commit 50b8f5aec04ebec7dbdf2adb17220b9148c99e63 upstream.
They have 4 rather than 8.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=63599
Signed-off-by: wojciech kapuscinski <wojtask9@wp.pl>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 8612ed0d97abcf1c016d34755b7cf2060de71963 upstream.
Calling the WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS and twice will cause a
interruptible deadlock.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream.
The some platforms (e.g., ARM) initializes their clocks as
late_initcalls for some unknown reason. So make sure
random_int_secret_init() is run after all of the late_initcalls are
run.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit bcc2c9c3fff859e0eb019fe6fec26f9b8eba795c upstream.
The SuSE security team suggested to use recvfrom instead of recv to be
certain that the connector message is originated from kernel.
CVE-2012-2669
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: Marcus Meissner <meissner@suse.de>
Signed-off-by: Sebastian Krahmer <krahmer@suse.de>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 715230a44310a8cf66fbfb5a46f9a62a9b2de424 upstream.
Commit 184b89044fb6e2a74611dafa69b1dce0d98612c6 ("tg3: Use VPD fw version
when present") introduced VPD parsing that contained a potential length
overflow.
Limit the hardware's reported firmware string length (max 255 bytes) to
stay inside the driver's firmware string length (32 bytes). On overflow,
truncate the formatted firmware string instead of potentially overwriting
portions of the tg3 struct.
http://cansecwest.com/slides/2013/PrivateCore%20CSW%202013.pdf
-js: This fixes CVE-2013-1929.
Reported-by: Oded Horovitz <oded@privatecore.com>
Reported-by: Brad Spengler <spender@grsecurity.net>
Cc: stable@vger.kernel.org
Cc: Matt Carlson <mcarlson@broadcom.com>
Acked-by: Jeff Mahoney <jeffm@suse.com>
commit 06a8566bcf5cf7db9843a82cde7a33c7bf3947d9 upstream.
This patch fixes the issues indicated by the test results that
ipmi_msg_handler() is invoked in atomic context.
BUG: scheduling while atomic: kipmi0/18933/0x10000100
Modules linked in: ipmi_si acpi_ipmi ...
CPU: 3 PID: 18933 Comm: kipmi0 Tainted: G AW 3.10.0-rc7+ #2
Hardware name: QCI QSSC-S4R/QSSC-S4R, BIOS QSSC-S4R.QCI.01.00.0027.070120100606 07/01/2010
ffff8838245eea00 ffff88103fc63c98 ffffffff814c4a1e ffff88103fc63ca8
ffffffff814bfbab ffff88103fc63d28 ffffffff814c73e0 ffff88103933cbd4
0000000000000096 ffff88103fc63ce8 ffff88102f618000 ffff881035c01fd8
Call Trace:
<IRQ> [<ffffffff814c4a1e>] dump_stack+0x19/0x1b
[<ffffffff814bfbab>] __schedule_bug+0x46/0x54
[<ffffffff814c73e0>] __schedule+0x83/0x59c
[<ffffffff81058853>] __cond_resched+0x22/0x2d
[<ffffffff814c794b>] _cond_resched+0x14/0x1d
[<ffffffff814c6d82>] mutex_lock+0x11/0x32
[<ffffffff8101e1e9>] ? __default_send_IPI_dest_field.constprop.0+0x53/0x58
[<ffffffffa09e3f9c>] ipmi_msg_handler+0x23/0x166 [ipmi_si]
[<ffffffff812bf6e4>] deliver_response+0x55/0x5a
[<ffffffff812c0fd4>] handle_new_recv_msgs+0xb67/0xc65
[<ffffffff81007ad1>] ? read_tsc+0x9/0x19
[<ffffffff814c8620>] ? _raw_spin_lock_irq+0xa/0xc
[<ffffffffa09e1128>] ipmi_thread+0x5c/0x146 [ipmi_si]
Also Tony Camuso says:
We were getting occasional "Scheduling while atomic" call traces
during boot on some systems. Problem was first seen on a Cisco C210
but we were able to reproduce it on a Cisco c220m3. Setting
CONFIG_LOCKDEP and LOCKDEP_SUPPORT to 'y' exposed a lockdep around
tx_msg_lock in acpi_ipmi.c struct acpi_ipmi_device.
[ INFO: inconsistent lock state ]
2.6.32-415.el6.x86_64-debug-splck #1
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
ksoftirqd/3/17 [HC0[0]:SC1[1]:HE1:SE0] takes:
(&ipmi_device->tx_msg_lock){+.?...}, at: [<ffffffff81337a27>] ipmi_msg_handler+0x71/0x126
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff810ba11c>] __lock_acquire+0x63c/0x1570
[<ffffffff810bb0f4>] lock_acquire+0xa4/0x120
[<ffffffff815581cc>] __mutex_lock_common+0x4c/0x400
[<ffffffff815586ea>] mutex_lock_nested+0x4a/0x60
[<ffffffff8133789d>] acpi_ipmi_space_handler+0x11b/0x234
[<ffffffff81321c62>] acpi_ev_address_space_dispatch+0x170/0x1be
The fix implemented by this change has been tested by Tony:
Tested the patch in a boot loop with lockdep debug enabled and never
saw the problem in over 400 reboots.
Reported-and-tested-by: Tony Camuso <tcamuso@redhat.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Reviewed-by: Huang Ying <ying.huang@intel.com>
commit 677a31565692d596ef42ea589b53ba289abf4713 upstream.
The `insn_bits` handler `ni_65xx_dio_insn_bits()` has a `for` loop that
currently writes (optionally) and reads back up to 5 "ports" consisting
of 8 channels each. It reads up to 32 1-bit channels but can only read
and write a whole port at once - it needs to handle up to 5 ports as the
first channel it reads might not be aligned on a port boundary. It
breaks out of the loop early if the next port it handles is beyond the
final port on the card. It also breaks out early on the 5th port in the
loop if the first channel was aligned. Unfortunately, it doesn't check
that the current port it is dealing with belongs to the comedi subdevice
the `insn_bits` handler is acting on. That's a bug.
Redo the `for` loop to terminate after the final port belonging to the
subdevice, changing the loop variable in the process to simplify things
a bit. The `for` loop could now try and handle more than 5 ports if the
subdevice has more than 40 channels, but the test `if (bitshift >= 32)`
ensures it will break out early after 4 or 5 ports (depending on whether
the first channel is aligned on a port boundary). (`bitshift` will be
between -7 and 7 inclusive on the first iteration, increasing by 8 for
each subsequent operation.)
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 1e43692cdb7cc445d6347d8a5207d9cef0c71434 upstream.
Added USB ID for Corega WLUSB2GTST USB adapter.
Reported-by: Joerg Kalisch <the_force@gmx.de>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit 60ce314d1750fef843e9db70050e09e49f838b69 upstream.
The private array at the end of the rtl_priv struct is not aligned.
On ARM architecture, this causes an alignment trap and is fixed by aligning
that array with __align(sizeof(void *)). That should properly align that
space according to the requirements of all architectures.
Reported-by: Jason Andrews <jasona@cadence.com>
Tested-by: Jason Andrews <jasona@cadence.com>
commit eb2addd4044b4b2ce77693bde5bc810536dd96ee upstream.
my Huawei 3G modem has an embedded Smart Card reader which causes
trouble when the modem is being detected (a bunch of "<warn> (ttyUSBx):
open blocked by driver for more than 7 seconds!" in messages.log). This
trivial patch corrects the problem for me. The modem identifies itself
as "12d1:1406 Huawei Technologies Co., Ltd. E1750" in lsusb although the
description on the body says "Model E173u-1"
Signed-off-by: Michal Malý <madcatxster@prifuk.cz>
Cc: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 21af8107f27878813d0364733c0b08813c2c192a ]
Meelis Roos reports a crash in esp_free_lun_tag() in the presense
of a disk which has died.
The issue is that when we issue an autosense command, we do so by
hijacking the original command that caused the check-condition.
When we do so we clear out the ent->tag[] array when we issue it via
find_and_prep_issuable_command(). This is so that the autosense
command is forced to be issued non-tagged.
That is problematic, because it is the value of ent->tag[] which
determines whether we issued the original scsi command as tagged
vs. non-tagged (see esp_alloc_lun_tag()).
And that, in turn, is what trips up the sanity checks in
esp_free_lun_tag(). That function needs the original ->tag[] values
in order to free up the tag slot properly.
Fix this by remembering the original command's tag values, and
having esp_alloc_lun_tag() and esp_free_lun_tag() use them.
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
[ Upstream commit 7167cf0e8cd10287b7912b9ffcccd9616f382922 ]
The dma descriptors indexes are only initialized on the probe function.
If a packet is on the buffer when temac_stop is called, the dma
descriptors indexes can be left on a incorrect state where no other
package can be sent.
So an interface could be left in an usable state after ifdow/ifup.
This patch makes sure that the descriptors indexes are in a proper
status when the device is open.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
[ Upstream commit 5a0068deb611109c5ba77358be533f763f395ee4 ]
Recently grabbed this report:
https://bugzilla.redhat.com/show_bug.cgi?id=1005567
Of an issue in which the bonding driver, with an attached vlan encountered the
following errors when bond0 was taken down and back up:
dummy1: promiscuity touches roof, set promiscuity failed. promiscuity feature of
device might be broken.
The error occurs because, during __bond_release_one, if we release our last
slave, we take on a random mac address and issue a NETDEV_CHANGEADDR
notification. With an attached vlan, the vlan may see that the vlan and bond
mac address were in sync, but no longer are. This triggers a call to dev_uc_add
and dev_set_rx_mode, which enables IFF_PROMISC on the bond device. Then, when
we complete __bond_release_one, we use the current state of the bond flags to
determine if we should decrement the promiscuity of the releasing slave. But
since the bond changed promiscuity state during the release operation, we
incorrectly decrement the slave promisc count when it wasn't in promiscuous mode
to begin with, causing the above error
Fix is pretty simple, just cache the bonding flags at the start of the function
and use those when determining the need to set promiscuity.
This is also needed for the ALLMULTI flag
Reported-by: Mark Wu <wudxw@linux.vnet.ibm.com>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Mark Wu <wudxw@linux.vnet.ibm.com>
CC: "David S. Miller" <davem@davemloft.net>
[ Upstream commit bf0ea6380724beb64f27a722dfc4b0edabff816e ]
Pass-all-multicast is controlled by bit 3 in RX control, not bit 2
(pass undersized frames).
Reported-by: Joseph Chang <joseph_chang@davicom.com.tw>
Signed-off-by: Peter Korsgaard <peter@korsgaard.com>
[ Upstream commit 207070f5221e2a901d56a49df9cde47d9b716cd7 ]
Outgoing packets sent by via-rhine have their VLAN PCP field off by one
(when hardware acceleration is enabled). The TX descriptor expects only VID
and PCP (without a CFI/DEI bit).
Peter Boström noticed and reported the bug.
Signed-off-by: Roger Luethi <rl@hellgate.ch>
Cc: Peter Boström <peter.bostrom@netrounds.com>
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ]
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
commit 58f09e00ae095e46ef9edfcf3a5fd9ccdfad065e upstream.
The arg64 struct has a hole after ->buf_size which isn't cleared. Or if
any of the calls to copy_from_user() fail then that would cause an
information leak as well.
This was assigned CVE-2013-2147.
Acked-by: Mike Miller <mike.miller@hp.com>
commit 627aad1c01da6f881e7f98d71fd928ca0c316b1a upstream.
The pciinfo struct has a two byte hole after ->dev_fn so stack
information could be leaked to the user.
commit 3269ee0bd6686baf86630300d528500ac5b516d7 upstream.
At best the current code only seems to free the leaf pagetables and
the root. If you're unlucky enough to have a large gap (like any
QEMU guest with more than 3G of memory), only the first chunk of leaf
pagetables are freed (plus the root). This is a massive memory leak.
This patch re-writes the pagetable freeing function to use a
recursive algorithm and manages to not only free all the pagetables,
but does it without any apparent performance loss versus the current
broken version.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit 0fc86eca1b338d06ec500b34ef7def79c32b602b upstream.
Some error paths do not set a result, leading to the (false)
assumption that the value may be used uninitialized. Set results for
those paths as well.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 5f4513864304672e6ea9eac60583eeac32e679f2 upstream.
After reports from Chris and Josh Boyer of a rare crash in applesmc,
Guenter pointed at the initialization problem fixed below. The patch
has not been verified to fix the crash, but should be applied
regardless.
Reported-by: <jwboyer@fedoraproject.org>
Suggested-by: Guenter Roeck <linux@roeck-us.net>
commit 8d16f258217f2f583af1fd57c5144aa4bbe73e48 upstream.
There is no clear cut rules or specs for the retry interval, as there
are many factors that affect overall response time. Increase the
interval, and even more so on branch devices which may have limited i2c
bit rates.
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reference: https://bugs.freedesktop.org/show_bug.cgi?id=60263
Tested-by: Nicolas Suzor <nic@suzor.com>
Reviewed-by: Todd Previte <tprevite@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 60e356f381954d79088d0455e357db48cfdd6857 upstream.
LVM2, since version 2.02.96, creates origin with zero size, then loads
the snapshot driver and then loads the origin. Consequently, the
snapshot driver sees the origin size zero and sets the hash size to the
lower bound 64. Such small hash table causes performance degradation.
This patch changes it so that the hash size is determined by the size of
snapshot volume, not minimum of origin and snapshot size. It doesn't
make sense to set the snapshot size significantly larger than the origin
size, so we do not need to take origin size into account when
calculating the hash size.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 5ea330a75bd86b2b2a01d7b85c516983238306fb upstream.
The kernel reports a lockdep warning if a snapshot is invalidated because
it runs out of space.
The lockdep warning was triggered by commit 0976dfc1d0cd80a4e9dfaf87bd87
("workqueue: Catch more locking problems with flush_work()") in v3.5.
The warning is false positive. The real cause for the warning is that
the lockdep engine treats different instances of md->lock as a single
lock.
This patch is a workaround - we use flush_workqueue instead of flush_work.
This code path is not performance sensitive (it is called only on
initialization or invalidation), thus it doesn't matter that we flush the
whole workqueue.
The real fix for the problem would be to teach the lockdep engine to treat
different instances of md->lock as separate locks.
Acked-by: Alasdair G Kergon <agk@redhat.com>
direction bit
commit 831abf76643555a99b80a3b54adfa7e4fa0a3259 upstream.
Trying to read data from the Pegasus Technologies NoteTaker (0e20:0101)
[1] with the Windows App (EasyNote) works natively but fails when
Windows is running under KVM (and the USB device handed to KVM).
The reason is a USB control message
usb 4-2.2: control urb: bRequestType=22 bRequest=09 wValue=0200 wIndex=0001 wLength=0008
This goes to endpoint address 0x01 (wIndex); however, endpoint address
0x01 does not exist. There is an endpoint 0x81 though (same number,
but other direction); the app may have meant that endpoint instead.
The kernel thus rejects the IO and thus we see the failure.
Apparently, Linux is more strict here than Windows ... we can't change
the Win app easily, so that's a problem.
It seems that the Win app/driver is buggy here and the driver does not
behave fully according to the USB HID class spec that it claims to
belong to. The device seems to happily deal with that though (and
seems to not really care about this value much).
So the question is whether the Linux kernel should filter here.
Rejecting has the risk that somewhat non-compliant userspace apps/
drivers (most likely in a virtual machine) are prevented from working.
Not rejecting has the risk of confusing an overly sensitive device with
such a transfer. Given the fact that Windows does not filter it makes
this risk rather small though.
The patch makes the kernel more tolerant: If the endpoint address in
wIndex does not exist, but an endpoint with toggled direction bit does,
it will let the transfer through. (It does NOT change the message.)
With attached patch, the app in Windows in KVM works.
usb 4-2.2: check_ctrlrecip: process 13073 (qemu-kvm) requesting ep 01 but needs 81
I suspect this will mostly affect apps in virtual environments; as on
Linux the apps would have been adapted to the stricter handling of the
kernel. I have done that for mine[2].
[1] http://www.pegatech.com/
[2] https://sourceforge.net/projects/notetakerpen/
Signed-off-by: Kurt Garloff <kurt@garloff.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 526867c3ca0caa2e3e846cb993b0f961c33c2abb upstream.
The halted state of a endpoint cannot be cleared over CLEAR_HALT from a
user process, because the stopped_td variable was overwritten in the
handle_stopped_endpoint() function. So the xhci_endpoint_reset() function will
refuse the reset and communication with device can not run over this endpoint.
https://bugzilla.kernel.org/show_bug.cgi?id=60699
Signed-off-by: Florian Wolter <wolly84@web.de>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 284d20552461466b04d6bfeafeb1c47a8891b591 upstream.
When a command times out, the command ring is first aborted,
and then stopped. If the command ring is empty when it is stopped
the stop event will point to next command which is not yet set.
xHCI tries to handle this next event often causing an oops.
Don't handle command completion events on stopped cmd ring if ring is
empty.
This patch should be backported to kernels as old as 3.7, that contain
the commit b92cc66c047ff7cf587b318fe377061a353c120f "xHCI: add aborting
command ring function"
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Reported-by: Giovanni <giovanni.nervi@yahoo.com>
commit e3eb270fab7734427dd8171a93e4946fe28674bc upstream.
The vt6656 is prone to resetting on the usb bus.
It seems there is a race condition and wpa supplicant is
trying to open the device via iw_handlers before its actually
closed at a stage that the buffers are being removed.
The device is longer considered open when the
buffers are being removed. So move ~DEVICE_FLAGS_OPENED
flag to before freeing the device buffers.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
This bug fix is only for stable branches older than 3.10. The bug was
fixed upstream by commit 2768935a4660 ('sfc: reuse pages to avoid DMA
mapping/unmapping costs'), but that change is totally unsuitable for
stable.
Commit b590ace09d51 ('sfc: Fix efx_rx_buf_offset() in the presence of
swiotlb') added an explicit page_offset member to struct
efx_rx_buffer, which must be set consistently with the u.page and
dma_addr fields. However, it failed to add the necessary assignment
in efx_resurrect_rx_buffer(). It also did not correct the calculation
of efx_rx_buffer::dma_addr in efx_resurrect_rx_buffer(), which assumes
that DMA-mapping a page will result in a page-aligned DMA address
(exactly what swiotlb violates).
Add the assignment of efx_rx_buffer::page_offset and change the
calculation of dma_addr to make use of it.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit 46a7c17d26967922092f3a8291815ffb20f6cabe upstream.
iscsi_if_send_reply() may return -ESRCH if there were no targets to send
data to. Currently we're ignoring this value and looping in attempt to do it
over and over, which will usually lead in a hung task like this one:
[ 4920.817298] INFO: task trinity:9074 blocked for more than 120 seconds.
[ 4920.818527] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 4920.819982] trinity D 0000000000000000 5504 9074 2756 0x00000004
[ 4920.825374] ffff880003961a98 0000000000000086 ffff8800001aa000 ffff8800001aa000
[ 4920.826791] 00000000001d4340 ffff880003961fd8 ffff880003960000 00000000001d4340
[ 4920.828241] 00000000001d4340 00000000001d4340 ffff880003961fd8 00000000001d4340
[ 4920.833231]
[ 4920.833519] Call Trace:
[ 4920.834010] [<ffffffff826363fa>] schedule+0x3a/0x50
[ 4920.834953] [<ffffffff82634ac9>] __mutex_lock_common+0x209/0x5b0
[ 4920.836226] [<ffffffff81af805d>] ? iscsi_if_rx+0x2d/0x990
[ 4920.837281] [<ffffffff81053943>] ? sched_clock+0x13/0x20
[ 4920.838305] [<ffffffff81af805d>] ? iscsi_if_rx+0x2d/0x990
[ 4920.839336] [<ffffffff82634eb0>] mutex_lock_nested+0x40/0x50
[ 4920.840423] [<ffffffff81af805d>] iscsi_if_rx+0x2d/0x990
[ 4920.841434] [<ffffffff810dffed>] ? sub_preempt_count+0x9d/0xd0
[ 4920.842548] [<ffffffff82637bb0>] ? _raw_read_unlock+0x30/0x60
[ 4920.843666] [<ffffffff821f71de>] netlink_unicast+0x1ae/0x1f0
[ 4920.844751] [<ffffffff821f7997>] netlink_sendmsg+0x227/0x350
[ 4920.845850] [<ffffffff821857bd>] ? sock_update_netprioidx+0xdd/0x1b0
[ 4920.847060] [<ffffffff82185732>] ? sock_update_netprioidx+0x52/0x1b0
[ 4920.848276] [<ffffffff8217f226>] sock_aio_write+0x166/0x180
[ 4920.849348] [<ffffffff810dfe41>] ? get_parent_ip+0x11/0x50
[ 4920.850428] [<ffffffff811d0d9a>] do_sync_write+0xda/0x120
[ 4920.851465] [<ffffffff810dffed>] ? sub_preempt_count+0x9d/0xd0
[ 4920.852579] [<ffffffff810dfe41>] ? get_parent_ip+0x11/0x50
[ 4920.853608] [<ffffffff81791887>] ? security_file_permission+0x27/0xb0
[ 4920.854821] [<ffffffff811d0f4c>] vfs_write+0x16c/0x180
[ 4920.855781] [<ffffffff811d104f>] sys_write+0x4f/0xa0
[ 4920.856798] [<ffffffff82638e79>] system_call_fastpath+0x16/0x1b
[ 4920.877487] 1 lock held by trinity/9074:
[ 4920.878239] #0: (rx_queue_mutex){+.+...}, at: [<ffffffff81af805d>] iscsi_if_rx+0x2d/0x990
[ 4920.880005] Kernel panic - not syncing: hung_task: blocked tasks
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Cc: Jiri Slaby <jslaby@suse.cz>
commit fb93df1c2d8b3b1fb16d6ee9e32554e0c038815d upstream.
The table has the following format:
typedef struct _ATOM_SRC_DST_TABLE_FOR_ONE_OBJECT //usSrcDstTableOffset pointing to this structure
UCHAR ucNumberOfSrc;
USHORT usSrcObjectID[1];
UCHAR ucNumberOfDst;
USHORT usDstObjectID[1];
}ATOM_SRC_DST_TABLE_FOR_ONE_OBJECT;
usSrcObjectID[] and usDstObjectID[] are variably sized, so we
can't access them directly. Use pointers and update the offset
appropriately when accessing the Dst members.
commit acf88deb8ddbb73acd1c3fa32fde51af9153227f upstream.
Setting MC_MISC_CNTL.GART_INDEX_REG_EN causes hangs on
some boards on resume. The systems seem to work fine
without touching this bit so leave it as is.
v2: read-modify-write the GART_INDEX_REG_EN bit.
I suspect the problem is that we are losing the other
settings in the register.
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=52952
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Tested-by: Daniel Tobias <dan.g.tob@gmail.com>
commit 0b31e02363b0db4e7931561bc6c141436e729d9f upstream.
We need to allocate line buffer to each display when
setting up the watermarks. Failure to do so can lead
to a blank screen. This fixes blank screen problems
on dce4.1/5 asics.
Based on an initial fix from:
Jay Cornwall <jay.cornwall@amd.com>
commit 95663948ba22a4be8b99acd67fbf83e86ddffba4 upstream.
If the LCD table contains an EDID record, properly account
for the edid size when walking through the records.
This should fix error messages about unknown LCD records.
commit 78214e81a1bf43740ce89bb5efda78eac2f8ef83 upstream.
The zeroplus HID driver was not checking the size of allocated values
in fields it used. A HID device could send a malicious output report
that would cause the driver to write beyond the output report allocation
during initialization, causing a heap overflow:
[ 1442.728680] usb 1-1: New USB device found, idVendor=0c12, idProduct=0005
[ 1466.243173] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
CVE-2013-2889
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream.
Many drivers need to validate the characteristics of their HID report
during initialization to avoid misusing the reports. This adds a common
helper to perform validation of the report exisitng, the field existing,
and the expected number of values within the field.
commit 6e956da2027c767859128b9bfef085cf2a8e233b upstream.
We should not do temperature compensation on devices without
EXTERNAL_TX_ALC bit set (called DynamicTxAgcControl on vendor driver).
Such devices can have totally bogus TSSI parameters on the EEPROM,
but still threaded by us as valid and result doing wrong TX power
calculations.
This fix inability to connect to AP on slightly longer distance on
some Ralink chips/devices.
Reported-and-tested-by: Fabien ADAM <id2ndr@crocobox.org>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 0092820407901a0b2c4e343e85f96bb7abfcded1 upstream.
Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com>
Acked-by: Oliver Neukum <oliver@neukum.org>
commit be67b68d52fa28b9b721c47bb42068f0c1214855 upstream.
Defensively check that the field to be worked on is not NULL.
commit 875b4e3763dbc941f15143dd1a18d10bb0be303b upstream.
A HID device could send a malicious feature report that would cause the
ntrig HID driver to trigger a NULL dereference during initialization:
[57383.031190] usb 3-1: New USB device found, idVendor=1b96, idProduct=0001
[57383.315193] BUG: unable to handle kernel NULL pointer dereference at 0000000000000030
[57383.315308] IP: [<ffffffffa08102de>] ntrig_probe+0x25e/0x420 [hid_ntrig]
CVE-2013-2896
Signed-off-by: Rafi Rubin <rafi@seas.upenn.edu>
commit 43622021d2e2b82ea03d883926605bdd0525e1d1 upstream.
The "Report ID" field of a HID report is used to build indexes of
reports. The kernel's index of these is limited to 256 entries, so any
malicious device that sets a Report ID greater than 255 will trigger
memory corruption on the host:
[ 1347.156239] BUG: unable to handle kernel paging request at ffff88094958a878
[ 1347.156261] IP: [<ffffffff813e4da0>] hid_register_report+0x2a/0x8b
CVE-2013-2888
commit 412f30105ec6735224535791eed5cdc02888ecb4 upstream.
A HID device could send a malicious output report that would cause the
pantherlord HID driver to write beyond the output report allocation
[ 310.939483] usb 1-1: New USB device found, idVendor=0e8f, idProduct=0003
[ 315.980774] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten
CVE-2013-2892
commit a1c781bb20ac1e03280e420abd47a99eb8bbdd3b upstream.
They are not implemented, and accessing them might trigger errors
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 026d5b07c03458f9c0ccd19c3850564a5409c325 upstream.
Otherwise in some cases, EAPOL frames might be filtered during the
initial handshake, causing delays and assoc failures.
commit b4f17a488ae2e09bfcf95c0e0b4219c246f1116a upstream.
While reading the config parsing code I noticed this check is missing, without
this check config->desc.wTotalLength can end up with a value larger then the
dev->rawdescriptors length for the config, and when userspace then tries to
get the rawdescriptors bad things may happen.
commit 6dd433e6cf2475ce8abec1b467720858c24450eb upstream.
Both could want to submit the same URB. Some checks of the flag
intended to prevent that were missing.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 3b716caf190ccc6f2a09387210e0e6a26c1d81a4 upstream.
Fix endianess bugs in parallel-port code which caused corrupt
control-requests to be issued on big-endian machines.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit d0bd9a41186e076ea543c397ad8a67a6cf604b55 upstream.
The write_parport_reg_nonblock() function shouldn't sleep because it's
called with spinlocks held.
Acked-by: Johan Hovold <jhovold@gmail.com>
commit 2c4283ca7cdcc6605859c836fc536fcd83a4525f upstream.
In dt282x_ai_insn_read() we call this macro like:
wait_for(!mux_busy(), comedi_error(dev, "timeout\n"); return -ETIME;);
Because the if statement doesn't have curly braces it means we always
return -ETIME and the function never succeeds.
Acked-by: Ian Abbott <abbotti@mev.co.uk>
commit c8476fb855434c733099079063990e5bfa7ecad6 upstream.
If a USB controller with XHCI_RESET_ON_RESUME goes to runtime suspend,
a reset will be performed upon runtime resume. Any previously suspended
devices attached to the controller will be re-enumerated at this time.
This will cause problems, for example, if an open system call on the
device triggered the resume (the open call will fail).
Note that this change is only relevant when persist_enabled is not set
for USB devices.
This patch should be backported to kernels as old as 3.0, that
contain the commit c877b3b2ad5cb9d4fe523c5496185cc328ff3ae9 "xhci: Add
reset on resume quirk for asrock p67 host".
Signed-off-by: Shawn Nematbakhsh <shawnn@chromium.org>
