[ Upstream commit 5b9f57516337b523f7466a53939aaaea7b78141b ]
Another rebranded Novatel E371. qmi_wwan should drive this device, while
cdc_ether should ignore it. Even though the USB descriptors are plain
CDC-ETHER that USB interface is a QMI interface. Ref commit 7fdb7846c9ca
("qmi_wwan/cdc_ether: add device IDs for Dell 5804 (Novatel E371) WWAN
card")
Cc: Dan Williams <dcbw@redhat.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 6a0b76c04ec157c88ca943debf78a8ee58469f2d ]
Runtime suspend shouldn't be executed if the tx queue is not empty,
because the device is not idle.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
[ Upstream commit cd33b3e0da43522ff8e8f2b2b71d3d08298512b0 ]
Commit a1cba5613edf ("net: phy: Add Broadcom phy library for common
interfaces") make the BCM63xx PHY driver utilize bcm_phy_config_intr()
which would appear to do the right thing, except that it does not write
to the MII_BCM63XX_IR register but to MII_BCM54XX_ECR which is
different.
This would be causing invalid link parameters and events from being
generated by the PHY interrupt.
Fixes: a1cba5613edf ("net: phy: Add Broadcom phy library for common interfaces")
Signed-off-by: Daniel Gonzalez Cabanelas <dgcbueu@gmail.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 8ec3e8a192ba6f13be4522ee81227c792c86fb1a ]
Due to alignment requirements of the hardware transmissions are split into
two DMA descriptors, a small padding descriptor of 0 - 3 bytes in length
followed by a descriptor for rest of the packet.
In the case of IP packets the first descriptor will never be zero due to
the way that the stack aligns buffers for IP packets. However, for non-IP
packets it may be zero.
In that case it has been reported that timeouts occur, presumably because
transmission stops at the first zero-length DMA descriptor and thus the
packet is not transmitted. However, in my environment a BUG is triggered as
follows:
[ 20.381417] ------------[ cut here ]------------
[ 20.386054] kernel BUG at lib/swiotlb.c:495!
[ 20.390324] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 20.395805] Modules linked in:
[ 20.398862] CPU: 0 PID: 2089 Comm: mz Not tainted 4.10.0-rc3-00001-gf13ad2db193f #162
[ 20.406689] Hardware name: Renesas Salvator-X board based on r8a7796 (DT)
[ 20.413474] task: ffff80063b1f1900 task.stack: ffff80063a71c000
[ 20.419404] PC is at swiotlb_tbl_map_single+0x178/0x2ec
[ 20.424625] LR is at map_single+0x4c/0x98
[ 20.428629] pc : [<ffff00000839c4c0>] lr : [<ffff00000839c680>] pstate: 800001c5
[ 20.436019] sp : ffff80063a71f9b0
[ 20.439327] x29: ffff80063a71f9b0 x28: ffff80063a20d500
[ 20.444636] x27: ffff000008ed5000 x26: 0000000000000000
[ 20.449944] x25: 000000067abe2adc x24: 0000000000000000
[ 20.455252] x23: 0000000000200000 x22: 0000000000000001
[ 20.460559] x21: 0000000000175ffe x20: ffff80063b2a0010
[ 20.465866] x19: 0000000000000000 x18: 0000ffffcae6fb20
[ 20.471173] x17: 0000ffffa09ba018 x16: ffff0000087c8b70
[ 20.476480] x15: 0000ffffa084f588 x14: 0000ffffa09cfa14
[ 20.481787] x13: 0000ffffcae87ff0 x12: 000000000063abe2
[ 20.487098] x11: ffff000008096360 x10: ffff80063abe2adc
[ 20.492407] x9 : 0000000000000000 x8 : 0000000000000000
[ 20.497718] x7 : 0000000000000000 x6 : ffff000008ed50d0
[ 20.503028] x5 : 0000000000000000 x4 : 0000000000000001
[ 20.508338] x3 : 0000000000000000 x2 : 000000067abe2adc
[ 20.513648] x1 : 00000000bafff000 x0 : 0000000000000000
[ 20.518958]
[ 20.520446] Process mz (pid: 2089, stack limit = 0xffff80063a71c000)
[ 20.526798] Stack: (0xffff80063a71f9b0 to 0xffff80063a720000)
[ 20.532543] f9a0: ffff80063a71fa30 ffff00000839c680
[ 20.540374] f9c0: ffff80063b2a0010 ffff80063b2a0010 0000000000000001 0000000000000000
[ 20.548204] f9e0: 000000000000006e ffff80063b23c000 ffff80063b23c000 0000000000000000
[ 20.556034] fa00: ffff80063b23c000 ffff80063a20d500 000000013b1f1900 0000000000000000
[ 20.563864] fa20: ffff80063ffd18e0 ffff80063b2a0010 ffff80063a71fa60 ffff00000839cd10
[ 20.571694] fa40: ffff80063b2a0010 0000000000000000 ffff80063ffd18e0 000000067abe2adc
[ 20.579524] fa60: ffff80063a71fa90 ffff000008096380 ffff80063b2a0010 0000000000000000
[ 20.587353] fa80: 0000000000000000 0000000000000001 ffff80063a71fac0 ffff00000864f770
[ 20.595184] faa0: ffff80063b23caf0 0000000000000000 0000000000000000 0000000000000140
[ 20.603014] fac0: ffff80063a71fb60 ffff0000087e6498 ffff80063a20d500 ffff80063b23c000
[ 20.610843] fae0: 0000000000000000 ffff000008daeaf0 0000000000000000 ffff000008daeb00
[ 20.618673] fb00: ffff80063a71fc0c ffff000008da7000 ffff80063b23c090 ffff80063a44f000
[ 20.626503] fb20: 0000000000000000 ffff000008daeb00 ffff80063a71fc0c ffff000008da7000
[ 20.634333] fb40: ffff80063b23c090 0000000000000000 ffff800600000037 ffff0000087e63d8
[ 20.642163] fb60: ffff80063a71fbc0 ffff000008807510 ffff80063a692400 ffff80063a20d500
[ 20.649993] fb80: ffff80063a44f000 ffff80063b23c000 ffff80063a69249c 0000000000000000
[ 20.657823] fba0: 0000000000000000 ffff80063a087800 ffff80063b23c000 ffff80063a20d500
[ 20.665653] fbc0: ffff80063a71fc10 ffff0000087e67dc ffff80063a20d500 ffff80063a692400
[ 20.673483] fbe0: ffff80063b23c000 0000000000000000 ffff80063a44f000 ffff80063a69249c
[ 20.681312] fc00: ffff80063a5f1a10 000000103a087800 ffff80063a71fc70 ffff0000087e6b24
[ 20.689142] fc20: ffff80063a5f1a80 ffff80063a71fde8 000000000000000f 00000000000005ea
[ 20.696972] fc40: ffff80063a5f1a10 0000000000000000 000000000000000f ffff00000887fbd0
[ 20.704802] fc60: fffffff43a5f1a80 0000000000000000 ffff80063a71fc80 ffff000008880240
[ 20.712632] fc80: ffff80063a71fd90 ffff0000087c7a34 ffff80063afc7180 0000000000000000
[ 20.720462] fca0: 0000ffffcae6fe18 0000000000000014 0000000060000000 0000000000000015
[ 20.728292] fcc0: 0000000000000123 00000000000000ce ffff0000088d2000 ffff80063b1f1900
[ 20.736122] fce0: 0000000000008933 ffff000008e7cb80 ffff80063a71fd80 ffff0000087c50a4
[ 20.743951] fd00: 0000000000008933 ffff000008e7cb80 ffff000008e7cb80 000000100000000e
[ 20.751781] fd20: ffff80063a71fe4c 0000ffff00000300 0000000000000123 0000000000000000
[ 20.759611] fd40: 0000000000000000 ffff80063b1f0000 000000000000000e 0000000000000300
[ 20.767441] fd60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 20.775271] fd80: 0000000000000000 0000000000000000 ffff80063a71fda0 ffff0000087c8c20
[ 20.783100] fda0: 0000000000000000 ffff000008082f30 0000000000000000 0000800637260000
[ 20.790930] fdc0: ffffffffffffffff 0000ffffa0903078 0000000000000000 000000001ea87232
[ 20.798760] fde0: 000000000000000f ffff80063a71fe40 ffff800600000014 ffff000000000001
[ 20.806590] fe00: 0000000000000000 0000000000000000 ffff80063a71fde8 0000000000000000
[ 20.814420] fe20: 0000000000000000 0000000000000000 0000000000000000 0000000000000001
[ 20.822249] fe40: 0000000203000011 0000000000000000 0000000000000000 ffff80063a68aa00
[ 20.830079] fe60: ffff80063a68aa00 0000000000000003 0000000000008933 ffff0000081f1b9c
[ 20.837909] fe80: 0000000000000000 ffff000008082f30 0000000000000000 0000800637260000
[ 20.845739] fea0: ffffffffffffffff 0000ffffa07ca81c 0000000060000000 0000000000000015
[ 20.853569] fec0: 0000000000000003 000000001ea87232 000000000000000f 0000000000000000
[ 20.861399] fee0: 0000ffffcae6fe18 0000000000000014 0000000000000300 0000000000000000
[ 20.869228] ff00: 00000000000000ce 0000000000000000 00000000ffffffff 0000000000000000
[ 20.877059] ff20: 0000000000000002 0000ffffcae87ff0 0000ffffa09cfa14 0000ffffa084f588
[ 20.884888] ff40: 0000000000000000 0000ffffa09ba018 0000ffffcae6fb20 000000001ea87010
[ 20.892718] ff60: 0000ffffa09b9000 0000ffffcae6fe30 0000ffffcae6fe18 000000000000000f
[ 20.900548] ff80: 0000000000000003 000000001ea87232 0000000000000000 0000000000000000
[ 20.908378] ffa0: 0000000000000000 0000ffffcae6fdc0 0000ffffa09a7824 0000ffffcae6fdc0
[ 20.916208] ffc0: 0000ffffa0903078 0000000060000000 0000000000000003 00000000000000ce
[ 20.924038] ffe0: 0000000000000000 0000000000000000 ffffffffffffffff ffffffffffffffff
[ 20.931867] Call trace:
[ 20.934312] Exception stack(0xffff80063a71f7e0 to 0xffff80063a71f910)
[ 20.940750] f7e0: 0000000000000000 0001000000000000 ffff80063a71f9b0 ffff00000839c4c0
[ 20.948580] f800: ffff80063a71f840 ffff00000888a6e4 ffff80063a24c418 ffff80063a24c448
[ 20.956410] f820: 0000000000000000 ffff00000811cd54 ffff80063a71f860 ffff80063a24c458
[ 20.964240] f840: ffff80063a71f870 ffff00000888b258 ffff80063a24c418 0000000000000001
[ 20.972070] f860: ffff80063a71f910 ffff80063a7b7028 ffff80063a71f890 ffff0000088825e4
[ 20.979899] f880: 0000000000000000 00000000bafff000 000000067abe2adc 0000000000000000
[ 20.987729] f8a0: 0000000000000001 0000000000000000 ffff000008ed50d0 0000000000000000
[ 20.995560] f8c0: 0000000000000000 0000000000000000 ffff80063abe2adc ffff000008096360
[ 21.003390] f8e0: 000000000063abe2 0000ffffcae87ff0 0000ffffa09cfa14 0000ffffa084f588
[ 21.011219] f900: ffff0000087c8b70 0000ffffa09ba018
[ 21.016097] [<ffff00000839c4c0>] swiotlb_tbl_map_single+0x178/0x2ec
[ 21.022362] [<ffff00000839c680>] map_single+0x4c/0x98
[ 21.027411] [<ffff00000839cd10>] swiotlb_map_page+0xa4/0x138
[ 21.033072] [<ffff000008096380>] __swiotlb_map_page+0x20/0x7c
[ 21.038821] [<ffff00000864f770>] ravb_start_xmit+0x174/0x668
[ 21.044484] [<ffff0000087e6498>] dev_hard_start_xmit+0x8c/0x120
[ 21.050407] [<ffff000008807510>] sch_direct_xmit+0x108/0x1a0
[ 21.056064] [<ffff0000087e67dc>] __dev_queue_xmit+0x194/0x4cc
[ 21.061807] [<ffff0000087e6b24>] dev_queue_xmit+0x10/0x18
[ 21.067214] [<ffff000008880240>] packet_sendmsg+0xf40/0x1220
[ 21.072873] [<ffff0000087c7a34>] sock_sendmsg+0x18/0x2c
[ 21.078097] [<ffff0000087c8c20>] SyS_sendto+0xb0/0xf0
[ 21.083150] [<ffff000008082f30>] el0_svc_naked+0x24/0x28
[ 21.088462] Code: d34bfef7 2a1803f3 1a9f86d6 35fff878 (d4210000)
[ 21.094611] ---[ end trace 5bc544ad491f3814 ]---
[ 21.099234] Kernel panic - not syncing: Fatal exception in interrupt
[ 21.105587] Kernel Offset: disabled
[ 21.109073] Memory Limit: none
[ 21.112126] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
Fixes: 2f45d1902acf ("ravb: minimize TX data copying")
Signed-off-by: Masaru Nagai <masaru.nagai.vx@renesas.com
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 148d3d021cf9724fcf189ce4e525a094bbf5ce89 ]
The __bcm_sysport_tx_reclaim() function is used to reclaim transmit
resources in different places within the driver. Most of them should
not affect the state of the transit flow control.
Introduce bcm_sysport_tx_clean() which cleans the ring, but does not
re-enable flow control towards the networking stack, and make
bcm_sysport_tx_reclaim() do the actual transmit queue flow control.
Fixes: 80105befdb4b ("net: systemport: add Broadcom SYSTEMPORT Ethernet MAC driver")
[ Upstream commit 28e46a0f2e03ab4ed0e23cace1ea89a68c8c115b ]
The event_data starts from address 0x00-0x0C and not from 0x08-0x014. This
leads to duplication with other fields in the Event Queue Element such as
sub-type, cqn and owner.
Fixes: eda6500a987a0 ("mlxsw: Add PCI bus implementation")
Signed-off-by: Elad Raz <eladr@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 400fc0106dd8c27ed84781c929c1a184785b9c79 ]
During transmission the skb is checked for headroom in order to
add vendor specific header. In case the skb needs to be re-allocated,
skb_realloc_headroom() is called to make a private copy of the original,
but doesn't release it. Current code assumes that the original skb is
released during reallocation and only releases it at the error path
which causes a memory leak.
Fix this by adding the original skb release to the main path.
Fixes: d003462a50de ("mlxsw: Simplify mlxsw_sx_port_xmit function")
Signed-off-by: Arkadi Sharshevsky <arkadis@mellanox.com>
[ Upstream commit 36bf38d158d3482119b3e159c0619b3c1539b508 ]
Fixes: 56ade8fe3fe1 ("mlxsw: spectrum: Add initial support for Spectrum ASIC")
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
[ Upstream commit 19c0f40d4fca3a47b8f784a627f0467f0138ccc8 ]
Fix the hw rx checksum is always enabled, and the user couldn't switch
it to sw rx checksum.
Note that the RTL_VER_01 only support sw rx checksum only. Besides,
the hw rx checksum for RTL_VER_02 is disabled after
commit b9a321b48af4 ("r8152: Fix broken RX checksums."). Re-enable it.
commit 5a00b6c2438460b870a451f14593fc40d3c7edf6 upstream.
The commit 1c6c69525b40 ("genirq: Reject bogus threaded irq requests")
starts refusing misconfigured interrupt handlers. This makes
intel_mid_powerbtn not working anymore.
Add a mandatory flag to a threaded IRQ request in the driver.
Fixes: 1c6c69525b40 ("genirq: Reject bogus threaded irq requests")
commit ecc8995363ee6231b32dad61c955b371b79cc4cf upstream.
PADCFGLOCK (and PADCFGLOCK_TX) offset in Broxton actually starts at 0x060
and not 0x090 as used in the driver. Fix it to use the correct offset.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit c739c0a7c3c2472d7562b8f802cdce44d2597c8b upstream.
A rare randconfig build failure shows up in this driver when
the CRC32 helper is not there:
drivers/media/built-in.o: In function `s5k4ecgx_s_power':
s5k4ecgx.c:(.text+0x9eb4): undefined reference to `crc32_le'
This adds the 'select' that all other users of this function have.
Fixes: 8b99312b7214 ("[media] Add v4l2 subdev driver for S5K4ECGX sensor")
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 828f6fa65ce7e80f77f5ab12942e44eb3d9d174e upstream.
1. Release pid before enter odp flow
2. Release pid when fail to allocate memory
Fixes: 87773dd56d54 ("IB: ib_umem_release() should decrement mm->pinned_vm from ib_umem_get")
Fixes: 8ada2c1c0c1d ("IB/core: Add support for on demand paging regions")
Signed-off-by: Kenneth Lee <liguozhu@hisilicon.com>
Reviewed-by: Haggai Eran <haggaie@mellanox.com>
Reviewed-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit fc791b6335152c5278dc4a4991bcb2d329f806f9 upstream.
After the commit 9207f9d45b0a ("net: preserve IP control block
during GSO segmentation"), the GSO CB and the IPoIB CB conflict.
That destroy the IPoIB address information cached there,
causing a severe performance regression, as better described here:
http://marc.info/?l=linux-kernel&m=146787279825501&w=2
This change moves the data cached by the IPoIB driver from the
skb control lock into the IPoIB hard header, as done before
the commit 936d7de3d736 ("IPoIB: Stop lying about hard_header_len
and use skb->cb to stash LL addresses").
In order to avoid GRO issue, on packet reception, the IPoIB driver
stash into the skb a dummy pseudo header, so that the received
packets have actually a hard header matching the declared length.
To avoid changing the connected mode maximum mtu, the allocated
head buffer size is increased by the pseudo header length.
After this commit, IPoIB performances are back to pre-regression
value.
v2 -> v3: rebased
v1 -> v2: avoid changing the max mtu, increasing the head buf size
Fixes: 9207f9d45b0a ("net: preserve IP control block during GSO segmentation")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Cc: Vasiliy Tolstov <v.tolstov@selfip.ru>
Cc: Nikolay Borisov <n.borisov.lkml@gmail.com>
Cc: Doug Ledford <dledford@redhat.com>
commit c34f078675f505c4437919bb1897b1351f16a050 upstream.
In the path where intel_crt_detect_ddc() detects a CRT, if would return
true without freeing the edid.
Fixes: a2bd1f541f19 ("drm/i915: check whether we actually received an edid in detect_ddc")
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Daniel Vetter <daniel.vetter@intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: intel-gfx@lists.freedesktop.org
Signed-off-by: Ander Conselvan de Oliveira <ander.conselvan.de.oliveira@intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1484922525-6131-1-git-send-email-ander.conselvan.de.oliveira@intel.com
(cherry picked from commit c96b63a6a7ac4bd670ec2e663793a9a31418b790)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit befa60113ce7ea270cb51eada28443ca2756f480 upstream.
In order to make the driver work with the common clock framework, this
patch converts the clk_enable()/clk_disable() to
clk_prepare_enable()/clk_disable_unprepare().
Also add error checking for clk_prepare_enable().
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit c97c52be78b8463ac5407f1cf1f22f8f6cf93a37 upstream.
The priv->device pointer for c_can_pci is never set, but it is used
without a NULL check in c_can_start(). Setting it in c_can_pci_probe()
like c_can_plat_probe() prevents c_can_pci.ko from crashing, with and
without CONFIG_PM.
This might also cause the pm_runtime_*() functions in c_can.c to
actually be executed for c_can_pci devices - they are the only other
place where priv->device is used, but they all contain a null check.
Signed-off-by: Einar Jón <tolvupostur@gmail.com>
commit b4cfe3971f6eab542dd7ecc398bfa1aeec889934 upstream.
If IPV6 has not been enabled in the underlying kernel, we must avoid
calling IPV6 procedures in rdma_cm.ko.
This requires using "IS_ENABLED(CONFIG_IPV6)" in "if" statements
surrounding any code which calls external IPV6 procedures.
In the instance fixed here, procedure cma_bind_addr() called
ipv6_addr_type() -- which resulted in calling external procedure
__ipv6_addr_type().
Fixes: 6c26a77124ff ("RDMA/cma: fix IPv6 address resolution")
Cc: Spencer Baugh <sbaugh@catern.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Reviewed-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
commit 950eabbd6ddedc1b08350b9169a6a51b130ebaaf upstream.
With some gcc versions, we get a warning about the eicon driver,
and that currently shows up as the only remaining warning in one
of the build bots:
In file included from ../drivers/isdn/hardware/eicon/message.c:30:0:
eicon/message.c: In function 'mixer_notify_update':
eicon/platform.h:333:18: warning: array subscript is above array bounds [-Warray-bounds]
The code is easily changed to open-code the unusual PUT_WORD() line
causing this to avoid the warning.
Link: http://arm-soc.lixom.net/buildlogs/stable-rc/v4.4.45/
commit fdf35a6b22247746a7053fc764d04218a9306f82 upstream.
I noticed that the VT switch doesn't work any longer with a Dell
laptop with 1366x768 eDP when the machine is connected with a DP
monitor. It behaves as if VT were switched, but the graphics remain
frozen. Actually the keyboard works, so I could switch back to VT7
again.
I tried to track down the problem, and encountered a long story until
we reach to this error:
- The machine is booted with video=1366x768 option (the distro
installer seems to add it as default).
- Recently, drm_helper_probe_single_connector_modes() deals with
cmdline modes, and it tries to create a new mode when no
matching mode is found.
- The drm_mode_create_from_cmdline_mode() creates a mode based on
either CVT of GFT according to the given cmdline mode; in our case,
it's 1366x768.
- Since both CVT and GFT can't express the width 1366 due to
alignment, the resultant mode becomes 1368x768, slightly larger than
the given size.
- Later on, the atomic commit is performed, and in
drm_atomic_check_only(), the size of each plane is checked.
- The size check of 1366x768 fails due to the above, and eventually
the whole VT switch fails.
Back in the history, we've had a manual fix-up of 1368x768 in various
places via c09dedb7a50e ("drm/edid: Add a workaround for 1366x768 HD
panel"), but they have been all in drm_edid.c at probing the modes
from EDID. For addressing the problem above, we need a similar hack
to the mode newly created from cmdline, manually adjusting the width
when the expected size is 1366 while we get 1368 instead.
Fixes: eaf99c749d43 ("drm: Perform cmdline mode parsing during...")
Link: http://patchwork.freedesktop.org/patch/msgid/20170109145614.29454-1-tiwai@suse.de
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
commit 2dc705a9930b4806250fbf5a76e55266e59389f2 upstream.
Copying color maps to userspace doesn't check the value of to->start,
which will cause kernel heap buffer OOB read due to signedness wraps.
CVE-2016-8405
Link: http://lkml.kernel.org/r/20170105224249.GA50925@beast
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-by: Peter Pi (@heisecode) of Trend Micro
Cc: Min Chong <mchong@google.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 5c9e6c2b2ba3ec3a442e2fb5b4286498f8b4dcb7 upstream.
PL330 DMA engine driver is leaking a runtime reference after any terminated
DMA transactions. This patch fixes this issue by tracking runtime PM state
of the device and making additional call to pm_runtime_put() in terminate_all
callback if needed.
Fixes: ae43b3289186 ("ARM: 8202/1: dmaengine: pl330: Add runtime Power Management support v12")
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 7ec03e60ef81c19b5d3a46dd070ee966774b860f upstream.
Function ite_set_carrier_params() uses variable use_demodulator after
having initialized it to false in some if branches, but this variable is
never set to true otherwise.
This bug has been found using clang -Wsometimes-uninitialized warning
flag.
Fixes: 620a32bba4a2 ("[media] rc: New rc-based ite-cir driver for
several ITE CIRs")
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
commit c9205e18b41a6ef5ad73e1c4b86a78b2ea3ccb9b upstream.
devm_pinctrl_get() can fail so we should check for that.
Fixes: 0a6824bc10de ('[media] v4l2: blackfin: select proper pinctrl state in ppi_set_params if CONFIG_PINCTRL is enabled')
commit bc7c36eedb0c7004aa06c2afc3c5385adada8fa3 upstream.
When a CPU goes offline a potentially pending timer interrupt is not
cleared. When the CPU comes online again then the pending interrupt is
delivered before the per cpu clockevent device is initialized. As a
consequence the tick interrupt handler dereferences a NULL pointer.
[ 51.251378] Unable to handle kernel NULL pointer dereference at virtual address 00000040
[ 51.289348] task: ee942d00 task.stack: ee960000
[ 51.293861] PC is at tick_periodic+0x38/0xb0
[ 51.298102] LR is at tick_handle_periodic+0x1c/0x90
Clear the pending interrupt in the cpu dying path.
Fixes: 56a94f13919c ("clocksource: exynos_mct: Avoid blocking calls in the cpu hotplug notifier")
Reported-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Cc: linux-samsung-soc@vger.kernel.org
Cc: cw00.choi@samsung.com
Cc: daniel.lezcano@linaro.org
Cc: javier@osg.samsung.com
Cc: kgene@kernel.org
Cc: krzk@kernel.org
Link: http://lkml.kernel.org/r/1484628876-22065-1-git-send-email-jy0922.shim@samsung.com
commit fc1ffd6cb38a1c1af625b9833c41928039e733f5 upstream.
During code inspection, while investigating following stack trace
seen on one of the test setup, we found out there was possibility
of memory leak becuase driver was not unwinding the stack properly.
This issue has not been reproduced in a test environment or on a
customer setup.
Here's stack trace that was seen.
[1469877.797315] Call Trace:
[1469877.799940] [<ffffffffa03ab6e9>] qla2x00_mem_alloc+0xb09/0x10c0 [qla2xxx]
[1469877.806980] [<ffffffffa03ac50a>] qla2x00_probe_one+0x86a/0x1b50 [qla2xxx]
[1469877.814013] [<ffffffff813b6d01>] ? __pm_runtime_resume+0x51/0xa0
[1469877.820265] [<ffffffff8157c1f5>] ? _raw_spin_lock_irqsave+0x25/0x90
[1469877.826776] [<ffffffff8157cd2d>] ? _raw_spin_unlock_irqrestore+0x6d/0x80
[1469877.833720] [<ffffffff810741d1>] ? preempt_count_sub+0xb1/0x100
[1469877.839885] [<ffffffff8157cd0c>] ? _raw_spin_unlock_irqrestore+0x4c/0x80
[1469877.846830] [<ffffffff81319b9c>] local_pci_probe+0x4c/0xb0
[1469877.852562] [<ffffffff810741d1>] ? preempt_count_sub+0xb1/0x100
[1469877.858727] [<ffffffff81319c89>] pci_call_probe+0x89/0xb0
Signed-off-by: Quinn Tran <quinn.tran@cavium.com>
Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ bvanassche: Fixed spelling in patch description ]
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
commit 73529c872a189c747bdb528ce9b85b67b0e28dec upstream.
The xway_nand driver accesses the ltq_ebu_membase symbol which is not
exported. This also should not get exported and we should handle the
EBU interface in a better way later. This quick fix just deactivated
support for building as module.
Fixes: 99f2b107924c ("mtd: lantiq: Add NAND support on Lantiq XWAY SoC.")
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
commit 05a974efa4bdf6e2a150e3f27dc6fcf0a9ad5655 upstream.
From 4.9 we should really avoid using the stack here as this will not be DMA
able on various platforms. This changes the buffers already being present in
time of 4.9 being released. This should go into stable as well.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Stefan Schmidt <stefan@osg.samsung.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 01167c7b9cbf099c69fe411a228e4e9c7104e123 upstream.
According to the code the intention is to append 8 SCK cycles
instead of 4 at end of a MMC_STOP_TRANSMISSION command. But this
will never happened because it's an AC command not an ADTC command.
So fix this by moving the statement into the right function.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Fixes: e4243f13d10e (mmc: mxs-mmc: add mmc host driver for i.MX23/28)
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 7a546af50eb78ab99840903083231eb635c8a566 upstream.
Make sure to check for short control transfers in order to avoid parsing
uninitialised buffer data and leaking it to user space.
Note that the backlight and macro-mode buffer constraints are kept as
loose as possible in order to avoid any regressions should the current
buffer sizes be larger than necessary.
Fixes: 6f78193ee9ea ("HID: corsair: Add Corsair Vengeance K90 driver")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 6d104af38b570d37aa32a5803b04c354f8ed513d upstream.
Not all platforms support DMA to the stack, and specifically since v4.9
this is no longer supported on x86 with VMAP_STACK either.
Note that the macro-mode buffer was larger than necessary.
commit 51ebfc92b72b4f7dac1ab45683bf56741e454b8c upstream.
A PCI-to-PCIe bridge (a "reverse bridge") has a PCI or PCI-X primary
interface and a PCI Express secondary interface. The PCIe interface is a
Downstream Port that originates a Link. See the "PCI Express to PCI/PCI-X
Bridge Specification", rev 1.0, sections 1.2 and A.6.
The bug report below involves a PCI-to-PCIe bridge and a PCIe switch below
the bridge:
00:1e.0 Intel 82801 PCI Bridge to [bus 01-0a]
01:00.0 Pericom PI7C9X111SL PCIe-to-PCI Reversible Bridge to [bus 02-0a]
02:00.0 Pericom Device 8608 [PCIe Upstream Port] to [bus 03-0a]
03:01.0 Pericom Device 8608 [PCIe Downstream Port] to [bus 0a]
01:00.0 is configured as a PCI-to-PCIe bridge (despite the name printed by
lspci). As we traverse a PCIe hierarchy, device connections alternate
between PCIe Links and internal Switch logic. Previously we did not
recognize that 01:00.0 had a secondary link, so we thought the 02:00.0
Upstream Port *did* have a secondary link. In fact, it's the other way
around: 01:00.0 has a secondary link, and 02:00.0 has internal Switch logic
on its secondary side.
When we thought 02:00.0 had a secondary link, the pci_scan_slot() ->
only_one_child() path assumed 02:00.0 could have only one child, so 03:00.0
was the only possible downstream device. But 03:00.0 doesn't exist, so we
didn't look for any other devices on bus 03.
Booting with "pci=pcie_scan_all" is a workaround, but we don't want users
to have to do that.
Recognize that PCI-to-PCIe bridges originate links on their secondary
interfaces.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=189361
Fixes: d0751b98dfa3 ("PCI: Add dev->has_secondary_link to track downstream PCIe links")
Tested-by: Blake Moore <blake.moore@men.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 0b59970e7d96edcb3c7f651d9d48e1a59af3c3b0 upstream.
Remove the warning print of "can't use of GFP_NOIO" to avoid prints in
each QP creation when devices aren't supporting IB_QP_CREATE_USE_GFP_NOIO.
This print become more annoying when the IPoIB interface is configured
to work in connected mode.
Fixes: 09b93088d750 ('IB: Add a QP creation flag to use GFP_NOIO allocations')
Signed-off-by: Kamal Heib <kamalh@mellanox.com>
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
commit 1f22e454df2eb99ba6b7ace3f594f6805cdf5cbc upstream.
According to the firmware spec, FLOW_STEERING_IB_UC_QP_RANGE command is
supported only if dmfs_ipoib bit is set.
If it isn't set we want to ensure allocating NET_IF QPs fail. We do so
by filling out the allocation bitmap. By thus, the NET_IF QPs allocating
function won't find any free QP and will fail.
Fixes: c1c98501121e ('IB/mlx4: Add support for steerable IB UD QPs')
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Signed-off-by: Daniel Jurgens <danielj@mellanox.com>
Reviewed-by: Mark Bloch <markb@mellanox.com>
commit 6fa26208206c406fa529cd73f7ae6bf4181e270b upstream.
Report the correct speed in the port attributes when using a 56Gbps
ethernet link. Without this change the field is incorrectly set to 10.
Fixes: a9c766bb75ee ('IB/mlx4: Fix info returned when querying IBoE ports')
Fixes: 2e96691c31ec ('IB: Use central enum for speed instead of hard-coded values')
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
commit c482af646d0809a8d5e1b7f4398cce3592589b98 upstream.
For non-special QPs, the port value becomes non-zero only at the
RESET-to-INIT transition. If the QP has not undergone that transition,
its port number value is still zero.
If such a QP is destroyed before being moved out of the RESET state,
subtracting one from the qp port number results in a negative value.
Using that negative value as an index into the qp1_proxy array
results in an out-of-bounds array reference.
Fix this by testing that the QP type is one that uses qp1_proxy before
using the port number. For special QPs of all types, the port number is
specified at QP creation time.
Fixes: 9433c188915c ("IB/mlx4: Invoke UPDATE_QP for proxy QP1 on MAC changes")
commit af4295c117b82a521b05d0daf39ce879d26e6cb1 upstream.
Set traffic class within sl_tclass_flowlabel when create iboe AH.
Without this the TOS value will be empty when running VLAN tagged
traffic, because the TOS value is taken from the traffic class in the
address handle attributes.
Fixes: 9106c4106974 ('IB/mlx4: Fix SL to 802.1Q priority-bits mapping for IBoE')
Signed-off-by: Maor Gottlieb <maorg@mellanox.com>
commit acbda523884dcf45613bf6818d8ead5180df35c2 upstream.
Wait before continuing unload till all pending mkey async creation requests
are done.
Fixes: e126ba97dba9 ('mlx5: Add driver for Mellanox Connect-IB adapters')
Signed-off-by: Eli Cohen <eli@mellanox.com>
commit 5d7400c4acbf7fe633a976a89ee845f7333de3e4 upstream.
Always stating PIN_CONFIG_BIAS_DISABLE is supported gives untrue output
when examining /sys/kernel/debug/pinctrl/e6060000.pfc/pinconf-pins if
the operation get_bias() is implemented but the pin is not handled by
the get_bias() implementation. In that case the output will state that
"input bias disabled" indicating that this pin has bias control
support.
Make support for PIN_CONFIG_BIAS_DISABLE depend on that the pin either
supports SH_PFC_PIN_CFG_PULL_UP or SH_PFC_PIN_CFG_PULL_DOWN. This also
solves the issue where SoC specific implementations print error messages
if their particular implementation of {set,get}_bias() is called with a
pin it does not know about.
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit c090959b9dd8c87703e275079aa4b4a824ba3f8e upstream.
Make sure to drop the reference to the parent device taken by
class_find_device() after populating the bus.
Fixes: 3b9334ac835b ("mfd: vexpress: Convert custom func API to regmap")
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
commit a545715d2dae8d071c5b06af947b07ffa846b288 upstream.
When removing and adding cpu 0 on a system with GHES NMI the following stack
trace is seen when re-adding the cpu:
WARNING: CPU: 0 PID: 0 at arch/x86/kernel/apic/apic.c:1349 setup_local_APIC+
Modules linked in: nfsv3 rpcsec_gss_krb5 nfsv4 nfs fscache coretemp intel_ra
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.0-rc6+ #2
Call Trace:
dump_stack+0x63/0x8e
__warn+0xd1/0xf0
warn_slowpath_null+0x1d/0x20
setup_local_APIC+0x275/0x370
apic_ap_setup+0xe/0x20
start_secondary+0x48/0x180
set_init_arg+0x55/0x55
early_idt_handler_array+0x120/0x120
x86_64_start_reservations+0x2a/0x2c
x86_64_start_kernel+0x13d/0x14c
During the cpu bringup, wakeup_cpu_via_init_nmi() is called and issues an
NMI on CPU 0. The GHES NMI handler, ghes_notify_nmi() runs the
ghes_proc_irq_work work queue which ends up setting IRQ_WORK_VECTOR
(0xf6). The "faulty" IR line set at arch/x86/kernel/apic/apic.c:1349 is also
0xf6 (specifically APIC IRR for irqs 255 to 224 is 0x400000) which confirms
that something has set the IRQ_WORK_VECTOR line prior to the APIC being
initialized.
Commit 2383844d4850 ("GHES: Elliminate double-loop in the NMI handler")
incorrectly modified the behavior such that the handler returns
NMI_HANDLED only if an error was processed, and incorrectly runs the ghes
work queue for every NMI.
This patch modifies the ghes_proc_irq_work() to run as it did prior to
2383844d4850 ("GHES: Elliminate double-loop in the NMI handler") by
properly returning NMI_HANDLED and only calling the work queue if
NMI_HANDLED has been set.
Fixes: 2383844d4850 (GHES: Elliminate double-loop in the NMI handler)
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
commit 8a10c06a20ec8097a68fd7a4a1c0e285095b4d2f upstream.
With preemption turned on we can read incorrect throttling state
while being switched to CPU on a different chip.
BUG: using smp_processor_id() in preemptible [00000000] code: cat/7343
caller is .powernv_cpufreq_throttle_check+0x2c/0x710
CPU: 13 PID: 7343 Comm: cat Not tainted 4.8.0-rc5-dirty #1
Call Trace:
[c0000007d25b75b0] [c000000000971378] .dump_stack+0xe4/0x150 (unreliable)
[c0000007d25b7640] [c0000000005162e4] .check_preemption_disabled+0x134/0x150
[c0000007d25b76e0] [c0000000007b63ac] .powernv_cpufreq_throttle_check+0x2c/0x710
[c0000007d25b7790] [c0000000007b6d18] .powernv_cpufreq_target_index+0x288/0x360
[c0000007d25b7870] [c0000000007acee4] .__cpufreq_driver_target+0x394/0x8c0
[c0000007d25b7920] [c0000000007b22ac] .cpufreq_set+0x7c/0xd0
[c0000007d25b79b0] [c0000000007adf50] .store_scaling_setspeed+0x80/0xc0
[c0000007d25b7a40] [c0000000007ae270] .store+0xa0/0x100
[c0000007d25b7ae0] [c0000000003566e8] .sysfs_kf_write+0x88/0xb0
[c0000007d25b7b70] [c0000000003553b8] .kernfs_fop_write+0x178/0x260
[c0000007d25b7c10] [c0000000002ac3cc] .__vfs_write+0x3c/0x1c0
[c0000007d25b7cf0] [c0000000002ad584] .vfs_write+0xc4/0x230
[c0000007d25b7d90] [c0000000002aeef8] .SyS_write+0x58/0x100
[c0000007d25b7e30] [c00000000000bfec] system_call+0x38/0xfc
Fixes: 09a972d16209 (cpufreq: powernv: Report cpu frequency throttling)
Reviewed-by: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
Signed-off-by: Denis Kirjanov <kda@linux-powerpc.org>
commit f24d311f92b516a8aadef5056424ccabb4068e7b upstream.
The pinctrl_gpio_request is called with the "full" gpio number, already
containing the base, then meson_pmx_request_gpio is then called with the
final pin number.
Remove the base addition when calling meson_pmx_disable_other_groups.
Fixes: 6ac730951104 ("pinctrl: add driver for Amlogic Meson SoCs")
CC: Beniamino Galvani <b.galvani@gmail.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Kevin Hilman <khilman@baylibre.com>
Acked-by: Beniamino Galvani <b.galvani@gmail.com>
commit 030ee7ae52a46a2be52ccc8242c4a330aba8d38e upstream.
The modem-control signals are managed by the tty-layer during open and
should not be asserted prematurely when set_termios is called from
driver open.
Also make sure that the signals are asserted only when changing speed
from B0.
Fixes: 664d5df92e88 ("USB: usb-serial ch341: support for DTR/RTS/CTS")
commit ce5e292828117d1b71cbd3edf9e9137cf31acd30 upstream.
Fix reset-resume handling which failed to resubmit the read and
interrupt URBs, thereby leaving a port that was open before suspend in a
broken state until closed and reopened.
Fixes: 1ded7ea47b88 ("USB: ch341 serial: fix port number changed after
resume")
Fixes: 2bfd1c96a9fb ("USB: serial: ch341: remove reset_resume callback")
commit 8a08403bcb39f5d0e733bcf59a8a74f16b538f6e upstream.
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=98897
https://bugs.launchpad.net/bugs/1651981
Acked-by: Edward O'Callaghan <funfunctor@folklore1984.net>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Adrian Fiergolski <A.Fiergolski@gmail.com>
commit 802c03881f29844af0252b6e22be5d2f65f93fd0 upstream.
The sysrq input handler should be attached to the input device which has
a left alt key.
On 32-bit kernels, some input devices which has a left alt key cannot
attach sysrq handler. Because the keybit bitmap in struct input_device_id
for sysrq is not correctly initialized. KEY_LEFTALT is 56 which is
greater than BITS_PER_LONG on 32-bit kernels.
I found this problem when using a matrix keypad device which defines
a KEY_LEFTALT (56) but doesn't have a KEY_O (24 == 56%32).
Cc: Jiri Slaby <jslaby@suse.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
commit 89d8232411a85b9a6b12fd5da4d07d8a138a8e0c upstream.
If we don't disable the transmitter in atmel_stop_tx, the DMA buffer
continues to send data until it is emptied.
This cause problems with the flow control (CTS is asserted and data are
still sent).
So, disabling the transmitter in atmel_stop_tx is a sane thing to do.
Tested on at91sam9g35-cm(DMA)
Tested for regressions on sama5d2-xplained(Fifo) and at91sam9g20ek(PDC)
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit c8a6a09c1c617402cc9254b2bc8da359a0347d75 upstream.
In ca91cx42_slave_get function, the value pointed by vme_base pointer is
set through:
*vme_base = ioread32(bridge->base + CA91CX42_VSI_BS[i]);
So it must be dereferenced to be used in calculation of pci_base:
*pci_base = (dma_addr_t)*vme_base + pci_offset;
This bug was caught thanks to the following gcc warning:
drivers/vme/bridges/vme_ca91cx42.c: In function ‘ca91cx42_slave_get’:
drivers/vme/bridges/vme_ca91cx42.c:467:14: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
*pci_base = (dma_addr_t)vme_base + pci_offset;
Signed-off-by: Augusto Mecking Caringi <augustocaringi@gmail.com>
Acked-By: Martyn Welch <martyn@welchs.me.uk>
commit d6169d04097fd9ddf811e63eae4e5cd71e6666e2 upstream.
If a URB is killed while the host is removed we can end up in a situation
where the hub thread takes the roothub device lock, and waits for
the URB to be given back by xhci-hcd, blocking the host remove code.
xhci-hcd tries to stop the endpoint and give back the urb, but can't
as the host is removed from PCI bus at the same time, preventing the normal
way of giving back urb.
Instead we need to rely on the stop command timeout function to give back
the urb. This xhci_stop_endpoint_command_watchdog() timeout function
used a XHCI_STATE_DYING flag to indicate if the timeout function is already
running, but later this flag has been taking into use in other places to
mark that xhci is dying.
Remove checks for XHCI_STATE_DYING in xhci_urb_dequeue. We are still
checking that reading from pci state does not return 0xffffffff or that
host is not halted before trying to stop the endpoint.
This whole area of stopping endpoints, giving back URBs, and the wathdog
timeout need rework, this fix focuses on solving a specific deadlock
issue that we can then send to stable before any major rework.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
