commit f400991bf872debffb01c46da882dc97d7e3248e upstream.
vt_dont_switch is pure boolean, no need for whole char.
Link: https://lore.kernel.org/r/20200219073951.16151-6-jslaby@suse.cz
commit e587e8f17433ddb26954f0edf5b2f95c42155ae9 upstream.
These two were macros. Switch them to static inlines, so that it's more
understandable what they are doing.
Link: https://lore.kernel.org/r/20200219073951.16151-2-jslaby@suse.cz
commit dce05aa6eec977f1472abed95ccd71276b9a3864 upstream.
Avoid global variables (namely sel_cons) by introducing vc_is_sel. It
checks whether the parameter is the current selection console. This will
help putting sel_cons to a struct later.
Link: https://lore.kernel.org/r/20200219073951.16151-1-jslaby@suse.cz
commit a246b4d547708f33ff4d4b9a7a5dbac741dc89d8 upstream.
Make sure to check that we have two alternate settings and at least one
endpoint before accessing the second altsetting structure and
dereferencing the endpoint arrays.
This specifically avoids dereferencing NULL-pointers or corrupting
memory when a device does not have the expected descriptors.
Note that the sanity check in cit_get_packet_size() is not redundant as
the driver is mixing looking up altsettings by index and by number,
which may not coincide.
Fixes: 659fefa0eb17 ("V4L/DVB: gspca_xirlink_cit: Add support for camera with a bcd version of 0.01")
Fixes: 59f8b0bf3c12 ("V4L/DVB: gspca_xirlink_cit: support bandwidth changing for devices with 1 alt setting")
Cc: stable <stable@vger.kernel.org> # 2.6.37
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
commit 485b06aadb933190f4bc44e006076bc27a23f205 upstream.
Note that the sanity checks in stv06xx_start() and pb0100_start() are
not redundant as the driver is mixing looking up altsettings by index
and by number, which may not coincide.
Fixes: 8668d504d72c ("V4L/DVB (12082): gspca_stv06xx: Add support for st6422 bridge and sensor")
Fixes: c0b33bdc5b8d ("[media] gspca-stv06xx: support bandwidth changing")
Cc: stable <stable@vger.kernel.org> # 2.6.31
commit f52981019ad8d6718de79b425a574c6bddf81f7c upstream.
Make sure to use the current alternate setting when verifying the
interface descriptors to avoid submitting an URB to an invalid endpoint.
Failing to do so could cause the driver to misbehave or trigger a WARN()
in usb_submit_urb() that kernels with panic_on_warn set would choke on.
Fixes: c4018fa2e4c0 ("[media] dib0700: fix RC support on Hauppauge Nova-TD")
Cc: stable <stable@vger.kernel.org> # 3.16
Signed-off-by: Sean Young <sean@mess.org>
commit 998912346c0da53a6dbb71fab3a138586b596b30 upstream.
Make sure to check that we have at least one endpoint before accessing
the endpoint array to avoid dereferencing a NULL-pointer on stream
start.
Note that these sanity checks are not redundant as the driver is mixing
looking up altsettings by index and by number, which need not coincide.
Fixes: 1876bb923c98 ("V4L/DVB (12079): gspca_ov519: add support for the ov511 bridge")
Fixes: b282d87332f5 ("V4L/DVB (12080): gspca_ov519: Fix ov518+ with OV7620AE (Trust spacecam 320)")
commit 1165dd73e811a07d947aee218510571f516081f6 upstream.
We can't handle the case length > WLAN_DATA_MAXLEN.
Because the size of rxfrm->data is WLAN_DATA_MAXLEN(2312), and we can't
read more than that.
Thanks-to: Hillf Danton <hdanton@sina.com>
Reported-and-tested-by: syzbot+7d42d68643a35f71ac8a@syzkaller.appspotmail.com
Signed-off-by: Qiujun Huang <hqjagain@gmail.com>
Link: https://lore.kernel.org/r/20200326131850.17711-1-hqjagain@gmail.com
commit a1f165a6b738f0c9d744bad4af7a53909278f5fc upstream.
We should cancel hw->usb_work before kfree(hw).
Reported-by: syzbot+6d2e7f6fa90e27be9d62@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/1585120006-30042-1-git-send-email-hqjagain@gmail.com
commit 38ef48f7d4b7342f145a1b4f96023bde99aeb245 upstream.
The ASUS USB-N10 Nano B1 has been reported as a new RTL8188EU device.
Add it to the device tables.
Reported-by: kovi <zraetn@gmail.com>
Cc: Stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20200321180011.26153-1-Larry.Finger@lwfinger.net
commit 536f561d871c5781bc33d26d415685211b94032e upstream.
The driver was issuing synchronous uninterruptible control requests
without using a timeout. This could lead to the driver hanging on
various user requests due to a malfunctioning (or malicious) device
until the device is physically disconnected.
The USB upper limit of five seconds per request should be more than
enough.
Fixes: f3d27f34fdd7 ("[media] usbtv: Add driver for Fushicai USBTV007 video frame grabber")
Fixes: c53a846c48f2 ("[media] usbtv: add video controls")
Cc: stable <stable@vger.kernel.org> # 3.11
Acked-by: Lubomir Rintel <lkundrak@v3.sk>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit bca243b1ce0e46be26f7c63b5591dfbb41f558e5 upstream.
commit 1b976fc6d684 ("media: b2c2-flexcop-usb: add sanity checking") added
an endpoint sanity check to address a NULL-pointer dereference on probe.
Unfortunately the check was done on the current altsetting which was later
changed.
Fix this by moving the sanity check to after the altsetting is changed.
Fixes: 1b976fc6d684 ("media: b2c2-flexcop-usb: add sanity checking")
Cc: Oliver Neukum <oneukum@suse.com>
commit 52974d94a206ce428d9d9b6eaa208238024be82a upstream.
When handling a PIO bulk transfer with highmem buffer, a temporary
mapping is assigned to urb->transfer_buffer. After the transfer is
complete, an invalid address is left behind in this pointer. This is
not ordinarily a problem since nothing touches that buffer before the
urb is released. However, when usbmon is active, usbmon_urb_complete()
calls (indirectly) mon_bin_get_data() which does access the transfer
buffer if it is set. To prevent an invalid memory access here, reset
urb->transfer_buffer to NULL when finished (musb_host_rx()), or do not
set it at all (musb_host_tx()).
Fixes: 8e8a55165469 ("usb: musb: host: Handle highmem in PIO mode")
Signed-off-by: Mans Rullgard <mans@mansr.com>
Cc: stable@vger.kernel.org
Signed-off-by: Bin Liu <b-liu@ti.com>
Link: https://lore.kernel.org/r/20200316211136.2274-8-b-liu@ti.com
commit 57aa9f294b09463492f604feaa5cc719beaace32 upstream.
Fix slab-out-of-bounds read in the interrupt-URB completion handler.
The boundary condition should be (length - 1) as we access
data[position + 1].
Reported-and-tested-by: syzbot+37ba33391ad5f3935bbd@syzkaller.appspotmail.com
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
commit 62d65bdd9d05158aa2547f8ef72375535f3bc6e3 upstream.
commit b401f8c4f492c ("USB: cdc-acm: fix rounding error in TIOCSSERIAL")
introduced a regression by changing the order of capability and close
settings change checks. When running with CAP_SYS_ADMIN setting the
close settings to the values already set resulted in -EOPNOTSUPP.
Fix this by changing the check order back to how it was before.
Fixes: b401f8c4f492c ("USB: cdc-acm: fix rounding error in TIOCSSERIAL")
Cc: Anthony Mallet <anthony.mallet@laas.fr>
Signed-off-by: Matthias Reichl <hias@horus.com>
Link: https://lore.kernel.org/r/20200327150350.3657-1-hias@horus.com
commit dfee7e2f478346b12ea651d5c28b069f6a4af563 upstream.
This modem is embedded on dlink dwr-960 router.
The oem configuration states:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1435 ProdID=d191 Rev=ff.ff
S: Manufacturer=Android
S: Product=Android
S: SerialNumber=0123456789ABCDEF
C:* #Ifs= 6 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=42 Prot=01 Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=84(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=86(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=88(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
E: Ad=89(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=125us
Tested on openwrt distribution
Signed-off-by: Pawel Dembicki <paweldembicki@gmail.com>
commit 6cb2669cb97fc4fdf526127159ac59caae052247 upstream.
BroadMobi BM806U is an Qualcomm MDM9225 based 3G/4G modem.
Tested hardware BM806U is mounted on D-Link DWR-921-C3 router.
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.01 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2020 ProdID=2033 Rev= 2.28
S: Manufacturer=Mobile Connect
S: Product=Mobile Connect
S: SerialNumber=f842866cfd5a
C:* #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=87(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=89(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Co-developed-by: Cezary Jackiewicz <cezary@eko.one.pl>
Signed-off-by: Cezary Jackiewicz <cezary@eko.one.pl>
commit 007d20dca2376a751b1dad03442f118438b7e65e upstream.
ASKEY WWHC050 is a mcie LTE modem.
P: Vendor=1690 ProdID=7588 Rev=ff.ff
S: Product=Android
S: SerialNumber=813f0eef6e6e
Tested on openwrt distribution.
[ Upstream commit 32cf3a610c35cb21e3157f4bbf29d89960e30a36 ]
These functions are supposed to return negative error codes but instead
it returns true on failure and false on success. The error codes are
eventually propagated back to user space.
Fixes: 48a2b783483b ("Input: add Raydium I2C touchscreen driver")
Link: https://lore.kernel.org/r/20200303101306.4potflz7na2nn3od@kili.mountain
[ Upstream commit 6cad4e269e25dddd7260a53e9d9d90ba3a3cc35a ]
Return statements in functions returning bool should use true or false
instead of an integer value.
This code was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
commit ea697a8bf5a4161e59806fab14f6e4a46dc7dcb0 upstream.
Some USB bridge devices will return a default set of characteristics during
initialization. And then, once an attached drive has spun up, substitute
the actual parameters reported by the drive. According to the SCSI spec,
the device should return a UNIT ATTENTION in case any reported parameters
change. But in this case the change is made silently after a small window
where default values are reported.
Commit a83da8a4509d ("scsi: sd: Optimal I/O size should be a multiple of
physical block size") validated the reported optimal I/O size against the
physical block size to overcome problems with devices reporting nonsensical
transfer sizes. However, this validation did not account for the fact that
aforementioned devices will return default values during a brief window
during spin-up. The subsequent change in reported characteristics would
invalidate the checking that had previously been performed.
Unset a previously configured optimal I/O size should the sanity checking
fail on subsequent revalidate attempts.
Link: https://lore.kernel.org/r/33fb522e-4f61-1b76-914f-c9e6a3553c9b@gmail.com
Cc: Bryan Gurney <bgurney@redhat.com>
Cc: <stable@vger.kernel.org>
Reported-by: Bernhard Sulzer <micraft.b@gmail.com>
Tested-by: Bernhard Sulzer <micraft.b@gmail.com>
commit e1b9f99ff8c40bba6e59de9ad4a659447b1e4112 upstream.
The driver forgets to disable and unprepare clk when remove.
Add a call to clk_disable_unprepare to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: stable@kernel.org
[ Upstream commit f3cc008bf6d59b8d93b4190e01d3e557b0040e15 ]
This patch fixes an off-by-one error in strncpy size argument in
drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c. The issue is that in:
strncmp(opt, "eee_timer:", 6)
the passed string literal: "eee_timer:" has 10 bytes (without the NULL
byte) and the passed size argument is 6. As a result, the logic will
also accept other, malformed strings, e.g. "eee_tiXXX:".
This bug doesn't seem to have any security impact since its present in
module's cmdline parsing code.
Signed-off-by: Dominik Czarnota <dominik.b.czarnota@gmail.com>
[ Upstream commit 394b61711f3ce33f75bf70a3e22938464a13b3ee ]
When trying to rescan disks in petitboot shell, we hit the following
softlockup stacktrace:
Kernel panic - not syncing: System is deadlocked on memory
[ 241.223394] CPU: 32 PID: 693 Comm: sh Not tainted 5.4.16-openpower1 #1
[ 241.223406] Call Trace:
[ 241.223415] [c0000003f07c3180] [c000000000493fc4] dump_stack+0xa4/0xd8 (unreliable)
[ 241.223432] [c0000003f07c31c0] [c00000000007d4ac] panic+0x148/0x3cc
[ 241.223446] [c0000003f07c3260] [c000000000114b10] out_of_memory+0x468/0x4c4
[ 241.223461] [c0000003f07c3300] [c0000000001472b0] __alloc_pages_slowpath+0x594/0x6d8
[ 241.223476] [c0000003f07c3420] [c00000000014757c] __alloc_pages_nodemask+0x188/0x1a4
[ 241.223492] [c0000003f07c34a0] [c000000000153e10] alloc_pages_current+0xcc/0xd8
[ 241.223508] [c0000003f07c34e0] [c0000000001577ac] alloc_slab_page+0x30/0x98
[ 241.223524] [c0000003f07c3520] [c0000000001597fc] new_slab+0x138/0x40c
[ 241.223538] [c0000003f07c35f0] [c00000000015b204] ___slab_alloc+0x1e4/0x404
[ 241.223552] [c0000003f07c36c0] [c00000000015b450] __slab_alloc+0x2c/0x48
[ 241.223566] [c0000003f07c36f0] [c00000000015b754] kmem_cache_alloc_node+0x9c/0x1b4
[ 241.223582] [c0000003f07c3760] [c000000000218c48] blk_alloc_queue_node+0x34/0x270
[ 241.223599] [c0000003f07c37b0] [c000000000226574] blk_mq_init_queue+0x2c/0x78
[ 241.223615] [c0000003f07c37e0] [c0000000002ff710] scsi_mq_alloc_queue+0x28/0x70
[ 241.223631] [c0000003f07c3810] [c0000000003005b8] scsi_alloc_sdev+0x184/0x264
[ 241.223647] [c0000003f07c38a0] [c000000000300ba0] scsi_probe_and_add_lun+0x288/0xa3c
[ 241.223663] [c0000003f07c3a00] [c000000000301768] __scsi_scan_target+0xcc/0x478
[ 241.223679] [c0000003f07c3b20] [c000000000301c64] scsi_scan_channel.part.9+0x74/0x7c
[ 241.223696] [c0000003f07c3b70] [c000000000301df4] scsi_scan_host_selected+0xe0/0x158
[ 241.223712] [c0000003f07c3bd0] [c000000000303f04] store_scan+0x104/0x114
[ 241.223727] [c0000003f07c3cb0] [c0000000002d5ac4] dev_attr_store+0x30/0x4c
[ 241.223741] [c0000003f07c3cd0] [c0000000001dbc34] sysfs_kf_write+0x64/0x78
[ 241.223756] [c0000003f07c3cf0] [c0000000001da858] kernfs_fop_write+0x170/0x1b8
[ 241.223773] [c0000003f07c3d40] [c0000000001621fc] __vfs_write+0x34/0x60
[ 241.223787] [c0000003f07c3d60] [c000000000163c2c] vfs_write+0xa8/0xcc
[ 241.223802] [c0000003f07c3db0] [c000000000163df4] ksys_write+0x70/0xbc
[ 241.223816] [c0000003f07c3e20] [c00000000000b40c] system_call+0x5c/0x68
As a part of the scan process Linux will allocate and configure a
scsi_device for each target to be scanned. If the device is not present,
then the scsi_device is torn down. As a part of scsi_device teardown a
workqueue item will be scheduled and the lockups we see are because there
are 250k workqueue items to be processed. Accoding to the specification of
SIS-64 sas controller, max_channel should be decreased on SIS-64 adapters
to 4.
The patch fixes softlockup issue.
Thanks for Oliver Halloran's help with debugging and explanation!
Link: https://lore.kernel.org/r/1583510248-23672-1-git-send-email-wenxiong@linux.vnet.ibm.com
Signed-off-by: Wen Xiong <wenxiong@linux.vnet.ibm.com>
[ Upstream commit 065fd83e1be2e1ba0d446a257fd86a3cc7bddb51 ]
For the case where the last mvneta_poll did not process all
RX packets, we need to xor the pp->cause_rx_tx or port->cause_rx_tx
before claculating the rx_queue.
Fixes: 2dcf75e2793c ("net: mvneta: Associate RX queues with each CPU")
Signed-off-by: Jisheng Zhang <Jisheng.Zhang@synaptics.com>
[ Upstream commit 384d91c267e621e0926062cfb3f20cb72dc16928 ]
gro_cells_init() returns error if memory allocation is failed.
But the vxlan module doesn't check the return value of gro_cells_init().
Fixes: 58ce31cca1ff ("vxlan: GRO support at tunnel layer")`
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
[ Upstream commit 2091a3d42b4f339eaeed11228e0cbe9d4f92f558 ]
As the description before netdev_run_todo, we cannot call free_netdev
before rtnl_unlock, fix it by reorder the code.
This patch is a 1:1 copy of upstream slip.c commit f596c87005f7
("slip: not call free_netdev before rtnl_unlock in slip_open").
Reported-by: yangerkun <yangerkun@huawei.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
[ Upstream commit 0dcdf9f64028ec3b75db6b691560f8286f3898bf ]
The nci_conn_max_data_pkt_payload_size() function sometimes returns
-EPROTO so "max_size" needs to be signed for the error handling to
work. We can make "payload_size" an int as well.
Fixes: a06347c04c13 ("NFC: Add Intel Fields Peak NFC solution driver")
[ Upstream commit b06d072ccc4b1acd0147b17914b7ad1caa1818bb ]
Only attach macsec to ethernet devices.
Syzbot was able to trigger a KMSAN warning in macsec_handle_frame
by attaching to a phonet device.
Macvlan has a similar check in macvlan_port_create.
v1->v2
- fix commit message typo
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
commit 9765635b30756eb74e05e260ac812659c296cd28 upstream.
This reverts commit:
c54c7374ff44 ("drm/dp_mst: Skip validating ports during destruction, just ref")
ugh.
In drm_dp_destroy_connector_work(), we have a pretty good chance of
freeing the actual struct drm_dp_mst_port. However, after destroying
things we send a hotplug through (*mgr->cbs->hotplug)(mgr) which is
where the problems start.
For i915, this calls all the way down to the fbcon probing helpers,
which start trying to access the port in a modeset.
[ 45.062001] ==================================================================
[ 45.062112] BUG: KASAN: use-after-free in ex_handler_refcount+0x146/0x180
[ 45.062196] Write of size 4 at addr ffff8882b4b70968 by task kworker/3:1/53
[ 45.062325] CPU: 3 PID: 53 Comm: kworker/3:1 Kdump: loaded Tainted: G O 4.20.0-rc4Lyude-Test+ #3
[ 45.062442] Hardware name: LENOVO 20BWS1KY00/20BWS1KY00, BIOS JBET71WW (1.35 ) 09/14/2018
[ 45.062554] Workqueue: events drm_dp_destroy_connector_work [drm_kms_helper]
[ 45.062641] Call Trace:
[ 45.062685] dump_stack+0xbd/0x15a
[ 45.062735] ? dump_stack_print_info.cold.0+0x1b/0x1b
[ 45.062801] ? printk+0x9f/0xc5
[ 45.062847] ? kmsg_dump_rewind_nolock+0xe4/0xe4
[ 45.062909] ? ex_handler_refcount+0x146/0x180
[ 45.062970] print_address_description+0x71/0x239
[ 45.063036] ? ex_handler_refcount+0x146/0x180
[ 45.063095] kasan_report.cold.5+0x242/0x30b
[ 45.063155] __asan_report_store4_noabort+0x1c/0x20
[ 45.063313] ex_handler_refcount+0x146/0x180
[ 45.063371] ? ex_handler_clear_fs+0xb0/0xb0
[ 45.063428] fixup_exception+0x98/0xd7
[ 45.063484] ? raw_notifier_call_chain+0x20/0x20
[ 45.063548] do_trap+0x6d/0x210
[ 45.063605] ? _GLOBAL__sub_I_65535_1_drm_dp_aux_unregister_devnode+0x2f/0x1c6 [drm_kms_helper]
[ 45.063732] do_error_trap+0xc0/0x170
[ 45.063802] ? _GLOBAL__sub_I_65535_1_drm_dp_aux_unregister_devnode+0x2f/0x1c6 [drm_kms_helper]
[ 45.063929] do_invalid_op+0x3b/0x50
[ 45.063997] ? _GLOBAL__sub_I_65535_1_drm_dp_aux_unregister_devnode+0x2f/0x1c6 [drm_kms_helper]
[ 45.064103] invalid_op+0x14/0x20
[ 45.064162] RIP: 0010:_GLOBAL__sub_I_65535_1_drm_dp_aux_unregister_devnode+0x2f/0x1c6 [drm_kms_helper]
[ 45.064274] Code: 00 48 c7 c7 80 fe 53 a0 48 89 e5 e8 5b 6f 26 e1 5d c3 48 8d 0e 0f 0b 48 8d 0b 0f 0b 48 8d 0f 0f 0b 48 8d 0f 0f 0b 49 8d 4d 00 <0f> 0b 49 8d 0e 0f 0b 48 8d 08 0f 0b 49 8d 4d 00 0f 0b 48 8d 0b 0f
[ 45.064569] RSP: 0018:ffff8882b789ee10 EFLAGS: 00010282
[ 45.064637] RAX: ffff8882af47ae70 RBX: ffff8882af47aa60 RCX: ffff8882b4b70968
[ 45.064723] RDX: ffff8882af47ae70 RSI: 0000000000000008 RDI: ffff8882b788bdb8
[ 45.064808] RBP: ffff8882b789ee28 R08: ffffed1056f13db4 R09: ffffed1056f13db3
[ 45.064894] R10: ffffed1056f13db3 R11: ffff8882b789ed9f R12: ffff8882af47ad28
[ 45.064980] R13: ffff8882b4b70968 R14: ffff8882acd86728 R15: ffff8882b4b75dc8
[ 45.065084] drm_dp_mst_reset_vcpi_slots+0x12/0x80 [drm_kms_helper]
[ 45.065225] intel_mst_disable_dp+0xda/0x180 [i915]
[ 45.065361] intel_encoders_disable.isra.107+0x197/0x310 [i915]
[ 45.065498] haswell_crtc_disable+0xbe/0x400 [i915]
[ 45.065622] ? i9xx_disable_plane+0x1c0/0x3e0 [i915]
[ 45.065750] intel_atomic_commit_tail+0x74e/0x3e60 [i915]
[ 45.065884] ? intel_pre_plane_update+0xbc0/0xbc0 [i915]
[ 45.065968] ? drm_atomic_helper_swap_state+0x88b/0x1d90 [drm_kms_helper]
[ 45.066054] ? kasan_check_write+0x14/0x20
[ 45.066165] ? i915_gem_track_fb+0x13a/0x330 [i915]
[ 45.066277] ? i915_sw_fence_complete+0xe9/0x140 [i915]
[ 45.066406] ? __i915_sw_fence_complete+0xc50/0xc50 [i915]
[ 45.066540] intel_atomic_commit+0x72e/0xef0 [i915]
[ 45.066635] ? drm_dev_dbg+0x200/0x200 [drm]
[ 45.066764] ? intel_atomic_commit_tail+0x3e60/0x3e60 [i915]
[ 45.066898] ? intel_atomic_commit_tail+0x3e60/0x3e60 [i915]
[ 45.067001] drm_atomic_commit+0xc4/0xf0 [drm]
[ 45.067074] restore_fbdev_mode_atomic+0x562/0x780 [drm_kms_helper]
[ 45.067166] ? drm_fb_helper_debug_leave+0x690/0x690 [drm_kms_helper]
[ 45.067249] ? kasan_check_read+0x11/0x20
[ 45.067324] restore_fbdev_mode+0x127/0x4b0 [drm_kms_helper]
[ 45.067364] ? kasan_check_read+0x11/0x20
[ 45.067406] drm_fb_helper_restore_fbdev_mode_unlocked+0x164/0x200 [drm_kms_helper]
[ 45.067462] ? drm_fb_helper_hotplug_event+0x30/0x30 [drm_kms_helper]
[ 45.067508] ? kasan_check_write+0x14/0x20
[ 45.070360] ? mutex_unlock+0x22/0x40
[ 45.073748] drm_fb_helper_set_par+0xb2/0xf0 [drm_kms_helper]
[ 45.075846] drm_fb_helper_hotplug_event.part.33+0x1cd/0x290 [drm_kms_helper]
[ 45.078088] drm_fb_helper_hotplug_event+0x1c/0x30 [drm_kms_helper]
[ 45.082614] intel_fbdev_output_poll_changed+0x9f/0x140 [i915]
[ 45.087069] drm_kms_helper_hotplug_event+0x67/0x90 [drm_kms_helper]
[ 45.089319] intel_dp_mst_hotplug+0x37/0x50 [i915]
[ 45.091496] drm_dp_destroy_connector_work+0x510/0x6f0 [drm_kms_helper]
[ 45.093675] ? drm_dp_update_payload_part1+0x1220/0x1220 [drm_kms_helper]
[ 45.095851] ? kasan_check_write+0x14/0x20
[ 45.098473] ? kasan_check_read+0x11/0x20
[ 45.101155] ? strscpy+0x17c/0x530
[ 45.103808] ? __switch_to_asm+0x34/0x70
[ 45.106456] ? syscall_return_via_sysret+0xf/0x7f
[ 45.109711] ? read_word_at_a_time+0x20/0x20
[ 45.113138] ? __switch_to_asm+0x40/0x70
[ 45.116529] ? __switch_to_asm+0x34/0x70
[ 45.119891] ? __switch_to_asm+0x40/0x70
[ 45.123224] ? __switch_to_asm+0x34/0x70
[ 45.126540] ? __switch_to_asm+0x34/0x70
[ 45.129824] process_one_work+0x88d/0x15d0
[ 45.133172] ? pool_mayday_timeout+0x850/0x850
[ 45.136459] ? pci_mmcfg_check_reserved+0x110/0x128
[ 45.139739] ? wake_q_add+0xb0/0xb0
[ 45.143010] ? check_preempt_wakeup+0x652/0x1050
[ 45.146304] ? worker_enter_idle+0x29e/0x740
[ 45.149589] ? __schedule+0x1ec0/0x1ec0
[ 45.152937] ? kasan_check_read+0x11/0x20
[ 45.156179] ? _raw_spin_lock_irq+0xa3/0x130
[ 45.159382] ? _raw_read_unlock_irqrestore+0x30/0x30
[ 45.162542] ? kasan_check_write+0x14/0x20
[ 45.165657] worker_thread+0x1a5/0x1470
[ 45.168725] ? set_load_weight+0x2e0/0x2e0
[ 45.171755] ? process_one_work+0x15d0/0x15d0
[ 45.174806] ? __switch_to_asm+0x34/0x70
[ 45.177645] ? __switch_to_asm+0x40/0x70
[ 45.180323] ? __switch_to_asm+0x34/0x70
[ 45.182936] ? __switch_to_asm+0x40/0x70
[ 45.185539] ? __switch_to_asm+0x34/0x70
[ 45.188100] ? __switch_to_asm+0x40/0x70
[ 45.190628] ? __schedule+0x7d4/0x1ec0
[ 45.193143] ? save_stack+0xa9/0xd0
[ 45.195632] ? kasan_check_write+0x10/0x20
[ 45.198162] ? kasan_kmalloc+0xc4/0xe0
[ 45.200609] ? kmem_cache_alloc_trace+0xdd/0x190
[ 45.203046] ? kthread+0x9f/0x3b0
[ 45.205470] ? ret_from_fork+0x35/0x40
[ 45.207876] ? unwind_next_frame+0x43/0x50
[ 45.210273] ? __save_stack_trace+0x82/0x100
[ 45.212658] ? deactivate_slab.isra.67+0x3d4/0x580
[ 45.215026] ? default_wake_function+0x35/0x50
[ 45.217399] ? kasan_check_read+0x11/0x20
[ 45.219825] ? _raw_spin_lock_irqsave+0xae/0x140
[ 45.222174] ? __lock_text_start+0x8/0x8
[ 45.224521] ? replenish_dl_entity.cold.62+0x4f/0x4f
[ 45.226868] ? __kthread_parkme+0x87/0xf0
[ 45.229200] kthread+0x2f7/0x3b0
[ 45.231557] ? process_one_work+0x15d0/0x15d0
[ 45.233923] ? kthread_park+0x120/0x120
[ 45.236249] ret_from_fork+0x35/0x40
[ 45.240875] Allocated by task 242:
[ 45.243136] save_stack+0x43/0xd0
[ 45.245385] kasan_kmalloc+0xc4/0xe0
[ 45.247597] kmem_cache_alloc_trace+0xdd/0x190
[ 45.249793] drm_dp_add_port+0x1e0/0x2170 [drm_kms_helper]
[ 45.252000] drm_dp_send_link_address+0x4a7/0x740 [drm_kms_helper]
[ 45.254389] drm_dp_check_and_send_link_address+0x1a7/0x210 [drm_kms_helper]
[ 45.256803] drm_dp_mst_link_probe_work+0x6f/0xb0 [drm_kms_helper]
[ 45.259200] process_one_work+0x88d/0x15d0
[ 45.261597] worker_thread+0x1a5/0x1470
[ 45.264038] kthread+0x2f7/0x3b0
[ 45.266371] ret_from_fork+0x35/0x40
[ 45.270937] Freed by task 53:
[ 45.273170] save_stack+0x43/0xd0
[ 45.275382] __kasan_slab_free+0x139/0x190
[ 45.277604] kasan_slab_free+0xe/0x10
[ 45.279826] kfree+0x99/0x1b0
[ 45.282044] drm_dp_free_mst_port+0x4a/0x60 [drm_kms_helper]
[ 45.284330] drm_dp_destroy_connector_work+0x43e/0x6f0 [drm_kms_helper]
[ 45.286660] process_one_work+0x88d/0x15d0
[ 45.288934] worker_thread+0x1a5/0x1470
[ 45.291231] kthread+0x2f7/0x3b0
[ 45.293547] ret_from_fork+0x35/0x40
[ 45.298206] The buggy address belongs to the object at ffff8882b4b70968
which belongs to the cache kmalloc-2k of size 2048
[ 45.303047] The buggy address is located 0 bytes inside of
2048-byte region [ffff8882b4b70968, ffff8882b4b71168)
[ 45.308010] The buggy address belongs to the page:
[ 45.310477] page:ffffea000ad2dc00 count:1 mapcount:0 mapping:ffff8882c080cf40 index:0x0 compound_mapcount: 0
[ 45.313051] flags: 0x8000000000010200(slab|head)
[ 45.315635] raw: 8000000000010200 ffffea000aac2808 ffffea000abe8608 ffff8882c080cf40
[ 45.318300] raw: 0000000000000000 00000000000d000d 00000001ffffffff 0000000000000000
[ 45.320966] page dumped because: kasan: bad access detected
[ 45.326312] Memory state around the buggy address:
[ 45.329085] ffff8882b4b70800: fb fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 45.331845] ffff8882b4b70880: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 45.334584] >ffff8882b4b70900: fc fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb
[ 45.337302] ^
[ 45.340061] ffff8882b4b70980: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 45.342910] ffff8882b4b70a00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 45.345748] ==================================================================
So, this definitely isn't a fix that we want. This being said; there's
no real easy fix for this problem because of some of the catch-22's of
the MST helpers current design. For starters; we always need to validate
a port with drm_dp_get_validated_port_ref(), but validation relies on
the lifetime of the port in the actual topology. So once the port is
gone, it can't be validated again.
If we were to try to make the payload helpers not use port validation,
then we'd cause another problem: if the port isn't validated, it could
be freed and we'd just start causing more KASAN issues. There are
already hacks that attempt to workaround this in
drm_dp_mst_destroy_connector_work() by re-initializing the kref so that
it can be used again and it's memory can be freed once the VCPI helpers
finish removing the port's respective payloads. But none of these really
do anything helpful since the port still can't be validated since it's
gone from the topology. Also, that workaround is immensely confusing to
read through.
What really needs to be done in order to fix this is to teach DRM how to
track the lifetime of the structs for MST ports and branch devices
separately from their lifetime in the actual topology. Simply put; this
means having two different krefs-one that removes the port/branch device
from the topology, and one that finally calls kfree(). This would let us
simplify things, since we'd now be able to keep ports around without
having to keep them in the topology at the same time, which is exactly
what we need in order to teach our VCPI helpers to only validate ports
when it's actually necessary without running the risk of trying to use
unallocated memory.
Such a fix is on it's way, but for now let's play it safe and just
revert this. If this bug has been around for well over a year, we can
wait a little while to get an actual proper fix here.
Signed-off-by: Lyude Paul <lyude@redhat.com>
Fixes: c54c7374ff44 ("drm/dp_mst: Skip validating ports during destruction, just ref")
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Sean Paul <sean@poorly.run>
Cc: Jerry Zuo <Jerry.Zuo@amd.com>
Cc: Harry Wentland <Harry.Wentland@amd.com>
Cc: stable@vger.kernel.org # v4.6+
Acked-by: Sean Paul <sean@poorly.run>
Link: https://patchwork.freedesktop.org/patch/msgid/20181128210005.24434-1-lyude@redhat.com
commit ae62cf5eb2792d9a818c2d93728ed92119357017 upstream.
Newer GCC warns about possible truncations of two generated path names as
we're concatenating the configurable sysfs and debugfs path prefixes
with a filename and placing the results in buffers of the same size as
the maximum length of the prefixes.
snprintf(d->name, MAX_STR_LEN, "gb_loopback%u", dev_id);
snprintf(d->sysfs_entry, MAX_SYSFS_PATH, "%s%s/",
t->sysfs_prefix, d->name);
snprintf(d->debugfs_entry, MAX_SYSFS_PATH, "%sraw_latency_%s",
t->debugfs_prefix, d->name);
Fix this by separating the maximum path length from the maximum prefix
length and reducing the latter enough to fit the generated strings.
Note that we also need to reduce the device-name buffer size as GCC
isn't smart enough to figure out that we ever only used MAX_STR_LEN
bytes of it.
Fixes: 6b0658f68786 ("greybus: tools: Add tools directory to greybus repo and add loopback")
Link: https://lore.kernel.org/r/20200312110151.22028-4-johan@kernel.org
commit f16023834863932f95dfad13fac3fc47f77d2f29 upstream.
Newer GCC warns about a possible truncation of a generated sysfs path
name as we're concatenating a directory path with a file name and
placing the result in a buffer that is half the size of the maximum
length of the directory path (which is user controlled).
loopback_test.c: In function 'open_poll_files':
loopback_test.c:651:31: warning: '%s' directive output may be truncated writing up to 511 bytes into a region of size 255 [-Wformat-truncation=]
651 | snprintf(buf, sizeof(buf), "%s%s", dev->sysfs_entry, "iteration_count");
loopback_test.c:651:3: note: 'snprintf' output between 16 and 527 bytes into a destination of size 255
Fix this by making sure the buffer is large enough the concatenated
strings.
Fixes: 9250c0ee2626 ("greybus: Loopback_test: use poll instead of inotify")
Link: https://lore.kernel.org/r/20200312110151.22028-3-johan@kernel.org
[ Upstream commit b401f8c4f492cbf74f3f59c9141e5be3071071bb ]
By default, tty_port_init() initializes those parameters to a multiple
of HZ. For instance in line 69 of tty_port.c:
port->close_delay = (50 * HZ) / 100;
https://github.com/torvalds/linux/blob/master/drivers/tty/tty_port.c#L69
With e.g. CONFIG_HZ = 250 (as this is the case for Ubuntu 18.04
linux-image-4.15.0-37-generic), the default setting for close_delay is
thus 125.
When ioctl(fd, TIOCGSERIAL, &s) is executed, the setting returned in
user space is '12' (125/10). When ioctl(fd, TIOCSSERIAL, &s) is then
executed with the same setting '12', the value is interpreted as '120'
which is different from the current setting and a EPERM error may be
raised by set_serial_info() if !CAP_SYS_ADMIN.
https://github.com/torvalds/linux/blob/master/drivers/usb/class/cdc-acm.c#L919
Fixes: ba2d8ce9db0a6 ("cdc-acm: implement TIOCSSERIAL to avoid blocking close(2)")
Signed-off-by: Anthony Mallet <anthony.mallet@laas.fr>
Link: https://lore.kernel.org/r/20200312133101.7096-2-anthony.mallet@laas.fr
[ Upstream commit 633e2b2ded739a34bd0fb1d8b5b871f7e489ea29 ]
close_delay and closing_wait are specified in hundredth of a second but stored
internally in jiffies. Use the jiffies_to_msecs() and msecs_to_jiffies()
functions to convert from each other.
Link: https://lore.kernel.org/r/20200312133101.7096-1-anthony.mallet@laas.fr
commit 763802b53a427ed3cbd419dbba255c414fdd9e7c upstream.
Commit 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in
__purge_vmap_area_lazy()") introduced a call to vmalloc_sync_all() in
the vunmap() code-path. While this change was necessary to maintain
correctness on x86-32-pae kernels, it also adds additional cycles for
architectures that don't need it.
Specifically on x86-64 with CONFIG_VMAP_STACK=y some people reported
severe performance regressions in micro-benchmarks because it now also
calls the x86-64 implementation of vmalloc_sync_all() on vunmap(). But
the vmalloc_sync_all() implementation on x86-64 is only needed for newly
created mappings.
To avoid the unnecessary work on x86-64 and to gain the performance
back, split up vmalloc_sync_all() into two functions:
* vmalloc_sync_mappings(), and
* vmalloc_sync_unmappings()
Most call-sites to vmalloc_sync_all() only care about new mappings being
synchronized. The only exception is the new call-site added in the
above mentioned commit.
Shile Zhang directed us to a report of an 80% regression in reaim
throughput.
Fixes: 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()")
Reported-by: kernel test robot <oliver.sang@intel.com>
Reported-by: Shile Zhang <shile.zhang@linux.alibaba.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Tested-by: Borislav Petkov <bp@suse.de>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [GHES]
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Link: http://lkml.kernel.org/r/20191009124418.8286-1-joro@8bytes.org
Link: https://lists.01.org/hyperkitty/list/lkp@lists.01.org/thread/4D3JPPHBNOSPFK2KEPC6KGKS6J25AIDB/
Link: http://lkml.kernel.org/r/20191113095530.228959-1-shile.zhang@linux.alibaba.com
commit 5d892919fdd0cefd361697472d4e1b174a594991 upstream.
I have hit the following build error:
armv7a-hardfloat-linux-gnueabi-ld: drivers/rtc/rtc-max8907.o: in function `max8907_rtc_probe':
rtc-max8907.c:(.text+0x400): undefined reference to `regmap_irq_get_virq'
max8907 should select REGMAP_IRQ
Fixes: 94c01ab6d7544 ("rtc: add MAX8907 RTC driver")
Signed-off-by: Corentin Labbe <clabbe@baylibre.com>
commit ce666be89a8a09c5924ff08fc32e119f974bdab6 upstream.
There are a few places in the driver that end up returning ENOTSUPP to
the user, replace those with EINVAL.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Fixes: ba82664c134ef ("intel_th: Add Memory Storage Unit driver")
Cc: stable@vger.kernel.org # v4.4+
Link: https://lore.kernel.org/r/20200317062215.15598-6-alexander.shishkin@linux.intel.com
commit 9d32c0cde4e2d1343dfb88a67b2ec6397705b32b upstream.
get_char was erroneously given the address of the pointer to the text
instead of the address of the text, thus leading to random crashes when
the user requests speaking a word while the current position is on a space
character and say_word_ctl is not enabled.
Reported-on: https://github.com/bytefire/speakup/issues/1
Reported-by: Kirk Reiser <kirk@reisers.ca>
Reported-by: Janina Sajka <janina@rednote.net>
Reported-by: Alexandr Epaneshnikov <aarnaarn2@gmail.com>
Reported-by: Gregory Nowak <greg@gregn.net>
Reported-by: deedra waters <deedra@the-brannons.com>
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Tested-by: Alexandr Epaneshnikov <aarnaarn2@gmail.com>
Tested-by: Gregory Nowak <greg@gregn.net>
Tested-by: Michael Taboada <michael@michaels.world>
Link: https://lore.kernel.org/r/20200306003047.thijtmqrnayd3dmw@function
commit bb5786b9286c253557a0115bc8d21879e61b7b94 upstream.
This device was added to the stand-alone driver on github.
Add it to the staging driver as well.
Link: https://github.com/lwfinger/rtl8188eu/commit/2141f244c3e7
Signed-off-by: Michael Straube <straube.linux@gmail.com>
Link: https://lore.kernel.org/r/20200312093652.13918-1-straube.linux@gmail.com
commit 53dd0a7cd65edc83b0c243d1c08377c8b876b2ee upstream.
SAMA5D2x doesn't drive CMD line if GPIO is used as CD line (at least
SAMA5D27 doesn't). Fix this by forcing card-detect in the module
if module-controlled CD is not used.
Fixed commit addresses the problem only for non-removable cards. This
amends it to also cover gpio-cd case.
Fixes: 7a1e3f143176 ("mmc: sdhci-of-at91: force card detect value for non removable devices")
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Link: https://lore.kernel.org/r/8d10950d9940468577daef4772b82a071b204716.1584290561.git.mirq-linux@rere.qmqm.pl
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit b500c086e4110829a308c23e83a7cdc65b26228a upstream.
At the moment, reading from in_magn_*_raw in sysfs tends to return
large values around 65000, even though the output of ak8974 is actually
limited to ±32768. This happens because the value is never converted
to the signed 16-bit integer variant.
Add an explicit cast to s16 to fix this.
Fixes: 7c94a8b2ee8c ("iio: magn: add a driver for AK8974")
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Reviewed-by: Linus Waleij <linus.walleij@linaro.org>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit cecc113c1af0dd41ccf265c1fdb84dbd05e63423 upstream.
Add a device id for HP LD381 Display
LD381: 03f0:0f7f
Signed-off-by: Scott Chen <scott@labau.com.tw>
commit b433e340e7565110b0ce9ca4b3e26f4b97a1decf upstream.
When loading new kernel via kexec, we need to shutdown host controller to
avoid any un-expected memory accessing during new kernel boot.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Tested-by: Stephen Boyd <swboyd@chromium.org>
Reviewed-by: Peter Chen <peter.chen@nxp.com>
Link: https://lore.kernel.org/r/20200306092328.41253-1-ran.wang_1@nxp.com
commit 8e852a7953be2a6ee371449f7257fe15ace6a1fc upstream.
Add ME910G1 ECM composition 0x110b: tty, tty, tty, ecm
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
Link: https://lore.kernel.org/r/20200304104310.2938-1-dnlplm@gmail.com
commit 75d7676ead19b1fbb5e0ee934c9ccddcb666b68c upstream.
We have been receiving bug reports that ethernet connections over
RTL8153 based ethernet adapters stops working after a while with
errors like these showing up in dmesg when the ethernet stops working:
[12696.189484] r8152 6-1:1.0 enp10s0u1: Tx timeout
[12702.333456] r8152 6-1:1.0 enp10s0u1: Tx timeout
[12707.965422] r8152 6-1:1.0 enp10s0u1: Tx timeout
This has been reported on Dell WD15 docks, Belkin USB-C Express Dock 3.1
docks and with generic USB to ethernet dongles using the RTL8153
chipsets. Some users have tried adding usbcore.quirks=0bda:8153:k to
the kernel commandline and all users who have tried this report that
this fixes this.
Also note that we already have an existing NO_LPM quirk for the RTL8153
used in the Microsoft Surface Dock (where it uses a different usb-id).
This commit adds a NO_LPM quirk for the generic Realtek RTL8153
0bda:8153 usb-id, fixing the Tx timeout errors on these devices.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=198931
Cc: russianneuromancer@ya.ru
Link: https://lore.kernel.org/r/20200313120708.100339-1-hdegoede@redhat.com
commit b63e48fb50e1ca71db301ca9082befa6f16c55c4 upstream.
Realtek Hub (0bda:0x0487) used in Dell Dock WD19 sometimes drops off the
bus when bringing underlying ports from U3 to U0.
Disabling LPM on the hub during setting link state is not enough, so
let's disable LPM completely for this hub.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Link: https://lore.kernel.org/r/20200205112633.25995-3-kai.heng.feng@canonical.com
[ Upstream commit 3745488e9d599916a0b40d45d3f30e3d4720288e ]
altera_get_note is called from altera_init, where key is kzalloc(33).
When the allocation functions are annotated to allow the compiler to see
the sizes of objects, and with FORTIFY_SOURCE, we see:
In file included from drivers/misc/altera-stapl/altera.c:14:0:
In function ‘strlcpy’,
inlined from ‘altera_init’ at drivers/misc/altera-stapl/altera.c:2189:5:
include/linux/string.h:378:4: error: call to ‘__write_overflow’ declared with attribute error: detected write beyond size of object passed as 1st parameter
__write_overflow();
That refers to this code in altera_get_note:
if (key != NULL)
strlcpy(key, &p[note_strings +
get_unaligned_be32(
&p[note_table + (8 * i)])],
length);
The error triggers because the length of 'key' is 33, but the copy
uses length supplied as the 'length' parameter, which is always
256. Split the size parameter into key_len and val_len, and use the
appropriate length depending on what is being copied.
Detected by compiler error, only compile-tested.
Cc: "Igor M. Liplianin" <liplianin@netup.ru>
Signed-off-by: Daniel Axtens <dja@axtens.net>
Link: https://lore.kernel.org/r/20200120074344.504-2-dja@axtens.net
Link: https://lore.kernel.org/r/202002251042.D898E67AC@keescook
[ Upstream commit c0fd99d659ba5582e09625c7a985d63fc2ca74b5 ]
Writing to the built-in strings arrays doesn't work if driver is loaded
as kernel module. This is also considered as a bad pattern. Fix this by
adding a call to clk_get() with legacy clock name. This fixes following
kernel oops if driver is loaded as module:
Unable to handle kernel paging request at virtual address bf047978
pgd = (ptrval)
[bf047978] *pgd=59344811, *pte=5903c6df, *ppte=5903c65f
Internal error: Oops: 80f [#1] SMP ARM
Modules linked in: mc exynosdrm(+) analogix_dp rtc_s3c exynos_ppmu i2c_gpio
CPU: 1 PID: 212 Comm: systemd-udevd Not tainted 5.6.0-rc2-next-20200219 #326
videodev: Linux video capture interface: v2.00
Hardware name: Samsung Exynos (Flattened Device Tree)
PC is at exynos_dsi_probe+0x1f0/0x384 [exynosdrm]
LR is at exynos_dsi_probe+0x1dc/0x384 [exynosdrm]
Process systemd-udevd (pid: 212, stack limit = 0x(ptrval))
[<bf03cf14>] (exynos_dsi_probe [exynosdrm]) from [<c09b1ca0>] (platform_drv_probe+0x6c/0xa4)
[<c09b1ca0>] (platform_drv_probe) from [<c09afcb8>] (really_probe+0x210/0x350)
[<c09afcb8>] (really_probe) from [<c09aff74>] (driver_probe_device+0x60/0x1a0)
[<c09aff74>] (driver_probe_device) from [<c09b0254>] (device_driver_attach+0x58/0x60)
[<c09b0254>] (device_driver_attach) from [<c09b02dc>] (__driver_attach+0x80/0xbc)
[<c09b02dc>] (__driver_attach) from [<c09ade00>] (bus_for_each_dev+0x68/0xb4)
[<c09ade00>] (bus_for_each_dev) from [<c09aefd8>] (bus_add_driver+0x130/0x1e8)
[<c09aefd8>] (bus_add_driver) from [<c09b0d64>] (driver_register+0x78/0x110)
[<c09b0d64>] (driver_register) from [<bf038558>] (exynos_drm_init+0xe8/0x11c [exynosdrm])
[<bf038558>] (exynos_drm_init [exynosdrm]) from [<c0302fa8>] (do_one_initcall+0x50/0x220)
[<c0302fa8>] (do_one_initcall) from [<c03dd02c>] (do_init_module+0x60/0x210)
[<c03dd02c>] (do_init_module) from [<c03dbf44>] (load_module+0x1c0c/0x2310)
[<c03dbf44>] (load_module) from [<c03dc85c>] (sys_finit_module+0xac/0xbc)
[<c03dc85c>] (sys_finit_module) from [<c0301000>] (ret_fast_syscall+0x0/0x54)
Exception stack(0xd979bfa8 to 0xd979bff0)
---[ end trace db16efe05faab470 ]---
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
[ Upstream commit 0a9d1e3f3f038785ebc72d53f1c409d07f6b4ff5 ]
Properly propagate error value from devm_regulator_bulk_get() and don't
confuse user with meaningless warning about failure in getting regulators
in case of deferred probe.
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 5dd8304981ecffa77bb72b1c57c4be5dfe6cfae9 ]
In the public interface for chipselect, there is always an entry
commented as "Dummy generic FIFO entry" pushed down to the fifo right
after the activate/deactivate command. The dummy entry is 0x0,
irregardless if the intention was to activate or deactive the cs. This
causes the cs line to glitch rather than beeing activated in the case
when there was an activate command.
This has been observed on oscilloscope, and have caused problems for at
least one specific flash device type connected to the qspi port. After
the change the glitch is gone and cs goes active when intended.
The reason why this worked before (except for the glitch) was because
when sending the actual data, the CS bits are once again set. Since
most flashes uses mode 0, there is always a half clk period anyway for
cs to clk active setup time. If someone would rely on timing from a
chip_select call to a transfer_one, it would fail though.
It is unknown why the dummy entry was there in the first place, git log
seems to be of no help in this case. The reference manual gives no
indication of the necessity of this. In fact the lower 8 bits are a
setup (or hold in case of deactivate) time expressed in cycles. So this
should not be needed to fulfill any setup/hold timings.
Signed-off-by: Thommy Jakobsson <thommyj@gmail.com>
Reviewed-by: Naga Sureshkumar Relli <naga.sureshkumar.relli@xilinx.com>
Link: https://lore.kernel.org/r/20200224162643.29102-1-thommyj@gmail.com
Signed-off-by: Mark Brown <broonie@kernel.org>
