In order to allow tighter integration with external thermal throttling
code add local temperature and remote critical shutdown temperature
hooks. Rename the existing hooks for clarity.
Add BERR counter functionality to MCP251x driver.
Signed-off-by: Mitja Spes <mitja@lxnav.com>
In order to allow integrating with external thermal throttling code add
a probe callback and remote over-temperature shutdown hooks.
In addition to the critical temperature alarm limit this chip features
a second alarm limit called remote over-temperature shutdown ROS with
a separate pin configurable as trigger output. Implement this feature
and add platform data to allow configuring respective pin as output.
Rather than using hard-coded register indices and offsets define and
use an enumeration thereof.
The irq request flag sometimes does not get reset or is asserted
immediately, but iir does not indicated this, if so ISR is entered with
iir set to 0xc1, i.e. no irq pending.
Try enabling the transmit register empty interrupt, iir becomes 0xc2,
irq gets de-asserted and ier is reverted by the regular code flow in
the ISR.
We try this every 4096 spurious irq.
Revise Ethernet MAC address assignment: should now use MAC from EEPROM
if set and further handles up to two instances of custom user MACs (2nd
one with a 0x100000 offset). This way customer does not have to put
EEPROM on a secondary Ethernet on the carrier board and still gets a
valid official MAC address from us (e.g. analogous to how we did it on
our Protea carrier board).
Fix spurious whitespace in Tegra's UDC driver log message.
Trying to build USB device controller driver as a module failed as
follows:
ERROR: "g_usb_high_speed" [drivers/usb/gadget/tegra_udc.ko] undefined!
This is due to a missing export of above mentioned global variable.
Allow limiting externally accessible USB OTG and host port to full
speed only in order to be compatible with older carrier boards (e.g.
old Colibri Evaluation Board v2.1c, Orchid or Protea). The following
kernel argument can be set to either 0 meaning false or 1 meaning true:
usb_high_speed
Tegra USB1 port needs to issue Port Reset twice internally, otherwise it
fails to enumerate devices attached to it
Signed-off-by: Jim Lin <jilin@nvidia.com>
Signed-off-by: Olof Johansson <olofj@chromium.org>
[ squash two patches into one and minor style cleanups ]
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Android R14 userspace seems to have issues with timestamp support:
[ 14.764337] host1x host1x: SurfaceFlinger: syncpoint id 8 (disp0_a) stuck waiting 3, timeout=2147483447
[ 14.773845] host1x host1x: id 8 (disp0_a) min 2 max 4
[ 14.779163] host1x host1x: id 9 (disp1_a) min 2 max 4
[ 14.784316] host1x host1x: id 18 (2d_0) min 21 max 25
[ 14.789586] host1x host1x: id 20 (disp0_b) min 2 max 4
[ 14.794889] host1x host1x: id 21 (disp1_b) min 2 max 4
[ 14.800241] host1x host1x: id 22 (3d) min 77 max 95
[ 14.805217] host1x host1x: id 24 (disp0_c) min 2 max 4
[ 14.810573] host1x host1x: id 25 (disp1_c) min 2 max 4
[ 14.815873] host1x host1x: id 26 (vblank0) min 800 max 0
[ 14.821264] host1x host1x: id 27 (vblank1) min 684 max 0
[ 14.826810] host1x host1x: waitbase id 3 val 77
Therefore conditionally revert it in that case for now.
See e4e2e776a3d4bf1adf37fc061cfdfb92281f3ace.
Notify USB connection events to otg core. These notifications will be
used by drivers (e.g. otg wakelock driver) who registered for the
events.
See a4c597152f0b69ba1172b3d52d4e9d39ea3bbd53.
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Hack to avoid extensive warning messages from Redpine Signals LiteFi
driver due to unaligned DMA accesses.
Update framebuffer's fix line_length parameter when changing
video mode dynamically.The new line_length should be according
to new x resolution. On addition, check the return value from
dc driver while setting a mode.
Bug 1163682
Bug 1056767
Bug 1056782
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Change-Id: Ib0ab48474f0af3235556a7f7f0d8354af3b50994
Reviewed-on: http://git-master/r/147511
(cherry picked from commit 5856c4afde9459ba6afaf2cdcb07361d9fbf8c79)
Reviewed-on: http://git-master/r/160788
Tested-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
With our default gcc 4.7.2 toolchain from oe building nvhdcp with
activated CONFIG_CC_OPTIMIZE_FOR_SIZE fails as follows:
/linux-toradex.git/drivers/video/tegra/dc/nvhdcp.c: In function
'nvhdcp_downstream_worker':
/linux-toradex.git/drivers/video/tegra/dc/nvhdcp.c:807:3: error:
'b_status' may be used uninitialized in this function
[-Werror=maybe-uninitialized]
/linux-toradex.git/drivers/video/tegra/dc/nvhdcp.c:763:6: note:
'b_status' was declared here
make[5]: *** [drivers/video/tegra/dc/nvhdcp.o] Error 1
Android immediately shuts down due to too low voltage reading from
wm97xx-battery driver on our analog input pins if nothing is connected.
Making our hack not Android dependant means driver still fails loading
on Android therefore resolving above issue for now.
Fix building of Android RNDIS Ethernet gadget.
While the ADC platform data passing worked just fine in kernel 2.6.36.2
this currently fails. Therefore introduce an ugly hack to explicitly
get said data via a board level call back.
Previous HZ / 50 calculation allowed for a touch sampling time of 20 ms
which is not sufficient if either the touch detect delay or the
settling time is longer than 500 us.
Add BTN_TOUCH event reporting to stmpe-ts touchscreen driver. This will
make this touchscreen driver behave consistently wrt. BTN_TOUCH.
cd2d64b1a0a12283d63c9d853d5b1403d5cd6c9d
65db86ac07e2f7f91a552490c0be6a99aab8e4a8
problem:
The macro wiphy_from_scan retrieves wiphy from
wl_priv->escan_info.wiphy which is in turn set by
a 'scan' initiated from kernel space (like
scheduled scan) or from user space (like iwlist command).
Without a scan, a 'connect' crashes in function
wl_inform_single_bss, with NULL pointer access,
as the variable wiphy (in turn, wl->escan_info.wiphy)
is not initialized properly.
solution:
wireless_device data structures maintained for both
STA and P2P mode point to the same wiphy (see,
wl_cfgp2p_register_ndev in wl_cfgp2p.c). So,
irrespective of whatever wireless_device is in
use, a scan will always set wl_priv->escan_info.wiphy
to the same wiphy. There is no point in getting
wiphy using wl_priv->escan_info.wiphy, rather use
the wiphy referred by all wireless_device structures.
Bug 1029792
Bug 1029733
Change-Id: I6d744950d3a053642ffa998b3c3f3ba60c0cb687
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/141629
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
GVS: Gerrit_Virtual_Submit
Do not turn off mmc at probe if watchdog thread is
in use.
Bug 1029792
Bug 1029733
Change-Id: Ia2e303daa27688c96e7fa5941e01cf821166c498
Reviewed-on: http://git-master/r/141628
cleanup bcmdhd driver Kconfig and Makefile
Bug 1029792
Bug 1029733
Change-Id: Ic947644d2159a52fab7aea1621e12e51d8ee6332
Reviewed-on: http://git-master/r/141627
Set activation of a mode forcefully via setting FB_ACTIVATE_FORCE
flag. Required for stereo modes also.
Bug 1005399
Change-Id: I37872cc2a04abc8774a5f9f9df7d9e90f2c977f6
Reviewed-on: http://git-master/r/122087
(cherry picked from commit 80a7b7b2d10a97427e12884d469a518cc2b5f765)
Reviewed-on: http://git-master/r/140033
This patch contains following changes:
1. Modify tegra_fb_update_monspecs to select best mode to apply
on framebuffer, in HDMI hotplug.
2. Add a console_lock to prevent corruption while fbcon running
in multiple threads.
3. Add a tegra_dc_disable/enable in tegra_fb_set_par to reflect
the programmed new mode applied on DC.
Bug: 1005399
Change-Id: I133b38b00f25f767afc05549550fecde8d092fb2
Reviewed-on: http://git-master/r/120932
(cherry picked from commit ec7552ef36c0d0979cb31db6d2d4bd54e7f1c9fb)
Reviewed-on: http://git-master/r/140031
Clean-up the definition of the tegra_gpio enable/disable so that
it compares to the l4t r16 rel.
Change-Id: Ia8584ada1e2a728d2784d6d57c72ed4b0ee01cf1
Signed-off-by: Matt Pedro <mapedro@nvidia.com>
Reviewed-on: http://git-master/r/140648
Removing tegra_gpio_enable calls as they are supported through
set direction calls in the driver.
Change our locking strategy to be the same as the conservative
and ondemand governor for GOV_START and GOV_STOP to allow
for correct handling of multiple CPUs
Bug 1049258
Change-Id: I15ab620e2f9d47b00ec8186c224eb719b9735aa7
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/133360
Reviewed-by: Satya Popuri <spopuri@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Adding the check for vbus before setting the
run bit.
Bug 1046443
Change-Id: If71748f0fe9c942061ca871034ad4298a58efc23
Signed-off-by: Rohith Seelaboyina <rseelaboyina@nvidia.com>
Reviewed-on: http://git-master/r/131733
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Sends kobject_uevent signal back to userspace to signal that
the cpufreq governor has been set to interactive
Bug 1039141
Change-Id: I699e9d5834a1874b36c675764c080112ccba0f9f
Reviewed-on: http://git-master/r/131224
When a throughput hint is available, still keep track of the idle time
percentage and use both in gpu scaling. Also modifying fallback
scaling code to use same idle estimate used when a throughput hint is
available. Dropping different time frames for scaling up and down.
Bug 1034948
Bug 965517
Change-Id: Ib3945642768e36a6c0c50f4195c89e3bb67f8442
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/129410
(cherry picked from commit 1e9974097286a78f34367683a3921c9b5bf77d4d)
Reviewed-on: http://git-master/r/131155
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
As WAR, limit 3d clock frequency and emc clock frequency
when camera is on and chip is AP37. 3d clock is set to
361MHz and 437MHz is requested for emc clock with this
change. This change allows 3d to request 1.1V in Core
instead of 1.3V in AP37.
Bug 1001262
Bug 1019309
Change-Id: I9f46f93d8da0fcf5afe05839177bf0d6e43a5840
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/130945
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
- Set frame duration to 0 in NULL modeset.
bug 1039104
Reviewed-on: http://git-master/r/127603
(cherry picked from commit 604cda21d79ed168e9863f0122eb0c23fa1a901b)
Change-Id: I0be1b96529e40a374e4507ecd3da990677d4cbd4
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/130943
Merge with latest NVIDIA L4T R16.
Only real conflict concerning inverted VBUS gpio support.
Add a variant of rndis_bind_config to let gadget drivers change
rndis vendorID and manufacturer parameters.
Signed-off-by: Benoit Goby <benoit@android.com>
[make rndis_bind_config a static inline function]
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
When reading alarm of RTC-max77663, it didn't set alrm->enabled correctly,
if irq is masked, means disable alarm, alrm->enabled should be set to 0,
else it should be 1.
Change-Id: Id0b1ffd9a816643712f33624d7d52cbe7b66b3c3
Signed-off-by: Daniel Fu <danifu@nvidia.com>
Reviewed-on: http://git-master/r/129593
Reviewed-by: Simone Willett <swillett@nvidia.com>
This patch fixes wait base handling in CDMA timeouts.
Bug 1025617
Change-Id: Ia93e55631c1159da161d5c4f257d3beebf0d3149
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-on: http://git-master/r/129278
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Set default mode for probe and resume to enable initialization of dc.1
Skipping this initialization results in hard system hang.
bug 1030415
Reviewed-on: http://git-master/r/124001
(cherry picked from commit 50fa5e50b74a0534d7524fb6d7dcaa65b2e6e74c)
Change-Id: Id9ad95e114a27c1667f0286443534a23b7fa64d4
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/128533
Set default videomode happens during probe and resume. _tegra_dc_enable
is also called during hotplug, setting default videomode there causes
hdcp test failure.
Bug 991805
Reviewed-on: http://git-master/r/121052
(cherry picked from commit 7d4e0461a88b8cf638963e69829274824fecc38b)
Change-Id: I98be07e883699ba9fa6e222bb1d8ea68d199dfc6
Reviewed-on: http://git-master/r/128532
The wday is configured only when disabled alarm.
When enable alarm, set it to its default reset value 0x01,
and not enable it, to prevent an error happened when re-read the
alarm value into the virtualized generic layer at boot up in
reading alarm setting of RTC.
Bug 1034871
Change-Id: I8bfa997653edaaa286cf768c1827b5ab986f52cc
Reviewed-on: http://git-master/r/129398
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Oliver Neukum <oneukum@suse.de>
Cc: stable@kernel.org
(cherry picked from commit 5b6e9bcdeb65634b4ad604eb4536404bbfc62cfa)
Bug 1040642
Change-Id: I1a8c248016529bebf71d540738ad4726cf3f59b7
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/128693
Add wait for vsync support for one-shot panels. The code supports extension
of this feature to other panels.
Bug 1033411.
Change-Id: Ie4d6cb45e5de81083458169ccdfa33230235ed72
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/128927
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
Add stub runtime_pm calls which go through the flow of enabling and
disabling but don't actually do anything with the device itself as
there's nothing useful we can do. This provides the core PM framework
with information about when the device is idle, enabling chip wide
power savings.
Change-Id: Ie795c16840ccbe07e1a8bfac1a1c5a87281e6849
Reviewed-on: http://git-master/r/128184
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
power savings.
The change is based on change done by Mark Brown for s3c2410 i2c bus
driver.
Author: Mark Brown <broonie@opensource.wolfsonmicro.com>
i2c-s3c2410: Add stub runtime power management
Change-Id: Icb92129c4f79a1642b2b73d14578b05928d745a8
Reviewed-on: http://git-master/r/128151
Rename fast clock to "fast-clk" and div clock to
"div-clk" in driver and clock table to have aligned
with mainline as:
This is based on change:
commit f16e6e77a105ec53496f0d8343895da342917873
Author: Laxman Dewangan <ldewangan@nvidia.com>
i2c: tegra: pass proper name for getting clock
Change-Id: Ie9a1972a18e2e60ac7c84c4509860cf72405ef16
Reviewed-on: http://git-master/r/128150
The Tegra i2c controller actually can not support the reverse of
direction address (toggling r/w bit of address) as controller
take 7 bit address from configuration and HW make it 8 bit address
based on read/write flag.
Hence reverting this protocol mangling support.
Change-Id: I987b2be343d535c078e27b44575717a209d15584
Reviewed-on: http://git-master/r/128149
Sync point values are unsigned, but sysfs creates the text
representation as signed. Correct to use unsigned representation.
Bug 1039058
Change-Id: I96de13952eeeba9510bae179a036459ddee18dcd
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/128075
Reviewed-by: Michal Pecio <mpecio@nvidia.com>
Disable host1x interrupts when clock gating host1x. This fixes a race
where host1x interrupt was raised at the same time when host1x clock
is turned off.
Bug 1031724
Change-Id: I169cd5796608b8888a6b48ed99bb5da754559b2c
Reviewed-on: http://git-master/r/125129
