To be consistent with other Broadcom drivers, the Broadcom Capri pinctrl
driver and its related CONFIG option are renamed to bcm281xx.
Devicetree compatible string and binding documentation use
"brcm,bcm11351-pinctrl" to match the machine binding here:
Documentation/devicetree/bindings/arm/bcm/bcm11351.txt
This driver supports pinctrl on BCM11130, BCM11140, BCM11351, BCM28145
and BCM28155 SoCs.
Signed-off-by: Sherman Yin <syin@broadcom.com>
Reviewed-by: Matt Porter <mporter@linaro.org>
Acking interrupts are done differently between on v2 and v3, so add an extra
attribute to the pingroup struct to let the platform definitions control this.
Also make sure to start dual edge detection by detecting the rising edge.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
I left this in by mistake, get rid of it.
The first half of pinbank 0 only has one muxing function (as gpios) and
does not have a special mux-register.
Therefore ensure that no other mux function can be selected and also do not
write to a non-existent register.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
In a following change, rockchip_set_mux gets the possibility to fail.
Therefore add a return value to it and honor error codes in functions
using rockchip_set_mux.
The correct value of .mux_offset for rk3188 seems to be 0x60
instead of 0x68.
Heiko adds:
GPIO0 only has the second two IOMUX registers:
- GRF_GPIO0C_IOMUX at 0x68
- GRF_GPIO0D_IOMUX at 0x6c
which I guess is where my mistake comes from.
It looks like there does no iomux register exist at all
for the first 16 pins.
In any case, the current number is wrong, and the 0x60
offset is the correct one, but I guess we need to
determine what the affected pins do - do they always have a
gpio mux or such?
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
This patch fixes I/O errors with the sym53c8xx_2 driver when the disk
returns QUEUE FULL status.
When the controller encounters an error (including QUEUE FULL or BUSY
status), it aborts all not yet submitted requests in the function
sym_dequeue_from_squeue.
This function aborts them with DID_SOFT_ERROR.
If the disk has full tag queue, the request that caused the overflow is
aborted with QUEUE FULL status (and the scsi midlayer properly retries
it until it is accepted by the disk), but the sym53c8xx_2 driver aborts
the following requests with DID_SOFT_ERROR --- for them, the midlayer
does just a few retries and then signals the error up to sd.
The result is that disk returning QUEUE FULL causes request failures.
The error was reproduced on 53c895 with COMPAQ BD03685A24 disk
(rebranded ST336607LC) with command queue 48 or 64 tags. The disk has
64 tags, but under some access patterns it return QUEUE FULL when there
are less than 64 pending tags. The SCSI specification allows returning
QUEUE FULL anytime and it is up to the host to retry.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: James Bottomley <JBottomley@Parallels.com>
Pull yet more networking updates from David Miller:
1) Various fixes to the new Redpine Signals wireless driver, from
Fariya Fatima.
2) L2TP PPP connect code takes PMTU from the wrong socket, fix from
Dmitry Petukhov.
3) UFO and TSO packets differ in whether they include the protocol
header in gso_size, account for that in skb_gso_transport_seglen().
From Florian Westphal.
4) If VLAN untagging fails, we double free the SKB in the bridging
output path. From Toshiaki Makita.
5) Several call sites of sk->sk_data_ready() were referencing an SKB
just added to the socket receive queue in order to calculate the
second argument via skb->len. This is dangerous because the moment
the skb is added to the receive queue it can be consumed in another
context and freed up.
It turns out also that none of the sk->sk_data_ready()
implementations even care about this second argument.
So just kill it off and thus fix all these use-after-free bugs as a
side effect.
6) Fix inverted test in tcp_v6_send_response(), from Lorenzo Colitti.
7) pktgen needs to do locking properly for LLTX devices, from Daniel
Borkmann.
8) xen-netfront driver initializes TX array entries in RX loop :-) From
Vincenzo Maffione.
9) After refactoring, some tunnel drivers allow a tunnel to be
configured on top itself. Fix from Nicolas Dichtel.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits)
vti: don't allow to add the same tunnel twice
gre: don't allow to add the same tunnel twice
drivers: net: xen-netfront: fix array initialization bug
pktgen: be friendly to LLTX devices
r8152: check RTL8152_UNPLUG
net: sun4i-emac: add promiscuous support
net/apne: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
net: ipv6: Fix oif in TCP SYN+ACK route lookup.
drivers: net: cpsw: enable interrupts after napi enable and clearing previous interrupts
drivers: net: cpsw: discard all packets received when interface is down
net: Fix use after free by removing length arg from sk_data_ready callbacks.
Drivers: net: hyperv: Address UDP checksum issues
Drivers: net: hyperv: Negotiate suitable ndis version for offload support
Drivers: net: hyperv: Allocate memory for all possible per-pecket information
bridge: Fix double free and memory leak around br_allowed_ingress
bonding: Remove debug_fs files when module init fails
i40evf: program RSS LUT correctly
i40evf: remove open-coded skb_cow_head
ixgb: remove open-coded skb_cow_head
igbvf: remove open-coded skb_cow_head
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc
Pull remoteproc cleanups from Ohad Ben-Cohen:
"Several remoteproc cleanup patches coming from Jingoo Han, Julia
Lawall and Uwe Kleine-König"
* tag 'remoteproc-3.15-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc:
remoteproc/ste_modem: staticize local symbols
remoteproc/davinci: simplify use of devm_ioremap_resource
remoteproc/davinci: drop needless devm_clk_put
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the target pending updates for v3.15-rc1. Apologies in
advance for waiting until the second to last day of the merge window
to send these out.
The highlights this round include:
- iser-target support for T10 PI (DIF) offloads (Sagi + Or)
- Fix Task Aborted Status (TAS) handling in target-core (Alex Leung)
- Pass in transport supported PI at session initialization (Sagi + MKP + nab)
- Add WRITE_INSERT + READ_STRIP T10 PI support in target-core (nab + Sagi)
- Fix iscsi-target ERL=2 ASYNC_EVENT connection pointer bug (nab)
- Fix tcm_fc use-after-free of ft_tpg (Andy Grover)
- Use correct ib_sg_dma primitives in ib_isert (Mike Marciniszyn)
Also, note the virtio-scsi + vhost-scsi changes to expose T10 PI
metadata into KVM guest have been left-out for now, as there where a
few comments from MST + Paolo that where not able to be addressed in
time for v3.15. Please expect this feature for v3.16-rc1"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (43 commits)
ib_srpt: Use correct ib_sg_dma primitives
target/tcm_fc: Rename ft_tport_create to ft_tport_get
target/tcm_fc: Rename ft_{add,del}_lport to {add,del}_wwn
target/tcm_fc: Rename structs and list members for clarity
target/tcm_fc: Limit to 1 TPG per wwn
target/tcm_fc: Don't export ft_lport_list
target/tcm_fc: Fix use-after-free of ft_tpg
target: Add check to prevent Abort Task from aborting itself
target: Enable READ_STRIP emulation in target_complete_ok_work
target/sbc: Add sbc_dif_read_strip software emulation
target: Enable WRITE_INSERT emulation in target_execute_cmd
target/sbc: Add sbc_dif_generate software emulation
target/sbc: Only expose PI read_cap16 bits when supported by fabric
target/spc: Only expose PI mode page bits when supported by fabric
target/spc: Only expose PI inquiry bits when supported by fabric
target: Pass in transport supported PI at session initialization
target/iblock: Fix double bioset_integrity_free bug
Target/sbc: Initialize COMPARE_AND_WRITE write_sg scatterlist
target/rd: T10-Dif: RAM disk is allocating more space than required.
iscsi-target: Fix ERL=2 ASYNC_EVENT connection pointer bug
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"A series of bug fix patches for v3.15-rc1. Most are just driver
fixes. There are some changes at remote controller core level, fixing
some definitions on a new API added for Kernel v3.15.
It also adds the missing include at include/uapi/linux/v4l2-common.h,
to allow its compilation on userspace, as pointed by you"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (24 commits)
[media] gpsca: remove the risk of a division by zero
[media] stk1160: warrant a NUL terminated string
[media] v4l: ti-vpe: retain v4l2_buffer flags for captured buffers
[media] v4l: ti-vpe: Set correct field parameter for output and capture buffers
[media] v4l: ti-vpe: zero out reserved fields in try_fmt
[media] v4l: ti-vpe: Fix initial configuration queue data
[media] v4l: ti-vpe: Use correct bus_info name for the device in querycap
[media] v4l: ti-vpe: report correct capabilities in querycap
[media] v4l: ti-vpe: Allow usage of smaller images
[media] v4l: ti-vpe: Use video_device_release_empty
[media] v4l: ti-vpe: Make sure in job_ready that we have the needed number of dst_bufs
[media] lgdt3305: include sleep functionality in lgdt3304_ops
[media] drx-j: use customise option correctly
[media] m88rs2000: fix sparse static warnings
[media] r820t: fix size and init values
[media] rc-core: remove generic scancode filter
[media] rc-core: split dev->s_filter
[media] rc-core: do not change 32bit NEC scancode format for now
[media] rtl28xxu: remove duplicate ID 0458:707f Genius TVGo DVB-T03
[media] xc2028: add missing break to switch
Pull PCIe non-transparent bridge fixes and features from Jon Mason:
"NTB driver bug fixes to address issues in list traversal, skb leak in
ntb_netdev, a typo, and a leak of msix entries in the error path.
Clean ups of the event handling logic, as well as a overall style
cleanup. Finally, the driver was converted to use the new
pci_enable_msix_range logic (and the refactoring to go along with it)"
* tag 'ntb-3.15' of git://github.com/jonmason/ntb:
ntb: Use pci_enable_msix_range() instead of pci_enable_msix()
ntb: Split ntb_setup_msix() into separate BWD/SNB routines
ntb: Use pci_msix_vec_count() to obtain number of MSI-Xs
NTB: Code Style Clean-up
NTB: client event cleanup
ntb: Fix leakage of ntb_device::msix_entries[] array
NTB: Fix typo in setting one translation register
ntb_netdev: Fix skb free issue in open
ntb_netdev: Fix list_for_each_entry exit issue
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
This patch fixes the initialization of an array used in the TX
datapath that was mistakenly initialized together with the
RX datapath arrays. An out of range array access could happen
when RX and TX rings had different sizes.
Signed-off-by: Vincenzo Maffione <v.maffione@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net
Jeff Kirsher says:
Intel Wired LAN Driver Updates
This series contains updates to e1000, e1000e, igb, igbvf, ixgb, ixgbe,
ixgbevf and i40evf.
Mark fixes an issue with ixgbe and ixgbevf by adding a bit to indicate
when workqueues have been initialized. This permits the register read
error handling from attempting to use them prior to that, which also
generates warnings. Checking for a detected removal after initializing
the work queues allows the probe function to return an error without
getting the workqueue involved. Further, if the error_detected
callback is entered before the workqueues are initialized, exit without
recovery since the device initialization was so truncated.
Francois Romieu provides several patches to all the drivers to remove
the open coded skb_cow_head.
Jakub Kicinski provides a fix for igb where last_rx_timestamp should be
updated only when Rx time stamp is read.
Mitch provides a fix for i40evf where a recent change broke the RSS LUT
programming causing it to be programmed with all 0's.
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
When the device is unplugged, the driver would try to disable the
device. Add checking the flag of RTL8152_UNPLUG to skip setting
the device when it is unplugged. This could shorten the time of
unloading the driver.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
The sun4i-emac driver is rather primitive, and doesn't support
promiscuous mode. This makes usage such as bridging impossible,
which is a shame on virtualization capable HW such as the
Allwinner A20.
The fix is fairly simple: move the RX setup code to the ndo_set_rx_mode
vector, and add the required HW configuration when IFF_PROMISC is passed
by the core code.
This has been tested on a generic A20 box running a few virtual
machines hanging off a bridge with the EMAC chip as the link to the
outside world.
Cc: Stefan Roese <sr@denx.de>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
This patch fixes coccinelle error regarding usage of IS_ERR and
PTR_ERR instead of PTR_ERR_OR_ZERO.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci
Pull async SCSI resume support from Dan Williams:
"Allow disks and other devices to resume in parallel.
This provides a tangible speed up for a non-esoteric use case (laptop
resume):
https://01.org/suspendresume/blogs/tebrandt/2013/hard-disk-resume-optimization-simpler-approach"
* 'async-scsi-resume' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci:
scsi: async sd resume
Pull md updates from Neil Brown:
"Just a few md patches for the 3.15 merge window.
Not much happening in md/raid at the moment. Just a few bug fixes
(one for -stable) and a couple of performance tweaks"
* tag 'md/3.15' of git://neil.brown.name/md:
raid5: get_active_stripe avoids device_lock
raid5: make_request does less prepare wait
md: avoid oops on unload if some process is in poll or select.
md/raid1: r1buf_pool_alloc: free allocate pages when subsequent allocation fails.
md/bitmap: don't abuse i_writecount for bitmap files.
Pull NVMe driver updates from Matthew Wilcox:
"Various updates to the NVMe driver. The most user-visible change is
that drive hotplugging now works and CPU hotplug while an NVMe drive
is installed should also work better"
* git://git.infradead.org/users/willy/linux-nvme:
NVMe: Retry failed commands with non-fatal errors
NVMe: Add getgeo to block ops
NVMe: Start-stop nvme_thread during device add-remove.
NVMe: Make I/O timeout a module parameter
NVMe: CPU hot plug notification
NVMe: per-cpu io queues
NVMe: Replace DEFINE_PCI_DEVICE_TABLE
NVMe: Fix divide-by-zero in nvme_trans_io_get_num_cmds
NVMe: IOCTL path RCU protect queue access
NVMe: RCU protected access to io queues
NVMe: Initialize device reference count earlier
NVMe: Add CONFIG_PM_SLEEP to suspend/resume functions
The code was incorrectly using sg_dma_address() and
sg_dma_len() instead of ib_sg_dma_address() and
ib_sg_dma_len().
This prevents srpt from functioning with the
Intel HCA and indeed will corrupt memory
badly.
Cc: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Tested-by: Vinod Kumar <vinod.kumar@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Cc: stable@vger.kernel.org # 3.3+
Because it doesn't always create, if there's an existing one it just
returns it.
Signed-off-by: Andy Grover <agrover@redhat.com>
These functions are not adding or deleting an lport. They are adding a
wwn that may match with an lport that is present on the system.
Renaming ft_del_lport also means we won't have functions named
both ft_del_lport and ft_lport_del any more.
Rename struct ft_lport_acl to ft_lport_wwn. "acl" is associated with
something different in LIO terms. Really, ft_lport_wwn is the
fabric-specific wrapper for the struct se_wwn.
Rename "lacl" local variables to "ft_wwn" as well.
Rename list_heads used as list members to make it clear they're nodes, not
heads.
Rename lport_node to ft_wwn_node.
Rename ft_lport_list to ft_wwn_list
tcm_fc doesn't support multiple TPGs per wwn. For proof, see
ft_lport_find_tpg. Enforce this in the code.
Replace ft_lport_wwn.tpg_list with a single pointer. We can't fold ft_tpg
into ft_lport_wwn because they can have different lifetimes.
Nobody outside tfc_conf.c uses it.
ft_del_tpg checks tpg->tport is set before unlinking the tpg from the
tport when the tpg is being removed. Set this pointer in ft_tport_create,
or the unlinking won't happen in ft_del_tpg and tport->tpg will reference
a deleted object.
This patch sets tpg->tport in ft_tport_create, because that's what
ft_del_tpg checks, and is the only way to get back to the tport to
clear tport->tpg.
The bug was occuring when:
- lport created, tport (our per-lport, per-provider context) is
allocated.
tport->tpg = NULL
- tpg created
- a PRLI is received. ft_tport_create is called, tpg is found and
tport->tpg is set
- tpg removed. ft_tpg is freed in ft_del_tpg. Since tpg->tport was not
set, tport->tpg is not cleared and points at freed memory
- Future calls to ft_tport_create return tport via first conditional,
instead of searching for new tpg by calling ft_lport_find_tpg.
tport->tpg is still invalid, and will access freed memory.
see https://bugzilla.redhat.com/show_bug.cgi?id=1071340
Cc: stable@vger.kernel.org # 3.0+
This patch addresses an issue that occurs when an ABTS is received
for an se_cmd that completes just before the sess_cmd_list is searched
in core_tmr_abort_task(). When the sess_cmd_list is searched, since
the ABTS and the FCP_CMND being aborted (that just completed) both
have the same OXID, TFO->get_task_tag(TMR) returns a value that
matches tmr->ref_task_tag (from TFO->get_task_tag(FCP_CMND)), and
the Abort Task tries to abort itself. When this occurs,
transport_wait_for_tasks() hangs forever since the TMR is waiting
for itself to finish.
This patch adds a check to core_tmr_abort_task() to make sure the
TMR does not attempt to abort itself.
Signed-off-by: Alex Leung <alex.leung@emulex.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi fixes from Mark Brown:
"A few driver specific fixes, the main one being the fix for handling
of complete callbacks that are open coded in individual drivers to
allow callers to omit the completion. As we move things into the core
that sort of issue should become less and less common"
* tag 'spi-v3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: qup: Depend on ARCH_QCOM
spi: efm32: Update binding document to make "efm32,location" property optional
spi: omap2-mcspi: Convert to use devm_kcalloc
spi: Always check complete callback before calling it
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
Please pull this batch of fixes intended for the 3.15 stream!
Chun-Yeow Yeoh gives us an ath9k_htc fix so that mac80211 can report
last_tx_rate correctly for those devices..
Fariya Fatima has a number of small fixes for things identified by
the static analysis folks in the new rsi driver.
Felix Fietkau brings an ath9k fix to better support some older chips,
and a fix for a scheduling while atomic bug introduced by an earlier
patch.
Janusz Dziedzic produced an ath9k fix to only enable DFS when a
related build option is selected.
Paul Bolle removes some dead code in rtlwifi.
Rafał Miłecki fixes some b43 code that was accessing some registers
with operations for the wrong register width.
Please let me know if there are problems!
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"A few driver specific fixes that have come in over the merge window,
all only relevant for the specific driver"
* tag 'regulator-v3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: bcm590xx: Set n_voltages for linear reg
regulator: s5m8767: Fix carried over ena_gpio assignment
regulator: s2mps11: Don't check enable_shift before setting enable ramp rate
regulator: s2mpa01: Don't check enable_shift before setting enable ramp rate
previous interrupts
When the Ethernet interface is put down and up with heavy Ethernet
traffic, then there is prossibility of an interrupt waiting in irq
controller to be processed, so when the interface is brought up again
just after enable interrupt, it goes to ISR due to the previous
unhandled interrutp and in ISR napi is not scheduled as the napi
is not enabled in ndo_open which results in disabled interrupt for
CPSW and no packets are received in cpsw. So this patch moves enabling
of interupts after napi_enable and clearing CPDMA interrupts.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
When the Ethernet interface is brought down during high Ethernet traffic,
then cpsw creates the following warn dump. When cpdma has already processed
the packet then the status will be greater than 0, so the cpsw_rx_handler
considers that the interface is up and try to resubmit one more rx buffer
to cpdma which fails as the DMA is in teardown process. This can be avoided
by checking the interface state and then process the received packet, if the
interface is down just discard and free the skb and return.
[ 2823.104591] WARNING: CPU: 0 PID: 1823 at drivers/net/ethernet/ti/cpsw.c:711 cpsw_rx_handler+0x148/0x164()
[ 2823.114654] Modules linked in:
[ 2823.117872] CPU: 0 PID: 1823 Comm: ifconfig Tainted: G W 3.14.0-11992-gf34c4a3 #11
[ 2823.126860] [<c0014b5c>] (unwind_backtrace) from [<c00117e4>] (show_stack+0x10/0x14)
[ 2823.135030] [<c00117e4>] (show_stack) from [<c0533a9c>] (dump_stack+0x80/0x9c)
[ 2823.142619] [<c0533a9c>] (dump_stack) from [<c003f0e0>] (warn_slowpath_common+0x6c/0x90)
[ 2823.151141] [<c003f0e0>] (warn_slowpath_common) from [<c003f120>] (warn_slowpath_null+0x1c/0x24)
[ 2823.160336] [<c003f120>] (warn_slowpath_null) from [<c03caeb0>] (cpsw_rx_handler+0x148/0x164)
[ 2823.169314] [<c03caeb0>] (cpsw_rx_handler) from [<c03c730c>] (__cpdma_chan_free+0x90/0xa8)
[ 2823.178028] [<c03c730c>] (__cpdma_chan_free) from [<c03c7418>] (__cpdma_chan_process+0xf4/0x134)
[ 2823.187279] [<c03c7418>] (__cpdma_chan_process) from [<c03c7560>] (cpdma_chan_stop+0xb4/0x17c)
[ 2823.196349] [<c03c7560>] (cpdma_chan_stop) from [<c03c766c>] (cpdma_ctlr_stop+0x44/0x9c)
[ 2823.204872] [<c03c766c>] (cpdma_ctlr_stop) from [<c03cb708>] (cpsw_ndo_stop+0x154/0x188)
[ 2823.213321] [<c03cb708>] (cpsw_ndo_stop) from [<c046f0ec>] (__dev_close_many+0x84/0xc8)
[ 2823.221761] [<c046f0ec>] (__dev_close_many) from [<c046f158>] (__dev_close+0x28/0x3c)
[ 2823.230012] [<c046f158>] (__dev_close) from [<c0474ca8>] (__dev_change_flags+0x88/0x160)
[ 2823.238483] [<c0474ca8>] (__dev_change_flags) from [<c0474da0>] (dev_change_flags+0x18/0x48)
[ 2823.247316] [<c0474da0>] (dev_change_flags) from [<c04d12c4>] (devinet_ioctl+0x61c/0x6e0)
[ 2823.255884] [<c04d12c4>] (devinet_ioctl) from [<c045c660>] (sock_ioctl+0x68/0x2a4)
[ 2823.263789] [<c045c660>] (sock_ioctl) from [<c0125fe4>] (do_vfs_ioctl+0x78/0x61c)
[ 2823.271629] [<c0125fe4>] (do_vfs_ioctl) from [<c01265ec>] (SyS_ioctl+0x64/0x74)
[ 2823.279284] [<c01265ec>] (SyS_ioctl) from [<c000e580>] (ret_fast_syscall+0x0/0x48)
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap fix from Mark Brown:
"regmap: Fix for nodev mode
Add mising braces so that the nodev mode actually works (which was a
bit of an oversight)"
Testing schmesting. We don't need not steenking testing. We have
deadlines to beat, and new code to write.
* tag 'regmap-v3.15-nodev' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: adds missing braces in regmap_init()
Pull more ACPI and power management fixes and updates from Rafael Wysocki:
"This is PM and ACPI material that has emerged over the last two weeks
and one fix for a CPU hotplug regression introduced by the recent CPU
hotplug notifiers registration series.
Included are intel_idle and turbostat updates from Len Brown (these
have been in linux-next for quite some time), a new cpufreq driver for
powernv (that might spend some more time in linux-next, but BenH was
asking me so nicely to push it for 3.15 that I couldn't resist), some
cpufreq fixes and cleanups (including fixes for some silly breakage in
a couple of cpufreq drivers introduced during the 3.14 cycle),
assorted ACPI cleanups, wakeup framework documentation fixes, a new
sysfs attribute for cpuidle and a new command line argument for power
domains diagnostics.
Specifics:
- Fix for a recently introduced CPU hotplug regression in ARM KVM
from Ming Lei.
- Fixes for breakage in the at32ap, loongson2_cpufreq, and unicore32
cpufreq drivers introduced during the 3.14 cycle (-stable material)
from Chen Gang and Viresh Kumar.
- New powernv cpufreq driver from Vaidyanathan Srinivasan, with bits
from Gautham R Shenoy and Srivatsa S Bhat.
- Exynos cpufreq driver fix preventing it from being included into
multiplatform builds that aren't supported by it from Sachin Kamat.
- cpufreq cleanups related to the usage of the driver_data field in
struct cpufreq_frequency_table from Viresh Kumar.
- cpufreq ppc driver cleanup from Sachin Kamat.
- Intel BayTrail support for intel_idle and ACPI idle from Len Brown.
- Intel CPU model 54 (Atom N2000 series) support for intel_idle from
Jan Kiszka.
- intel_idle fix for Intel Ivy Town residency targets from Len Brown.
- turbostat updates (Intel Broadwell support and output cleanups)
from Len Brown.
- New cpuidle sysfs attribute for exporting C-states' target
residency information to user space from Daniel Lezcano.
- New kernel command line argument to prevent power domains enabled
by the bootloader from being turned off even if they are not in use
(for diagnostics purposes) from Tushar Behera.
- Fixes for wakeup sysfs attributes documentation from Geert
Uytterhoeven.
- New ACPI video blacklist entry for ThinkPad Helix from Stephen
Chandler Paul.
- Assorted ACPI cleanups and a Kconfig help update from Jonghwan
Choi, Zhihui Zhang, Hanjun Guo"
* tag 'pm+acpi-3.15-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits)
ACPI: Update the ACPI spec information in Kconfig
arm, kvm: fix double lock on cpu_add_remove_lock
cpuidle: sysfs: Export target residency information
cpufreq: ppc: Remove duplicate inclusion of fsl_soc.h
cpufreq: create another field .flags in cpufreq_frequency_table
cpufreq: use kzalloc() to allocate memory for cpufreq_frequency_table
cpufreq: don't print value of .driver_data from core
cpufreq: ia64: don't set .driver_data to index
cpufreq: powernv: Select CPUFreq related Kconfig options for powernv
cpufreq: powernv: Use cpufreq_frequency_table.driver_data to store pstate ids
cpufreq: powernv: cpufreq driver for powernv platform
cpufreq: at32ap: don't declare local variable as static
cpufreq: loongson2_cpufreq: don't declare local variable as static
cpufreq: unicore32: fix typo issue for 'clk'
cpufreq: exynos: Disable on multiplatform build
PM / wakeup: Correct presence vs. emptiness of wakeup_* attributes
PM / domains: Add pd_ignore_unused to keep power domains enabled
ACPI / dock: Drop dock_device_ids[] table
ACPI / video: Favor native backlight interface for ThinkPad Helix
ACPI / thermal: Fix wrong variable usage in debug statement
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
ws2008r2 does not support UDP checksum offload. Thus, we cannnot turn on
UDP offload in the host. Also, on ws2012 and ws2012 r2, there appear to be
an issue with UDP checksum offload.
Fix this issue by computing the UDP checksum in the Hyper-V driver.
Based on Dave Miller's comments, in this version, I have COWed the skb
before modifying the UDP header (the checksum field).
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
Ws2008R2 supports ndis_version 6.1 and 6.1 is the minimal version required
for various offloads. Negotiate ndis_version 6.1 when on ws2008r2.
An outgoing packet can potentially need per-packet information for
all the offloads and VLAN tagging. Fix this issue.
Remove the bonding debug_fs entries when the
module initialization fails. The debug_fs
entries should be removed together with all other
already allocated resources.
Signed-off-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
Signed-off-by: Jay Vosburgh <j.vosburgh@gmail.com>
Pull x86 fixes from Peter Anvin:
"This is a collection of minor fixes for x86, plus the IRET information
leak fix (forbid the use of 16-bit segments in 64-bit mode)"
NOTE! We may have to relax the "forbid the use of 16-bit segments in
64-bit mode" part, since there may be people who still run and depend on
16-bit Windows binaries under Wine.
But I'm taking this in the current unconditional form for now to see who
(if anybody) screams bloody murder. Maybe nobody cares. And maybe
we'll have to update it with some kind of runtime enablement (like our
vm.mmap_min_addr tunable that people who run dosemu/qemu/wine already
need to tweak).
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
efi: Pass correct file handle to efi_file_{read,close}
x86/efi: Correct EFI boot stub use of code32_start
x86/efi: Fix boot failure with EFI stub
x86/platform/hyperv: Handle VMBUS driver being a module
x86/apic: Reinstate error IRQ Pentium erratum 3AP workaround
x86, CMCI: Add proper detection of end of CMCI storms
A recent change broke the RSS LUT programming, causing it to be
programmed with all 0. Correct this by actually assigning the
incremented value back to the counter variable so that the increment
will be remembered by the calling function.
While we're at it, add a proper kernel-doc function comment to our
helper function.
Signed-off-by: Mitch Williams <mitch.a.williams@intel.com>
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Jesse Brandeburg <jesse.brandeburg@intel.com>
Tested-by: Sibai Li <sibai.li@intel.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
last_rx_timestamp should be updated only when rx time stamp is
read. Also it's only used with NICs that have per-interface time
stamping resources so it can be moved to adapter structure and
set in igb_ptp_rx_rgtstamp().
Signed-off-by: Jakub Kicinski <kubakici@wp.pl>
Acked-by: Matthew Vick <matthew.vick@intel.com>
