Basically all the nic_init flow should be in the transport layer.
iwl_prepare_card_hw will move to the transport too in a separate patch.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
All the configurations of the HW for AMPDU are now in the transport layer.
For temperature offset calibration, send radio sensor offset in le16 format
Use the valid calibration mask for init calibration
IWL_PHY_CALIBRATE_DIFF_GAIN_CMD is for legacy device, remove it
Set calibration config flag for complete notification
Since iwlagn_setup_deferred_work is always called, fold it into
iwl_setup_deferred_work. BT related works are setup by the new
bt_setup_deferred_work lib_ops.
Signed-off-by: Wey-Yi Guy <wey-yi.guy@intel.com>
Since iwlagn_rx_handler_setup is always called, fold it into
iwl_rx_handler_setup. BT related handlers are setup by the new
bt_rx_handler_setup lib_ops.
kick_nic means to remove the RESET bit from the embedded CPU
Previously, the mesh was running whenever the appropriate hardware
and firmware was present.
Now we only run the mesh when the interface is running.
Also simplifies interface management a little.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Acked-by: Dan Williams <dcbw@redhat.com>
Remove unused blindlist code.
Mark a few items const and static where possible. Involved some
code re-ordering, but no code changes.
Cc: Bing Zhao <bzhao@marvell.com>
Cc: "Luis R. Rodriguez" <lrodriguez@atheros.com>
Cc: ath9k-devel@lists.ath9k.org
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Signed-off-by: Pavel Roskin <proski@gnu.org>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Both ath5k_hw and ath5k_softc represent one instance of the hardware.
This duplication is historical and is not needed anymore.
Keep the name "ath5k_hw" for the merged structure and "ah" for the
variable pointing to it. "ath5k_hw" is shorter than "ath5k_softc", more
descriptive and more widely used.
Put the combined structure to ath5k.h where the old ath5k_softc used to
be. Move some code from base.h to ath5k.h as needed.
Remove memory allocation for struct ath5k_hw and the corresponding error
handling. Merge iobase and ah_iobase fields.
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Some of the newer Broadcom chipsets have longe names like BCM43224,
BCM43225, etc. However Broadcom decided to keep using u16 for storing
them. Use %X or %d depending on chip_id value to avoid BCMA8D8, etc.
Acked-by: Pavel Roskin <proski@gnu.org>
Old masks were causing ugly, delayed lock ups.
Some cards do not use additional 0x30 offset for SPROM location. We do
not know the real condition for it yet, make it BCM4331 specific for
now.
Following operation was incorrectly translated:
radio_read(0x0011) -> 0xffff
radio_write(0x0011) <- 0xfff7
Also change the default channel to 11. This is the first channel closed
driver switches to.
BCMA_IOCTL is register in agent (AKA wrapper) core, we need to use
special R/W ops for it.
drivers/net/wireless/ath/ath9k/hif_usb.c +135 hif_usb_mgmt_cb(6) warn:
variable dereferenced before check 'cmd'
drivers/net/wireless/ath/ath9k/btcoex.c +77 ath9k_hw_init_btcoex_hw(38)
error: buffer overflow 'ah->hw_gen_timers.gen_timer_index' 32 <=
2009813776
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
drivers/net/wireless/ath/ath9k/init.c:199:21: warning: context imbalance
in 'ath9k_reg_rmw' - different lock contexts for basic block
drivers/net/wireless/ath/ath9k/xmit.c:1175:31: warning: context
imbalance in 'ath_drain_txq_list' - unexpected unlock
drivers/net/wireless/ath/ath9k/xmit.c:2047:23: warning: context
imbalance in 'ath_tx_process_buffer' - unexpected unlock
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c:3041:24: warning: cast to
restricted __le32
We use all that functions by pointers only. This forces compiler to
create additional duplicated functions that are not inline.
Noticed by Michael in similar bcma code.
Harshal Chhaya discovered during network tests, that
several of his clients dropped-off the network. The
captured packets shows that the beacons sent by the
AP are at a much lower power than the other data
packets.
The reason for this mishap: The driver never updated
the beacon phy register, so all beacons were always
sent at the lowest power.
Reference: http://marc.info/?l=linux-wireless&m=131067225105801
Reported-by: Harshal Chhaya <harshal@gmail.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
* reserves feature bit for CCA counters
* extends hardware register file definitions
SPROM rev 9 was discovered on 14e4:4331, it seems to have very similar
layout to rev 8 one. Use the same extracting function until we find some
differences.
We use value supplied via SPROM, or default 10:90 as fallback.
tx start will start the tx queues: basically configure the SCD
Remove the IWLAGN prefix to SCD defines on the way.
Since the ICT is transport related, move all its functions to the transport
layer.
Since iwlagn_stop_device was the only caller to the rx_stop / tx_stop,
these two don't need to be API any more.
There are still a few functions here and there that should be
put in the transport layer. Mainly the functions that are related to the reclaim flow.
Also create a new file: iwl-trans-int-pcie.h which will include
the non static functions that are shared among the current pcie transport layer.
Not needed since the driver split.
Signed-off-by: Don Fry <donald.h.fry@intel.com>
Define bitmap for calibration
The driver should take the ownership of the uCode as default setting
for later operations after interface up.
Signed-off-by: Kenny Hsu <kenny.hsu@intel.com>
The first assignment of TX_CMD_FLG_SEQ_CTL_MSK for
ack-expected mgmt frames is overwritten later in
the function, so it's useless. Also, probe response
frames, BACK request and others there are mutually
exclusive so can be moved into an else branch.
Those comments were missed in a previous commit.
