The current implementation of poll_sample() has the problem that one of
its arguments, the channel to be selected, differs from wm9713 to other
variants. This parameter gets passed to the (currently unused)
mach-specific functions pre_sample() and post_sample() which thus have
to deal with codec-specific differences. Refactor the routine so that
the argument to poll_sample() is generic for all codecs and do necessary
conversions only in the codec-specific driver. The outcome even uses
less code and removes the non-standard use of the PEN_DOWN bit to mark
the AUX-channels.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This patch implements rumble support for XBox360 Wireless Controllers.
Signed-off-by: Chris Moeller <kode54@gmail.c>
Handle the objects with multiple instances correctly when the configuration
data is loaded.
Signed-off-by: Iiro Valkonen <iiro.valkonen@atmel.com>
Update the object list to include new objects, and add unique identifiers
so we can distinguish between old & new generation of the same object.
The Quick Charge bit in Electrode conf register should be set in init
function. This bit was missed in chip's document, which may cause touch
controller charge too slow to generate an interrupt.
Also, adjust the default vlaue of touch and release threshold
to make touch key more sensitive, this fix touch may not sensitive
after setup with plastic case.
Signed-off-by: Jiejing Zhang <jiejing.zhang@freescale.com>
This driver is registered as an input device. An IRQ is required in this
basic driver configuration.
Signed-off-by: Joseph Lai <joseph_lai@wistron.com>
[Cleaned up PM_RUNTIME defines]
Signed-off-by: Alan Cox <alan@linux.intel.com>
[dtor@mail.ru: consolidated PM methods, some code rearrangement]
This patch updates the email address of the gpio_mouse, at32psif, and
atmel-wm97xx drivers supported by me to an email account I will use on a more
regular basis in the future.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Use gpio_request_one() instead of multiple gpiolib calls.
This also simplifies error handling a bit.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Tested-by: Alex Tervoort <alex.tervoort@gmail.com> for 6A
Signed-off-by: David Foley <favux.is@gmail.com>
Signed-off-by: Ping Cheng <pingc@wacom.com>
D4 has 1024, not 512, pressure levels.
Reported-by: David Foley <favux.is@gmail.com>
Initialize gpio_keys driver at late_initcall level, to give it a chance to
work with GPIO expanders that might not be ready yet if we initialize the
driver at module_init time.
This is strictly a band-aid until there is a better way to specify
inter-device dependencies.
Signed-off-by: David Jander <david@protonic.nl>
Remove the space between "platform:" prefix and the driver name.
It was pointed out by 'make versioncheck' that some includes of
linux/version.h are not needed in drivers/input/.
This patch removes them.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Sammy He <r62914@freescale.com>
Signed-off-by: Eric Miao <eric.miao@linaro.org>
The Wacom DTU-2231 tablet has two interfaces on its default configuration
and both have HID class, leading to the creation of two input devices
instead of one. Only the first one is used, so filter out the second.
Signed-off-by: Aristeu Rozanski <aris@redhat.com>
So don't set ABS_RX/ABS_RY for them.
Signed-off-by: Magnus Hörlin <magnus@alefors.se>
Reviewed-by: Christoph Fritz <chf.fritz@googlemail.com>
Use a threaded interrupt handler in order to permit the handler to use
a GPIO driver that causes things like I2C transactions being done inside
the handler context.
According to the data sheet the interrupt should be level rather than
edge triggered. This fixes the issue of the Nokia N810 keypad stopping
responding if multiple key events occur in quick succession.
Signed-off-by: Leigh Brown <leigh@solinno.co.uk>
There's no need for that workqueue anymore. Get rid of it and move to
threaded IRQs instead.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Tested-by: Leigh Brown <leigh@solinno.co.uk>
A few new i2c-drivers came into the kernel which clear the clientdata
pointer on exit or error. This is not required anymore since the core
will do it for us.
Acked-by: Jean Delvare <khali@linux-fr.org>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon/kms/r6xx+: voltage fixes
drm/nouveau: drop leftover debugging
drm/radeon: avoid warnings from r600/eg irq handlers on powered off card.
drm/radeon/kms: add missing param for dce3.2 DP transmitter setup
drm/radeon/kms/atom: fix duallink on some early DCE3.2 cards
drm/nouveau: fix assumption that semaphore dmaobj is valid in x-chan sync
drm/nv50/disp: fix gamma with page flipping overlay turned on
drm/nouveau/pm: Prevent overflow in nouveau_perf_init()
drm/nouveau: fix big-endian switch
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits)
pxa168_eth: fix race in transmit path.
ipv4, ping: Remove duplicate icmp.h include
netxen: fix race in skb->len access
sgi-xp: fix a use after free
hp100: fix an skb->len race
netpoll: copy dev name of slaves to struct netpoll
ipv4: fix multicast losses
r8169: fix static initializers.
inet_diag: fix inet_diag_bc_audit()
gigaset: call module_put before restart of if_open()
farsync: add module_put to error path in fst_open()
net: rfs: enable RFS before first data packet is received
fs_enet: fix freescale FCC ethernet dp buffer alignment
netdev: bfin_mac: fix memory leak when freeing dma descriptors
vlan: don't call ndo_vlan_rx_register on hardware that doesn't have vlan support
caif: Bugfix - XOFF removed channel from caif-mux
tun: teach the tun/tap driver to support netpoll
dp83640: drop PHY status frames in the driver.
dp83640: fix phy status frame event parsing
phylib: Allow BCM63XX PHY to be selected only on BCM63XX.
0xff01 is not an actual voltage value, but a flag
for the driver. If the power state as that value,
skip setting the voltage.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Because the socket buffer is freed in the completion interrupt, it is not
safe to access it after submitting it to the hardware.
Cc: stable@kernel.org
Cc: Sachin Sanap <ssanap@marvell.com>
Cc: Zhangfei Gao <zgao6@marvell.com>
Cc: Philip Rakity <prakity@marvell.com>
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
As soon as skb is given to hardware, TX completion can free skb under
us.
Therefore, we should update dev stats before kicking the device.
CC: Amit Kumar Salecha <amit.salecha@qlogic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/setup: Fix for incorrect xen_extra_mem_start.
xen: When calling power_off, don't call the halt function.
xen: Fix compile warning when CONFIG_SMP is not defined.
xen: support CONFIG_MAXSMP
xen: partially revert "xen: set max_pfn_mapped to the last pfn mapped"
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: sh_keysc - 8x8 MODE_6 fix
Input: omap-keypad - add missing input_sync()
Input: evdev - try to wake up readers only if we have full packet
Input: properly assign return value of clamp() macro.
this printk isn't really useful, just drop it for now.
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes
* 'drm-nouveau-fixes' of git://anongit.freedesktop.org/git/nouveau/linux-2.6:
Since we were calling the wptr function before checking if the IH was
even enabled, or the GPU wasn't shutdown, we'd get spam in the logs when
the GPU readback 0xffffffff. This reorders things so we return early
in the no IH and GPU shutdown cases.
Reported-and-tested-by: ManDay on #radeon
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
This is used during phy init to set up the phy for DP. This may
fix DP problems on DCE3.2 cards.
Certain revisions of the vbios on DCE3.2 cards have a bug
in the transmitter control table which prevents duallink from
being enabled properly on some cards. The action switch statement
jumps to the wrong offset for the OUTPUT_ENABLE action. The fix
is to use the ENABLE action rather than the OUTPUT_ENABLE action
on the affected cards. In fixed version of the vbios, both
actions jump to the same offset, so the change should be safe.
Reported-and-tested-by: Dave Airlie <airlied@redhat.com>
Its illegal to dereference skb after dev_kfree_skb(skb)
CC: Robin Holt <holt@sgi.com>
As soon as skb is given to hardware and spinlock released, TX completion
can free skb under us. Therefore, we should update netdev stats before
spinlock release.
git://git.kernel.org/pub/scm/linux/kernel/git/romieu/netdev-2.6
Otherwise we will not see the name of the slave dev in error
message:
[ 388.469446] (null): doesn't support polling, aborting.
Signed-off-by: WANG Cong <amwang@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon: (s3c) Initialize sysfs attributes
hwmon: (ibmpex) Initialize sysfs attributes
hwmon: (ibmaem) Initialize sysfs attributes
hwmon: (asus_atk0110) Consolidate sysfs attribute initialization
hwmon: (coretemp) Drop unused struct members
According to the data sheet for G4, AP4 and AG5 KEYSC MODE_6 is 8x8 keys.
Bump up MAXKEYS to 64 too.
Signed-off-by: Magnus Damm <damm@opensource.se>
Reviewed-by: Simon Horman <horms@verge.net.au>
Otherwise the updated evdev driver (commit cdda911c34006f1089f3c87b1a1f,
"Input: evdev - only signal polls on full packets") no longer works on
top of omap-keypad.
Tested on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
We should only wake waiters on the event device when we actually post
an EV_SYN/SYN_REPORT to the queue. Otherwise we end up making waiting
threads runnable only to go right back to sleep because the device
still isn't readable.
Reported-by: Jeffrey Brown <jeffbrown@android.com>
Initialize dynamically allocated sysfs attributes before device_create_file()
call to suppress lockdep_init_map() warning if lockdep debugging is enabled.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: stable@kernel.org # 2.6.34+
Call sysfs_attr_init() from atk_init_attribute() to handle sysfs attribute
initialization in a single function.
Cc: Luca Tettamanti <kronos.it@gmail.com>
pdev_entry.cpu and pdev_entry.cpu_core_id aren't used anywhere in the
driver code so we can drop these struct members.
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Cc: Durgadoss R <durgadoss.r@intel.com>
