non-rebuilding drive completed it.
commit 3056e3aec8d8ba61a0710fb78b2d562600aa2ea7 upstream.
Without that fix, the following scenario could happen:
- RAID1 with drives A and B; drive B was freshly-added and is rebuilding
- Drive A fails
- WRITE request arrives to the array. It is failed by drive A, so
r1_bio is marked as R1BIO_WriteError, but the rebuilding drive B
succeeds in writing it, so the same r1_bio is marked as
R1BIO_Uptodate.
- r1_bio arrives to handle_write_finished, badblocks are disabled,
md_error()->error() does nothing because we don't fail the last drive
of raid1
- raid_end_bio_io() calls call_bio_endio()
- As a result, in call_bio_endio():
if (!test_bit(R1BIO_Uptodate, &r1_bio->state))
clear_bit(BIO_UPTODATE, &bio->bi_flags);
this code doesn't clear the BIO_UPTODATE flag, and the whole master
WRITE succeeds, back to the upper layer.
So we returned success to the upper layer, even though we had written
the data onto the rebuilding drive only. But when we want to read the
data back, we would not read from the rebuilding drive, so this data
is lost.
[neilb - applied identical change to raid10 as well]
This bug can result in lost data, so it is suitable for any
-stable kernel.
Signed-off-by: Alex Lyakas <alex@zadarastorage.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit c3456fb3e4712d0448592af3c5d644c9472cd3c1 upstream.
In
commit 53d3b4d7778daf15900867336c85d3f8dd70600c
Author: Egbert Eich <eich@suse.de>
Date: Tue Jun 4 17:13:21 2013 +0200
drm/i915/sdvo: Use &intel_sdvo->ddc instead of intel_sdvo->i2c for DDC
Egbert Eich fixed a long-standing bug where we simply used a
non-working i2c controller to read the EDID for SDVO-LVDS panels.
Unfortunately some machines seem to not be able to cope with the mode
provided in the EDID. Specifically they seem to not be able to cope
with a 4x pixel mutliplier instead of a 2x one, which seems to have
been worked around by slightly changing the panels native mode in the
VBT so that the dotclock is just barely above 50MHz.
Since it took forever to notice the breakage it's fairly safe to
assume that at least for SDVO-LVDS panels the VBT contains fairly sane
data. So just switch around the order and use VBT modes first.
v2: Also add EDID modes just in case, and spell Egbert correctly.
v3: Elaborate a bit more about what's going on on Chris' machine.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=65524
Reported-and-tested-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Egbert Eich <eich@suse.de>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 03f47e888daf56c8e9046c674719a0bcc644eed5 upstream.
If a new logical drive is added and the CCISS_REGNEWD ioctl is invoked
(as is normal with the Array Configuration Utility) the process will
hang as below. It attempts to acquire the same mutex twice, once in
do_ioctl() and once in cciss_unlocked_open(). The BKL was recursive,
the mutex isn't.
Linux version 3.10.0-rc2 (scameron@localhost.localdomain) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-3) (GCC) ) #1 SMP Fri May 24 14:32:12 CDT 2013
acu D 0000000000000001 0 3246 3191 0x00000080
Call Trace:
schedule+0x29/0x70
schedule_preempt_disabled+0xe/0x10
__mutex_lock_slowpath+0x17b/0x220
mutex_lock+0x2b/0x50
cciss_unlocked_open+0x2f/0x110 [cciss]
__blkdev_get+0xd3/0x470
blkdev_get+0x5c/0x1e0
register_disk+0x182/0x1a0
add_disk+0x17c/0x310
cciss_add_disk+0x13a/0x170 [cciss]
cciss_update_drive_info+0x39b/0x480 [cciss]
rebuild_lun_table+0x258/0x370 [cciss]
cciss_ioctl+0x34f/0x470 [cciss]
do_ioctl+0x49/0x70 [cciss]
__blkdev_driver_ioctl+0x28/0x30
blkdev_ioctl+0x200/0x7b0
block_ioctl+0x3c/0x40
do_vfs_ioctl+0x89/0x350
SyS_ioctl+0xa1/0xb0
system_call_fastpath+0x16/0x1b
This mutex usage was added into the ioctl path when the big kernel lock
was removed. As it turns out, these paths are all thread safe anyway
(or can easily be made so) and we don't want ioctl() to be single
threaded in any case.
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Cc: Mike Miller <mike.miller@hp.com>
commit 5efac94999ff218e0101f67a059e44abb4b0b523 upstream.
The ath9k rate control algorithm has various architectural
issues that make it a poor fit in scenarios like congested
environments etc.
An example: https://bugzilla.redhat.com/show_bug.cgi?id=927191
Change the default to minstrel which is more robust in such cases.
The ath9k RC code is left in the driver for now, maybe it can
be removed altogether later on.
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
Cc: Jouni Malinen <jouni@qca.qualcomm.com>
commit 531671cb17af07281e6f28c1425f754346e65c41 upstream.
Almost all the DMA issues which have plagued ath9k (in station mode)
for years are related to PS. Disabling PS usually "fixes" the user's
connection stablility. Reports of DMA problems are still trickling in
and are sitting in the kernel bugzilla. Until the PS code in ath9k is
given a thorough review, disbale it by default. The slight increase
in chip power consumption is a small price to pay for improved link
stability.
commit 22e7c385a80d771aaf3a15ae7ccea3b0686bbe10 upstream.
The framebuffer needs to be unpinned in the crtc->disable callback
because of previous pinning in psb_intel_pipe_set_base(). This will fix
a memory leak where the framebuffer was released but not unpinned
properly. This patch only affects Cedarview.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=889511
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=812113
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
commit 820de86a90089ee607d7864538c98a23b503c846 upstream.
properly. This patch only affects Poulsbo.
device tree
commit 24b8256a1fb28d357bc6fa09184ba29b4255ba5c upstream.
When booted in legacy mode device_init_wakeup() gets called by
drivers/mfd/twl-core.c when the children are initialized. However, when
booted using device tree, the children are created with
of_platform_populate() instead add_children().
This means that the RTC driver will not have device_init_wakeup() set,
and we need to call it from the driver probe like RTC drivers typically
do.
Without this we cannot test PM wake-up events on omaps for cases where
there may not be any physical wake-up event.
Reported-by: Kevin Hilman <khilman@linaro.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Jingoo Han <jg1.han@samsung.com>
commit e0e29b683d6784ef59bbc914eac85a04b650e63c upstream.
The module parameter "fwpostfix" is userspace controllable, unfiltered,
and is used to define the firmware filename. b43_do_request_fw() populates
ctx->errors[] on error, containing the firmware filename. b43err()
parses its arguments as a format string. For systems with b43 hardware,
this could lead to a uid-0 to ring-0 escalation.
CVE-2013-2852
commit cbbd379aa43890f36da934f5af619d2fb8ec3d87 upstream.
By having a higher max resolution we can now set up a virtual
framebuffer that spans several monitors. 4096 should be ok since we're
gen 3 or higher and should be enough for most dual head setups.
Bugzilla:
https://bugs.launchpad.net/ubuntu/+source/xserver-xorg-video-modesetting/+bug/1169147
commit a816e3113b63753c330ca4751ea1d208e93e3015 upstream.
Pointers should not be compared to plain integers.
Quiets the sparse warning:
warning: Using plain integer as NULL pointer
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Cc: Lotfi Manseur <lotfi.manseur@gmail.com>
commit 51ac8893a7a51b196501164e645583bf78138699 upstream.
... as being guest triggerable (e.g. by invoking
XEN_PCI_OP_enable_msi{,x} on a device not being MSI/MSI-X capable).
This is CVE-2013-0231 / XSA-43.
Also make the two messages uniform in both their wording and severity.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[stable tree: Added two extra #include files]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 45a211d75137b1ac869a8a758a6667f15827a115 upstream.
Last year, a patch was made for the "HP t5740e Thin Client" (see
http://lists.freedesktop.org/archives/dri-devel/2012-May/023245.html).
This device reports an lvds panel, but does not really have one.
The predecessor of this device is the "hp t5740", which also does not have
an lvds panel. This patch will add the same quirk for this device.
Signed-off-by: Ben Mesman <ben@bnc.nl>
commit 53d3b4d7778daf15900867336c85d3f8dd70600c upstream.
In intel_sdvo_get_lvds_modes() the wrong i2c adapter record is used
for DDC. Thus the code will always have to rely on a LVDS panel
mode supplied by VBT.
In most cases this succeeds, so this didn't get detected for quite
a while.
This regression seems to have been introduced in
commit f899fc64cda8569d0529452aafc0da31c042df2e
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Tue Jul 20 15:44:45 2010 -0700
drm/i915: use GMBUS to manage i2c links
Signed-off-by: Egbert Eich <eich@suse.de>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
[danvet: Add note about which commit likely introduced this issue.]
commit b7ea85a4fed37835eec78a7be3039c8dc22b8178 upstream.
When GPU acceleration is disabled, drm_vblank_cleanup() will free the
vblank-related data, such as vblank_refcount, vblank_inmodeset, etc.
But we found that drm_vblank_post_modeset() may be called after the
cleanup, which use vblank_refcount and vblank_inmodeset. And this will
cause a kernel panic.
Fix this by return immediately if dev->num_crtcs is zero. This is the
same thing that drm_vblank_pre_modeset() does.
Call trace of a drm_vblank_post_modeset() after drm_vblank_cleanup():
[ 62.628906] [<ffffffff804868d0>] drm_vblank_post_modeset+0x34/0xb4
[ 62.628906] [<ffffffff804c7008>] atombios_crtc_dpms+0xb4/0x174
[ 62.628906] [<ffffffff804c70e0>] atombios_crtc_commit+0x18/0x38
[ 62.628906] [<ffffffff8047f038>] drm_crtc_helper_set_mode+0x304/0x3cc
[ 62.628906] [<ffffffff8047f92c>] drm_crtc_helper_set_config+0x6d8/0x988
[ 62.628906] [<ffffffff8047dd40>] drm_fb_helper_set_par+0x94/0x104
[ 62.628906] [<ffffffff80439d14>] fbcon_init+0x424/0x57c
[ 62.628906] [<ffffffff8046a638>] visual_init+0xb8/0x118
[ 62.628906] [<ffffffff8046b9f8>] take_over_console+0x238/0x384
[ 62.628906] [<ffffffff80436df8>] fbcon_takeover+0x7c/0xdc
[ 62.628906] [<ffffffff8024fa20>] notifier_call_chain+0x44/0x94
[ 62.628906] [<ffffffff8024fcbc>] __blocking_notifier_call_chain+0x48/0x68
[ 62.628906] [<ffffffff8042d990>] register_framebuffer+0x228/0x260
[ 62.628906] [<ffffffff8047e010>] drm_fb_helper_single_fb_probe+0x260/0x314
[ 62.628906] [<ffffffff8047e2c4>] drm_fb_helper_initial_config+0x200/0x234
[ 62.628906] [<ffffffff804e5560>] radeon_fbdev_init+0xd4/0xf4
[ 62.628906] [<ffffffff804e0e08>] radeon_modeset_init+0x9bc/0xa18
[ 62.628906] [<ffffffff804bfc14>] radeon_driver_load_kms+0xdc/0x12c
[ 62.628906] [<ffffffff8048b548>] drm_get_pci_dev+0x148/0x238
[ 62.628906] [<ffffffff80423564>] local_pci_probe+0x5c/0xd0
[ 62.628906] [<ffffffff80241ac4>] work_for_cpu_fn+0x1c/0x30
[ 62.628906] [<ffffffff802427c8>] process_one_work+0x274/0x3bc
[ 62.628906] [<ffffffff80242934>] process_scheduled_works+0x24/0x44
[ 62.628906] [<ffffffff8024515c>] worker_thread+0x31c/0x3f4
[ 62.628906] [<ffffffff802497a8>] kthread+0x88/0x90
[ 62.628906] [<ffffffff80206794>] kernel_thread_helper+0x10/0x18
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Binbin Zhou <zhoubb@lemote.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
Acked-by: Paul Menzel <paulepanter@users.sourceforge.net>
Signed-off-by: Dave Airlie <airlied@gmail.com>
commit 591bfcfc334a003ba31c0deff03b22e73349939b upstream.
On a system with both MAX1617 and JC42 sensors, JC42 sensors can be misdetected
as LM84. Strengthen detection sufficiently enough to avoid this misdetection.
Also improve detection for ADM1021.
Modeled after chip detection code in sensors-detect command.
Tested-by: Jean Delvare <khali@linux-fr.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
commit 1cbcca302a318499f20a512847c5d6a510c08c35 upstream.
It's not supported yet. Fixes display issues when
users force it on.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit e49f3959a96dc279860af7e86e6dbcfda50580a5 upstream.
The current radeon driver initialization routines, when using KMS, are written
so that the IRQ installation routine is called before initializing the WB buffer
and the CP rings. With some ASICs, though, the IRQ routine tries to access the
GFX_INDEX ring causing a call to RREG32 with the value of -1 in
radeon_fence_read. This, in turn causes the system to completely hang with some
cards, requiring a hard reset.
A call stack that can cause such a hang looks like this (using rv515 ASIC for the
example here):
* rv515_init (rv515.c)
* radeon_irq_kms_init (radeon_irq_kms.c)
* drm_irq_install (drm_irq.c)
* radeon_driver_irq_preinstall_kms (radeon_irq_kms.c)
* rs600_irq_process (rs600.c)
* radeon_fence_process - due to SW interrupt (radeon_fence.c)
* radeon_fence_read (radeon_fence.c)
* hang due to RREG32(-1)
The patch moves the IRQ installation to the card startup routine, after the ring
has been initialized, but before the IRQ has been set. This fixes the issue, but
requires a check to see if the IRQ is already installed, as is the case in the
system resume codepath.
I have tested the patch on three machines using the rv515, the rv770 and the
evergreen ASIC. They worked without issues.
This seems to be a known issue and has been reported on several bug tracking
sites by various distributions (see links below). Most of reports recommend
booting the system with KMS disabled and then enabling KMS by reloading the
radeon module. For some reason, this was indeed a usable workaround, however,
UMS is now deprecated and disabled by default.
Bug reports:
https://bugzilla.redhat.com/show_bug.cgi?id=845745
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/561789
https://bbs.archlinux.org/viewtopic.php?id=156964
Signed-off-by: Adis Hamzić <adis@hamzadis.com>
commit 780a6ec640a3fed671fc2c40e4dd30c03eca3ac3 upstream.
This patch addresses kernel bug 56661. BIOS reports an incorrect
backlight value, causing the driver to switch off the backlight
completely during startup. This patch ignores the incorrect value from
BIOS.
References: https://bugzilla.kernel.org/show_bug.cgi?id=56661
Signed-off-by: Ash Willis <ashwillis@programmer.net>
commit fedbe9bc6fd3e14b1ffbb3dac407777ac4a3650c upstream.
On HP m4 lapops, BIOS reports minimum backlight on boot and
causes backlight to dim completely. This ignores the initial backlight
values and set to max brightness.
References: https://bugs.launchpad.net/bugs/1184501
Signed-off-by: Alex Hung <alex.hung@canonical.com>
commit a26f009a070e840fadacb91013b2391ba7ab6cc2 upstream.
The register access to enable hardware flow control depends on the
device port number and not the port minor number.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 849513a7809175420d353625b6f651d961e99d49 upstream.
The control and bulk-message timeouts are specified in milliseconds and
should not depend on HZ.
commit 72ea18a558ed7a63a50bb121ba60d73b5b38ae30 upstream.
The read_mos_reg function is called with stack-allocated buffers, which
must not be used for control messages.
commit fdc03438f53a00294ed9939eb3a1f6db6f3d8963 upstream.
This patch reverts commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d
(USB: EHCI: fix bug in scheduling periodic split transfers). The
commit was valid -- it fixed a real bug -- but the periodic scheduler
in ehci-hcd is in such bad shape (especially the part that handles
split transactions) that fixing one bug is very likely to cause
another to surface. That's what happened in this case; the result was
choppy and noisy playback on certain 24-bit audio devices.
The only real fix will be to rewrite this entire section of code. My
next project...
This fixes https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1136110.
Thanks to Tim Richardson for extra testing and feedback, and to Joseph
Salisbury and Tyson Tan for tracking down the original source of the
problem.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Joseph Salisbury <joseph.salisbury@canonical.com>
CC: Tim Richardson <tim@tim-richardson.net>
commit 5f8e2c07d75967ee49a5da1d21ddf5f50d48cda0 upstream.
The first and second interrupt-in urbs are swapped for some Treo/Kyocera
devices, but the urb context was never updated with the new port.
commit 9eecf22d2b375b9064a20421c6c307b760b03d46 upstream.
When configuring the port (e.g. set_termios) the port minor number
rather than the port number was used in the request (and they only
coincide for minor number 0).
commit 6529591e3eef65f0f528a81ac169f6e294b947a7 upstream.
The patch adds a new HIDCOM device and does not affect other devices
driven by the cypress_M8 module. Changes are:
- add VendorID ProductID to device tables
- skip unstable speed check because FRWD uses 115200bps
- skip reset at probe which is an issue workaround for this
particular device.
Signed-off-by: Robert Butora <robert.butora.fi@gmail.com>
commit 420021a395ce38b7ab2cceb52dee4038be7d8fa3 upstream.
Fix regression introduced by commit 214916f2e ("USB: visor: reimplement
using generic framework") which broke initialisation of Treo/Kyocera
devices that re-mapped bulk-in endpoints.
commit 634371911730a462626071065b64cd6e1fe213e0 upstream.
The control-message timeout is specified in milliseconds and should not
depend on HZ.
commit a07088098a650267b2eda689538133a324b9523f upstream.
The outcont_endpoints array was indexed using the port minor number
(which can be greater than the array size) rather than the device port
number.
commit 6c13ff68a7ce01da7a51b44241a7aad8eaaedde7 upstream.
The bulk-message timeout is specified in milliseconds and should not
depend on HZ.
commit 88696ae432ce7321540ac53d9caab3de9118b094 upstream.
If for whatever reason we fall into fail path in xhci_mem_init()
before bw table gets initialized we may access the uninitialized lists
in xhci_mem_cleanup().
Check for bw table before traversing lists in cleanup routine.
This patch should be backported to kernels as old as 3.2, that contain
the commit 839c817ce67178ca3c7c7ad534c571bba1e69ebe "xhci: Store
information about roothubs and TTs."
Reported-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Signed-off-by: Vladimir Murzin <murzin.v@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 331de00a64e5027365145bdf51da27b9ce15dfd5 upstream.
It is possible that we fail on xhci_mem_init, just before doing
the INIT_LIST_HEAD, and calling xhci_mem_cleanup.
Problem is that, the list_for_each_entry_safe macro, assumes
list heads are initialized (not NULL), and dereferences their 'next'
pointer, causing a kernel panic if this is not yet initialized.
Let's protect from that by moving inits to the beginning.
contain the commit 9574323c39d1f8359a04843075d89c9f32d8b7e6 "xHCI: test
USB2 software LPM".
Signed-off-by: Sergio Aguirre <sergio.a.aguirre.rodriguez@intel.com>
Acked-by: David Cohen <david.a.cohen@intel.com>
commit 77df9e0b799b03e1d5d9c68062709af5f637e834 upstream.
Commit 71c731a2 (usb: host: xhci: Fix Compliance Mode on SN65LVPE502CP
Hardware) was a workaround for systems using the SN65LVPE502CP,
controller, but it introduced a bug in resume from hibernate.
The fix created a timer, comp_mode_recovery_timer, which is deleted from
a timer list when xhci_suspend() is called. However, the hibernate image,
including the timer list containing the comp_mode_recovery_timer, had
already been saved before the timer was deleted.
Upon resume from hibernate, the list containing the comp_mode_recovery_timer
is restored from the image saved to disk, and xhci_resume(), assuming that
the timer had been deleted by xhci_suspend(), makes a call to
compliance_mode_recoery_timer_init(), which creates a new instance of the
comp_mode_recovery_timer and attempts to place it into the same list in which
it is already active, thus corrupting the list during the list_add() call.
At this point, a call trace is emitted indicating the list corruption.
Soon afterward, the system locks up, the watchdog times out, and the
ensuing NMI crashes the system.
The problem did not occur when resuming from suspend. In suspend, the
image in RAM remains exactly as it was when xhci_suspend() deleted the
comp_mode_recovery_timer, so there is no problem when xhci_resume()
creates a new instance of this timer and places it in the still empty
list.
This patch avoids the problem by deleting the timer in xhci_resume()
when resuming from hibernate. Now xhci_resume() can safely make the
call to create a new instance of this timer, whether returning from
suspend or hibernate.
Thanks to Alan Stern for his help with understanding the problem.
[Sarah reworked this patch to cover the case where the xHCI restore
register operation fails, and (temp & STS_SRE) is true (and we re-init
the host, including re-init for the compliance mode), but hibernate is
false. The original patch would have caused list corruption in this
case.]
contain the commit 71c731a296f1b08a3724bd1b514b64f1bda87a23 "usb: host:
xhci: Fix Compliance Mode on SN65LVPE502CP Hardware"
Signed-off-by: Tony Camuso <tcamuso@redhat.com>
Tested-by: Tony Camuso <tcamuso@redhat.com>
Acked-by: Don Zickus <dzickus@redhat.com>
commit b8a24e6281d37243c06b9497dcbfaa98c1e2ad35 upstream.
The mode used by Windows for the Huawei E1820 will use the
same ff/ff/ff class codes for both serial and network
functions.
Reported-by: Graham Inggs <graham.inggs@uct.ac.za>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit a4f46bb9fa84642e356898ee44b670989622f8bb upstream.
In the latest V-series bios DMI_PRODUCT_VERSION does not contain
the string Lenovo or Thinkpad, but is set to the model number, this
causes the thinkpad_acpi module to fail to load. Recognize laptop
as Lenovo using DMI_BIOS_VENDOR instead, which is set to Lenovo.
Test on V490u
== After the patch ==
[ 1350.295757] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[ 1350.295760] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 1350.295761] thinkpad_acpi: ThinkPad BIOS H7ET21WW (1.00 ), EC unknown
[ 1350.295763] thinkpad_acpi: Lenovo LENOVO, model LV5DXXX
[ 1350.296086] thinkpad_acpi: detected a 8-level brightness capable ThinkPad
[ 1350.296694] thinkpad_acpi: radio switch found; radios are enabled
[ 1350.296703] thinkpad_acpi: possible tablet mode switch found; ThinkPad in laptop mode
[ 1350.306466] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[ 1350.307082] Registered led device: tpacpi::thinklight
[ 1350.307215] Registered led device: tpacpi::power
[ 1350.307255] Registered led device: tpacpi::standby
[ 1350.307294] Registered led device: tpacpi::thinkvantage
[ 1350.308160] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[ 1350.308333] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[ 1350.312287] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input14
== Before the patch ==
sudo modprobe thinkpad_acpi
FATAL: Error inserting thinkpad_acpi (/lib/modules/3.2.0-27-generic/kernel/drivers/platform/x86/thinkpad_acpi.ko): No such device
Test on B485
This patch was also test in a B485 where the thinkpad_acpi module does not
have any issues loading. But, I tested it to make sure this patch does not
break on already functioning models of Lenovo products.
[13486.746359] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[13486.746364] thinkpad_acpi: http://ibm-acpi.sf.net/
[13486.746368] thinkpad_acpi: ThinkPad BIOS HJET15WW(1.01), EC unknown
[13486.746373] thinkpad_acpi: Lenovo Lenovo LB485, model 814TR01
[13486.747300] thinkpad_acpi: detected a 8-level brightness capable ThinkPad
[13486.752435] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[13486.752883] Registered led device: tpacpi::thinklight
[13486.752915] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[13486.753216] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[13486.757147] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input15
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Cc: Shuduo Sang <shuduo.sang@canonical.com>
commit d3263bc29706e42f74d8800807c2dedf320d77f1 upstream.
Work around an IOMMU hardware bug where clearing the
EVT_INT or PPR_INT bit in the status register may race with
the hardware trying to set it again. When not handled the
bit might not be cleared and we lose all future event or ppr
interrupts.
Reported-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit 925fe08bce38d1ff052fe2209b9e2b8d5fbb7f98 upstream.
Current driver does not clear the IOMMU event log interrupt bit
in the IOMMU status register after processing an interrupt.
This causes the IOMMU hardware to generate event log interrupt only once.
This has been observed in both IOMMU v1 and V2 hardware.
This patch clears the bit by writing 1 to bit 1 of the IOMMU
status register (MMIO Offset 2020h)
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
commit 27f852282ab9a028f57da96d05c26f38c424a315 upstream.
This variable is never used.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
commit bee980d9e9642e96351fa3ca9077b853ecf62f57 upstream.
This avoids any other hardirq handler seeing a very stale jiffies
value immediately after wakeup from a long idle period. The one
observable symptom of this was a USB keyboard, with software keyboard
repeat, which would always repeat a key immediately that it was
pressed. This is due to the key press waking the guest, the key
handler immediately runs, sees an old jiffies value, and then that
jiffies value significantly updated, before the key is unpressed.
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Keir Fraser <keir.fraser@citrix.com>
commit e771451c0a831d96a7c14b0ca8a8ec671d98567b upstream.
libata honors DMADIR for regular commands, but not for internal commands
used (among other) during device initialisation.
This makes SATA-host-to-PATA-device bridges based on Silicon Image SiL3611
(such as "Abit Serillel 2") end up disabled when used with an ATAPI device
after a few tries.
Log output of the bridge being hot-plugged with an ATAPI drive:
[ 9631.212901] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen
[ 9631.212913] ata1: irq_stat 0x00000040, connection status changed
[ 9631.212923] ata1: SError: { CommWake 10B8B DevExch }
[ 9631.212939] ata1: hard resetting link
[ 9632.104962] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9632.106393] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33
[ 9632.106407] ata1.00: applying bridge limits
[ 9632.108151] ata1.00: configured for UDMA/33
[ 9637.105303] ata1.00: qc timeout (cmd 0xa0)
[ 9637.105324] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5)
[ 9637.105335] ata1: hard resetting link
[ 9638.044599] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9638.047878] ata1.00: configured for UDMA/33
[ 9643.044933] ata1.00: qc timeout (cmd 0xa0)
[ 9643.044953] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5)
[ 9643.044963] ata1: limiting SATA link speed to 1.5 Gbps
[ 9643.044971] ata1.00: limiting speed to UDMA/33:PIO3
[ 9643.044979] ata1: hard resetting link
[ 9643.984225] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 9643.987471] ata1.00: configured for UDMA/33
[ 9648.984591] ata1.00: qc timeout (cmd 0xa0)
[ 9648.984612] ata1.00: failed to clear UNIT ATTENTION (err_mask=0x5)
[ 9648.984619] ata1.00: disabled
[ 9649.000593] ata1: hard resetting link
[ 9649.939902] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 9649.955864] ata1: EH complete
With this patch, the drive enumerates correctly when libata is loaded with
atapi_dmadir=1:
[ 9891.810863] ata1: exception Emask 0x10 SAct 0x0 SErr 0x40c0000 action 0xe frozen
[ 9891.810874] ata1: irq_stat 0x00000040, connection status changed
[ 9891.810884] ata1: SError: { CommWake 10B8B DevExch }
[ 9891.810900] ata1: hard resetting link
[ 9892.762105] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 9892.763544] ata1.00: ATAPI: PIONEER DVD-RW DVR-115, 1.06, max UDMA/33, DMADIR
[ 9892.763558] ata1.00: applying bridge limits
[ 9892.765393] ata1.00: configured for UDMA/33
[ 9892.786063] ata1: EH complete
[ 9892.792062] scsi 0:0:0:0: CD-ROM PIONEER DVD-RW DVR-115 1.06 PQ: 0 ANSI: 5
[ 9892.798455] sr2: scsi3-mmc drive: 12x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 9892.798837] sr 0:0:0:0: Attached scsi CD-ROM sr2
[ 9892.799109] sr 0:0:0:0: Attached scsi generic sg6 type 5
Based on a patch by Csaba Halász <csaba.halasz@gmail.com> on linux-ide:
http://marc.info/?l=linux-ide&m=136121147832295&w=2
tj: minor formatting changes.
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
commit fca8c90d519dedd4f4b19901d005c243f7f0bf2e upstream.
Adds IDE-mode SATA Device IDs for the Intel BayTrail platform.
Signed-off-by: Chew, Chiau Ee <chiau.ee.chew@intel.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 1ee0a224bc9aad1de496c795f96bc6ba2c394811 upstream.
The tty is NULL when the port is hanging up.
chase_port() needs to check for this.
This patch is intended for stable series.
The behavior was observed and tested in Linux 3.2 and 3.7.1.
Johan Hovold submitted a more elaborate patch for the mainline kernel.
[ 56.277883] usb 1-1: edge_bulk_in_callback - nonzero read bulk status received: -84
[ 56.278811] usb 1-1: USB disconnect, device number 3
[ 56.278856] usb 1-1: edge_bulk_in_callback - stopping read!
[ 56.279562] BUG: unable to handle kernel NULL pointer dereference at 00000000000001c8
[ 56.280536] IP: [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.281212] PGD 1dc1b067 PUD 1e0f7067 PMD 0
[ 56.282085] Oops: 0002 [#1] SMP
[ 56.282744] Modules linked in:
[ 56.283512] CPU 1
[ 56.283512] Pid: 25, comm: khubd Not tainted 3.7.1 #1 innotek GmbH VirtualBox/VirtualBox
[ 56.283512] RIP: 0010:[<ffffffff8144e62a>] [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.283512] RSP: 0018:ffff88001fa99ab0 EFLAGS: 00010046
[ 56.283512] RAX: 0000000000000046 RBX: 00000000000001c8 RCX: 0000000000640064
[ 56.283512] RDX: 0000000000010000 RSI: ffff88001fa99b20 RDI: 00000000000001c8
[ 56.283512] RBP: ffff88001fa99b20 R08: 0000000000000000 R09: 0000000000000000
[ 56.283512] R10: 0000000000000000 R11: ffffffff812fcb4c R12: ffff88001ddf53c0
[ 56.283512] R13: 0000000000000000 R14: 00000000000001c8 R15: ffff88001e19b9f4
[ 56.283512] FS: 0000000000000000(0000) GS:ffff88001fd00000(0000) knlGS:0000000000000000
[ 56.283512] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 56.283512] CR2: 00000000000001c8 CR3: 000000001dc51000 CR4: 00000000000006e0
[ 56.283512] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 56.283512] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 56.283512] Process khubd (pid: 25, threadinfo ffff88001fa98000, task ffff88001fa94f80)
[ 56.283512] Stack:
[ 56.283512] 0000000000000046 00000000000001c8 ffffffff810578ec ffffffff812fcb4c
[ 56.283512] ffff88001e19b980 0000000000002710 ffffffff812ffe81 0000000000000001
[ 56.283512] ffff88001fa94f80 0000000000000202 ffffffff00000001 0000000000000296
[ 56.283512] Call Trace:
[ 56.283512] [<ffffffff810578ec>] ? add_wait_queue+0x12/0x3c
[ 56.283512] [<ffffffff812fcb4c>] ? usb_serial_port_work+0x28/0x28
[ 56.283512] [<ffffffff812ffe81>] ? chase_port+0x84/0x2d6
[ 56.283512] [<ffffffff81063f27>] ? try_to_wake_up+0x199/0x199
[ 56.283512] [<ffffffff81263a5c>] ? tty_ldisc_hangup+0x222/0x298
[ 56.283512] [<ffffffff81300171>] ? edge_close+0x64/0x129
[ 56.283512] [<ffffffff810612f7>] ? __wake_up+0x35/0x46
[ 56.283512] [<ffffffff8106135b>] ? should_resched+0x5/0x23
[ 56.283512] [<ffffffff81264916>] ? tty_port_shutdown+0x39/0x44
[ 56.283512] [<ffffffff8125d38c>] ? __tty_hangup+0x307/0x351
[ 56.283512] [<ffffffff812e6ddc>] ? usb_hcd_flush_endpoint+0xde/0xed
[ 56.283512] [<ffffffff8144e625>] ? _raw_spin_lock_irqsave+0x14/0x35
[ 56.283512] [<ffffffff812fd361>] ? usb_serial_disconnect+0x57/0xc2
[ 56.283512] [<ffffffff812ea99b>] ? usb_unbind_interface+0x5c/0x131
[ 56.283512] [<ffffffff8128d738>] ? __device_release_driver+0x7f/0xd5
[ 56.283512] [<ffffffff8128d9cd>] ? device_release_driver+0x1a/0x25
[ 56.283512] [<ffffffff8128d393>] ? bus_remove_device+0xd2/0xe7
[ 56.283512] [<ffffffff8128b7a3>] ? device_del+0x119/0x167
[ 56.283512] [<ffffffff812e8d9d>] ? usb_disable_device+0x6a/0x180
[ 56.283512] [<ffffffff812e2ae0>] ? usb_disconnect+0x81/0xe6
[ 56.283512] [<ffffffff812e4435>] ? hub_thread+0x577/0xe82
[ 56.283512] [<ffffffff8144daa7>] ? __schedule+0x490/0x4be
[ 56.283512] [<ffffffff8105798f>] ? abort_exclusive_wait+0x79/0x79
[ 56.283512] [<ffffffff812e3ebe>] ? usb_remote_wakeup+0x2f/0x2f
[ 56.283512] [<ffffffff810570b4>] ? kthread+0x81/0x89
[ 56.283512] [<ffffffff81057033>] ? __kthread_parkme+0x5c/0x5c
[ 56.283512] [<ffffffff8145387c>] ? ret_from_fork+0x7c/0xb0
[ 56.283512] Code: 8b 7c 24 08 e8 17 0b c3 ff 48 8b 04 24 48 83 c4 10 c3 53 48 89 fb 41 50 e8 e0 0a c3 ff 48 89 04 24 e8 e7 0a c3 ff ba 00 00 01 00
<f0> 0f c1 13 48 8b 04 24 89 d1 c1 ea 10 66 39 d1 74 07 f3 90 66
[ 56.283512] RIP [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.283512] RSP <ffff88001fa99ab0>
[ 56.283512] ---[ end trace 49714df27e1679ce ]---
Signed-off-by: Wolfgang Frisch <wfpub@roembden.net>
Cc: Johan Hovold <jhovold@gmail.com>
commit 09fb8bd1a63b0f9f15e655c4fe8d047e5d2bf67a upstream.
Newer asics have variable numbers of crtcs. Use that
rather than the asic family to determine which crtcs
to check. This avoids checking non-existent crtcs or
missing crtcs on certain asics.
commit cea4dcfdad926a27a18e188720efe0f2c9403456 upstream.
If a key was larger than 64 bytes, as checked by iscsi_check_key(), the
error response packet, generated by iscsi_add_notunderstood_response(),
would still attempt to copy the entire key into the packet, overflowing
the structure on the heap.
Remote preauthentication kernel memory corruption was possible if a
target was configured and listening on the network.
CVE-2013-2850
commit dfd20b2b174d3a9b258ea3b7a35ead33576587b1 upstream.
The index on the page must be set before it is inserted in the radix
tree. Otherwise there is a small race which can occur during lookup
where the page can be found with the incorrect index. This will trigger
the BUG_ON() in brd_lookup_page().
Signed-off-by: Brian Behlendorf <behlendorf1@llnl.gov>
Reported-by: Chris Wedgwood <cw@f00f.org>
commit 4b949b8af12e24b8a48fa5bb775a13b558d9f4da upstream.
During the development of this driver an in-house register documentation
was used. The last week some integration tests were done and this
problem was found. It turned out that the released register
documentation is wrong.
The fix is very simple: shift all masks by one.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Bryan Wu <cooloney@gmail.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 997ff893603c6455da4c5e26ba1d0f81adfecdfc upstream.
HP's virtual UHCI host controller takes a long time to suspend
(several hundred microseconds), even when no devices are attached.
This provokes a warning message from uhci-hcd in the auto-stop case.
To prevent this from happening, this patch adds a test to avoid
performing an auto-stop when the wait_for_hp quirk flag is set. The
controller will still suspend through the normal runtime PM mechanism.
And since that pathway includes a 1-ms delay, the slowness of the
virtual hardware won't matter.
Reported-and-tested-by: ZhenHua <zhen-hual@hp.com>
commit e4f47e3675e6f1f40906b785b934ce963e9f2eb3 upstream.
This patch shortens the logic in xhci_endpoint_init() by moving common
calculations involving max_packet and max_burst outside the switch
statement, rather than repeating the same code in multiple
case-specific statements. It also replaces two usages of max_packet
which were clearly intended to be max_burst all along.
More importantly, it compensates for a common bug in high-speed bulk
endpoint descriptors. In many devices there is a bulk endpoint having
a wMaxPacketSize value smaller than 512, which is forbidden by the USB
spec. Some xHCI controllers can't handle this and refuse to accept
the endpoint. This patch changes the max_packet value to 512, which
allows the controller to use the endpoint properly.
In practice the bogus maxpacket size doesn't matter, because none of
the transfers sent via these endpoints are longer than the maxpacket
value anyway.
Reported-and-tested-by: "Aurélien Leblond" <blablack@gmail.com>
commit bac6b03275184c912ad0818c9a0a736847804dca upstream.
Werner Fink has reported problems with this hub.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
