process to die
If a process forked and the child process was killed by the
lowmemorykiller, the lowmemory killer would be disabled until
the parent process reaped the child or it died itself.
Change-Id: I49822d847ee54876b474a837743b4f4821fba57f
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Reviewed-on: http://git-master/r/15091
Reviewed-by: Ching Kuang (Roger) Hsieh <rhsieh@nvidia.com>
Tested-by: Ching Kuang (Roger) Hsieh <rhsieh@nvidia.com>
The lowmemorykiller registers an atomic notifier for notfication of when
the task is freed. From this atomic notifier callback, it removes the
atomic notifier via task_free_unregister(). This is incorrect because
atomic_notifier_chain_unregister() calls syncronize_rcu(), which can
sleep, which shouldn't be done from an atomic notifier.
Fix this by registering the notifier during init, and only unregister it
if the lowmemorykiller is unloaded.
Change-Id: Ie9cf2f23d31c78e1fe1b9dd2e11af5267832ee94
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Signed-off-by: Christian Bejram <christian.bejram@stericsson.com>
Reviewed-on: http://git-master/r/13943
(cherry picked from commit 9dc305371bfe820db10e554e0bd8e60b16f94ab8)
Change-Id: Ie857ffa2ebdb2eec5b75bf93ae954798e74dad3f
Reviewed-on: http://git-master/r/9847
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
This reverts commit 6469f378a596f0572035cd27a17851ea86b763c9.
Bug 758628
Bug 748669
Original commit attmpted to have a smarter cache cleaning code.
But that work didn't work out well and just resulted in display
corruption.
Reviewed-on: http://git-master/r/11817
(cherry picked from commit 60207394cc16689f06ccbac993eefd2928565031)
Change-Id: I92bd95154f372eb0a081a4c3919b87d576ea4cb5
Reviewed-on: http://git-master/r/12449
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Tested-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-by: Markus Holtmanns <mholtmanns@nvidia.com>
Tested-by: Markus Holtmanns <mholtmanns@nvidia.com>
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Reviewed-on: http://git-master/r/10445
Tested-by: Yu-Huan Hsu <yhsu@nvidia.com>
(cherry picked from commit 0a4752eb037a5d4492d108ec094dd5367f5faa09)
Change-Id: I03a8224b8d3ccb4e7b0f682a75648ff9e9cda06f
Reviewed-on: http://git-master/r/11717
Reviewed-by: Robert R Collins <rcollins@nvidia.com>
Tested-by: Robert R Collins <rcollins@nvidia.com>
(Cherry-Picked Panjit driver from cc8231d0ddef32343db199b6a668d572c079afc4)
Reviewed-on: http://git-master/r/10443
(cherry picked from commit 208bbaaf873e202531e3d8045c9a5f534ba4906e)
Change-Id: Ie08bc42669fad152931be095a8a549852dd9be12
Reviewed-on: http://git-master/r/11716
Bug: 730157
Change-Id: I8741f2be5c3c8933edf0dcc3b9d00006eeb86117
Reviewed-on: http://git-master/r/11682
Reviewed-by: Rahul Bansal <rbansal@nvidia.com>
Tested-by: Rahul Bansal <rbansal@nvidia.com>
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
The requested SD clock will be limited to the maximum
supported clock on the platform.
Bug 761966
Change-Id: I03cd76ae42f56675f47d185da73352e716f6d255
Reviewed-on: http://git-master/r/11429
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
For large allocations, cleaning each page of the allocation can
take a significant amount of time. If an allocation that nvmap needs
to clean or invalidate out of the cache is significantly larger than
the cache, just flush the entire cache.
bug 711478 and bug 744221
Revert "video: tegra: nvmap: perform cache maintenance for rw_handle"
This reverts commit d963f09c3ebb2d690d266f8f607b4876acaf2ab1.
Reviewed-on: http://git-master/r/10213
(cherry picked from commit 6469f378a596f0572035cd27a17851ea86b763c9)
Change-Id: I1e514f505db860eb01d575a98f0f80c8794e8463
Reviewed-on: http://git-master/r/10497
Reviewed-by: Eric Werness <ewerness@nvidia.com>
Reviewed-by: Janne Hellsten <jhellsten@nvidia.com>
Getting the transfer count by dma with rts disable. In this way
we can avoid the race condition arise by hw with incoming data.
Change-Id: Ieeeadfeea9293c70fd2eb96ff9d82888a58b2b3a
Reviewed-on: http://git-master/r/11020
Tested-by: Rakesh Goyal <rgoyal@nvidia.com>
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Udaykumar Rameshchan Raval <uraval@nvidia.com>
There is sysrq feature which works from console with
sending break and then character.
The console driver uses the 8250 driver.
In tegra uart controller, after receiving break, it
needs to clear the rx fifo by reading fifo till empty
to receive the another break/character.
Fixing this issue in 8250 driver.
bug 697978
Change-Id: I4eb71a67bafc186ec9934fce164e28ad86fa0ace
Reviewed-on: http://git-master/r/8736
Support for device wakeup on receiving SDIO
interrupt in LP1/LP0 for incoming wifi pakcket.
Bug: 730157
Change-Id: Ia2e9bf2af215f33d6d6d8d78ba0cdf2d71011917
Reviewed-on: http://git-master/r/9813
Tested-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Fast compaction algorithm: for every free block from the
beginning of CO, try to reallocate block before
and after the free block. Once enough free space for
requested allocation is freed, return.
Full compaction triggers if fast one fails: it works like
fast one but also uses block moving algorithm which
doesn't require extra CO memory. It compacts all heap,
merging as much free space as possible.
Also fixed few bugs.
bug 740842
bug 746972
(cherry picked from commit 171edd17a191c8a4a4f9a8434dec796089cda141)
Change-Id: I40ec2c49a3c3f37fd7149e8123eda59da4caef39
Reviewed-on: http://git-master/r/10149
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Tested-by: Kirill Artamonov <kartamonov@nvidia.com>
Gate access to h->carveout.co_heap by (h->alloc && !h->pg_alloc)
Bug 743185
(cherry picked from commit daba1dc0a3e050a2739293904cad9e65eb27a559)
Change-Id: I5014fb40074e79e4db293767e3ef512ea35401d8
Reviewed-on: http://git-master/r/10148
Adding bluesleep support for CSR chip
BUG 691608
Change-Id: I5cb9420201e99b36a9ee26a411c0312b3c6e3fa1
Reviewed-on: http://git-master/r/9678
Clean up warning message caused by unused variable and
improper struct type.
Bug 682070
Change-Id: I3409ad22e67252df14d6d14898aa8792a0019574
Reviewed-on: http://git-master/r/8436
Reviewed-by: Lance Zhao <lazhao@nvidia.com>
Tested-by: Lance Zhao <lazhao@nvidia.com>
New API added to odm_kit to register a callback to use on RTC interrupt.
Supported added for RTC alarms in the max8907b PMU.
Bug 717253
Bug 734529
Change-Id: I34abebd7dd3caf4ef8923fcf651c50f6d245f6b4
Reviewed-on: http://git-master/r/7328
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Update card_present variable during resume by reading
card detect gpio value inorder to detect cards inserted
during suspend.
Change-Id: Ie3eb7cb09cf84fa0795a21c44b28e07e6302adb7
Reviewed-on: http://git-master/r/8060
Fixed the following:
Missing node creation for debug_fs while doing compaction.
Missing locks in handle_free
Split heap functionality was not creating debugfs node
Misc code clean-up.
roll up of unmerged changes from other branch
Bug 743185
(Cherry picked from commit 396c587981b2d0d1abb1daf481a5fe4bbd0ba70d)
Change-Id: I55249e14ea69c3780b24efbfaea9ceef9ef23534
Reviewed-on: http://git-master/r/8236
Reviewed-by: Thomas Roell <troell@nvidia.com>
The tegra_sdhci structure pointer is passed to the sdhci_readl
and sdhci_writel macros instead of the required sdhci_host
structure pointer. Corrected this.
Change-Id: Icc7172387fc206c65c685e5ee5ee6ab390e9ad89
Reviewed-on: http://git-master/r/9020
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
The late resume of touch was not invoked when display was not turned on.
This has been handled now.
Bug 740740
(cherry picked from commit ef6a066e3ad9254312660bbb725be9ed49448ffa)
Change-Id: Id2f1cd255ed59019fb46778da1b93cbe7aa3b8bb
Reviewed-on: http://git-master/r/7973
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
When USB cable is removed from the USB1 port side then VBUS is turned
off but, if USB cable is removed from the device side then VBUS is not
getting turned off and is showing high even when USB cable is removed
completely from the USB1 port. Fixed this by checking the OTG state
"OTG_STATE_A_SUSPEND" and then turning off the VBUS and phy power down.
Bug 741587
Change-Id: Ib8f3dbddc48de0d12179dbd504503621854f44cd
Reviewed-on: http://git-master/r/8199
If serial core driver request for the stop rx then dequeue
the dma request and read the rx fifo only if rx is in progress.
Change-Id: I8cd8a75a59773f0195ed876f7faeb89ac0f2cbec
Reviewed-on: http://git-master/r/7579
Reviewed-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Keyboard controller goes to continuous polling mode from
wakeup mode if any key is pressed and stay for hw default
to 5 second. This parameter was not configurable from odm.
It is require to configure this parameter from odm based on
platform.
Adding support for keeping this time as configurable. The default
time still be 5 second if it is not configured from odm.
Change-Id: I0fc11cc2a2d64db33b00c048f87081b6181354fa
Reviewed-on: http://git-master/r/8644
Reviewed-by: Chun-Hung (Alex) Wu <chuwu@nvidia.com>
Tested-by: Chun-Hung (Alex) Wu <chuwu@nvidia.com>
Made sure graphics and sdhci clocks are enabled before the respective
rate is configured.
Change-Id: I2d09ad111321b296a8d8fbb2d4bff02016e12feb
Reviewed-on: http://git-master/r/8272
Drastic reduction of ACM timeout to 2ms (from 1sec) resulted in power
increase for NV omxplayer video-playback (bug 738557). The reason is
that short-term scheduling does not provide enough idle time for LP2
state (CPU powered down). On the other hand, 1 sec timeout prevented
core voltage scaling during Android music audio-playback (bug 735111).
Hence, tuned ACM timeout to 25ms.
(cherry picked from commit 32c727ae2c4f91e8d7c9c261921bb62ad14217c9)
Change-Id: I96c46c43e9b3089b6a7e01db5f6d122122758c90
Reviewed-on: http://git-master.nvidia.com/r/8470
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Hoang Pham <hopham@nvidia.com>
Bug 731923
Reviewed-on: http://git-master/r/7002
(cherry picked from commit b927a389930941297f987cc7967d10d319deba6b)
Change-Id: I576de9b2dfd4245f471ca26636a146ead3df021b
Reviewed-on: http://git-master.nvidia.com/r/8430
Reviewed-by: Venkata (Muni) Anda <vanda@nvidia.com>
Tested-by: Andrew Wright <awright@nvidia.com>
Added EM770 vendor and product id in usb serial driver.
Bug 721467
Change-Id: Ib64820f25b02a69c8a366b9251f9419dd4bfa786
Reviewed-on: http://git-master.nvidia.com/r/8385
Check for pgalloc is not required.
Bug 731923
Reviewed-on: http://git-master/r/7218
(cherry picked from commit 665dba4dd0617f763815bce96dec4a14f8a0c6f6)
Change-Id: I82e701555605f4322a95a66b75ffe3f3bce2a5a6
Reviewed-on: http://git-master.nvidia.com/r/8266
When the memory for a handle is not allocated, and then
if the caller calls _nvmap_handle_free it should
not do the cache operations on the memory as there
is no memory allocated
Bug 731923
Reviewed-on: http://git-master.nvidia.com/r/7166
(cherry picked from commit f3824fd58e2654a0d8d3159cb1f776d3ad0169a2)
Change-Id: Icf11ece6d07e122991e0d9b6b4a3dbf8c45ea017
Reviewed-on: http://git-master.nvidia.com/r/8265
Reviewed-on: http://git-master/r/6507
(cherry picked from commit 3708cd7a859d1ca4f3230bc8bfb018894bb6277e)
Change-Id: I1609b8b8d1f2de51f7eafa2105fb1f695903a252
Reviewed-on: http://git-master.nvidia.com/r/8262
Added syncpoints reset to host initialization, to synchronize h/w state
with shadow variables.
Bug 743910
Change-Id: I09420fe2fb85b0e79f0e5d11ade8515e28e96910
Reviewed-on: http://git-master/r/8038
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
KBC does not behave properly after resume from LP0 if KBC
is in continuous mode before entering into LP0.
So making sure that KBC should be in wakeup mode before
entering to LP0.
bug 740263
Change-Id: Ia882dfb034bd9ab87811855f2ac20d26fc9581d8
Reviewed-on: http://git-master/r/7756
USB devices are not recognised when connected to the USB port, when system is
already in LP0. Root port power is not getting enabled when resume from LP0.
By the time root hub checks for the port connection auto suspend is getting
called and device is not recognised. Fixed this by enabling the root port power
during the ehci_restart functionality.
Bug 741890
(cherry picked from commit 188bf7050751a40d6f2d6a858e2702774fc70f77)
Change-Id: Ib88ed3fc4b01719777a0e49e27434ef6425bc53d
Reviewed-on: http://git-master/r/7834
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Tested-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Incorrect address is passed to iounmap, which is causing virtual space leak.
Bug 732355
Reviewed-on: http://git-master/r/7554
(cherry picked from commit 593fc2ae6dfadff51ca45353b35dfbd3de0fcce7)
Change-Id: Id69a7b3a6e130c91d594fc0ff32b8080cf192e2c
Reviewed-on: http://git-master/r/7858
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
During resume from LP0 controller is getting restarted in host mode due to this
hcd state is getting changed from the suspend state. Controller state should not
be changed for host mode. Fixed this to restart the controller only in OTG mode.
Bug 724437
(cherry picked from commit cbea530301ae3d9a4a7271d11c819bfc8de8f892)
Change-Id: Idc2897a2790087e00ee66e30fea734c9d117029e
Reviewed-on: http://git-master/r/7833
There is one wmb missing in the usb host controller driver after the queue head
update. Due to this data transaction is not happening on the bus after urb
submission by the hcd driver. Register updates/queue heads data in the memory
is not reflected on the AHB bus. After adding the wmb after queue head update
data transaction the USB bus started with out any delay.
Bug 737242
(cherry picked from commit eff18c3f40253f7af0b576126b954d8572cbea64)
Change-Id: I9f3ae6d8743a03a58034a82f4fe2850fd7278c4f
Reviewed-on: http://git-master/r/7747
When user switches on wifi, wifi driver need to poweron wifi card and
ask sdhci stack to enumerate the card. Sdhci stack does not provide any
interface to achieve this. Major wifi vendors depend on platform to
provide wifi poweron/reset/carddetect abstraction function.
Bug ID 739374
Change-Id: I988393352ff6cb54be3d70a59c94f67eedff06fb
Reviewed-on: http://git-master/r/7097
On k32, remote wake up is enabled in the descriptor based on gadget->ops. Since,
remote wakeup is not supported, disabled gadget->op->remote_wakeup based
on USB_ANDROID.
Bug 710624
(cherry picked from commit c0340053278c9c9ceb98772cc3566d298dca4d9a)
Change-Id: I760632dd38a9f56dadfbb4d446e83f28cdb5338f
Reviewed-on: http://git-master/r/7556
Keep enabling the kc controller only if any of keys are configured
as wakeup source during suspend.
bug 735233
(cherry picked from commit 13825a46587b0508aa7a43054964b76524d5f2b6)
Change-Id: I028965400ee4f96c1460f8e261a2376943384030
Reviewed-on: http://git-master/r/7499
A new driver is implemented to actively manage the bluetooth module
power. bluesleep also tries to manage the power of the transport used.
Two signals (GPIOs) are used to manage the power events.
BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep.
HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/
activate the transport modules required for BT communication.
Bug 680524, 691608
(cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8)
Change-Id: I5edba2aa18c566f0ebfc4ecf9c54149ee3376666
Reviewed-on: http://git-master/r/6850
Reviewed-by: Anantha Idapalapati <aidapalapati@nvidia.com>
Tested-by: Anantha Idapalapati <aidapalapati@nvidia.com>
Moving the isl29018 from hwmon to the staging/iio/light driver.
Replacing the hwmon registration with iio registration and doing
required changes to make it iio driver.
bug 728678
(cherry picked from commit 2c72f7dff2b74375b35936cd4c94a891f169009d)
Change-Id: I223d4451b62f2260cd2f9ee2ed8ba77ec8672b52
Reviewed-on: http://git-master/r/7109
Following are changes:
- using smbus api to read/write from/to device.
- Adding proximitysensing with scheme 0 and 1.
- Adding ir sensing.
- Removing the undesired definition and code.
- Remove gpio initialzation and usage.
- Sysfs interface for setting range/resolution/proximity scheme.
- sysfs interface for reading lux/proximity ir and ir.
- General code cleaning.
(cherry picked from commit 0a148f035c9284cfa0e60e875052d6768267d731)
Change-Id: I0d84f534a14b85e5a6bcea3218ecd8d864c0a103
Reviewed-on: http://git-master.nvidia.com/r/7102
Reduced ACM timeout to 2ms (from 1sec). This is necessary to detect
host / 3D idle under frequent activity bursts.
Bug 735111
Bug 726052
(cherry picked from commit 1ff7aa46f02f61f070ae41abd8e0a36d4a4f1f3d)
Change-Id: I711286925776c2955f7c43acae0cb8b2c1763e4a
Reviewed-on: http://git-master.nvidia.com/r/7007
Reviewed-by: Niranjan Wartikar <nwartikar@nvidia.com>
limit the number of times adb_open and adb_release may be printed
in a short period of time, to prevent adb death spirals when
exiting suspend
(cherry picked from commit 3a1e33f6715f7133ba9fe26d68342c1ff6106b20)
Change-Id: I575f38269c9a4c46a3a59ff7a06c8bda36a0c0d4
Reviewed-on: http://git-master/r/6723
Tested-by: Narendra Damahe <ndamahe@nvidia.com>
Reviewed-by: Gary King <gking@nvidia.com>
When user doesn't use default heap policy and selects
GART or carveout allocation, automatic single-page-to-sysmem
rule doesn't work. Because of broken rule many single page
allocations go to GART and carveout.
The fix adds sysmem bit to heap mask when allocation is
single page and GART or carveout is present in heap mask.
bug 730124
bug 731923
(cherry picked from commit 3ca9989c922420a57215d297189738a0464c4073)
Change-Id: I2ea8018ae5ed9d31e90659479d0e44052ebf9431
Reviewed-on: http://git-master/r/6701
add a driver for the hardware watchdog timer embedded in NVIDIA
Tegra SoCs
Change-Id: I40730213119b4f325e3de008a5efb28f5d578b1c
Signed-off-by: Gary King <gking@nvidia.com>
Reviewed-on: http://git-master/r/6305
Reviewed-on: http://git-master/r/6705
bug 715382
Integrate from tegra-2010-07
Change-Id: I790bd0e6ff5ddd9513ae7a5ddfce491dcd1e32b3
Reviewed-on: http://git-master/r/6673
Reviewed-by: Antti Hatala <ahatala@nvidia.com>
Tested-by: Antti Hatala <ahatala@nvidia.com>
When system runs out of dma and uart driver tries to allocate
dma, the dma allocation fails. In such case, the uart
communication should work with interrupt based -non dma mode.
bug 730003
(cherry picked from commit 4a9d5633474c806799ccc6d167f3d624c92d560c)
(cherry picked from commit 2000a076103c559446d11ad49debc4e0f2952e8a)
Change-Id: I96c2a3f79fd9044e3b54771b60cad7dcb12f517b
Reviewed-on: http://git-master/r/6599
Reviewed-by: Harry Hong <hhong@nvidia.com>
Tested-by: Harry Hong <hhong@nvidia.com>
[bug] 729378
Change-Id: I34d276d2552491c933983309df0fe31f7bf3ba7e
Reviewed-on: http://git-master/r/6443
Reviewed-by: Andy Carman <acarman@nvidia.com>
Tested-by: Andy Carman <acarman@nvidia.com>
