commit 10879ae5f12e9cab3c4e8e9504c1aaa8a033bde7 upstream.
This patch adds function pl011_console_match() that implements
method match of struct console. It allows to match consoles against
data specified in a string, for example taken from command line or
compiled by ACPI SPCR table handler.
This patch was merged to tty-next but then reverted because of
conflict with
commit 46e36683f433 ("serial: earlycon: Extend earlycon command line option to support 64-bit addresses")
Now it is fixed.
Signed-off-by: Aleksey Makarov <aleksey.makarov@linaro.org>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Tested-by: Christopher Covington <cov@codeaurora.org>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit b3fb22733ae61050f8d10a1d6a8af176c5c5db1a upstream.
Radiant P845 does not have LVDS, only VGA.
Cc: stable@vger.kernel.org
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=105468
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180309222204.4771-1-linux@rainbow-software.org
(cherry picked from commit 7f7105f99b75aca4f8c2a748ed6b82c7f8be3293)
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
commit bdcc02cf1bb508fc700df7662f55058f651f2621 upstream.
Entry corresponding to 220 us setup time was missing. I am not aware of
any specific bug this fixes, but this could potentially result in enabling
PSR on a panel with a higher setup time requirement than supported by the
hardware.
I verified the value is present in eDP spec versions 1.3, 1.4 and 1.4a.
Fixes: 6608804b3d7f ("drm/dp: Add drm_dp_psr_setup_time()")
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Jose Roberto de Souza <jose.souza@intel.com>
Cc: dri-devel@lists.freedesktop.org
Reviewed-by: José Roberto de Souza <jose.souza@intel.com>
Reviewed-by: Tarun Vyas <tarun.vyas@intel.com>
Signed-off-by: Dhinakaran Pandiyan <dhinakaran.pandiyan@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180511195145.3829-3-dhinakaran.pandiyan@intel.com
commit a840c93ca7582bb6c88df2345a33f979b7a67874 upstream.
When a GID entry is invalid EAGAIN is returned. This is an incorrect error
code, there is nothing that will make this GID entry valid again in
bounded time.
Some user space tools fail incorrectly if EAGAIN is returned here, and
this represents a small ABI change from earlier kernels.
The first patch in the Fixes list makes entries that were valid before
to become invalid, allowing this code to trigger, while the second patch
in the Fixes list introduced the wrong EAGAIN.
Therefore revert the return result to EINVAL which matches the historical
expectations of the ibv_query_gid_type() API of the libibverbs user space
library.
Cc: <stable@vger.kernel.org>
Fixes: 598ff6bae689 ("IB/core: Refactor GID modify code for RoCE")
Fixes: 03db3a2d81e6 ("IB/core: Add RoCE GID table management")
Reviewed-by: Daniel Jurgens <danielj@mellanox.com>
Signed-off-by: Parav Pandit <parav@mellanox.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
commit 806e30873f0e74d9d41b0ef761bd4d3e55c7d510 upstream.
Commit b5e2ced9bf81 ("stm class: Use vmalloc for the master map") caused
a build error on some arches as vmalloc.h was not explicitly included.
Fix that by adding it to the list of includes.
Fixes: b5e2ced9bf81 ("stm class: Use vmalloc for the master map")
Reported-by: kbuild test robot <lkp@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
commit b5e2ced9bf81393034072dd4d372f6b430bc1f0a upstream.
Fengguang is running into a warning from the buddy allocator:
> swapper/0: page allocation failure: order:9, mode:0x14040c0(GFP_KERNEL|__GFP_COMP), nodemask=(null)
> CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.17.0-rc1 #262
> Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
> Call Trace:
> __kmalloc+0x14b/0x180: ____cache_alloc at mm/slab.c:3127
> stm_register_device+0xf3/0x5c0: stm_register_device at drivers/hwtracing/stm/core.c:695
Which is basically a result of the stm class trying to allocate ~512kB
for the dummy_stm with its default parameters. There's no reason, however,
for it not to be vmalloc()ed instead, which is what this patch does.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
CC: stable@vger.kernel.org # v4.4+
commit c9ddf73476ff4fffb7a87bd5107a0705bf2cf64b upstream.
Since an SRP remote port is attached as a child to shost->shost_gendev
and as the only child, the translation from the shost pointer into an
rport pointer must happen by looking up the shost child that is an
rport. This patch fixes the following KASAN complaint:
BUG: KASAN: slab-out-of-bounds in srp_timed_out+0x57/0x110 [scsi_transport_srp]
Read of size 4 at addr ffff880035d3fcc0 by task kworker/1:0H/19
CPU: 1 PID: 19 Comm: kworker/1:0H Not tainted 4.16.0-rc3-dbg+ #1
Workqueue: kblockd blk_mq_timeout_work
Call Trace:
dump_stack+0x85/0xc7
print_address_description+0x65/0x270
kasan_report+0x231/0x350
scsi_times_out+0xc7/0x3f0 [scsi_mod]
blk_mq_terminate_expired+0xc2/0x140
bt_iter+0xbc/0xd0
blk_mq_queue_tag_busy_iter+0x1c7/0x350
blk_mq_timeout_work+0x325/0x3f0
process_one_work+0x441/0xa50
worker_thread+0x76/0x6c0
kthread+0x1b2/0x1d0
ret_from_fork+0x24/0x30
Fixes: e68ca75200fe ("scsi_transport_srp: Reduce failover time")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Jason Gunthorpe <jgg@mellanox.com>
Cc: Doug Ledford <dledford@redhat.com>
Cc: Laurence Oberman <loberman@redhat.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 3d13de4b027d5f6276c0f9d3a264f518747d83f2 upstream.
Currently, the following causes a kernel OOPS in memcpy:
echo 1073741825 > buffer/length
echo 1 > buffer/enable
Note that using 1073741824 instead of 1073741825 causes "write error:
Cannot allocate memory" but no OOPS.
This is because 1073741824 == 2^30 and 1073741825 == 2^30+1. Since kfifo
rounds up to the nearest power of 2, it will actually call kmalloc with
roundup_pow_of_two(length) * bytes_per_datum.
Using length == 1073741825 and bytes_per_datum == 2, we get:
kmalloc(roundup_pow_of_two(1073741825) * 2
or kmalloc(2147483648 * 2)
or kmalloc(4294967296)
or kmalloc(UINT_MAX + 1)
so this overflows to 0, causing kmalloc to return ZERO_SIZE_PTR and
subsequent memcpy to fail once the device is enabled.
Fix this by checking for overflow prior to allocating a kfifo. With this
check added, the above code returns -EINVAL when enabling the buffer,
rather than causing an OOPS.
Signed-off-by: Martin Kelly <mkelly@xevo.com>
cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Not relevant upstream, therefore no upstream commit. ]
To fix, unmap the page as soon as possible.
When swiotlb is in use, calling dma_unmap_page means that
the original page mapped with dma_map_page must still be valid,
as swiotlb will copy data from its internal cache back to the
originally requested DMA location.
When GRO is enabled, before this patch all references to the
original frag may be put and the page freed before dma_unmap_page
in mlx4_en_free_frag is called.
It is possible there is a path where the use-after-free occurs
even with GRO disabled, but this has not been observed so far.
The bug can be trivially detected by doing the following:
* Compile the kernel with DEBUG_PAGEALLOC
* Run the kernel as a Xen Dom0
* Leave GRO enabled on the interface
* Run a 10 second or more test with iperf over the interface.
This bug was likely introduced in
commit 4cce66cdd14a ("mlx4_en: map entire pages to increase throughput"),
first part of u3.6.
It was incidentally fixed in
commit 34db548bfb95 ("mlx4: add page recycling in receive path"),
first part of v4.12.
This version applies to the v4.9 series.
Signed-off-by: Sarah Newman <srn@prgmr.com>
Tested-by: Sarah Newman <srn@prgmr.com>
Cc: Tariq Toukan <tariqt@mellanox.com>
Cc: Yishai Hadas <yishaih@mellanox.com>
commit a4023f682739439b434165b54af7cb3676a4766e upstream.
The hypervisor may not have full access to the kernel data structures
and hence cannot safely use cpus_have_cap() helper for checking the
system capability. Add a safe helper for hypervisors to check a constant
system capability, which *doesn't* fall back to checking the bitmap
maintained by the kernel. With this, make the cpus_have_cap() only
check the bitmask and force constant cap checks to use the new API
for quicker checks.
Cc: Robert Ritcher <rritcher@cavium.com>
Cc: Tirumalesh Chalamarla <tchalamarla@cavium.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
[4.9: restore cpus_have_const_cap() to previously-backported code]
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
commit a4b0e8a4e92b1baa860e744847fbdb84a50a5071 upstream.
Since in UFS 2.1 specification some of the descriptor lengths differs
from 2.0 specification and some devices, which are reporting spec
version 2.0 have different descriptor lengths we can not rely on
hardcoded values taken from 2.0 specification. This patch introduces
reading these lengths per each device from descriptor headers at probe
time to ensure their correctness.
Signed-off-by: Michal' Potomski <michalx.potomski@intel.com>
Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org>
[Wei Li: Slight tweaks to get the cherry-pick to apply,resolved collisions]
Signed-off-by: Li Wei <liwei213@huawei.com>
commit 93fdd5ac64bbe80dac6416f048405362d7ef0945 upstream.
Pull device descriptor reading out of ufs quirk so it can be used also
for other purposes.
Revamp the fixup setup:
1. Rename ufs_device_info to ufs_dev_desc as very similar name
ufs_dev_info is already in use.
2. Make the handlers static as they are not used out of the ufshdc.c
file.
[mkp: applied by hand]
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit bde44bb665d049468b6a1a2fa7d666434de4f83f upstream.
While reading variable size descriptors (like string descriptor), some UFS
devices may report the "LENGTH" (field in "Transaction Specific fields" of
Query Response UPIU) same as what was requested in Query Request UPIU
instead of reporting the actual size of the variable size descriptor.
Although it's safe to ignore the "LENGTH" field for variable size
descriptors as we can always derive the length of the descriptor from
the descriptor header fields. Hence this change impose the length match
check only for fixed size descriptors (for which we always request the
correct size as part of Query Request UPIU).
Reviewed-by: Venkat Gopalakrishnan <venkatg@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
[Wei Li: Slight tweaks to get the cherry-pick to apply,resolved collisions.]
commit d3b56c566d4ba8cae688baf3cca94425d57ea783 upstream.
Pointer request is being assigned but never used, so remove it. Cleans
up the clang warning:
drivers/platform/chrome/cros_ec_lpc.c:68:2: warning: Value stored to
'request' is never read
Signed-off-by: Benson Leung <bleung@chromium.org>
commit fb239c1209bb0f0b4830cc72507cc2f2d63fadbd upstream.
In _rtl92c_get_txpower_writeval_by_regulatory() the variable writeVal
is assigned to itself in an if ... else statement, apparently only to
document that the branch condition is handled and that a previously read
value should be returned unmodified. The self-assignment causes clang to
raise the following warning:
drivers/net/wireless/realtek/rtlwifi/rtl8192cu/rf.c:304:13:
error: explicitly assigning value of variable of type 'u32'
(aka 'unsigned int') to itself [-Werror,-Wself-assign]
writeVal = writeVal;
Delete the branch with the self-assignment.
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Reviewed-by: Guenter Roeck <groeck@chromium.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 531beb067c6185aceabfdee0965234c6a8fd133b upstream.
sg_table is being initialized and is never read before it is updated
again later on, hence making the initialization redundant. Remove
the initialization.
Detected by clang scan-build:
"warning: Value stored to 'sg_table' during its initialization is
never read"
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20170914230516.6056-1-colin.king@canonical.com
commit 40f7090bb1b4ec327ea1e1402ff5783af5b35195 upstream.
New ICs (like the one on the Lenovo T480s) answer to
ETP_SMBUS_IAP_VERSION_CMD 4 bytes instead of 3. This corrupts the stack
as i2c_smbus_read_block_data() uses the values returned by the i2c
device to know how many data it need to return.
i2c_smbus_read_block_data() can read up to 32 bytes (I2C_SMBUS_BLOCK_MAX)
and there is no safeguard on how many bytes are provided in the return
value. Ensure we always have enough space for any future firmware.
Also 0-initialize the values to prevent any access to uninitialized memory.
Cc: <stable@vger.kernel.org> # v4.4.x, v4.9.x, v4.14.x, v4.15.x, v4.16.x
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: KT Liao <kt.liao@emc.com.tw>
This reverts commit 0bd77073e693e8f93ff6ddba65a9f426153221cb which is
commit a7aa75a2a7dba32594291a71c3704000a2fd7089 upstream.
There's been too many complaints about this. Personally I think it's
going to blow up when people hit this in mainline, but hey, it's not my
systems. At least we don't have to backport the mess to the stable
kernels to give them some more life to live unscathed :)
Reported-by: Timur Tabi <timur@codeaurora.org>
Reported-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Sasha Levin <alexander.levin@microsoft.com>
commit 009615ab7fd4e43b82a38e4e6adc5e23c1ee567f upstream.
On sparc32, tcflag_t is unsigned long, unlike all other architectures:
drivers/usb/serial/cp210x.c: In function 'cp210x_get_termios':
drivers/usb/serial/cp210x.c:717:3: warning: passing argument 2 of 'cp210x_get_termios_port' from incompatible pointer type
cp210x_get_termios_port(tty->driver_data,
drivers/usb/serial/cp210x.c:35:13: note: expected 'unsigned int *' but argument is of type 'tcflag_t *'
static void cp210x_get_termios_port(struct usb_serial_port *port,
Consistently use tcflag_t to fix this.
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit a7aa75a2a7dba32594291a71c3704000a2fd7089 ]
The base of the TLMM gpiochip should not be statically defined as 0, fix
this to not artificially restrict the existence of multiple pinctrl-msm
devices.
Fixes: f365be092572 ("pinctrl: Add Qualcomm TLMM driver")
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
'of_regulator_match()'
[ Upstream commit 30966861a7a2051457be8c49466887d78cc47e97 ]
If an unlikely failure in 'of_get_regulator_init_data()' occurs, we must
release the reference on the current 'child' node before returning.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 71df179363a5a733a8932e9afb869760d7559383 ]
The cache pointer points to the actual memory used by the cache, as the
comparison here is looking for the type of the cache it should check
against cache_type.
Fixes: 1ea975cf1ef5 ("regmap: Add a function to check if a regmap register is cached")
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
[ Upstream commit 57de50af162b67612da99207b061ade3239e57db ]
When mapping external DMA-bufs through the PRIME mmap call, we might be
given an offset which has to be respected. However for the internal DRM
GEM mmap path, we have to ignore the fake mmap offset used to identify
the buffer only. Currently the code always zeroes out vma->vm_pgoff,
which breaks the former.
This patch fixes the problem by moving the vm_pgoff assignment to a
function that is used only for GEM mmap path, so that the PRIME path
retains the original offset.
Cc: Daniel Kurtz <djkurtz@chromium.org>
Signed-off-by: Ørjan Eide <orjan.eide@arm.com>
Signed-off-by: Tomasz Figa <tfiga@chromium.org>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Thierry Escande <thierry.escande@collabora.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Link: https://patchwork.freedesktop.org/patch/msgid/20180130202913.28724-4-thierry.escande@collabora.com
[ Upstream commit b418c4609d5052d174668ad6d13efe023c45c595 ]
This patch fixes MOD_SEL1 bit20 and MOD_SEL2 bit20, bit21 pin assignment
for SSI pins group.
This is a correction to the incorrect implementation of MOD_SEL register
pin assignment for R8A7796 SoC specification of R-Car Gen3 Hardware
User's Manual Rev.0.51E or later.
Fixes: f9aece7344bd ("pinctrl: sh-pfc: Initial R8A7796 PFC support")
Signed-off-by: Takeshi Kihara <takeshi.kihara.df@renesas.com>
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit 832e4e1f76b8a84991e9db56fdcef1ebce839b8b ]
Add Marvell 88SE9220 DMA quirk as found and tested on bug 42679.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=42679
Signed-off-by: Thomas Vincent-Cross <me@tvc.id.au>
Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
[ Upstream commit b24b6478e65f140610ab1ffaadc7bc6bf0be8aad ]
Ideally the de-allocation of resources should happen in the exact
opposite order in which they were allocated. It helps maintain the code
in long term, even if nothing really breaks with incorrect ordering.
That wasn't followed in cpufreq_online() and it has some
inconsistencies. For example, the symlinks were created from within
the locked region while they are removed only after putting the locks.
Also ->exit() should have been called only after the symlinks are
removed and the lock is dropped, as that was the case when ->init()
was first called.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
[ rjw: Subject ]
[ Upstream commit 15d2ee42a3087089e73ad52fd8c1b37ab496b87c ]
A dma_wmb() is used to guarantee the ordering, with respect to
other writes, to cache coherent DMA memory.
There is a dma_wmb() in prepare_tx_desc()/prepare_tso_tx_desc() which
ensures that TDES0/1/2 is written before TDES3 (which contains the own
bit), for First Desc.
However, in the rare case that MSS changes, there will be a MSS
context descriptor in front of the regular DMA descriptors:
<MSS desc> <- DMA Next Descriptor
<First Desc>
<desc n>
<Last Desc>
Thus, for this special case, we need a dma_wmb()
after prepare_tso_tx_desc()/before writing the own bit to the MSS desc,
so that we flush the write to TDES3 for First Desc,
in order to ensure that the MSS descriptor is the last descriptor to
set the own bit.
Signed-off-by: Niklas Cassel <niklas.cassel@axis.com>
[ Upstream commit a6b25da5e7ba212af5826a662e6a035a79bffabd ]
According to Documentation/memory-barriers.txt, we need to use a
dma_rmb() after reading the status/own bit, to ensure that all
descriptor fields are read after reading the own bit.
This way, we ensure that the DMA engine is done with the DMA
descriptor before we read the other descriptor fields, e.g. reading
the tx hardware timestamp (if PTP is enabled).
[ Upstream commit 48d163b1aa6e7f650c0b7a4f9c61c387a6def868 ]
When Linux is master of BAM, it can directly read registers to know number
of supported channels, however when its remotely controlled reading these
registers would trigger a crash if the BAM is not yet initialized or
powered up on the remote side.
This patch allows driver to read num-channels and num-ees from Device Tree
for remotely controlled BAM.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 326ed382256475aa4b8b7eae8a2f60689fd25e78 ]
Avoid issue when probing the RNG without
reset if bad status has been detected previously
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
[ Upstream commit e8588e268509292550634d9a35f2723a207683b2 ]
rq should be enabled before posting the buffers to rq desc. If not hw sees
stale value and casuses DMAR errors.
Signed-off-by: Govindarajulu Varadarajan <gvaradar@cisco.com>
[ Upstream commit 3e081628d510b2ddbe493371d9c574d9275da17e ]
This patch fixes an issue that a race condition happens between a client
driver and the rcar-dmac driver:
- The rcar_dmac_isr_transfer_end() is called.
- The done list appears, and desc.running is the next active list.
- rcar_dmac_chan_get_residue() is called by a client driver before
rcar_dmac_isr_channel_thread() is called.
- The rcar_dmac_chan_get_residue() will not find any descriptors.
- And, the following WARNING happens:
WARN(1, "No descriptor for cookie!");
The sh-sci driver with HSCIF (921,600bps) on R-Car H3 can cause this
situation.
So, this patch checks the done lists in rcar_dmac_chan_get_residue()
and returns zero if the done lists has the argument cookie.
Tested-by: Nguyen Viet Dung <dung.nguyen.aj@renesas.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit a3ca831249ca8c4c226e4ceafee04e280152e59d ]
When booting up with "threadirqs" in command line, all irq handlers of the DMA
controller pl330 will be threaded forcedly. These threads will race for the same
list, pl330->req_done.
Before the callback, the spinlock was released. And after it, the spinlock was
taken. This opened an race window where another threaded irq handler could steal
the spinlock and be permitted to delete entries of the list, pl330->req_done.
If the later deleted an entry that was still referred to by the former, there would
be a kernel panic when the former was scheduled and tried to get the next sibling
of the deleted entry.
The scenario could be depicted as below:
Thread: T1 pl330->req_done Thread: T2
| -A-B-C-D- |
Locked | |
| | Waiting
Del A | |
| -B-C-D- |
Unlocked | |
| | Locked
Waiting | |
| | Del B
| -C-D- Unlocked
Waiting | |
Locked
get C via B
- Kernel panic
The kernel panic looked like as below:
Unable to handle kernel paging request at virtual address dead000000000108
pgd = ffffff8008c9e000
[dead000000000108] *pgd=000000027fffe003, *pud=000000027fffe003, *pmd=0000000000000000
Internal error: Oops: 96000044 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 85 Comm: irq/59-66330000 Not tainted 4.8.24-WR9.0.0.12_standard #2
Hardware name: Broadcom NS2 SVK (DT)
task: ffffffc1f5cc3c00 task.stack: ffffffc1f5ce0000
PC is at pl330_irq_handler+0x27c/0x390
LR is at pl330_irq_handler+0x2a8/0x390
pc : [<ffffff80084cb694>] lr : [<ffffff80084cb6c0>] pstate: 800001c5
sp : ffffffc1f5ce3d00
x29: ffffffc1f5ce3d00 x28: 0000000000000140
x27: ffffffc1f5c530b0 x26: dead000000000100
x25: dead000000000200 x24: 0000000000418958
x23: 0000000000000001 x22: ffffffc1f5ccd668
x21: ffffffc1f5ccd590 x20: ffffffc1f5ccd418
x19: dead000000000060 x18: 0000000000000001
x17: 0000000000000007 x16: 0000000000000001
x15: ffffffffffffffff x14: ffffffffffffffff
x13: ffffffffffffffff x12: 0000000000000000
x11: 0000000000000001 x10: 0000000000000840
x9 : ffffffc1f5ce0000 x8 : ffffffc1f5cc3338
x7 : ffffff8008ce2020 x6 : 0000000000000000
x5 : 0000000000000000 x4 : 0000000000000001
x3 : dead000000000200 x2 : dead000000000100
x1 : 0000000000000140 x0 : ffffffc1f5ccd590
Process irq/59-66330000 (pid: 85, stack limit = 0xffffffc1f5ce0020)
Stack: (0xffffffc1f5ce3d00 to 0xffffffc1f5ce4000)
3d00: ffffffc1f5ce3d80 ffffff80080f09d0 ffffffc1f5ca0c00 ffffffc1f6f7c600
3d20: ffffffc1f5ce0000 ffffffc1f6f7c600 ffffffc1f5ca0c00 ffffff80080f0998
3d40: ffffffc1f5ce0000 ffffff80080f0000 0000000000000000 0000000000000000
3d60: ffffff8008ce202c ffffff8008ce2020 ffffffc1f5ccd668 ffffffc1f5c530b0
3d80: ffffffc1f5ce3db0 ffffff80080f0d70 ffffffc1f5ca0c40 0000000000000001
3da0: ffffffc1f5ce0000 ffffff80080f0cfc ffffffc1f5ce3e20 ffffff80080bf4f8
3dc0: ffffffc1f5ca0c80 ffffff8008bf3798 ffffff8008955528 ffffffc1f5ca0c00
3de0: ffffff80080f0c30 0000000000000000 0000000000000000 0000000000000000
3e00: 0000000000000000 0000000000000000 0000000000000000 ffffff80080f0b68
3e20: 0000000000000000 ffffff8008083690 ffffff80080bf420 ffffffc1f5ca0c80
3e40: 0000000000000000 0000000000000000 0000000000000000 ffffff80080cb648
3e60: ffffff8008b1c780 0000000000000000 0000000000000000 ffffffc1f5ca0c00
3e80: ffffffc100000000 ffffff8000000000 ffffffc1f5ce3e90 ffffffc1f5ce3e90
3ea0: 0000000000000000 ffffff8000000000 ffffffc1f5ce3eb0 ffffffc1f5ce3eb0
3ec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3ee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3fa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3fc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
3fe0: 0000000000000000 0000000000000000 0000000275ce3ff0 0000000275ce3ff8
Call trace:
Exception stack(0xffffffc1f5ce3b30 to 0xffffffc1f5ce3c60)
3b20: dead000000000060 0000008000000000
3b40: ffffffc1f5ce3d00 ffffff80084cb694 0000000000000008 0000000000000e88
3b60: ffffffc1f5ce3bb0 ffffff80080dac68 ffffffc1f5ce3b90 ffffff8008826fe4
3b80: 00000000000001c0 00000000000001c0 ffffffc1f5ce3bb0 ffffff800848dfcc
3ba0: 0000000000020000 ffffff8008b15ae4 ffffffc1f5ce3c00 ffffff800808f000
3bc0: 0000000000000010 ffffff80088377f0 ffffffc1f5ccd590 0000000000000140
3be0: dead000000000100 dead000000000200 0000000000000001 0000000000000000
3c00: 0000000000000000 ffffff8008ce2020 ffffffc1f5cc3338 ffffffc1f5ce0000
3c20: 0000000000000840 0000000000000001 0000000000000000 ffffffffffffffff
3c40: ffffffffffffffff ffffffffffffffff 0000000000000001 0000000000000007
[<ffffff80084cb694>] pl330_irq_handler+0x27c/0x390
[<ffffff80080f09d0>] irq_forced_thread_fn+0x38/0x88
[<ffffff80080f0d70>] irq_thread+0x140/0x200
[<ffffff80080bf4f8>] kthread+0xd8/0xf0
[<ffffff8008083690>] ret_from_fork+0x10/0x40
Code: f2a00838 f9405763 aa1c03e1 aa1503e0 (f9000443)
---[ end trace f50005726d31199c ]---
Kernel panic - not syncing: Fatal exception in interrupt
SMP: stopping secondary CPUs
SMP: failed to stop secondary CPUs 0-1
Kernel Offset: disabled
Memory Limit: none
---[ end Kernel panic - not syncing: Fatal exception in interrupt
To fix this, re-start with the list-head after dropping the lock then
re-takeing it.
Reviewed-by: Frank Mori Hess <fmh6jj@gmail.com>
Tested-by: Frank Mori Hess <fmh6jj@gmail.com>
Signed-off-by: Qi Hou <qi.hou@windriver.com>
[ Upstream commit 90c29ed7627b6b4aeb603ee197650173c8434512 ]
hdr.len includes both the size of the header and the fragment, so using
this when stepping through the firmware causes us to skip 16 bytes every
chunk of 3072 bytes; causing only the first fragment to actually be
valid data.
Instead use fragment size steps through the firmware blob.
Fixes: ea7a1f275cf0 ("soc: qcom: Introduce WCNSS_CTRL SMD client")
Reported-by: Will Newton <will.newton@gmail.com>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
[ Upstream commit 2bbea6e117357d17842114c65e9a9cf2d13ae8a3 ]
when mounting an ISO filesystem sometimes (very rarely)
the system hangs because of a race condition between two tasks.
PID: 6766 TASK: ffff88007b2a6dd0 CPU: 0 COMMAND: "mount"
#0 [ffff880078447ae0] __schedule at ffffffff8168d605
#1 [ffff880078447b48] schedule_preempt_disabled at ffffffff8168ed49
#2 [ffff880078447b58] __mutex_lock_slowpath at ffffffff8168c995
#3 [ffff880078447bb8] mutex_lock at ffffffff8168bdef
#4 [ffff880078447bd0] sr_block_ioctl at ffffffffa00b6818 [sr_mod]
#5 [ffff880078447c10] blkdev_ioctl at ffffffff812fea50
#6 [ffff880078447c70] ioctl_by_bdev at ffffffff8123a8b3
#7 [ffff880078447c90] isofs_fill_super at ffffffffa04fb1e1 [isofs]
#8 [ffff880078447da8] mount_bdev at ffffffff81202570
#9 [ffff880078447e18] isofs_mount at ffffffffa04f9828 [isofs]
#10 [ffff880078447e28] mount_fs at ffffffff81202d09
#11 [ffff880078447e70] vfs_kern_mount at ffffffff8121ea8f
#12 [ffff880078447ea8] do_mount at ffffffff81220fee
#13 [ffff880078447f28] sys_mount at ffffffff812218d6
#14 [ffff880078447f80] system_call_fastpath at ffffffff81698c49
RIP: 00007fd9ea914e9a RSP: 00007ffd5d9bf648 RFLAGS: 00010246
RAX: 00000000000000a5 RBX: ffffffff81698c49 RCX: 0000000000000010
RDX: 00007fd9ec2bc210 RSI: 00007fd9ec2bc290 RDI: 00007fd9ec2bcf30
RBP: 0000000000000000 R8: 0000000000000000 R9: 0000000000000010
R10: 00000000c0ed0001 R11: 0000000000000206 R12: 00007fd9ec2bc040
R13: 00007fd9eb6b2380 R14: 00007fd9ec2bc210 R15: 00007fd9ec2bcf30
ORIG_RAX: 00000000000000a5 CS: 0033 SS: 002b
This task was trying to mount the cdrom. It allocated and configured a
super_block struct and owned the write-lock for the super_block->s_umount
rwsem. While exclusively owning the s_umount lock, it called
sr_block_ioctl and waited to acquire the global sr_mutex lock.
PID: 6785 TASK: ffff880078720fb0 CPU: 0 COMMAND: "systemd-udevd"
#0 [ffff880078417898] __schedule at ffffffff8168d605
#1 [ffff880078417900] schedule at ffffffff8168dc59
#2 [ffff880078417910] rwsem_down_read_failed at ffffffff8168f605
#3 [ffff880078417980] call_rwsem_down_read_failed at ffffffff81328838
#4 [ffff8800784179d0] down_read at ffffffff8168cde0
#5 [ffff8800784179e8] get_super at ffffffff81201cc7
#6 [ffff880078417a10] __invalidate_device at ffffffff8123a8de
#7 [ffff880078417a40] flush_disk at ffffffff8123a94b
#8 [ffff880078417a88] check_disk_change at ffffffff8123ab50
#9 [ffff880078417ab0] cdrom_open at ffffffffa00a29e1 [cdrom]
#10 [ffff880078417b68] sr_block_open at ffffffffa00b6f9b [sr_mod]
#11 [ffff880078417b98] __blkdev_get at ffffffff8123ba86
#12 [ffff880078417bf0] blkdev_get at ffffffff8123bd65
#13 [ffff880078417c78] blkdev_open at ffffffff8123bf9b
#14 [ffff880078417c90] do_dentry_open at ffffffff811fc7f7
#15 [ffff880078417cd8] vfs_open at ffffffff811fc9cf
#16 [ffff880078417d00] do_last at ffffffff8120d53d
#17 [ffff880078417db0] path_openat at ffffffff8120e6b2
#18 [ffff880078417e48] do_filp_open at ffffffff8121082b
#19 [ffff880078417f18] do_sys_open at ffffffff811fdd33
#20 [ffff880078417f70] sys_open at ffffffff811fde4e
#21 [ffff880078417f80] system_call_fastpath at ffffffff81698c49
RIP: 00007f29438b0c20 RSP: 00007ffc76624b78 RFLAGS: 00010246
RAX: 0000000000000002 RBX: ffffffff81698c49 RCX: 0000000000000000
RDX: 00007f2944a5fa70 RSI: 00000000000a0800 RDI: 00007f2944a5fa70
RBP: 00007f2944a5f540 R8: 0000000000000000 R9: 0000000000000020
R10: 00007f2943614c40 R11: 0000000000000246 R12: ffffffff811fde4e
R13: ffff880078417f78 R14: 000000000000000c R15: 00007f2944a4b010
ORIG_RAX: 0000000000000002 CS: 0033 SS: 002b
This task tried to open the cdrom device, the sr_block_open function
acquired the global sr_mutex lock. The call to check_disk_change()
then saw an event flag indicating a possible media change and tried
to flush any cached data for the device.
As part of the flush, it tried to acquire the super_block->s_umount
lock associated with the cdrom device.
This was the same super_block as created and locked by the previous task.
The first task acquires the s_umount lock and then the sr_mutex_lock;
the second task acquires the sr_mutex_lock and then the s_umount lock.
This patch fixes the issue by moving check_disk_change() out of
cdrom_open() and let the caller take care of it.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
[ Upstream commit ecb29abd4cb0670c616fb563a078f25d777ce530 ]
A negative page register value means that no page needs to be
selected. This is used by status register read operations and needs
to be accepted. The failure to do so so results in missed status
and limit registers.
Fixes: da8e48ab483e1 ("hwmon: (pmbus) Always call _pmbus_read_byte in core driver")
[ Upstream commit a46f8cd696624ef757be0311eb28f119c36778e8 ]
selected. This is used by status register evaluations and needs
to be accepted.
[ Upstream commit 5651e5e094591f479adad5830ac1bc45196a39b3 ]
This fixes bad color output. When I was first testing the device I
had the DPI hardware set to 666 mode, but apparently in the refactor
to use the bus_format information from the panel driver, I failed to
actually update the panel.
Signed-off-by: Eric Anholt <eric@anholt.net>
Fixes: e8b6f561b2ee ("drm/panel: simple: Add the 7" DPI panel from Adafruit")
Cc: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180309233332.1769-1-eric@anholt.net
[ Upstream commit f002612b9d86613bc6fde0a444e0095225f6053e ]
This happens when BMC doesn't return any data and the code is trying
to print the value of data[2].
Getting following crash:
[ 484.728410] Unable to handle kernel NULL pointer dereference at virtual address 00000002
[ 484.736496] pgd = ffff0000094a2000
[ 484.739885] [00000002] *pgd=00000047fcffe003, *pud=00000047fcffd003, *pmd=0000000000000000
[ 484.748158] Internal error: Oops: 96000005 [#1] SMP
[ 485.101451] Call trace:
[ 485.188473] [<ffff000000a46e68>] msg_done_handler+0x668/0x700 [ipmi_ssif]
[ 485.195249] [<ffff000000a456b8>] ipmi_ssif_thread+0x110/0x128 [ipmi_ssif]
[ 485.202038] [<ffff0000080f1430>] kthread+0x108/0x138
[ 485.206994] [<ffff0000080838e0>] ret_from_fork+0x10/0x30
[ 485.212294] Code: aa1903e1 aa1803e0 b900227f 95fef6a5 (39400aa3)
Adding a check to validate the data len before printing data[2] to fix this issue.
Signed-off-by: Kamlakant Patel <kamlakant.patel@cavium.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
[ Upstream commit 5775b843a619b3c93f946e2b55a208d9f0f48b59 ]
We leave PCI devices not bound to a driver in D0 during runtime suspend.
But they may have a parent which is bound and can be transitioned to
D3cold at runtime. Once the parent goes to D3cold, the unbound child
may go to D3cold as well. When the child goes to D3cold, its internal
state, including configuration of BARs, MSI, ASPM, MPS, etc., is lost.
One example are recent hybrid graphics laptops which cut power to the
discrete GPU when the root port above it goes to ACPI power state D3.
Users may provoke this by unbinding the GPU driver and allowing runtime
PM on the GPU via sysfs: The PM core will then treat the GPU as
"suspended", which in turn allows the root port to runtime suspend,
causing the power resources listed in its _PR3 object to be powered off.
The GPU's BARs will be uninitialized when a driver later probes it.
Another example are hybrid graphics laptops where the GPU itself (rather
than the root port) is capable of runtime suspending to D3cold. If the
GPU's integrated HDA controller is not bound and the GPU's driver
decides to runtime suspend to D3cold, the HDA controller's BARs will be
Fix by saving and restoring config space over a runtime suspend cycle
even if the device is not bound.
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Tested-by: Peter Wu <peter@lekensteyn.nl> # Nvidia Optimus
Tested-by: Lukas Wunner <lukas@wunner.de> # MacBook Pro
[lukas: add commit message, bikeshed code comments for clarity]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Link: https://patchwork.freedesktop.org/patch/msgid/92fb6e6ae2730915eb733c08e2f76c6a313e3860.1520068884.git.lukas@wunner.de
[ Upstream commit bc3cc75281b3c2b1c5355d88d147b66a753bb9a5 ]
For some reason, commit c0368e4db4a3 ("spi: bcm-qspi: Fix use after free
in bcm_qspi_probe() in error path") has updated some gotos, but not all of
them.
This looks spurious, so fix it.
Fixes: fa236a7ef240 ("spi: bcm-qspi: Add Broadcom MSPI driver")
[ Upstream commit ed8cffda27dea6fd3dafb3ee881c5a786edac9ca ]
Re-order error handling code and gotos to avoid leaks in error handling
paths.
Fixes: 9f946099fe19 ("regulator: gpio: fix parsing of gpio list")
[ Upstream commit 563c4ba3bd2b8b0b21c65669ec2226b1cfa1138b ]
ah_attr contains the port number to which cm_id is bound. However, while
searching for GID table for matching GID entry, the port number is
ignored.
This could cause the wrong GID to be used when the ah_attr is converted to
an AH.
Signed-off-by: Leon Romanovsky <leon@kernel.org>
[ Upstream commit 31184d8c6ea49ea0676d100cdd7e1f102ad025b5 ]
The errata FE-8471889 description has been updated. There is still a
timing violation for repeated start. But the errata now states that it
was only the case for the Standard mode (100 kHz), in Fast mode (400 kHz)
there is no issue.
This patch limit the errata fix to the Standard mode.
It has been tesed successfully on the clearfog (Aramda 388 based board).
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit d7cb44496a9bb458632cb3c18acb08949c210448 ]
Setting sge_uld_rxq_info to NULL in free_queues_uld().
We are referencing sge_uld_rxq_info in cxgb_up(). This
will fix a panic when interface is brought up after a
ULDq creation failure.
Fixes: 94cdb8bb993a (cxgb4: Add support for dynamic allocation
of resources for ULD)
Signed-off-by: Arjun Vynipadath <arjun@chelsio.com>
Signed-off-by: Casey Leedom <leedom@chelsio.com>
Signed-off-by: Ganesh Goudhar <ganeshgr@chelsio.com>
[ Upstream commit 97f3c0a4b0579b646b6b10ae5a3d59f0441cc12c ]
I found an ACPI cache leak in ACPI early termination and boot continuing case.
When early termination occurs due to malicious ACPI table, Linux kernel
terminates ACPI function and continues to boot process. While kernel terminates
ACPI function, kmem_cache_destroy() reports Acpi-Operand cache leak.
Boot log of ACPI operand cache leak is as follows:
>[ 0.464168] ACPI: Added _OSI(Module Device)
>[ 0.467022] ACPI: Added _OSI(Processor Device)
>[ 0.469376] ACPI: Added _OSI(3.0 _SCP Extensions)
>[ 0.471647] ACPI: Added _OSI(Processor Aggregator Device)
>[ 0.477997] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.482706] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.487503] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.492136] ACPI Error: Method parse/execution failed [\_SB._INI] (Node ffff88021710a618), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.497683] ACPI: Interpreter enabled
>[ 0.499385] ACPI: (supports S0)
>[ 0.501151] ACPI: Using IOAPIC for interrupt routing
>[ 0.503342] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.506522] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.510463] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.514477] ACPI Error: Method parse/execution failed [\_PIC] (Node ffff88021710ab18), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.518867] ACPI Exception: AE_AML_INTERNAL, Evaluating _PIC (20170303/bus-991)
>[ 0.522384] kmem_cache_destroy Acpi-Operand: Slab cache still has objects
>[ 0.524597] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.12.0-rc5 #26
>[ 0.526795] Hardware name: innotek gmb_h virtual_box/virtual_box, BIOS virtual_box 12/01/2006
>[ 0.529668] Call Trace:
>[ 0.530811] ? dump_stack+0x5c/0x81
>[ 0.532240] ? kmem_cache_destroy+0x1aa/0x1c0
>[ 0.533905] ? acpi_os_delete_cache+0xa/0x10
>[ 0.535497] ? acpi_ut_delete_caches+0x3f/0x7b
>[ 0.537237] ? acpi_terminate+0xa/0x14
>[ 0.538701] ? acpi_init+0x2af/0x34f
>[ 0.540008] ? acpi_sleep_proc_init+0x27/0x27
>[ 0.541593] ? do_one_initcall+0x4e/0x1a0
>[ 0.543008] ? kernel_init_freeable+0x19e/0x21f
>[ 0.546202] ? rest_init+0x80/0x80
>[ 0.547513] ? kernel_init+0xa/0x100
>[ 0.548817] ? ret_from_fork+0x25/0x30
>[ 0.550587] vgaarb: loaded
>[ 0.551716] EDAC MC: Ver: 3.0.0
>[ 0.553744] PCI: Probing PCI hardware
>[ 0.555038] PCI host bridge to bus 0000:00
> ... Continue to boot and log is omitted ...
I analyzed this memory leak in detail and found acpi_ns_evaluate() function
only removes Info->return_object in AE_CTRL_RETURN_VALUE case. But, when errors
occur, the status value is not AE_CTRL_RETURN_VALUE, and Info->return_object is
also not null. Therefore, this causes acpi operand memory leak.
This cache leak causes a security threat because an old kernel (<= 4.9) shows
memory locations of kernel functions in stack dump. Some malicious users
could use this information to neutralize kernel ASLR.
I made a patch to fix ACPI operand cache leak.
Signed-off-by: Seunghun Han <kkamagui@gmail.com>
Signed-off-by: Erik Schmauss <erik.schmauss@intel.com>
[ Upstream commit b4c0de312613ca676db5bd7e696a44b56795612a ]
This ensures that acpi_ev_fixed_event_detect() does not use fixed_status
and and fixed_enable as uninitialized variables.
[ Upstream commit fadd94e05c02afec7b70b0b14915624f1782f578 ]
In patch "bcache: fix cached_dev->count usage for bch_cache_set_error()",
cached_dev_get() is called when creating dc->writeback_thread, and
cached_dev_put() is called when exiting dc->writeback_thread. This
modification works well unless people detach the bcache device manually by
'echo 1 > /sys/block/bcache<N>/bcache/detach'
Because this sysfs interface only calls bch_cached_dev_detach() which wakes
up dc->writeback_thread but does not stop it. The reason is, before patch
"bcache: fix cached_dev->count usage for bch_cache_set_error()", inside
bch_writeback_thread(), if cache is not dirty after writeback,
cached_dev_put() will be called here. And in cached_dev_make_request() when
a new write request makes cache from clean to dirty, cached_dev_get() will
be called there. Since we don't operate dc->count in these locations,
refcount d->count cannot be dropped after cache becomes clean, and
cached_dev_detach_finish() won't be called to detach bcache device.
This patch fixes the issue by checking whether BCACHE_DEV_DETACHING is
set inside bch_writeback_thread(). If this bit is set and cache is clean
(no existing writeback_keys), break the while-loop, call cached_dev_put()
and quit the writeback thread.
Please note if cache is still dirty, even BCACHE_DEV_DETACHING is set the
writeback thread should continue to perform writeback, this is the original
design of manually detach.
It is safe to do the following check without locking, let me explain why,
+ if (!test_bit(BCACHE_DEV_DETACHING, &dc->disk.flags) &&
+ (!atomic_read(&dc->has_dirty) || !dc->writeback_running)) {
If the kenrel thread does not sleep and continue to run due to conditions
are not updated in time on the running CPU core, it just consumes more CPU
cycles and has no hurt. This should-sleep-but-run is safe here. We just
focus on the should-run-but-sleep condition, which means the writeback
thread goes to sleep in mistake while it should continue to run.
1, First of all, no matter the writeback thread is hung or not,
kthread_stop() from cached_dev_detach_finish() will wake up it and
terminate by making kthread_should_stop() return true. And in normal
run time, bit on index BCACHE_DEV_DETACHING is always cleared, the
condition
is always true and can be ignored as constant value.
2, If one of the following conditions is true, the writeback thread should
go to sleep,
"!atomic_read(&dc->has_dirty)" or "!dc->writeback_running)"
each of them independently controls the writeback thread should sleep or
not, let's analyse them one by one.
2.1 condition "!atomic_read(&dc->has_dirty)"
If dc->has_dirty is set from 0 to 1 on another CPU core, bcache will
call bch_writeback_queue() immediately or call bch_writeback_add() which
indirectly calls bch_writeback_queue() too. In bch_writeback_queue(),
wake_up_process(dc->writeback_thread) is called. It sets writeback
thread's task state to TASK_RUNNING and following an implicit memory
barrier, then tries to wake up the writeback thread.
In writeback thread, its task state is set to TASK_INTERRUPTIBLE before
doing the condition check. If other CPU core sets the TASK_RUNNING state
after writeback thread setting TASK_INTERRUPTIBLE, the writeback thread
will be scheduled to run very soon because its state is not
TASK_INTERRUPTIBLE. If other CPU core sets the TASK_RUNNING state before
writeback thread setting TASK_INTERRUPTIBLE, the implict memory barrier
of wake_up_process() will make sure modification of dc->has_dirty on
other CPU core is updated and observed on the CPU core of writeback
thread. Therefore the condition check will correctly be false, and
continue writeback code without sleeping.
2.2 condition "!dc->writeback_running)"
dc->writeback_running can be changed via sysfs file, every time it is
modified, a following bch_writeback_queue() is alwasy called. So the
change is always observed on the CPU core of writeback thread. If
dc->writeback_running is changed from 0 to 1 on other CPU core, this
condition check will observe the modification and allow writeback
thread to continue to run without sleeping.
Now we can see, even without a locking protection, multiple conditions
check is safe here, no deadlock or process hang up will happen.
I compose a separte patch because that patch "bcache: fix cached_dev->count
usage for bch_cache_set_error()" already gets a "Reviewed-by:" from Hannes
Reinecke. Also this fix is not trivial and good for a separate patch.
Signed-off-by: Coly Li <colyli@suse.de>
Reviewed-by: Michael Lyle <mlyle@lyle.org>
Cc: Huijun Tang <tang.junhui@zte.com.cn>
[ Upstream commit 55496d3fe2acd1a365c43cbd613a20ecd4d74395 ]
The generic DMA API uses dev->dma_mask to check the DMA addressable
memory bitmask, and warns if no mask is set or even allocated.
Set z->dev.dma_coherent_mask on Zorro bus scan, and make z->dev.dma_mask
to point to z->dev.dma_coherent_mask so device drivers that need DMA have
everything set up to avoid warnings from dma_alloc_coherent(). Drivers can
still use dma_set_mask_and_coherent() to explicitly set their DMA bit mask.
Signed-off-by: Michael Schmitz <schmitzmic@gmail.com>
[geert: Handle Zorro II with 24-bit address space]
Acked-by: Christoph Hellwig <hch@lst.de>
[ Upstream commit 55b55abc17f238c61921360e61dde90dd9a326d1 ]
Kmemleak reported the below leak. When cppc_cpufreq_init went into
failure path, the cpu mask is not freed. After fix, this report is
gone. And to avaoid potential NULL pointer reference, check the cpu
value first.
unreferenced object 0xffff800fd5ea4880 (size 128):
comm "swapper/0", pid 1, jiffies 4294939510 (age 668.680s)
hex dump (first 32 bytes):
00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 .... ...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffff0000082c4ae4>] __kmalloc_node+0x278/0x634
[<ffff0000088f4a74>] alloc_cpumask_var_node+0x28/0x60
[<ffff0000088f4af0>] zalloc_cpumask_var+0x14/0x1c
[<ffff000008d20254>] cppc_cpufreq_init+0xd0/0x19c
[<ffff000008083828>] do_one_initcall+0xec/0x15c
[<ffff000008cd1018>] kernel_init_freeable+0x1f4/0x2a4
[<ffff0000089099b0>] kernel_init+0x18/0x10c
[<ffff000008084d50>] ret_from_fork+0x10/0x18
[<ffffffffffffffff>] 0xffffffffffffffff
Signed-off-by: Chunyu Hu <chuhu@redhat.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
