path: root/drivers
2010-04-12MIPS: Fix SSB PCIcore IO resource managementAndreas Ferber
The SSB PCIcore code reused the IO resource fixup code from the original 2.4.x Broadcom patch for BCM47xx based devices, which was a quick hack for doing PCI IO resource configuration back then (the boot loader doesn't configure PCI devices on this platform). However, this code is no longer necessary since the kernel now can do PCI resource management fine all by itself, so remove the old code. When removing the code, it becomes obvious that the mem_offset setting in the PCIcore driver was wrong, however this was masked by the fixup code before, except in a few cases involving yenta_socket. For BCM47xx, the correct offset is 0, and since this is the only device using PCIcore in host mode, the offset can simply be removed unconditionally. Signed-off-by: Andreas Ferber <af@chaos-agency.de> Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Markus Wigge <markus@cultcom.de> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1070/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/mlx4: Check correct variable for allocation failure RDMA/nes: Correct cap.max_inline_data assignment in nes_query_qp() RDMA/cm: Set num_paths when manually assigning path records IB/cm: Fix device_create() return value check
2010-04-09Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] Update default configuration. [S390] nss: add missing .previous statement to asm function [S390] increase default size of vmalloc area [S390] s390: disable change bit override [S390] fix io_return critical section cleanup [S390] sclp_async: potential buffer overflow [S390] arch/s390/kernel: Add missing unlock
2010-04-09Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (34 commits) cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatch loop: Update mtime when writing using aops block: expose the statistics in blkio.time and blkio.sectors for the root cgroup backing-dev: Handle class_create() failure Block: Fix block/elevator.c elevator_get() off-by-one error drbd: lc_element_by_index() never returns NULL cciss: unlock on error path cfq-iosched: Do not merge queues of BE and IDLE classes cfq-iosched: Add additional blktrace log messages in CFQ for easier debugging i2o: Remove the dangerous kobj_to_i2o_device macro block: remove 16 bytes of padding from struct request on 64bits cfq-iosched: fix a kbuild regression block: make CONFIG_BLK_CGROUP visible Remove GENHD_FL_DRIVERFS block: Export max number of segments and max segment size in sysfs block: Finalize conversion of block limits functions block: Fix overrun in lcm() and move it to lib vfs: improve writeback_inodes_wb() paride: fix off-by-one test drbd: fix al-to-on-disk-bitmap for 4k logical_block_size ...
2010-04-09Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (29 commits) drm/nouveau: bail out of auxch transaction if we repeatedly recieve defers drm/nv50: implement gpio set/get routines drm/nv50: parse/use some more de-magiced parts of gpio table entries drm/nouveau: store raw gpio table entry in bios gpio structs drm/nv40: Init some tiling-related PGRAPH state. drm/nv50: Add NVA3 support in ctxprog/ctxvals generator. drm/nv50: another dodgy DP hack drm/nv50: punt hotplug irq handling out to workqueue drm/nv50: preserve an unknown SOR_MODECTRL value for DP encoders drm/nv50: Allow using the NVA3 new compute class. drm/nv50: cleanup properly if PDISPLAY init fails drm/nouveau: fixup the init failure paths some more drm/nv50: fix instmem init on IGPs if stolen mem crosses 4GiB mark drm/nv40: add LVDS table quirk for Dell Latitude D620 drm/nv40: rework lvds table parsing drm/nouveau: detect vram amount once, and save the value drm/nouveau: remove some unused members from drm_nouveau_private drm/nouveau: Make use of TTM busy_placements. drm/nv50: add more 0x100c80 flushy magic drm/nv50: fix fbcon when framebuffer above 4GiB mark ...
2010-04-09Revert "memory-hotplug: add 0x prefix to HEX block_size_bytes"Linus Torvalds
This reverts commit ba168fc37dea145deeb8fa9e7e71c748d2e00d74. It changes user-visible sysfs interfaces, and breaks some existing user space applications which apparently rely on the fact that the output does not contain the "0x" prefix. Requested-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-09Merge branches 'cma', 'misc', 'mlx4' and 'nes' into for-linusRoland Dreier
2010-04-09[S390] sclp_async: potential buffer overflowDan Carpenter
"len" hasn't been properly range checked so we shouldn't use it as an array offset. This can only be written to by root but it would still be annoying to accidentally write more than 3 characters and corrupt your memory. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-04-09Merge remote branch 'nouveau/for-airlied' of ../drm-nouveau-next into drm-linusDave Airlie
* 'nouveau/for-airlied' of ../drm-nouveau-next: (21 commits) drm/nouveau: bail out of auxch transaction if we repeatedly recieve defers drm/nv50: implement gpio set/get routines drm/nv50: parse/use some more de-magiced parts of gpio table entries drm/nouveau: store raw gpio table entry in bios gpio structs drm/nv40: Init some tiling-related PGRAPH state. drm/nv50: Add NVA3 support in ctxprog/ctxvals generator. drm/nv50: another dodgy DP hack drm/nv50: punt hotplug irq handling out to workqueue drm/nv50: preserve an unknown SOR_MODECTRL value for DP encoders drm/nv50: Allow using the NVA3 new compute class. drm/nv50: cleanup properly if PDISPLAY init fails drm/nouveau: fixup the init failure paths some more drm/nv50: fix instmem init on IGPs if stolen mem crosses 4GiB mark drm/nv40: add LVDS table quirk for Dell Latitude D620 drm/nv40: rework lvds table parsing drm/nouveau: detect vram amount once, and save the value drm/nouveau: remove some unused members from drm_nouveau_private drm/nouveau: Make use of TTM busy_placements. drm/nv50: add more 0x100c80 flushy magic drm/nv50: fix fbcon when framebuffer above 4GiB mark ...
2010-04-09drm/nouveau: bail out of auxch transaction if we repeatedly recieve defersBen Skeggs
There's one known case where we never stop recieving DEFER, and loop here forever. Lets not do that.. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: implement gpio set/get routinesBen Skeggs
2010-04-09drm/nv50: parse/use some more de-magiced parts of gpio table entriesBen Skeggs
2010-04-09drm/nouveau: store raw gpio table entry in bios gpio structsBen Skeggs
And use our own version of the GPIO table for the INIT_GPIO opcode. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv40: Init some tiling-related PGRAPH state.Francisco Jerez
Fixes garbled 3D on an nv46 card. Reported-by: Francesco Marella <francesco.marella@gmail.com> Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: Add NVA3 support in ctxprog/ctxvals generator.Marcin Kościelnicki
Signed-off-by: Marcin Kościelnicki <koriakin@0x04.net> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: another dodgy DP hackBen Skeggs
Allows *some* DP cards to keep working in some corner cases that most people shouldn't hit. I hit it all the time with development, so this can stay for now. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: punt hotplug irq handling out to workqueueBen Skeggs
On DP outputs we'll likely end up running vbios init tables here, which may sleep. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: preserve an unknown SOR_MODECTRL value for DP encodersBen Skeggs
This value interacts with some registers we don't currently know how to program properly ourselves. The default of 5 that we were using matches what the VBIOS on early DP cards do, but later ones use 6, which would cause nouveau to program an incorrect mode on these chips. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: Allow using the NVA3 new compute class.Marcin Kościelnicki
2010-04-09drm/nv50: cleanup properly if PDISPLAY init failsBen Skeggs
2010-04-09drm/nouveau: fixup the init failure paths some moreBen Skeggs
2010-04-09drm/nv50: fix instmem init on IGPs if stolen mem crosses 4GiB markBen Skeggs
2010-04-09drm/nv40: add LVDS table quirk for Dell Latitude D620Ben Skeggs
Should fix: https://bugzilla.redhat.com/show_bug.cgi?id=505132 https://bugzilla.redhat.com/show_bug.cgi?id=543091 https://bugzilla.redhat.com/show_bug.cgi?id=530425 https://bugs.edge.launchpad.net/ubuntu/+source/xserver-xorg-video-nouveau/ +bug/539730 Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv40: rework lvds table parsingBen Skeggs
All indications seem to be that the version 0x30 table should be handled the same way as 0x40 (as used on G80), at least for the parts that we currently try use. This commit cleans up the parsing to make it clearer about what we're actually trying to achieve, and unifies the 0x30/0x40 parsing. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nouveau: detect vram amount once, and save the valueBen Skeggs
As opposed to repeatedly reading the amount back from the GPU every time we need to know the VRAM size. We should now fail to load gracefully on detecting no VRAM, rather than something potentially messy happening. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nouveau: remove some unused members from drm_nouveau_privateBen Skeggs
2010-04-09drm/nouveau: Make use of TTM busy_placements.Francisco Jerez
Previously we were filling it the same as "placements", but in some cases there're valid alternatives that we were ignoring completely. Keeping a back-up memory type helps on several low-mem situations. Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: add more 0x100c80 flushy magicBen Skeggs
Fixes the !vbo_fifo path in the 3D driver on certain chipsets. Still not really any good idea of what exactly the magic achieves, but it makes things work. While we're at it, in the PCIEGART path, flush on unbinding also. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: fix fbcon when framebuffer above 4GiB markBen Skeggs
This can't actually happen right now, but lets fix it anyway. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2010-04-09drm/nv50: Fix NEWCTX_DONE flag numberMarcin Kościelnicki
2010-04-08loop: Update mtime when writing using aopsNikanth Karthikesan
Update mtime when writing to backing filesystem using the address space operations write_begin and write_end. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6: ide: Fix IDE taskfile with cfq scheduler ide: Must hold queue lock when requeueing ide: Requeue request after DMA timeout
2010-04-08Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI / PM: Move ACPI video resume to a PM notifier ACPI: Reduce ACPI resource conflict message to KERN_WARNING, printk cleanup ACPI: battery drivers should call power_supply_changed() ACPI: battery: Fix CONFIG_ACPI_SYSFS_POWER=n PNPACPI: truncate _CRS windows with _LEN > _MAX - _MIN + 1 ACPI: Don't send KEY_UNKNOWN for random video notifications ACPI: NUMA: map pxms to low node ids ACPI: use _HID when supplied by root-level devices ACPI / ACPICA: Do not check reference counters in acpi_ev_enable_gpe() ACPI: fixes a false alarm from lockdep ACPI dock: support multiple ACPI dock devices ACPI: EC: Allow multibyte access to EC
2010-04-08hvc_console: Fix race between hvc_close and hvc_removeAnton Blanchard
I don't claim to understand the tty layer, but it seems like hvc_open and hvc_close should be balanced in their kref reference counting. Right now we get a kref every call to hvc_open: if (hp->count++ > 0) { tty_kref_get(tty); <----- here spin_unlock_irqrestore(&hp->lock, flags); hvc_kick(); return 0; } /* else count == 0 */ tty->driver_data = hp; hp->tty = tty_kref_get(tty); <------ or here if hp->count was 0 But hvc_close has: tty_kref_get(tty); if (--hp->count == 0) { ... /* Put the ref obtained in hvc_open() */ tty_kref_put(tty); ... } tty_kref_put(tty); Since the outside kref get/put balance we only do a single kref_put when count reaches 0. The patch below changes things to call tty_kref_put once for every hvc_close call, and with that my machine boots fine. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-04-08virtio: disable multiport console support.Michael S. Tsirkin
Move MULTIPORT feature and related config changes out of exported headers, and disable the feature at runtime. At this point, it seems less risky to keep code around until we can enable it than rip it out completely. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-04-08virtio: console makes incorrect assumption about virtio APIRusty Russell
The get_buf() API sets the second arg to the number of bytes *written* by the other side; in this case it should be zero as these are output buffers. lguest gets this right (obviously kvm's console doesn't), resulting in continual buildup of console writes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Amit Shah <amit.shah@redhat.com>
2010-04-08virtio: console: Fix early_put_chars usageFrançois Diakhaté
Currently early_put_chars is not used by virtio_console because it can only be used once a port has been found, at which point it's too late because it is no longer needed. This patch should fix it. Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-04-07IB/mlx4: Check correct variable for allocation failureDan Carpenter
The intent here is to check the "mfrpl->mapped_page_list" allocation. We checked "mfrpl->ibfrpl.page_list" earlier. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-04-07RDMA/nes: Correct cap.max_inline_data assignment in nes_query_qp()Chien Tung
cap.max_inline_data is incorrectly set in init_attr instead of attr. Set it in attr so subsequent init_attr.cap assignment will get the correct value. Signed-off-by: Chien Tung <chien.tin.tung@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-04-07RDMA/cm: Set num_paths when manually assigning path recordsSean Hefty
When manually assigning the path records to use for a connection, save the number of paths that were set. Otherwise, checks against num_path will show 0, even though path record data is available. This was discovered by manually setting the path records from user space, then querying the kernel to see if the correct path records were assigned, only to discover that the kernel returned 0 path records to the query. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-04-07Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip: x86: Fix double enable_IR_x2apic() call on SMP kernel on !SMP boards x86: Increase CONFIG_NODES_SHIFT max to 10 ibft, x86: Change reserve_ibft_region() to find_ibft_region() x86, hpet: Fix bug in RTC emulation x86, hpet: Erratum workaround for read after write of HPET comparator bootmem, x86: Fix 32bit numa system without RAM on node 0 nobootmem, x86: Fix 32bit numa system without RAM on node 0 x86: Handle overlapping mptables x86: Make e820_remove_range to handle all covered case x86-32, resume: do a global tlb flush in S4 resume
2010-04-07Merge branch 'slabh' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/miscLinus Torvalds
* 'slabh' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc: nodemask: include slab.h from drivers/base/node.c
2010-04-07frv: hide uncached_access() when pgprot_noncached is not #definedDavid Howells
Hide uncached_access() when pgprot_noncached is not #defined. This prevents the following warning: CC drivers/char/mem.o drivers/char/mem.c:229: warning: 'uncached_access' defined but not used Repairs d7d4d849b4e3acc405ec222884936800ffb26d48 ("drivers/char/mem.c: cleanups"). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07rtc-mxc: multiple fixes in rtc-mxc probe methodVladimir Zapolskiy
On exit paths in mxc_rtc_probe() method some resources are not freed correctly. This patch fixes: * unrequested memory region containing imx RTC registers * iounmap() isn't called on exit_free_pdata branch * clock get rate is called for freed clock source * clock isn't disabled on exit_put_clk branch To simplify the fix managed device resources are used. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Daniel Mack <daniel@caiaq.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07/dev/mem: allow rewindingEric Dumazet
commit dcefafb6 ("/dev/mem: dont allow seek to last page") inadvertently disabled rewinding on /dev/mem. This broke x86info for example. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07vfs: rename block_fsync() to blkdev_fsync()Andrew Morton
Requested by hch, for consistency now it is exported. Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Anton Blanchard <anton@samba.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07raw: fsync method is now requiredAnton Blanchard
Commit 148f948ba877f4d3cdef036b1ff6d9f68986706a (vfs: Introduce new helpers for syncing after writing to O_SYNC file or IS_SYNC inode) broke the raw driver. We now call through generic_file_aio_write -> generic_write_sync -> vfs_fsync_range. vfs_fsync_range has: if (!fop || !fop->fsync) { ret = -EINVAL; goto out; } But drivers/char/raw.c doesn't set an fsync method. We have two options: fix it or remove the raw driver completely. I'm happy to do either, the fact this has been broken for so long suggests it is rarely used. The patch below adds an fsync method to the raw driver. My knowledge of the block layer is pretty sketchy so this could do with a once over. If we instead decide to remove the raw driver, this patch might still be useful as a backport to 2.6.33 and 2.6.32. Signed-off-by: Anton Blanchard <anton@samba.org> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <jens.axboe@oracle.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Tested-by: Jeff Moyer <jmoyer@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07mb862xxfb: update Valentin's email addressAlexander Shishkin
Since Valentin's email address @siemens.com is no longer valid, it's time to change it to the one that actually works so that I don't have to manually forward patches against mb862xx to him every time. Signed-off-by: Alexander Shishkin <virtuoso@slind.org> Acked-by: Valentin Sitdikov <v.sitdikov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07mb862xxfb: fix acceleration module licenseRandy Dunlap
mb862xxfb_accel built as a separate module, but it does not have a MODULE_LICENSE, so it taints the kernel. Add a MODULE_LICENSE to it (same as mb862xxfb license). mb862xxfb_accel: module license 'unspecified' taints kernel. Or should mb862xxfb_accel be built into the mb862xxfb binary file instead? Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Alexander Shishkin <virtuoso@slind.org> Cc: Valentin Sitdikov <v.sitdikov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-07devmem: handle class_create() failureAnton Blanchard
I hit this when we had a bug in IDR for a few days. Basically sysfs would fail to create new inodes since it uses an IDR and therefore class_create would fail. While we are unlikely to see this fail we may as well handle it instead of oopsing. Signed-off-by: Anton Blanchard <anton@samba.org> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
