/0x1e0
[<ffffffff8182568f>] ret_from_fork+0x3f/0x70
