path: root/drivers
2014-04-04ENGR00306993 revert gpu2d may cause bus hang fixkk4.4.2_1.0.0-betaRichard Liu
gpu2d hang fix has side effect, it causes flicker issue for popup window menu on android, not integrate this fix before the side effect be fixed. Revert "ENGR00302036-3 gpu:gpu2d may cause bus hang in some corner case" This reverts commit 0d5505cfd0b50db4bd046270b119c4dae0a143c2. Signed-off-by: Richard Liu <r66033@freescale.com> Acked-by: Shawn Guo
2014-04-02ENGR00302036-3 gpu:gpu2d may cause bus hang in some corner caseLoren Huang
Vivante patch name: cl17466.17776.rls.lockup.2dhang(clear.blit) -Updated the outstanding request limit to 12. -Refined the 2D chip feature check. -Refine the 2D cache flush operation (avoid FE and PE access memory through the same port). -Enable cache flush for filterblt. -Dynamic enabling SPLIT_RECT by checking chip feature(disable for us) -Use brush stretch blt for clear operation. Date: Mar 26, 2014 Signed-off-by: Loren Huang <b02279@freescale.com> Acked-by: Shawn Guo
2014-04-01ENGR00306340 usb: ehci-arc: fix build warningPeter Chen
drivers/usb/host/ehci-arc.c: In function 'ehci_fsl_drv_resume': drivers/usb/host/ehci-arc.c:805: warning: ISO C90 forbids mixed declarations and code Signed-off-by: Peter Chen <peter.chen@freescale.com>
2014-04-01ENGR00306257 [#1027]fix system hang up issue caused by GPURichard Liu
This issue happens when multiple thread is trying to idle GPU at the same time, root cause is some wrong logic related with powerMutex which cause cpu still access GPU AHB register after GPU is suspend(clock off), that cause the bus lockup and make the whole system hang. Signed-off-by: Richard Liu <r66033@freescale.com> Acked-by: Jason Liu
2014-04-01ENGR00303543 usb: ehci-arc: do noop during resume if it is not in host modePeter Chen
We find a bug that the usb will produce endless interrupt during the resume after below steps: - nothing connected at usb otg port, but enable usb gadget driver - system enters suspend - plug in usb cable - system leaves suspend The reasons of endless interrupt is: the host controller resume routine leaves the phy low power mode, but device controller resume routine has still not been called, so the software considers it is still at low power mode. After this time, the vbus change interrupt comes, the wakeup routine considers it is an wakeup interrupt, but in fact it is not. So, the endless interrupt occurs. The solution of this problem is do noop during host controller resume routine if current usb mode is not host mode, and the device controller reusme routine will handle it. Signed-off-by: Peter Chen <peter.chen@freescale.com>
2014-03-27ENGR00305465 MXC IPUv3 fb: Fix permissions of fsl_disp_property sysfs entryJulien Olivain
Set the correct permissions of the fsl_disp_property sysfs entry. Acked-by: Liu Ying <Ying.Liu@freescale.com> Signed-off-by: Julien Olivain <julien.olivain@freescale.com> (cherry picked from commit 9db2d982c90b6edb3dfebe03a68f50f381bb99bb)
2014-03-25ENGR00304402 video: mxc LDB: Enable LDB channel after display controllerLiu Ying
In order to avoid any random pixelation issue, we should follow a correct display controller/LDB initialization sequence, that is, LDB channel should be enabled after its relevant display controller is enabled. Since the enable() callback of the mxc display driver is called after a display controller is enabled, this patch uses the enable()/disable() callbacks to replace the fb notifier callback implemented in the LDB driver. Also, we disable a LDB channel in the setup() callback of the mxc display driver to make sure of the correct sequence in any fb set_par() function. As the enable()/disable() callbacks are always invoked with fb_blank(), this patch drops the suspend()/resume() functions of the LDB driver which do nothing but enable/disable LDB channels. We also remove the code to enable ldb di clocks because they can be enabled when their relevant child pixel clocks are enabled. Conflicts: drivers/video/mxc/ldb.c drivers/video/mxc/mxc_dispdrv.h Signed-off-by: Liu Ying <Ying.Liu@freescale.com> (cherry picked from commit 8d189a9cc067f74cc3d49757af25118b459b9726)
2014-03-18ENGR00303820 [#887] refine physical address check for external memoryXianzhong
2G above address will cause system reboot and fixed in original patch, error check code is added based on the original logic. Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2014-03-10rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
commit c7ac8679bec9397afe8918f788cbcef88c38da54 upstream. The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-04Fix race between starved list and device removalJames Bottomley
scsi_run_queue() examines all SCSI devices that are present on the starved list. Since scsi_run_queue() unlocks the SCSI host lock a SCSI device can get removed after it has been removed from the starved list and before its queue is run. Protect against that race condition by holding a reference on the queue while running it. Reported-by: Chanho Min <chanho.min@lge.com> Reviewed-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-03-04driver: scsi: Stop accepting SCSI requests before removing a devicePeter Chen
Based on Bart Van Assche's below patch Avoid that the code for requeueing SCSI requests triggers a crash by making sure that that code isn't scheduled anymore after a device has been removed. Also, source code inspection of __scsi_remove_device() revealed a race condition in this function: no new SCSI requests must be accepted for a SCSI device after device removal started. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Peter Chen <peter.chen@freescale.com>
2014-02-10ENGR00296516 : FOV fail for ov5640 as camera1(csi)Fang Hui
Set 720x576's HS, HW register's value same as other resolutions Signed-off-by: Fang Hui <b31070@freescale.com>
2014-01-21ENGR00294354 gpu:Using vitural memory cause AXI bus errorLoren Huang
There are two possible reasons to cause AXI bus error 1.Allocate Tile status buffer from virtual memory. It seems gc2000 and gc880 doesn't support tile status buffer from virtual memory. 2.Stream buffer using very beginning gpu mmu address. In this condition, a faked non gpu mmu address maybe generated and fill into gpu which cause AXI bus error. [DATE]09-01-2014 Signed-off-by: Loren Huang <b02279@freescale.com> Acked-by: Shawn Guo
2014-01-10ENGR00294178-1 Sensor:update mma8451 driver to support fifoJianzheng Zhou
Update new sensor version to support new batch feature in Android4.4. Patch is from sensor team. Signed-off-by: b38342 <b38342@freescale.com> Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com> Acked-by: Jason Liu
2014-01-09ENGR00294352 testPreviewPictureSizesCombination failedFang Hui
For some resolution, add some delay to walk around this issue Signed-off-by: Fang Hui <b31070@freescale.com>
2013-12-26ENGR00293329 Audio will block when HDMI-DVI interface pluggedShengjiu Wang
Don't send hdmi_audio uevent when HDMI-DVI connected. Signed-off-by: Shengjiu Wang <b02247@freescale.com>
2013-12-20ENGR00292372 Add consumer IR support in android 4.4Ke Qinghua
Fix EVK SL build failed. Signed-off-by: Ke Qinghua <qinghua.ke@freescale.com>
2013-12-19ENGR00292372 Add consumer IR support in android 4.4Ke Qinghua
Add IR char driver,mx6_ir driver,epit driver and update configuration for support IR. Signed-off-by: Ke Qinghua <qinghua.ke@freescale.com>
2013-12-12ENGR00283354 Wifi:fix one suspend&resume for new wifi driverJianzheng Zhou
In rtl8723as new driver, it introduce CONFIG_MMC_PM_KEEP_POWER , in fact our platform is using boarddata->keep_power_at_suspend to config mmc host's MMC_PM_KEEP_POWER capability.Just remove it will make suspend&resume OK. Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-12-04ENGR00290615 Wifi:Update rtl8723as wifi driverJianzheng Zhou
Update rtl8723as driver from realtek. New version is 20131126_RTL8723A_WiFi_linux_v4.1.8_9660_BT_V2.15_P17. Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-12-04ENGR00290463 revert exact pages allocator to fix system reboot issueXianzhong
System reboot occur during 1080p recording if exit MovieStudio after play a mixed clip with single HDMI, Vivante's intial feedback is alloc_pages_exact/free_pages_exact APIs are not stable in some kernel, In other side, need check if some memory size miscalculated is hided by this optimization. Temporarily this optimization shall be reverted to fix the critical issue. Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2013-11-29ENGR00215174 HDMI video: use default video mode when HDMI cable plug.Liu Xiaowen
In original implement, HDMI driver will use the last video mode when cable plugin. Change the mechanism, use default video mode seting in bootargs. Signed-off-by: Liu Xiaowen <b37945@freescale.com>
2013-11-29ENGR00289999 fixed gc880 invalid command state messageXianzhong
gpu kernel dump the error message when enable DEBUG mode: gckCONTEXT_Update(1493): State 0x0518 is not mapped. gckCONTEXT_Update(1493): State 0x0520 is not mapped. gckCONTEXT_Update(1493): State 0x0518 is not mapped. gckCONTEXT_Update(1493): State 0x0520 is not mapped. align gpu kernel driver to fix the error message Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2013-11-29ENGR00288588 fixed system reboot when run webGL testXianzhong
this is a fake recovery to cause system reboot, when run http://people.mozilla.org/~sicking/webgl/ray.html the fix is to disable GPU recovery in Chrome browser, Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2013-11-29ENGR00283031 [GPU]Integrate 4.6.9p13 release kernel driverXianzhong
Integrate GPU 4.6.9p13 release kernel driver for Android. Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2013-10-25ENGR00284988 Camera recording kernel crash on WFD sourcejb4.3_1.0.0-gaRichard Liu
Fix kernel crash issue meet when do 720p Camera recording on WFD source side, the crash is related with timer schedule, fixed by add protection code in gckOS_StartTimer function. Kernel crash log: [<c004ffec>] (__bug+0x1c/0x28) from [<c00a7e00>] (queue_delayed_work_on+0x10c/0x148) [<c00a7e00>] (queue_delayed_work_on+0x10c/0x148) from [<c046f4d0>] (gckOS_StartTimer+0x44/0x84) [<c046f4d0>] (gckOS_StartTimer+0x44/0x84) from [<c047f4ac>] (gckHARDWARE_SetPowerManagementState+0xa24/0xa5c) [<c047f4ac>] (gckHARDWARE_SetPowerManagementState+0xa24/0xa5c) from [<c046e608>] (gckOS_Broadcast+0xb8/0xe8) [<c046e608>] (gckOS_Broadcast+0xb8/0xe8) from [<c0475734>] (_TryToIdleGPU+0xd8/0x18c) [<c0475734>] (_TryToIdleGPU+0xd8/0x18c) from [<c0476cdc>] (gckEVENT_Notify+0x2dc/0x4c8) [<c0476cdc>] (gckEVENT_Notify+0x2dc/0x4c8) from [<c047d494>] (gckHARDWARE_Interrupt+0x58/0x68) [<c047d494>] (gckHARDWARE_Interrupt+0x58/0x68) from [<c04693a8>] (threadRoutine+0x20/0x78) [<c04693a8>] (threadRoutine+0x20/0x78) from [<c00ad0c8>] (kthread+0x80/0x88) [<c00ad0c8>] (kthread+0x80/0x88) from [<c004d408>] (kernel_thread_exit+0x0/0x8) Signed-off-by: Richard Liu <r66033@freescale.com> Acked-by: Jason Liu
2013-10-23ENGR00278452 PU: fix system hang if run Audio loop testRobin Gong
cpufreq and pu power management will oprate the same register, it looks should keep them operating in order not concurrent. Then use the cpufreq mutex in xPU driver to make sure. Another code bug is in pu power management which base regulator framework, we set the reister directly not regulator, then there is the chance set_volatage will miss the chance if this time voltage setting as the last time setting before PU disable, but we have to do this, so add regulator_sync_voltage to force sync the voltage setting. The drawback is setting twice... Note: This patch is temporary and supposed to be replaced it once we find the root cause. Signed-off-by: Robin Gong <b38343@freescale.com> Acked-by: Jason Liu
2013-10-15ENGR00275869 wifi: update new rtl8723as wifi driverJianzheng Zhou
Base on rtl8723as driver(v4.1.8_9180.20130927_BTCOEX20130528_ver3.3_beta) still do the following changes for imx6: 1.add imx6 in Makefile. 2.fix suspend/resume issue.Just refactor runtime_pm in suspend. Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-10-15ENGR00277333 gpu: Enable OT limitation for gc880Loren HUANG
Enable OT limitation for gc880, without this limitation 3D core may stall system bus when it is running at a very low clock. Signed-off-by: Loren HUANG <b02279@freescale.com> Acked-by: Shawn Guo
2013-09-25ENGR00278899: IPU: fix screen black issue on mx6dqRichard Liu
black screen occurs sometimes during 720p recording when wifi display enable and WFD source is HDMI 720p or 1080p output. This patch is a workaround to fix IPU CSC done on IPU0. console log is below when black screen happen: imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_10 = 0x00080000 imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_5 = 0x00800000 imx-ipuv3 imx-ipuv3.1: IPU Warning - IPU_INT_STAT_5 = 0x00800000 Signed-off-by: Richard Liu <r66033@freescale.com> Acked-by: Jason Liu
2013-09-18ENGR00278701 use alloc_pages instead of alloc_pages_exactRichard Liu
alloc_pages_exact is added by Vivante in gpu git commit e3debfdf4c3f29519ee66d60ac9b5e4db4c41026. alloc_pages_exact is more easy make memory fragment, video playback and camera recording case need large physical continue memory, using alloc_pages_exact will easy make memory fragment and no large physical continue memory, it will impact video playback and camera case. Signed-off-by: Richard Liu <r66033@freescale.com>
2013-09-12ENGR00278179 query gpu memory with seperate typesXianzhong
In this new implementation, gpu memory can be queried with seperate types, root@sabresd_6dq:/ # ./gmem_info Pid Total Reserved Contiguous Virtual Nonpaged Name 2367 143,845,248 42,575,232 98,124,288 0 3,145,728 /system/bin/surfaceflinger 3870 46,297,952 19,706,720 26,066,944 0 524,288 com.android.email 2794 32,802,656 9,753,952 22,524,416 0 524,288 com.android.inputmethod.latin 2844 21,292,240 20,767,952 0 0 524,288 com.android.launcher 2735 15,037,248 14,512,960 0 0 524,288 com.android.systemui 2658 13,812,480 10,273,536 0 0 3,538,944 system_server 3706 10,759,776 10,235,488 0 0 524,288 com.android.settings 3654 10,742,656 10,218,368 0 0 524,288 com.android.contacts 3725 10,719,552 10,195,264 0 0 524,288 com.android.gallery3d 3793 10,715,456 10,191,168 0 0 524,288 com.android.calendar 3837 10,707,904 10,183,616 0 0 524,288 com.android.mms 3774 10,707,072 10,182,784 0 0 524,288 com.android.calculator2 2370 262,144 0 0 0 262,144 /system/bin/mediaserver ------------------------------------------------------------------------------ 13 337,702,384 178,797,040 146,715,648 0 12,189,696 Summary - - 5,752,336 - - - Availabe Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2013-08-30ENGR00277045-1 fix system reboot with video playbackXianzhong
gpu virtual memory cannot be allocated for external use this issue occurs in ARD board with 2G above memory address Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2013-08-28ENGR00277003 IPUv3: Update IC RGB2YUV CSC matrix parametersLiu Ying
This patch updates IPUv3 IC RGB to YUV color space conversion matrix's parameters to align with the default VIV GPU CSC implementation so that we may pass relevant Android CTS test cases. Signed-off-by: Liu Ying <Ying.Liu@freescale.com> (cherry picked from commit 17b6dbef8eea2051a6c3819f3690c21948bd0e93)
2013-08-27ENGR00275429 Recovery: Screen flashing found when wipe data in recovery modeguoyin.chen
Android Recovery UI framework uses FBIOPUT_VSCREENINFO with yoffset update to update display. Both elcdif and ipuv3 FB will set var.activate to be FB_ACTIVATE_FORCE in driver's probe. User space will get the VSCREENINFO with activate been set to FB_ACTIVE_FORCE. Each FBIOPUT_VSCREENINFO with only yoffset update will make the driver reinit.The activate should be cleared once set_par() been finished. HDMI driver should only reinit hdmi only when the mode changed. fbmem will broadcast MODE_CHANGE for each FBIOPUT_VSCREENINFO ioctl even it only have yoffset update. Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
2013-08-23ENGR00274478 fix gpu memory multi-lock failureXianzhong
this issue cause system boot with multi-user switch on JB4.3, root cause is gpu memory cannot be multi-locked in same process, gpu memory lock reference is added to allow multi-lock in kernel driver. Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Jason Liu
2013-08-19ENGR00275613 [EVK_6SL]: system crash when boot without 5640 cameraFang Hui
Fixed by add check for cam->sensor Signed-off-by: Fang Hui <b31070@freescale.com>
2013-08-16ENGR00275408 Wifi: fix rtl8723as reopen error issueJianzheng Zhou
We enable WOW mode last commit, it will try to set mmc host's power capability to keep power on at some points. Delete this act which is bond with one force scan action. For we didn't add force scan function in it. We are using runtime_pm feature to trigger scan when doing init. Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-08-16Merge remote-tracking branch 'fsl-linux-sdk/imx_3.0.35_4.1.0' into ↵guoyin.chen
imx_3.0.35_android
2013-08-16ENGR00275459 mx6sl: csi/v4l: fix kernel dump when do repeated streamon/streamoffrel_imx_3.0.35_4.1.0_rc3rel_imx_3.0.35_4.1.0Robby Cai
When do stream on/off in pair repeatedly without close the v4l device, the kernel dump happens: Unable to handle kernel paging request at virtual address 00200200 pgd = c0004000 [00200200] *pgd=00000000 Internal error: Oops: 805 [#1] PREEMPT Modules linked in: CPU: 0 Not tainted (3.0.35-06027-gbbea887-dirty #21) PC is at camera_callback+0x15c/0x1c8 LR is at 0x200200 pc : [<c03747d0>] lr : [<00200200>] psr: 20000193 sp : c0b0fed0 ip : 00200200 fp : daf1102c r10: daf11034 r9 : 00100100 r8 : daf11098 r7 : daf11100 r6 : daf11034 r5 : daf11000 r4 : c0b0e000 r3 : 00000000 r2 : 00000001 r1 : 00000001 r0 : daf114b8 Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c53c7d Table: 8cc8c059 DAC: 00000015 ... Process swapper (pid: 0, stack limit = 0xc0b0e2e8) Stack: (0xc0b0fed0 to 0xc0b10000) fec0: c0374674 822a4000 daf11000 c0b87eb4 fee0: 00000000 00000027 c0b73904 c0b305e0 00000001 c0374090 da2bbbe0 c0b0e000 ff00: 00000000 c00acc58 00000000 c0098058 00989680 c0b305e0 c0b0e000 00000000 ff20: 00000002 00000001 c0b0e000 00000000 00000000 c00acdf8 00000000 c0b0e000 ff40: 9e4e7881 c0b305e0 c0b0e000 c00aee44 c00aed9c c0b43c6c 00000027 c00ac634 ff60: 00000270 c004257c ffffffff f2a00100 00000027 c00417cc 20000000 00000006 ff80: f40c4000 00000000 c0b0e000 c0b6a924 c0b1876c c0b18764 80004059 412fc09a ffa0: 00000000 00000000 c0063a40 c0b0ffc0 c004f758 c0042690 80000013 ffffffff ffc0: c004266c c004294c c0b1013c 00000000 c10960c0 c00088ec c0008334 00000000 ffe0: 00000000 c00337d4 10c53c7d c0b10060 c00337d0 80008040 00000000 00000000 [<c03747d0>] (camera_callback+0x15c/0x1c8) from [<c0374090>] (csi_irq_handler+ 0x7c/0x160) [<c0374090>] (csi_irq_handler+0x7c/0x160) from [<c00acc58>] ( handle_irq_event_percpu+0x50/0x19c) [<c00acc58>] (handle_irq_event_percpu+0x50/0x19c) from [<c00acdf8>] ( handle_irq_event+0x54/0x84) [<c00acdf8>] (handle_irq_event+0x54/0x84) from [<c00aee44>] (handle_fasteoi_irq +0xa8/0x160) [<c00aee44>] (handle_fasteoi_irq+0xa8/0x160) from [<c00ac634>] ( generic_handle_irq+0x2c/0x40) [<c00ac634>] (generic_handle_irq+0x2c/0x40) from [<c004257c>] (handle_IRQ +0x30/0x84) [<c004257c>] (handle_IRQ+0x30/0x84) from [<c00417cc>] (__irq_svc+0x4c/0xa8) [<c00417cc>] (__irq_svc+0x4c/0xa8) from [<c0042690>] (default_idle+0x24/0x28) [<c0042690>] (default_idle+0x24/0x28) from [<c004294c>] (cpu_idle+0x8c/0xc0) [<c004294c>] (cpu_idle+0x8c/0xc0) from [<c00088ec>] (start_kernel+0x294/0x2e4) [<c00088ec>] (start_kernel+0x294/0x2e4) from [<80008040>] (0x80008040) Code: e88c4200 e595c030 e5858030 e8881800 (e58c8000) ---[ end trace 224150c26d2bd5f7 ]--- The root cause is cam->enc_counter is not re-initialized to 0 when calls STREAMOFF ioctl, and then in DQBUF ioctl wait_event_interruptible_timeout() sees the condition is true and access cam->done_q queue which has no strict check and could be empty. This patch adds the re-initialization and the sanity check. Also, add the pointer check for memcpy because the destination may be NULL on UERSPTR mode. Signed-off-by: Robby Cai <R63905@freescale.com>
2013-08-13ENGR00275011 Make V4L2_PIX_FMT_YUYV visiable as CSI output formatRobby Cai
V4L2_PIX_FMT_YUYV is the original format from camera and the source format for CSI. This format may be needed on Android to do CSC before encoding. We can now choose V4L2_PIX_FMT_YUYV or V4L2_PIX_FMT_UYVY for the CSI output format. Signed-off-by: Robby Cai <R63905@freescale.com>
2013-08-13ENGR00215174 wifi:fix rtl8723as suspend resume fail issueJianzheng Zhou
Fix "Timeout Waiting for Hardware Interrupt on mmc1" issue in suspend/resume which is caused by not keep power in host. Enable WOW mode in card side to enable MMC_KEEP_POWER capability of host will tackle this issue. Signed-off-by: Jianzheng Zhou <jianzheng.zhou@freescale.com>
2013-08-14ENGR00274782 fixed gpu crash when baseAddress is not 0 or 2GXianzhong
The baseAddress of contiguousVidMem is the actual physical address which is not subtracted by gpu baseAddress, but the allocated physical address has been subtracted by gpu baseAddress in gckVIDMEM_Lock, so the invalid offset is produced and used to calculate the logical address. Signed-off-by: Xianzhong <b07117@freescale.com> Acked-by: Shawn Guo
2013-08-12Merge remote-tracking branch 'fsl-linux-sdk/imx_3.0.35_4.1.0' into ↵guoyin.chen
imx_3.0.35_android
2013-08-08ENGR00274493 mx6sl: csi/v4l: Fix capture incorrect data with format UYVYrel_imx_3.0.35_4.1.0_rc2Robby Cai
There's an interim buffer which should only be used when PxP CSC is used. Otherwise the video buffer gets incorrect data by copying the content of interim buffer. The patch fixes this by moving the memcpy to the right place. Signed-off-by: Robby Cai <R63905@freescale.com> (cherry picked from commit 8e0b8ff485dd7cdeabc653f1e27c271ac923710e)
2013-08-08ENGR00273432 DMA: imx-sdma: Allocate 4KB iram page size for bdNicolin Chen
One bd actually needs 4KB page size. So changed the iram_alloc() size parameter to allocate a precise iram memory for bd. This patch also removed the extra iram pool for SDMA due to its insufficient total size: SDMA allows around 48 channels to work simultaneously, so it's better to allocate memory from iram pool directly. [There will be 3KB size waste in sdma->channel_control, which is 640B but actually using 4KB due to 4KB alignment for iram pool.] Acked-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Nicolin Chen <b42378@freescale.com>
2013-08-08ENGR00273973-1 Revert "ENGR00270573-2 [MX6SL]Add support for dynamic Power GatiRobby Cai
This reverts commit 881e21c1275dcc40ccd63fb4fa46b990eeb4fb00. With the commit 881e21c1 and 7b60e285, the system will hang when do suspend and resume stress test continuouly while run edpc test in the background. Revert it now and revisit it later. Signed-off-by: Robby Cai <R63905@freescale.com>
2013-07-25Merge remote-tracking branch 'fsl-linux-sdk/imx_3.0.35_4.1.0' into ↵guoyin.chen
imx_3.0.35_android
2013-07-25ENGR00270573-2 [MX6SL]Add support for dynamic Power Gating of the display MIXRanjani Vaidyanathan
The display MIX can be power gated when EPDC, PXP and LCDIF are all inactive. This will save around 1.5mW-1.8mW of power in system IDLE mode. Need to re-initialize the EPDC and PXP whenever the display MIX is powered up as all the register state is lost when the display MIX is power gated. Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
2013-07-22ENGR00272031 Lcdif FB:Add timestamp in MXCFB_WAIT_FOR_VSYNC's return valueguoyin.chen
Android Framework need the timestamp from VSYNC to driver the UI update Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
