Commit d5c55fa31a29, the backport of upstream 79d59d08082d
("iscsi-target: Fix wrong buffer / buffer overrun in
iscsi_change_param_value()") left out applying one chunk of the fix in
iscsi_login_non_zero_tsih_s2(). Add the missing chunk.
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit f5ebec9629cf78eeeea4b8258882a9f439ab2404 upstream.
disconnected_handler works are scheduled on system_wq.
When attempting to unload, first make sure all works
have cleaned up.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
commit 88c4015fda6d014392f76d3b1688347950d7a12d upstream.
There are 4 RDMA_CM events that all basically mean that
the user should teardown the IB connection:
- DISCONNECTED
- ADDR_CHANGE
- DEVICE_REMOVAL
- TIMEWAIT_EXIT
Only in DISCONNECTED/ADDR_CHANGE it makes sense to
call rdma_disconnect (send DREQ/DREP to our initiator).
So we keep the same teardown handler for all of them
but only indicate calling rdma_disconnect for the relevant
events.
This patch also removes redundant debug prints for each single
event.
v2 changes:
- Call isert_disconnected_handler() for DEVICE_REMOVAL (Or + Sag)
commit e5e4746510d140261918aecce2e5e3aa4456f7e9 upstream.
Without a timetout some tests e.g. test_halt() can remain stuck forever.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
[Note that a different patch to address the same issue went in during
v3.15-rc1 (commit 4442dc8a), but includes a bunch of other changes that
don't strictly apply to fixing the bug]
This patch changes rd_allocate_sgl_table() to explicitly clear
ramdisk_mcp backend memory pages by passing __GFP_ZERO into
alloc_pages().
This addresses a potential security issue where reading from a
ramdisk_mcp could return sensitive information, and follows what
>= v3.15 does to explicitly clear ramdisk_mcp memory at backend
device initialization time.
Reported-by: Jorge Daniel Sequeira Matias <jdsm@tecnico.ulisboa.pt>
Cc: Jorge Daniel Sequeira Matias <jdsm@tecnico.ulisboa.pt>
commit 2426bd456a61407388b6e61fc5f98dbcbebc50e2 upstream.
When an initiator sends an allocation length bigger than what its
command consumes, the target should only return the actual response data
and set the residual length to the unused part of the allocation length.
Add a helper function that command handlers (INQUIRY, READ CAPACITY,
etc) can use to do this correctly, and use this code to get the correct
residual for commands that don't use the full initiator allocation in the
handlers for READ CAPACITY, READ CAPACITY(16), INQUIRY, MODE SENSE and
REPORT LUNS.
This addresses a handful of failures as reported by Christophe with
the Windows Certification Kit:
http://permalink.gmane.org/gmane.linux.scsi.target.devel/6515
Tested-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr>
commit bbc050488525e1ab1194c27355f63c66814385b8 upstream.
This patch fixes a iscsi_queue_req memory leak when ABORT_TASK response
has been queued by TFO->queue_tm_rsp() -> lio_queue_tm_rsp() after a
long standing I/O completes, but the connection has already reset and
waiting for cleanup to complete in iscsit_release_commands_from_conn()
-> transport_generic_free_cmd() -> transport_wait_for_tasks() code.
It moves iscsit_free_queue_reqs_for_conn() after the per-connection command
list has been released, so that the associated se_cmd tag can be completed +
released by target-core before freeing any remaining iscsi_queue_req memory
for the connection generated by lio_queue_tm_rsp().
Cc: Thomas Glanzmann <thomas@glanzmann.de>
Cc: Charalampos Pournaris <charpour@gmail.com>
commit a95d6511303b848da45ee27b35018bb58087bdc6 upstream.
This patch fixes a bug where multiple waiters on ->t_transport_stop_comp
occurs due to a concurrent ABORT_TASK and session reset both invoking
transport_wait_for_tasks(), while waiting for the associated se_cmd
descriptor backend processing to complete.
For this case, complete_all() should be invoked in order to wake up
both waiters in core_tmr_abort_task() + transport_generic_free_cmd()
process contexts.
commit f15e9cd910c4d9da7de43f2181f362082fc45f0f upstream.
This patch fixes a bug where se_cmd descriptors associated with a
Task Management Request (TMR) where not setting CMD_T_ACTIVE before
being dispatched into target_tmr_work() process context.
This is required in order for transport_generic_free_cmd() ->
transport_wait_for_tasks() to wait on se_cmd->t_transport_stop_comp
if a session reset event occurs while an ABORT_TASK is outstanding
waiting for another I/O to complete.
commit 9d49f5e284e700576f3b65f1e28dea8539da6661 upstream.
In ungraceful teardowns isert close flows seem racy such that
isert_wait_conn hangs as RDMA_CM_EVENT_DISCONNECTED never
gets invoked (no one called rdma_disconnect).
Both graceful and ungraceful teardowns will have rx flush errors
(isert posts a batch once connection is established). Once all
flush errors are consumed we invoke isert_wait_conn and it will
be responsible for calling rdma_disconnect. This way it can be
sure that rdma_disconnect was called and it won't wait forever.
This patch also removes the logout_posted indicator. either the
logout completion was consumed and no problem decrementing the
post_send_buf_count, or it was consumed as a flush error. no point
of keeping it for isert_wait_conn as there is no danger that
isert_conn will be accidentally removed while it is running.
(Drop unnecessary sleep_on_conn_wait_comp check in
isert_cq_rx_comp_err - nab)
commit e346ab343f4f58c12a96725c7b13df9cc2ad56f6 upstream.
In case np_thread state is in RESET/SHUTDOWN/EXIT states,
no point for isert to stall there as we may get a hang in
case no one will wake it up later.
commit da64c27d3c93ee9f89956b9de86c4127eb244494 upstream.
LDISCs shouldn't call tty->ops->write() from within
->write_wakeup().
->write_wakeup() is called with port lock taken and
IRQs disabled, tty->ops->write() will try to acquire
the same port lock and we will deadlock.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Reported-by: Huang Shijie <b32955@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Tested-by: Andreas Bießmann <andreas@biessmann.de>
commit 3b35fc81e7ec552147a4fd843d0da0bbbe4ef253 upstream.
timestamps in v4l2 buffers returned to userspace are updated in
uvc_video_clock_update() which uses timestamps fetched from
uvc_video_clock_decode() by calling unconditionally ktime_get_ts().
Hence setting the module clock param to realtime has no effect before
this patch.
This has been tested with ffmpeg:
ffmpeg -y -f v4l2 -input_format yuyv422 -video_size 640x480 -framerate 30 -i /dev/video0 \
-f alsa -acodec pcm_s16le -ar 16000 -ac 1 -i default \
-c:v libx264 -preset ultrafast \
-c:a libfdk_aac \
out.mkv
and inspecting the v4l2 input starting timestamp.
Signed-off-by: Olivier Langlois <olivier@trillion01.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit 73577d1df8e1f31f6b1a5eebcdbc334eb0330e47 upstream.
This patch fixes the following issue:
If DSDT is customized, no local DSDT copy is needed.
References: https://bugzilla.kernel.org/show_bug.cgi?id=69711
Signed-off-by: Enrico Etxe Arte <goitizena.generoa@gmail.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
[rjw: Subject]
commit 5d42b0fa25df7ef2f575107597c1aaebe2407d10 upstream.
ACPICA BZ 1077. David Binderman.
References: https://bugs.acpica.org/show_bug.cgi?id=1077
Signed-off-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
commit 85ac1a1772bb41da895bad83a81f6a62c8f293f6 upstream.
Currently stk1160_read_reg() uses a stack-allocated char to get the
read control value. This is wrong because usb_control_msg() requires
a kmalloc-ed buffer.
This commit fixes such issue by kmalloc'ating a 1-byte buffer to receive
the read value.
While here, let's remove the urb_buf array which was meant for a similar
purpose, but never really used.
Cc: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Sander Eikelenboom <linux@eikelenboom.it>
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
commit deb29e90221a6d4417aa67be971613c353180331 upstream.
When ivtv PCM device is accessed at the state where no firmware is
loaded, it oopses like:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000050
IP: [<ffffffffa049a881>] try_mailbox.isra.0+0x11/0x50 [ivtv]
Call Trace:
[<ffffffffa049aa20>] ivtv_api_call+0x160/0x6b0 [ivtv]
[<ffffffffa049af86>] ivtv_api+0x16/0x40 [ivtv]
[<ffffffffa049b10c>] ivtv_vapi+0xac/0xc0 [ivtv]
[<ffffffffa049d40d>] ivtv_start_v4l2_encode_stream+0x19d/0x630 [ivtv]
[<ffffffffa0530653>] snd_ivtv_pcm_capture_open+0x173/0x1c0 [ivtv_alsa]
[<ffffffffa04526f1>] snd_pcm_open_substream+0x51/0x100 [snd_pcm]
[<ffffffffa0452853>] snd_pcm_open+0xb3/0x260 [snd_pcm]
[<ffffffffa0452a37>] snd_pcm_capture_open+0x37/0x50 [snd_pcm]
[<ffffffffa033f557>] snd_open+0xa7/0x1e0 [snd]
[<ffffffff8118a628>] chrdev_open+0x88/0x1d0
[<ffffffff811840be>] do_dentry_open+0x1de/0x270
[<ffffffff81193a73>] do_last+0x1c3/0xec0
[<ffffffff81194826>] path_openat+0xb6/0x670
[<ffffffff81195b65>] do_filp_open+0x35/0x80
[<ffffffff81185449>] do_sys_open+0x129/0x210
[<ffffffff815b782d>] system_call_fastpath+0x1a/0x1f
This patch adds the check of firmware at PCM open callback like other
open callbacks of this driver.
Bugzilla: https://apibugzilla.novell.com/show_bug.cgi?id=875440
commit c14829fad88dbeda57253590695b85ba51270621 upstream.
Only call usb_autopm_put_interface() if the corresponding
usb_autopm_get_interface() was successful.
This prevents a potential runtime PM counter imbalance should
usb_autopm_get_interface() fail. Note that the USB PM usage counter is
reset when the interface is unbound, but that the runtime PM counter may
be left unbalanced.
Also add comment on why we don't need to worry about racing
resume/suspend on autopm_get failures.
Fixes: d5fd650cfc7f ("usb: serial: prevent suspend/resume from racing
against probe/remove")
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 0ce5fb58564fd85aa8fd2d24209900e2e845317b upstream.
A set of new VID/PIDs retrieved from the out-of-tree GobiNet/GobiSerial
Sierra Wireless drivers.
Signed-off-by: Aleksander Morgado <aleksander@aleksander.es>
Link: http://marc.info/?l=linux-usb&m=140136310027293&w=2
Cc: <stable@vger.kernel.org> # backport in link above
commit ff1fcd50bc2459744e6f948310bc18eb7d6e8c72 upstream.
commit 80cc0fcbdaeaf10d04ba27779a2d7ceb73d2717a upstream.
Make sure that needs_remote_wake up is always set when there are open
ports.
Currently close() would unconditionally set needs_remote_wakeup to 0
even though there might still be open ports. This could lead to blocked
input and possibly dropped data on devices that do not support remote
wakeup (and which must therefore not be runtime suspended while open).
Add an open_ports counter (protected by the susp_lock) and only clear
needs_remote_wakeup when the last port is closed.
Fixes: e6929a9020ac ("USB: support for autosuspend in sierra while
online")
commit 014333f77c0b71123d6ef7d31a9724e0699c9548 upstream.
The delayed-write queue was never emptied on disconnect, something which
would lead to leaked urbs and transfer buffers if the device is
disconnected before being runtime resumed due to a write.
online")
commit 7fdd26a01eb7b6cb6855ff8f69ef4a720720dfcb upstream.
Neither the transfer buffer or the urb itself were released in the
resume error path for delayed writes. Also on errors, the remainder of
the queue was not even processed, which leads to further urb and buffer
leaks.
The same error path also failed to balance the outstanding-urb counter,
something which results in degraded throughput or completely blocked
writes.
Fix this by releasing urb and buffer and balancing counters on errors,
and by always processing the whole queue even when submission of one urb
fails.
online")
commit 8452727de70f6ad850cd6d0aaa18b5d9050aa63b upstream.
Fix use after free or NULL-pointer dereference during suspend and
resume.
The port data may never have been allocated (port probe failed)
or may already have been released by port_remove (e.g. driver is
unloaded) when suspend and resume are called.
online")
commit 353fe198602e8b4d1c7bdcceb8e60955087201b1 upstream.
Fix AA deadlock in open error path that would call close() and try to
grab the already held disc_mutex.
Fixes: b9a44bc19f48 ("sierra: driver urb handling improvements")
commit fb7ad4f93d9f0f7d49beda32f5e7becb94b29a4d upstream.
Keep trying to submit urbs rather than bail out on first read-urb
submission error, which would also prevent I/O for any further ports
from being resumed.
Instead keep an error count, for all types of failed submissions, and
let USB core know that something went wrong.
Also make sure to always clear the suspended flag. Currently a failed
read-urb submission would prevent cached writes as well as any
subsequent writes from being submitted until next suspend-resume cycle,
something which may not even necessarily happen.
Note that USB core currently only logs an error if an interface resume
failed.
Fixes: 383cedc3bb43 ("USB: serial: full autosuspend support for the
option driver")
commit 9096f1fbba916c2e052651e9de82fcfb98d4bea7 upstream.
The interrupt urb was submitted unconditionally at resume, something
which could lead to a NULL-pointer dereference in the urb completion
handler as resume may be called after the port and port data is gone.
Fix this by making sure the interrupt urb is only submitted and active
when the port is open.
option driver")
commit 79eed03e77d481b55d85d1cfe5a1636a0d3897fd upstream.
The delayed-write queue was never emptied at shutdown (close), something
which could lead to leaked urbs if the port is closed before being
When this happens the output buffer would not drain on close
(closing_wait timeout), and after consecutive opens, writes could be
corrupted with previously buffered data, transfered with reduced
throughput or completely blocked.
Note that unbusy_queued_urb() was simply moved out of CONFIG_PM.
option driver")
commit 170fad9e22df0063eba0701adb966786d7a4ec5a upstream.
Fix race between write() and suspend() which could lead to writes being
dropped (or I/O while suspended) if the device is runtime suspended
while a write request is being processed.
Specifically, suspend() releases the susp_lock after determining the
device is idle but before setting the suspended flag, thus leaving a
window where a concurrent write() can submit an urb.
option driver")
commit d9e93c08d8d985e5ef89436ebc9f4aad7e31559f upstream.
We find a race between write and resume. usb_wwan_resume run play_delayed()
and spin_unlock, but intfdata->suspended still is not set to zero.
At this time usb_wwan_write is called and anchor the urb to delay
list. Then resume keep running but the delayed urb have no chance
to be commit until next resume. If the time of next resume is far
away, tty will be blocked in tty_wait_until_sent during time. The
race also can lead to writes being reordered.
This patch put play_Delayed and intfdata->suspended together in the
spinlock, it's to avoid the write race during resume.
option driver")
Signed-off-by: xiao jin <jin.xiao@intel.com>
Signed-off-by: Zhang, Qi1 <qi1.zhang@intel.com>
Reviewed-by: David Cohen <david.a.cohen@linux.intel.com>
commit db0904737947d509844e171c9863ecc5b4534005 upstream.
When enable usb serial for modem data, sometimes the tty is blocked
in tty_wait_until_sent because portdata->out_busy always is set and
have no chance to be cleared.
We find a bug in write error path. usb_wwan_write set portdata->out_busy
firstly, then try autopm async with error. No out urb submit and no
usb_wwan_outdat_callback to this write, portdata->out_busy can't be
cleared.
This patch clear portdata->out_busy if usb_wwan_write try autopm async
with error.
option driver")
commit 972754cfaee94d6e25acf94a497bc0a864d91b7e upstream.
I had occasional screen corruption with the matrox framebuffer driver and
I found out that the reason for the corruption is that the hardware
blitter accesses the videoram while it is being written to.
The matrox driver has a macro WaitTillIdle() that should wait until the
blitter is idle, but it sometimes doesn't work. I added a dummy read
mga_inl(M_STATUS) to WaitTillIdle() to fix the problem. The dummy read
will flush the write buffer in the PCI chipset, and the next read of
M_STATUS will return the hardware status.
Since applying this patch, I had no screen corruption at all.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit 1b15d2e5b8077670b1e6a33250a0d9577efff4a5 upstream.
Some drivers use the first HID report in the list instead of using an
index. In these cases, validation uses ID 0, which was supposed to mean
"first known report". This fixes the problem, which was causing at least
the lgff family of devices to stop working since hid_validate_values
was being called with ID 0, but the devices used single numbered IDs
for their reports:
0x05, 0x01, /* Usage Page (Desktop), */
0x09, 0x05, /* Usage (Gamepad), */
0xA1, 0x01, /* Collection (Application), */
0xA1, 0x02, /* Collection (Logical), */
0x85, 0x01, /* Report ID (1), */
Reported-by: Simon Wood <simon@mungewell.org>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit acf47d4f9c39b1cba467aa9442fc2efe0b1da741 upstream.
Fix potential I/O while runtime suspended due to missing PM operations
in send_setup.
option driver")
commit b0a50e92bda3c4aeb8017d4e6c6e92146ebd5c9b upstream.
Leandro Liptak reports that his HASEE E200 computer hangs when we ask
the BIOS to hand over control of the EHCI host controller. This
definitely sounds like a bug in the BIOS, but at the moment there is
no way to fix it.
This patch works around the problem by avoiding the handoff whenever
the motherboard and BIOS version match those of Leandro's computer.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Leandro Liptak <leandroliptak@gmail.com>
Tested-by: Leandro Liptak <leandroliptak@gmail.com>
commit 77c2f02edbeda9409a7cf3fd66233015820c213a upstream.
Commit 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built")
apparently required that checks for CONFIG_USB_GADGET_OMAP would be
replaced with checks for CONFIG_USB_OMAP. Do so now for the remaining
checks for CONFIG_USB_GADGET_OMAP, even though these checks have
basically been broken since v3.1.
And, since we're touching this code, use the IS_ENABLED() macro, so
things will now (hopefully) also work if USB_OMAP is modular.
Fixes: 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built")
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
commit 687ef9817df7ed960d14575b9033dde3d04631fe upstream.
so it seems like DWC3 IP doesn't clear stalls
automatically when we disable an endpoint, because
of that, we _must_ make sure stalls are cleared
before clearing the proper bit in DALEPENA register.
Reported-by: Johannes Stezenbach <js@sig21.net>
commit d30f2065d6da377cc76771aca5a9850cfca8723b upstream.
basically renamed the Kconfig symbol USB_GADGET_PXA25X to USB_PXA25X. It
did not rename the related macros in use at that time. Commit
c0a39151a405 ("ARM: pxa: fix inconsistent CONFIG_USB_PXA27X") did so for
all but one macro. Rename that last macro too now.
commit 32b36eeae6a859670d2939a7d6136cb5e9ed64f8 upstream.
In usbtest, tests 5 - 8 use the scatter-gather library in usbcore
without any sort of timeout. If there's a problem in the gadget or
host controller being tested, the test can hang.
This patch adds a 10-second timeout to the tests, so that they will
fail gracefully with an ETIMEDOUT error instead of hanging.
Reported-by: Huang Rui <ray.huang@amd.com>
Tested-by: Huang Rui <ray.huang@amd.com>
commit e4d58f5dcb7d7be45df8def31881ebfae99c75da upstream.
TEST 12 and TEST 24 unlinks the URB write request for N times. When
host and gadget both initialize pattern 1 (mod 63) data series to
transfer, the gadget side will complain the wrong data which is not
expected. Because in host side, usbtest doesn't fill the data buffer
as mod 63 and this patch fixed it.
[20285.488974] dwc3 dwc3.0.auto: ep1out-bulk: Transfer Not Ready
[20285.489181] dwc3 dwc3.0.auto: ep1out-bulk: reason Transfer Not Active
[20285.489423] dwc3 dwc3.0.auto: ep1out-bulk: req ffff8800aa6cb480 dma aeb50800 length 512 last
[20285.489727] dwc3 dwc3.0.auto: ep1out-bulk: cmd 'Start Transfer' params 00000000 a9eaf000 00000000
[20285.490055] dwc3 dwc3.0.auto: Command Complete --> 0
[20285.490281] dwc3 dwc3.0.auto: ep1out-bulk: Transfer Not Ready
[20285.490492] dwc3 dwc3.0.auto: ep1out-bulk: reason Transfer Active
[20285.490713] dwc3 dwc3.0.auto: ep1out-bulk: endpoint busy
[20285.490909] dwc3 dwc3.0.auto: ep1out-bulk: Transfer Complete
[20285.491117] dwc3 dwc3.0.auto: request ffff8800aa6cb480 from ep1out-bulk completed 512/512 ===> 0
[20285.491431] zero gadget: bad OUT byte, buf[1] = 0
[20285.491605] dwc3 dwc3.0.auto: ep1out-bulk: cmd 'Set Stall' params 00000000 00000000 00000000
[20285.491915] dwc3 dwc3.0.auto: Command Complete --> 0
[20285.492099] dwc3 dwc3.0.auto: queing request ffff8800aa6cb480 to ep1out-bulk length 512
[20285.492387] dwc3 dwc3.0.auto: ep1out-bulk: Transfer Not Ready
[20285.492595] dwc3 dwc3.0.auto: ep1out-bulk: reason Transfer Not Active
[20285.492830] dwc3 dwc3.0.auto: ep1out-bulk: req ffff8800aa6cb480 dma aeb51000 length 512 last
[20285.493135] dwc3 dwc3.0.auto: ep1out-bulk: cmd 'Start Transfer' params 00000000 a9eaf000 00000000
[20285.493465] dwc3 dwc3.0.auto: Command Complete --> 0
Signed-off-by: Huang Rui <ray.huang@amd.com>
commit 8bab797c6e5724a43b7666ad70860712365cdb71 upstream.
This is a static checker fix. The "dev" variable is always NULL after
the while statement so we would be dereferencing a NULL pointer here.
Fixes: 819a3eba4233 ('[PATCH] applicom: fix error handling')
commit d3921a03a89acb1b9ca599590c0131c89f8737d8 upstream.
Commit d0f47ff17f29 ("ASoC: OMAP: Build config cleanup for McBSP")
removed the Kconfig symbol OMAP_MCBSP. It left two checks for
CONFIG_OMAP_MCBSP untouched.
Convert these to checks for CONFIG_SND_OMAP_SOC_MCBSP. That must be
correct, since that re-enables calls to functions that are all found in
sound/soc/omap/mcbsp.c. And that file is built only if
CONFIG_SND_OMAP_SOC_MCBSP is defined.
Fixes: d0f47ff17f29 ("ASoC: OMAP: Build config cleanup for McBSP")
commit dfee4111febf3d9ef3a640b2cd6205c75f4e7e3d upstream.
Fix NULL pointer exception when platform data is not supplied. The
driver dereferenced pdata pointer where it could be NULL.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 810d601f07c
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
commit 6954cc1f238199e971ec905c5cc87120806ac981 upstream.
Fix null-pointer dereference at probe when the mdio platform device is
missing (e.g. when it has been disabled in DT).
commit 0b5a958cf4df3a5cd578b861471e62138f55c85e upstream.
As remarked by Christopher R. Baker in his post at
http://marc.info/?l=linux-can&m=139707295706465&w=2
there's a possibility for an use after free condition at device removal.
This simplified patch introduces an additional variable to prevent the issue.
Thanks for catching this.
Reported-by: Christopher R. Baker <cbaker@rec.ri.cmu.edu>
Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 8ba42fb7b17649c9ab5b5e79d4e90370a0b4645e upstream.
i2c_smbus_read_word_data() does host endian conversion already,
no need for le16_to_cpu()
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 4f3bcd878f1d3c730fe00f619b7260c6125d49eb upstream.
at91_adc_get_trigger_value_by_name() was returning -ENOMEM truncated to
a positive u8 and that doesn't work. I've changed it to int and
refactored it to preserve the error code.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Tested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit c404618cd06dad771495fe1cf9d5a63b5664f65f upstream.
Consider high byte of proximity min and max treshold in function
'tsl2x7x_chip_on'. So far, the high byte was not set.
Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
max11611.
commit a91a73c8b39a6b8bcc53fafa5372c65387c81233 upstream.
Reported-by: Erik Habbinga <Erik.Habbinga@schneider-electric.com>
Acked-by: Hartmut Knaack <knaack.h@gmx.de>
commit ae339336dc950b9b05e7ccd3565dd3e8781c06d9 upstream.
The current code posts periodic memory pressure status from a dedicated thread.
Under some conditions, especially when we are releasing a lot of memory into
the guest, we may not send timely pressure reports back to the host. Fix this
issue by reporting pressure in all contexts that can be active in this driver.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
