path: root/drivers
2009-04-14sbus: changed ioctls to unlockedStoyan Gaydarov
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-14Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: drm/i915: fix scheduling while holding the new active list spinlock drm/i915: Allow tiling of objects with bit 17 swizzling by the CPU. drm/i915: Correctly set the write flag for get_user_pages in pread. drm/i915: Fix use of uninitialized var in 40a5f0de drm/i915: indicate framebuffer restore key in SysRq help message drm/i915: sync hdmi detection by hdmi identifier with 2D drm/i915: Fix a mismerge of the IGD patch (new .find_pll hooks missed) drm/i915: Implement batch and ring buffer dumping
2009-04-14drm/i915: fix scheduling while holding the new active list spinlockShaohua Li
regression caused by commit 5e118f4139feafe97e913df67b1f7c1e5083e535: i915_gem_object_move_to_inactive() should be called in task context, as it calls fput(); Signed-off-by: Shaohua Li<shaohua.li@intel.com> [anholt: Add more detail to the comment about the lock break that's added] Signed-off-by: Eric Anholt <eric@anholt.net>
2009-04-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Add in PCI bus for DMA API debugging. sh: Pre-allocate a reasonable number of DMA debug entries. sh: sh7786: modify usb setup timeout judgment bug. MAINTAINERS: Update sh architecture file patterns. sh: ap325: use edge control for ov772x camera sh: Plug in support for ARCH=sh64 using sh SRCARCH. sh: urquell: Fix up address mapping in board comments. sh: Add support for DMA API debugging. sh: Provide cpumask_of_pcibus() to fix NUMA build. sh: urquell: Add board comment sh: wire up sys_preadv/sys_pwritev() syscalls. sh: sh7785lcr: fix PCI address map for 32-bit mode sh: intc: Added resume from hibernation support to the intc
2009-04-14Fix lpfc_parse_bg_err()'s use of do_div()David Howells
Fix lpfc_parse_bg_err()'s use of do_div(). It should be passing a 64-bit variable as the first parameter. However, since it's only using a 32-bit variable, it doesn't need to use do_div() at all, but can instead use the division operator. This deals with the following warnings: CC drivers/scsi/lpfc/lpfc_scsi.o drivers/scsi/lpfc/lpfc_scsi.c: In function 'lpfc_parse_bg_err': drivers/scsi/lpfc/lpfc_scsi.c:1397: warning: comparison of distinct pointer types lacks a cast drivers/scsi/lpfc/lpfc_scsi.c:1397: warning: right shift count >= width of type drivers/scsi/lpfc/lpfc_scsi.c:1397: warning: passing argument 1 of '__div64_32' from incompatible pointer type Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-14parport: Fix various uses of parport_pcAlan Cox
These got overlooked first time around. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-14tty: Fix leak in ti-usbAlan Cox
If the ti-usb adapter returns an zero data length frame (which happens) then we leak a kref. Found by Christoph Mair <christoph.mair@gmail.com> who proposed a patch. The patch here is different as Christoph's patch didn't work for the case where tty = NULL and data arrived but Christoph did all the hard work chasing it down. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-14cdc-acm: Fix long standing abuse of tty->low_latencyAlan Cox
ACM sets the low latency flag but calls the flip buffer routines from IRQ context which isn't permitted (and as of 2.6.29 causes a warning hence this one was caught) Fortunatelt ACM doesn't need to set this flag in the first place as it only set it to work around problems in ancient (pre tty flip rewrite) kernels. Reported-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13Merge branch 'for-rc1/xen/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'for-rc1/xen/core' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen: add FIX_TEXT_POKE to fixmap xen: honour VCPU availability on boot xen: clean up gate trap/interrupt constants xen: set _PAGE_NX in __supported_pte_mask before pagetable construction xen: resume interrupts before system devices. xen/mmu: weaken flush_tlb_other test xen/mmu: some early pagetable cleanups Xen: Add virt_to_pfn helper function x86-64: remove PGE from must-have feature list xen: mask XSAVE from cpuid NULL noise: arch/x86/xen/smp.c xen: remove xen_load_gdt debug xen: make xen_load_gdt simpler xen: clean up xen_load_gdt xen: split construction of p2m mfn tables from registration xen: separate p2m allocation from setting xen: disable preempt for leave_lazy_mmu
2009-04-13edac: use to_delayed_work()Jean Delvare
The edac-core driver includes code which assumes that the work_struct which is included in every delayed_work is the first member of that structure. This is currently the case but might change in the future, so use to_delayed_work() instead, which doesn't make such an assumption. linux-2.6.30-rc1 has the to_delayed_work() function that will allow this patch to work Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13edac: fix local pci_write_bits32Jeff Haran
Fix the edac local pci_write_bits32 to properly note the 'escape' mask if all ones in a 32-bit word. Currently no consumer of this function uses that mask, so there is no danger to existing code. Signed-off-by: Jeff Haran <jharan@Brocade.COM> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: clean up numerous globalsRobin Holt
Introduce xpc_arch_ops and eliminate numerous individual global definitions. Signed-off-by: Robin Holt <holt@sgi.com> Cc: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: implement opencomplete messagingRobin Holt
sgi-xpc has a window of failure where an open message can be sent and a subsequent data message can get lost. We have added a new message (opencomplete) which closes that window. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sgi-xpc: prevent false heartbeat failuresRobin Holt
The heartbeat timeout functionality in sgi-xpc is currently not trained to the connection time. If a connection is made and the code is in the last polling window prior to doing a timeout, the next polling window will see the heartbeat as unchanged and initiate a no-heartbeat disconnect. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13Replace all DMA_nBIT_MASK macro with DMA_BIT_MASK(n)Yang Hongyang
This is the second go through of the old DMA_nBIT_MASK macro,and there're not so many of them left,so I put them into one patch.I hope this is the last round. After this the definition of the old DMA_nBIT_MASK macro could be removed. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Tony Lindgren <tony@atomide.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Greg KH <greg@kroah.com> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13intelfb: support i854Stefan Husemann
Support the Intel 854 Chipset in fbdev. We test and use the patch on a Thomson IP1101 IPTV-Box. On the VGA-Port we get a normal signal. Here is the link to the Mambux-Project: http://www.mambux.de Cc: Keith Packard <keithp@keithp.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Stefan Husemann <shusemann@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13at25: make input buffers of at25_*write() constGeert Uytterhoeven
| drivers/misc/eeprom/at25.c:358: warning: assignment from incompatible pointer type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13at24: make input buffers of at24_*write() constGeert Uytterhoeven
| drivers/misc/eeprom/at24.c:508: warning: assignment from incompatible pointer type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sysrq: remove duplicated #includeHuang Weiyi
Remove duplicated #include in drivers/char/sysrq.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13spi: spi_write_then_read() bugfixesDavid Brownell
The "simplify spi_write_then_read()" patch included two regressions from the 2.6.27 behaviors: - The data it wrote out during the (full duplex) read side of the transfer was not zeroed. - It fails completely on half duplex hardware, such as Microwire and most "3-wire" SPI variants. So, revert that patch. A revised version should be submitted at some point, which can get the speedup on standard hardware (full duplex) without breaking on less-capable half-duplex stuff. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <stable@kernel.org> [2.6.28.x, 2.6.29.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13cirrusfb: do not allow unsupported pixel depthKrzysztof Helt
Do not allow modes with unsupported pixel depth. Otherwise, one can hang a computer by setting incorrect value with fbset command. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13drivers/video/aty/radeon_base.c: fix typo in commentPaul Menzel
Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sisfb: fix color component length for pseudocolor modesMichal Januszewski
sisfb incorrectly sets the length of the color fields to 6 bits for PSEUDOCOLOR modes, even though 8 bits are always used per pixel. Fix this by setting the length to 8. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Thomas Winischhofer <thomas@winischhofer.net> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sa1100fb: fix color component length for pseudocolor modesMichal Januszewski
sa1100fb incorrectly sets the length of the color fields to 8 bits for PSEUDOCOLOR modes for which only 4 bits are used per pixel. Fix this by setting the length to 4 bits for these modes. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13s3fb: fix color component length for pseudocolor modesMichal Januszewski
s3fb incorrectly sets the length of the color fields to 6 bits for PSEUDOCOLOR modes, even though 8 or 4 bits are used per pixel. Fix this by setting the length to 8 or 4, respectively. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13hwmon: sht15 humidity sensor driverJonathan Cameron
Data sheet at: http://www.sensirion.ch/en/pdf/product_information/Datasheet-humidity-sensor-SHT1x.pdf These sensors communicate over a 2 wire bus running a device specific protocol. The complexity of the driver is mainly due to handling the substantial delays between requesting a reading and the device pulling the data line low to indicate that the data is available. This is handled by an interrupt that is disabled under all other conditions. I wasn't terribly clear on the best way to handle this, so comments on that aspect would be particularly welcome! Interpretation of the temperature depends on knowing the supply voltage. If configured in a board config as a regulator consumer this is obtained from the regulator subsystem. If not it should be provided in the platform data. I've placed this driver in the hwmon subsystem as it is definitely a device that may be used for hardware monitoring and with it's relatively slow response times (up to 120 millisecs to get a reading) a caching strategy certainly seems to make sense! Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13efifb: exit if framebuffer address is invalidMatthew Garrett
efifb will attempt to ioremap a framebuffer even if its starting address is 0, failing and causing an ugly backtrace in the process. Exit before probing if this is the case. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Peter Jones <pjones@redhat.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13uvesafb: fix color component length for pseudocolor modesMichal Januszewski
uvesafb incorrectly sets the length of the color fields to 6 bits for PSEUDOCOLOR modes, even though 8 bits are always used per pixel. Fix this by setting the length to 8. The switch of the DAC width from the default 6 bits to 8 bits is retained and tracked internally in the driver, but never exposed to userspace. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <syrjala@sci.fi> Cc: Geert Uytterhoeven <geert.uytterhoeven@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13fbdev: fix color component field length documentationMichal Januszewski
The documentation about the meaning of the color component bitfield lengths in pseudocolor modes is inconsistent. Fix it, so that it indicates the correct interpretation everywhere, i.e. that 1 << length is the number of palette entries. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <syrjala@sci.fi> Acked-by: Geert Uytterhoeven <geert.uytterhoeven@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13fbdev: fix info->lock deadlock in fbcon_event_notify()Andrea Righi
fb_notifier_call_chain() is called with info->lock held, i.e. in do_fb_ioctl() => FBIOPUT_VSCREENINFO => fb_set_var() and the some notifier callbacks, like fbcon_event_notify(), try to re-acquire info->lock again. Remove the lock/unlock_fb_info() in all the framebuffer notifier callbacks' and be sure to always call fb_notifier_call_chain() with info->lock held. Reported-by: Pavel Roskin <proski@gnu.org> Reported-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13hp_accel: remove unused #include <version.h>Huang Weiyi
Remove unused #include <version.h> in drivers/hwmon/hp_accel.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-14Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2009-04-13Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ata: fix obviously wrong comment ahci: force CAP_NCQ for earlier NV MCPs [libata] sata_via: kill uninit'd var warning
2009-04-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (22 commits) Input: i8042 - add HP DV9700 to the noloop list Input: arrange drivers/input/misc/Makefile in alphabetical order Input: add AD7879 Touchscreen driver Input: add AD7877 touchscreen driver Input: bf54x-keys - fix typo in warning Input: add driver for S1 button of rb532 Input: generic driver for rotary encoders on GPIOs Input: hilkbd - fix crash when removing hilkbd module Input: atkbd - add quirk for Fujitsu Siemens Amilo PA 1510 Input: atkbd - consolidate force release quirk setup Input: add accelerated touchscreen support for Marvell Zylonite Input: ucb1400_ts, mainstone-wm97xx - add BTN_TOUCH events Input: wm97xx - use disable_irq_nosync() for Mainstone Input: wm97xx - add BTN_TOUCH event to wm97xx to use it with Android Input: fix polling of /proc/bus/input/devices Input: psmouse - add newline to OLPC HGPK touchpad debugging Input: ati_remote2 - check module params Input: ati_remote2 - add per device attrs Input: ati_remote2 - complete suspend support Input: stop autorepeat timer on key release ...
2009-04-13PM/Hibernate: Wait for SCSI devices scan to complete during resumeRafael J. Wysocki
There is a race between resume from hibernation and the asynchronous scanning of SCSI devices and to prevent it from happening we need to call scsi_complete_async_scans() during resume from hibernation. In addition, if the resume from hibernation is userland-driven, it's better to wait for all device probes in the kernel to complete before attempting to open the resume device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Avoid panic() for DRHD at address zero. Intel-IOMMU Alignment Issue in dma_pte_clear_range()
2009-04-13Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Let new-style drivers implement attach_adapter i2c: Fix sparse warnings for I2C_BOARD_INFO() i2c-voodoo3: Deprecate in favor of tdfxfb i2c-algo-pca: Fix use of uninitialized variable in debug message
2009-04-13Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-ledsLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds: leds: just ignore invalid GPIOs in leds-gpio
2009-04-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] omap_wdt.c: move probe function to .devinit.text [WATCHDOG] ks8695_wdt.c: move probe function to .devinit.text [WATCHDOG] at91rm9200_wdt.c: move probe function to .devinit.text [WATCHDOG] remove ARM26 sections [WATCHDOG] orion5x_wdt: Add shutdown callback, use watchdog ping function [WATCHDOG] i6300esb.c: Restructure initialization of the device [WATCHDOG] i6300esb.c: Fix the GETSTATUS and GETBOOTSTATUS ioctls. [WATCHDOG] i6300esb.c: Cleanup
2009-04-13Merge branch 'for-linus' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze: (60 commits) microblaze_v8: Add MAINTAINERS fragment microblaze_v8: Uartlite for Microblaze microblaze_v8: Makefiles for Microblaze cpu microblaze_v8: Kconfig patches microblaze_v8: Interrupt handling and timer support microblaze_v8: syscalls.h microblaze_v8: pci headers microblaze_v8: Kbuild file microblaze_v8: string.h thread_info.h microblaze_v8: unistd.h microblaze_v8: fcntl.h sockios.h ucontext.h microblaze_v8: pool.h socket.h microblaze_v8: device.h param.h topology.h microblaze_v8: headers files entry.h current.h mman.h registers.h sembuf.h microblaze_v8: namei.h microblaze_v8: gpio.h, serial.h microblaze_v8: headers simple files - empty or redirect to asm-generic microblaze_v8: sigcontext.h siginfo.h microblaze_v8: termbits.h termios.h microblaze_v8: stats headers ...
2009-04-13i2c: Let new-style drivers implement attach_adapterJean Delvare
While it isn't the way the standard device binding model works, it is OK for new-style drivers to implement attach_adapter. It may help convert the renaming legacy drivers to new style drivers faster. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net>
2009-04-13i2c-voodoo3: Deprecate in favor of tdfxfbJean Delvare
Support for I2C/DDC was recently added to the tdfxfb driver, which means that the i2c-voodoo3 driver can be deprecated. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
2009-04-13i2c-algo-pca: Fix use of uninitialized variable in debug messageJean Delvare
A recent change broke debugging of pca_xfer(), fix it. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2009-04-13ata: fix obviously wrong commentVegard Nossum
Also remove the now-useless debug printouts which are supposed to tell us when the scan starts and ends. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-13ahci: force CAP_NCQ for earlier NV MCPsTejun Heo
Along with MCP65, MCP67 and 73 also don't set CAP_NCQ. Force it. Reported by zaceni@yandex.ru on bko#13014 and confirmed by Peer Chen. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: NightFox <zaceni2@yandex.ru> Cc: Peer Chen <pchen@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-13[libata] sata_via: kill uninit'd var warningJeff Garzik
Reported and initial patch by Marin Mitov. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-11Revert "ACPI battery: fix async boot oops"Linus Torvalds
This reverts commit 5d38258ec026921a7b266f4047ebeaa75db358e5, since the underlying problem got fixed properly in the previous commit ("async: Fix module loading async-work regression"). Cc: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10intel-iommu: Avoid panic() for DRHD at address zero.David Woodhouse
If the BIOS does something obviously stupid, like claiming that the registers for the IOMMU are at physical address zero, then print a nasty message and abort, rather than trying to set up the IOMMU and then later panicking. It's becoming more and more obvious that trusting this stuff to the BIOS was a mistake. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-10Merge git://git.infradead.org/~dwmw2/firmware-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/firmware-2.6: qla1280: Fix off-by-some error in firmware loading. Add README.AddingFirmware file. Basically telling people not to. firmware: Remove newly-added slicoss and sxg firmware images firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fw ALSA: wavefront - Always use request_firmware() Remove fdump tool for av7110 firmware firmware: convert av7110 driver to request_firmware() Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card" Revert "fix modules_install via NFS" Add-add conflicts in firmware/WHENCE fixed manually
2009-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: Separate out the proc- and unit-specific header directories from the general Move arch headers from include/asm-mn10300/ to arch/mn10300/include/asm/.
