soc_camera_link supports passing power on/off control callback to
soc_camera stack. So the power control can be handled by soc_camera
stack instead of our Tegra V4L2 host driver.
Also pass other platform_data fields via soc_camera_link instead of
a hacking nvhost_device_data struct.
Bug 1240806
Bug 1369083
Change-Id: I443a7d28196cc8292805da70d2d5ff1c3cd50a5d
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/246267
(cherry picked from commit 9083d270bf93b583cd5bf5151a52ea250f8541a3)
Reviewed-on: http://git-master/r/279986
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
drivers/media/video/tegra_v4l2_camera.c
CSI host controller of Tegra can support Bayer Raw8 and Raw 10 data
input, it also output data as extended 16-bit data format in memory
directly.
Raw data output should be handled by the second output channel.
This patch add supporting for Raw data input/output and the second
output channel.
All were tested on Cardhu board.
Change-Id: Ifd1d8c94671a1d4571dcf176774e2d3cffafc399
Reviewed-on: http://git-master/r/200225
GVS: Gerrit_Virtual_Submit
Enable IEEE 1588 precision time protocol (PTP) support.
Springville/i211 with a blank Flash/iNVM use different PCI IDs. Extend
the driver to load despite i210/i211 data sheets claiming tools only,
not for driver.
Only warn rather than fail on NVM validation failures on Apalis T30.
Revise Ethernet MAC address assignment: should now handle up to two
instances of custom user MACs (2nd one with a 0x100000 offset). This
way customer does not have to worry about NVM on a secondary Ethernet
on the carrier board and still gets a valid official MAC address from
us (e.g. analogous to how we did it on our Protea carrier board).
Use the Toradex OUI as default MAC address if no valid one is
encountered.
Tested on samples of Apalis T30 2GB V1.0B, V1.0C and Apalis T30 1GB
V1.0A both with blank NVMs as well as iNVMs programmed with Intel's
defaults.
Springville/i211 with a blank Flash/iNVM use a different PCI ID (tools
only, not for driver) than properly programmed ones.
Integrate latest igb driver version 5.1.2
(igb-5.1.2.tar.gz from e1000.sf.net).
This commit adds a method that MAC drivers may call in order to find out
the device number of their associated PTP Hardware Clock.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
Add a new ethtool operation (get_rxfh_indir_size) to get the
indirectional table size. Use this to validate the user buffer size
before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get
the number of RX rings, and validate the contents of the new
indirection table before calling set_rxfh_indir. Remove this
validation from drivers.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Dimitris Michailidis <dm@chelsio.com>
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
While setup, there is a time the serial port is running on a
predefined speed (115200). When data arrived during this phase at
a lower baudrate (e.g. 9600), a lot of overrun and break error
messages were shown. Due to those messages, the terminal setup
never finished, and thus never reached the selected baudrate (e.g.
9600). By choosing a lower baudrate at the startup (9600), a lot
less (if any at all) messages are shown and those initialization
always succeeds.
Another solution would be to disable those messages completely.
However, while normal mode its good to have those UART error
messages.
Hack to avoid 24 Hz mode in X resulting in no display at all. This has
been encountered using e.g. a Samsung SyncMaster F2380 if connected by
HDMI.
root@colibri-t20:~# xrandr
Screen 0: minimum 256 x 128, current 1920 x 1080, maximum 2048 x 2048
LVDS-1 connected 1920x1080+0+0 (normal left inverted right x axis y
axis) 0mm x 0mm
1920x1080 60.0*+
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y
axis) 160mm x 90mm
1920x1080 60.0 + 24.0*
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
1024x768 75.0 70.1 60.0
832x624 74.6
800x600 72.2 75.0 60.3 56.2
720x576 50.0
720x480 59.9
640x480 75.0 72.8 66.7 59.9
720x400 70.1
This is really just enabling the same hack from Apalis/Colibri T30
which is now relevant on the Colibri T20 as well due to the modedb
changes:
3a6fc5303b9e798295caa01d2cfe75b05fdccf55
Before updating modes on HDMI hotplug, check if framebuffer is
registered at all. This allows to disable framebuffers completely.
Use platform independent description for requested GPIOs.
Fix chip reset by sleeping long enought after reset. Do proper error
handling (free GPIO on failure). Use dev_* for message logging to get
similar messages for all fusion driver related errors and warnings.
To avoid warnings use the new I2C power management function for
suspend and resume.
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
When the next interrupt request apeares between the confirmation of
the previous (a write via I2C, fusion_F0710A_write_complete) and
the reenable of the GPIO interrupt, the driver hangs and no more
touch inputs are reported.
This patch moves the confirmation after the reenabling of the GPIO
interrupt.
Recent evdev X-Server input driver implementation complain when
only multitouch axes have been reported ("found only multitouch-axes.
That shouldn't happen."). Therefor also report the primary touch
detection with default axis.
Allow to change clock polarity for RGB display output using the
keywords outputen/pixclockpol/vsync and hsync. Add them right
after the driver specification, use 0/1 to specifiy high/low
polarity, e.g. video=tegrafb0:pixclockpol:1,800x480
Remove special clocks for Tegra 2, but use backup clock source
instead. This allows to run all common used resolution within
the drivers -1/+9% allowed band for pixelclock exactness.
Add some more modes e.g. for full HD panel.
Also add tweaked pixel clock for Tegra 2 because the clock is always
a child of the peripherial clock and only some divisors are available.
HDMI.
root@apalis-t30:~# xrandr
axis) 0mm x 0mm
1920x1080 58.6*+
axis) 160mm x 90mm
1920x1080 60.0*+
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
832x624 74.6
720x576 50.0
720x480 59.9
720x400 70.1
This is basically a revamp of the following commit which got scrapped
by the modedb changes:
8174d21e5fe0d086cb5824161c58eb065f412281
When grepping through sysfs, grep tries to read all sysfs files
which are available. Some of them lead to error due to null pointers.
Therefor check for null pointers before using them.
Updated several comments to make code easier to read and understand.
Also use the front_porch workaround in any case, for HDMI output
too.
In order to find a viable resolution we not only parse VESA mode,
we also parse CEA (multimedia) modes and our own small modedb (for
specific touch screens).
Use new modedb based framebuffer settings by defining default_mode
in the display controllers platform data. Also impelmented the
fallback logic to this default_mode in case no kernel cmd line
parameter was set.
Allow to specify framebufffer videomode using kernel command line
parameters. NVIDIAs binary X driver later on picks up those settings
and start X with current mode settings, if no EDID data are available.
This adds an ADC driver for the STMPE device using the industrial
input/output interface. The driver supports raw reading of values.
The driver depends on the MFD stmpe driver. If the touchscreen
block is enabled too, only for of the 8 ADC channels are available.
In order to use the auxiliar ADC inputs of STMPE811 devices we need
to add resources for the ADC block. Also move the ADC macros from
the touchscreen driver to the general header file. We will need them
for the ADC driver in future.
The voltage table for the SM2 regulator on TPS658643 was wrong. However,
since the requested voltage of 1.8V was at the right place, the system
worked fine nonetheless.
The port used for KEY_BACK does not support wakeup (no wake PIN). Remove
the wake flag, this prevents unbalanced irq warning messages.
After suspend, mode filter might be called with empty yres. This leads
to division by zero when checking aspect ratio. Return as invalid mode
when yres is zero.
When enabling SATA clocks, the PCIE clocks are enabled as well since
those are the parent clocks. In order to enable this parent clocks,
the PCIE regulator avdd_plle needs to be enabled. The resume path used
to freeze because the PCIE PLL did not lock.
Setting the resolution to 1088p (as of now), since
there are flickers observed for 1080p and also
the encoder is not compatible with alignement of
the RM surfaces of 1080p. 1088p is a stop-gap solution
until the issues with 1080p are resolved.
Bug 1369083
Change-Id: I3e73076451e7671d90603c6496ad14733591edeb
Reviewed-on: http://git-master/r/309543
Tested-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Bug 1369083
Change-Id: I1a81bcb62e8f6bb654ffbebba09661187ab4b512
Reviewed-on: http://git-master/r/309536
The tweaks are only specific to r16-r2 branch
and will not go into mainline.
- Pass nvmap memory handle to the user through
the mmap'd buffer allocated by videobuf2 client.
- Allow the "user" nvmap client to access the
nvmap memory handle of "videobuf2-dma-nvmap" client.
Re-arranging the copyright message in nvmap_dev.c
for Automatic validation to pass.
Bug 1369083
Change-Id: Ia27d172253860e79557911c2e848bc9084d662d4
Signed-off-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-on: http://git-master/r/309494
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This reverts commit dd9a841da571a41d43f1eeaac1785b2adb1d80f3.
The config changes (for V4L2) can be done manually as per need
basis for V4L2, followed by compiling the kernel.
Change-Id: I9174bce0f3da2974ab703b238dfb8fb3bbf607c5
Reviewed-on: http://git-master/r/327607
- Disables TEGRA_CAMERA
- Enables SOC_CAMERA and OV5640 sensor support
Bug 1369083
Change-Id: I073c226e9f04a6f4f4699051f624a755dceb36cb
Reviewed-on: http://git-master/r/309491
When hotpluging hdmi the read of edid often fails.
Add up to 4 retries with a 500ms delay before giving up.
Bug 1369083
Change-Id: I1522b688e0681e52592c0f26a8e335937372836a
Reviewed-on: http://git-master/r/279989
Add support for dual cameras from both CSI-A and CSI-B:
- move all the CSI settings into video buffer struct
- queue the video buffer struct to a dedicated queue
- process one video buffer struct from the queue at one time
Bug 1369083
Change-Id: Ie64d69282ab991b66e97327e288a2bacde088bd6
Reviewed-on: http://git-master/r/246269
(cherry picked from commit 228b0c2d9ae3fa1121f88836626d654ae0fc4ff0)
Reviewed-on: http://git-master/r/279987
Bug 1240806
Bug 1369083
Bug 1369083
Change-Id: I43acb0d1dd6ca182291895d294a8458bfc99da05
Reviewed-on: http://git-master/r/279985
Reviewed-by: Allen Martin <amartin@nvidia.com>
Use right buffer flag NVMAP_HANDLE_WRITE_COMBINE to allocate buffer,
which can be shared by VI/CSI and CPU. Don't use NVMAP_HEAP_SYSMEM.
It is validated to old T20 silicon and can't support big buffers. By
default, our nvmap_alloc() will use IOVMM to allocate buffers.
nvmap_pin() gives us IOVA for hardware engines like VI/CSI module
with IOMMU enabled in kernel. nvmap_mmap() gives us VA for CPU
read/write operations. So we need to convert VA address to physical
address of the buffer and map that buffer to user space processor's
memory space "page by page".
Bug 1369083
Change-Id: I4629eebe206c7640adf63551968fd89260dd0082
Reviewed-on: http://git-master/r/279984
- tweak offset registers
- add test mode to output color bars
- use BGGR RAW format
Bug 1369083
Change-Id: I61352c018f8ca099ff3d39158a67052a1e185eec
Reviewed-on: http://git-master/r/279983
