Call tegra_hotplug_signal to queue deferred work after a delay of 30ms and call gpio_get_value
in tegra_dc_hpd
bug 1310096
bug 1298680
Change-Id: Iab37af3258429b1e281705eb5b077be31b53b07f
Signed-off-by: sharath sarangpur <ssarangpur@nvidia.com>
Reviewed-on: http://git-master/r/241633
GVS: Gerrit_Virtual_Submit
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Anshul Jain (SW) <anshulj@nvidia.com>
This change takes a wakelock before stating the recovery
mechanism of JS
Bug 1306389
Change-Id: I0109455647988248f1e37d5a000e1e34654e40e5
Signed-off-by: Anshul Jain <anshulj@nvidia.com>
Reviewed-on: http://git-master/r/241103
This change recovery the JS uC after USB resume failure by
unloading USB, resetting uC from ISSP and then reloading USB
Bug 1306389
Change-Id: I086636d4b7b91e3a2874f584fa6efbfd2cae6014
Signed-off-by: Michael Hsu <mhsu@nvidia.com>
Reviewed-on: http://git-master/r/240004
Unbalanced irq_enable/disable will cause potential risk of the sensor
data not being sent out. Add critical section and flag to prevent
this situation.
Change-Id: I4a8b3ebfd07b3e4901ad807c8052c38e3f23315e
Signed-off-by: Xiaohui Tao <xtao@nvidia.com>
Reviewed-on: http://git-master/r/239385
Reviewed-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-by: Robert Collins <rcollins@nvidia.com>
Change DEF_ACCEL_ST_SHIFT_DELTA and DEF_GYRO_CT_SHIFT_DELTA to
500.
Change-Id: Id4db11789d561dfc3899d8de592421f04dbf19db
Reviewed-on: http://git-master/r/239833
This is a WAR to reset the USB device if the device
fails to resume. We assume that the resume failure is
because of the uC hang.
Change-Id: I6fc85cd0ce2fad7a7dbff5b6ddee0a96149a5d76
Reviewed-on: http://git-master/r/239086
Reviewed-by: Tao Xie <txie@nvidia.com>
Tested-by: Tao Xie <txie@nvidia.com>
Reviewed-by: Ankit Pashiney <apashiney@nvidia.com>
Use mutexes to prevent concurrent wifi / bluetooth turn
on sequence.
Bug 1302412
Change-Id: Icd086b616af2f5ccbff7968d613310c365ad549a
Reviewed-on: http://git-master/r/236533
Change-Id: I2158918b6a22a4ceeadecdfa5a51fc87a624a105
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/235510
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
On P2560 hardware only, wifi chip generates excessive wifi
activity interrupts:
- on first boot after flashing image
WAR is to mask this specific wifi activity interrupt to
prevent it from keeping application processor awake.
Bug 1299635
Change-Id: Idf0fdaf817621e3ae5e0f63864c488366dbbcaba
Reviewed-on: http://git-master/r/235330
Reviewed-by: Matt Wagner <mwagner@nvidia.com>
Change-Id: Ib87ff58487c324124987a563fc0621d8f8482784
Reviewed-on: http://git-master/r/234417
disable OTG mode when over temprature and over current
interrupt occurs and re-enable OTG mode after 30sec.
Bug 1285652
Change-Id: Ic7ee97a3b14cea03462d16b24f8de670e0e76904
Signed-off-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Reviewed-on: http://git-master/r/226994
(cherry picked from commit 4e8d08beb0a8659862018eda355c845167adac9d)
Reviewed-on: http://git-master/r/231751
Tested-by: Matt Wagner <mwagner@nvidia.com>
Problem description:
- nct1008_suspend powers off nct1008
- nct1008_suspend does stop the workqueue and irq, but
if there is a kernel thread which would trigger
nct1008_read_reg or nct1008_write_reg, nct1008 would
still be accessed after it is powered off
Fix description:
- Rename the existing flag shutdown_complete to nct_disabled
- Update the value of nct_disabled when powering nct1008 on and off
Bug 1288427
Change-Id: Id885794eb39a71025ad9f5c3615156c19039d13f
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/228011
(cherry picked from commit 08eed1ddbacece2f1c8b4fba633c01c0f87ba2cd)
Reviewed-on: http://git-master/r/232275
Problem descritpion:
- Even after powering off the device through inv_set_power_state,
inv_read_fifo can be running in paralell, still talking to the
device
Fix description:
- When powering off the device, also disable the irq to avoid
talking to a powered off device
- As a side effect, this change will also ensure interrupts from gyro
do not result in a lock up of i2c bus during suspend even in case
of an interrupt storm
Bug 1285239
Change-Id: I42dfa094b645944e22d600b64abc18b10b7fb38b
Reviewed-on: http://git-master/r/227781
(cherry picked from commit a2ce58ee6da12bbe3f9d18dfcef1e6a48a4572a9)
Reviewed-on: http://git-master/r/232274
1. CTS failure
2. Suspend/Resume time
Bug 1283362
Change-Id: I5cbd85bbab26f029dd7400cd17c9bb1358fc2ef8
Reviewed-on: http://git-master/r/231660
(cherry picked from commit 10c3573c922e79d81be2d2e0812b1945d4fab0f4)
Reviewed-on: http://git-master/r/232253
Update speaker model, EQ, and configs for
the NXP tfa8997 device.
Change-Id: Iabed2761aa6156eaac1ca3753d8c58599f885726
Signed-off-by: Scott Peterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/231741
Don't wait for communication to stop if HDMI isn't plugged
Bug 1275577
Change-Id: Ifb56bc8a4b36ac2cb40614811398920b7e293e04
Reviewed-on: http://git-master/r/231350
(cherry picked from commit fc774f94ffa54b1a6ce1771ac82b82c3a1eea39f)
Reviewed-on: http://git-master/r/231692
- Fixed Miracast discovery issue after P2P disconnection.
- Fixed P2P action frame issue when multiple P2P IEs are in the probe response.
- BW allocation for VSDB
- Support offset for RSSI report
Bug 1282745
Change-Id: Ie55a05c51e95941e09e5c582c4936909f490575e
Signed-off-by: bibhayr <bibhayr@nvidia.com>
Reviewed-on: http://git-master/r/#change,228838
(cherry picked from commit 6147573414026a4ff978885f38e4842de55fb4fe)
Reviewed-on: http://git-master/r/230104
Reviewed-by: Narayan Reddy <narayanr@nvidia.com>
Tested-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Code drop from raydium
1. RESET signal correction during suspend/resume
2. The LP0 touch not work issue fix
3. The old functionality such as environment variable and calibration should remain the same.
Change-Id: Ibb71c2ddb4a7b6760baa991a737fa6c3580b893a
(cherry picked from commit 7df8f34a4b4a26305afac8aff42eeaa528655d33)
Reviewed-on: http://git-master/r/230050
If "caps2" host capabilities does not indicate support for MMC
HS200, don't allow clock speeds >52MHz. Currently, for MMC, the
clock speed is set to the lesser of the max speed the eMMC module
supports (card->ext_csd.hs_max_dtr) or the max base clock of the
host controller (host->f_max based on BASE_CLK_FREQ in the host
CAPS register). This means that a host controller that doesn't
support HS200 mode but has a base clock of 100MHz and an eMMC module
that supports HS200 speeds will end up using a 100MHz clock.
Change-Id: I2967fcc733b7178bdf54d6f75f65bdff253fc1cc
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Signed-off-by: Al Cooper <alcooperx@gmail.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Reviewed-on: http://git-master/r/227758
(cherry picked from commit ed5cc4ef1e8bcdae292b6f234dbb7054cf5542cb)
Reviewed-on: http://git-master/r/230047
Current implementation decides the card type exclusively. Even though
eMMC device can support both HS200 and DDR mode, card type will be
set only for HS200. If the host doesn't support HS200 but has DDR
capability, then DDR mode can't be selected.
Change-Id: Id2b9095f8ffe59c520850acd40681a9ef15c3ff9
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
Reviewed-on: http://git-master/r/227757
(cherry picked from commit 084aa8cc074b0e95883934f82f5521d0cc5e0941)
Reviewed-on: http://git-master/r/230046
Clear dhd driver hang event upon device close, so that next open
will not be blocked.
Prevents condition where wifi cannot be turned off / on because
of a previous hang event flag being set.
Bug 1280309
Change-Id: I6569cd39c8866682c7a19fa840b32162c2a4dd5b
Reviewed-on: http://git-master/r/229999
Updated the auto calibration values.
Fixed call to register access function.
Bug 1166307
Bug 1283871
Change-Id: I39976bd3cbdcc09df682589c418b06281d7eec97
Signed-off-by: Vineel Kumar Reddy Kovvuri <vineelkumarr@nvidia.com>
Reviewed-on: http://git-master/r/229915
Implementation of DSI MIPI auto calibration
Bug 1166307
Change-Id: Id4be420978b56d662d77c6d145f9e51dc881d159
Reviewed-on: http://git-master/r/229914
Update charger type up on connection.
Bug 1281945
Change-Id: Iea2bf0323636ae54e2e911705fd795c273de50f7
Signed-off-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-on: http://git-master/r/225208
Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com>
tegra_dc_hpd(), which uses gpio_get_value_cansleep(),
is called from tegra_dc_hdmi_irq() in atomic context.
Move this call outside of the atomic context to avoid
potential lockup.
Change-Id: If62a3d257ab29eae34fd0999e6d182906a568846
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/226531
(cherry picked from commit e0a5c3a078138b9db103aa428a6667efb3e3a1d0)
Reviewed-on: http://git-master/r/228493
Wait for hdmi accesses to finish before turning nvhdcp off.
Bug 1275577.
Change-Id: Ieef8635b66cfdddece7b2e1140b776b91350d272
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/227243
(cherry picked from commit ac6205a26fbf52d8439524543321012ed95c9d78)
Reviewed-on: http://git-master/r/228104
Low Power Accelerometer is disabled due to known HW bug.
Bug 1279237
Change-Id: I8477fb84bbca7f8d139f5495ab7f584df528f44d
Reviewed-on: http://git-master/r/224897
(cherry picked from commit e0a3ba3b906cda0c54242c37e1fb5e03af5ba562)
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/227973
This reverts commit 1c48c746ea721f95c594c08f5f1320ba78de40e4.
Bug 1281367
Change-Id: I78ad0f9886d4834b2a19542331bfd2b2e0f823af
Reviewed-on: http://git-master/r/227044
Reviewed-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Change-Id: I9df90c7774a30f5e512d492b3dce85d3f689cfff
Signed-off-by: Narayan Reddy <narayanr@nvidia.com>
Reviewed-on: http://git-master/r/222776
Reviewed-by: Harshada Kale <hkale@nvidia.com>
Tested-by: Harshada Kale <hkale@nvidia.com>
Remove warning about creation of debugfs
nodes for the NXP tfa9887 devices.
Bug 1284011
Change-Id: Iaf67b5e0e50a803d2d934370165c7887809f0685
Reviewed-on: http://git-master/r/226353
Reviewed-by: Vinod Subbarayalu <vsubbarayalu@nvidia.com>
This change is needed since we are moving to the new firmware
version which has disconnect and RSSI issue fix
Bug 1264805
This reverts commit c635cc0776dd095c805d22c882a4d92eb82454c8.
Change-Id: I54263803e75329f610541880d5a01eb047359def
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/222741
Tested-by: Rakesh Kumar <krakesh@nvidia.com>
Adding WAR to have 3 retries for SDIO RW CMD52.
Bug 1281367
Change-Id: I1167126d46021f6725f5fe91ebdf8e9d85a106e6
Reviewed-on: http://git-master/r/224935
Reviewed-by: R Raj Kumar <rrajk@nvidia.com>
Reduce speakers pops when enabling/disabling
the NXP speaker protection device. Add an alsa
mixer control to mute the device from the audio
HAL prior to disabling the device.
Bug 1268519
Change-Id: I2d16c0443bd833b65d07ec2fabc36102443cc8ad
Reviewed-on: http://git-master/r/224002
- nct1008_shutdown and nct1008_suspend disable nct1008_irq
- If nct1008_irq triggers during shutdown or suspend, the irq handler will
schedule nct1008_work_func, which will re-enable nct1008_irq
- This work could trigger after disabling the power rail as well, causing
an access of nct1008 after disabling its power rail
Fix description:
- Add a new flag stop_workqueue
- While the flag is set, nct1008_work_func will return without doing anything
- After setting the flag to effectively disable nct1008_work_func, wait for
running nct1008_work_func to complete then disable nct1008_irq
Bug 1280843
Change-Id: I69176ad466f4c49e62932425fdf7a8583b2cf8bf
Reviewed-on: http://git-master/r/223906
Reviewed-by: Gaurav Batra <gbatra@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
If minimum override voltage tuning is not done or if the nominal core
voltage details are not specified, find full window using tuning and
set the best tap value as 50% of the full window.
Printing tuning window and tap value details.
Bug 1280293
Change-Id: I5d77f5b03e0543cb33ac97420a92ca08cb4f21a8
Reviewed-on: http://git-master/r/224224
Raydium code drop for v55.3 driver
(1) Does not let the suspend/resume fail if there is no internal clock
It will allow external clock to pass suspend/resume.
(2) Turn touch off when display off
Bug 1280093
Change-Id: Ie1e46727531cad3314ae39c0e9a90b275880ea57
Reviewed-on: http://git-master/r/223624
Code drop from raydium to update kernel to v55.2
Change-Id: I3562e487cdbf55b45428139f093aa245cd8e0b90
Reviewed-on: http://git-master/r/223425
Release the spinlock before calling the dvfs override API
to set/unset tuning override voltages.
Bug 1259286
Change-Id: Ib247ca3e6f7d7e86c52c8f762b4331adddb95dfe
Reviewed-on: http://git-master/r/222944
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
Additional adjustments to the curves used
on the NXP tfa9887 device.
Change-Id: I5b311d6c499c36f440c865f4fa8b909588b689be
Reviewed-on: http://git-master/r/223498
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Tested-by: Rajat Aggarwal <raggarwal@nvidia.com>
Bug 1267612
Change-Id: Ibaaa09491776e45b85f8850b3c2c1faa4ca3375a
Signed-off-by: Jean Huang <jeanh@nvidia.com>
Reviewed-on: http://git-master/r/222626
Reviewed-by: Simone Willett <swillett@nvidia.com>
This change adds support for the firmware to be
force updated. This flag can be used to downgrade the
firmware.
Bug 1270341
Change-Id: I2c7eee9029cce38fdb902b211fb2800071579ff9
Reviewed-on: http://git-master/r/222598
Reviewed-by: Richard Zhao <rizhao@nvidia.com>
Original design was to restore fan to the state before suspend,
but fan-thermal detection should work itself to decide fan state after resume.
Bug 1273984
Change-Id: Ieac7688ed2ccf3dca3427c61e3d51a209cda79a3
Reviewed-on: http://git-master/r/222157
tegra_dc_hpd(), which uses gpio_get_value_cansleep(), is called from
tegra_dc_hdmi_resume() in atomic context. Move this call outside of the
atomic context to avoid potential lockup.
Change-Id: I983e58724727803c67a4145e11630746aff86a52
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-on: http://git-master/r/216593
sdhci_tegra_sd_error_stats can be called from sdhci_irq. Move memory
allocation to the probe() function so we don't perform it in interrupt
context.
Change-Id: Ic4278526f72ebeb11d59bfe8a7d3e112172035a8
Reviewed-on: http://git-master/r/216591
Enable QUEUE_BW to support Realtime Bandwidth
estimation for user applications.
Bug 1190552
Change-Id: I8af0befffb34da0bbd22d3a36ec0df377d1f3c50
Reviewed-on: http://git-master/r/217323
Raydium does not support external clock and the regulator functions
are not balanced. Modify the code to support that.
Change-Id: I59c1d6018c666d87a697c19c29b9ab78484cf7dc
Reviewed-on: http://git-master/r/222163
Change-Id: I882038b2dee419daf7c402a9c03aad06a0a25807
Reviewed-on: http://git-master/r/216315
Reviewed-by: Chaitanya Bandi <bandik@nvidia.com>
Tested-by: Jun Yan <juyan@nvidia.com>
Increase DCP current limit to 2A.
Bug 1274950
Change-Id: Ic5f24f1c400f965f2989a54b0cc941dedae081fd
Reviewed-on: http://git-master/r/220803
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Set tuning override voltages using dvfs APIs rather than regulators.
During boot, if the minimum override voltage cannot be set, schedule
for retuning.
Bug 1246712
Change-Id: I91acd10b748a9d828b172420999f3cceda26d218
Reviewed-on: http://git-master/r/221394
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Raydium code drop to use partition for storing calibration data.
Correct delay of touch after resume.
Bug 1257642
Bug 1245549
Bug 1245404
Change-Id: Idb3677e7c369b577bd89fbba039c2c6ffff88bf4
Signed-off-by: David Jung <djung@nvidia.com>
Signed-off-by: Robert Collins <rcollins@nvidia.com>
Reviewed-on: http://git-master/r/218646
Reviewed-by: Xiaohui Tao <xtao@nvidia.com>
Tested-by: Xiaohui Tao <xtao@nvidia.com>
