commit e512d56c799517f33b301d81e9a5e0ebf30c2d1e upstream.
git commit 37f81fa1f63ad38e16125526bb2769ae0ea8d332
"n_tty: do O_ONLCR translation as a single write"
surfaced a bug in the 3215 device driver. In combination this
broke tab expansion for tty ouput.
The cause is an asymmetry in the behaviour of tty3215_ops->write
vs tty3215_ops->put_char. The put_char function scans for '\t'
but the write function does not.
As the driver has logic for the '\t' expansion remove XTABS
from c_oflag of the initial termios as well.
Reported-by: Stephen Powell <zlinuxman@wowway.com>
commit 26d766c60f4ea08cd14f0f3435a6db3d6cc2ae96 upstream.
The ccw_device_start in raw3215_start_io can fail. raw3215_try_io
does not check if the request could be started and removes any
pending timer. This can leave the system in a hanging state.
Check for pending request after raw3215_start_io and start a
timer if necessary.
commit bcf090e0040e30f8409e6a535a01e6473afb096f upstream.
this was very wrong - mempool_alloc() only guarantees success with GFP_WAIT.
bcache uses GFP_NOWAIT in various other places where we have a fallback,
circuits must've gotten crossed when writing this code or something.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: Gabriel de Perthuis <g2p.code@gmail.com>
commit b02efbfc9a051b41e71fe8f94ddf967260e024a6 upstream.
In situations such as bond failover, The new session establishment
implicitly invokes the termination of the old connection.
So, we don't want to wait for the old connection wait_conn to completely
terminate before we accept the new connection and post a login response.
The solution is to deffer the comp_wait completion and the conn_put to
a work so wait_conn will effectively be non-blocking (flush errors are
assumed to come very fast).
We allocate isert_release_wq with WQ_UNBOUND and WQ_UNBOUND_MAX_ACTIVE
to spread the concurrency of release works.
Reported-by: Slava Shwartsman <valyushash@gmail.com>
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
commit ca6c1d82d12d8013fb75ce015900d62b9754623c upstream.
The np listener cm_id will also get ADDR_CHANGE event
upcall (in case it is bound to a specific IP). Handle
it correctly by creating a new cm_id and implicitly
destroy the old one.
Since this is the second event a listener np cm_id may
encounter, we move the np cm_id event handling to a
routine.
Squashed:
iser-target: Move cma_id setup to a function
commit 19e2090fb246ca21b3e569ead51a6a7a1748eadd upstream.
Take isert_conn pointer from cm_id->qp->qp_context. This
will allow us to know that the cm_id context is always
the network portal. This will make the cm_id event check
(connection or network portal) more reliable.
In order to avoid a NULL dereference in cma_id->qp->qp_context
we destroy the qp after we destroy the cm_id (and make the
dereference safe). session stablishment/teardown sequences
can happen in parallel, we should take into account that
connected_handler might race with connection teardown flow.
Also, protect isert_conn->conn_device->active_qps decrement
within the error patch during QP creation failure and the
normal teardown path in isert_connect_release().
Squashed:
iser-target: Decrement completion context active_qps in error flow
commit 2371e5da8cfe91443339b54444dec6254fdd6dfc upstream.
There is no point in accepting a new CM request only
when we are completely done with the last iscsi login.
Instead we accept immediately, this will also cause the
CM connection to reach connected state and the initiator
is allowed to send the first login. We mark that we got
the initial login and let iscsi layer pick it up when it
gets there.
This reduces the parallel login sequence by a factor of
more then 4 (and more for multi-login) and also prevents
the initiator (who does all logins in parallel) from
giving up on login timeout expiration.
In order to support multiple login requests sequence (CHAP)
we call isert_rx_login_req from isert_rx_completion insead
of letting isert_get_login_rx call it.
Squashed:
iser-target: Use kref_get_unless_zero in connected_handler
iser-target: Acquire conn_mutex when changing connection state
iser-target: Reject connect request in failure path
commit 128e9cc84566a84146baea2335b3824288eed817 upstream.
ISER_CONN_UP state is not sufficient to know if
we should wait for completion of flush errors and
disconnected_handler event.
Instead, split it to 2 states:
- ISER_CONN_UP: Got to CM connected phase, This state
indicates that we need to wait for a CM disconnect
event before going to teardown.
- ISER_CONN_FULL_FEATURE: Got to full feature phase
after we posted login response, This state indicates
that we posted recv buffers and we need to wait for
flush completions before going to teardown.
Also avoid deffering disconnected handler to a work,
and handle it within disconnected handler.
More work here is needed to handle DEVICE_REMOVAL event
correctly (cleanup all resources).
Squashed:
iser-target: Don't deffer disconnected handler to a work
commit 954f23722b5753305be490330cf2680b7a25f4a3 upstream.
Since commit 0fc4ea701fcf ("Target/iser: Don't put isert_conn inside
disconnected handler") we put the conn kref in isert_wait_conn, so we
need .wait_conn to be invoked also in the error path.
Introduce call to isert_conn_terminate (called under lock)
which transitions the connection state to TERMINATING and calls
rdma_disconnect. If the state is already teminating, just bail
out back (temination started).
Also, make sure to destroy the connection when getting a connect
error event if didn't get to connected (state UP). Same for the
handling of REJECTED and UNREACHABLE cma events.
Squashed:
iscsi-target: Add call to wait_conn in establishment error flow
commit 46243860806bdc2756f3ce8ac86b4d7c616bcd6c upstream.
While looking at hch's recent conversion to drop the MSG_*_TAG
definitions, I noticed a long standing bug in vhost-scsi where
the VIRTIO_SCSI_S_* attribute definitions where incorrectly
being passed directly into target_submit_cmd_map_sgls().
This patch adds the missing virtio-scsi to TCM/SAM task attribute
conversion.
Cc: Michael S. Tsirkin <mst@redhat.com>
commit 506787a2c7daed45f0a213674ca706cbc83a9089 upstream.
tcm_loop has the I_T nexus associated with the HBA. This causes
commands to become misdirected if the HBA has more than one
target portal group; any command is then being sent to the
first target portal group instead of the correct one.
The nexus needs to be associated with the target portal group
instead.
Signed-off-by: Hannes Reinecke <hare@suse.de>
commit 6375f8908255ea7438b60bb5998e6b3e1628500d upstream.
The SCSI command tag is set to the tag assigned from the block
layer, not the SCSI-II tag message. So we need to convert
it into the correct SCSI-II tag message based on the
device flags, not the tag value itself.
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
commit 9333caeaeae4f831054e0e127a6ed3948b604d3e upstream.
When KBC is in active multiplexing mode the touchpad on this laptop does
not work.
Reported-by: Bilal Koc <koc.bilo@googlemail.com>
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream.
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
commit 5e7e6e0c9b47a45576c38b4a72d67927a5e049f7 upstream.
Recent Leaf firmware versions (>= 3.1.557) do not allow to send
commands for non-existing channels. If a command is sent for a
non-existing channel, the firmware crashes.
Reported-by: Christopher Storah <Christopher.Storah@invetech.com.au>
Signed-off-by: Olivier Sobrie <olivier@sobrie.be>
Signed-off-by: Ahmed S. Darwish <ahmed.darwish@valeo.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 889b77f7fd2bcc922493d73a4c51d8a851505815 upstream.
Flooding the Kvaser CAN to USB dongle with multiple reads and
writes in very high frequency (*), closing the CAN channel while
all the transmissions are on (#), opening the device again (@),
then sending a small number of packets would make the driver
enter an almost infinite loop of:
[15959.853988] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853990] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853991] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853993] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853994] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853995] kvaser_usb 4-3:1.0 can0: cannot find free context
_dragging the whole system down_ in the process due to the
excessive logging output.
Initially, this has caused random panics in the kernel due to a
buggy error recovery path. That got fixed in an earlier commit.(%)
This patch aims at solving the root cause. -->
16 tx URBs and contexts are allocated per CAN channel per USB
device. Such URBs are protected by:
a) A simple atomic counter, up to a value of MAX_TX_URBS (16)
b) A flag in each URB context, stating if it's free
c) The fact that ndo_start_xmit calls are themselves protected
by the networking layers higher above
After grabbing one of the tx URBs, if the driver noticed that all
of them are now taken, it stops the netif transmission queue.
Such queue is worken up again only if an acknowedgment was received
from the firmware on one of our earlier-sent frames.
Meanwhile, upon channel close (#), the driver sends a CMD_STOP_CHIP
to the firmware, effectively closing all further communication. In
the high traffic case, the atomic counter remains at MAX_TX_URBS,
and all the URB contexts remain marked as active. While opening
the channel again (@), it cannot send any further frames since no
more free tx URB contexts are available.
Reset all tx URB contexts upon CAN channel close.
(*) 50 parallel instances of `cangen0 -g 0 -ix`
(#) `ifconfig can0 down`
(@) `ifconfig can0 up`
(%) "can: kvaser_usb: Don't free packets when tight on URBs"
commit b442723fcec445fb0ae1104888dd22cd285e0a91 upstream.
writes in high frequency caused seemingly-random panics in the
kernel.
On further inspection, it seems the driver erroneously freed the
to-be-transmitted packet upon getting tight on URBs and returning
NETDEV_TX_BUSY, leading to invalid memory writes and double frees
at a later point in time.
Note:
Finding no more URBs/transmit-contexts and returning NETDEV_TX_BUSY
is a driver bug in and out of itself: it means that our start/stop
queue flow control is broken.
This patch only fixes the (buggy) error handling code; the root
cause shall be fixed in a later commit.
Acked-by: Olivier Sobrie <olivier@sobrie.be>
commit 68693b8ea4e284c46bff919ac62bd9ccdfdbb6ba upstream.
since the split of host+gadget mode in commit 74c2e9360058 ("usb: musb:
factor out hcd initalization") we leak the usb_hcd struct. We call now
musb_host_cleanup() which does basically usb_remove_hcd() and also sets
the hcd variable to NULL. Doing so makes the finall call to
musb_host_free() basically a nop and the usb_hcd remains around for ever
without anowner.
This patch drops that NULL assignment for that reason.
Fixes: 74c2e9360058 ("usb: musb: factor out hcd initalization")
Cc: Daniel Mack <zonque@gmail.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 6d89252a998a695ecb0348fc2d717dc33d90cae9 upstream.
Commit c3ee9b76aa93 (EHCI: improved logic for isochronous scheduling)
introduced the idea of using ehci->last_iso_frame as the origin (or
base) for the circular calculations involved in modifying the
isochronous schedule. However, the new code it added used
ehci->last_iso_frame before the value was properly initialized. This
patch rectifies the mistake by moving the initialization lines earlier
in iso_stream_schedule().
This fixes Bugzilla #72891.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Fixes: c3ee9b76aa93
Reported-by: Joe Bryant <tenminjoe@yahoo.com>
Tested-by: Joe Bryant <tenminjoe@yahoo.com>
Tested-by: Martin Long <martin@longhome.co.uk>
commit 32a4bf2e81ec378e5925d4e069e0677a6c86a6ad upstream.
Use tty kref to release the fake tty in usb_console_setup to avoid use
after free if the underlying serial driver has acquired a reference.
Note that using the tty destructor release_one_tty requires some more
state to be initialised.
Fixes: 4a90f09b20f4 ("tty: usb-serial krefs")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit d269d4434c72ed0da3a9b1230c30da82c4918c63 upstream.
The USB console currently allocates a temporary fake tty which is used
to pass terminal settings to the underlying serial driver.
The tty struct is not fully initialised, something which can lead to a
lockdep warning (or worse) if a serial driver tries to acquire a
line-discipline reference:
usbserial: USB Serial support registered for pl2303
pl2303 1-2.1:1.0: pl2303 converter detected
usb 1-2.1: pl2303 converter now attached to ttyUSB0
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 0 PID: 68 Comm: udevd Tainted: G W 3.18.0-rc5 #10
[<c0016f04>] (unwind_backtrace) from [<c0013978>] (show_stack+0x20/0x24)
[<c0013978>] (show_stack) from [<c0449794>] (dump_stack+0x24/0x28)
[<c0449794>] (dump_stack) from [<c006f730>] (__lock_acquire+0x1e50/0x2004)
[<c006f730>] (__lock_acquire) from [<c0070128>] (lock_acquire+0xe4/0x18c)
[<c0070128>] (lock_acquire) from [<c027c6f8>] (ldsem_down_read_trylock+0x78/0x90)
[<c027c6f8>] (ldsem_down_read_trylock) from [<c027a1cc>] (tty_ldisc_ref+0x24/0x58)
[<c027a1cc>] (tty_ldisc_ref) from [<c0340760>] (usb_serial_handle_dcd_change+0x48/0xe8)
[<c0340760>] (usb_serial_handle_dcd_change) from [<bf000484>] (pl2303_read_int_callback+0x210/0x220 [pl2303])
[<bf000484>] (pl2303_read_int_callback [pl2303]) from [<c031624c>] (__usb_hcd_giveback_urb+0x80/0x140)
[<c031624c>] (__usb_hcd_giveback_urb) from [<c0316fc0>] (usb_giveback_urb_bh+0x98/0xd4)
[<c0316fc0>] (usb_giveback_urb_bh) from [<c0042e44>] (tasklet_hi_action+0x9c/0x108)
[<c0042e44>] (tasklet_hi_action) from [<c0042380>] (__do_softirq+0x148/0x42c)
[<c0042380>] (__do_softirq) from [<c00429cc>] (irq_exit+0xd8/0x114)
[<c00429cc>] (irq_exit) from [<c007ae58>] (__handle_domain_irq+0x84/0xdc)
[<c007ae58>] (__handle_domain_irq) from [<c000879c>] (omap_intc_handle_irq+0xd8/0xe0)
[<c000879c>] (omap_intc_handle_irq) from [<c0014544>] (__irq_svc+0x44/0x7c)
Exception stack(0xdf4e7f08 to 0xdf4e7f50)
7f00: debc0b80 df4e7f5c 00000000 00000000 debc0b80 be8da96c
7f20: 00000000 00000128 c000fc84 df4e6000 00000000 df4e7f94 00000004 df4e7f50
7f40: c038ebc0 c038d74c 600f0013 ffffffff
[<c0014544>] (__irq_svc) from [<c038d74c>] (___sys_sendmsg.part.29+0x0/0x2e0)
[<c038d74c>] (___sys_sendmsg.part.29) from [<c038ec08>] (SyS_sendmsg+0x18/0x1c)
[<c038ec08>] (SyS_sendmsg) from [<c000fa00>] (ret_fast_syscall+0x0/0x48)
console [ttyUSB0] enabled
Fixes: 36697529b5bb ("tty: Replace ldisc locking with ldisc_sem")
commit b5122236bba8d7ef62153da5b55cc65d0944c61e upstream.
Fix null-pointer dereference during probe if the interface-status
completion handler is called before the individual ports have been set
up.
Fixes: f79b2d0fe81e ("USB: keyspan: fix NULL-pointer dereferences and
memory leaks")
Reported-by: Richard <richjunk@pacbell.net>
Tested-by: Richard <richjunk@pacbell.net>
commit 1ae78a4870989a354028cb17dabf819b595e70e3 upstream.
Added virtual com port VID/PID entries for CEL USB sticks and MeshWorks
devices.
Signed-off-by: David Peterson <david.peterson@cel.com>
commit 90441b4dbe90ba0c38111ea89fa093a8c9627801 upstream.
Fixing typo for MeshConnect IDs. The original PID (0x8875) is not in
production and is not needed. Instead it has been changed to the
official production PID (0x8857).
Signed-off-by: Preston Fick <pffick@gmail.com>
commit 39e60635a01520e8c8ed3946a28c2b98e6a46f79 upstream.
DWC3 gadget sets up a pool of 32 TRBs for each EP during initialization. This
means, the max TRBs that can be submitted for an EP is fixed to 32. Since the
request queue for an EP is a linked list, any number of requests can be queued
to it by the gadget layer. However, the dwc3 driver must not submit TRBs more
than the pool it has created for. This limit wasn't respected when SG was used
resulting in submitting more than the max TRBs, eventually leading to
non-transfer of the TRBs submitted over the max limit.
Root cause:
When SG is used, there are two loops iterating to prepare TRBs:
- Outer loop over the request_list
- Inner loop over the SG list
The code was missing break to get out of the outer loop.
Fixes: eeb720fb21d6 (usb: dwc3: gadget: add support for SG lists)
Signed-off-by: Amit Virdi <amit.virdi@st.com>
commit ec512fb8e5611fed1df2895f90317ce6797d6b32 upstream.
When scatter gather (SG) is used, multiple TRBs are prepared from one DWC3
request (dwc3_request). So while preparing TRBs, the 'last' flag should be set
only when it is the last TRB being prepared from the last dwc3_request entry.
The current implementation uses list_is_last to check if the dwc3_request is the
last entry from the request_list. However, list_is_last returns false for the
last entry too. This is because, while preparing the first TRB from a request,
the function dwc3_prepare_one_trb modifies the request's next and prev pointers
while moving the URB to req_queued. Hence, list_is_last always returns false no
matter what.
The correct way is not to access the modified pointers of dwc3_request but to
use list_empty macro instead.
Fixes: e5ba5ec833aa (usb: dwc3: gadget: fix scatter gather implementation)
commit 56abcab833fafcfaeb2f5b25e0364c1dec45f53e upstream.
Commit 8dccddbc2368 ("OHCI: final fix for NVIDIA problems (I hope)")
introduced into 3.1.9 broke boot on e.g. Freescale P2020DS development
board. The code path that was previously specific to NVIDIA controllers
had then become taken for all chips.
However, the M5237 installed on the board wedges solid when accessing
its base+OHCI_FMINTERVAL register, making it impossible to boot any
kernel newer than 3.1.8 on this particular and apparently other similar
machines.
Don't readl() and writel() base+OHCI_FMINTERVAL on PCI ID 10b9:5237.
The patch is suitable for the -next tree as well as all maintained
kernels up to 3.2 inclusive.
Signed-off-by: Arseny Solokha <asolokha@kb.kras.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 5539b3c938d64a60cb1fc442ac3ce9263d52de0c upstream.
Memory allocated and references taken by of_gpiochip_add and
acpi_gpiochip_add were never released on errors in gpiochip_add (e.g.
failure to find free gpio range).
Fixes: 391c970c0dd1 ("of/gpio: add default of_xlate function if device
has a node pointer")
Fixes: 664e3e5ac64c ("gpio / ACPI: register to ACPI events
automatically")
commit 7b8792bbdffdff3abda704f89c6a45ea97afdc62 upstream.
of_get_named_gpiod_flags fails with -EPROBE_DEFER in cases
where the gpio chip is available and the GPIO translation fails.
This causes drivers to be re-probed erroneusly, and hides the
real problem(i.e. the GPIO number being out of range).
Signed-off-by: Hans Holmberg <hans.holmberg@intel.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
commit 25906052d953d3fbdb7e19480b9de5e6bb949f3f upstream.
Since ALE table is a common resource for both the interfaces in Dual EMAC
mode and while bringing up the second interface in cpsw_ndo_set_rx_mode()
all the multicast entries added by the first interface is flushed out and
only second interface multicast addresses are added. Fixing this by
flushing multicast addresses based on dual EMAC port vlans which will not
affect the other emac port multicast addresses.
Fixes: d9ba8f9 (driver: net: ethernet: cpsw: dual emac interface implementation)
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
commit 7c2e211f3c95b91912a92a8c6736343690042e2e upstream.
Current vfio-pci just supports normal pci device, so vfio_pci_probe() will
return if the pci device is not a normal device. While current code makes a
mistake. PCI_HEADER_TYPE is the offset in configuration space of the device
type, but we use this value to mask the type value.
This patch fixs this by do the check directly on the pci_dev->hdr_type.
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit 2228d80dd05a4fc5a410fde847677b8fb3eb23d7 upstream.
We've got a bug report at disconnecting a Webcam, where the kernel
spews warnings like below:
WARNING: CPU: 0 PID: 8385 at ../fs/sysfs/group.c:219 sysfs_remove_group+0x87/0x90()
sysfs group c0b2350c not found for kobject 'event3'
CPU: 0 PID: 8385 Comm: queue2:src Not tainted 3.16.2-1.gdcee397-default #1
Hardware name: ASUSTeK Computer INC. A7N8X-E/A7N8X-E, BIOS ASUS A7N8X-E Deluxe ACPI BIOS Rev 1013 11/12/2004
c08d0705 ddc75cbc c0718c5b ddc75ccc c024b654 c08c6d44 ddc75ce8 000020c1
c08d0705 000000db c03d1ec7 c03d1ec7 00000009 00000000 c0b2350c d62c9064
ddc75cd4 c024b6a3 00000009 ddc75ccc c08c6d44 ddc75ce8 ddc75cfc c03d1ec7
Call Trace:
[<c0205ba6>] try_stack_unwind+0x156/0x170
[<c02046f3>] dump_trace+0x53/0x180
[<c0205c06>] show_trace_log_lvl+0x46/0x50
[<c0204871>] show_stack_log_lvl+0x51/0xe0
[<c0205c67>] show_stack+0x27/0x50
[<c0718c5b>] dump_stack+0x3e/0x4e
[<c024b654>] warn_slowpath_common+0x84/0xa0
[<c024b6a3>] warn_slowpath_fmt+0x33/0x40
[<c03d1ec7>] sysfs_remove_group+0x87/0x90
[<c05a2c54>] device_del+0x34/0x180
[<c05e3989>] evdev_disconnect+0x19/0x50
[<c05e06fa>] __input_unregister_device+0x9a/0x140
[<c05e0845>] input_unregister_device+0x45/0x80
[<f854b1d6>] uvc_delete+0x26/0x110 [uvcvideo]
[<f84d66f8>] v4l2_device_release+0x98/0xc0 [videodev]
[<c05a25bb>] device_release+0x2b/0x90
[<c04ad8bf>] kobject_cleanup+0x6f/0x1a0
[<f84d5453>] v4l2_release+0x43/0x70 [videodev]
[<c0372f31>] __fput+0xb1/0x1b0
[<c02650c1>] task_work_run+0x91/0xb0
[<c024d845>] do_exit+0x265/0x910
[<c024df64>] do_group_exit+0x34/0xa0
[<c025a76f>] get_signal_to_deliver+0x17f/0x590
[<c0201b6a>] do_signal+0x3a/0x960
[<c02024f7>] do_notify_resume+0x67/0x90
[<c071ebb5>] work_notifysig+0x30/0x3b
[<b7739e60>] 0xb7739e5f
---[ end trace b1e56095a485b631 ]---
The cause is that uvc_status_cleanup() is called after usb_put_*() in
uvc_delete(). usb_put_*() removes the sysfs parent and eventually
removes the children recursively, so the later device_del() can't find
its sysfs. The fix is simply rearrange the call orders in
uvc_delete() so that the child is removed before the parent.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=897736
Reported-and-tested-by: Martin Pluskal <mpluskal@suse.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 5d1f00a20d2d56ed480e64e938a2391353ee565b upstream.
Add a macro to simplify au0828 quirk table. That makes easier
to check it against the USB IDs at drivers/media/usb/au0828/au0828-cards.c.
commit f85698cd296f08218a7750f321e94607da128600 upstream.
The mutex does not serialise anything in this case but avoids a lockdep
warning from the control framework.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 2279948735609d0d17d7384e776b674619f792ef upstream.
This patches fixes an ancient bug in the dvb_usb_af9005 driver, which
has been reported at least in the following threads:
https://lkml.org/lkml/2009/2/4/350
https://lkml.org/lkml/2014/9/18/558
If the driver is compiled in without any IR support (neither
DVB_USB_AF9005_REMOTE nor custom symbols), the symbol_request calls in
af9005_usb_module_init() return pointers != NULL although the IR
symbols are not available.
This leads to the following oops:
[ 8.529751] usbcore: registered new interface driver dvb_usb_af9005
[ 8.531584] BUG: unable to handle kernel paging request at 02e00000
[ 8.533385] IP: [<7d9d67c6>] af9005_usb_module_init+0x6b/0x9d
[ 8.535613] *pde = 00000000
[ 8.536416] Oops: 0000 [#1] PREEMPT PREEMPT DEBUG_PAGEALLOCDEBUG_PAGEALLOC
[ 8.537863] CPU: 0 PID: 1 Comm: swapper Not tainted 3.15.0-rc6-00151-ga5c075c #1
[ 8.539827] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 8.541519] task: 89c9a670 ti: 89c9c000 task.ti: 89c9c000
[ 8.541519] EIP: 0060:[<7d9d67c6>] EFLAGS: 00010206 CPU: 0
[ 8.541519] EIP is at af9005_usb_module_init+0x6b/0x9d
[ 8.541519] EAX: 02e00000 EBX: 00000000 ECX: 00000006 EDX: 00000000
[ 8.541519] ESI: 00000000 EDI: 7da33ec8 EBP: 89c9df30 ESP: 89c9df2c
[ 8.541519] DS: 007b ES: 007b FS: 0000 GS: 00e0 SS: 0068
[ 8.541519] CR0: 8005003b CR2: 02e00000 CR3: 05a54000 CR4: 00000690
[ 8.541519] Stack:
[ 8.541519] 7d9d675b 89c9df90 7d992a49 7d7d5914 89c9df4c 7be3a800 7d08c58c 8a4c3968
[ 8.541519] 89c9df80 7be3a966 00000192 00000006 00000006 7d7d3ff4 8a4c397a 00000200
[ 8.541519] 7d6b1280 8a4c3979 00000006 000009a6 7da32db8 b13eec81 00000006 000009a6
[ 8.541519] Call Trace:
[ 8.541519] [<7d9d675b>] ? ttusb2_driver_init+0x16/0x16
[ 8.541519] [<7d992a49>] do_one_initcall+0x77/0x106
[ 8.541519] [<7be3a800>] ? parameqn+0x2/0x35
[ 8.541519] [<7be3a966>] ? parse_args+0x113/0x25c
[ 8.541519] [<7d992bc2>] kernel_init_freeable+0xea/0x167
[ 8.541519] [<7cf01070>] kernel_init+0x8/0xb8
[ 8.541519] [<7cf27ec0>] ret_from_kernel_thread+0x20/0x30
[ 8.541519] [<7cf01068>] ? rest_init+0x10c/0x10c
[ 8.541519] Code: 08 c2 c7 05 44 ed f9 7d 00 00 e0 02 c7 05 40 ed f9 7d 00 00 e0 02 c7 05 3c ed f9 7d 00 00 e0 02 75 1f b8 00 00 e0 02 85 c0 74 16 <a1> 00 00 e0 02 c7 05 54 84 8e 7d 00 00 e0 02 a3 58 84 8e 7d eb
[ 8.541519] EIP: [<7d9d67c6>] af9005_usb_module_init+0x6b/0x9d SS:ESP 0068:89c9df2c
[ 8.541519] CR2: 0000000002e00000
[ 8.541519] ---[ end trace 768b6faf51370fc7 ]---
The prefered fix would be to convert the whole IR code to use the kernel IR
infrastructure (which wasn't available at the time this driver had been created).
Until anyone who still has this old hardware steps up an does the conversion,
fix it by not calling the symbol_request calls if the driver is compiled in
without the default IR symbols (CONFIG_DVB_USB_AF9005_REMOTE).
Due to the IR related pointers beeing NULL by default, IR support will then be disabled.
The downside of this solution is, that it will no longer be possible to
compile custom IR symbols (not using CONFIG_DVB_USB_AF9005_REMOTE) in.
Please note that this patch has NOT been tested with all possible cases.
I don't have the hardware and could only verify that it fixes the reported
bug.
Reported-by: Fengguag Wu <fengguang.wu@intel.com>
Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com>
Acked-by: Luca Olivetti <luca@ventoso.org>
commit bc47150ab93988714d1fab7bc82fe5f505a107ad upstream.
The PLL flags were not used correctly.
commit 92b004d1aa9f367c372511ca0330f58216b25703 upstream.
If the probe of an fb driver has been deferred due to missing
dependencies, and the probe is later ran when a module is loaded, the
fbdev framework will try to find a logo to use.
However, the logos are __initdata, and have already been freed. This
causes sometimes page faults, if the logo memory is not mapped,
sometimes other random crashes as the logo data is invalid, and
sometimes nothing, if the fbdev decides to reject the logo (e.g. the
random value depicting the logo's height is too big).
This patch adds a late_initcall function to mark the logos as freed. In
reality the logos are freed later, and fbdev probe may be ran between
this late_initcall and the freeing of the logos. In that case we will
miss drawing the logo, even if it would be possible.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit 7ce67a38f799d1fb332f672b117efbadedaa5352 upstream.
The CPSW IP implements pulse-signaled interrupts. Due to
that we must write a correct, pre-defined value to the
CPDMA_MACEOIVECTOR register so the controller generates
a pulse on the correct IRQ line to signal the End Of
Interrupt.
The way the driver is written today, all four IRQ lines
are requested using the same IRQ handler and, because of
that, we could fall into situations where a TX IRQ fires
but we tell the controller that we ended an RX IRQ (or
vice-versa). This situation triggers an IRQ storm on the
reserved IRQ 127 of INTC which will in turn call ack_bad_irq()
which will, then, print a ton of:
unexpected IRQ trap at vector 00
In order to fix the problem, we are moving all calls to
cpdma_ctlr_eoi() inside the IRQ handler and making sure
we *always* write the correct value to the CPDMA_MACEOIVECTOR
register. Note that the algorithm assumes that IRQ numbers and
value-to-be-written-to-EOI are proportional, meaning that a
write of value 0 would trigger an EOI pulse for the RX_THRESHOLD
Interrupt and that's the IRQ number sitting in the 0-th index
of our irqs_table array.
This, however, is safe at least for current implementations of
CPSW so we will refrain from making the check smarter (and, as
a side-effect, slower) until we actually have a platform where
IRQ lines are swapped.
This patch has been tested for several days with AM335x- and
AM437x-based platforms. AM57x was left out because there are
still pending patches to enable ethernet in mainline for that
platform. A read of the TRM confirms the statement on previous
paragraph.
Reported-by: Yegor Yefremov <yegorslists@googlemail.com>
Fixes: 510a1e7 (drivers: net: davinci_cpdma: acknowledge interrupt properly)
commit e86fb5e8ab95f10ec5f2e9430119d5d35020c951 upstream.
When ring buffer returns an error indicating retry, storvsc may not
return a proper error code to SCSI when bounce buffer is not used.
This has introduced I/O freeze on RAID running atop storvsc devices.
This patch fixes it by always returning a proper error code.
Signed-off-by: Long Li <longli@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
commit 10cdfe54dab034311c8e2fad9ba2dffbe616caa9 upstream.
As __clk_release could call kfree on clk and then we wouldn't have a safe way
of getting the module that owns the clock.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Fixes: fcb0ee6a3d33 ("clk: Implement clk_unregister")
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
commit c31844ffdbd4e73a16c66e9d7df8ec290ab4b159 upstream.
During driver unbind the syscore ops were not unregistered which lead to
double add on syscore list:
$ echo "3810000.audss-clock-controller" > /sys/bus/platform/drivers/exynos-audss-clk/unbind
$ echo "3810000.audss-clock-controller" > /sys/bus/platform/drivers/exynos-audss-clk/bind
[ 1463.044061] ------------[ cut here ]------------
[ 1463.047255] WARNING: CPU: 0 PID: 1 at lib/list_debug.c:36 __list_add+0x8c/0xc0()
[ 1463.054613] list_add double add: new=c06e52c0, prev=c06e52c0, next=c06d5f84.
[ 1463.061625] Modules linked in:
[ 1463.064623] CPU: 0 PID: 1 Comm: bash Tainted: G W 3.18.0-rc5-next-20141121-00005-ga8fab06eab42-dirty #1022
[ 1463.075338] [<c0014e2c>] (unwind_backtrace) from [<c0011d80>] (show_stack+0x10/0x14)
[ 1463.083046] [<c0011d80>] (show_stack) from [<c048bb70>] (dump_stack+0x70/0xbc)
[ 1463.090236] [<c048bb70>] (dump_stack) from [<c00233d4>] (warn_slowpath_common+0x74/0xb0)
[ 1463.098295] [<c00233d4>] (warn_slowpath_common) from [<c00234a4>] (warn_slowpath_fmt+0x30/0x40)
[ 1463.106962] [<c00234a4>] (warn_slowpath_fmt) from [<c020fe80>] (__list_add+0x8c/0xc0)
[ 1463.114760] [<c020fe80>] (__list_add) from [<c0282094>] (register_syscore_ops+0x30/0x3c)
[ 1463.122819] [<c0282094>] (register_syscore_ops) from [<c0392f20>] (exynos_audss_clk_probe+0x36c/0x460)
[ 1463.132091] [<c0392f20>] (exynos_audss_clk_probe) from [<c0283084>] (platform_drv_probe+0x48/0xa4)
[ 1463.141013] [<c0283084>] (platform_drv_probe) from [<c0281a14>] (driver_probe_device+0x13c/0x37c)
[ 1463.149852] [<c0281a14>] (driver_probe_device) from [<c0280560>] (bind_store+0x90/0xe0)
[ 1463.157822] [<c0280560>] (bind_store) from [<c027fd10>] (drv_attr_store+0x20/0x2c)
[ 1463.165363] [<c027fd10>] (drv_attr_store) from [<c0143898>] (sysfs_kf_write+0x4c/0x50)
[ 1463.173252] [<c0143898>] (sysfs_kf_write) from [<c0142c80>] (kernfs_fop_write+0xbc/0x198)
[ 1463.181395] [<c0142c80>] (kernfs_fop_write) from [<c00e2be0>] (vfs_write+0xa0/0x1a8)
[ 1463.189104] [<c00e2be0>] (vfs_write) from [<c00e2f00>] (SyS_write+0x40/0x8c)
[ 1463.196122] [<c00e2f00>] (SyS_write) from [<c000f2a0>] (ret_fast_syscall+0x0/0x48)
[ 1463.203655] ---[ end trace 08f6710c9bc8d8f3 ]---
[ 1463.208244] exynos-audss-clk 3810000.audss-clock-controller: setup completed
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 1241ef94ccc3 ("clk: samsung: register audio subsystem clocks using common clock framework")
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
commit 198a956a11b15b564ac06d1411881e215b587408 upstream.
The Microsoft iSCSI target does not support REPORT SUPPORTED OPERATION
CODES. Blacklist these devices so we don't attempt to send the command.
Tested-by: Mike Christie <michaelc@cs.wisc.edu>
Reported-by: jazz@deti74.ru
commit 2311ce4d9c91ed63a46e18f0378f3e406e7e888e upstream.
This reverts commit 963ba22b90a955363644cd397b20226928eab976
("mpt3sas: Remove phys on topology change")
Reverting the previous mpt3sas drives patch changes,
since we will observe below issue
Issue:
Drives connected Enclosure/Expander will unregister with
SCSI Transport Layer, if any one remove and add expander
cable with in DMD (Device Missing Delay) time period or
even any one power-off and power-on the Enclosure with in
the DMD period.
Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@avagotech.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
commit 81a89c2d891b78695aa7e4cc0d5a7427785ae078 upstream.
This reverts commit 3520f9c779bed098ca76dd3fb6377264301d57ed
("mpt2sas: Remove phys on topology change")
Reverting the previous mpt2sas drives patch changes,
Issue:
the DMD period.
commit 6bf6ca7515c1df06f5c03737537f5e0eb191e29e upstream.
This patch changes iscsit_do_tx_data() to fail on short writes
when kernel_sendmsg() returns a value different than requested
transfer length, returning -EPIPE and thus causing a connection
reset to occur.
This avoids a potential bug in the original code where a short
write would result in kernel_sendmsg() being called again with
the original iovec base + length.
In practice this has not been an issue because iscsit_do_tx_data()
is only used for transferring 48 byte headers + 4 byte digests,
along with seldom used control payloads from NOPIN + TEXT_RSP +
REJECT with less than 32k of data.
So following Al's audit of iovec consumers, go ahead and fail
the connection on short writes for now, and remove the bogus
logic ahead of his proper upstream fix.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
commit a5fd9733a30d18d7ac23f17080e7e07bb3205b69 upstream.
commit 4dbd27711cd9 "tick: export nohz tick idle symbols for module
use" was merged via the thermal tree without an explicit ack from the
relevant maintainers.
The exports are abused by the intel powerclamp driver which implements
a fake idle state from a sched FIFO task. This causes all kinds of
wreckage in the NOHZ core code which rightfully assumes that
tick_nohz_idle_enter/exit() are only called from the idle task itself.
Recent changes in the NOHZ core lead to a failure of the powerclamp
driver and now people try to hack completely broken and backwards
workarounds into the NOHZ core code. This is completely unacceptable
and just papers over the real problem. There are way more subtle
issues lurking around the corner.
The real solution is to fix the powerclamp driver by rewriting it with
a sane concept, but that's beyond the scope of this.
So the only solution for now is to remove the calls into the core NOHZ
code from the powerclamp trainwreck along with the exports.
Fixes: d6d71ee4a14a "PM: Introduce Intel PowerClamp Driver"
Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Frederic Weisbecker <frederic@kernel.org>
Cc: Pan Jacob jun <jacob.jun.pan@intel.com>
Cc: LKP <lkp@01.org>
Cc: Zhang Rui <rui.zhang@intel.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1412181110110.17382@nanos
commit 6583659e0f92e38079a8dd081e0a1181a0f37747 upstream.
HP ZBook 15 laptop needs a non-standard mapping (x_inverted).
BugLink: http://bugzilla.opensuse.org/show_bug.cgi?id=905329
Signed-off-by: Dominique Leuenberger <dimstar@opensuse.org>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit add284a3a2481e759d6bec35f6444c32c8ddc383 upstream.
In order to act as a full command barrier by itself, we need to tell the
pipecontrol to actually stall the command streamer while the flush runs.
We require the full command barrier before operations like
MI_SET_CONTEXT, which currently rely on a prior invalidate flush.
References: https://bugs.freedesktop.org/show_bug.cgi?id=83677
Cc: Simon Farnsworth <simon@farnz.org.uk>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 148b83d0815a3778c8949e6a97cb798cbaa0efb3 upstream.
In the gen7 pipe control there is an extra bit to flush the media
caches, so let's set it during cache invalidation flushes.
v2: Rename to MEDIA_STATE_CLEAR to be more inline with spec.
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 4761703bd04bbdf56396d264903cc5a1fdcb3c01 upstream.
Several users have, over time, reported issues with MSI on these IGPs.
They're old, rarely available, and MSI doesn't provide such huge
advantages on them. Just disable.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=87361
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=74492
Fixes: fa8c9ac72fe ("drm/nv4c/mc: nv4x igp's have a different msi rearm register")
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
