path: root/drivers
2019-12-19Merge remote-tracking branch 'fslc/4.14-2.0.x-imx' into ↵Marcel Ziswiler
toradex_4.14-2.0.x-imx-next
2019-12-19crypto: mxs-dcp: remove merge conflict markersMarcel Ziswiler
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-12-19Merge branch 'github.com/Freescale/linux-fslc/4.14-2.0.x-imx' into ↵Marcel Ziswiler
toradex_4.14-2.0.x-imx-next Conflicts: sound/soc/codecs/sgtl5000.c
2019-12-18Merge tag 'v4.14.159' into 4.14-2.0.x-imxMarcel Ziswiler
This is the 4.14.159 stable release Conflicts: arch/arm/Kconfig.debug arch/arm/boot/dts/imx7s.dtsi arch/arm/mach-imx/cpuidle-imx6sx.c drivers/crypto/caam/caamalg.c drivers/crypto/mxs-dcp.c drivers/dma/imx-sdma.c drivers/input/keyboard/imx_keypad.c drivers/net/can/flexcan.c drivers/net/can/rx-offload.c drivers/net/wireless/ath/ath10k/pci.c drivers/pci/dwc/pci-imx6.c drivers/spi/spi-fsl-lpspi.c drivers/usb/dwc3/gadget.c
2019-12-17of: unittest: fix memory leak in attach_node_and_childrenErhard Furtner
[ Upstream commit 2aacace6dbbb6b6ce4e177e6c7ea901f389c0472 ] In attach_node_and_children memory is allocated for full_name via kasprintf. If the condition of the 1st if is not met the function returns early without freeing the memory. Add a kfree() to fix that. This has been detected with kmemleak: Link: https://bugzilla.kernel.org/show_bug.cgi?id=205327 It looks like the leak was introduced by this commit: Fixes: 5babefb7f7ab ("of: unittest: allow base devicetree to have symbol metadata") Signed-off-by: Erhard Furtner <erhard_f@mailbox.org> Reviewed-by: Michael Ellerman <mpe@ellerman.id.au> Reviewed-by: Tyrel Datwyler <tyreld@linux.ibm.com> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17raid5: need to set STRIPE_HANDLE for batch headGuoqing Jiang
[ Upstream commit a7ede3d16808b8f3915c8572d783530a82b2f027 ] With commit 6ce220dd2f8ea71d6afc29b9a7524c12e39f374a ("raid5: don't set STRIPE_HANDLE to stripe which is in batch list"), we don't want to set STRIPE_HANDLE flag for sh which is already in batch list. However, the stripe which is the head of batch list should set this flag, otherwise panic could happen inside init_stripe at BUG_ON(sh->batch_head), it is reproducible with raid5 on top of nvdimm devices per Xiao oberserved. Thanks for Xiao's effort to verify the change. Fixes: 6ce220dd2f8ea ("raid5: don't set STRIPE_HANDLE to stripe which is in batch list") Reported-by: Xiao Ni <xni@redhat.com> Tested-by: Xiao Ni <xni@redhat.com> Signed-off-by: Guoqing Jiang <guoqing.jiang@cloud.ionos.com> Signed-off-by: Song Liu <songliubraving@fb.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17gpiolib: acpi: Add Terra Pad 1061 to the run_edge_events_on_boot_blacklistHans de Goede
[ Upstream commit 2727315df3f5ffbebcb174eed3153944a858b66f ] The Terra Pad 1061 has the usual micro-USB-B id-pin handler, but instead of controlling the actual micro-USB-B it turns the 5V boost for the tablet's USB-A connector and its keyboard-cover connector off. The actual micro-USB-B connector on the tablet is wired for charging only, and its id pin is *not* connected to the GPIO which is used for the (broken) id-pin event handler in the DSDT. While at it not only add a comment why the Terra Pad 1061 is on the blacklist, but also fix the missing comment for the Minix Neo Z83-4 entry. Fixes: 61f7f7c8f978 ("gpiolib: acpi: Add gpiolib_acpi_run_edge_events_on_boot option and blacklist") Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17net/mlx5e: Fix SFF 8472 eeprom lengthEran Ben Elisha
[ Upstream commit c431f8597863a91eea6024926e0c1b179cfa4852 ] SFF 8472 eeprom length is 512 bytes. Fix module info return value to support 512 bytes read. Fixes: ace329f4ab3b ("net/mlx5e: ethtool, Remove unsupported SFP EEPROM high pages query") Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com> Reviewed-by: Aya Levin <ayal@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17firmware: qcom: scm: Ensure 'a0' status code is treated as signedWill Deacon
commit ff34f3cce278a0982a7b66b1afaed6295141b1fc upstream. The 'a0' member of 'struct arm_smccc_res' is declared as 'unsigned long', however the Qualcomm SCM firmware interface driver expects to receive negative error codes via this field, so ensure that it's cast to 'long' before comparing to see if it is less than 0. Cc: <stable@vger.kernel.org> Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org> Signed-off-by: Will Deacon <will@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17ath10k: fix fw crash by moving chip reset after napi disabledMiaoqing Pan
[ Upstream commit 08d80e4cd27ba19f9bee9e5f788f9a9fc440a22f ] On SMP platform, when continuously running wifi up/down, the napi poll can be scheduled during chip reset, which will call ath10k_pci_has_fw_crashed() to check the fw status. But in the reset period, the value from FW_INDICATOR_ADDRESS register will return 0xdeadbeef, which also be treated as fw crash. Fix the issue by moving chip reset after napi disabled. ath10k_pci 0000:01:00.0: firmware crashed! (guid 73b30611-5b1e-4bdd-90b4-64c81eb947b6) ath10k_pci 0000:01:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe ath10k_pci 0000:01:00.0: htt-ver 2.2 wmi-op 6 htt-op 4 cal otp max-sta 512 raw 0 hwcrypto 1 ath10k_pci 0000:01:00.0: failed to get memcpy hi address for firmware address 4: -16 ath10k_pci 0000:01:00.0: failed to read firmware dump area: -16 ath10k_pci 0000:01:00.0: Copy Engine register dump: ath10k_pci 0000:01:00.0: [00]: 0x0004a000 0 0 0 0 ath10k_pci 0000:01:00.0: [01]: 0x0004a400 0 0 0 0 ath10k_pci 0000:01:00.0: [02]: 0x0004a800 0 0 0 0 ath10k_pci 0000:01:00.0: [03]: 0x0004ac00 0 0 0 0 ath10k_pci 0000:01:00.0: [04]: 0x0004b000 0 0 0 0 ath10k_pci 0000:01:00.0: [05]: 0x0004b400 0 0 0 0 ath10k_pci 0000:01:00.0: [06]: 0x0004b800 0 0 0 0 ath10k_pci 0000:01:00.0: [07]: 0x0004bc00 1 0 1 0 ath10k_pci 0000:01:00.0: [08]: 0x0004c000 0 0 0 0 ath10k_pci 0000:01:00.0: [09]: 0x0004c400 0 0 0 0 ath10k_pci 0000:01:00.0: [10]: 0x0004c800 0 0 0 0 ath10k_pci 0000:01:00.0: [11]: 0x0004cc00 0 0 0 0 Tested HW: QCA9984,QCA9887,WCN3990 Signed-off-by: Miaoqing Pan <miaoqing@codeaurora.org> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17media: vimc: fix component match compareHelen Koike
[ Upstream commit ee1c71a8e1456ab53fe667281d855849edf26a4d ] If the system has other devices being registered in the component framework, the compare function will be called with a device that doesn't belong to vimc. This device is not necessarily a platform_device, nor have a platform_data (which causes a NULL pointer dereference error) and if it does have a pdata, it is not necessarily type of struct vimc_platform_data. So casting to any of these types is wrong. Instead of expecting a given pdev with a given pdata, just expect for the device it self. vimc-core is the one who creates them, we know in advance exactly which object to expect in the match. Fixes: 4a29b7090749 ("[media] vimc: Subdevices as modules") Signed-off-by: Helen Koike <helen.koike@collabora.com> Reviewed-by: Boris Brezillon <boris.brezillon@collabora.com> Tested-by: Boris Brezillon <boris.brezillon@collabora.com> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17mlxsw: spectrum_router: Refresh nexthop neighbour when it becomes deadIdo Schimmel
[ Upstream commit 83d5782681cc12b3d485a83cb34c46b2445f510c ] The driver tries to periodically refresh neighbours that are used to reach nexthops. This is done by periodically calling neigh_event_send(). However, if the neighbour becomes dead, there is nothing we can do to return it to a connected state and the above function call is basically a NOP. This results in the nexthop never being written to the device's adjacency table and therefore never used to forward packets. Fix this by dropping our reference from the dead neighbour and associating the nexthop with a new neigbhour which we will try to refresh. Fixes: a7ff87acd995 ("mlxsw: spectrum_router: Implement next-hop routing") Signed-off-by: Ido Schimmel <idosch@mellanox.com> Reported-by: Alex Veber <alexve@mellanox.com> Tested-by: Alex Veber <alexve@mellanox.com> Acked-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17power: supply: cpcap-battery: Fix signed counter sample registerTony Lindgren
[ Upstream commit c68b901ac4fa969db8917b6a9f9b40524a690d20 ] The accumulator sample register is signed 32-bits wide register on droid 4. And only the earlier version of cpcap has a signed 24-bits wide register. We're currently passing it around as unsigned, so let's fix that and use sign_extend32() for the earlier revision. Signed-off-by: Tony Lindgren <tony@atomide.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17e100: Fix passing zero to 'PTR_ERR' warning in e100_load_ucode_waitYueHaibing
[ Upstream commit cd0d465bb697a9c7bf66a9fe940f7981232f1676 ] Fix a static code checker warning: drivers/net/ethernet/intel/e100.c:1349 e100_load_ucode_wait() warn: passing zero to 'PTR_ERR' Signed-off-by: YueHaibing <yuehaibing@huawei.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17drbd: Change drbd_request_detach_interruptible's return type to intNathan Chancellor
[ Upstream commit 5816a0932b4fd74257b8cc5785bc8067186a8723 ] Clang warns when an implicit conversion is done between enumerated types: drivers/block/drbd/drbd_state.c:708:8: warning: implicit conversion from enumeration type 'enum drbd_ret_code' to different enumeration type 'enum drbd_state_rv' [-Wenum-conversion] rv = ERR_INTR; ~ ^~~~~~~~ drbd_request_detach_interruptible's only call site is in the return statement of adm_detach, which returns an int. Change the return type of drbd_request_detach_interruptible to match, silencing Clang's warning. Reported-by: Nick Desaulniers <ndesaulniers@google.com> Reviewed-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: lpfc: Correct code setting non existent bits in sli4 ABORT WQEJames Smart
[ Upstream commit 1c36833d82ff24d0d54215fd956e7cc30fffce54 ] Driver is setting bits in word 10 of the SLI4 ABORT WQE (the wqid). The field was a carry over from a prior SLI revision. The field does not exist in SLI4, and the action may result in an overlap with future definition of the WQE. Remove the setting of WQID in the ABORT WQE. Also cleaned up WQE field settings - initialize to zero, don't bother to set fields to zero. Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com> Signed-off-by: James Smart <jsmart2021@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: lpfc: Cap NPIV vports to 256James Smart
[ Upstream commit 8b47ae69e049ae0b3373859d901f0334322f9fe9 ] Depending on the chipset, the number of NPIV vports may vary and be in excess of what most switches support (256). To avoid confusion with the users, limit the reported NPIV vports to 256. Additionally correct the 16G adapter which is reporting a bogus NPIV vport number if the link is down. Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com> Signed-off-by: James Smart <jsmart2021@gmail.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17phy: renesas: rcar-gen3-usb2: Fix sysfs interface of "role"Yoshihiro Shimoda
[ Upstream commit 4bd5ead82d4b877ebe41daf95f28cda53205b039 ] Since the role_store() uses strncmp(), it's possible to refer out-of-memory if the sysfs data size is smaller than strlen("host"). This patch fixes it by using sysfs_streq() instead of strncmp(). Reported-by: Pavel Machek <pavel@denx.de> Fixes: 9bb86777fb71 ("phy: rcar-gen3-usb2: add sysfs for usb role swap") Cc: <stable@vger.kernel.org> # v4.10+ Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Pavel Machek <pavel@denx.de> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17iio: adis16480: Add debugfs_reg_access entryNuno Sá
[ Upstream commit 4c35b7a51e2f291471f7221d112c6a45c63e83bc ] The driver is defining debugfs entries by calling `adis16480_debugfs_init()`. However, those entries are attached to the iio_dev debugfs entry which won't exist if no debugfs_reg_access callback is provided. Fixes: 2f3abe6cbb6c ("iio:imu: Add support for the ADIS16480 and similar IMUs") Signed-off-by: Nuno Sá <nuno.sa@analog.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17xhci: make sure interrupts are restored to correct stateMathias Nyman
[ Upstream commit bd82873f23c9a6ad834348f8b83f3b6a5bca2c65 ] spin_unlock_irqrestore() might be called with stale flags after reading port status, possibly restoring interrupts to a incorrect state. If a usb2 port just finished resuming while the port status is read the spin lock will be temporary released and re-acquired in a separate function. The flags parameter is passed as value instead of a pointer, not updating flags properly before the final spin_unlock_irqrestore() is called. Cc: <stable@vger.kernel.org> # v3.12+ Fixes: 8b3d45705e54 ("usb: Fix xHCI host issues on remote wakeup.") Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Link: https://lore.kernel.org/r/20191211142007.8847-7-mathias.nyman@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17xhci: Fix memory leak in xhci_add_in_port()Mika Westerberg
[ Upstream commit ce91f1a43b37463f517155bdfbd525eb43adbd1a ] When xHCI is part of Alpine or Titan Ridge Thunderbolt controller and the xHCI device is hot-removed as a result of unplugging a dock for example, the driver leaks memory it allocates for xhci->usb3_rhub.psi and xhci->usb2_rhub.psi in xhci_add_in_port() as reported by kmemleak: unreferenced object 0xffff922c24ef42f0 (size 16): comm "kworker/u16:2", pid 178, jiffies 4294711640 (age 956.620s) hex dump (first 16 bytes): 21 00 0c 00 12 00 dc 05 23 00 e0 01 00 00 00 00 !.......#....... backtrace: [<000000007ac80914>] xhci_mem_init+0xcf8/0xeb7 [<0000000001b6d775>] xhci_init+0x7c/0x160 [<00000000db443fe3>] xhci_gen_setup+0x214/0x340 [<00000000fdffd320>] xhci_pci_setup+0x48/0x110 [<00000000541e1e03>] usb_add_hcd.cold+0x265/0x747 [<00000000ca47a56b>] usb_hcd_pci_probe+0x219/0x3b4 [<0000000021043861>] xhci_pci_probe+0x24/0x1c0 [<00000000b9231f25>] local_pci_probe+0x3d/0x70 [<000000006385c9d7>] pci_device_probe+0xd0/0x150 [<0000000070241068>] really_probe+0xf5/0x3c0 [<0000000061f35c0a>] driver_probe_device+0x58/0x100 [<000000009da11198>] bus_for_each_drv+0x79/0xc0 [<000000009ce45f69>] __device_attach+0xda/0x160 [<00000000df201aaf>] pci_bus_add_device+0x46/0x70 [<0000000088a1bc48>] pci_bus_add_devices+0x27/0x60 [<00000000ad9ee708>] pci_bus_add_devices+0x52/0x60 unreferenced object 0xffff922c24ef3318 (size 8): comm "kworker/u16:2", pid 178, jiffies 4294711640 (age 956.620s) hex dump (first 8 bytes): 34 01 05 00 35 41 0a 00 4...5A.. backtrace: [<000000007ac80914>] xhci_mem_init+0xcf8/0xeb7 [<0000000001b6d775>] xhci_init+0x7c/0x160 [<00000000db443fe3>] xhci_gen_setup+0x214/0x340 [<00000000fdffd320>] xhci_pci_setup+0x48/0x110 [<00000000541e1e03>] usb_add_hcd.cold+0x265/0x747 [<00000000ca47a56b>] usb_hcd_pci_probe+0x219/0x3b4 [<0000000021043861>] xhci_pci_probe+0x24/0x1c0 [<00000000b9231f25>] local_pci_probe+0x3d/0x70 [<000000006385c9d7>] pci_device_probe+0xd0/0x150 [<0000000070241068>] really_probe+0xf5/0x3c0 [<0000000061f35c0a>] driver_probe_device+0x58/0x100 [<000000009da11198>] bus_for_each_drv+0x79/0xc0 [<000000009ce45f69>] __device_attach+0xda/0x160 [<00000000df201aaf>] pci_bus_add_device+0x46/0x70 [<0000000088a1bc48>] pci_bus_add_devices+0x27/0x60 [<00000000ad9ee708>] pci_bus_add_devices+0x52/0x60 Fix this by calling kfree() for the both psi objects in xhci_mem_cleanup(). Cc: <stable@vger.kernel.org> # 4.4+ Fixes: 47189098f8be ("xhci: parse xhci protocol speed ID list for usb 3.1 usage") Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Link: https://lore.kernel.org/r/20191211142007.8847-2-mathias.nyman@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: qla2xxx: Fix message indicating vectors used by driverHimanshu Madhani
[ Upstream commit da48b82425b8bf999fb9f7c220e967c4d661b5f8 ] This patch updates log message which indicates number of vectors used by the driver instead of displaying failure to get maximum requested vectors. Driver will always request maximum vectors during initialization. In the event driver is not able to get maximum requested vectors, it will adjust the allocated vectors. This is normal and does not imply failure in driver. Signed-off-by: Himanshu Madhani <hmadhani@marvell.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Reviewed-by: Lee Duncan <lduncan@suse.com> Link: https://lore.kernel.org/r/20190830222402.23688-2-hmadhani@marvell.com Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: qla2xxx: Always check the qla2x00_wait_for_hba_online() return valueBart Van Assche
[ Upstream commit e6803efae5acd109fad9f2f07dab674563441a53 ] This patch fixes several Coverity complaints about not always checking the qla2x00_wait_for_hba_online() return value. Cc: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Himanshu Madhani <hmadhani@marvell.com> Reviewed-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: qla2xxx: Fix qla24xx_process_bidir_cmd()Bart Van Assche
[ Upstream commit c29282c65d1cf54daeea63be46243d7f69d72f4d ] Set the r??_data_len variables before using these instead of after. This patch fixes the following Coverity complaint: const: At condition req_data_len != rsp_data_len, the value of req_data_len must be equal to 0. const: At condition req_data_len != rsp_data_len, the value of rsp_data_len must be equal to 0. dead_error_condition: The condition req_data_len != rsp_data_len cannot be true. Cc: Himanshu Madhani <hmadhani@marvell.com> Fixes: a9b6f722f62d ("[SCSI] qla2xxx: Implementation of bidirectional.") # v3.7. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Himanshu Madhani <hmadhani@marvell.com> Reviewed-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: qla2xxx: Fix session lookup in qlt_abort_work()Bart Van Assche
[ Upstream commit ac452b8e79320c9e90c78edf32ba2d42431e4daf ] Pass the correct session ID to find_sess_by_s_id() instead of passing an uninitialized variable. Cc: Himanshu Madhani <hmadhani@marvell.com> Fixes: 2d70c103fd2a ("[SCSI] qla2xxx: Add LLD target-mode infrastructure for >= 24xx series") # v3.5. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Tested-by: Himanshu Madhani <hmadhani@marvell.com> Reviewed-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: qla2xxx: Fix DMA unmap leakHimanshu Madhani
[ Upstream commit 5d328de64d89400dcf9911125844d8adc0db697f ] With debug kernel we see following wanings indicating memory leak. [28809.523959] WARNING: CPU: 3 PID: 6790 at lib/dma-debug.c:978 dma_debug_device_change+0x166/0x1d0 [28809.523964] pci 0000:0c:00.6: DMA-API: device driver has pending DMA allocations while released from device [count=5] [28809.523964] One of leaked entries details: [device address=0x00000002aefe4000] [size=8208 bytes] [mapped with DMA_BIDIRECTIONAL] [mapped as coherent] Fix this by unmapping DMA memory. Signed-off-by: Quinn Tran <qutran@marvell.com> Signed-off-by: Himanshu Madhani <hmadhani@marvell.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17scsi: zfcp: trace channel log even for FCP command responsesSteffen Maier
[ Upstream commit 100843f176109af94600e500da0428e21030ca7f ] While v2.6.26 commit b75db73159cc ("[SCSI] zfcp: Add qtcb dump to hba debug trace") is right that we don't want to flood the (payload) trace ring buffer, we don't trace successful FCP command responses by default. So we can include the channel log for problem determination with failed responses of any FSF request type. Fixes: b75db73159cc ("[SCSI] zfcp: Add qtcb dump to hba debug trace") Fixes: a54ca0f62f95 ("[SCSI] zfcp: Redesign of the debug tracing for HBA records.") Cc: <stable@vger.kernel.org> #2.6.38+ Link: https://lore.kernel.org/r/e37597b5c4ae123aaa85fd86c23a9f71e994e4a9.1572018132.git.bblock@linux.ibm.com Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Steffen Maier <maier@linux.ibm.com> Signed-off-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17video/hdmi: Fix AVI bar unpackVille Syrjälä
commit 6039f37dd6b76641198e290f26b31c475248f567 upstream. The bar values are little endian, not big endian. The pack function did it right but the unpack got it wrong. Fix it. Cc: stable@vger.kernel.org Cc: linux-media@vger.kernel.org Cc: Martin Bugge <marbugge@cisco.com> Cc: Hans Verkuil <hans.verkuil@cisco.com> Cc: Thierry Reding <treding@nvidia.com> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Fixes: 2c676f378edb ("[media] hdmi: added unpack and logging functions for InfoFrames") Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190919132853.30954-1-ville.syrjala@linux.intel.com Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17ppdev: fix PPGETTIME/PPSETTIME ioctlsArnd Bergmann
commit 998174042da229e2cf5841f574aba4a743e69650 upstream. Going through the uses of timeval in the user space API, I noticed two bugs in ppdev that were introduced in the y2038 conversion: * The range check was accidentally moved from ppsettime to ppgettime * On sparc64, the microseconds are in the other half of the 64-bit word. Fix both, and mark the fix for stable backports. Cc: stable@vger.kernel.org Fixes: 3b9ab374a1e6 ("ppdev: convert to y2038 safe") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Link: https://lore.kernel.org/r/20191108203435.112759-8-arnd@arndb.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17mmc: host: omap_hsmmc: add code for special init of wl1251 to get rid of ↵H. Nikolaus Schaller
pandora_wl1251_init_card commit f6498b922e57aecbe3b7fa30a308d9d586c0c369 upstream. Pandora_wl1251_init_card was used to do special pdata based setup of the sdio mmc interface. This does no longer work with v4.7 and later. A fix requires a device tree based mmc3 setup. Therefore we move the special setup to omap_hsmmc.c instead of calling some pdata supplied init_card function. The new code checks for a DT child node compatible to wl1251 so it will not affect other MMC3 use cases. Generally, this code was and still is a hack and should be moved to mmc core to e.g. read such properties from optional DT child nodes. Fixes: 81eef6ca9201 ("mmc: omap_hsmmc: Use dma_request_chan() for requesting DMA channel") Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com> Cc: <stable@vger.kernel.org> # v4.7+ [Ulf: Fixed up some checkpatch complaints] Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17pinctrl: samsung: Fix device node refcount leaks in S3C64xx wakeup ↵Krzysztof Kozlowski
controller init commit 7f028caadf6c37580d0f59c6c094ed09afc04062 upstream. In s3c64xx_eint_eint0_init() the for_each_child_of_node() loop is used with a break to find a matching child node. Although each iteration of for_each_child_of_node puts the previous node, but early exit from loop misses it. This leads to leak of device node. Cc: <stable@vger.kernel.org> Fixes: 61dd72613177 ("pinctrl: Add pinctrl-s3c64xx driver") Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17pinctrl: samsung: Fix device node refcount leaks in init codeKrzysztof Kozlowski
commit a322b3377f4bac32aa25fb1acb9e7afbbbbd0137 upstream. Several functions use for_each_child_of_node() loop with a break to find a matching child node. Although each iteration of for_each_child_of_node puts the previous node, but early exit from loop misses it. This leads to leak of device node. Cc: <stable@vger.kernel.org> Fixes: 9a2c1c3b91aa ("pinctrl: samsung: Allow grouping multiple pinmux/pinconf nodes") Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17pinctrl: samsung: Fix device node refcount leaks in S3C24xx wakeup ↵Krzysztof Kozlowski
controller init commit 6fbbcb050802d6ea109f387e961b1dbcc3a80c96 upstream. In s3c24xx_eint_init() the for_each_child_of_node() loop is used with a break to find a matching child node. Although each iteration of for_each_child_of_node puts the previous node, but early exit from loop misses it. This leads to leak of device node. Cc: <stable@vger.kernel.org> Fixes: af99a7507469 ("pinctrl: Add pinctrl-s3c24xx driver") Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17pinctrl: samsung: Add of_node_put() before return in error pathNishka Dasgupta
commit 3d2557ab75d4c568c79eefa2e550e0d80348a6bd upstream. Each iteration of for_each_child_of_node puts the previous node, but in the case of a return from the middle of the loop, there is no put, thus causing a memory leak. Hence add an of_node_put before the return of exynos_eint_wkup_init() error path. Issue found with Coccinelle. Signed-off-by: Nishka Dasgupta <nishkadg.linux@gmail.com> Cc: <stable@vger.kernel.org> Fixes: 14c255d35b25 ("pinctrl: exynos: Add irq_chip instance for Exynos7 wakeup interrupts") Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17ACPI: PM: Avoid attaching ACPI PM domain to certain devicesRafael J. Wysocki
commit b9ea0bae260f6aae546db224daa6ac1bd9d94b91 upstream. Certain ACPI-enumerated devices represented as platform devices in Linux, like fans, require special low-level power management handling implemented by their drivers that is not in agreement with the ACPI PM domain behavior. That leads to problems with managing ACPI fans during system-wide suspend and resume. For this reason, make acpi_dev_pm_attach() skip the affected devices by adding a list of device IDs to avoid to it and putting the IDs of the affected devices into that list. Fixes: e5cc8ef31267 (ACPI / PM: Provide ACPI PM callback routines for subsystems) Reported-by: Zhang Rui <rui.zhang@intel.com> Tested-by: Todd Brandt <todd.e.brandt@linux.intel.com> Cc: 3.10+ <stable@vger.kernel.org> # 3.10+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17ACPI: bus: Fix NULL pointer check in acpi_bus_get_private_data()Vamshi K Sthambamkadi
commit 627ead724eff33673597216f5020b72118827de4 upstream. kmemleak reported backtrace: [<bbee0454>] kmem_cache_alloc_trace+0x128/0x260 [<6677f215>] i2c_acpi_install_space_handler+0x4b/0xe0 [<1180f4fc>] i2c_register_adapter+0x186/0x400 [<6083baf7>] i2c_add_adapter+0x4e/0x70 [<a3ddf966>] intel_gmbus_setup+0x1a2/0x2c0 [i915] [<84cb69ae>] i915_driver_probe+0x8d8/0x13a0 [i915] [<81911d4b>] i915_pci_probe+0x48/0x160 [i915] [<4b159af1>] pci_device_probe+0xdc/0x160 [<b3c64704>] really_probe+0x1ee/0x450 [<bc029f5a>] driver_probe_device+0x142/0x1b0 [<d8829d20>] device_driver_attach+0x49/0x50 [<de71f045>] __driver_attach+0xc9/0x150 [<df33ac83>] bus_for_each_dev+0x56/0xa0 [<80089bba>] driver_attach+0x19/0x20 [<cc73f583>] bus_add_driver+0x177/0x220 [<7b29d8c7>] driver_register+0x56/0xf0 In i2c_acpi_remove_space_handler(), a leak occurs whenever the "data" parameter is initialized to 0 before being passed to acpi_bus_get_private_data(). This is because the NULL pointer check in acpi_bus_get_private_data() (condition->if(!*data)) returns EINVAL and, in consequence, memory is never freed in i2c_acpi_remove_space_handler(). Fix the NULL pointer check in acpi_bus_get_private_data() to follow the analogous check in acpi_get_data_full(). Signed-off-by: Vamshi K Sthambamkadi <vamshi.k.sthambamkadi@gmail.com> [ rjw: Subject & changelog ] Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17ACPI: OSL: only free map once in osl.cFrancesco Ruggeri
commit 833a426cc471b6088011b3d67f1dc4e147614647 upstream. acpi_os_map_cleanup checks map->refcount outside of acpi_ioremap_lock before freeing the map. This creates a race condition the can result in the map being freed more than once. A panic can be caused by running for ((i=0; i<10; i++)) do for ((j=0; j<100000; j++)) do cat /sys/firmware/acpi/tables/data/BERT >/dev/null done & done This patch makes sure that only the process that drops the reference to 0 does the freeing. Fixes: b7c1fadd6c2e ("ACPI: Do not use krefs under a mutex in osl.c") Signed-off-by: Francesco Ruggeri <fruggeri@arista.com> Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17cpufreq: powernv: fix stack bloat and hard limit on number of CPUsJohn Hubbard
commit db0d32d84031188443e25edbd50a71a6e7ac5d1d upstream. The following build warning occurred on powerpc 64-bit builds: drivers/cpufreq/powernv-cpufreq.c: In function 'init_chip_info': drivers/cpufreq/powernv-cpufreq.c:1070:1: warning: the frame size of 1040 bytes is larger than 1024 bytes [-Wframe-larger-than=] This is with a cross-compiler based on gcc 8.1.0, which I got from: https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/8.1.0/ The warning is due to putting 1024 bytes on the stack: unsigned int chip[256]; ...and it's also undesirable to have a hard limit on the number of CPUs here. Fix both problems by dynamically allocating based on num_possible_cpus, as recommended by Michael Ellerman. Fixes: 053819e0bf840 ("cpufreq: powernv: Handle throttling due to Pmax capping at chip level") Signed-off-by: John Hubbard <jhubbard@nvidia.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: 4.10+ <stable@vger.kernel.org> # 4.10+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17PM / devfreq: Lock devfreq in trans_stat_showLeonard Crestez
commit 2abb0d5268ae7b5ddf82099b1f8d5aa8414637d4 upstream. There is no locking in this sysfs show function so stats printing can race with a devfreq_update_status called as part of freq switching or with initialization. Also add an assert in devfreq_update_status to make it clear that lock must be held by caller. Fixes: 39688ce6facd ("PM / devfreq: account suspend/resume for stats") Cc: stable@vger.kernel.org Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com> Reviewed-by: Matthias Kaehlcke <mka@chromium.org> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17intel_th: pci: Add Tiger Lake CPU supportAlexander Shishkin
commit 6e6c18bcb78c0dc0601ebe216bed12c844492d0c upstream. This adds support for the Trace Hub in Tiger Lake CPU. Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: stable@vger.kernel.org Link: https://lore.kernel.org/r/20191120130806.44028-4-alexander.shishkin@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17intel_th: pci: Add Ice Lake CPU supportAlexander Shishkin
commit 6a1743422a7c0fda26764a544136cac13e5ae486 upstream. This adds support for the Trace Hub in Ice Lake CPU. Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: stable@vger.kernel.org Link: https://lore.kernel.org/r/20191120130806.44028-3-alexander.shishkin@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17intel_th: Fix a double put_device() in error pathAlexander Shishkin
commit 512592779a337feb5905d8fcf9498dbf33672d4a upstream. Commit a753bfcfdb1f ("intel_th: Make the switch allocate its subdevices") factored out intel_th_subdevice_alloc() from intel_th_populate(), but got the error path wrong, resulting in two instances of a double put_device() on a freshly initialized, but not 'added' device. Fix this by only doing one put_device() in the error path. Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Fixes: a753bfcfdb1f ("intel_th: Make the switch allocate its subdevices") Reported-by: Wen Yang <wenyang@linux.alibaba.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: stable@vger.kernel.org # v4.14+ Link: https://lore.kernel.org/r/20191120130806.44028-2-alexander.shishkin@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17cpuidle: Do not unset the driver if it is there alreadyZhenzhong Duan
commit 918c1fe9fbbe46fcf56837ff21f0ef96424e8b29 upstream. Fix __cpuidle_set_driver() to check if any of the CPUs in the mask has a driver different from drv already and, if so, return -EBUSY before updating any cpuidle_drivers per-CPU pointers. Fixes: 82467a5a885d ("cpuidle: simplify multiple driver support") Cc: 3.11+ <stable@vger.kernel.org> # 3.11+ Signed-off-by: Zhenzhong Duan <zhenzhong.duan@oracle.com> [ rjw: Subject & changelog ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17media: radio: wl1273: fix interrupt masking on releaseJohan Hovold
commit 1091eb830627625dcf79958d99353c2391f41708 upstream. If a process is interrupted while accessing the radio device and the core lock is contended, release() could return early and fail to update the interrupt mask. Note that the return value of the v4l2 release file operation is ignored. Fixes: 87d1a50ce451 ("[media] V4L2: WL1273 FM Radio: TI WL1273 FM radio driver") Cc: stable <stable@vger.kernel.org> # 2.6.38 Cc: Matti Aaltonen <matti.j.aaltonen@nokia.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17media: bdisp: fix memleak on releaseJohan Hovold
commit 11609a7e21f8cea42630350aa57662928fa4dc63 upstream. If a process is interrupted while accessing the video device and the device lock is contended, release() could return early and fail to free related resources. Note that the return value of the v4l2 release file operation is ignored. Fixes: 28ffeebbb7bd ("[media] bdisp: 2D blitter driver using v4l2 mem2mem framework") Cc: stable <stable@vger.kernel.org> # 4.2 Signed-off-by: Johan Hovold <johan@kernel.org> Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17ar5523: check NULL before memcpy() in ar5523_cmd()Denis Efremov
commit 315cee426f87658a6799815845788fde965ddaad upstream. memcpy() call with "idata == NULL && ilen == 0" results in undefined behavior in ar5523_cmd(). For example, NULL is passed in callchain "ar5523_stat_work() -> ar5523_cmd_write() -> ar5523_cmd()". This patch adds ilen check before memcpy() call in ar5523_cmd() to prevent an undefined behavior. Cc: Pontus Fuchs <pontus.fuchs@gmail.com> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: David Laight <David.Laight@ACULAB.COM> Cc: stable@vger.kernel.org Signed-off-by: Denis Efremov <efremov@linux.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17dm zoned: reduce overhead of backing device checksDmitry Fomichev
commit e7fad909b68aa37470d9f2d2731b5bec355ee5d6 upstream. Commit 75d66ffb48efb3 added backing device health checks and as a part of these checks, check_events() block ops template call is invoked in dm-zoned mapping path as well as in reclaim and flush path. Calling check_events() with ATA or SCSI backing devices introduces a blocking scsi_test_unit_ready() call being made in sd_check_events(). Even though the overhead of calling scsi_test_unit_ready() is small for ATA zoned devices, it is much larger for SCSI and it affects performance in a very negative way. Fix this performance regression by executing check_events() only in case of any I/O errors. The function dmz_bdev_is_dying() is modified to call only blk_queue_dying(), while calls to check_events() are made in a new helper function, dmz_check_bdev(). Reported-by: zhangxiaoxu <zhangxiaoxu5@huawei.com> Fixes: 75d66ffb48efb3 ("dm zoned: properly handle backing device failure") Cc: stable@vger.kernel.org Signed-off-by: Dmitry Fomichev <dmitry.fomichev@wdc.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17hwrng: omap - Fix RNG wait loop timeoutSumit Garg
commit be867f987a4e1222114dd07a01838a17c26f3fff upstream. Existing RNG data read timeout is 200us but it doesn't cover EIP76 RNG data rate which takes approx. 700us to produce 16 bytes of output data as per testing results. So configure the timeout as 1000us to also take account of lack of udelay()'s reliability. Fixes: 383212425c92 ("hwrng: omap - Add device variant for SafeXcel IP-76 found in Armada 8K") Cc: <stable@vger.kernel.org> Signed-off-by: Sumit Garg <sumit.garg@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-17watchdog: aspeed: Fix clock behaviour for ast2600Joel Stanley
[ Upstream commit c04571251b3d842096f1597f5d4badb508be016d ] The ast2600 no longer uses bit 4 in the control register to indicate a 1MHz clock (It now controls whether this watchdog is reset by a SOC reset). This means we do not want to set it. It also does not need to be set for the ast2500, as it is read-only on that SoC. The comment next to the clock rate selection wandered away from where it was set, so put it back next to the register setting it's describing. Fixes: b3528b487448 ("watchdog: aspeed: Add support for AST2600") Signed-off-by: Joel Stanley <joel@jms.id.au> Reviewed-by: Cédric Le Goater <clg@kaod.org> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Link: https://lore.kernel.org/r/20191108032905.22463-1-joel@jms.id.au Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@linux-watchdog.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-17md/raid0: Fix an error message in raid0_make_request()Dan Carpenter
[ Upstream commit e3fc3f3d0943b126f76b8533960e4168412d9e5a ] The first argument to WARN() is supposed to be a condition. The original code will just print the mdname() instead of the full warning message. Fixes: c84a1372df92 ("md/raid0: avoid RAID0 data corruption due to layout confusion.") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Song Liu <songliubraving@fb.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
