commit eda98796aff0d9bf41094b06811f5def3b4c333c upstream.
The vivid_fb_ioctl() code fails to initialize the 16 _reserved bytes of
struct fb_vblank after the ->hcount member. Add an explicit
memset(0) before filling the structure to avoid the info leak.
Signed-off-by: Salva Peiró <speirofr@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 9225c0b7b976dd9ceac2b80727a60d8fcb906a62 upstream.
missing get_user()
commit 79b568b9d0c7c5d81932f4486d50b38efdd6da6d upstream.
hid_connect adds various strings to the buffer but they're all
conditional. You can find circumstances where nothing would be written
to it but the kernel will still print the supposedly empty buffer with
printk. This leads to corruption on the console/in the logs.
Ensure buf is initialized to an empty string.
Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org>
[dvhart: Initialize string to "" rather than assign buf[0] = NULL;]
Cc: Jiri Kosina <jikos@kernel.org>
Cc: linux-input@vger.kernel.org
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit e46e31a3696ae2d66f32c207df3969613726e636 upstream.
When using the Promise TX2+ SATA controller on PA-RISC, the system often
crashes with kernel panic, for example just writing data with the dd
utility will make it crash.
Kernel panic - not syncing: drivers/parisc/sba_iommu.c: I/O MMU @ 000000000000a000 is out of mapping resources
CPU: 0 PID: 18442 Comm: mkspadfs Not tainted 4.4.0-rc2 #2
Backtrace:
[<000000004021497c>] show_stack+0x14/0x20
[<0000000040410bf0>] dump_stack+0x88/0x100
[<000000004023978c>] panic+0x124/0x360
[<0000000040452c18>] sba_alloc_range+0x698/0x6a0
[<0000000040453150>] sba_map_sg+0x260/0x5b8
[<000000000c18dbb4>] ata_qc_issue+0x264/0x4a8 [libata]
[<000000000c19535c>] ata_scsi_translate+0xe4/0x220 [libata]
[<000000000c19a93c>] ata_scsi_queuecmd+0xbc/0x320 [libata]
[<0000000040499bbc>] scsi_dispatch_cmd+0xfc/0x130
[<000000004049da34>] scsi_request_fn+0x6e4/0x970
[<00000000403e95a8>] __blk_run_queue+0x40/0x60
[<00000000403e9d8c>] blk_run_queue+0x3c/0x68
[<000000004049a534>] scsi_run_queue+0x2a4/0x360
[<000000004049be68>] scsi_end_request+0x1a8/0x238
[<000000004049de84>] scsi_io_completion+0xfc/0x688
[<0000000040493c74>] scsi_finish_command+0x17c/0x1d0
The cause of the crash is not exhaustion of the IOMMU space, there is
plenty of free pages. The function sba_alloc_range is called with size
0x11000, thus the pages_needed variable is 0x11. The function
sba_search_bitmap is called with bits_wanted 0x11 and boundary size is
0x10 (because dma_get_seg_boundary(dev) returns 0xffff).
The function sba_search_bitmap attempts to allocate 17 pages that must not
cross 16-page boundary - it can't satisfy this requirement
(iommu_is_span_boundary always returns true) and fails even if there are
many free entries in the IOMMU space.
How did it happen that we try to allocate 17 pages that don't cross
16-page boundary? The cause is in the function iommu_coalesce_chunks. This
function tries to coalesce adjacent entries in the scatterlist. The
function does several checks if it may coalesce one entry with the next,
one of those checks is this:
if (startsg->length + dma_len > max_seg_size)
break;
When it finishes coalescing adjacent entries, it allocates the mapping:
sg_dma_len(contig_sg) = dma_len;
dma_len = ALIGN(dma_len + dma_offset, IOVP_SIZE);
sg_dma_address(contig_sg) =
PIDE_FLAG
| (iommu_alloc_range(ioc, dev, dma_len) << IOVP_SHIFT)
| dma_offset;
It is possible that (startsg->length + dma_len > max_seg_size) is false
(we are just near the 0x10000 max_seg_size boundary), so the funcion
decides to coalesce this entry with the next entry. When the coalescing
succeeds, the function performs
And now, because of non-zero dma_offset, dma_len is greater than 0x10000.
iommu_alloc_range (a pointer to sba_alloc_range) is called and it attempts
to allocate 17 pages for a device that must not cross 16-page boundary.
To fix the bug, we must make sure that dma_len after addition of
dma_offset and alignment doesn't cross the segment boundary. I.e. change
break;
to
if (ALIGN(dma_len + dma_offset + startsg->length, IOVP_SIZE) > max_seg_size)
break;
This patch makes this change (it precalculates max_seg_boundary at the
beginning of the function iommu_coalesce_chunks). I also added a check
that the mapping length doesn't exceed dma_get_seg_boundary(dev) (it is
not needed for Promise TX2+ SATA, but it may be needed for other devices
that have dma_get_seg_boundary lower than dma_get_max_seg_size).
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Helge Deller <deller@gmx.de>
commit d14053b3c714178525f22660e6aaf41263d00056 upstream.
The VT-d specification says that "Software must enable ATS on endpoint
devices behind a Root Port only if the Root Port is reported as
supporting ATS transactions."
We walk up the tree to find a Root Port, but for integrated devices we
don't find one — we get to the host bridge. In that case we *should*
allow ATS. Currently we don't, which means that we are incorrectly
failing to use ATS for the integrated graphics. Fix that.
We should never break out of this loop "naturally" with bus==NULL,
since we'll always find bridge==NULL in that case (and now return 1).
So remove the check for (!bridge) after the loop, since it can never
happen. If it did, it would be worthy of a BUG_ON(!bridge). But since
it'll oops anyway in that case, that'll do just as well.
[ Upstream commit ca88ea1247dfee094e2467a3578eaec9bdf0833a ]
Sometimes xennet_create_queues() may failed to created all requested
queues, we need to update num_queues to real created to avoid NULL
pointer dereference.
Signed-off-by: Joe Jin <joe.jin@oracle.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit 32a844056fd43dda647e1c3c6b9983bdfa04d17d ]
Originally that parameter was always reset to num_online_cpus during
module initialisation, which renders it useless.
The fix is to only set max_queues to num_online_cpus when user has not
provided a value.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
[ Upstream commit 4c82ac3c37363e8c4ded6a5fe1ec5fa756b34df3 ]
provided a value.
Reported-by: Johnny Strom <johnny.strom@linuxsolutions.fi>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
[ Upstream commit 60a6531bfe49555581ccd65f66a350cc5693fcde ]
We can't be within an RCU read-side critical section when deleting
VLANs, as underlying drivers might sleep during the hardware operation.
Therefore, replace the RCU critical section with a mutex. This is
consistent with team_vlan_rx_add_vid.
Fixes: 3d249d4ca7d0 ("net: introduce ethernet teaming device")
Acked-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
[ Upstream commit 4ab42d78e37a294ac7bc56901d563c642e03c4ae ]
Currently slhc_init() treats out-of-range values of rslots and tslots
as equivalent to 0, except that if tslots is too large it will
dereference a null pointer (CVE-2015-7799).
Add a range-check at the top of the function and make it return an
ERR_PTR() on error instead of NULL. Change the callers accordingly.
Compile-tested only.
Reported-by: 郭永刚 <guoyonggang@360.cn>
References: http://article.gmane.org/gmane.comp.security.oss.general/17908
[ Upstream commit 0baa57d8dc32db78369d8b5176ef56c5e2e18ab3 ]
[ Upstream commit 03d84a5f83a67e692af00a3d3901e7820e3e84d5 ]
Commit 1f718f0f4f97 ("bonding: populate neighbour's private on enslave")
undoes the fix provided by commit c2edacf80e15 ("bonding / ipv6: no addrconf
for slaves separately from master") by effectively setting the slave flag
after the slave has been opened. If the slave comes up quickly enough, it
will go through the IPv6 addrconf before the slave flag has been set and
will get a link local IPv6 address.
In order to ensure that addrconf knows to ignore the slave devices on state
change, set IFF_SLAVE before dev_open() during bonding enslavement.
Fixes: 1f718f0f4f97 ("bonding: populate neighbour's private on enslave")
Signed-off-by: Karl Heiss <kheiss@gmail.com>
Signed-off-by: Jay Vosburgh <jay.vosburgh@canonical.com>
Reviewed-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Andy Gospodarek <gospo@cumulusnetworks.com>
[ Upstream commit 07b9b37c227cb8d88d478b4a9c5634fee514ede1 ]
When a vxlan interface is created, the driver checks that there is not
another vxlan interface with the same properties. To do this, it checks
the existing vxlan udp socket. Since commit 1c51a9159dde, the creation of
the vxlan socket is done only when the interface is set up, thus it breaks
that test.
Example:
$ ip l a vxlan10 type vxlan id 10 group 239.0.0.10 dev eth0 dstport 0
$ ip l a vxlan11 type vxlan id 10 group 239.0.0.10 dev eth0 dstport 0
$ ip -br l | grep vxlan
vxlan10 DOWN f2:55:1c:6a:fb:00 <BROADCAST,MULTICAST>
vxlan11 DOWN 7a:cb:b9:38:59:0d <BROADCAST,MULTICAST>
Instead of checking sockets, let's loop over the vxlan iface list.
Fixes: 1c51a9159dde ("vxlan: fix race caused by dropping rtnl_unlock")
Reported-by: Thomas Faivre <thomas.faivre@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit 55285bf09427c5abf43ee1d54e892f352092b1f1 ]
Dmitry reports memleak with syskaller program.
Problem is that connector bumps skb usecount but might not invoke callback.
So move skb_get to where we invoke the callback.
[ Upstream commit 1dfddff5fcd869fcab0c52fafae099dfa435a935 ]
NCM buffer sizes are negotiated with the device independently of
the network device MTU. The RX buffers are allocated by the
usbnet framework based on the rx_urb_size value set by cdc_ncm. A
single RX buffer can hold a number of MTU sized packets.
The default usbnet change_mtu ndo only modifies rx_urb_size if it
is equal to hard_mtu. And the cdc_ncm driver will set rx_urb_size
and hard_mtu independently of each other, based on dwNtbInMaxSize
and dwNtbOutMaxSize respectively. It was therefore assumed that
usbnet_change_mtu() would never touch rx_urb_size. This failed to
consider the case where dwNtbInMaxSize and dwNtbOutMaxSize happens
to be equal.
Fix by implementing an NCM specific change_mtu ndo, modifying the
netdev MTU without touching the buffer size settings.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
as good.
[ Upstream commit ce8c839b74e3017996fad4e1b7ba2e2625ede82f ]
Packets that arrive from real hardware devices have ip_summed ==
CHECKSUM_UNNECESSARY if the hardware verified the checksums, or
CHECKSUM_NONE if the packet is bad or it was unable to verify it. The
current version of veth will replace CHECKSUM_NONE with
CHECKSUM_UNNECESSARY, which causes corrupt packets routed from hardware to
a veth device to be delivered to the application. This caused applications
at Twitter to receive corrupt data when network hardware was corrupting
packets.
We believe this was added as an optimization to skip computing and
verifying checksums for communication between containers. However, locally
generated packets have ip_summed == CHECKSUM_PARTIAL, so the code as
written does nothing for them. As far as we can tell, after removing this
code, these packets are transmitted from one stack to another unmodified
(tcpdump shows invalid checksums on both sides, as expected), and they are
delivered correctly to applications. We didn’t test every possible network
configuration, but we tried a few common ones such as bridging containers,
using NAT between the host and a container, and routing from hardware
devices to containers. We have effectively deployed this in production at
Twitter (by disabling RX checksum offloading on veth devices).
This code dates back to the first version of the driver, commit
<e314dbdc1c0dc6a548ecf> ("[NET]: Virtual ethernet device driver"), so I
suspect this bug occurred mostly because the driver API has evolved
significantly since then. Commit <0b7967503dc97864f283a> ("net/veth: Fix
packet checksumming") (in December 2010) fixed this for packets that get
created locally and sent to hardware devices, by not changing
CHECKSUM_PARTIAL. However, the same issue still occurs for packets coming
in from hardware devices.
Co-authored-by: Evan Jones <ej@evanjones.ca>
Signed-off-by: Evan Jones <ej@evanjones.ca>
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Cc: Phil Sutter <phil@nwl.cc>
Cc: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Cc: netdev@vger.kernel.org
Signed-off-by: Vijay Pandurangan <vijayp@vijayp.ca>
Acked-by: Cong Wang <cwang@twopensource.com>
commit 1eaf35e4dd592c59041bc1ed3248c46326da1f5f upstream.
The module should fail to load.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
commit f7d7f59ab124748156ea551edf789994f05da342 upstream.
Add the USB device ID for ELV Marble Sound Board 1.
Signed-off-by: Oliver Freyermuth <o.freyermuth@googlemail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit abdc9a3b4bac97add99e1d77dc6d28623afe682b upstream.
The code expects the loop to end with "retries" set to zero but, because
it is a post-op, it will end set to -1. I have fixed this by moving the
decrement inside the loop.
Fixes: 014aa2a3c32e ('USB: ipaq: minor ipaq_open() cleanup.')
commit e50293ef9775c5f1cf3fcc093037dd6a8c5684ea upstream.
Commit 8520f38099cc ("USB: change hub initialization sleeps to
delayed_work") changed the hub_activate() routine to make part of it
run in a workqueue. However, the commit failed to take a reference to
the usb_hub structure or to lock the hub interface while doing so. As
a result, if a hub is plugged in and quickly unplugged before the work
routine can run, the routine will try to access memory that has been
deallocated. Or, if the hub is unplugged while the routine is
running, the memory may be deallocated while it is in active use.
This patch fixes the problem by taking a reference to the usb_hub at
the start of hub_activate() and releasing it at the end (when the work
is finished), and by locking the hub interface while the work routine
is running. It also adds a check at the start of the routine to see
if the hub has already been disconnected, in which nothing should be
done.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Alexandru Cornea <alexandru.cornea@intel.com>
Tested-by: Alexandru Cornea <alexandru.cornea@intel.com>
Fixes: 8520f38099cc ("USB: change hub initialization sleeps to delayed_work")
CC: <stable@vger.kernel.org>
commit aa0850e1d56623845b46350ffd971afa9241886d upstream.
Driver requested device firmware version string during probe using
only 24 byte long buffer. That buffer is too small for newer firmware
versions, which causes device firmware hang - device stops responding
to any commands after that. Increase buffer size to 128 which should
be enough for any current and future version strings.
Link: https://github.com/airspy/host/issues/27
Reported-by: Benjamin Vernoux <bvernoux@gmail.com>
Signed-off-by: Antti Palosaari <crope@iki.fi>
commit 096b110a3dd3c868e4610937c80d2e3f3357c1a9 upstream.
if a full speed hub connects to a high speed hub which
supports MTT, the MTT field of its slot context will be set
to 1 when xHCI driver setups an xHCI virtual device in
xhci_setup_addressable_virt_dev(); once usb core fetch its
hub descriptor, and need to update the xHC's internal data
structures for the device, the HUB field of its slot context
will be set to 1 too, meanwhile MTT is also set before,
this will cause configure endpoint command fail, so in the
case, we should clear MTT to 0 for full speed hub according
to section 6.2.2
Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 27f972d3e00b50639deb4cc1392afaeb08d3cecc upstream.
We encountered a panic on boot in ipmi_si on a dell per320 due to an
uninitialized timer as follows.
static int smi_start_processing(void *send_info,
ipmi_smi_t intf)
/* Try to claim any interrupts. */
if (new_smi->irq_setup)
new_smi->irq_setup(new_smi);
--> IRQ arrives here and irq handler tries to modify uninitialized timer
which triggers BUG_ON(!timer->function) in __mod_timer().
Call Trace:
<IRQ>
[<ffffffffa0532617>] start_new_msg+0x47/0x80 [ipmi_si]
[<ffffffffa053269e>] start_check_enables+0x4e/0x60 [ipmi_si]
[<ffffffffa0532bd8>] smi_event_handler+0x1e8/0x640 [ipmi_si]
[<ffffffff810f5584>] ? __rcu_process_callbacks+0x54/0x350
[<ffffffffa053327c>] si_irq_handler+0x3c/0x60 [ipmi_si]
[<ffffffff810efaf0>] handle_IRQ_event+0x60/0x170
[<ffffffff810f245e>] handle_edge_irq+0xde/0x180
[<ffffffff8100fc59>] handle_irq+0x49/0xa0
[<ffffffff8154643c>] do_IRQ+0x6c/0xf0
[<ffffffff8100ba53>] ret_from_intr+0x0/0x11
/* Set up the timer that drives the interface. */
setup_timer(&new_smi->si_timer, smi_timeout, (long)new_smi);
The following patch fixes the problem.
To: Openipmi-developer@lists.sourceforge.net
To: Corey Minyard <minyard@acm.org>
CC: linux-kernel@vger.kernel.org
Signed-off-by: Jan Stancek <jstancek@redhat.com>
Signed-off-by: Tony Camuso <tcamuso@redhat.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
commit 0cfec916e86d881e209de4b4ae9959a6271e6660 upstream.
The timer and thread were not being started for internal messages,
so in interrupt mode if something hung the timer would never go
off and clean things up. Factor out the internal message sending
and start the timer for those messages, too.
Tested-by: Gouji, Masayuki <gouji.masayuki@jp.fujitsu.com>
commit 9c17d96500f78d7ecdb71ca6942830158bc75a2b upstream.
Doing so will cause the grant to be unmapped and then, during
fault handling, the fault to be mistakenly treated as NUMA hint
fault.
In addition, even if those maps could partcipate in NUMA
balancing, it wouldn't provide any benefit since we are unable
to determine physical page's node (even if/when VNUMA is
implemented).
Marking grant maps' VMAs as VM_IO will exclude them from being
part of NUMA balancing.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
[ Upstream commit 09ccfd238e5a0e670d8178cf50180ea81ae09ae1 ]
Reported-by: Dmitry Vyukov <dvyukov@gmail.com>
[ Upstream commit 248be83dcb3feb3f6332eb3d010a016402138484 ]
In a low memory situation the following kernel oops occurs:
Unable to handle kernel NULL pointer dereference at virtual address 00000050
pgd = 8490c000
[00000050] *pgd=4651e831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT ARM
Modules linked in:
CPU: 0 Not tainted (3.4-at16 #9)
PC is at skb_put+0x10/0x98
LR is at sh_eth_poll+0x2c8/0xa10
pc : [<8035f780>] lr : [<8028bf50>] psr: 60000113
sp : 84eb1a90 ip : 84eb1ac8 fp : 84eb1ac4
r10: 0000003f r9 : 000005ea r8 : 00000000
r7 : 00000000 r6 : 940453b0 r5 : 00030000 r4 : 9381b180
r3 : 00000000 r2 : 00000000 r1 : 000005ea r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 4248c059 DAC: 00000015
Process klogd (pid: 2046, stack limit = 0x84eb02e8)
This is because netdev_alloc_skb() fails and 'mdp->rx_skbuff[entry]' is left
NULL but sh_eth_rx() later uses it without checking. Add such check...
Reported-by: Yasushi SHOJI <yashi@atmark-techno.com>
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 90186af404ada5a47b875bf3c16d0b02bb023ea0 ]
When an interface is brought up which was previously suspended (via
runtime PM), it would hang. This happens because napi_disable is called
before napi_enable.
Solve this by avoiding napi_enable in the resume during open function
(netif_running is true when open is called, IFF_UP is set after a
successful open; netif_running is false when close is called, but IFF_UP
is then still set).
While at it, remove WORK_ENABLE check from rtl8152_open (introduced with
the original change) because it cannot happen:
- After this patch, runtime resume will not set it during rtl8152_open.
- When link is up, rtl8152_open is not called.
- When link is down during system/auto suspend/resume, it is not set.
Fixes: 41cec84cf285 ("r8152: don't enable napi before rx ready")
Link: https://lkml.kernel.org/r/20151205105912.GA1766@al
Signed-off-by: Peter Wu <peter@lekensteyn.nl>
Acked-by: Hayes Wang <hayeswang@realtek.com>
[ Upstream commit ed7d42e24effbd3681e909711a7a2119a85e9217 ]
In case of a tx queue timeout every transmit is blocked until the
QCA7000 resets himself and triggers a sync which makes the driver
flushs the tx ring. So avoid this blocking situation by triggering
the sync immediately after the timeout. Waking the queue doesn't
make sense in this situation.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Fixes: 291ab06ecf67 ("net: qualcomm: new Ethernet over SPI driver for QCA7000")
[ Upstream commit f2a3771ae8aca879c32336c76ad05a017629bae2 ]
atl1c driver is doing order-4 allocation with GFP_ATOMIC
priority. That often breaks networking after resume. Switch to
GFP_KERNEL. Still not ideal, but should be significantly better.
atl1c_setup_ring_resources() is called from .open() function, and
already uses GFP_KERNEL, so this change is safe.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit fe53985aaac83d516b38358d4f39921d9942a0e2 ]
pppoe_connect() mustn't touch the padt_work field of pppoe sockets
because that work could be already pending.
[ 21.473147] BUG: unable to handle kernel NULL pointer dereference at 00000004
[ 21.474523] IP: [<c1043177>] process_one_work+0x29/0x31c
[ 21.475164] *pde = 00000000
[ 21.475513] Oops: 0000 [#1] SMP
[ 21.475910] Modules linked in: pppoe pppox ppp_generic slhc crc32c_intel aesni_intel virtio_net xts aes_i586 lrw gf128mul ablk_helper cryptd evdev acpi_cpufreq processor serio_raw button ext4 crc16 mbcache jbd2 virtio_blk virtio_pci virtio_ring virtio
[ 21.476168] CPU: 2 PID: 164 Comm: kworker/2:2 Not tainted 4.4.0-rc1 #1
[ 21.476168] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014
[ 21.476168] task: f5f83c00 ti: f5e28000 task.ti: f5e28000
[ 21.476168] EIP: 0060:[<c1043177>] EFLAGS: 00010046 CPU: 2
[ 21.476168] EIP is at process_one_work+0x29/0x31c
[ 21.484082] EAX: 00000000 EBX: f678b2a0 ECX: 00000004 EDX: 00000000
[ 21.484082] ESI: f6c69940 EDI: f5e29ef0 EBP: f5e29f0c ESP: f5e29edc
[ 21.484082] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[ 21.484082] CR0: 80050033 CR2: 000000a4 CR3: 317ad000 CR4: 00040690
[ 21.484082] Stack:
[ 21.484082] 00000000 f6c69950 00000000 f6c69940 c0042338 f5e29f0c c1327945 00000000
[ 21.484082] 00000008 f678b2a0 f6c69940 f678b2b8 f5e29f30 c1043984 f5f83c00 f6c69970
[ 21.484082] f678b2a0 c10437d3 f6775e80 f678b2a0 c10437d3 f5e29fac c1047059 f5e29f74
[ 21.484082] Call Trace:
[ 21.484082] [<c1327945>] ? _raw_spin_lock_irq+0x28/0x30
[ 21.484082] [<c1043984>] worker_thread+0x1b1/0x244
[ 21.484082] [<c10437d3>] ? rescuer_thread+0x229/0x229
[ 21.484082] [<c1047059>] kthread+0x8f/0x94
[ 21.484082] [<c1327a32>] ? _raw_spin_unlock_irq+0x22/0x26
[ 21.484082] [<c1327ee9>] ret_from_kernel_thread+0x21/0x38
[ 21.484082] [<c1046fca>] ? kthread_parkme+0x19/0x19
[ 21.496082] Code: 5d c3 55 89 e5 57 56 53 89 c3 83 ec 24 89 d0 89 55 e0 8d 7d e4 e8 6c d8 ff ff b9 04 00 00 00 89 45 d8 8b 43 24 89 45 dc 8b 45 d8 <8b> 40 04 8b 80 e0 00 00 00 c1 e8 05 24 01 88 45 d7 8b 45 e0 8d
[ 21.496082] EIP: [<c1043177>] process_one_work+0x29/0x31c SS:ESP 0068:f5e29edc
[ 21.496082] CR2: 0000000000000004
[ 21.496082] ---[ end trace e362cc9cf10dae89 ]---
Reported-by: Andrew <nitr0@seti.kr.ua>
Fixes: 287f3a943fef ("pppoe: Use workqueue to die properly when a PADT is received")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
commit 5377adb092664d336ac212499961cac5e8728794 upstream.
usb_parse_ss_endpoint_companion() now decodes the burst multiplier
correctly in order to check that it's <= 3, but still uses the wrong
expression if warning that it's > 3.
Fixes: ff30cbc8da42 ("usb: Use the USB_SS_MULT() macro to get the ...")
commit 464ad8c43a9ead98c2b0eaed86bea727f2ad106e upstream.
When a USB 3.0 mass storage device is disconnected in transporting
state, storage device driver may handle it as a transport error and
reset the device by invoking usb_reset_and_verify_device()
and following could happen:
in usb_reset_and_verify_device():
udev->bos = NULL;
For U1/U2 enabled devices, driver will disable LPM, and in some
conditions:
from usb_unlocked_disable_lpm()
--> usb_disable_lpm()
--> usb_enable_lpm()
udev->bos->ss_cap->bU1devExitLat;
And it causes 'NULL pointer' and 'kernel panic':
[ 157.976257] Unable to handle kernel NULL pointer dereference
at virtual address 00000010
[ 158.026400] PC is at usb_enable_link_state+0x34/0x2e0
[ 158.031442] LR is at usb_enable_lpm+0x98/0xac
[ 158.137368] [<ffffffc0006a1cac>] usb_enable_link_state+0x34/0x2e0
[ 158.143451] [<ffffffc0006a1fec>] usb_enable_lpm+0x94/0xac
[ 158.148840] [<ffffffc0006a20e8>] usb_disable_lpm+0xa8/0xb4
[ 158.214954] Kernel panic - not syncing: Fatal exception
This commit moves 'udev->bos = NULL' behind usb_unlocked_disable_lpm()
to prevent from NULL pointer access.
Issue can be reproduced by following setup:
1) A SS pen drive behind a SS hub connected to the host.
2) Transporting data between the pen drive and the host.
3) Abruptly disconnect hub and pen drive from host.
4) With a chance it crashes.
Signed-off-by: Hans Yang <hansy@nvidia.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 183e53e8ddf4165c3763181682189362d6b403f7 upstream.
The CPPI-4.1 driver selects TI_CPPI41, which is a dmaengine
driver and that may not be available when CONFIG_DMADEVICES
is not set:
warning: (USB_TI_CPPI41_DMA) selects TI_CPPI41 which has unmet direct dependencies (DMADEVICES && ARCH_OMAP)
This adds an extra dependency to avoid generating warnings in randconfig
builds. Ideally we'd remove the 'select' statement, but that has the
potential to break defconfig files.
Fixes: 411dd19c682d ("usb: musb: Kconfig: Select the DMA driver if DMA mode of MUSB is enabled")
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 391e6dcb37857d5659b53def2f41e2f56850d33c upstream.
pxa27x disconnects pullups on suspend but doesn't
notify the gadget driver about it, so gadget driver
can't disable the endpoints it was using.
This causes problems on resume because gadget core
will think endpoints are still enabled and just
ignore the following usb_ep_enable().
Fix this problem by calling
gadget_driver->disconnect().
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit f9fa1887dcf26bd346665a6ae3d3f53dec54cba1 upstream.
qset_fill_page_list() do not check for dma mapping errors.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
commit ad87e03213b552a5c33d5e1e7a19a73768397010 upstream.
Some USB device / host controller combinations seem to have problems
with Link Power Management. For example, Steinar found that his xHCI
controller wouldn't handle bandwidth calculations correctly for two
video cards simultaneously when LPM was enabled, even though the bus
had plenty of bandwidth available.
This patch introduces a new quirk flag for devices that should remain
disabled for LPM, and creates quirk entries for Steinar's devices.
Reported-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
commit 7c90e610b60cd1ed6abafd806acfaedccbbe52d1 upstream.
CP2110 ID (0x10c4, 0xea80) doesn't belong here because it's a HID
and completely different from CP210x devices.
Signed-off-by: Konstantin Shkolnyy <konstantin.shkolnyy@gmail.com>
commit 9fa62b1a31c96715aef34f25000e882ed4ac4876 upstream.
The patch extends the family of SATA-to-USB JMicron adapters that need
FUA to be disabled and applies the same policy for uas driver.
See details in http://unix.stackexchange.com/questions/237204/
Signed-off-by: Dmitry Katsubo <dmitry.katsubo@gmail.com>
Tested-by: Dmitry Katsubo <dmitry.katsubo@gmail.com>
commit a0e80fbd56b4573de997c9a088a33abbc1121400 upstream.
The flash loader has been seen on a Telit UE910 modem. The flash loader
is a bit special, it presents both an ACM and CDC Data interface but
only the latter is useful. Unless a magic string is sent to the device
it will disappear and the regular modem device appears instead.
Signed-off-by: Jonas Jonsson <jonas@ludd.ltu.se>
Tested-by: Daniele Palmas <dnlplm@gmail.com>
commit f33a7f72e5fc033daccbb8d4753d7c5c41a4d67b upstream.
Some modems, such as the Telit UE910, are using an Infineon Flash Loader
utility. It has two interfaces, 2/2/0 (Abstract Modem) and 10/0/0 (CDC
Data). The latter can be used as a serial interface to upgrade the
firmware of the modem. However, that isn't possible when the cdc-acm
driver takes control of the device.
The following is an explanation of the behaviour by Daniele Palmas during
discussion on linux-usb.
"This is what happens when the device is turned on (without modifying
the drivers):
[155492.352031] usb 1-3: new high-speed USB device number 27 using ehci-pci
[155492.485429] usb 1-3: config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 255, changing to 11
[155492.485436] usb 1-3: New USB device found, idVendor=058b, idProduct=0041
[155492.485439] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[155492.485952] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
This is the flashing device that is caught by the cdc-acm driver. Once
the ttyACM appears, the application starts sending a magic string
(simple write on the file descriptor) to keep the device in flashing
mode. If this magic string is not properly received in a certain time
interval, the modem goes on in normal operative mode:
[155493.748094] usb 1-3: USB disconnect, device number 27
[155494.916025] usb 1-3: new high-speed USB device number 28 using ehci-pci
[155495.059978] usb 1-3: New USB device found, idVendor=1bc7, idProduct=0021
[155495.059983] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[155495.059986] usb 1-3: Product: 6 CDC-ACM + 1 CDC-ECM
[155495.059989] usb 1-3: Manufacturer: Telit
[155495.059992] usb 1-3: SerialNumber: 359658044004697
[155495.138958] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
[155495.140832] cdc_acm 1-3:1.2: ttyACM1: USB ACM device
[155495.142827] cdc_acm 1-3:1.4: ttyACM2: USB ACM device
[155495.144462] cdc_acm 1-3:1.6: ttyACM3: USB ACM device
[155495.145967] cdc_acm 1-3:1.8: ttyACM4: USB ACM device
[155495.147588] cdc_acm 1-3:1.10: ttyACM5: USB ACM device
[155495.154322] cdc_ether 1-3:1.12 wwan0: register 'cdc_ether' at usb-0000:00:1a.7-3, Mobile Broadband Network Device, 00:00:11:12:13:14
Using the cdc-acm driver, the string, though being sent in the same way
than using the usb-serial-simple driver (I can confirm that the data is
passing properly since I used an hw usb sniffer), does not make the
device to stay in flashing mode."
commit d2f20619942fe4618160a7fa3dbdcbac335cff59 upstream.
Commit 53147b6cabee5e8d1997b5682fcc0c3b72ddf9c2 ("toshiba_acpi: Fix
hotkeys registration on some toshiba models") fixed an issue on some
laptops regarding hotkeys registration, however, if failed to address
the initialization of the hotkey_event_type variable, and thus, it can
lead to potential unwanted effects as the variable is being checked.
This patch initializes such variable to avoid such unwanted effects.
Signed-off-by: Azael Avalos <coproscefalo@gmail.com>
commit 399235dc6e95400a1322a9999e92073bc572f0c8 upstream.
Both for FIFO and CRB interface TCG has decided to use the same HID
MSFT0101. They can be differentiated by looking at the start method from
TPM2 ACPI table. This patches makes necessary fixes to tpm_tis and
tpm_crb modules in order to correctly detect, which module should be
used.
For MSFT0101 we must use struct acpi_driver because struct pnp_driver
has a 7 character limitation.
It turned out that the root cause in b371616b8 was not correct for
https://bugzilla.kernel.org/show_bug.cgi?id=98181.
v2:
* One fixup was missing from v1: is_tpm2_fifo -> is_fifo
v3:
* Use pnp_driver for existing HIDs and acpi_driver only for MSFT0101 in
order ensure backwards compatibility.
v4:
* Check for FIFO before doing *anything* in crb_acpi_add().
* There was return immediately after acpi_bus_unregister_driver() in
cleanup_tis(). This caused pnp_unregister_driver() not to be called.
Reported-by: Michael Saunders <mick.saunders@gmail.com>
Reported-by: Michael Marley <michael@michaelmarley.com>
Reported-by: Jethro Beekman <kernel@jbeekman.nl>
Reported-by: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Tested-by: Michael Marley <michael@michaelmarley.com>
Tested-by: Mimi Zohar <zohar@linux.vnet.ibm.com> (on TPM 1.2)
Reviewed-by: Peter Huewe <peterhuewe@gmx.de>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
commit 100ceb66d5c40cc0c7018e06a9474302470be73c upstream.
Reported by Clifford and Craig for JMicron OHCI-1394 + SDHCI combo
controllers: Often or even most of the time, the controller is
initialized with the message "added OHCI v1.10 device as card 0, 4 IR +
0 IT contexts, quirks 0x10". With 0 isochronous transmit DMA contexts
(IT contexts), applications like audio output are impossible.
However, OHCI-1394 demands that at least 4 IT contexts are implemented
by the link layer controller, and indeed JMicron JMB38x do implement
four of them. Only their IsoXmitIntMask register is unreliable at early
access.
With my own JMB381 single function controller I found:
- I can reproduce the problem with a lower probability than Craig's.
- If I put a loop around the section which clears and reads
IsoXmitIntMask, then either the first or the second attempt will
return the correct initial mask of 0x0000000f. I never encountered
a case of needing more than a second attempt.
- Consequently, if I put a dummy reg_read(...IsoXmitIntMaskSet)
before the first write, the subsequent read will return the correct
result.
- If I merely ignore a wrong read result and force the known real
result, later isochronous transmit DMA usage works just fine.
So let's just fix this chip bug up by the latter method. Tested with
JMB381 on kernel 3.13 and 4.3.
Since OHCI-1394 generally requires 4 IT contexts at a minium, this
workaround is simply applied whenever the initial read of IsoXmitIntMask
returns 0, regardless whether it's a JMicron chip or not. I never heard
of this issue together with any other chip though.
I am not 100% sure that this fix works on the OHCI-1394 part of JMB380
and JMB388 combo controllers exactly the same as on the JMB381 single-
function controller, but so far I haven't had a chance to let an owner
of a combo chip run a patched kernel.
Strangely enough, IsoRecvIntMask is always reported correctly, even
though it is probed right before IsoXmitIntMask.
Reported-by: Clifford Dunn
Reported-by: Craig Moore <craig.moore@qenos.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit 70b16db86f564977df074072143284aec2cb1162 upstream.
Commit 4e752f0ab0e8 ("rbd: access snapshot context and mapping size
safely") moved ceph_get_snap_context() out of rbd_img_request_create()
and into rbd_queue_workfn(), adding a ceph_put_snap_context() to the
error path in rbd_queue_workfn(). However, rbd_img_request_create()
consumes a ref on snapc, so calling ceph_put_snap_context() after
a successful rbd_img_request_create() leads to an extra put. Fix it.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Josh Durgin <jdurgin@redhat.com>
[ Upstream commit 3c25a860d17b7378822f35d8c9141db9507e3beb ]
Commit fcb26ec5b18d ("broadcom: move all PHY_ID's to header")
updated broadcom_tbl to use PHY_IDs, but incorrectly replaced 0x0143bca0
with PHY_ID_BCM5482 (making a duplicate entry, and completely omitting
the original). Fix that.
Fixes: fcb26ec5b18d ("broadcom: move all PHY_ID's to header")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit 68242a5a1e2edce39b069385cbafb82304eac0f1 ]
Thomas reports
4gsystems sells two total different LTE-surfsticks under the same name.
The newer version of XS Stick W100 is from "omega"
Under windows the driver switches to the same ID, and uses MI03\6 for
network and MI01\6 for modem.
echo "1c9e 9b01" > /sys/bus/usb/drivers/qmi_wwan/new_id
echo "1c9e 9b01" > /sys/bus/usb-serial/drivers/option1/new_id
T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1c9e ProdID=9b01 Rev=02.32
S: Manufacturer=USB Modem
S: Product=USB Modem
S: SerialNumber=
C: #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
I: If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Now all important things are there:
wwp0s29f7u2i3 (net), ttyUSB2 (at), cdc-wdm0 (qmi), ttyUSB1 (at)
There is also ttyUSB0, but it is not usable, at least not for at.
The device works well with qmi and ModemManager-NetworkManager.
Reported-by: Thomas Schäfer <tschaefer@t-online.de>
commit 9f088dba3cc267ea11ec0da318cd0175575b5f9b upstream.
The recently introduced lnet_peer_set_alive() function uses
get_seconds() to read the current time into a shared variable,
but all other uses of that variable compare it to jiffies values.
This changes the current use to jiffies as well for consistency.
Fixes: af3fa7c71bf ("staging/lustre/lnet: peer aliveness status and NI status")
Cc: Liang Zhen <liang.zhen@intel.com>
Cc: James Simmons <uja.ornl@gmail.com>
Cc: Isaac Huang <he.huang@intel.com>
Signed-off-by: Oleg Drokin <oleg.drokin@intel.com>
commit a5964396190d0c40dd549c23848c282fffa5d1f2 upstream.
Existing Intel xHCI controllers require a delay of 1 mS,
after setting the CMD_RESET bit in command register, before
accessing any HC registers. This allows the HC to complete
the reset operation and be ready for HC register access.
Without this delay, the subsequent HC register access,
may result in a system hang, very rarely.
Verified CherryView / Braswell platforms go through over
5000 warm reboot cycles (which was not possible without
this patch), without any xHCI reset hang.
Signed-off-by: Rajmohan Mani <rajmohan.mani@intel.com>
Tested-by: Joe Lawrence <joe.lawrence@stratus.com>
commit ee0c1a65cf95230d5eb3d9de94fd2ead9a428c67 upstream.
The correct lock order is atomic_write_lock => termios_rwsem, as
established by tty_write() => n_tty_write().
Fixes: c274f6ef1c666 ("tty: Hold termios_rwsem for tcflow(TCIxxx)")
Reported-and-Tested-by: Dmitry Vyukov <dvyukov@google.com>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
