Fix the following build issue introduced by commit
5cfcbc23d116927a7ae8d5b67baeacf2905b21f9 if neither
CONFIG_MACH_APALIS_T30 nor CONFIG_MACH_COLIBRI_T30 is defined as in
case of e.g. the Colibri T20:
drivers/mmc/host/sdhci-tegra.c:951:2:
error: expected expression before '.' token
The Dell 5800 appears to be a simple rebrand of the Novatel E362.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Cc: stable <stable@vger.kernel.org>
This device is also known as the Verizon USB551L.
Signed-off-by: Forest Bond <forest.bond@rapidrollout.com>
Acked-by: Dan Williams <dcbw@redhat.com>
SDR12, SDR25, SDR50, SDR104 and DDR50 all require 1.8V signalling which
our current T30 designs can't do. Newer cards will fail as follows:
Kingston 32GB microSDHC class 10
[ 69.000280] mmc1: error -84 whilst initialising SD card
SanDisk Mobile Ultra 8GB microSDHC I
[ 28.289174] mmc1: error -110 whilst initialising SD card
This patch activates a quirk which signals our lack of 1.8V support.
The OLPC XO-1.75 laptop includes a SDHCI controller which is 1.8v
capable, and it truthfully reports so in its capabilities. This
alternate voltage is used for driving new "UHS-I" SD cards at their
full speed.
However, what the controller doesn't know is that the motherboard
physically doesn't have a 1.8v supply available.
Add a quirk so that systems such as this one can override disable
1.8v support, adding support for UHS-I cards (by running them at
3.3v).
This avoids a problem where the system would first try to run the
card at 1.8v, fail, and then not be able to fully reset the card
to retry at the normal 3.3v voltage.
This is more appropriate than using the MISSING_CAPS quirk, which
is intended for cases where the SDHCI controller is actually lying
about its capabilities, and would force us to somehow override both
caps words from another source.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Reviewed-by: Philip Rakity <prakity@nvidia.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Turns out after suspend an unbind and bind operation is executed upon
which we subsequently gave out the 2nd custom user MAC address followed
by the default ASIX MAC address.
This patch fixes it by checking for the custom user MAC address upon
unbinding and in this case properly releasing it for subsequent reuse.
resolution for PAL/NTSC.
For Android use ICS variant of Fusion 7 and 10 multi-touch driver (See
Fusion 7 and 10 drivers for Linux.pdf and Linux Drivers Fusion 10.zip).
Tested to be working both with Android 4.0.4 for Colibri T20 as well as
Android 4.2.1 for Colibri T30.
This involved adding some callback methods, and pretending that this is a
YUV sensor.
Signed-off-by: Andrew Chew <achew@nvidia.com>
The Android idc parser seems to have an issue with spaces in names:
D/EventHub( 159): No input device configuration file found for device
'wm97xx touchscreen'.
Rename the driver in order for the idc parser to recognise idc file
/system/usr/idc/wm97xx-ts.idc being a simple copy of the qwerty.idc
one.
Rotate touch for now due to missing resistive touch calibration
integration. This makes our 5.7 inch EDT ET057090DHU panel usable.
Integrate CAN support for the Colibri Evaluation Board V3.1a with built-in
MCP2515 SPI CAN controller resp. the Colibri Evaluation Board V2.1c with its
built-in SJA1000 CAN controller connected to the GMI bus.
The following kernel configuration needs to be enabled as well:
CONFIG_CAN
CONFIG_CAN_RAW
CONFIG_CAN_BCM
CONFIG_CAN_DEV
Plus depending on the Evaluation Board revision:
CONFIG_CAN_MCP251X
or
CONFIG_CAN_SJA1000
CONFIG_CAN_SJA1000_PLATFORM
Optional support for 32-bit GMI as well as xPOD CAN on MECS Tellurium for
Colibri T20 is provided via commented defines in
arch/arm/mach-tegra/board-colibri_t20.h.
The VI client within drivers/video/tegra is mutually exclusive with the
Tegra V4L2 framework, since they both want to own the camera hardware.
set some platform_data.
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
integration. This makes our 7 inch EDT ET070080DH6 panel usable.
This patch adds the multi-touch input driver for the TouchRevolution
Fusion 7 and 10 panels (See Fusion 7 and 10 drivers for Linux.pdf and
set is_int_enable to true only if we register for a irq.
Bug 1211260
Change-Id: I603efe721796db70d504da7999e5d7939d45d13a
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/193047
(cherry picked from commit 8b89b2b64c67d80fcfc29cd4f6a92d4527e70df9)
Reviewed-on: http://git-master/r/195844
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
The following commit actually missed adding the new files:
7925180aee227f3de7af4a8cbad1c4b203a9132e
Springville with a blank Flash uses a different PCI ID. Hack the driver
to load despite i210 data sheet claiming tools only, not for driver.
Hack the driver to skip NVM validation on Apalis T30 for now.
Hack the driver to use a hard-code MAC address on Apalis T30 for now.
The following two functions seem to be obsolete therefore commented
resp. ifdefed out for now:
port_idle_status tegra_ahci_is_port_slumber()
tegra_ahci_are_all_ports_slumber()
This patch adds new initialization functions and device support
for i210 and i211 devices.
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
82580 and later parts did not have low power setting functions. This patch
adds the specific functions, pointers and assignments for these low
power settings.
Changing the condition for vbus check. VBUS will be
present when OTG cable is connected, hence vbus
status will be reflected wrong. Correct status
is tracked through vbus_active variable.
Bug 1158853
Bug 1214802
Change-Id: Ic904beb5919ddafef5becf39ddac1767cdda79cd
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/145148
(cherry picked from commit 00777683b05af76f15daa0152fb014183a32fa28)
Reviewed-on: http://git-master/r/190673
Tested-by: Preetham Chandru <pchandru@nvidia.com>
Function pointer int (*queue_setup)() of struct vb2_ops in
include/media/videobuf2-core.h is not compatible with our function
call tegra_camera_videobuf_setup(). So building will generate warning
and it will cause alloc_ctxs[] with wrong value, then introduce
memory access oops later.
Bug 1215617
Change-Id: I5d49ccd611a9435a5ee3b21e344bc0b5464ba747
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/190036
Reviewed-by: Andrew Chew <achew@nvidia.com>
Use 1x1 as the minimum window size.
Bug 1193195
Change-Id: I42e13fec82bbc2dc37bde6416088f3ae49b304b7
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/173302
(cherry picked from commit 3f160560b48fdf501547b9fc1f7c5bf8bd5e32af)
Reviewed-on: http://git-master/r/190810
Reviewed-by: Eric Brower <ebrower@nvidia.com>
Tested-by: Eric Brower <ebrower@nvidia.com>
initialize SSID variable properly to ensure
no memory overrun.
Bug 1204024
Change-Id: I2485c13edcf6a0feeae3cd4b2e9e98910a771dd2
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/190684
Videobuf2-dma-nvmap driver using by Tegra v4l2 camera driver needs to
allocation memory from system memory with nvmap_alloc(). If we don't
enable config option CONFIG_NVMAP_ALLOW_SYSMEM, nvmap_alloc() will
fail and application stops working.
Bug 1215629
Change-Id: I40af697d8aee1a4981a9684953107dd070cc9bea
Reviewed-on: http://git-master/r/190037
do not allow scheduling hang thread after cleanup
is done.
Bug 1210849
Bug 1205910
Bug 1163014
Change-Id: Idc5f9fd6a3d210843f1168e57ceef107599d5789
Reviewed-on: http://git-master/r/189721
Reviewed-by: Allen Martin <amartin@nvidia.com>
In order to allow tighter integration with external thermal throttling
code add local temperature and remote critical shutdown temperature
hooks. Rename the existing hooks for clarity.
Add BERR counter functionality to MCP251x driver.
Signed-off-by: Mitja Spes <mitja@lxnav.com>
when platform device is unregistered, the call to platform_device_release()
will kfree the platform data. Hence do not free the platform data again.
Bug 1209618
Change-Id: Ied67f550223ec199da4bc8e38a12e7ee94c2d98a
Reviewed-on: http://git-master/r/187806
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
In order to allow integrating with external thermal throttling code add
a probe callback and remote over-temperature shutdown hooks.
In addition to the critical temperature alarm limit this chip features
a second alarm limit called remote over-temperature shutdown ROS with
a separate pin configurable as trigger output. Implement this feature
and add platform data to allow configuring respective pin as output.
Rather than using hard-coded register indices and offsets define and
use an enumeration thereof.
- Fix a bug in ahci-tegra.c when checking if SATA is on when resuming
- Add codes to support PM315 which uses LDO1 regulator for SATA rails
bug 1206518
Change-Id: Iaa910b1948fbcf5e45491977fd8ed0b313d2e0ae
Signed-off-by: Yen Lin <yelin@nvidia.com>
Reviewed-on: http://git-master/r/188441
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Peng Wu <pengw@nvidia.com>
Tested-by: Peng Wu <pengw@nvidia.com>
Fix manual rebase error
Change-Id: I3b2165488b11bddda271cecdc979341c130def9b
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/173554
Send change all vc's notification from HDMI hot-plug reader to
fbcon, so that the new selected mode can be applied on all the
vc's from vc1 to vc6. This sometimes causes corruption on HDMI
hot plugin, when fbcon is mapped to HDMI
Bug 1166008
Change-Id: Id173de3014597f79c8c8b31bbbee7c9c560547b6
Reviewed-on: http://git-master/r/168683
Tested-by: Matthew Pedro <mapedro@nvidia.com>
When porting change from mainline to balance dc irq, the change
of enable/disable order was not ported, thus dc irq is disabled
if dc is enabled during probe.
This is part of http://git-master/r/146107.
Original change is big for many bugs, only port one here.
bug 1173177
bug 1173038
bug 1008313
Change-Id: Idd703daca9f980e905b185eeeae19dc6309d76e5
Signed-off-by: Dongfang Shi <dshi@nvidia.com>
Reviewed-on: http://git-master/r/162868
(cherry picked from commit 6ddd8b02f7a17d2269290d06159c20860ffb92e9)
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/173249
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Unconditionally update line_length using disply width to avoid discrepancy
between line_length and actual display width.
bug 1186388
Change-Id: I8ef2f9cf76a61764c2121f3c2c013b72b830ce2e
Reviewed-on: http://git-master/r/170664
Based on ov5642 driver. There seem to be some register differences,
so forking the driver to make those changes.
Change-Id: Idb4a79757cbbcd15d5456ce82a708f433faaff7a
Reviewed-on: http://git-master/r/169836
Change-Id: Ic4d91f4ed70fc3daf52768118f6ea537d529a5a8
Reviewed-on: http://git-master/r/169835
Add this function, to be able to set the global field of an
nvmap_handle while preserving the nvmap API's encapsulation
mechanisms.
Change-Id: I62de773a65119722f059b114e2d0e906c7e04e83
Reviewed-on: http://git-master/r/169834
Add a companion function to nvhost_client_device_get_resources()
called nvhost_client_device_put_resources() that does the opposite
thing. This is useful for any nvhost clients that need to be loaded
as modules, since the driver removal path will be exercised in that
case.
Change-Id: Ib5cec6fce7b05c780b135b03fcd88e068f772244
Reviewed-on: http://git-master/r/169833
This is based off of videobuf2-dma-contig, except we use Tegra's
nvmap for the buffer allocations.
Change-Id: I15e689c33ee7b4fc0aade794c78701c82483df3f
Reviewed-on: http://git-master/r/145345
(cherry picked from commit 70a4f20fbdd6c2c719400d6c59ef58d845657031)
Change-Id: Ia0632d7fcb28415e33fbb22c48f29117d7436f1d
Reviewed-on: http://git-master/r/170824
