Commit 2b48716d1d2f2edb1e7cbc5ecf1cb2cb39373e33 back in January
2006 was a bit overzealous. It removed .owner from all i2c drivers,
including i2c-isa ones, while they still need it.
Fix from http://bugzilla.kernel.org/show_bug.cgi?id=7747
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Put in new email address.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Update the pci device id table to match 2.6.20 (except for new 88e807x
that is still experimental).
This is a simple enhancement to dump more device statistics with ethtool.
Ben added this for 2.6.18, it allows sky2 to run on big endian.
The 802 standard allows pause frames to be either unicast or multicast.
Switches seem to send unicast frames, but on a direct link, other boards send
multicast pause. Unless the filter bit is set, these pause frames get
dropped.
Different chipsets have different amount of ram buffer (some have none),
so need to make sure that driver does proper setup for all cases from 0 on
to 48K, in units of 1K.
This is a backport of the code from 2.6.19 or later
Add support for the Winbond W83687THF chip to the w83627hf hardware
monitoring driver. This new chip is almost similar to the already
supported W83627THF chip, except for VID and a few other minor
changes.
The alarm bits and the beep enable bits are in different positions in
the hardware. Document the problem and leave it to the user-space code
to handle the situation. When this driver is updated to the standardized
sysfs alarm/beep methodology, this won't be a problem.
This is a documentation only change.
Signed-off by: Charles Spirakis <bezaur@gmail.com>
Add support for the w83791d sensor chip. The w83791d hardware is
somewhere between the w83781d and the w83792d and this driver code
is derived from the code that supports those chips.
Signed-off-by: Charles Spirakis <bezaur@gmail.com>
New driver (smsc47m192) which supports voltage and temperature
measurement features of SMSC LPC47M192 and LPC47M997 chips.
Signed-off-by: Hartmut Rick <linux@rick.claranet.de>
This is a new hardware monitoring driver for the National Semiconductor
PC87427 Super-I/O chip. It only supports fan speed monitoring for now,
while the chip can do much more.
Thanks to Amir Habibi at Candelis for setting up a test system, and to
Michael Kress for testing several iterations of this driver.
Add LM82 temperature sensor support (similar to the LM83,
but less featureful).
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
This patch adds the ATI IXP southbridges support to i2c-piix4,
as it turned out those chips are compatible with it.
Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz>
Add Broadcom HT-1000 south bridge's PCI ID to i2c-piix driver. Note
that at least on Supermicro H8SSL it uses non-standard SMBHSTCFG = 3
and standard values like 0 or 9 causes hangup.
Signed-off-by: Martin Devera <devik@cdi.cz>
Arjan van de Ven <arjan@infradead.org> reported an illegal re-usage of
the fileoperations struct if more than one dvb device (e.g. frontend) is
present.
This patch fixes this issue.
It allocates a new fileoperations struct each time a device is
registered and copies the default template fileops.
Signed-off-by: Marcel Siegert <mws@linuxtv.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
This one adds another vendor ID to rtl8150 driver.
Signed-off-by: Petko Manolov <petkan@nucleusys.com>
I just got a "ZyXEL Prestige USB Adapter" that is actually RTL8150
adapter. Here is the relevant /proc/bus/usb/devices output (after
adding the vendor/product IDs to the driver):
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#=119 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=0586 ProdID=401a Rev= 1.00
S: Manufacturer=ZyXEL
S: Product=Prestige USB Adapter
S: SerialNumber=1027
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=120mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=ff Driver=rtl8150
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
This patch adds the ZyXEL vendor ID to the rtl8150.c driver. The
device has absolutely no identifying marks on the outside for model
type, just a serial number, and I can't find anything on ZyXEL's
website, so I called the product ID PRODUCT_ID_PRESTIGE to match the
product string.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Add a workaround for dual port PCI-X card that returns status out of
order sometimes because of split transactions.
This driver uses port 0 to handle receives on both ports. So
the netif_poll_disable call in dev_close would end up stopping the
second port on dual port cards.
That code doesn't do what its author apparently thought it would do...
6.5.7(5): The result of E1 >> E2 is E1 right-shifted E2 bit positions.
If E1 has a signed type and a negative value, the resulting value
is implementation defined.
So, cast -1 to unsigned type to make result well-defined.
[ Modified to use ~0U based upon recommendation from Al Viro. -DaveM ]
gcc emits the following warning:
drivers/atm/firestream.c: In function ‘fs_open’:
drivers/atm/firestream.c:870: warning: ‘tmc0’ may be used uninitialized in this function
This indicates a real bug. We should check make_rate() return value for
potential errors.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Thanks to Randy Dunlap.
We are doing ->buf_prepare(buf) before adding buf to q->stream list. This
means that videobuf_qbuf() should not try to re-add a STATE_PREPARED buffer.
Adrian Bunk:
Backported to 2.6.16.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
We are inside spin_lock_irqsave(). quoth akpm's debug facility:
[ 231.948000] SCSI device sda: 195371568 512-byte hdwr sectors (100030 MB)
[ 232.232000] ata1.00: configured for UDMA/33
[ 232.404000] WARNING (1) at arch/i386/mm/highmem.c:47 kmap_atomic()
[ 232.404000] [<c01162e6>] kmap_atomic+0xa9/0x1ab
[ 232.404000] [<c0242c81>] ata_scsi_rbuf_get+0x1c/0x30
[ 232.404000] [<c0242caf>] ata_scsi_rbuf_fill+0x1a/0x87
[ 232.404000] [<c0243ab2>] ata_scsiop_mode_sense+0x0/0x309
[ 232.404000] [<c01729d5>] end_bio_bh_io_sync+0x0/0x37
[ 232.404000] [<c02311c6>] scsi_done+0x0/0x16
[ 232.404000] [<c0242dcc>] ata_scsi_simulate+0xb0/0x13f
The Silicon Hill club is not what it used to be.
Signed-off-by: Rudolf Marek <r.marek@assembler.cz>
Update the documentation for the k8temp driver.
When 'repair' finds a block that is different one the various
parts of the mirror. it is meant to write a chosen good version
to the others. However it currently writes out the original data
to each. The memcpy to make all the data the same is missing.
Also correct a test so that 'repair' causes a repair, rather than
anything other then 'repair'.
Signed-off-by: Neil Brown <neilb@suse.de>
Add support for the temperature sensor(s) found in AMD K8 CPUs.
The sysfs files in arcmsr are non-standard in that they aren't simple
filename value pairs, the values actually contain preceeding text which
would have to be parsed. The idea of sysfs files is that the file name
is the description and the contents is a simple value.
Fix up arcmsr to conform to this standard.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Remove sysfs_remove_bin_file() return-value checking from the areca driver.
There's nothing a driver can do if sysfs file removal fails, so we'll soon be
changing sysfs_remove_bin_file() to internally print a diagnostic and to
return void.
arcmsr is a driver for the Areca Raid controller, a host based RAID
subsystem that speaks SCSI at the firmware level.
This patch is quite a clean up over the initial submission with
contributions from:
Randy Dunlap <rdunlap@xenotime.net>
Christoph Hellwig <hch@lst.de>
Matthew Wilcox <matthew@wil.cx>
Signed-off-by: Erich Chen <erich@areca.com.tw>
Stumbled over this because of coverity (id #492),
seems like we are missing a return statement here and fail
to do proper bounds checking. If this assumption is false
we should at least change the identation to make it clear
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
.. fix debug printk. Why, oh why, one would want to do
(u16 & 0xff) << 8
and print it with %02x format?
Spotted by coverity/Adrian Bunk.
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
Ramiro Voicu hits the BUG_ON(!pte_none(*pte)) in zeromap_pte_range: kernel
bugzilla 7645. Right: read_zero_pagealigned uses down_read of mmap_sem,
but another thread's racing read of /dev/zero, or a normal fault, can
easily set that pte again, in between zap_page_range and zeromap_page_range
getting there. It's been wrong ever since 2.4.3.
The simple fix is to use down_write instead, but that would serialize reads
of /dev/zero more than at present: perhaps some app would be badly
affected. So instead let zeromap_page_range return the error instead of
BUG_ON, and read_zero_pagealigned break to the slower clear_user loop in
that case - there's no need to optimize for it.
Use -EEXIST for when a pte is found: BUG_ON in mmap_zero (the other user of
zeromap_page_range), though it really isn't interesting there. And since
mmap_zero wants -EAGAIN for out-of-memory, the zeromaps better return that
than -ENOMEM.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
When the old IDE layer calls into methods in the driver during error
handling it is essentially random whether ide_lock is already held. This
causes a deadlock in the atiixp driver which also uses ide_lock internally
for locking.
Switch to a private lock instead.
[akpm@osl.org: cleanup]
Signed-off-by: Alan Cox <alan@redhat.com>
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
It's a known fact that Windows times out commands after 7 seconds, so
drives generally try and respond if they can before that happens. We
default to 5 seconds, which sometimes is a bit too short.
Jeremy Higdon reported here:
http://lkml.org/lkml/2007/1/1/145
that his drive takes longer than 5 seconds for a "read track
information" command, later confirming that it is about 6.7 seconds.
So just do the sane thing and change the default command timeout to 7
seconds to avoid other surprises.
Fix typo in check of return value of qla1280_bus_reset() which would
result in an adapter reset in addition to the bus reset.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Original patch from Ian Dall in bugzilla. Set command timeout as
specified by the SCSI layer rather than hardcode it to 30 seconds. I
have received a couple of reports of people hitting this one with
various tape configurations and the patch looks obviously correct.
From http://bugzilla.kernel.org/show_bug.cgi?id=6275
Ian Dall <ian@beware.dropbear.id.au>:
The command sent to the card was using a 30second timeout regardless of the
timeout requested in the scsi command passed down from higher levels.
BUG: warning at kernel/lockdep.c:1816/trace_hardirqs_on() (Not tainted)
[<c04051ee>] show_trace_log_lvl+0x58/0x171
[<c0405802>] show_trace+0xd/0x10
[<c040591b>] dump_stack+0x19/0x1b
[<c043abee>] trace_hardirqs_on+0xa2/0x11e
[<c06143c3>] _spin_unlock_irq+0x22/0x26
[<c0541540>] rtc_get_rtc_time+0x32/0x176
[<c0419ba4>] hpet_rtc_interrupt+0x92/0x14d
[<c0450f94>] handle_IRQ_event+0x20/0x4d
[<c0451055>] __do_IRQ+0x94/0xef
[<c040678d>] do_IRQ+0x9e/0xbd
[<c0404a49>] common_interrupt+0x25/0x2c
DWARF2 unwinder stuck at common_interrupt+0x25/0x2c
I have a Marvell board which has the same i2c hw block than mv64xxx, so
I'm trying to use i2c-mv64xxx driver.
But I get the following random oops at boot:
Unable to handle kernel NULL pointer dereference at virtual address 00000002
Backtrace:
[<c0397e4c>] (mv64xxx_i2c_intr+0x0/0x2b8) from [<c02879c4>] (__do_irq+0x4c/0x8c)
[<c0287978>] (__do_irq+0x0/0x8c) from [<c0287c0c>] (do_level_IRQ+0x68/0xc0)
r8 = C0501E08 r7 = 00000005 r6 = C0501E08 r5 = 00000005
r4 = C048BB78
[<c0287ba4>] (do_level_IRQ+0x0/0xc0) from [<c02885f8>] (asm_do_IRQ+0x50/0x134)
r6 = C0449C78 r5 = F1020000 r4 = FFFFFFFF
[<c02885a8>] (asm_do_IRQ+0x0/0x134) from [<c02869c4>] (__irq_svc+0x24/0x100)
r8 = C1CAC400 r7 = 00000005 r6 = 00000002 r5 = F1020000
r4 = FFFFFFFF
[<c0287efc>] (setup_irq+0x0/0x124) from [<c02880d0>] (request_irq+0xb0/0xd0)
r7 = C041B2AC r6 = C0397E4C r5 = 00000000 r4 = 00000005
[<c0288020>] (request_irq+0x0/0xd0) from [<c03985f4>] (mv64xxx_i2c_probe+0x148/0x244)
[<c03984ac>] (mv64xxx_i2c_probe+0x0/0x244) from [<c038bedc>] (platform_drv_probe+0x20/0x24)
The oops is caused by a spurious interrupt that occurs when request_irq
is called. mv64xxx_i2c_fsm() tries to read drv_data->msg, which is NULL.
I noticed that hardware init is done after requesting irq. Thus any
pending irq from previous hardware usage may cause this.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
reference to .init.text: from .text between 'cx88_card_setup'
(at offset 0x68c) and 'cx88_risc_field'
Caused by leadtek_eeprom() being declared __devinit and called from
a non-devinit context.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Stolen from a patch by Randy Dunlap.
The line:
hp->Mode &= !RIO_PCI_INT_ENABLE;
is obviously wrong as RIO_PCI_INT_ENABLE=0x04 and is used as a bitmask
2 lines before. Getting no IRQ would not disable RIO_PCI_INT_ENABLE
but rather RIO_PCI_BOOT_FROM_RAM which equals 0x01.
Obvious fix is to change ! for ~.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Update pci ids.
Signed-off-by: Chuck Short <zulcss@gmail.com>
Signed-off-by: Ben Collins <bcollins@ubuntu.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
