path: root/drivers
2010-09-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: Staging: vt6655: fix buffer overflow Revert: "Staging: batman-adv: Adding netfilter-bridge hooks"
2010-09-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: musb: MAINTAINERS: Fix my mail address USB: serial/mos*: prevent reading uninitialized stack memory USB: otg: twl4030: fix phy initialization(v1) USB: EHCI: Disable langwell/penwell LPM capability usb: musb_debugfs: don't use the struct file private_data field with seq_files
2010-09-20Staging: vt6655: fix buffer overflowDan Carpenter
"param->u.wpa_associate.wpa_ie_len" comes from the user. We should check it so that the copy_from_user() doesn't overflow the buffer. Also further down in the function, we assume that if "param->u.wpa_associate.wpa_ie_len" is set then "abyWPAIE[0]" is initialized. To make that work, I changed the test here to say that if "wpa_ie_len" is set then "wpa_ie" has to be a valid pointer or we return -EINVAL. Oddly, we only use the first element of the abyWPAIE[] array. So I suspect there may be some other issues in this function. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20Revert: "Staging: batman-adv: Adding netfilter-bridge hooks"Sven Eckelmann
This reverts commit 96d592ed599434d2d5f339a1d282871bc6377d2c. The netfilter hook seems to be misused and may leak skbs in situations when NF_HOOK returns NF_STOLEN. It may not filter everything as expected. Also the ethernet bridge tables are not yet capable to understand batman-adv packet correctly. It was only added for testing purposes and can be removed again. Reported-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: Sven Eckelmann <sven.eckelmann@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20serial: mfd: fix bug in serial_hsu_remove()Feng Tang
Medfield HSU driver deal with 4 pci devices(3 uart ports + 1 dma controller), so in pci remove func, we need handle them differently Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20serial: amba-pl010: fix set_ldiscMika Westerberg
Commit d87d9b7d1 ("tty: serial - fix tty referencing in set_ldisc") changed set_ldisc to take ldisc number as parameter. This patch fixes AMBA PL010 driver according the new prototype. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Cc: Alan Cox <alan@linux.intel.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20USB: serial/mos*: prevent reading uninitialized stack memoryDan Rosenberg
The TIOCGICOUNT device ioctl in both mos7720.c and mos7840.c allows unprivileged users to read uninitialized stack memory, because the "reserved" member of the serial_icounter_struct struct declared on the stack is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20USB: otg: twl4030: fix phy initialization(v1)Ming Lei
Commit 461c317705eca5cac09a360f488715927fd0a927(into 2.6.36-v3) is put forward to power down phy if no usb cable is connected, but does introduce the two issues below: 1), phy is not into work state if usb cable is connected with PC during poweron, so musb device mode is not usable in such case, follows the reasons: -twl4030_phy_resume is not called, so regulators are not enabled i2c access are not enabled usb mode not configurated 2), The kernel warings[1] of regulators 'unbalanced disables' is caused if poweron without usb cable connected with PC or b-device. This patch fixes the two issues above: -power down phy only if no usb cable is connected with PC and b-device -do phy initialization(via __twl4030_phy_resume) if usb cable is connected with PC(vbus event) or another b-device(ID event) in twl4030_usb_probe. This patch also doesn't put VUSB3V1 LDO into active mode in twl4030_usb_ldo_init until VBUS/ID change detected, so we can save more power consumption than before. This patch is verified OK on Beagle board either connected with usb cable or not when poweron. [1]. warnings of 'unbalanced disables' of regulators. [root@OMAP3EVM /]# dmesg ------------[ cut here ]------------ WARNING: at drivers/regulator/core.c:1357 _regulator_disable+0x38/0x128() unbalanced disables for VUSB1V8 Modules linked in: Backtrace: [<c0030c48>] (dump_backtrace+0x0/0x110) from [<c034f5a8>] (dump_stack+0x18/0x1c) r7:c78179d8 r6:c01ed6b8 r5:c0410822 r4:0000054d [<c034f590>] (dump_stack+0x0/0x1c) from [<c0057da8>] (warn_slowpath_common+0x54/0x6c) [<c0057d54>] (warn_slowpath_common+0x0/0x6c) from [<c0057e64>] (warn_slowpath_fmt+0x38/0x40) r9:00000000 r8:00000000 r7:c78e6608 r6:00000000 r5:fffffffb r4:c78e6c00 [<c0057e2c>] (warn_slowpath_fmt+0x0/0x40) from [<c01ed6b8>] (_regulator_disable+0x38/0x128) r3:c0410e53 r2:c0410ad5 [<c01ed680>] (_regulator_disable+0x0/0x128) from [<c01ed87c>] (regulator_disable+0x24/0x38) r7:c78e6608 r6:00000000 r5:c78e6c40 r4:c78e6c00 [<c01ed858>] (regulator_disable+0x0/0x38) from [<c02382dc>] (twl4030_phy_power+0x15c/0x17c) r5:c78595c0 r4:00000000 [<c0238180>] (twl4030_phy_power+0x0/0x17c) from [<c023831c>] (twl4030_phy_suspend+0x20/0x2c) r6:00000000 r5:c78595c0 r4:c78595c0 [<c02382fc>] (twl4030_phy_suspend+0x0/0x2c) from [<c0238638>] (twl4030_usb_irq+0x11c/0x16c) r5:c78595c0 r4:00000040 [<c023851c>] (twl4030_usb_irq+0x0/0x16c) from [<c034ec18>] (twl4030_usb_probe+0x2c4/0x32c) r6:00000000 r5:00000000 r4:c78595c0 [<c034e954>] (twl4030_usb_probe+0x0/0x32c) from [<c02152a0>] (platform_drv_probe+0x20/0x24) r7:00000000 r6:c047d49c r5:c78e6608 r4:c047d49c [<c0215280>] (platform_drv_probe+0x0/0x24) from [<c0214244>] (driver_probe_device+0xd0/0x190) [<c0214174>] (driver_probe_device+0x0/0x190) from [<c02143d4>] (__device_attach+0x44/0x48) r7:00000000 r6:c78e6608 r5:c78e6608 r4:c047d49c [<c0214390>] (__device_attach+0x0/0x48) from [<c0213694>] (bus_for_each_drv+0x50/0x90) r5:c0214390 r4:00000000 [<c0213644>] (bus_for_each_drv+0x0/0x90) from [<c0214474>] (device_attach+0x70/0x94) r6:c78e663c r5:c78e6608 r4:c78e6608 [<c0214404>] (device_attach+0x0/0x94) from [<c02134fc>] (bus_probe_device+0x2c/0x48) r7:00000000 r6:00000002 r5:c78e6608 r4:c78e6600 [<c02134d0>] (bus_probe_device+0x0/0x48) from [<c0211e48>] (device_add+0x340/0x4b4) [<c0211b08>] (device_add+0x0/0x4b4) from [<c021597c>] (platform_device_add+0x110/0x16c) [<c021586c>] (platform_device_add+0x0/0x16c) from [<c0220cb0>] (add_numbered_child+0xd8/0x118) r7:00000000 r6:c045f15c r5:c78e6600 r4:00000000 [<c0220bd8>] (add_numbered_child+0x0/0x118) from [<c001c618>] (twl_probe+0x3a4/0x72c) [<c001c274>] (twl_probe+0x0/0x72c) from [<c02601ac>] (i2c_device_probe+0x7c/0xa4) [<c0260130>] (i2c_device_probe+0x0/0xa4) from [<c0214244>] (driver_probe_device+0xd0/0x190) r5:c7856e20 r4:c047c860 [<c0214174>] (driver_probe_device+0x0/0x190) from [<c02143d4>] (__device_attach+0x44/0x48) r7:c7856e04 r6:c7856e20 r5:c7856e20 r4:c047c860 [<c0214390>] (__device_attach+0x0/0x48) from [<c0213694>] (bus_for_each_drv+0x50/0x90) r5:c0214390 r4:00000000 [<c0213644>] (bus_for_each_drv+0x0/0x90) from [<c0214474>] (device_attach+0x70/0x94) r6:c7856e54 r5:c7856e20 r4:c7856e20 [<c0214404>] (device_attach+0x0/0x94) from [<c02134fc>] (bus_probe_device+0x2c/0x48) r7:c7856e04 r6:c78fd048 r5:c7856e20 r4:c7856e20 [<c02134d0>] (bus_probe_device+0x0/0x48) from [<c0211e48>] (device_add+0x340/0x4b4) [<c0211b08>] (device_add+0x0/0x4b4) from [<c0211fd8>] (device_register+0x1c/0x20) [<c0211fbc>] (device_register+0x0/0x20) from [<c0260aa8>] (i2c_new_device+0xec/0x150) r5:c7856e00 r4:c7856e20 [<c02609bc>] (i2c_new_device+0x0/0x150) from [<c0260dc0>] (i2c_register_adapter+0xa0/0x1c4) r7:00000000 r6:c78fd078 r5:c78fd048 r4:c781d5c0 [<c0260d20>] (i2c_register_adapter+0x0/0x1c4) from [<c0260f80>] (i2c_add_numbered_adapter+0x9c/0xb4) r7:00000a28 r6:c04600a8 r5:c78fd048 r4:00000000 [<c0260ee4>] (i2c_add_numbered_adapter+0x0/0xb4) from [<c034efa4>] (omap_i2c_probe+0x324/0x3e8) r5:00000000 r4:c78fd000 [<c034ec80>] (omap_i2c_probe+0x0/0x3e8) from [<c02152a0>] (platform_drv_probe+0x20/0x24) [<c0215280>] (platform_drv_probe+0x0/0x24) from [<c0214244>] (driver_probe_device+0xd0/0x190) [<c0214174>] (driver_probe_device+0x0/0x190) from [<c021436c>] (__driver_attach+0x68/0x8c) r7:c78b2140 r6:c047e214 r5:c04600e4 r4:c04600b0 [<c0214304>] (__driver_attach+0x0/0x8c) from [<c021399c>] (bus_for_each_dev+0x50/0x84) r7:c78b2140 r6:c047e214 r5:c0214304 r4:00000000 [<c021394c>] (bus_for_each_dev+0x0/0x84) from [<c0214068>] (driver_attach+0x20/0x28) r6:c047e214 r5:c047e214 r4:c00270d0 [<c0214048>] (driver_attach+0x0/0x28) from [<c0213274>] (bus_add_driver+0xa8/0x228) [<c02131cc>] (bus_add_driver+0x0/0x228) from [<c02146a4>] (driver_register+0xb0/0x13c) [<c02145f4>] (driver_register+0x0/0x13c) from [<c0215744>] (platform_driver_register+0x4c/0x60) r9:00000000 r8:c001f688 r7:00000013 r6:c005b6fc r5:c00083dc r4:c00270d0 [<c02156f8>] (platform_driver_register+0x0/0x60) from [<c001f69c>] (omap_i2c_init_driver+0x14/0x1c) [<c001f688>] (omap_i2c_init_driver+0x0/0x1c) from [<c002c460>] (do_one_initcall+0xd0/0x1a4) [<c002c390>] (do_one_initcall+0x0/0x1a4) from [<c0008478>] (kernel_init+0x9c/0x154) [<c00083dc>] (kernel_init+0x0/0x154) from [<c005b6fc>] (do_exit+0x0/0x688) r5:c00083dc r4:00000000 ---[ end trace 1b75b31a2719ed1d ]--- Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Felipe Balbi <me@felipebalbi.com> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20USB: EHCI: Disable langwell/penwell LPM capabilityAlek Du
We have to do so due to HW limitation. Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20usb: musb_debugfs: don't use the struct file private_data field with seq_filesMathias Nyman
seq_files use the private_data field of a file struct for storing a seq_file structure, data should be stored in seq_file's own private field (e.g. file->private_data->private) Otherwise seq_release() will free the private data when the file is closed. Signed-off-by: Mathias Nyman <mathias.nyman@nokia.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6: ide: Fix ordering of procfs registry.
2010-09-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) dca: disable dca on IOAT ver.3.0 multiple-IOH platforms netpoll: Disable IRQ around RCU dereference in netpoll_rx sctp: Do not reset the packet during sctp_packet_config(). net/llc: storing negative error codes in unsigned short MAINTAINERS: move atlx discussions to netdev drivers/net/cxgb3/cxgb3_main.c: prevent reading uninitialized stack memory drivers/net/eql.c: prevent reading uninitialized stack memory drivers/net/usb/hso.c: prevent reading uninitialized memory xfrm: dont assume rcu_read_lock in xfrm_output_one() r8169: Handle rxfifo errors on 8168 chips 3c59x: Remove atomic context inside vortex_{set|get}_wol tcp: Prevent overzealous packetization by SWS logic. net: RPS needs to depend upon USE_GENERIC_SMP_HELPERS phylib: fix PAL state machine restart on resume net: use rcu_barrier() in rollback_registered_many bonding: correctly process non-linear skbs ipv4: enable getsockopt() for IP_NODEFRAG ipv4: force_igmp_version ignored when a IGMPv3 query received ppp: potential NULL dereference in ppp_mp_explode() net/llc: make opt unsigned in llc_ui_setsockopt() ...
2010-09-17dca: disable dca on IOAT ver.3.0 multiple-IOH platformsSosnowski, Maciej
Direct Cache Access is not supported on IOAT ver.3.0 multiple-IOH platforms. This patch blocks registering of dca providers when multiple IOH detected with IOAT ver.3.0. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-17Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (lm95241) Replace rate sysfs attribute with update_interval hwmon: (adm1031) Replace update_rate sysfs attribute with update_interval hwmon: (w83627ehf) Use proper exit sequence hwmon: (emc1403) Remove unnecessary hwmon_device_unregister hwmon: (f75375s) Do not overwrite values read from registers hwmon: (f75375s) Shift control mode to the correct bit position hwmon: New subsystem maintainers hwmon: (lis3lv02d) Prevent NULL pointer dereference
2010-09-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: nosy: fix build when CONFIG_FIREWIRE=N firewire: ohci: activate cycle timer register quirk on Ricoh chips
2010-09-17Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: fix v1.x metadata update when a disk is missing. md: call md_update_sb even for 'external' metadata arrays.
2010-09-17hwmon: (lm95241) Replace rate sysfs attribute with update_intervalGuenter Roeck
update_interval is the matching attribute defined in the hwmon sysfs ABI. Use it. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-17hwmon: (adm1031) Replace update_rate sysfs attribute with update_intervalGuenter Roeck
The attribute reflects an interval, not a rate. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-17hwmon: (w83627ehf) Use proper exit sequenceJonas Jonsson
According to the datasheet for Winbond W83627DHG the proper way to exit the Extended Function Mode is to write 0xaa to the EFER(0x2e or 0x4e). Signed-off-by: Jonas Jonsson <jonas@ludd.ltu.se> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-17hwmon: (emc1403) Remove unnecessary hwmon_device_unregisterYong Wang
It is unnecessary and wrong to call hwmon_device_unregister in error handling before hwmon_device_register is called. Signed-off-by: Yong Wang <yong.y.wang@intel.com> Reviewed-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-17hwmon: (f75375s) Do not overwrite values read from registersGuillem Jover
All bits in the values read from registers to be used for the next write were getting overwritten, avoid doing so to not mess with the current configuration. Signed-off-by: Guillem Jover <guillem@hadrons.org> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-17hwmon: (f75375s) Shift control mode to the correct bit positionGuillem Jover
The spec notes that fan0 and fan1 control mode bits are located in bits 7-6 and 5-4 respectively, but the FAN_CTRL_MODE macro was making the bits shift by 5 instead of by 4. Signed-off-by: Guillem Jover <guillem@hadrons.org> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-17hwmon: (lis3lv02d) Prevent NULL pointer dereferenceKuninori Morimoto
If CONFIG_PM was selected and lis3lv02d_platform_data was NULL, the kernel will be panic when halt command run. Reported-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Acked-by: Samu Onkalo <samu.p.onkalo@nokia.com> Sigend-off-by: Jean Delvare <khali@linux-fr.org>
2010-09-16drivers/net/cxgb3/cxgb3_main.c: prevent reading uninitialized stack memoryDan Rosenberg
Fixed formatting (tabs and line breaks). The CHELSIO_GET_QSET_NUM device ioctl allows unprivileged users to read 4 bytes of uninitialized stack memory, because the "addr" member of the ch_reg struct declared on the stack in cxgb_extension_ioctl() is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-16drivers/net/eql.c: prevent reading uninitialized stack memoryDan Rosenberg
Fixed formatting (tabs and line breaks). The EQL_GETMASTRCFG device ioctl allows unprivileged users to read 16 bytes of uninitialized stack memory, because the "master_name" member of the master_config_t struct declared on the stack in eql_g_master_cfg() is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-16drivers/net/usb/hso.c: prevent reading uninitialized memoryDan Rosenberg
Fixed formatting (tabs and line breaks). The TIOCGICOUNT device ioctl allows unprivileged users to read uninitialized stack memory, because the "reserved" member of the serial_icounter_struct struct declared on the stack in hso_get_count() is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-17md: fix v1.x metadata update when a disk is missing.NeilBrown
If an array with 1.x metadata is assembled with the last disk missing, md doesn't properly record the fact that the disk was missing. This is unlikely to cause a real problem as the event count will be different to the count on the missing disk so it won't be included in the array. However it could still cause confusion. So make sure we clear all the relevant slots, not just the early ones. Signed-off-by: NeilBrown <neilb@suse.de>
2010-09-17md: call md_update_sb even for 'external' metadata arrays.NeilBrown
Now that we depend on md_update_sb to clear variable bits in mddev->flags (rather than trying not to set them) it is important to always call md_update_sb when appropriate. md_check_recovery has this job but explicitly avoids it for ->external metadata arrays. This is not longer appropraite, or needed. However we do want to avoid taking the mddev lock if only MD_CHANGE_PENDING is set as that is not cleared by md_update_sb for external-metadata arrays. Reported-by: "Kwolek, Adam" <adam.kwolek@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2010-09-17firewire: nosy: fix build when CONFIG_FIREWIRE=NStefan Richter
drivers/firewire/nosy* is a stand-alone driver that does not depend on CONFIG_FIREWIRE. Hence let make descend into drivers/firewire/ also if that option is off. The stand-alone driver drivers/ieee1394/init_ohci1394_dma* will soon be moved into drivers/firewire/ too and will require the same makefile fix. Side effect: As mentioned in https://bugzilla.novell.com/show_bug.cgi?id=586172#c24 this influences the order in which either firewire-ohci or ohci1394 is going to be bound to an OHCI-1394 controller in case of a modular build of both drivers if no modprobe blacklist entries are configured. However, a user of such a setup cannot expect deterministic behavior anyway. The Kconfig help and the migration guide at ieee1394.wiki.kernel.org recommend blacklist entries when a dual IEEE 1394 stack build is being used. (The coexistence period of the two stacks is planned to end soon.) Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-09-16Merge branch '2.6.36-fixes' of git://github.com/schandinat/linux-2.6Linus Torvalds
* '2.6.36-fixes' of git://github.com/schandinat/linux-2.6: drivers/video/via/ioctl.c: prevent reading uninitialized stack memory
2010-09-16Merge branch 'urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6 * 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia pcnet_cs: try setting io_lines to 16 if card setup fails pcmcia: per-device, not per-socket debug messages pcmcia serial_cs.c: fix multifunction card handling
2010-09-16Merge git://git.infradead.org/users/cbou/battery-2.6.36Linus Torvalds
* git://git.infradead.org/users/cbou/battery-2.6.36: apm_power: Add missing break statement intel_pmic_battery: Fix battery charging status on mrst
2010-09-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: watchdog: Enable NXP LPC32XX support in Kconfig (resend) watchdog: ts72xx_wdt: disable watchdog at probe watchdog: sb_wdog: release irq and reboot notifier in error path and module_exit()
2010-09-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: regulator: wm8350-regulator - fix the logic of checking REGULATOR_MODE_STANDBY mode regulator: wm831x-ldo - fix the logic to set REGULATOR_MODE_IDLE and REGULATOR_MODE_STANDBY modes regulator: ab8500 - fix off-by-one value range checking for selector regulator: 88pm8607 - fix value range checking for accessing info->vol_table regulator: isl6271a-regulator - fix regulator_desc parameter for regulator_register() regulator: ad5398 - fix a memory leak regulator: Update e-mail address for Liam Girdwood regulator: set max8998->dev to &pdev->dev. regulator: tps6586x-regulator - fix bit_mask parameter for tps6586x_set_bits() regulator: tps6586x-regulator - fix value range checking for val regulator: max8998 - set max8998->num_regulators regulator: max8998 - fix memory allocation size for max8998->rdev regulator: tps6507x - remove incorrect comments regulator: max1586 - improve the logic of choosing selector regulator: ab8500 - fix the logic to remove already registered regulators in error path regulator: ab3100 - fix the logic to remove already registered regulators in error path regulator/ab8500: move dereference below the check for NULL
2010-09-16Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms: only warn on mipmap size checks in r600 cs checker (v2) drm/radeon/kms: force legacy pll algo for RV620 LVDS drm: fix race between driver loading and userspace open. drm: Use a nondestructive mode for output detect when polling (v2) drm/radeon/kms: fix the colorbuffer CS checker for r300-r500 drm/radeon/kms: increase lockup detection interval to 10 sec for r100-r500 drm/radeon/kms/evergreen: fix backend setup drm: Use a nondestructive mode for output detect when polling drm/radeon: add some missing copyright headers drm: Only decouple the old_fb from the crtc is we call mode_set* drm/radeon/kms: don't enable underscan with interlaced modes drm/radeon/kms: add connector table for Mac x800 drm/radeon/kms: fix regression in RMX code (v2) drm: Fix regression in disable polling e58f637
2010-09-15r8169: Handle rxfifo errors on 8168 chipsMatthew Garrett
The Thinkpad X100e seems to have some odd behaviour when the display is powered off - the onboard r8169 starts generating rxfifo overflow errors. The root cause of this has not yet been identified and may well be a hardware design bug on the platform, but r8169 should be more resiliant to this. This patch enables the rxfifo interrupt on 8168 devices and removes the MAC version check in the interrupt handler, and the machine no longer crashes when under network load while the screen turns off. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15drivers/video/via/ioctl.c: prevent reading uninitialized stack memoryDan Rosenberg
The VIAFB_GET_INFO device ioctl allows unprivileged users to read 246 bytes of uninitialized stack memory, because the "reserved" member of the viafb_ioctl_info struct declared on the stack is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2010-09-153c59x: Remove atomic context inside vortex_{set|get}_wolDenis Kirjanov
There is no need to use spinlocks in vortex_{set|get}_wol. This also fixes a bug: [ 254.214993] 3c59x 0000:00:0d.0: PME# enabled [ 254.215021] BUG: sleeping function called from invalid context at kernel/mutex.c:94 [ 254.215030] in_atomic(): 0, irqs_disabled(): 1, pid: 4875, name: ethtool [ 254.215042] Pid: 4875, comm: ethtool Tainted: G W 2.6.36-rc3+ #7 [ 254.215049] Call Trace: [ 254.215050] [] __might_sleep+0xb1/0xb6 [ 254.215050] [] mutex_lock+0x17/0x30 [ 254.215050] [] acpi_enable_wakeup_device_power+0x2b/0xb1 [ 254.215050] [] acpi_pm_device_sleep_wake+0x42/0x7f [ 254.215050] [] acpi_pci_sleep_wake+0x5d/0x63 [ 254.215050] [] platform_pci_sleep_wake+0x1d/0x20 [ 254.215050] [] __pci_enable_wake+0x90/0xd0 [ 254.215050] [] acpi_set_WOL+0x8e/0xf5 [3c59x] [ 254.215050] [] vortex_set_wol+0x4e/0x5e [3c59x] [ 254.215050] [] dev_ethtool+0x1cf/0xb61 [ 254.215050] [] ? debug_mutex_free_waiter+0x45/0x4a [ 254.215050] [] ? __mutex_lock_common+0x204/0x20e [ 254.215050] [] ? __mutex_lock_slowpath+0x12/0x15 [ 254.215050] [] ? mutex_lock+0x23/0x30 [ 254.215050] [] dev_ioctl+0x42c/0x533 [ 254.215050] [] ? _cond_resched+0x8/0x1c [ 254.215050] [] ? lock_page+0x1c/0x30 [ 254.215050] [] ? page_address+0x15/0x7c [ 254.215050] [] ? filemap_fault+0x187/0x2c4 [ 254.215050] [] sock_ioctl+0x1d4/0x1e0 [ 254.215050] [] ? sock_ioctl+0x0/0x1e0 [ 254.215050] [] vfs_ioctl+0x19/0x33 [ 254.215050] [] do_vfs_ioctl+0x424/0x46f [ 254.215050] [] ? selinux_file_ioctl+0x3c/0x40 [ 254.215050] [] sys_ioctl+0x40/0x5a [ 254.215050] [] sysenter_do_call+0x12/0x22 vortex_set_wol protected with a spinlock, but nested acpi_set_WOL acquires a mutex inside atomic context. Ethtool operations are already serialized by RTNL mutex, so it is safe to drop the locks. Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15watchdog: Enable NXP LPC32XX support in Kconfig (resend)Kevin Wells
The NXP LPC32XX processor use the same watchdog as the Philips PNX4008 processor. Signed-off-by: Kevin Wells <wellsk40@gmail.com> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-09-15watchdog: ts72xx_wdt: disable watchdog at probeMika Westerberg
Since it may be already enabled by bootloader or some other utility. This patch makes sure that the watchdog is disabled before any userspace daemon opens the device. It is also required by the watchdog API. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-09-15watchdog: sb_wdog: release irq and reboot notifier in error path and ↵Akinobu Mita
module_exit() irq and reboot notifier are acquired in module_init() but never released. They should be released correctly, otherwise reloading the module or error during module_init() will cause a problem. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andrew Sharp <andy.sharp@lsi.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-09-15pcmcia pcnet_cs: try setting io_lines to 16 if card setup failsDominik Brodowski
Some pcnet_cs compatible cards require an exact 16-lines match of the ioport areas specified in CIS, but set the "iolines" value in the CIS incorrectly. We can easily work around this issue -- same as we do in serial_cs -- by first trying setting iolines to the CIS-specified value, and then trying a 16-line match. Reported-and-tested-by: Wolfram Sang <w.sang@pengutronix.de> Hardware-supplied-by: Jochen Frieling <j.frieling@pengutronix.de> CC: netdev@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-15pcmcia: per-device, not per-socket debug messagesDominik Brodowski
As the iomem / ioport setup differs per device, it is much better to print out the device instead of the socket. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-15pcmcia serial_cs.c: fix multifunction card handlingDominik Brodowski
We shouldn't overwrite pre-set values, and we should also set the port address to the beginning, and not the end of the 8-port range. CC: linux-serial@vger.kernel.org Reported-by: Komuro <komurojun-mbn@nifty.com> Hardware-supplied-by: Jochen Frieling <j.frieling@pengutronix.de> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-15drm/radeon/kms: only warn on mipmap size checks in r600 cs checker (v2)Alex Deucher
The texture base address registers are in units of 256 bytes. The original CS checker treated these offsets as bytes, so the original check was wrong. I fixed the units in a patch during the 2.6.36 cycle, but this ended up breaking some existing userspace (probably due to a bug in either userspace texture allocation or the drm texture mipmap checker). So for now, until we come up with a better fix, just warn if the mipmap size it too large. This will keep existing userspace working and it should be just as safe as before when we were checking the wrong units. These are GPU MC addresses, so if they fall outside of the VRAM or GART apertures, they end up at the GPU default page, so this should be safe from a security perspective. v2: Just disable the warning. It just spams the log and there's nothing the user can do about it. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: Jerome Glisse <glisse@freedesktop.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-14Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd: pxa3xx: fix build error when CONFIG_MTD_PARTITIONS is not defined mtd: mxc_nand: configure pages per block for v2 controller mtd: OneNAND: Fix loop hang when DMA error at Samsung SoCs mtd: OneNAND: Fix 2KiB pagesize handling at Samsung SoCs mtd: Blackfin NFC: fix invalid free in remove() mtd: Blackfin NFC: fix build error after nand_scan_ident() change mxc_nand: Do not do byte accesses to the NFC buffer.
2010-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: fix hiddev's use of usb_find_interface HID: fixup blacklist entry for Asus T91MT HID: add device ID for new Asus Multitouch Controller HID: add no-get quirk for eGalax touch controller HID: Add quirk for eGalax touch controler. HID: add support for another BTC Emprex remote control HID: Set Report ID properly for Output reports on the Control endpoint. HID: Kanvus Note A5 tablet needs HID_QUIRK_MULTI_INPUT HID: Add support for chicony multitouch screens.
2010-09-14phylib: fix PAL state machine restart on resumeSimon Guinot
On resume, before starting the PAL state machine, check if the adjust_link() method is well supplied. If not, this would lead to a NULL pointer dereference in the phy_state_machine() function. This scenario can happen if the Ethernet driver call manually the PHY functions instead of using the PAL state machine. The mv643xx_eth driver is a such example. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14bonding: correctly process non-linear skbsAndy Gospodarek
It was recently brought to my attention that 802.3ad mode bonds would no longer form when using some network hardware after a driver update. After snooping around I realized that the particular hardware was using page-based skbs and found that skb->data did not contain a valid LACPDU as it was not stored there. That explained the inability to form an 802.3ad-based bond. For balance-alb mode bonds this was also an issue as ARPs would not be properly processed. This patch fixes the issue in my tests and should be applied to 2.6.36 and as far back as anyone cares to add it to stable. Thanks to Alexander Duyck <alexander.h.duyck@intel.com> and Jesse Brandeburg <jesse.brandeburg@intel.com> for the suggestions on this one. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> CC: Alexander Duyck <alexander.h.duyck@intel.com> CC: Jesse Brandeburg <jesse.brandeburg@intel.com> CC: stable@kerne.org Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14drm/radeon/kms: force legacy pll algo for RV620 LVDSAlex Deucher
There has been periodic evidence that LVDS, on at least some panels, prefers the dividers selected by the legacy pll algo. This patch forces the use of the legacy pll algo on RV620 LVDS panels. The old behavior (new pll algo) can be selected by setting the new_pll module parameter to 1. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=30029 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
