commit 21404b772a1c65f7b935b8c0fddc388a949f4e31 upstream.
This removes the use of the special "macbookair_fn_keys" keyboard
translation table for the MacBookAir4,x models (ie the 2011 refresh).
They use the standard apple_fn_keys[] translation. Apparently only the
old MacBook Air's need a different translation table.
This mirrors the change that commit da617c7cb915 ("HID: consolidate
MacbookAir 4,1 mappings") did for the WELLSPRING6A ones, but does it for
the WELLSPRING6 model used on the MacBookAir4,2.
Reported-and-tested-by: Dirk Hohndel <hohndel@infradead.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Joshua V Dillon <jvdillon@gmail.com>
Cc: Chase Douglas <chase.douglas@canonical.com>
commit da617c7cb915545dda4280df888dd6f8d5697420 upstream.
MacbookAir 4,1 doesn't require extra mapping table, as the mappings
are identical to apple_fn_keys[].
commit ad734bc1565364f9e4b70888d3ce5743b3c1030a upstream.
I've recently bought a Apple wireless aluminum keyboard (model 2011) which is
not yet supported by the kernel - it seems they just changed the device id.
After applying the attached patch, the device is fully functional.
Signed-off-by: Andreas Krist <andreas.krist@gmail.com>
commit 213f9da80533940560bef8fa43b10c590895459c upstream.
This patch adds keyboard support for Macbook Pro 8 models which has
WELLSPRING5A model name and 0x0252, 0x0253 and 0x0254 USB IDs. Trackpad
support for those models are added to bcm5974 in
c331eb580a0a7906c0cdb8dbae3cfe99e3c0e555 ("Input: bcm5974 - Add
support for newer MacBookPro8,2).
Signed-off-by: Gökçen Eraslan <gokcen@pardus.org.tr>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
commit d762cc290b9f17e346f4297fd5984b70ce71ef66 upstream.
Added USB device IDs and keyboard map for MacBookAir 4,1 keyboard.
commit f6f554f09c5b831efdaf67c449e18ca06ee648fe upstream.
Otherwise the generic driver wouldn't unbind from it and wouldn't
let hid-apple to automatically take over.
commit c50bb1a4005630f47b5da26336f74a485033a515 upstream.
This panel is also known as the Dell ST2220Tc.
Signed-off-by: jeffbrown@android.com
Reviewed-By: Benjamin Tissoires <Benjamin_Tissoires@logitech.com>
commit 5d922baa631058c7e37ae33e81c4d3e6437f8d1d upstream.
Added USB device IDs for MacBookAir4,2 keyboard. Device constants were
copied from the MacBookAir3,2 constants. The 4,2 device specification is
reportedly unchanged from the 3,2 predecessor and seems to work well.
Signed-off-by: Joshua V Dillon <jvdillon@gmail.com>
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
commit 6d1db0777981e1626ae71243984ac300b61789ff upstream.
Create each gamepad as a separate joystick
Signed-off-by: Clemens Werther <clemens.werther@gmail.com>
commit 4a4c879904aa0cc64629e14a49b64fb3d149bf1a upstream.
Add USB device ids for the new revision (MB110LL/B) of Apple's wired aluminum
keyboard. I have only confirmed that the ANSI version is correct - it is
assumed that the ISO and JIS versions follow the standard numbering convention.
Signed-off-by: Dan Bastone <dan@pwienterprises.com>
commit f722013ee9fd24623df31dec9a91a6d02c3e2f2f upstream.
In nand_do_write_ops() code it is possible for a caller to provide
ops.oobbuf populated and ops.mode == MTD_OOB_AUTO, which currently
means that the chip->oob_poi buffer isn't initialised to all 0xFF.
The nand_fill_oob() method then carries out the task of copying
the provided OOB data to oob_poi, but with MTD_OOB_AUTO it skips
areas marked as unavailable by the layout struct, including the
bad block marker bytes.
An example of this causing issues is when the last OOB data read
was from the start of a bad block where the markers are not 0xFF,
and the caller wishes to write new OOB data at the beginning of
another block. In this scenario the caller would provide OOB data,
but nand_fill_oob() would skip the bad block marker bytes in
oob_poi before copying the OOB data provided by the caller.
This means that when the OOB data is written back to NAND,
the block is inadvertently marked as bad without the caller knowing.
This has been witnessed when using YAFFS2 where tags are stored
in the OOB.
To avoid this oob_poi is always initialised to 0xFF to make sure
no left over data is inadvertently written back to the OOB area.
Credits to Brian Norris <computersforpeace@gmail.com> for fixing this
patch.
Signed-off-by: Adam Thomson <adam.thomson@alcatel-lucent.com>
Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
commit 52d6d4ef5e6d1517688e27c11c01ab303ec681dd upstream.
My recent commits (3782c69d, 324c74a) introduced regression
for register offset selection that based on the macversion.
Not using parentheses in proper manner for ternary operator
leads to select wrong offset for the registers.
This issue was observed with AR9462 chip that immediate disconnect
after the association with the following message
ieee80211 phy3: wlan0: Failed to send nullfunc to AP 00:23:69:12:ea:47
after 500ms, disconnecting.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
commit f5ff7cd1a84caa9545d952a37ac872ccb73825fb upstream.
The previous commit enforces a new rule for handling the cloned packets
for transmit time stamping. These packets must not be freed using any other
function than skb_complete_tx_timestamp. This commit fixes the one and only
driver using this API.
The driver first appeared in v3.0.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
commit 543e32d5ff165d0d68deedb0e3557478c7c36a4a upstream.
This bug was introduced in f8155a40 ("mtd: pxa3xx_nand: rework irq
logic") and causes the PXA3xx NAND controller fail to operate with NAND
flash that has empty pages. According to the comment in this block, the
hardware controller will report a double-bit error for empty pages,
which can and must be ignored.
This patch restores the original behaviour of the driver.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Acked-by: Lei Wen <leiwen@marvell.com>
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 0fab028b77d714ad302404b23306cf7adb885223 upstream.
When keep_config is set, the detection would goes different routine.
That the driver would read out the setting which is set previously
by bootloader. While most bootloader keep the irq mask as off, and
current driver need all irq default open, keep_config behavior would
lead to no irq at all.
Signed-off-by: Lei Wen <leiwen@marvell.com>
Tested-by: Daniel Mack <zonque@gmail.com>
commit d5de1907d0af22e1a02de2b16a624148517a39c2 upstream.
parse_mtd_partitions takes a list of partition types; if the driver
isn't loaded, it attempts to load it, and then it grabs the partition
parser. For redboot, the module name is "redboot.ko", while the parser
name is "RedBoot". Since modprobe is case-sensitive, attempting to
modprobe "RedBoot" will never work. I suspect the embedded systems that
make use of redboot just always manually loaded redboot prior to loading
their specific nand chip drivers (or statically compiled it in).
Signed-off-by: Andres Salomon <dilinger@queued.net>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit bf5140817b2d65faac9b32fc9057a097044ac35b upstream.
On writes in MODE_RAW the mtd_oob_ops struct is not sufficiently
initialized which may cause nandwrite to fail. With this patch
it is possible to write raw nand/oob data without additional ECC
(either for testing or when some sectors need different oob layout
e.g. bootloader) like
nandwrite -n -r -o /dev/mtd0 <myfile>
Signed-off-by: Peter Wippich <pewi@gw-instruments.de>
Tested-by: Ricard Wanderlof <ricardw@axis.com>
commit 98fb2cc115b4ef1ea0a2d87a170c183bd395dd6c upstream.
This patch fixes system hang when resuming from S3 state
and lower rate sens failure issue.
commit 3bf3f8b19d2bfccc40f13c456bf339fd8f535ebc upstream.
Callers to __acpi_ioremap_fast() pass the bit_width that they found in the
acpi_generic_address structure. Convert from bits to bytes when passing to
__acpi_find_iomap() - as it wants to see bytes, not bits.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit c4853efec665134b2e6fc9c13447323240980351 upstream.
The P600 requires a small delay when changing states. Otherwise we may think
the board did not reset and we bail. This for kdump only and is particular
to the P600.
Signed-off-by: Mike Miller <mike.miller@hp.com>
commit 5c62cb48602dba95159c81ffeca179d3852e25be upstream.
We did not increment the amount of sectors written to disk
b/c we tested for the == WRITE which is incorrect - as the
operations are more of WRITE_FLUSH, WRITE_ODIRECT. This patch
fixes it by doing a & WRITE check.
Reported-by: Andy Burns <xen.lists@burns.me.uk>
Suggested-by: Ian Campbell <Ian.Campbell@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 0167ac67ff6f35bf2364f7672c8012b0cd40277f upstream.
Fix for issue : While discovery is in progress, hot unplug and hot plug of
enclosure connected to the controller card is causing system to hang.
When a device is in the process of being detected at driver load time then
if it is removed, the device that is no longer present will not be added
to the list. So the code in _scsih_probe_sas() is rearranged as such so
the devices that failed to be detected are not added to the list.
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit f7c9c6bb14f3104608a3a83cadea10a6943d2804 upstream.
When looking at memory consumption issues I noticed quite a
lot of memory in the kmalloc-2048 bucket:
OBJS ACTIVE USE OBJ SIZE SLABS OBJ/SLAB CACHE SIZE NAME
6561 6471 98% 2.30K 243 27 15552K kmalloc-2048
Over 15MB. slub debug shows that cfq is responsible for almost
all of it:
# sort -nr /sys/kernel/slab/kmalloc-2048/alloc_calls
6402 .cfq_init_queue+0xec/0x460 age=43423/43564/43655 pid=1 cpus=4,11,13
In scsi_alloc_sdev we do scsi_alloc_queue but if slave_alloc
fails we don't free it with scsi_free_queue.
The patch below fixes the issue:
135 72 53% 2.30K 5 27 320K kmalloc-2048
# cat /sys/kernel/slab/kmalloc-2048/alloc_calls
3 .cfq_init_queue+0xec/0x460 age=3811/3876/3925 pid=1 cpus=4,11,13
commit 3308511c93e6ad0d3c58984ecd6e5e57f96b12c8 upstream.
Make sure that SCSI device removal via scsi_remove_host() does finish
all pending SCSI commands. Currently that's not the case and hence
removal of a SCSI host during I/O can cause a deadlock. See also
"blkdev_issue_discard() hangs forever if underlying storage device is
removed" (http://bugzilla.kernel.org/show_bug.cgi?id=40472). See also
http://lkml.org/lkml/2011/8/27/6.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
commit a18a920c70d48a8e4a2b750d8a183b3c1a4be514 upstream.
This patch validates sdev pointer in scsi_dh_activate before proceeding further.
Without this check we might see the panic as below. I have seen this
panic multiple times..
Call trace:
#0 [ffff88007d647b50] machine_kexec at ffffffff81020902
#1 [ffff88007d647ba0] crash_kexec at ffffffff810875b0
#2 [ffff88007d647c70] oops_end at ffffffff8139c650
#3 [ffff88007d647c90] __bad_area_nosemaphore at ffffffff8102dd15
#4 [ffff88007d647d50] page_fault at ffffffff8139b8cf
[exception RIP: scsi_dh_activate+0x82]
RIP: ffffffffa0041922 RSP: ffff88007d647e00 RFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 00000000000093c5
RDX: 00000000000093c5 RSI: ffffffffa02e6640 RDI: ffff88007cc88988
RBP: 000000000000000f R8: ffff88007d646000 R9: 0000000000000000
R10: ffff880082293790 R11: 00000000ffffffff R12: ffff88007cc88988
R13: 0000000000000000 R14: 0000000000000286 R15: ffff880037b845e0
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0000
#5 [ffff88007d647e38] run_workqueue at ffffffff81060268
#6 [ffff88007d647e78] worker_thread at ffffffff81060386
#7 [ffff88007d647ee8] kthread at ffffffff81064436
#8 [ffff88007d647f48] kernel_thread at ffffffff81003fba
Signed-off-by: Babu Moger <babu.moger@netapp.com>
commit c68bf8eeaa57c852e74adcf597237be149eef830 upstream.
The call to complete() in st_scsi_execute_end() wakes up sleeping thread
in write_behind_check(), which frees the st_request, thus invalidating
the pointer to the associated bio structure, which is then passed to the
blk_rq_unmap_user(). Fix by storing pointer to bio structure into
temporary local variable.
This bug is present since at least linux-2.6.32.
Signed-off-by: Petr Uzel <petr.uzel@suse.cz>
Reported-by: Juergen Groß <juergen.gross@ts.fujitsu.com>
Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi>
commit 8cd79f24350826b81e16990d9e12bc878e67d385 upstream.
This patch addresses an issue with buggy userspace code sending I/O
via scsi-generic that does not explictly clear their associated read
buffers. It adds an explict memset of the first SGL entry within
tcm_loop_new_cmd_map() for SCF_SCSI_CONTROL_SG_IO_CDB payloads that
are currently guaranteed to be a single SGL by target-core code.
This issue is a side effect of the v3.1-rc1 merge to remove the
extra memcpy between certain control CDB types using a contigious
+ cleared buffer in target-core, and performing a memcpy into the
SGL list within tcm_loop.
It was originally mainfesting itself by udev + scsi_id + scsi-generic
not properly setting up the expected /dev/disk/by-id/ symlinks because
the INQUIRY payload was containing extra bogus data preventing the
proper NAA IEEE WWN from being parsed by userspace.
Cc: Andy Grover <agrover@redhat.com>
commit bfa02b0da66965caf46e441270af87edda4fea14 upstream.
Commit 2265cef2 (hwmon: (w83627ehf) Properly report PECI and AMD-SI
sensor types) results in kernel panic if data->temp_label was not
initialized.
The problem was found with chip W83627DHG-P.
Add check if data->temp->label was set before use.
Based on incomplete patch by Alexander Beregalov.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
Tested-by: Alexander Beregalov <a.beregalov@gmail.com>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 2265cef2751b3441df91f85e0107f9f549e5b711 upstream.
When temperature sources are PECI or AMD-SI agents, it makes no sense
to report their type as diode or thermistor. Instead we must report
their digital nature.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 2aba6cac2a84f3b80e11a680c34d55e7739b474d upstream.
The definition of TO_ATTR_NO in the non-SMP case is wrong. As the SMP
definition resolves to the correct value, just use this for both
cases.
Without this fix the temperature attributes are named temp0_* instead
of temp2_*, so libsensors won't pick them. Broken since kernel 3.0.
Tested-by: Phil Sutter <phil@nwl.cc>
Acked-by: Durgadoss R <Durgadoss.r@intel.com>
commit ab5dbebe33e0c353e8545f09c34553ac3351dad6 upstream.
to the P600.
commit b2c0a863e14676fa5760c6d828fd373288e2f64a upstream.
Originally, the runtime PM core would send an idle notification
whenever a suspend attempt failed. The idle callback routine could
then schedule a delayed suspend for some time later.
However this behavior was changed by commit
f71648d73c1650b8b4aceb3856bebbde6daa3b86 (PM / Runtime: Remove idle
notification after failing suspend). No notifications were sent, and
there was no clear mechanism to retry failed suspends.
This caused problems for the usbhid driver, because it fails
autosuspend attempts as long as a key is being held down. A companion
patch changes the PM core's behavior, but we also need to change the
USB core. In particular, this patch (as1493) updates the device's
last_busy time when an autosuspend fails, so that the PM core will
retry the autosuspend in the future when the delay time expires
again.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Henrik Rydberg <rydberg@euromail.se>
commit 886486b792e4f6f96d4fbe8ec5bf20811cab7d6a upstream.
autosuspend attempts as long as a key is being held down. Therefore
this patch (as1492) adds a mechanism for retrying failed
autosuspends. If the callback routine updates the last_busy field so
that the next autosuspend expiration time is in the future, the
autosuspend will automatically be rescheduled.
commit 64912e997f0fe13512e4c7b90e4f7c11cb922ab5 upstream.
Polarity needs to be set accordingly to connector status (connected
or disconnected). Set it up in hpd_init() so first hotplug works
reliably no matter what is the initial set of connector. hpd_init()
also covers resume so HPD will work correctly after resume as well.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Cc: Jerome Glisse <j.glisse@gmail.com>
commit a18cee15ed4c8b6a35f96b7b26a46bac32e04bd9 upstream.
Allow the user to override whether MSIs are enabled
or not on supported ASICs. MSIs are disabled by default
on IGP chips as they tend not to work. However certain
IGP chips only seem to work with MSIs enabled.
I suspect this is a chipset or bios issue, but I'm not sure
what the proper fix is. This will at least make diagnosing
and working around the problem much easier.
See:
https://bugs.freedesktop.org/show_bug.cgi?id=37679
commit 01e718ec194e30b3e8eb3858c742c13649757efc upstream.
Some Dell laptops only seem to work with MSIs. This
looks like a platform/bios bug.
Fixes:
commit 00dfb8df5bf8c3afe4c0bb8361133156b06b7a2c upstream.
This should make eDP more reliable.
commit 8ab250d4484b72ccc78e34276c5ffa84c1d41303 upstream.
or disconnected). Set it up at module init so first hotplug works
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
commit b362105f7f5223fa4d2e03ceeea0e51da754ccc6 upstream.
Some HP laptops only seem to work with MSIs. This
Fixes:
commit 8f6c25c59b0c895c68cae59d1b34e9a7b36971bc upstream.
This makes it easier to add quirks for certain systems.
commit 340764465aa4a586ca332e61ae64883e5ad6f183 upstream.
Since force handling rework of d0d0a225e6ad43314c9aa7ea081f76adc5098ad4
we could end up bouncing connector status btw disconnected and unknown.
When connector status change a call to output_poll_changed happen which
in turn ask again for detect but with force set.
So set the load detect flags whenever we report the connector as
connected or unknown this avoid bouncing btw disconnected and unknown.
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Cc: Stefan Lippers-Hollmann <s.L-H@gmx.de>
commit 6fd4562178508a0949c9fdecd8558d8b10d671bd upstream.
When the link state changes, xHC will report a port status change event
and set the PORT_PLC bit, for both USB3 and USB2 root hub ports.
The PLC will be cleared by usbcore for USB3 root hub ports, but not for
USB2 ports, because they do not report USB_PORT_STAT_C_LINK_STATE in
wPortChange.
Clear it for USB2 root hub ports in handle_port_status().
Signed-off-by: Andiry Xu <andiry.xu@amd.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit d2f52c9e585bbb1a3c164e02b8dcd0d996c67353 upstream.
Introduce xhci_test_and_clear_bit() to clear RWC bit in PORTSC register.
commit 2dc3753997f3c80ce8b950242ab9bb3fb936acfd upstream.
Some alternate interface settings have no endpoints associated with them.
This shows up in some USB webcams, particularly the Logitech HD 1080p,
which uses the uvcvideo driver. If a driver switches between two alt
settings with no endpoints, there is no need to issue a configure endpoint
command, because there is no endpoint information to update.
The only time a configure endpoint command with just the add slot flag set
makes sense is when the driver is updating hub characteristics in the slot
context. However, that code never calls xhci_check_bandwidth, so we
should be safe not issuing a command if only the slot context add flag is
set.
commit f02fe890ece7d695a5744b20525d45312382e6e4 upstream.
Scanning cannot be run during suspend or hibernation, but if
usb-stor-scan freezes another thread waiting on scanning to
complete may fail to freeze.
However, if usb-stor-scan is left freezable without ever actually
freezing then the freezer will wait on it to exit, and threads
waiting for scanning to finish will no longer be blocked. One
problem with this approach is that usb-stor-scan has a delay to
wait for devices to settle (which is currently the only point where
it can freeze). To work around this we can request that the freezer
send a fake signal when freezing, then use interruptible sleep to
wake the thread early when freezing happens.
To make this happen, the following changes are made to
usb-stor-scan:
* Use set_freezable_with_signal() instead of set_freezable() to
request a fake signal when freezing
* Use wait_event_interruptible_timeout() instead of
wait_event_freezable_timeout() to avoid freezing
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit c510eae377c773241ff0b6369a8f3581da941a51 upstream.
This device declares itself to be vendor specific
It therefore needs to be added to the device table
to make btusb bind.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
commit f78b68261e80899f81a21dfdf91e2a1456ea8175 upstream.
Today I noticed that the usb bluetooth adapter (BCM2046B1) on my 2011
mac mini was not working. I've created a patch to get it going.
Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl>
commit 2d25f8b462f3b849d8913d02978657ef06e67dd8 upstream.
The new Ath3k needs to download patch and radio table,
and it keeps same PID/VID even after downloading the patch and radio
table. This patch is to use the bcdDevice (Device Release Number) to
judge whether the chip has been patched or not. The init bcdDevice
value of the chip is 0x0001, this value increases after patch and
radio table downloading.
Signed-off-by: Steven.Li <yongli@qca.qualcomm.com>
commit 8e7c3d2e4ba18ee4cdcc1f89aec944fbff4ce735 upstream.
Blacklist Toshiba-branded AR3011 based AR5B195 [0930:0215] and add to
ath3k.c for firmware loading.
Signed-off-by: Ricardo Mendoza <ricmm@gentoo.org>
commit a63b723d02531f7add0b2b8a0e6a77ee176f1626 upstream.
This patch against current git adds the hardware ID for the Apple
MacBookAir4,1, released in July 2011. The device features a BCM2046
USB chip. The patch was inspired by the previous modifications adding
support for the MacBookAir3,x.
Signed-off-by: Pieter-Augustijn Van Malleghem <p-a@scarlet.be>
