path: root/drivers
2012-11-03Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management & ACPI update from Zhang Rui, Ho humm. Normally these things go through Len. But it's just three small fixes, I guess I can pull directly too. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: exynos4_tmu_driver_ids should be exynos_tmu_driver_ids. ACPI video: Ignore errors after _DOD evaluation. thermal: solve compilation errors in rcar_thermal
2012-11-03Merge branch 'i2c-embedded/for-current' of ↵Linus Torvalds
git://git.pengutronix.de/git/wsa/linux Pull i2c embedded fixes from Wolfram Sang: "Two patches are usual stuff. The bigger patch is needed to correct a wrong decision made in this merge window. We hoped to get the PIOQUEUE mode in the mxs driver working with DMA, but it turned out to be too broken (leading to data loss), so we now think it is best to remove it entirely and work only with DMA now. The patch should be in 3.7. IMO, so users never get the chance to use both modes in parallel." * 'i2c-embedded/for-current' of git://git.pengutronix.de/git/wsa/linux: i2c: tegra: set irq name as device name i2c-nomadik: Fixup clock handling i2c: mxs: remove broken PIOQUEUE support
2012-11-03Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Scattered selection of fixes: - radeon: load detect fixes from SuSE/AMD - intel: misc i830, sdvo regression, vesafb kickoff ums fix - exynos: maintainers entry update + fixes - udl: fix stride scanout issue it's slightly bigger than I'd probably like, but nothing looked dangerous enough to hold off on." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/udl: fix stride issues scanning out stride != width*bpp drm/radeon: add load detection support for ext DAC on R200 (v2) DRM/radeon: For single CRTC GPUs move handling of CRTC_CRT_ON to crtc_dpms(). DRM/Radeon: Fix TV DAC Load Detection for single CRTC chips. DRM/Radeon: Clean up code in TV DAC load detection. drm/radeon: fix ATPX function documentation drivers/gpu/drm/radeon/evergreen_cs.c: Remove unnecessary semicolon DRM/Radeon: On DVI-I use Load Detection when EDID is bogus. DRM/Radeon: Fix primary DAC Load Detection for RV100 chips. DRM/Radeon: Fix Load Detection on legacy primary DAC. drm: exynos: removed warning due to missing typecast for mixer driver data drm/exynos: add support for ARCH_MULTIPLATFORM MAINTAINERS: Add git repository for Exynos DRM drm/exynos: fix display on issue drm/i915: Only kick out vesafb if we takeover the fbcon with KMS drm/i915: be less verbose about inability to provide vendor backlight drm/i915: clear the entire sdvo infoframe buffer drm/i915: VGA needs to be on pipe A on i830M drm/i915: fix overlay on i830M
2012-11-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "First post-Sandy pull request" 1) Fix antenna gain handling and initialization of chan->max_reg_power in wireless, from Felix Fietkau. 2) Fix nexthop handling in H.232 conntrack helper, from Julian Anastasov. 3) Only process 80211 mesh config header in certain kinds of frames, from Javier Cardona. 4) 80211 management frame header length needs to be validated, from Johannes Berg. 5) Don't access free'd SKBs in ath9k driver, from Felix Fietkay. 6) Test for permanent state correctly in VXLAN driver, from Stephen Hemminger. 7) BNX2X bug fixes from Yaniv Rosner and Dmitry Kravkov. 8) Fix off by one errors in bonding, from Nikolay ALeksandrov. 9) Fix divide by zero in TCP-Illinois congestion control. From Jesper Dangaard Brouer. 10) TCP metrics code says "Yo dawg, I heard you like sizeof, so I did a sizeof of a sizeof, so you can size your size" Fix from Julian Anastasov. 11) Several drivers do mdiobus_free without first doing an mdiobus_unregister leading to stray pointer references. Fix from Peter Senna Tschudin. 12) Fix OOPS in l2tp_eth_create() error path, it's another danling pointer kinda situation. Fix from Tom Parkin. 13) Hardware driven by the vmxnet driver can't handle larger than 16K fragments, so split them up when necessary. From Eric Dumazet. 14) Handle zero length data length in tcp_send_rcvq() properly. Fix from Pavel Emelyanov. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits) tcp-repair: Handle zero-length data put in rcv queue vmxnet3: must split too big fragments l2tp: fix oops in l2tp_eth_create() error path cxgb4: Fix unable to get UP event from the LLD drivers/net/phy/mdio-bitbang.c: Call mdiobus_unregister before mdiobus_free drivers/net/ethernet/nxp/lpc_eth.c: Call mdiobus_unregister before mdiobus_free bnx2x: fix HW initialization using fw 7.8.x tcp: Fix double sizeof in new tcp_metrics code net: fix divide by zero in tcp algorithm illinois net: sctp: Fix typo in net/sctp bonding: fix second off-by-one error bonding: fix off-by-one error bnx2x: Disable FCoE for 57840 since not yet supported by FW bnx2x: Fix no link on 577xx 10G-baseT bnx2x: Fix unrecognized SFP+ module after driver is loaded bnx2x: Fix potential incorrect link speed provision bnx2x: Restore global registers back to default. bnx2x: Fix link down in 57712 following LFA bnx2x: Fix 57810 1G-KR link against certain switches. ixgbe: PTP get_ts_info missing software support ...
2012-11-02vmxnet3: must split too big fragmentsEric Dumazet
vmxnet3 has a 16Kbytes limit per tx descriptor, that happened to work as long as we provided PAGE_SIZE fragments. Our stack can now build larger fragments, so we need to split them to the 16kbytes boundary. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: jongman heo <jongman.heo@samsung.com> Tested-by: jongman heo <jongman.heo@samsung.com> Cc: Shreyas Bhatewara <sbhatewara@vmware.com> Reviewed-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Shreyas Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-03exynos4_tmu_driver_ids should be exynos_tmu_driver_ids.Jonghwan Choi
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Reviewed-by: Amit Daniel Kachhap <amit.kachhap@linaro.org> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2012-11-03ACPI video: Ignore errors after _DOD evaluation.Igor Murzov
There are systems where video module known to work fine regardless of broken _DOD and ignoring returned value here doesn't cause any issues later. This should fix brightness controls on some laptops. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=47861 Signed-off-by: Igor Murzov <e-mail@date.by> Reviewed-by: Sergey V <sftp.mtuci@gmail.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2012-11-03thermal: solve compilation errors in rcar_thermalDevendra Naga
following were the errors reported drivers/thermal/rcar_thermal.c: In function ‘rcar_thermal_probe’: drivers/thermal/rcar_thermal.c:214:10: warning: passing argument 3 of ‘thermal_zone_device_register’ makes integer from pointer without a cast [enabled by default] include/linux/thermal.h:166:29: note: expected ‘int’ but argument is of type ‘struct rcar_thermal_priv *’ drivers/thermal/rcar_thermal.c:214:10: error: too few arguments to function ‘thermal_zone_device_register’ include/linux/thermal.h:166:29: note: declared here make[1]: *** [drivers/thermal/rcar_thermal.o] Error 1 make: *** [drivers/thermal/rcar_thermal.o] Error 2 with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) Signed-off-by: Devendra Naga <develkernel412222@gmail.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2012-11-02cxgb4: Fix unable to get UP event from the LLDVipul Pandya
If T4 configuration file gets loaded from the /lib/firmware/cxgb4/ directory then offload capabilities of the cards were getting disabled during initialization. Hence ULDs do not get an UP event from the LLD. Signed-off-by: Jay Hernandez <jay@chelsio.com> Signed-off-by: Vipul Pandya <vipul@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02drivers/net/phy/mdio-bitbang.c: Call mdiobus_unregister before mdiobus_freePeter Senna Tschudin
Based on commit b27393aecf66199f5ddad37c302d3e0cfadbe6c0 Calling mdiobus_free without calling mdiobus_unregister causes BUG_ON(). This patch fixes the issue. The semantic patch that found this issue(http://coccinelle.lip6.fr/): // <smpl> @@ expression E; @@ ... when != mdiobus_unregister(E); + mdiobus_unregister(E); mdiobus_free(E); // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02drivers/net/ethernet/nxp/lpc_eth.c: Call mdiobus_unregister before mdiobus_freePeter Senna Tschudin
Based on commit b27393aecf66199f5ddad37c302d3e0cfadbe6c0 Calling mdiobus_free without calling mdiobus_unregister causes BUG_ON(). This patch fixes the issue. The semantic patch that found this issue(http://coccinelle.lip6.fr/): // <smpl> @@ expression E; @@ ... when != mdiobus_unregister(E); + mdiobus_unregister(E); mdiobus_free(E); // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Tested-by: Roland Stigge <stigge@antcom.de> Tested-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02bnx2x: fix HW initialization using fw 7.8.xDmitry Kravkov
Since commit 96bed4b9 (use FW 7.8.2) BRB HW block needs to be initialized using fw values for all devices. Otherwise ETS on 57712/578xx will not work. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-02Merge tag 'pm-for-3.7-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management update from Rafael J. Wysocki: "Change the email address of the powernow-k8 maintainer." * tag 'pm-for-3.7-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq / powernow-k8: Change maintainer's email address
2012-11-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem fixes from Dmitry Torokhov: "Just a few driver fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: tsc40 - remove wrong announcement of pressure support Input: lpc32xx-keys - select INPUT_MATRIXKMAP Input: pxa27x_keypad - clear pending interrupts on keypad config Input: wacom - correct bad Cintiq 24HD check Input: wacom - add INPUT_PROP_DIRECT flag to Cintiq 24HD Input: egalax_ts - get gpio from devicetree
2012-11-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull more scsi target fixes from Nicholas Bellinger: "This series is a second round of target fixes for v3.7-rc4 that have come into target-devel over the last days, and are important enough to be applied ASAP. All are being CC'ed to stable. The most important two are: - target: Re-add explict zeroing of INQUIRY bounce buffer memory to fix a regression for handling zero-length payloads, a bug that went during v3.7-rc1, and hit >= v3.6.3 stable. (nab + paolo) - iscsi-target: Fix a long-standing missed R2T wakeup race in TX thread processing when using a single queue slot. (Roland) Thanks to Roland & PureStorage team for helping to track down this long standing race with iscsi-target single queue slot operation. Also, the tcm_fc(FCoE) regression bug that was observed recently with -rc2 code has also been resolved with the cancel_delayed_work() return bugfix (commit c0158ca64da5: "workqueue: cancel_delayed_work() should return %false if work item is idle") now in -rc3. Thanks again to Yi Zou, MDR, Robert Love @ Intel for helping to track this down." * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: Fix incorrect usage of nested IRQ spinlocks in ABORT_TASK path iscsi-target: Fix missed wakeup race in TX thread target: Avoid integer overflow in se_dev_align_max_sectors() target: Don't return success from module_init() if setup fails target: Re-add explict zeroing of INQUIRY bounce buffer memory
2012-11-02Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: "An e-mail address update, and fix a compile error on SPARC" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: Only include of_match_table with CONFIG_OF_GPIO hwmon, fam15h_power: Change email address, MAINTAINERS entry
2012-11-02Merge tag 'stable/for-linus-3.7-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bugfixes from Konrad Rzeszutek Wilk: - Use appropriate macros instead of hand-rolling our own (ARM). - Fixes if FB/KBD closed unexpectedly. - Fix memory leak in /dev/gntdev ioctl calls. - Fix overflow check in xenbus_file_write. - Document cleanup. - Performance optimization when migrating guests. * tag 'stable/for-linus-3.7-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/mmu: Use Xen specific TLB flush instead of the generic one. xen/arm: use the __HVC macro xen/xenbus: fix overflow check in xenbus_file_write() xen-kbdfront: handle backend CLOSED without CLOSING xen-fbfront: handle backend CLOSED without CLOSING xen/gntdev: don't leak memory from IOCTL_GNTDEV_MAP_GRANT_REF x86: remove obsolete comment from asm/xen/hypervisor.h
2012-11-02i2c: tegra: set irq name as device nameLaxman Dewangan
When watching the irqs name of tegra i2c, all instances irq name shows as tegra_i2c. Passing the device name properly to have the irq names with instance like tegra-i2c.0, tegra-i2c.1 etc. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-11-02i2c-nomadik: Fixup clock handlingPhilippe Begnic
Make sure to clk_prepare as well as clk_enable. Signed-off-by: Philippe Begnic <philippe.begnic@stericsson.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-11-02i2c: mxs: remove broken PIOQUEUE supportWolfram Sang
This I2C master can do DMA and PIOQUEUE (PIO with FIFO). Originally, only PIOQUEUE was supported and it had issues, then DMA support was added this cycle. The original intention was to keep PIOQUEUE since it has less overhead what is nice for small transfers. However, runtime switching between PIOQEUE and DMA depending on the transfer size never worked despite a lot of trying. Since PIOQUEUE mode itself was flaky (polling at places where interrupts failed to work) and the implementation also imposed a size limit for transfers, it is best to remove the support, so users don't fall over its limitations. It also makes the driver a lot cleaner and more robust. If somebody really wants less overhead, plain PIO mode could still be implemented with the addidtional advantage that this mode is also available on MX23, too. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Reviewed-by: Marek Vasut <marex@denx.de>
2012-11-02drm/udl: fix stride issues scanning out stride != width*bppDave Airlie
When buffer sharing with the i915 and using a 1680x1050 monitor, the i915 gives is a 6912 buffer for the 6720 width, the code doesn't render this properly as it uses one value to set the base address for reading from the vmap and for where to start on the device. This fixes it by calculating the values correctly for the device and for the pixmap. No idea how I haven't seen this before now. Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-11-01hwmon: Only include of_match_table with CONFIG_OF_GPIOJamie Lentin
The following fixes build errors on sparc. Without any DT support, of_match_ptr is NULL and the below is a no-op. However, if just CONFIG_OF is defined then so is of_match_ptr. All useful parts of the gpio-fan DT support rely on CONFIG_OF_GPIO anyway, so of_match_table should too. Signed-off-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-11-02Merge branch 'exynos-drm-fixes' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-fixes Inki writes: "As I posted before, we have added a new git repository for Exynos drm to MAINTAINERS file so change it to new one like below, from git://git.infradead.org/users/kmpark/linux-samsung to git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos And this pull request includes the following: - fix display on issue when user requested dpms mode changing. - add git repository for Exynos drm to MAINTAINERS file. - add support for ARCH_MULTIPLATFORM. - and code clean." * 'exynos-drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos: drm: exynos: removed warning due to missing typecast for mixer driver data drm/exynos: add support for ARCH_MULTIPLATFORM MAINTAINERS: Add git repository for Exynos DRM drm/exynos: fix display on issue
2012-11-02Merge branch 'drm-fixes-3.7' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes Alex writes: "This request is mostly load detection fixes from Egbert and me." * 'drm-fixes-3.7' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: add load detection support for ext DAC on R200 (v2) DRM/radeon: For single CRTC GPUs move handling of CRTC_CRT_ON to crtc_dpms(). DRM/Radeon: Fix TV DAC Load Detection for single CRTC chips. DRM/Radeon: Clean up code in TV DAC load detection. drm/radeon: fix ATPX function documentation drivers/gpu/drm/radeon/evergreen_cs.c: Remove unnecessary semicolon DRM/Radeon: On DVI-I use Load Detection when EDID is bogus. DRM/Radeon: Fix primary DAC Load Detection for RV100 chips. DRM/Radeon: Fix Load Detection on legacy primary DAC.
2012-11-02Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes Daniel Vetter writes" Nothing big at all for -fixes, just small stuff: - Two patches to fix bugs on i830M - ums regression fixer due to kicking firmeware fbs (Chris) - tune down a too loud warning (Jani) - be more careful with sdvo infoframes, which fixes a long-standing sdvo-hdmi regression" * 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel: drm/i915: Only kick out vesafb if we takeover the fbcon with KMS drm/i915: be less verbose about inability to provide vendor backlight drm/i915: clear the entire sdvo infoframe buffer drm/i915: VGA needs to be on pipe A on i830M drm/i915: fix overlay on i830M
2012-11-01bonding: fix second off-by-one errornikolay@redhat.com
Fix off-by-one error because IFNAMSIZ == 16 and when this code gets executed we stick a NULL byte where we should not. How to reproduce: with CONFIG_CC_STACKPROTECTOR=y (otherwise it may pass by silently) modprobe bonding; echo 1 > /sys/class/net/bond0/bonding/mode; echo "AAAAAAAAAAAAAAAA" > /sys/class/net/bond0/bonding/active_slave; Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Note: Sorry for the second patch but I missed this one while checking the file. You can squash them into one patch. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bonding: fix off-by-one errornikolay@redhat.com
Fix off-by-one error because IFNAMSIZ == 16 and when this code gets executed we stick a NULL byte where we should not. How to reproduce: with CONFIG_CC_STACKPROTECTOR=y (otherwise it may pass by silently) modprobe bonding; echo 1 > /sys/class/net/bond0/bonding/mode; echo "AAAAAAAAAAAAAAAA" > /sys/class/net/bond0/bonding/primary; Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bnx2x: Disable FCoE for 57840 since not yet supported by FWDmitry Kravkov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bnx2x: Fix no link on 577xx 10G-baseTYaniv Rosner
Since the Warpcore supports various link types, need to set only the correct supported modes for XFI which is the serdes interface for the 10G-baseT PHY. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Barak Witkowski <barak@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bnx2x: Fix unrecognized SFP+ module after driver is loadedYaniv Rosner
When SFP+ module is plugged in after driver is already loaded, it may not be recognized, so set SFP module recognition time up to 300ms, without resetting the module power in the middle. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Barak Witkowski <barak@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bnx2x: Fix potential incorrect link speed provisionYaniv Rosner
Fix possible incorrect link speed provision following rapid link speed change. Clear link speed mask after each link change, and not only after link down. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Barak Witkowski <barak@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bnx2x: Restore global registers back to default.Yaniv Rosner
Several KR registers were not set correctly back to default after loopback test, so set those global registers over the global WC lane (zero) rather than the current lane. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Barak Witkowski <barak@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bnx2x: Fix link down in 57712 following LFAYaniv Rosner
In case of link flap avoidance between PXE boot and bnx2x, set the appropriate PHY DEVAD even if LFA kicks in. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Barak Witkowski <barak@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01bnx2x: Fix 57810 1G-KR link against certain switches.Yaniv Rosner
Fix 1G KR link by restoring CL72 misc control register to default value rather than 0. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Barak Witkowski <barak@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01ixgbe: PTP get_ts_info missing software supportJacob Keller
This patch corrects the ethtool get_ts_info functon which did not state that software timestamping was supported, even though it is. Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> CC: Stable <stable@vger.kernel.org> [3.5] Tested-by: Stephen Ko <stephen.s.ko@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-01drm/radeon: add load detection support for ext DAC on R200 (v2)Alex Deucher
The R200 asics use an external DAC for the secondary DAC. The current KMS code tries to use code for the integrated TV DAC for R200 which leads to unpredictable results since R200 does not have an integrated TV DAC. This patch ports the external DAC load detection support from the UMS driver to KMS. v2: fix typo in loop break logic Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Egbert Eich <eich@suse.de>
2012-11-01DRM/radeon: For single CRTC GPUs move handling of CRTC_CRT_ON to crtc_dpms().Egbert Eich
On all dual CRTC GPUs the CRTC_CRT_ON in the RADEON_CRTC_EXT_CNTL register controls the CRTC of the primary DAC. Therefore it is set in the DAC DMPS function. This is different for GPU's with a single CRTC but a primary and a TV DAC: here it controls the single CRTC no matter where it is routed. Therefore we set it here. This avoids an elaborate on/off state tracking since both primary_dac_dpms() and tv_dac_dpms() functions would have to touch this bit. On single CRTC GPUs with just one DAC it's irrelevant where this bit is handled. agd5f: fix warning Signed-off-by: Egbert Eich <eich@suse.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-11-01DRM/Radeon: Fix TV DAC Load Detection for single CRTC chips.Egbert Eich
The RN50 has a TV DAC but only a single CRTC. For load detection this DAC is controlled by the primary CRTC. Signed-off-by: Egbert Eich <eich@suse.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-11-01DRM/Radeon: Clean up code in TV DAC load detection.Egbert Eich
2012-11-01drm/radeon: fix ATPX function documentationIgor Murzov
Fix a copy&pasted documentation. Signed-off-by: Igor Murzov <e-mail@date.by> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-11-01drivers/gpu/drm/radeon/evergreen_cs.c: Remove unnecessary semicolonPeter Senna Tschudin
A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r1@ statement S; position p,p1; @@ S@p1;@p @script:python r2@ p << r1.p; p1 << r1.p1; @@ if p[0].line != p1[0].line_end: cocci.include_match(False) @@ position r1.p; @@ -;@p // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-11-01DRM/Radeon: On DVI-I use Load Detection when EDID is bogus.Egbert Eich
The Radeon driver uses the analog/digital flag to determine if the DAC or the TMDS encoder should be enabled on a DVI-I connector. If the EDID is bogus this flag is no longer reliable. This fix adds a fallback to DAC load detection to determine if anything is connected to the DAC. If not and a (bogus) EDID is found it assumes a digital display is connected. This works around problems with some crappy IPMI devices using Radeon ES1000. Signed-off-by: Egbert Eich <eich@suse.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-11-01DRM/Radeon: Fix primary DAC Load Detection for RV100 chips.Egbert Eich
For Radeon 7500 ATI recommends a DAC_FORCE value of 0x1ac. This value works better on ES1000 (RV100) chips, too, as it doesn't produce any false positives on any cards I have tested. Therefore let's assume that this value is good for all RV100 and RV200 chipset generations. Signed-off-by: Egbert Eich <eich@suse.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2012-11-01DRM/Radeon: Fix Load Detection on legacy primary DAC.Egbert Eich
An uninitialized variable led to broken load detection. Signed-off-by: Egbert Eich <eich@suse.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2012-11-01target: Fix incorrect usage of nested IRQ spinlocks in ABORT_TASK pathSteve Hodgson
This patch changes core_tmr_abort_task() to use spin_lock -> spin_unlock around se_cmd->t_state_lock while spin_lock_irqsave is held via se_sess->sess_cmd_lock. Signed-off-by: Steve Hodgson <steve@purestorage.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-01iscsi-target: Fix missed wakeup race in TX threadRoland Dreier
The sleeping code in iscsi_target_tx_thread() is susceptible to the classic missed wakeup race: - TX thread finishes handle_immediate_queue() and handle_response_queue(), thinks both queues are empty. - Another thread adds a queue entry and does wake_up_process(), which does nothing because the TX thread is still awake. - TX thread does schedule_timeout() and sleeps forever. In practice this can kill an iSCSI connection if for example an initiator does single-threaded writes and the target misses the wakeup window when queueing an R2T; in this case the connection will be stuck until the initiator loses patience and does some task management operation (or kills the connection entirely). Fix this by converting to wait_event_interruptible(), which does not suffer from this sort of race. Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: Andy Grover <agrover@redhat.com> Cc: Hannes Reinecke <hare@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-01target: Avoid integer overflow in se_dev_align_max_sectors()Roland Dreier
The expression (max_sectors * block_size) might overflow a u32 (indeed, since iblock sets max_hw_sectors to UINT_MAX, it is guaranteed to overflow and end up with a much-too-small result in many common cases). Fix this by doing an equivalent calculation that doesn't require multiplication. While we're touching this code, avoid splitting a printk format across two lines and use pr_info(...) instead of printk(KERN_INFO ...). Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-11-01target: Don't return success from module_init() if setup failsRoland Dreier
If the call to core_dev_release_virtual_lun0() fails, then nothing sets ret to anything other than 0, so even though everything is torn down and freed, target_core_init_configfs() will seem to succeed and the module will be loaded. Fix this by passing the return value on up the chain. Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-10-31target: Re-add explict zeroing of INQUIRY bounce buffer memoryNicholas Bellinger
This patch fixes a regression in spc_emulate_inquiry() code where the local scope bounce buffer was no longer getting it's memory zeroed, causing various problems with SCSI initiators that depend upon areas of INQUIRY EVPD=0x83 payload having been zeroed. This bug was introduced with the following v3.7-rc1 patch + CC'ed stable commit: commit ffe7b0e9326d9c68f5688bef691dd49f1e0d3651 Author: Paolo Bonzini <pbonzini@redhat.com> Date: Fri Sep 7 17:30:38 2012 +0200 target: support zero allocation length in INQUIRY Go ahead and re-add the missing memset of bounce buffer memory to be copied into the outgoing se_cmd descriptor kmapped SGL payload. Reported-by: Kelsey Prantis <kelsey.prantis@intel.com> Cc: Kelsey Prantis <kelsey.prantis@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Andy Grover <agrover@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull scsi target fixes from Nicholas Bellinger: "These are the current target pending fixes headed for v3.7-rc4 code. This includes the following highlights: - Fix long-standing qla2xxx target bug where certain fc_port_t state transitions could cause the internal session b-tree list to become out-of-sync. (Roland) - Fix task management double free of se_cmd descriptor in exception path for users of target_submit_tmr(). (nab) - Re-introduce simple NOP emulation of REZERO_UNIT, SEEK_6, and SEEK_10 SCSI-2 commands in order to support legacy initiators that still require them. (Bernhard) Note these three patches are also CC'ed to stable. Also, there a couple of outstanding (external) regressions that are still being tracked down for tcm_fc(FCoE) and tcm_vhost fabrics for v3.7.0 code, so please expect another PULL as these issues identified -> resolved." * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: reintroduce some obsolete SCSI-2 commands target: Fix double-free of se_cmd in target_complete_tmr_failure qla2xxx: Update target lookup session tables when a target session changes tcm_qla2xxx: Format VPD page 83h SCSI name string according to SPC qla2xxx: Add missing ->vport_slock while calling qlt_update_vp_map
