path: root/drivers
2013-05-11qmi_wwan/cdc_ether: add device IDs for Dell 5804 (Novatel E371) WWAN cardDan Williams
commit 7fdb7846c9ca6fc06e380de0976a1228703b498a upstream. A rebranded Novatel E371 for AT&T's LTE bands. qmi_wwan should drive this device, while cdc_ether should ignore it. Even though the USB descriptors are plain CDC-ETHER that USB interface is a QMI interface. Signed-off-by: Dan Williams <dcbw@redhat.com> Acked-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11PCI: Delay final fixups until resources are assignedYinghai Lu
commit e253aaf0af51c1e4dc7dd3b26ea8e666bf9a2d8d upstream. Commit 4f535093cf "PCI: Put pci_dev in device tree as early as possible" moved final fixups from pci_bus_add_device() to pci_device_add(). But pci_device_add() happens before resource assignment, so BARs may not be valid yet. Typical flow for hot-add: pciehp_configure_device pci_scan_slot pci_scan_single_device pci_device_add pci_fixup_device(pci_fixup_final, dev) # previous location # resource assignment happens here pci_bus_add_devices pci_bus_add_device pci_fixup_device(pci_fixup_final, dev) # new location [bhelgaas: changelog, move fixups to pci_bus_add_device()] Reference: https://lkml.kernel.org/r/20130415182614.GB9224@xanatos Reported-by: David Bulkow <David.Bulkow@stratus.com> Tested-by: David Bulkow <David.Bulkow@stratus.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11EDAC: Don't give write permission to read-only filesSrivatsa S. Bhat
commit c8c64d165ccfd2274058ac84e0c680f9b48c4ec1 upstream. I get the following warning on boot: ------------[ cut here ]------------ WARNING: at drivers/base/core.c:575 device_create_file+0x9a/0xa0() Hardware name: -[8737R2A]- Write permission without 'store' ... </snip> Drilling down, this is related to dynamic channel ce_count attribute files sporting a S_IWUSR mode without a ->store() function. Looking around, it appears that they aren't supposed to have a ->store() function. So remove the bogus write permission to get rid of the warning. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> [ shorten commit message ] Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/tilcdc: Fix an incorrect conditionSachin Kamat
commit 9e48854c58ca9a0f39e716dcb18247bfc21e2022 upstream. Instead of checking if num_encoders is zero, it is being assigned 0. Convert the assignment to a check. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix handling of v6 power tablesAlex Deucher
commit 441e76ca83ac604eaf0f046def96d8e3a27eea28 upstream. The code was mis-handling variable sized arrays. Reported-by: Sylvain BERTRAND <sylware@legeek.net> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: add new richland pci idsAlex Deucher
commit 62d1f92e06aef9665d71ca7e986b3047ecf0b3c7 upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix possible segfault when parsing pm tablesAlex Deucher
commit f8e6bfc2ce162855fa4f9822a45659f4b542c960 upstream. If we have a empty power table, bail early and allocate the default power state. Should fix: https://bugs.freedesktop.org/show_bug.cgi?id=63865 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix endian bugs in atom_allocate_fb_scratch()Alex Deucher
commit beb71fc61c2cad64e347f164991b8ef476529e64 upstream. Reviwed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: disable the crtcs in mc_stop (r5xx-r7xx) (v2)Alex Deucher
commit e884fc640ccbdb6f94b9bdb57cfb8464b6688f4c upstream. Just disabling the mem requests should be enough, but that doesn't seem to work correctly on efi systems. v2: blank displays first, then disable. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: Always flush the VMJerome Glisse
commit 466476dfdcafbb4286ffa232a3a792731b9dc852 upstream. This is slightly cleaned up version of Jerome's patch. There seems to be an issue tracking the last flush of the VM which results in hangs in certain cases when VM is used. For now just flush the VM for every IB. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=62959 https://bugs.freedesktop.org/show_bug.cgi?id=62997 Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix typo in si_select_se_sh()Alex Deucher
commit 79b52d6a7085a3e430c6de450a5847fdbe04159b upstream. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix hdmi mode enable on RS600/RS690/RS740Alex Deucher
commit dcb852905772416e322536ced5cb3c796d176af5 upstream. These chips were previously skipped since they are pre-R600. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: cleanup properly if mmio mapping failsAlex Deucher
commit 0cd9cb76ae26a19df21abc6f94f5fff141e689c7 upstream. If we fail to map the mmio BAR, skip driver tear down that requires mmio. Should fix: https://bugzilla.kernel.org/show_bug.cgi?id=56541 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon/evergreen+: don't enable HPD interrupts on eDP/LVDSAlex Deucher
commit 2e97be73e5f74a317232740ae82eb8f95326a660 upstream. Avoids potential interrupt storms when the display is disabled. May fix: https://bugzilla.kernel.org/show_bug.cgi?id=56041 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: disable the crtcs in mc_stop (evergreen+) (v2)Alex Deucher
commit abf1457bbbe4c62066bd03c6d31837dea28644dc upstream. Just disabling the mem requests should be enough, but that doesn't seem to work correctly on efi systems. May fix: https://bugs.freedesktop.org/show_bug.cgi?id=57567 https://bugs.freedesktop.org/show_bug.cgi?id=43655 https://bugzilla.kernel.org/show_bug.cgi?id=56441 v2: blank displays first, then disable. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: update wait_for_vblank for r1xx-r4xxAlex Deucher
commit 2b48b968c0d00aa5ab520b65a15a4f374cda7dda upstream. Properly wait for the next vblank region. The previous code didn't always wait long enough depending on the timing. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: properly lock disp in mc_stop/resume for r5xx-r7xxAlex Deucher
commit 2f86e2ede39a98650c2d465857405ef1c51372b1 upstream. Need to wait for the new addresses to take affect before re-enabling the MC. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: properly lock disp in mc_stop/resume for evergreen+Alex Deucher
commit 968c01664ccbe0e46c19a1af662c4c266a904203 upstream. Need to wait for the new addresses to take affect before re-enabling the MC. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: update wait_for_vblank for evergreen+Alex Deucher
commit 10257a6d8359c41407eb26b7ad7bf710a7e00155 upstream. Properly wait for the next vblank region. The previous code didn't always wait long enough depending on the timing. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: update wait_for_vblank for r5xx-r7xxAlex Deucher
commit bea5497bfc1067620c8c8e9d37a42e0bb6d7d7fa upstream. Properly wait for the next vblank region. The previous code didn't always wait long enough depending on the timing. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon/dce6: add missing display reg for tiling setupAlex Deucher
commit 7c1c7c18fc752b2a1d07597286467ef186312463 upstream. A new tiling config register for the display blocks was added on DCE6. May fix: https://bugs.freedesktop.org/show_bug.cgi?id=62889 https://bugs.freedesktop.org/show_bug.cgi?id=57919 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: fix typo in rv515_mc_resume()Alex Deucher
commit 367cbe2fec9b57b72605e2ac4cfd4f2fa823a256 upstream. Doesn't affect anything as the same address gets written in both cases. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: use frac fb div on RS780/RS880Alex Deucher
commit 411678288d61ba17afe1f8afed92200be6bbc65d upstream. Monitors seem to prefer it. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=37696 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/radeon: don't use get_engine_clock() on APUsAlex Deucher
commit bf05d9985111f85ed6922c134567b96eb789283b upstream. It doesn't work reliably. Just report back the currently selected engine clock. Partially fixes: https://bugs.freedesktop.org/show_bug.cgi?id=62493 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: correct the calculation of first_pd_entry_in_global_ptZhang, Xiong Y
commit 43b27290dd42b40f3f23f49677a7faa5a4eb1eff upstream. When ppgtt is enabled, dev_priv->gtt.total has excluded the gtt space occupied by ppgtt table in i915_gem_init_global_gtt() function. So the calculation of first_pd_entry_in_global_pt doesn't need to subtract I915_PPGTT_PD_ENTRIES again. Or else PPGTT directory table will be destroyed by global gtt allocation. This regression has been introduced in commit a54c0c279f3864171fe53c66e769d5a137c5c651 Author: Ben Widawsky <ben@bwidawsk.net> Date: Thu Jan 24 14:45:00 2013 -0800 drm/i915: remove intel_gtt structure The breakage is pretty subtile since the old gtt_total_entries included the pde range, whereas the new on did not. Signed-off-by: Xiong Zhang<xiong.y.zhang@intel.com> [danvet: Add regression citation and cc: stable. Thanks to Chris for correcting my wrong guess about which commit broke things.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Fall back to bit banging mode for DVO transmitter detectionDavid Müller
commit e4bfff54ed3f5de88f5358504c78c2cb037813aa upstream. As discussed in this thread http://lists.freedesktop.org/archives/dri-devel/2013-April/037411.html GMBUS based DVO transmitter detection seems to be unreliable which could result in an unusable DVO port. The attached patch fixes this by falling back to bit banging mode for the time DVO transmitter detection is in progress. Signed-off-by: David Müller <d.mueller@elsoft.ch> Tested-by: David Müller <d.mueller@elsoft.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Fixup Oops in the pipe config computationDaniel Vetter
commit b6c5164d7bf624f3e1b750787ddb983150c5117c upstream. Yet again our current confusion between doing the modeset globally, but only having the new parameters for one crtc at a time. So that intel_set_mode essentially already does a global modeset: intel_modeset_affected_pipes compares the current state with where we want to go to (which is carefully set up by intel_crtc_set_config) and then goes through the modeset sequence for any crtc which needs updating. Now the issue is that the actual interface with the remaining code still only works on one crtc, and so we only pass in one fb and one mode. In intel_set_mode we also only compute one intel_crtc_config (which should be the one for the crtc we're doing a modeset on). The reason for that mismatch is twofold: - We want to eventually do all modeset as global state changes, so it's just infrastructure prep. - But even the old semantics can change more than one crtc when you e.g. move a connector from crtc A to crtc B, then both crtc A and B need to be updated. Usually that means one pipe is disabled and the other enabled. This is also the reason why the hack doesn't touch the disable_pipes mask. Now hilarity ensued in our kms config restore paths when we actually try to do a modeset on all crtcs: If the first crtc should be off and the second should be on, then the call on the first crtc will notice that the 2nd one should be switched on and so tries to compute the pipe_config. But due to a lack of passed-in fb (crtc 1 should be off after all) it only results in tears. This case is ridiculously easy to hit on gen2/3 where the lvds output is restricted to pipe B. Note that before the pipe_config bpp rework gen2/3 didn't care really about the fb->depth, so this is a regression brought to light with commit 4e53c2e010e531b4a014692199e978482d471c7e Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Wed Mar 27 00:44:58 2013 +0100 drm/i915: precompute pipe bpp before touching the hw But apparently Ajax also managed to blow up pch platforms, probably with some randomized configs, and pch platforms trip up over the lack of an fb even in the old code. So this actually goes back to the first introduction of the new modeset restore code in commit 45e2b5f640b3766da3eda48f6c35f088155c06f3 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Fri Nov 23 18:16:34 2012 +0100 drm/i915: force restore on lid open Fix this mess by now by justing shunting all the cool new global modeset logic in intel_modeset_affected_pipes. v2: Improve commit message and clean up all the comments in intel_modeset_affected_pipes - since the introduction of the modeset restore code they've been a bit outdated. Bugzill: https://bugzilla.redhat.com/show_bug.cgi?id=917725 References: http://www.mail-archive.com/stable@vger.kernel.org/msg38084.html Tested-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: don't intel_crt_init on any ULT machinesPaulo Zanoni
commit c40c0f5bd5b0f09e4386d2cf26c96c89c45ee539 upstream. We may have DDI_BUF_CTL(PORT_A) configured with 2 lanes and still not have CRT, so just check for !IS_ULT. This problem happened on a real machine and resulted in a very ugly dmesg. Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: ensure single initialization and cleanup of backlight deviceJani Nikula
commit dc652f90e088798bfa31f496ba994ddadd5d5680 upstream. Backlight cleanup in the eDP connector destroy callback caused the backlight device to be removed on some systems that first initialized LVDS and then attempted to initialize eDP. Prevent multiple backlight initializations, and ensure backlight cleanup is only done once by moving it to modeset cleanup. A small wrinkle is the introduced asymmetry in backlight setup/cleanup. This could be solved by adding refcounting, but it seems overkill considering that there should only ever be one backlight device. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=55701 Signed-off-by: Jani Nikula <jani.nikula@intel.com> Tested-by: Peter Verthez <peter.verthez@skynet.be> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: don't check inconsistent modeset state when force-restoringDaniel Vetter
commit f30da187cdcd0939288038e11fb3bfbd1b655564 upstream. It will be only consistent once we've restored all the crtcs. Since a bunch of other callers also want to just restore a single crtc, add a boolean to disable checking only where it doesn't make sense. Note that intel_modeset_setup_hw_state already has a call to intel_modeset_check_state at the end, so we don't reduce the amount of checking. v2: Try harder not to create a big patch (Chris). v3: Even smaller (still Chris). Also fix a trailing space. Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> References: https://lkml.org/lkml/2013/3/16/60 Cc: Tomas Melin <tomas.melin@iki.fi> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Tomas Melin <tomas.melin@iki.fi> Tested-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: set CPT FDI RX polarity bits based on VBTPaulo Zanoni
commit 3f704fa2778d3fe45e6529825a5c7a8bcbc686f4 upstream. Check the VBT to see if the machine has inverted FDI RX polarity on CPT. Based on this bit, set the appropriate bit on the TRANS_CHICKEN2 registers. This should fix some machines that were showing black screens on all outputs. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=60029 Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Use MLC (l3$) for context objectsChris Wilson
commit 4615d4c9e27eda42c3e965f208a4b4065841498c upstream. Enabling context support increases SwapBuffers latency by about 20% (measured on an i7-3720qm). We can offset that loss slightly by enabling faster caching for the contexts. As they are not backed by any particular cache (such as the sampler or render caches) our only option is to select the generic mid-level cache. This reduces the latency of the swap by about 5%. Oddly this effect can be observed running smokin-guns on IVB at 1280x1024: Using BLT copies for swaps: 151.67 fps Using Render copies for swaps (unpatched): 141.70 fps With contexts disabled: 150.23 fps With contexts in L3$: 150.77 fps Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Ben Widawsky <ben@bwidawsk.net> Cc: Kenneth Graunke <kenneth@whitecape.org> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Workaround incoherence between fences and LLC across multiple CPUsChris Wilson
commit 25ff1195f8a0b3724541ae7bbe331b4296de9c06 upstream. In order to fully serialize access to the fenced region and the update to the fence register we need to take extreme measures on SNB+, and manually flush writes to memory prior to writing the fence register in conjunction with the memory barriers placed around the register write. Fixes i-g-t/gem_fence_thrash v2: Bring a bigger gun v3: Switch the bigger gun for heavier bullets (Arjan van de Ven) v4: Remove changes for working generations. v5: Reduce to a per-cpu wbinvd() call prior to updating the fences. v6: Rewrite comments to ellide forgotten history. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=62191 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Jon Bloomfield <jon.bloomfield@intel.com> Tested-by: Jon Bloomfield <jon.bloomfield@intel.com> (v2) Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Fix SDVO connector and encoder get_hw_state functionsEgbert Eich
commit 7a7d1fb79fb581553f4830498045de774a9659f8 upstream. The connector associated with the encoder is considered active when the output associtated with this connector is active on the encoder. The encoder itself is considered active when either there is an active output on it or the respective SDVO channel is active. Having active outputs when the SDVO channel is inactive seems to be inconsistent: such states can be found when intel_modeset_setup_hw_state() collects the hardware state set by the BIOS. This inconsistency will be fixed in intel_sanitize_crtc() (when intel_crtc_update_dpms() is called), this however only happens when the encoder is associated with a crtc. This patch also reverts: commit bd6946e87a98fea11907b2a47368e13044458a35 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Tue Apr 2 21:30:34 2013 +0200 drm/i915: Fix sdvo connector get_hw_state function Signed-off-by: Egbert Eich <eich@suse.de> Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=63031 Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Add no-lvds quirk for Fujitsu Esprimo Q900Christian Lamparter
commit 9e9dd0e889c76c786e8f2e164c825c3c06dea30c upstream. The "Mobile Sandy Bridge CPUs" in the Fujitsu Esprimo Q900 mini desktop PCs are probably misleading the LVDS detection code in intel_lvds_supported. Nothing is connected to the LVDS ports in these systems. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/i915: Fix sdvo connector get_hw_state functionDaniel Vetter
commit bd6946e87a98fea11907b2a47368e13044458a35 upstream. The active output is only the currently selected one, which does not imply that it's actually enabled. Since we don't use the sdvo encoder side dpms support, we need to check whether the chip-side sdvo port is enabled instead. v2: Fix up Bugzilla links. v3: Simplify logic a bit (Chris). Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=60138 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=63031 Cc: Egbert Eich <eich@pdx.freedesktop.org> Cc: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Egbert Eich <eich@pdx.freedesktop.org> (v2) Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/ast: deal with bo reserve fail in dirty update pathDave Airlie
commit 306373b645d80625335b8e684fa09b14ba460cec upstream. Port over the mgag200 fix to ast as it suffers the same issue. On F19 testing, it was noticed we get a lot of errors in dmesg about being unable to reserve the buffer when plymouth starts, this is due to the buffer being in the process of migrating, so it makes sense we can't reserve it. In order to deal with it, this adds delayed updates for the dirty updates, when the bo is unreservable, in the normal console case this shouldn't ever happen, its just when plymouth or X is pushing the console bo to system memory. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/prime: keep a reference from the handle to exported dma-buf (v6)Dave Airlie
commit 219b47339ced80ca580bb6ce7d1636166984afa7 upstream. Currently we have a problem with this: 1. i915: create gem object 2. i915: export gem object to prime 3. radeon: import gem object 4. close prime fd 5. radeon: unref object 6. i915: unref object i915 has an imported object reference in its file priv, that isn't cleaned up properly until fd close. The reference gets added at step 2, but at step 6 we don't have enough info to clean it up. The solution is to take a reference on the dma-buf when we export it, and drop the reference when the gem handle goes away. So when we export a dma_buf from a gem object, we keep track of it with the handle, we take a reference to the dma_buf. When we close the handle (i.e. userspace is finished with the buffer), we drop the reference to the dma_buf, and it gets collected. This patch isn't meant to fix any other problem or bikesheds, and it doesn't fix any races with other scenarios. v1.1: move export symbol line back up. v2: okay I had to do a bit more, as the first patch showed a leak on one of my tests, that I found using the dma-buf debugfs support, the problem case is exporting a buffer twice with the same handle, we'd add another export handle for it unnecessarily, however we now fail if we try to export the same object with a different gem handle, however I'm not sure if that is a case I want to support, and I've gotten the code to WARN_ON if we hit something like that. v2.1: rebase this patch, write better commit msg. v3: cleanup error handling, track import vs export in linked list, these two patches were separate previously, but seem to work better like this. v4: danvet is correct, this code is no longer useful, since the buffer better exist, so remove it. v5: always take a reference to the dma buf object, import or export. (Imre Deak contributed this originally) v6: square the circle, remove import vs export tracking now that there is no difference Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm: prime: fix refcounting on the dmabuf import error pathImre Deak
commit 011c2282c74db120f01a8414edc66c3f217f5511 upstream. In commit be8a42ae60 we inroduced a refcount problem, where on the drm_gem_prime_fd_to_handle() error path we'll call dma_buf_put() for self imported dma buffers. Fix this by taking a reference on the dma buffer in the .gem_import hook instead of assuming the caller had taken one. Besides fixing the bug this is also more logical. Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/gma500: fix backlight hotkeys behaviour on netbooksAnisse Astier
commit e127dc28cc3057575da0216cde85687153ca180f upstream. Backlight hotkeys weren't working before on certain cedartrail laptops. The source of this problem is that the hotkeys' ASLE opregion interrupts were simply ignored. Driver seemed to expect the interrupt to be associated with a pipe, but it wasn't. Accepting the ASLE interrupt without an associated pipe event flag fixes the issue, the backlight code is called when needed, making the brightness keys work properly. [patrik: This patch affects irq handling on any netbook with opregion support] Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=833597 Reference: http://lists.freedesktop.org/archives/dri-devel/2012-July/025279.html Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/mgag200: deal with bo reserve fail in dirty update pathDave Airlie
commit 641719599528d806e00de8ae8c8453361266a312 upstream. On F19 testing, it was noticed we get a lot of errors in dmesg about being unable to reserve the buffer when plymouth starts, this is due to the buffer being in the process of migrating, so it makes sense we can't reserve it. In order to deal with it, this adds delayed updates for the dirty updates, when the bo is unreservable, in the normal console case this shouldn't ever happen, its just when plymouth or X is pushing the console bo to system memory. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11drm/cirrus: deal with bo reserve fail in dirty update pathDave Airlie
commit f3b2bbdc8a87a080ccd23d27fca4b87d61340dd4 upstream. Port over the mgag200 fix to cirrus as it suffers the same issue. On F19 testing, it was noticed we get a lot of errors in dmesg about being unable to reserve the buffer when plymouth starts, this is due to the buffer being in the process of migrating, so it makes sense we can't reserve it. In order to deal with it, this adds delayed updates for the dirty updates, when the bo is unreservable, in the normal console case this shouldn't ever happen, its just when plymouth or X is pushing the console bo to system memory. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11RDMA/cxgb4: Fix SQ allocation when on-chip SQ is disabledThadeu Lima de Souza Cascardo
commit 5b0c275926b8149c555da874bb4ec258ea3292aa upstream. Commit c079c28714e4 ("RDMA/cxgb4: Fix error handling in create_qp()") broke SQ allocation. Instead of falling back to host allocation when on-chip allocation fails, it tries to allocate both. And when it does, and we try to free the address from the genpool using the host address, we hit a BUG and the system crashes as below. We create a new function that has the previous behavior and properly propagate the error, as intended. kernel BUG at /usr/src/packages/BUILD/kernel-ppc64-3.0.68/linux-3.0/lib/genalloc.c:340! Oops: Exception in kernel mode, sig: 5 [#1] SMP NR_CPUS=1024 NUMA pSeries Modules linked in: rdma_ucm rdma_cm ib_addr ib_cm iw_cm ib_sa ib_mad ib_uverbs iw_cxgb4 ib_core ip6t_LOG xt_tcpudp xt_pkttype ipt_LOG xt_limit ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_raw xt_NOTRACK ipt_REJECT xt_state iptable_raw iptable_filter ip6table_mangle nf_conntrack_netbios_ns nf_conntrack_broadcast nf_conntrack_ipv4 nf_conntrack nf_defrag_ipv4 ip_tables ip6table_filter ip6_tables x_tables fuse loop dm_mod ipv6 ipv6_lib sr_mod cdrom ibmveth(X) cxgb4 sg ext3 jbd mbcache sd_mod crc_t10dif scsi_dh_emc scsi_dh_hp_sw scsi_dh_alua scsi_dh_rdac scsi_dh ibmvscsic(X) scsi_transport_srp scsi_tgt scsi_mod Supported: Yes NIP: c00000000037d41c LR: d000000003913824 CTR: c00000000037d3b0 REGS: c0000001f350ae50 TRAP: 0700 Tainted: G X (3.0.68-0.9-ppc64) MSR: 8000000000029032 <EE,ME,CE,IR,DR> CR: 24042482 XER: 00000001 TASK = c0000001f6f2a840[3616] 'rping' THREAD: c0000001f3508000 CPU: 0 GPR00: c0000001f6e875c8 c0000001f350b0d0 c000000000fc9690 c0000001f6e875c0 GPR04: 00000000000c0000 0000000000010000 0000000000000000 c0000000009d482a GPR08: 000000006a170000 0000000000100000 c0000001f350b140 c0000001f6e875c8 GPR12: d000000003915dd0 c000000003f40000 000000003e3ecfa8 c0000001f350bea0 GPR16: c0000001f350bcd0 00000000003c0000 0000000000040100 c0000001f6e74a80 GPR20: d00000000399a898 c0000001f6e74ac8 c0000001fad91600 c0000001f6e74ab0 GPR24: c0000001f7d23f80 0000000000000000 0000000000000002 000000006a170000 GPR28: 000000000000000c c0000001f584c8d0 d000000003925180 c0000001f6e875c8 NIP [c00000000037d41c] .gen_pool_free+0x6c/0xf8 LR [d000000003913824] .c4iw_ocqp_pool_free+0x8c/0xd8 [iw_cxgb4] Call Trace: [c0000001f350b0d0] [c0000001f350b180] 0xc0000001f350b180 (unreliable) [c0000001f350b170] [d000000003913824] .c4iw_ocqp_pool_free+0x8c/0xd8 [iw_cxgb4] [c0000001f350b210] [d00000000390fd70] .dealloc_sq+0x90/0xb0 [iw_cxgb4] [c0000001f350b280] [d00000000390fe08] .destroy_qp+0x78/0xf8 [iw_cxgb4] [c0000001f350b310] [d000000003912738] .c4iw_destroy_qp+0x208/0x2d0 [iw_cxgb4] [c0000001f350b460] [d000000003861874] .ib_destroy_qp+0x5c/0x130 [ib_core] [c0000001f350b510] [d0000000039911bc] .ib_uverbs_cleanup_ucontext+0x174/0x4f8 [ib_uverbs] [c0000001f350b5f0] [d000000003991568] .ib_uverbs_close+0x28/0x70 [ib_uverbs] [c0000001f350b670] [c0000000001e7b2c] .__fput+0xdc/0x278 [c0000001f350b720] [c0000000001a9590] .remove_vma+0x68/0xd8 [c0000001f350b7b0] [c0000000001a9720] .exit_mmap+0x120/0x160 [c0000001f350b8d0] [c0000000000af330] .mmput+0x80/0x160 [c0000001f350b960] [c0000000000b5d0c] .exit_mm+0x1ac/0x1e8 [c0000001f350ba10] [c0000000000b8154] .do_exit+0x1b4/0x4b8 [c0000001f350bad0] [c0000000000b84b0] .do_group_exit+0x58/0xf8 [c0000001f350bb60] [c0000000000ce9f4] .get_signal_to_deliver+0x2f4/0x5d0 [c0000001f350bc60] [c000000000017ee4] .do_signal_pending+0x6c/0x3e0 [c0000001f350bdb0] [c0000000000182cc] .do_signal+0x74/0x78 [c0000001f350be30] [c000000000009e74] do_work+0x24/0x28 Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Cc: Emil Goode <emilgoode@gmail.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11r8169: fix 8168evl frame padding.Stefan Bader
commit e5195c1f31f399289347e043d6abf3ffa80f0005 upstream. Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Cc: hayeswang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11net/eth/ibmveth: Fixup retrieval of MAC addressBenjamin Herrenschmidt
commit 13f85203e1060da83d9ec1c1c5a63343eaab8de4 upstream. Some ancient pHyp versions used to create a 8 bytes local-mac-address property in the device-tree instead of a 6 bytes one for veth. The Linux driver code to deal with that is an insane hack which also happens to break with some choices of MAC addresses in qemu by testing for a bit in the address rather than just looking at the size of the property. Sanitize this by doing the latter instead. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11iommu/amd: Properly initialize irq-table lockJoerg Roedel
commit 197887f03daecdb3ae21bafeb4155412abad3497 upstream. Fixes a lockdep warning. Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11remoteproc: fix kconfig dependencies for VIRTIOSuman Anna
commit b9777859ec015a78dae1476e317d04f851bfdd0d upstream. Fix this: warning: (VIRTIO_PCI && VIRTIO_MMIO && REMOTEPROC && RPMSG) selects VIRTIO which has unmet direct dependencies (VIRTUALIZATION) Signed-off-by: Suman Anna <s-anna@ti.com> [edit commit log] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11rpmsg: fix kconfig dependencies for VIRTIOSuman Anna
commit 397944df3290ddc46dcc6a08cd71fb560700431b upstream. Fix this: warning: (VIRTIO_PCI && VIRTIO_MMIO && REMOTEPROC && RPMSG) selects VIRTIO which has unmet direct dependencies (VIRTUALIZATION) Signed-off-by: Suman Anna <s-anna@ti.com> [edit commit log] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11pwm: spear: Fix checking return value of clk_enable() and clk_prepare()Axel Lin
commit 563861cd633ae52932843477bb6ca3f1c9e2f78b upstream. The logic to check return value of clk_enable() and clk_prepare() is reversed, fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07mfd: adp5520: Restore mode bits on resumeLars-Peter Clausen
commit c6cc25fda58da8685ecef3f179adc7b99c8253b2 upstream. The adp5520 unfortunately also clears the BL_EN bit when the nSTNDBY bit is cleared. So we need to make sure to restore it during resume if it was set before suspend. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
