At chipidea revision 2.40a, there is a below errata:
9000531823 B2-Medium Adding a dTD to a Primed Endpoint May Not Get Recognized
Title: Adding a dTD to a Primed Endpoint May Not Get Recognized
Impacted Configuration: All device mode configurations.
Description:
There is an issue with the add dTD tripwire semaphore (ATDTW bit in USBCMD register)
that can cause the controller to ignore a dTD that is added to a primed endpoint.
When this happens, the software can read the tripwire bit and the status bit at '1'
even though the endpoint is unprimed.
After executing a dTD, the device controller endpoint state machine executes a final
read of the dTD terminate bit to check if the application added a dTD to the linked
list at the last moment. This read is done in the finpkt_read_latest_next_td (44) state.
After the read is performed, if the terminate bit is still set, the state machine moves
to unprime the endpoint. The decision to unprime the endpoint is done in the
checkqh_decision (59) state, based on the value of the terminate bit.
Before reaching the checkqh_decision state, the state machine traverses the
writeqhtd_status (57), writeqh_status (56), and release_prime_mask (42) states.
As shown in the waveform, the ep_addtd_tripwire_clr signal is not set to clear
the tripwire bit in these states.
Workaround:
The software must implement a periodic poll cycle, and check for each dTD
pending on execution (Active = 1), if the enpoint is primed. It can do this by reading
the corresponding bits in the ENDPTPRIME and ENDPTSTAT registers. If these bits are
read at 0, the software needs to re-prime the endpoint by writing 1 to the corresponding
bit in the ENDPTPRIME register. This can be done for every microframe, every frame or
with a larger interval, depending on the urgency of transfer execution for the application.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Define ci_get_revision API to know the controller revision
information according to chipidea 1.1a, 2.0a, 2.4 and 2.5a
spec. Besides, add one entry in struct ci_hdrc to indicate
revision information. This can be used for adding different
code for revisions, implementing erratas.
Using hw_write_id_reg and hw_read_id_reg to write and read
identification registers contents. This can be used to get
controller information, change some system configurations
and so on.
This reverts commit 068ecdab500e551f313cd6b08dccc32c9d55e137.
Currently the Vybrid USB client does not work reliably
with usb gadget ethernet. This patch forces usage of
only a single transfer descriptor for the dTD list which
seems to work reliably well for now. Does not fix the
underlying issue and is only temporary.
The pixel clock polarity setting was still wrong: In contrast what
earlier mentioned, the reference manual is correct! But the kernel
display flags are rather somewhat confusing: The flags specify the
edge where the data should be driven by the controller (and hence not
sampled by the display!). We convert the display flag to the display
centric DCU notation when getting the videomode from device tree.
drivers/input/touchscreen/Makefile
Use level triggered interrupt which makes sure that even we miss a
rising edge (due to latencies in the kernel), the interrupt still
will be handled later, and doesn't freeze the input device.
Add device tree integration and add the device to the dtb.
i2c device, interrupt and reset GPIO can be specified in the dts as follows:
Note that additionally you may have to set the pinmuxing for the pins to
be GPIO.
&i2c1 {
status = "okay";
pcap@10 {
/* TouchRevolution Fusion 7 and 10 multi-touch controller */
compatible = "touchrevolution,fusion-f0710a";
reg = <0x10>;
gpios = <&gpio6 10 0 /* MXM-11, Pen down interrupt */
&gpio6 9 0 /* MXM-13, Reset interrupt */
Use platform independent description for requested GPIOs.
(cherry picked from commit c300f3a605f8984449c1a5324fd3edda6f2fd8ff)
Fix chip reset by sleeping long enought after reset. Do proper error
handling (free GPIO on failure). Use dev_* for message logging to get
similar messages for all fusion driver related errors and warnings.
(cherry picked from commit 63b293000723e61a880470f093fbe82e86ebd81b)
To avoid warnings use the new I2C power management function for
suspend and resume.
(cherry picked from commit 9d996316a470d37fb71c521f27106b014f3f0b23)
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
(cherry picked from commit cb82730b70f31af3b43041ac4e47de69c18016c9)
When the next interrupt request apeares between the confirmation of
the previous (a write via I2C, fusion_F0710A_write_complete) and
the reenable of the GPIO interrupt, the driver hangs and no more
touch inputs are reported.
This patch moves the confirmation after the reenabling of the GPIO
interrupt.
(cherry picked from commit e95019a4f20b8cdfbe03658e4f73b69cdcf97540)
Recent evdev X-Server input driver implementation complain when
only multitouch axes have been reported ("found only multitouch-axes.
That shouldn't happen."). Therefor also report the primary touch
detection with default axis.
(cherry picked from commit dda7a631ac901e4d140e8a6612c5c6b5506b6a91)
This patch adds the multi-touch input driver for the TouchRevolution
Fusion 7 and 10 panels (See Fusion 7 and 10 drivers for Linux.pdf and
Linux Drivers Fusion 10.zip) as downloaded in 07.2014
Linux 3.18
arch/arm/boot/dts/vf500.dtsi
arch/arm/boot/dts/vfxxx.dtsi
arch/arm/configs/imx_v6_v7_defconfig
In order to allow wake support in STOP sleep mode, clocks are
needed. Use imx_clk_gate2_cgr to disable automatic clock gating
in low power mode STOP. This allows to enable wake by UART using:
echo enabled > /sys/class/tty/ttyLP0/power/wakeup
However, if wake is not enabled, the driver should disable the
clocks explicitly to save power.
When entering suspend while the device is in runtime PM, the
sdhci_[suspend|resume]_host function are called without taking
care of runtime PM. On the Vybrid SoC, this leads to external
abort because during runtime suspend, the clocks required for
bus access are disabled.
[ 37.772967] Unhandled fault: imprecise external abort (0x1c06) at 0x76f5f000
[ 37.780304] Internal error: : 1c06 [#1] ARM
[ 37.784670] Modules linked in:
[ 37.787908] CPU: 0 PID: 428 Comm: sh Not tainted 3.18.0-rc5-00119-geefd097-dirty #1540
[ 37.796142] task: 8e246c00 ti: 8ca6c000 task.ti: 8ca6c000
[ 37.801785] PC is at esdhc_writel_le+0x40/0xec
[ 37.806431] LR is at sdhci_set_card_detection+0xe0/0xe4
[ 37.811877] pc : [<803f0584>] lr : [<803eaaa0>] psr: 400f0013
[ 37.811877] sp : 8ca6dd28 ip : 00000001 fp : 8ca6dd3c
[ 37.823766] r10: 807a233c r9 : 00000000 r8 : 8e8b7210
[ 37.829194] r7 : 802d8a08 r6 : 8082e928 r5 : 00000000 r4 : 00000002
[ 37.835974] r3 : 8ea34e90 r2 : 00000038 r1 : 00000000 r0 : 8ea32ac0
The alarm interrupt handler also reads registers which are part of SNVS and
need clocks enabled. However, the resume function is called after IRQ's
have been enabled, hence this leads to a abort:
[ 90.755222] Unhandled fault: external abort on non-linefetch (0x1008)
at 0x908c604c
[ 90.762892] Internal error: : 1008 [#1] ARM
[ 90.767082] Modules linked in:
[ 90.770174] CPU: 0 PID: 421 Comm: sh Not tainted 3.18.0-rc5-00135-g0689c67-dirty #1592
[ 90.778100] task: 8e03e800 ti: 8cad8000 task.ti: 8cad8000
[ 90.783530] PC is at snvs_rtc_irq_handler+0x14/0x74
[ 90.788424] LR is at handle_irq_event_percpu+0x3c/0x144
Fix this by using the .{suspend/resume}_noirq callbacks instead of
.{suspend/resume} .
Add suspend and resume support which disables the panel completely.
Tested with the main frame buffer instance (fb0).
Allow bit flips in a empty page up to half of the recoverable
bits (strength / 2). Some flash show bit flips in empty pages
which are larger then the corrected bit count according to the
ECC controller. It is not yet clear how to solve this correctly,
discussion is ongoing:
http://thread.gmane.org/gmane.linux.ports.arm.kernel/295424
Since we habe a 24-bit correction, this allows up to 12 bit
flips on a empty page before reporting it as page with ECC
errors.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"Three libata fixes for v3.18. Nothing too interesting. PCI ID ID and
quirk additions to ahci and an error handling path fix in sata_fsl"
* 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ahci: disable MSI on SAMSUNG 0xa800 SSD
sata_fsl: fix error handling of irq_of_parse_and_map
AHCI: Add DeviceIDs for Sunrise Point-LP SATA controller
Pull watchdog fix from Wim Van Sebroeck:
"Fix the watchdog mask bit offset for Exynos7"
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: s3c2410_wdt: Fix the mask bit offset for Exynos7
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Here are two more driver bugfixes for I2C which would be good to have"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: cadence: Set the hardware time-out register to maximum value
i2c: davinci: generate STP always when NACK is received
The watchdog mask bit offset listed for Exynos7 is incorrect.
Fix this.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Acked-by: Naveen Krishna Chatradhi <naveenkrishna.ch@gmail.com
Reviewd-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Pull drm intel fixes from Dave Airlie:
"Two intel stable fixes, that should be it from me for this round"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/i915: Unlock panel even when LVDS is disabled
drm/i915: More cautious with pch fifo underruns
Pull ACPI backlight fix from Rafael Wysocki:
"This is a simple fix for an ACPI backlight regression introduced by a
recent commit that overlooked a corner case which should have been
taken into account"
* tag 'pm+acpi-3.18-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / video: update condition to check if device is in _DOD list
git://anongit.freedesktop.org/drm-intel into drm-fixes
Silence some pch fifo underrun reports and panel locking backtraces,
both cc: stable.
* tag 'drm-intel-fixes-2014-12-04' of git://anongit.freedesktop.org/drm-intel:
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"A core fix and some driver fixes:
- regression fix in Remote Controller core affecting RC6 protocol
handling
- fix video buffer handling in cx23885
- race fix in solo6x10
- fix image selection in smiapp
- fix reported payload size on s2255drv
- two updates for MAINTAINERS file"
* tag 'media/v3.18-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] rc-core: fix toggle handling in the rc6 decoder
MAINTAINERS: Update mchehab's addresses
[media] cx23885: use sg = sg_next(sg) instead of sg++
[media] s2255drv: fix payload size for JPG, MJPEG
[media] Update MAINTAINERS for solo6x10
[media] solo6x10: fix a race in IRQ handler
[media] smiapp: Only some selection targets are settable
Cadence I2C controller has bug wherein it generates invalid read transactions
after timeout in master receiver mode. This driver does not use the HW
timeout and this interrupt is disabled but the feature itself cannot be
disabled. Hence, this patch writes the maximum value (0xFF) to this register.
This is one of the workarounds to this bug and it will not avoid the issue
completely but reduces the chances of error.
Signed-off-by: Vishnu Motghare <vishnum@xilinx.com>
Signed-off-by: Harini Katakam <harinik@xilinx.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: stable@kernel.org
According to I2C specification the NACK should be handled as follows:
"When SDA remains HIGH during this ninth clock pulse, this is defined as the Not
Acknowledge signal. The master can then generate either a STOP condition to
abort the transfer, or a repeated START condition to start a new transfer."
[I2C spec Rev. 6, 3.1.6: http://www.nxp.com/documents/user_manual/UM10204.pdf]
Currently the Davinci i2c driver interrupts the transfer on receipt of a
NACK but fails to send a STOP in some situations and so makes the bus
stuck until next I2C IP reset (idle/enable).
For example, the issue will happen during SMBus read transfer which
consists from two i2c messages write command/address and read data:
S Slave Address Wr A Command Code A Sr Slave Address Rd A D1..Dn A P
<--- write -----------------------> <--- read --------------------->
The I2C client device will send NACK if it can't recognize "Command Code"
and it's expected from I2C master to generate STP in this case.
But now, Davinci i2C driver will just exit with -EREMOTEIO and STP will
not be generated.
Hence, fix it by generating Stop condition (STP) always when NACK is received.
This patch fixes Davinci I2C in the same way it was done for OMAP I2C
commit cda2109a26eb ("i2c: omap: query STP always when NACK is received").
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Reported-by: Hein Tibosch <hein_tibosch@yahoo.es>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Just like 0x1600 which got blacklisted by 66a7cbc303f4 ("ahci: disable
MSI instead of NCQ on Samsung pci-e SSDs on macbooks"), 0xa800 chokes
on NCQ commands if MSI is enabled. Disable MSI.
Reported-by: Dominik Mierzejewski <dominik@greysector.net>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=89171
Cc: stable@vger.kernel.org
Pull i2c bugfixes from Wolfram Sang:
"A few driver bugfixes for 3.18"
i2c: omap: fix i207 errata handling
i2c: designware: prevent early stop on TX FIFO empty
i2c: omap: fix NACK and Arbitration Lost irq handling
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fix from Bjorn Helgaas:
"This fixes a Tegra20 regression that we introduced during the v3.18
merge window"
* tag 'pci-v3.18-fixes-4' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: tegra: Use physical range for I/O mapping
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux
Pull devicetree bugfix from Grant Likely:
"One more bug fix for v3.18. I debated whether or not to send you this
merge request because we're at such a late rc. The bug isn't critical
in that there is only one system known to be affected and the patch is
easy to backport. The codepath is used by pretty much every DT based
system, so there is risk a of regression (it /should/ be safe, but
I've been bitten by stuff that should be safe before). I've had it in
linux-next for a week and haven't received any complaints.
I think it probably should just be merged right away rather than
waiting for the merge window and backporting. It does fix a real bug
and the code is theoretically safer after the change. I can't think
of any situation where it would be dangerous to reserve the DT memory
an extra time.
Summary from tag:
Single bugfix for boot failure seen in the wild. The memory reserve
code tries to be clever about reserving the FDT, but it should just
go ahead and reserve it unconditionally to avoid the problem of
partial overlap described in the patch"
* tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux:
of/fdt: memblock_reserve /memreserve/ regions in the case of partial overlap
Pull drm fixes from Dave Airlie:
"Radeon and Nouveau fixes:
So nouveau had a few regression introduced, Ben and Maarten finally
tracked down the one that was causing problems on my MacBookPro, also
nvidia gave some info on the an engine we were using incorrectly, so
disable our use of it, and one regresion with pci hotplug affecting
optimus users.
Radeon has an oops fixs, sync fix, and one workaround to avoid broken
functionality on 32-bit x86, this needs better root causing and a
better fix, but the bandaid is a lot safer at this point"
drm/radeon: kernel panic in drm_calc_vbltimestamp_from_scanoutpos with 3.18.0-rc6
drm/radeon: Ignore RADEON_GEM_GTT_WC on 32-bit x86
drm/radeon: sync all BOs involved in a CS v2
nouveau: move the hotplug ignore to correct place.
drm/nouveau/gf116: remove copy1 engine
drm/nouveau: prevent stale fence->channel pointers, and protect with rcu
drm/nouveau/fifo/g84-: ack non-stall interrupt before handling it
Pull networking fixes from David Miller:
1) Fill in ethtool link parameters for all link types in cxgb4, from
Hariprasad Shenai.
2) Fix probe regressions in stmmac driver, from Huacai Chen.
3) Network namespace leaks on errirs in rtnetlink, from Nicolas
Dichtel.
4) Remove erroneous BUG check which can actually trigger legitimately,
in xen-netfront. From Seth Forshee.
5) Validate length of IFLA_BOND_ARP_IP_TARGET netlink attributes, from
Thomas Grag.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
cxgb4: Fill in supported link mode for SFP modules
xen-netfront: Remove BUGs on paged skb data which crosses a page boundary
sh_eth: Fix sleeping function called from invalid context
stmmac: platform: Move plat_dat checking earlier
sh_eth: Fix skb alloc size and alignment adjust rule.
rtnetlink: release net refcnt on error in do_setlink()
bond: Check length of IFLA_BOND_ARP_IP_TARGET attributes
If kzalloc() failed and then evdev_open_device() fails, evdev_open()
will pass a vmalloc'ed pointer to kfree.
This might fix https://bugzilla.kernel.org/show_bug.cgi?id=88401, where
there was a crash in kfree().
Reported-by: Christian Casteyde <casteyde.christian@free.fr>
Belatedly-Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Henrik Rydberg <rydberg@euromail.se>
Cc: <stable@vger.kernel.org>
The Colibri Vybrid VF50 module supports 4-wire touchscreens using
FETs and ADC inputs. This driver uses the IIO consumer interface
and relies on the vf610_adc driver based on the IIO framework.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Fix defines for pixel clock and pixel data polarity. Configuring
pixel clock is now actually possible. On most display this needs
to be set, hence until now, some displays showed green or white
artefacts (e.g. EDT 5.7"). This is solved by this commit.
Move the register writes from probe into a controller init function.
In the resume function, we can make us of this function to reinitialize
the controller after resuming from deep sleep states where the
controller loses its state.
