(VM-009) camera.
Signed-off-by: Andrei Andreyanau <a.andreyanau@sam-solutions.com>
modified: drivers/media/video/mt9m111.c
Signed-off-by: Christian Hemp <c.hemp@phytec.de>
particular 'power' button)
Signed-off-by: Uladzimir Bely <u.bely@sam-solutions.net>
modified: drivers/media/video/mxc_camera.c
modified: include/media/soc_camera.h
dividers for 26MHz clock source and 48/96MHz PCLK for mt9p031 camera.
modified: arch/arm/mach-mx6/board-mx6q_phyflex.c
modified: drivers/media/video/mt9p031.c
Disabled some warnings printing: in try_fmt and s_fmt functions -
their return code indicates the correctness of applied formats so
there is no need to print each time messages. Especially it is
meaningfull since gstreamer v4l source plugins are usually trying
several different formats until they found correct.
For led control pca9538 is used. Currently both green and red leds are
on for selected video input.
Works through CPMEM of CSI_MEM channels to do deinterlacing.
camera. Fixed support for switching on/off internal pll of MT9P031 camera and selecion of various target clocks (through the params got from the board specific code).
* soc_camera driver now tries to call enum_input, g_input and s_input
handlers from host camera driver if such exists;
* tw9910 v4l device type redefined from V4L2_INPUT_TYPE_TUNER to
V4L2_INPUT_TYPE_CAMERA;
* added basic implementation of g_input and s_input for managing
current videoinput handlers to tw9910 driver;
Note: currently deinterlacing is disabled by default in the mxc_ipu
driver so tw9910 returns interlaced image. Deinterlacing mode can be
hardcoded on in the csi_enc_setup(struct mxc_camera_dev *cam) from
drivers/media/video/mxc_ipu_csi_enc.c.
mt9p031 camera modified: drivers/media/video/mt9p031.c
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
I don't know what ticket TKT116501 is but
I don't see a problem with pause frame
enabled on rev 1.0 silicon.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
On an overrun, the other flags are not
valid, so don't check them.
Setting the FTRL register will stop the fec from
trying to use multiple receive buffers.
In the driver the testpattern bit (bit 6) are overwritten.
To correct this issue the first bit is to be masked.
Signed-off-by: Heiko Fendrich <h.fendrich@phytec.de>
drivers/net/phy/micrel.c modified: include/linux/micrel_phy.h
kernel driver)
modified: drivers/media/video/mt9v022.c
modified: include/media/v4l2-chip-ident.h
Signed-off-by: Yauhen Kharuzhy <y.kharuzhy@sam-solutions.net>
The sensor has ability to swap even and odd bytes in two-byte formats
and swap color components. Use this for support big endian RGB565,
RGB555, BGR565 and little endian BGR565.
Add ability to set rate and enable/disable of MCLK signal from CPU to
sensor.
Add support for 8-bit and 10-bit grayscale data on CSI interface
(non-tested yet).
Port is based on mx3_camera driver and uses Freescale's IPU driver for
all low-level operations.
speed pin settings as defaults; - turned off 1.8V-flag for SD-slots since on current base board doesn't have sd-cards voltage regulation support; - reverted changes done by previous fix.
than 1362.1
arch/arm/mach-mx6/Makefile
Add frame rate set/get methods to ioctl handlers.
Add handler for enumerating formats supported by sensor.
