commit c031235b395433350f25943b7580a5e343c7b7b2 upstream.
Don't flap VCs when carrier state changes; higher-level protocols
can detect loss of connectivity and act accordingly. This is more
consistent with how other network interfaces work.
We no longer use release_vccs() so we can delete it.
release_vccs() was duplicated from net/atm/common.c; make the
corresponding function exported, since other code duplicates it
and could leverage it if it were public.
Signed-off-by: Philip A. Prindeville <philipp@redfish-solutions.com>
commit 18b429e74eeafe42e947b1b0f9a760c7153a0b5c upstream.
Omit pkt_hdr preamble when dumping transmitted packet as hex-dump;
we can pull this up because the frame has already been sent, and
dumping it is the last thing we do with it before freeing it.
Also include the size, vpi, and vci in the debug as is done on
receive.
Use "port" consistently instead of "device" intermittently.
Signed-off-by: Philip Prindeville <philipp@redfish-solutions.com>
commit 8215af019040ce9182728afee9642d8fdeb17f59 upstream.
Acer BIOS keeps devices state when system reboot, but reset to default
device states (Wlan on, Bluetooth off, wwan on) if system cold boot.
That means BIOS's initial state is not always real persistence.
So, removed rfkill_init_sw_state because it sets initial state to
persistence then replicate to other new killswitch when rfkill-input
enabled.
After removed it, acer-wmi set initial soft-block state after rfkill
register, and doesn't allow set_block until rfkill initial finished.
Reference: bko#31002
https://bugzilla.kernel.org/show_bug.cgi?id=31002
Cc: Carlos Corbacho <carlos@strangeworlds.co.uk>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: OldÅich JedliÄka <oldium.pro@seznam.cz>
Cc: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Chun-Yi Lee <jlee@novell.com>
pd_vidioc_s_fmt
commit a07500ef690fcbec76e879ee2093d7ca69883825 upstream.
Error path in file drivers/media/video/tlg2300/pd-video.c:
1. First mutex_unlock on &pd->lock in line 767 (in function that
called from line 805)
2. Second in line 806
805 pd_vidioc_s_fmt(pd, &f->fmt.pix);
806 mutex_unlock(&pd->lock);
Found by Linux Device Drivers Verification Project
Signed-off-by: Alexander Strakh <strakh@ispras.ru>
Acked-by: Huang Shijie <shijie8@gmail.com>
commit 67d1da79b25c05d9a38b820bb5b5d89c91070ab2 upstream.
Don't allow everybody to change LED settings.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
commit ccd7510fd8dea5b4b2af87fb2aef2ebd6b23b76b upstream.
commit deb187e72470b0382d4f0cb859e76e1ebc3a1082 upstream.
Don't allow everybody to change device settings.
Acked-by: Hartley Sweeten <hartleys@visionengravers.com>
Cc: Matthieu Crapet <mcrapet@gmail.com>
commit 49d50fb1c28738ef6bad0c2b87d5355a1653fed5 upstream.
Don't allow everybogy to write to NVRAM.
Cc: Andy Sharp <andy.sharp@onstor.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
commit f8a0697722d12a201588225999cfc8bfcbc82781 upstream.
Don't allow everybody to change device hardware registers.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
commit 90c861c2a83d974684974441093ff8a50e6b430b upstream.
Don't allow everybody to interact with hardware registers.
commit 44bdcb54df2714da18c4a0c6f711a350ab4ed93c upstream.
commit 523f3c80bc41d663d5b35c0cd6ce0fad7f3e7188 upstream.
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 1309d7afbed112f0e8e90be9af975550caa0076b upstream.
This patch fixes information leakage to the userspace by initializing
the data buffer to zero.
Reported-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Peter Huewe <huewe.external@infineon.com>
Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com>
[ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way
deeper problems than a simple multiplication can fix. - Linus ]
commit 63a8588debd4dc72becb9e27add9343c76301c7d upstream.
Just adding the vendor details makes it work fine.
Signed-off-by: Marc-Antoine Perennou <Marc-Antoine@Perennou.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Tested-by: Grant Likely <grant.likely@secretlab.ca>
commit c85ce65ecac078ab1a1835c87c4a6319cf74660a upstream.
Otherwise, skb_put inside of dma_rx can fail...
https://bugzilla.kernel.org/show_bug.cgi?id=32042
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit 1b149bbe9156d2eb2afd5a072bd61ad0d4bfaca7 upstream.
RADIO_WL1273 needs to make sure that the mfd core is built to avoid
build errors:
ERROR: "mfd_add_devices" [drivers/mfd/wl1273-core.ko] undefined!
ERROR: "mfd_remove_devices" [drivers/mfd/wl1273-core.ko] undefined!
Cc: Matti Aaltonen <matti.j.aaltonen@nokia.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
commit 09b661b33268698d3b453dceb78cda129ad899b4 upstream.
We were allocating the size of the NVS file struct and not checking
whether the length of the buffer passed was correct before copying it
into the allocated memory. This is a security hole because buffer
overflows can occur if the userspace passes a bigger file than what is
expected.
With this patch, we check if the size of the data passed from
userspace matches the size required.
This bug was introduced in 2.6.36.
Reported-by: Ido Yariv <ido@wizery.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
commit 37f4ee0b6b39640828dac5937a482c20e8ac794f upstream.
{rx,tx}done_work's are only initialized for usb devices.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 7f6e144fb99a4a70d3c5ad5f074204c5b89a6f65 upstream.
PCI/PCIE radio off behavior is different from SOC/USB.
They mainly use MCU command to disable DMA, TX/RX and enter power saving mode.
Signed-off-by: RA-Jay Hung <jay_hung@ralinktech.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 220107610c7c2c9703e09eb363e8ab31025b9315 upstream.
Reported-by: Mark Davis [via p54/devices wiki]
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 3d7dc7e8c1566acb0fc55df228b2ed91f5638e9d upstream.
A number of these devices have appeared "in the wild", and apparently
the Windows driver is perfectly happy to support this EEPROM version.
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
pushed into the ring
commit 0fea4d6192cb82789e28905240d3c1dac6529c7c upstream.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
commit b181119723d62b19904e1f12e467e996631c5a29 upstream.
commit c59c95ce6ace6d256401fc3a3648a95375ef4e63 upstream.
Add delay after self test to satisfy timing requirements.
Increase start-up delay.
commit fc5b85b0ad1f9da948e4d683710081a9bda357cb upstream.
cs_change must not be set in the last transfer of a spi message
commit f62d816fc4324afbb7cf90110c70b6a14139b225 upstream.
When the chip is still asleep when ath9k_start is called,
ath9k_hw_configpcipowersave can trigger a data bus error.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 708748670c7c6dd5bd3b141473086e6937e72737 upstream.
'struct dmi_system_id' arrays must always have a terminator to keep
dmi_check_system() from looking at data (and possibly crashing) it
isn't supposed to look at.
The issue went unnoticed until ef8313bb1a22e7d2125d9d758aa8a81f1de91d81,
but was introduced about a year earlier with
7705d548cbe33f18ea7713b9a07aa11047aaeca4 (which also similarly changed
lifebook.c, but the problem there got eliminated shortly afterwards).
The first hunk therefore is a stable candidate back to 2.6.33, while
the full change is needed only on 2.6.38.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
commit cc5e0f08ca2a66fc4c6984ccff74fd529e969fac upstream.
The evdev buffer isn't big enough when you get many fingers on the
device. Bump up the buffer to a reasonable size, matching what other
multitouch devices use. Without this change, events may be discarded in
the evdev buffer before they are read.
Reported-by: Simon Budig <simon@budig.de>
Cc: Henrik Rydberg <rydberg@euromail.se>
Cc: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
commit 97ea530f6fac1f9632b0c4792a2a56411454adbe upstream.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=35502
agd5f: also add sanity check to connector records.
v2: fix one more case.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit 673e63c688f43104c73aad8ea4237f7ad41fa14d upstream.
After commit d5dbda23804156ae6f35025ade5307a49d1db6d7 "ethtool: Add
support for vlan accleration.", drivers that have NETIF_F_HW_VLAN_TX,
and/or NETIF_F_HW_VLAN_RX feature, but do not allow enable/disable vlan
acceleration via ethtool set_flags, always return -EINVAL from that
function. Fix by returning -EINVAL only if requested features do not
match current settings and can not be changed by driver.
Change any driver that define ethtool->set_flags to use
ethtool_invalid_flags() to avoid similar problems in the future
(also on drivers that do not have the problem).
Tested with modified (to reproduce this bug) myri10ge driver.
commit 90d241edd13bdeef70f264b569f7e150bf23621e upstream.
Stefano found SP5100 TCO watchdog driver using wrong address.
[ 9.148536] SP5100 TCO timer: SP5100 TCO WatchDog Timer Driver v0.01
[ 9.148628] DEBUG __ioremap_caller WARNING address=b8fe00 size=8 valid=1 reserved=1
and e820 said that range is RAM.
We should check if we can use that reading out. BIOS could just program wrong address there.
Reported-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by:Yinghai Lu <yinghai@kernel.org>
Acked-by: Mike Waychison <mikew@google.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit f712eacf02ecfbf4f1686addb8c569841549b0b7 upstream.
Request_mem_region should be used with release_mem_region, not
release_resource.
In pnx4008_wdt.c, a missing clk_put is added as well.
The semantic match that finds the first problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,E;
*x = request_mem_region(...)
... when != release_mem_region(x)
when != x = E
* release_resource(x);
// </smpl>
release_region/release_mem_region
commit f72401e94d159bc4b2beab51d74e956da2c32e0a upstream.
release_resource.
The semantic match that finds this problem is as follows:
// <smpl>
expression x,E;
when != x = E
// </smpl>
commit a9f0fbe2bbf328f869fc5ee5a12c6a4118c32689 upstream.
We check the pointers together but at least one of them could be invalid
due to failed allocation. Since we cannot continue if either of the two
allocations has failed, exit early by freeing them both.
Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
commit c996edcf1c451b81740abbcca5257ed7e353fcc6 upstream.
After Quick Migration, the network is not immediately operational in the
current context when receiving RNDIS_STATUS_MEDIA_CONNECT event. So, I added
another netif_notify_peers() into a scheduled work, otherwise GARP packet will
not be sent after quick migration, and cause network disconnection.
Thanks to Mike Surcouf <mike@surcouf.co.uk> for reporting the bug and
testing the patch.
Reported-by: Mike Surcouf <mike@surcouf.co.uk>
Tested-by: Mike Surcouf <mike@surcouf.co.uk>
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Signed-off-by: Hank Janssen <hjanssen@microsoft.com>
Signed-off-by: Abhishek Kane <v-abkane@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 22356585712d1ff08fbfed152edd8b386873b238 upstream.
Locking is required when tweaking bits located in a shared page, use the
sync_ version of bitops. Without this change vmbus_on_event() will miss
events and as a result, vmbus_isr() will not schedule the receive tasklet.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Acked-by: Haiyang Zhang <haiyangz@microsoft.com>
Acked-by: Hank Janssen <hjanssen@microsoft.com>
commit 28276a28d8b3cd19f4449991faad4945fe557656 upstream.
For isochronous packets the actual_length is the sum of the actual
length of each of the packets, however between the packets might be
padding, so it is not sufficient to just send the first actual_length
bytes of the buffer. To fix this and simultanesouly optimize the
bandwidth the content of the isochronous packets are send without the
padding, the padding is restored on the receiving end.
Signed-off-by: Arjan Mels <arjan.mels@gmx.net>
Cc: Takahiro Hirofuchi <hirofuchi@users.sourceforge.net>
Cc: Max Vozeler <max@vozeler.com>
commit 1325f85fa49f57df034869de430f7c302ae23109 upstream.
The number_of_packets was not transmitted for RET_SUBMIT packets. The
linux client used the stored number_of_packet from the submitted
request. The windows userland client does not do this however and needs
to know the number_of_packets to determine the size of the transmission.
commit d2dd0b07c3e725d386d20294ec906f7ddef207fa upstream.
When doing a usb port reset do a queued reset instead to prevent a
deadlock: the reset will cause the driver to unbind, causing the
usb_driver_lock_for_reset to stall.
commit 8b8bae901ce23addbdcdb54fa1696fb2d049feb5 upstream.
We need to distinguish the situation in which ASPM support is
disabled from the command line or through .config from the situation
in which it is disabled, because the hardware or BIOS can't handle
it. In the former case we should not report ASPM support to the BIOS
through ACPI _OSC, but in the latter case we should do that.
Introduce pcie_aspm_support_enabled() that can be used by
acpi_pci_root_add() to determine whether or not it should report ASPM
support to the BIOS through _OSC.
References: https://bugzilla.kernel.org/show_bug.cgi?id=29722
References: https://bugzilla.kernel.org/show_bug.cgi?id=20232
Reported-and-tested-by: Ortwin Glück <odi@odi.ch>
Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Tested-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 877a55979c189c590e819a61cbbe2b7947875f17 upstream.
enclosure page 7 gives us the "pretty" names of the enclosure slots.
Without a page 7, we can still use the enclosure code as long as we
make up numeric names for the slots. Unfortunately, the current code
fails to add any devices because the check for page 10 is in the wrong
place if we have no page 7. Fix it so that devices show up even if
the enclosure has no page 7.
commit 61e1b0b00c793ad5a32fe2181c9f77115fed5dc4 upstream.
Kernel panic occurs just after AR2427 establishes connection with AP.
Unless aggregation is enabled we don't initialize the TID structure.
Thus accesing the elements of the TID structure when aggregation is
disabled, leads to NULL pointer dereferencing.
[ 191.320358] Call Trace:
[ 191.320364] [<fd250ea7>] ? ath9k_tx+0xa7/0x200 [ath9k]
[ 191.320376] [<fd1ec7fc>] ? __ieee80211_tx+0x5c/0x1e0 [mac80211]
[ 191.320386] [<fd1edd2b>] ? ieee80211_tx+0x7b/0x90 [mac80211]
[ 191.320395] [<fd1edddd>] ? ieee80211_xmit+0x9d/0x1d0 [mac80211]
[ 191.320401] [<c014218f>] ? wake_up_state+0xf/0x20
[ 191.320405] [<c015dbc8>] ? signal_wake_up+0x28/0x40
[ 191.320410] [<c012a578>] ? default_spin_lock_flags+0x8/0x10
[ 191.320420] [<fd1ee308>] ? ieee80211_subif_start_xmit+0x2e8/0x7c0
[mac80211]
[ 191.320425] [<c058f905>] ? do_page_fault+0x295/0x3a0
[ 191.320431] [<c04c4a3d>] ? dev_hard_start_xmit+0x1ad/0x210
[ 191.320436] [<c04d96b5>] ? sch_direct_xmit+0x105/0x170
[ 191.320445] [<fd1f161a>] ? get_sta_flags+0x2a/0x40 [mac80211]
[ 191.320449] [<c04c780f>] ? dev_queue_xmit+0x37f/0x4b0
[ 191.320452] [<c04d75b0>] ? eth_header+0x0/0xb0
[ 191.320456] [<c04cc479>] ? neigh_resolve_output+0xe9/0x310
[ 191.320461] [<c053d295>] ? ip6_output_finish+0xa5/0x110
[ 191.320464] [<c053e354>] ? ip6_output2+0x134/0x250
[ 191.320468] [<c053f7dd>] ? ip6_output+0x6d/0x100
[ 191.320471] [<c0559665>] ? mld_sendpack+0x395/0x3e0
[ 191.320475] [<c0557f81>] ? add_grhead+0x31/0xa0
[ 191.320478] [<c055a83c>] ? mld_send_cr+0x1bc/0x2b0
[ 191.320482] [<c01535d9>] ? irq_exit+0x39/0x70
[ 191.320485] [<c055a940>] ? mld_ifc_timer_expire+0x10/0x40
[ 191.320489] [<c015b92e>] ? run_timer_softirq+0x13e/0x2c0
[ 191.320493] [<c0103a30>] ? common_interrupt+0x30/0x40
[ 191.320498] [<c055a930>] ? mld_ifc_timer_expire+0x0/0x40
[ 191.320502] [<c0153358>] ? __do_softirq+0x98/0x1b0
[ 191.320506] [<c01534b5>] ? do_softirq+0x45/0x50
[ 191.320509] [<c0153605>] ? irq_exit+0x65/0x70
[ 191.320513] [<c05917dc>] ? smp_apic_timer_interrupt+0x5c/0x8b
[ 191.320516] [<c0103df1>] ? apic_timer_interrupt+0x31/0x40
[ 191.320521] [<c016007b>] ? k_getrusage+0x12b/0x2f0
[ 191.320525] [<c039e384>] ? acpi_idle_enter_simple+0x117/0x148
[ 191.320529] [<c04a20da>] ? cpuidle_idle_call+0x7a/0x100
[ 191.320532] [<c01021d4>] ? cpu_idle+0x94/0xd0
[ 191.320536] [<c057ab88>] ? rest_init+0x58/0x60
[ 191.320541] [<c07a58ec>] ? start_kernel+0x351/0x357
[ 191.320544] [<c07a53c7>] ? unknown_bootoption+0x0/0x19e
[ 191.320548] [<c07a50aa>] ? i386_start_kernel+0xaa/0xb1
[ 191.320550] Code: 03 66 3d 00 03 0f 84 7c 02 00 00 83 c3 18 0f b6 03
8b 4d e0 89 c3 83 e3 0f 6b c3 48 89 5d d8 8d 04 06 8d 50 0c 89 55 d0 8b
40 20 <8b> 00 3b 01 0f 85 8e 02 00 00 f6 47 20 40 0f 84 29 ff ff ff 8b
[ 191.320634] EIP: [<fd2586d4>] ath_tx_start+0x474/0x770 [ath9k] SS:ESP
0068:c0761a90
[ 191.320642] CR2: 0000000000000000
[ 191.320647] ---[ end trace 9296ef23b9076ece ]---
[ 191.320650] Kernel panic - not syncing: Fatal exception in interrupt
Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
commit 1ddd5049545e0aa1a0ed19bca4d9c9c3ce1ac8a2 upstream.
Under certain workloads a command may seem to get lost. IOW, the Smart Array
thinks all commands have been completed but we still have commands in our
completion queue. This may lead to system instability, filesystems going
read-only, or even panics depending on the affected filesystem. We add an
extra read to force the write to complete.
Testing shows this extra read avoids the problem.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit cda6587c21a887254c8ed4b58da8fcc4040ab557 upstream.
Rmmod myri10ge crash at free_netdev() -> netif_napi_del(), because napi
structures are already deallocated. To fix call netif_napi_del() before
kfree() at myri10ge_free_slices().
commit dd65c736d1b5312c80c88a64bf521db4959eded5 upstream.
The dcdbas driver can do an I/O write to cause a SMI to occur. The SMI handler
looks at certain registers and memory locations, so the SMI needs to happen
immediately. On some systems I/O writes are posted, though, causing the SMI to
happen well after the "outb" occurred, which causes random failures. Following
the "outb" with an "inb" forces the write to go through even if it is posted.
Signed-off-by: Stuart Hayes <stuart_hayes@yahoo.com>
Acked-by: Doug Warzecha <douglas_warzecha@dell.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit fafcf94e2b5732d1e13b440291c53115d2b172e9 upstream.
On some servers there is a hardcoded EDID provided
in the vbios so that the driver will always see a
display connected even if something like a KVM
prevents traditional means like DDC or load
detection from working properly. Also most
server boards with DVI are not actually DVI, but
DVO connected to a virtual KVM service processor.
If we fail to detect a monitor via DDC or load
detection and a hardcoded EDID is available, use
it.
Additionally, when using the hardcoded EDID, use
a copy of it rather than the actual one stored
in the driver as the detect() and get_modes()
functions may free it if DDC is successful.
This fixes the virtual KVM on several internal
servers.
commit 64146f8b2af1ba77fe3c21d9d6d7213b9bb72b40 upstream.
ntsc seems to work fine with either algo, some
pal TVs seem pickier.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=30832
commit b74ad5ae14def5e81ad0be3dddb96e485b861b1b upstream.
As we may release the last reference, we need to store the device in a
local variable in order to unlock afterwards.
[ 60.140768] BUG: unable to handle kernel paging request at 6b6b6b9f
[ 60.140973] IP: [<c1536d11>] __mutex_unlock_slowpath+0x5a/0x111
[ 60.141014] *pdpt = 0000000024a54001 *pde = 0000000000000000
[ 60.141014] Oops: 0002 [#1] PREEMPT SMP
[ 60.141014] last sysfs file: /sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/PNP0C0A:00/power_supply/BAT0/voltage_now
[ 60.141014] Modules linked in: uvcvideo ath9k pegasus ath9k_common ath9k_hw hid_egalax ath3k joydev asus_laptop sparse_keymap battery input_polldev
[ 60.141014]
[ 60.141014] Pid: 771, comm: meego-ux-daemon Not tainted 2.6.37.2-7.1 #1 EXOPC EXOPG06411/EXOPG06411
[ 60.141014] EIP: 0060:[<c1536d11>] EFLAGS: 00010046 CPU: 0
[ 60.141014] EIP is at __mutex_unlock_slowpath+0x5a/0x111
[ 60.141014] EAX: 00000100 EBX: 6b6b6b9b ECX: e9b4a1b0 EDX: e4a4e580
[ 60.141014] ESI: db162558 EDI: 00000246 EBP: e480be50 ESP: e480be44
[ 60.141014] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[ 60.141014] Process meego-ux-daemon (pid: 771, ti=e480a000 task=e9b4a1b0 task.ti=e480a000)
[ 60.141014] Stack:
[ 60.141014] e4a4e580 db162558 f5a2f838 e480be58 c1536dd0 e480be68 c125ab1b db162558
[ 60.141014] db1624e0 e480be78 c10ba071 db162558 f760241c e480be94 c10bb0bc 000155fe
[ 60.141014] f760241c f5a2f838 f5a2f8c8 00000000 e480bea4 c1037c24 00000000 f5a2f838
[ 60.141014] Call Trace:
[ 60.141014] [<c1536dd0>] ? mutex_unlock+0x8/0xa
[ 60.141014] [<c125ab1b>] ? drm_gem_vm_close+0x39/0x3d
[ 60.141014] [<c10ba071>] ? remove_vma+0x2d/0x58
[ 60.141014] [<c10bb0bc>] ? exit_mmap+0x126/0x13f
[ 60.141014] [<c1037c24>] ? mmput+0x37/0x9a
[ 60.141014] [<c10d450d>] ? exec_mmap+0x178/0x19c
[ 60.141014] [<c1537f85>] ? _raw_spin_unlock+0x1d/0x36
[ 60.141014] [<c10d4eb0>] ? flush_old_exec+0x42/0x75
[ 60.141014] [<c1104442>] ? load_elf_binary+0x32a/0x922
[ 60.141014] [<c10d3f76>] ? search_binary_handler+0x200/0x2ea
[ 60.141014] [<c10d3ecf>] ? search_binary_handler+0x159/0x2ea
[ 60.141014] [<c1104118>] ? load_elf_binary+0x0/0x922
[ 60.141014] [<c10d56b2>] ? do_execve+0x1ff/0x2e6
[ 60.141014] [<c100970e>] ? sys_execve+0x2d/0x55
[ 60.141014] [<c1002a5a>] ? ptregs_execve+0x12/0x18
[ 60.141014] [<c10029dc>] ? sysenter_do_call+0x12/0x3c
[ 60.141014] [<c1530000>] ? init_centaur+0x9c/0x1ba
[ 60.141014] Code: c1 00 75 0f ba 38 01 00 00 b8 8c 3a 6c c1 e8 cc 2e b0 ff 9c 58 8d 74 26 00 89 c7 fa 90 8d 74 26 00 e8 d2 b4 b2 ff b8 00 01 00 00 <f0> 66 0f c1 43 04 38 e0 74 07 f3 90 8a 43 04 eb f5 83 3d 64 ef
[ 60.141014] EIP: [<c1536d11>] __mutex_unlock_slowpath+0x5a/0x111 SS:ESP 0068:e480be44
[ 60.141014] CR2: 000000006b6b6b9f
Reported-by: Rusty Lynch <rusty.lynch@intel.com>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 09bfa51773c1e90f13000dc2fc0c4b84047009bc upstream.
When i915_gem_retire_requests_ring calls i915_gem_request_remove_from_client,
the client_list for that request may already be removed in i915_gem_release.
So we may call twice list_del(&request->client_list), resulting in an
oops like this report:
[126167.230394] BUG: unable to handle kernel paging request at 00100104
[126167.230699] IP: [<f8c2ce44>] i915_gem_retire_requests_ring+0xd4/0x240 [i915]
[126167.231042] *pdpt = 00000000314c1001 *pde = 0000000000000000
[126167.231314] Oops: 0002 [#1] SMP
[126167.231471] last sysfs file: /sys/devices/LNXSYSTM:00/device:00/PNP0C0A:00/power_supply/BAT1/current_now
[126167.231901] Modules linked in: snd_seq_dummy nls_utf8 isofs btrfs zlib_deflate libcrc32c ufs qnx4 hfsplus hfs minix ntfs vfat msdos fat jfs xfs exportfs reiserfs cryptd aes_i586 aes_generic binfmt_misc vboxnetadp vboxnetflt vboxdrv parport_pc ppdev snd_hda_codec_hdmi snd_hda_codec_conexant snd_hda_intel snd_hda_codec snd_hwdep arc4 snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq uvcvideo videodev snd_timer snd_seq_device joydev iwlagn iwlcore mac80211 snd cfg80211 soundcore i915 drm_kms_helper snd_page_alloc psmouse drm serio_raw i2c_algo_bit video lp parport usbhid hid sky2 sdhci_pci ahci sdhci libahci
[126167.232018]
[126167.232018] Pid: 1101, comm: Xorg Not tainted 2.6.38-6-generic-pae #34-Ubuntu Gateway MC7833U /
[126167.232018] EIP: 0060:[<f8c2ce44>] EFLAGS: 00213246 CPU: 0
[126167.232018] EIP is at i915_gem_retire_requests_ring+0xd4/0x240 [i915]
[126167.232018] EAX: 00200200 EBX: f1ac25b0 ECX: 00000040 EDX: 00100100
[126167.232018] ESI: f1a2801c EDI: e87fc060 EBP: ef4d7dd8 ESP: ef4d7db0
[126167.232018] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[126167.232018] Process Xorg (pid: 1101, ti=ef4d6000 task=f1ba6500 task.ti=ef4d6000)
[126167.232018] Stack:
[126167.232018] f1a28000 f1a2809c f1a28094 0058bd97 f1aa2400 f1a2801c 0058bd7b 0058bd85
[126167.232018] f1a2801c f1a28000 ef4d7e38 f8c2e995 ef4d7e30 ef4d7e60 c14d1ebc f6b3a040
[126167.232018] f1522cc0 000000db 00000000 f1ba6500 ffffffa1 00000000 00000001 f1a29214
[126167.232018] Call Trace:
Unfortunately the call trace reported was cut, but looking at debug
symbols the crash is at __list_del, when probably list_del is called
twice on the same request->client_list, as the dereferenced value is
LIST_POISON1 + 4, and by looking more at the debug symbols before
list_del call it should have being called by
And as I can see in the code, it seems we indeed have the possibility
to remove a request->client_list twice, which would cause the above,
because we do list_del(&request->client_list) on both
i915_gem_request_remove_from_client and i915_gem_release
As Chris Wilson pointed out, it's indeed the case:
"(...) I had thought that the actual insertion/deletion was serialised
under the struct mutex and the intention of the spinlock was to protect
the unlocked list traversal during throttling. However, I missed that
i915_gem_release() is also called without struct mutex and so we do need
the double check for i915_gem_request_remove_from_client()."
This change does the required check to avoid the duplicate remove of
request->client_list.
Bugzilla: http://bugs.launchpad.net/bugs/733780
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
commit d4aeee776017b6da6dcd12f453cd82a3c951a0dc upstream.
Along the fast path for relocation handling, we attempt to copy directly
from the user data structures whilst holding our mutex. This causes
lockdep to warn about circular lock dependencies if we need to pagefault
the user pages. [Since when handling a page fault on a mmapped bo, we
need to acquire the struct mutex whilst already holding the mm
semaphore, it is then verboten to acquire the mm semaphore when already
holding the struct mutex. The likelihood of the user passing in the
relocations contained in a GTT mmaped bo is low, but conceivable for
extreme pathology.] In order to force the mm to return EFAULT rather
than handle the pagefault, we therefore need to disable pagefaults
across the relocation fast path.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
