Various Tegra HS UART backports
Signed-off-by: Mitja Spes <mitja@lxnav.com>
Fix HS UART HW buffer overrun issue when using no flow control
According to multi-touch-protocol.txt the kernel knows two type of
devices:
- Type A: devices which provide anonymous contacts
- Type B: devices which are capable of tracking individual contacts
The Fusion touch screen is a Type B device: The Touch ID field allows
to differentiate between 2 different fingers. This updates the driver
to properly allocate a slot for each identified contact and use the
helper functions available from the input core system.
(cherry picked from commit 698d0a9bb80d94adef58122717c61f55dd61e22d)
Use level triggered interrupt which makes sure that even we miss a
rising edge (due to latencies in the kernel), the interrupt still
will be handled later, and doesn't freeze the input device.
(cherry picked from commit ef25b8a9f9c0ca7cc0f0f955d89d112c3e19f75b)
sscanf() stops at first space it encounters, thus spaces are not represented
i.e. in iManufacturer or iProduct. Fix this by using strlcpy for string
attributes.
[ZI: Backported from upstream android gadget driver]
Signed-off-by: Tobias Klauser <tobias.klauser@zhinst.com>
Certain Hynix eMMC 4.41 cards might get broken when HPI feature is used
and hence this patch disables the HPI feature for such buggy cards.
As some of the other features like BKOPs/Cache/Sanitize are dependent on
HPI feature, those features would also get disabled if HPI is disabled.
Change-Id: I6a638ce089cbd977122e47aecb721bc3f0adf7b0
Signed-off-by: Pratibhasagar V <pratibha@codeaurora.org>
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Fix ported from the following Android MSM kernel commit:
https://www.codeaurora.org/cgit/quic/la/kernel/msm/commit/?id=84af3731019921a28d595dbf6cbf00539706a42c
It is fully legal for a controller to start handling busy-end interrupt
before it has signaled that the command has completed. So make sure
we do things in the proper order, Or it results that command interrupt
is ignored so it can cause unexpected operations. This is founded at some
toshiba emmc with the bellow warning.
"mmc0: Got command interrupt 0x00000001 even though
no command operation was in progress."
This issue has been also reported by Youssef TRIKI:
It is not specific to Toshiba devices, and happens with eMMC devices
as well as SD card which support Auto-CMD12 rather than CMD23.
Also, similar patch is submitted by:
Gwendal Grignou <gwendal@chromium.org>
Changes since v1:
Fixed conflict with the next of git.linaro.org/people/ulf.hansson/mmc.git
and Tested if issue is fixed again.
Signed-off-by: Hankyung Yu <hankyung.yu@lge.com>
Signed-off-by: Chanho Min <chanho.min@lge.com>
Tested-by: Youssef TRIKI <youssef.triki@st.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit e99783a45220a2c5f5a598e0e81213ecf2dbcf2f)
When we wait for busy after sending a command, if there is
a timeout, we got SDHCI_INT_DATA_TIMEOUT flags.
Before this commit we got the message :
"Got data interrupt 0x00100000 even though no data operation was in progress."
and we need to wait 10s that sdhci_timeout_timer expires.
Signed-off-by: Matthieu CASTET <matthieu.castet@parrot.com>
(cherry picked from commit c5abd5e8998e20c2e82999670a03f26f1437d744)
We don't need to change the SDHCI_SDIO_IRQ_ENABLED flag when we're
merely receiving an interrupt - IRQ handling thread in the MMC core
will either re-enable or disable the interrupt via the enable_sdio_irq
callback, which will update this status appropriately.
Tested-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Chris Ball <chris@printf.net>
(cherry picked from commit ef104333a234f66cd13fd16632086a21b90fced6)
sdhci interrupt handling is a mess; there is a lot of code doing very
similar things. Let's clean this up a bit:
1. set's clear down cmd, data and bus power interrupts in one go - we're
always going to handle these.
2. use a do { } while () loop for looping while there are pending
interrupts.
3. group clearing of bits in intmask into one place.
This results in the code becoming simpler and easier to read.
(cherry picked from commit 41005003bcaf4ecfc80e02af01247f2670269816)
When using MSI it is possible that a new MSI is sent while an earlier
MSI is currently handled. In this case SDHCI_INT_STATUS only contains
SDHCI_INT_RESPONSE and the ISR would not be called again. But at the end
of the ISR SDHCI_INT_DATA_END is now also pending which would be ignored.
Fix this by rereading the interrupt flags in the ISR until no interrupt
we care is pending.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
(cherry picked from commit 6379b2375a0c5a6ad437616a4018e6b8fd95e97c)
Ths patch allows runtime PM for sdhci-pci, runtime suspending after
inactivity of 50ms and ensuring runtime resume before SDHC registers
are accessed. During runtime suspend, interrupts are masked.
The host controller state is restored at runtime resume.
For Medfield, the host controller's card detect mechanism is
supplanted by an always-on GPIO which provides for card detect wake-up.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
(cherry picked from commit 66fd8ad5100b5003046aa744a4f12fa31bb831f9)
Revise Ethernet MAC address assignment: should now handle up to two
instances of custom user MACs (2nd one with a 0x100000 offset). This
way customer does not have to worry about NVM on a secondary Ethernet
on the carrier board and still gets a valid official MAC address from
us (e.g. analogous to how we did it on our Protea carrier board).
Please note that instead of defaulting to the default ASIX MAC address
if no valid one is encountered this driver now generates a random one
pre-fixed with the ASIX OUI.
Integrate latest ASIX proprietary driver version 4.17.0
(AX88772C_772B_772A_760_772_178_LINUX_DRIVER_v4.17.0_Source.tar.bz2).
Calculate the number of words in a transfer properly: if there are
129-131 bytes, then number of words is more than 32, therefore the
transfer should be handled with DMA rather than FIFO.
On Tegra30, on a high CPU load or operating at maximum frequency results
in continous interrupt generation, with the following log spewout:
(tegra_w1_irq: line 236) spurious interrupt, status = 0x800
which shows the TX_FIFO_DATA_REQ to be somehow continously being set. To
circumvent this specifically detect the bit transfer and presence done
IRQ's only, for generating a "completion" signal on which the core logic
waits. We anyhow only wait for these interrupts in particular. While at
it, also change the error message to be printed only if it is
conditionally enabled instead of all the time, which floods the serial
console and allows a wrong interpretation of the one wire device not
working at all.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
On Tegra3 at high CPU load, for example while running stress, reading
data from one wire results in the following stack trace:
[ 58.436052] [<c05e93d4>] (__raw_spin_lock_irqsave+0x3c/0xac) from
[<c05e945c>] (_raw_spin_lock_irqsave+0x18/0x1c)
[ 58.446322] [<c05e945c>] (_raw_spin_lock_irqsave+0x18/0x1c) from
[<c0048eb4>] (complete+0x28/0x64)
[ 58.455276] [<c0048eb4>] (complete+0x28/0x64) from [<c03e276c>]
(tegra_w1_irq+0x74/0xb4)
[ 58.463376] [<c03e276c>] (tegra_w1_irq+0x74/0xb4) from [<c009a1fc>]
(handle_irq_event_percpu+0x9c/0x278)
[ 58.472847] [<c009a1fc>] (handle_irq_event_percpu+0x9c/0x278) from
[<c009a424>] (handle_irq_event+0x4c/0x6c)
[ 58.482666] [<c009a424>] (handle_irq_event+0x4c/0x6c) from
[<c009cc40>] (handle_fasteoi_irq+0xe0/0x118)
[ 58.492048] [<c009cc40>] (handle_fasteoi_irq+0xe0/0x118) from
[<c0099bd8>] (generic_handle_irq+0x30/0x40)
[ 58.501616] [<c0099bd8>] (generic_handle_irq+0x30/0x40) from
[<c000ecfc>] (handle_IRQ+0x88/0xc8)
[ 58.510393] [<c000ecfc>] (handle_IRQ+0x88/0xc8) from [<c0008430>]
(asm_do_IRQ+0x18/0x1c)
[ 58.518475] [<c0008430>] (asm_do_IRQ+0x18/0x1c) from [<c000e098>]
(__irq_usr+0x38/0xc0)
[ 58.526464] Exception stack(0xe51a3fb0 to 0xe51a3ff8)
[ 58.531506] 3fa0: 00000000
bea29b04 4030b1b0 4030b4c8
[ 58.539673] 3fc0: 4030b22c 4fd2f305 0000d770 0000d6b0 00000000
00000001 0000000d 00000145
[ 58.547839] 3fe0: 193c62ce bea29af4 4030b22c 4020beb4 600b0010
ffffffff
[ 58.554445] Code: e5843004 e10f0000 f10c0080 e3a02001 (e1953f9f)
[ 58.560539] ---[ end trace fb2fc83ceb8e95c1 ]---
[ 58.565154] Kernel panic - not syncing: Fatal exception in interrupt
[ 58.571520] [<c0014ef4>] (unwind_backtrace+0x0/0xec) from
[<c05e10c8>] (dump_stack+0x20/0x24)
[ 58.580039] [<c05e10c8>] (dump_stack+0x20/0x24) from [<c05e16a0>]
(panic+0x7c/0x1ac)
[ 58.587783] [<c05e16a0>] (panic+0x7c/0x1ac) from [<c0012038>]
(die+0x280/0x2e8)
[ 58.595087] [<c0012038>] (die+0x280/0x2e8) from [<c05e1130>]
(__do_kernel_fault.part.3+0x64/0x84)
[ 58.603952] [<c05e1130>] (__do_kernel_fault.part.3+0x64/0x84) from
[<c0015c84>] (do_page_fault+0x204/0x21c)
[ 58.613681] [<c0015c84>] (do_page_fault+0x204/0x21c) from
[<c000830c>] (do_DataAbort+0x44/0xa8)
[ 58.622369] [<c000830c>] (do_DataAbort+0x44/0xa8) from [<c000de18>]
(__dabt_svc+0x38/0x60)
This seems to be generated due a possible race condition between the on
stack kernel completion being set to NULL in tegra_w1_touch_bit, while a
possible spurious IRQ calling this completion in the IRQ handler. This
is a temporary bandaid and the ideal solution would be to find why this
affects the Tegra3 and not Tegra2.
Springville/i211 with a blank Flash/iNVM use different PCI IDs. Extend
the driver to load despite i210/i211 data sheets claiming tools only,
not for driver.
Only warn rather than fail on NVM validation failures on Apalis T30.
Use the Toradex OUI as default MAC address if no valid one is
encountered.
Tested on samples of Apalis T30 2GB V1.0B, V1.0C, V1.1A, Apalis T30 1GB
V1.0A, V1.1A and Apalis T30 1GB IT V1.1A both with blank NVMs as well
as iNVMs programmed with Intel's defaults.
Springville/i211 with a blank Flash/iNVM use a different PCI ID (tools
only, not for driver) than properly programmed ones.
While at it also fix ethtool time stamping as well as RX flow hash
indirection functionality.
Integrate latest igb driver version 5.2.17
(igb-5.2.17.tar.gz from e1000.sf.net).
drivers/mtd/ubi/ubi.h
drivers/mtd/ubi/wl.c
This reverts commit bdf9e11d339ebc121e80e7ecdd44e0abcaf4ff38.
When commands timeout, previously we had code to
retry the same command 3 times. But under some
situations 3 retries do not suffice. Increasing
the retries to 10 does the trick. Also if the card
does not respond after 10 retries then the card is
dead for sure. But if the same card responds in
between 3 to 10 retries then it is always beneficial
to have retries as 10.
Bug 914934
Change-Id: I6b1e95c10ca5a62dde84ce8cacbe53ad2197ab33
Reviewed-on: http://git-master/r/72092
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
(cherry picked from commit c4beda3e798ed91e1dadbce4206b407832fcc40b)
If the data commands fail due to some error, retry the transfer.
Add 3 retries for data commands.
for bug 914934
Change-Id: I53245ddd159abdbade09f841d9490d2f106e7c88
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-on: http://git-master/r/71181
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
(cherry picked from commit fd804ee58d3f9ce10cb2fe16aa76ae0407912d32)
Add tracepoints to record the start and end of each mmc block
operation. This includes read, write, erase, secure erase,
trim, secure trim1 and secure trim 2, discard and
sanitize commands.
Change-Id: Ic5d1cbdb9adb940d8b1a2a13c73970023575df50
Signed-off-by: Ken Sumrall <ksumrall@android.com>
Signed-off-by: Iliyan Malchev <malchev@google.com>
drivers/mmc/card/block.c
drivers/mmc/core/core.c
(cherry picked from commit 4de9a433c26e47d9b4a93105eb92935321100786)
Support discard feature if MID field in the CID register is 0x15, EXT.CSD[192]
(device version) is 5 and Bit 0 in the EXT.CSD[64] is 1. Also removed REQ_SECURE flag
check to avoid kernel hang.
This patch is released from samsung.
Change-Id: I4023a900680e9bca10c40311b09ed077a22617db
(cherry picked from commit 4acc227edfb631d377e14911287c1b73682fc9c2)
Change-Id: Ia56018522e5d18ca5bfd25858ec943da93d3edc3
(cherry picked from commit e363e576f448d6132340c5d0bda580fef212888d)
drivers/mmc/host/sdhci-tegra.c
Change-Id: I46e3f1a158d61a0b255fae5d510c8f87579c435d
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/47847
Reviewed-by: Kirt Hsieh <Kirt_Hsieh@asus.com>
Tested-by: Kirt Hsieh <Kirt_Hsieh@asus.com>
Reviewed-by: Vincent Yue <Vincent_Yue@asus.com>
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/48199
Reviewed-by: Jim1 Lin <jim1_lin@asus.com>
Tested-by: Jim1 Lin <jim1_lin@asus.com>
Reviewed-by: Leslie Yu <Leslie_Yu@asus.com>
(cherry picked from commit 8eadc6d514b7838c398ff3499ab5f2e012e2fc06)
drivers/mmc/host/sdhci.c
Change-Id: I40a8481618b1a5995a713ff343c7532badd20b65
Change-Id: I399302118c9d8d8246a4a304ff7a1ea80889dbc6
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45568
Reviewed-by: Ban Feng <Ban_Feng@asus.com>
Tested-by: Ban Feng <Ban_Feng@asus.com>
Reviewed-by: Sam hblee <Sam_hblee@asus.com>
(cherry picked from commit 121c0c6dffe16c683f4dbf00ed841fb4de1f70a0)
drivers/mmc/core/mmc.c
Change-Id: I28d670944cbfd55e2b2ad98b727368a8dfdc0944
Change-Id: I2bb65335c2468b257473fe264e705826cfd4474e
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45300
(cherry picked from commit 1711f72a9840f3667cf93c774ac16c2d8417375c)
Change-Id: I89b544afbb0a109a222621a9948399fba8f77693
Change-Id: Ie366a152100a478e7811b4395f3fae9794bb1386
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/45221
include/linux/mmc/card.h
asdf
(tegra-l4t-r16-16.5)
drivers/media/video/tegra_v4l2_camera.c
drivers/watchdog/tegra_wdt.c
include/media/tegra_v4l2_camera.h
The pixel clock polarity setting was wrong: The kernel display flags
are rather somewhat confusing: The flags specify the edge where the
data should be driven by the controller (and hence not sampled by the
display!).
Please note that we don't change the default pixel clock polarity.
Our move to modedb lead to the HDMI display controller always being
enabled (unless forced off by vidargs). This patch makes sure it gets
disabled upon boot disconnected as well as upon later disconnect.
Note: This also fixes DVFS on Colibri T30 in the sense that it will
again stay at 400 MHz EMC as long as no DVI-D aka HDMI display is
connected during boot.
As stated by the eMMC 5.0 specification, a chip should not be rejected
only because of the revision stated in the EXT_CSD_REV field of the
EXT_CSD register.
Remove the control on this value, the control of the CSD_STRUCTURE field
should be sufficient to reject future incompatible changes.
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
(cherry picked from commit 03a59437ef6b6ad7fb0165cb9b96c08d6bf057fc)
With the new eMMC5.1 spec, there is a new EXT_CSD register with
the revision number(EXT_CSD_REV) 7. This patch updates the check
for ext-csd.rev number as 7.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
(cherry picked from commit 6636bad839d9936e73e48c4841eda83a58fcdb53)
This commit, updates the driver to work faster with 32-Lead and 40-Lead
versions of adv7180 chip. Output pin VS/FIELD is now configured as
VSYNC.
Newer eMMC standards use CMD23 for multi-block transfer. These
command has the advantage that only one command is necessary, no
stop command after the transfer is required. The kernel already
supports this command, but we need to enable the capability on
the host level.
Tests verified that the MMC code detects that SD-card do not
support CMD23 and hence don't use that command.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The whole rounding stuff really depends on a specific resolution.
This reverts commit 4dd83942b418b937e3da02746baabf63f37fe682.
Force round down in division calculating required logo height as
preceding code did round up as follows:
logo_lines = DIV_ROUND_UP(logo_height, vc->vc_font.height);
Which resulted in no boot-logo shown at all due to not enough lines
being available.
Additionally disable cursor for custom boot logo.
Using this unconditionally cuts the birds feet (;-p).
This reverts commit 491f263ebfb338c59abfbde6d4e0e7256a0150fa.
Make sure that we dont enter infinite loop due to
negative value of pins in some cases. Also remove
debugging check for refcount.
Bug 1478467
Change-Id: I7df8efa5b3cf8927a0c18363add4f031aca48e48
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/450209
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
