path: root/drivers
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19fix typos in drivers/block/KconfigPatrick Ringl
2007-10-19Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (41 commits) ACPICA: hw: Don't carry spinlock over suspend ACPICA: hw: remove use_lock flag from acpi_hw_register_{read, write} ACPI: cpuidle: port idle timer suspend/resume workaround to cpuidle ACPI: clean up acpi_enter_sleep_state_prep Hibernation: Make sure that ACPI is enabled in acpi_hibernation_finish ACPI: suppress uninitialized var warning cpuidle: consolidate 2.6.22 cpuidle branch into one patch ACPI: thinkpad-acpi: skip blanks before the data when parsing sysfs ACPI: AC: Add sysfs interface ACPI: SBS: Add sysfs alarm ACPI: SBS: Add ACPI_PROCFS around procfs handling code. ACPI: SBS: Add support for power_supply class (and sysfs) ACPI: SBS: Make SBS reads table-driven. ACPI: SBS: Simplify data structures in SBS ACPI: SBS: Split host controller (ACPI0001) from SBS driver (ACPI0002) ACPI: EC: Add new query handler to list head. ACPI: Add acpi_bus_generate_event4() function ACPI: Battery: add sysfs alarm ACPI: Battery: Add sysfs support ACPI: Battery: Misc clean-ups, no functional changes ... Fix up conflicts in drivers/misc/thinkpad_acpi.[ch] manually
2007-10-19Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NET]: Fix possible dev_deactivate race condition [INET]: Justification for local port range robustness. [PACKET]: Kill unused pg_vec_endpage() function [NET]: QoS/Sched as menuconfig [NET]: Fix bug in sk_filter race cures. [PATCH] mac80211: make ieee802_11_parse_elems return void
2007-10-19NULL terminate the pci_device_ids in pasemi_edacStephen Rothwell
Fixes: drivers/edac/pasemi_edac: struct pci_device_id is 32 bytes. The last of 1 is: 0x00 0x00 0x19 0x59 0x00 0x00 0xa0 0x0a 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 FATAL: drivers/edac/pasemi_edac: struct pci_device_id is not terminated with a NULL entry! Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Change struct marker usersMathieu Desnoyers
Prior to use struct marker in the linux kernel markers, we need to clean two drivers which use this structure name. Change bonding driver types : - struct marker to struct bond_marker. - marker_t to bond_marker_t. - marker_header to bond_marker_header. - marker_header_t to bond_marker_header_t. Change qla4xxx struct marker_entry usage : - Change struct marker_entry for struct qla4_marker_entry. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Chad Tindel <ctindel@users.sourceforge.net> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: David Somayajulu <david.somayajulu@qlogic.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Cc: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19FlashPoint, use BIT instead of BITWJiri Slaby
FlashPoint, use BIT instead of BITW BITW was an ushort variant of BIT, use BIT instead Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19amba-pl011, rename BIT macroJiri Slaby
amba-pl011, rename BIT macro Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19s2io, rename BIT macroJiri Slaby
s2io, rename BIT macro BIT macro will be global definiton of (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ramkrishna Vepa <ram.vepa@neterion.com> Cc: Rastapur Santosh <santosh.rastapur@neterion.com> Cc: Sivakumar Subramani <sivakumar.subramani@neterion.com> Cc: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19i2c-pxa, rename BIT macro to PXA_BITJiri Slaby
i2c-pxa, rename BIT macro to PXA_BIT BIT macro will be global definiton of (1 << x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Nicolas Pitre <nico@cam.org> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cyber2000fb: checkpatch fixesKrzysztof Helt
This patch fixes errors and warnings pointed out by the checkpatch.pl script. Antonino Daplas replaced BIT with ENCODE_BIT. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cyber2000fb, rename BIT macroJiri Slaby
cyber2000fb, rename BIT macro BIT will be global macro for (1 << x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Misc: phantom, improved data passingJiri Slaby
This new version guarantees amb_bit switch in small enough intervals, so that the device won't stop working in the middle of a movement anymore. However it preserves old (openhaptics) functionality. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Misc: phantom, add comment about openhapticsJiri Slaby
2007-10-19Misc: phantom, synchronize_irq() on suspendJiri Slaby
Wait after disabling device's interrupt until the handler finishes its work if still in progress. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: round up the APIPavel Emelianov
The set of functions process_session, task_session, process_group and task_pgrp is confusing, as the names can be mixed with each other when looking at the code for a long time. The proposals are to * equip the functions that return the integer with _nr suffix to represent that fact, * and to make all functions work with task (not process) by making the common prefix of the same name. For monotony the routines signal_session() and set_signal_session() are replaced with task_session_nr() and set_task_session(), especially since they are only used with the explicit task->signal dereference. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19isdn/sc: remove unused REQUEST_IRQ and unnecessary header fileFernando Luis Vázquez Cao
REQUEST_IRQ is never used, so delete it. In the process get rid of the macro FREE_IRQ which makes the code unnecessarily difficult to read. Signed-off-by: Fernando Luis Vázquez Cao <fernando@oss.ntt.co.jp> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19isdn: fix random hard freeze with AVM T1 cardsKarsten Keil
This fixes the hard freeze debugged for AVM C4 cards for the AVM T1 cards. Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19isdn: fix random hard freeze with AVM cards using b1dmaKarsten Keil
This fixes the hard freeze debugded for AVM C4 cards using the b1dma interface. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19isdn: fix random hard freeze with AVM c4 card part 2Karsten Keil
One call was missing in the previous patch. Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Console events and accessibilitySamuel Thibault
Some external modules like Speakup need to monitor console output. This adds a VT notifier that such modules can use to get console output events: allocation, deallocation, writes, other updates (cursor position, switch, etc.) [akpm@linux-foundation.org: fix headers_check] Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19ps3av: remove unused fields in ps3av_monitor_quirksGeert Uytterhoeven
Remove the `clear_50' and `clear_vesa' fields of struct ps3av_monitor_quirk, as they're currently unused. We can always re-add them when we really need them. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Console keyboard events and accessibilitySamuel Thibault
Some blind people use a kernel engine called Speakup which uses hardware synthesis to speak what gets displayed on the screen. They use the PC keyboard to control this engine (start/stop, accelerate, ...) and also need to get keyboard feedback (to make sure to know what they are typing, the caps lock status, etc.) Up to now, the way it was done was very ugly. Below is a patch to add a notifier list for permitting a far better implementation, see ChangeLog above for details. You may wonder why this can't be done at the input layer. The problem is that what people want to monitor is the console keyboard, i.e. all input keyboards that got attached to the console, and with the currently active keymap (i.e. keysyms, not only keycodes). This adds a keyboard notifier that such modules can use to get the keyboard events and possibly eat them, at several stages: - keycodes: even before translation into keysym. - unbound keycodes: when no keysym is bound. - unicode: when the keycode would get translated into a unicode character. - keysym: when the keycode would get translated into a keysym. - post_keysym: after the keysym got interpreted, so as to see the result (caps lock, etc.) This also provides access to k_handler so as to permit simulation of keypresses. [akpm@linux-foundation.org: various fixes] Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19advansys: depends on VIRT_TO_BUSAndrew Morton
Fix powerpc allmodconfig build: advansys requires virt_to_bus() but powerpc doesn't implement it. Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Matthew Wilcox <willy@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18[INET]: Justification for local port range robustness.Anton Arapov
There is a justifying patch for Stephen's patches. Stephen's patches disallows using a port range of one single port and brakes the meaning of the 'remaining' variable, in some places it has different meaning. My patch gives back the sense of 'remaining' variable. It should mean how many ports are remaining and nothing else. Also my patch allows using a single port. I sure we must be able to use mentioned port range, this does not restricted by documentation and does not brake current behavior. usefull links: Patches posted by Stephen Hemminger http://marc.info/?l=linux-netdev&m=119206106218187&w=2 http://marc.info/?l=linux-netdev&m=119206109918235&w=2 Andrew Morton's comment http://marc.info/?l=linux-kernel&m=119248225007737&w=2 1. Allows using a port range of one single port. 2. Gives back sense of 'remaining' variable. Signed-off-by: Anton Arapov <aarapov@redhat.com> Acked-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-18Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: pcnet32: remove private net_device_stats structure vortex_up should initialize "err" pcnet32: remove compile warnings in non-napi mode pcnet32: fix non-napi packet reception fix EMAC driver for proper napi_synchronize API sky2: shutdown cleanup napi_synchronize: waiting for NAPI forcedeth msi bugfix gianfar: fix obviously wrong #ifdef CONFIG_GFAR_NAPI placement fs_enet: Update for API changes gianfar: remove orphan struct. forcedeth: fix rx-work condition in nv_rx_process_optimized() too
2007-10-18Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6: (37 commits) ide: set drive->autotune in ide_pci_setup_ports() triflex: always tune PIO opti621: always tune PIO cy82c693: always tune PIO cs5520: always tune PIO alim15x3: always tune PIO ide: add IDE_HFLAG_LEGACY_IRQS host flag ide: add IDE_HFLAG_SERIALIZE host flag ide: add IDE_HFLAG_ERROR_STOPS_FIFO host flag piix: add DECLARE_ICH_DEV() macro pdc202xx_old: add DECLARE_PDC2026X_DEV() macro pdc202xx_new: add DECLARE_PDCNEW_DEV() macro aec62xx: no need to disable UDMA in ->init_hwif method for ATP850UF ide: remove .init_setup from ide_pci_device_t serverworks: remove ->init_setup scc_pata: remove ->init_setup pdc202xx_old: remove ->init_setup pdc202xx_new: remove ->init_setup hpt366: remove ->init_setup cmd64x: remove ->init_setup ...
2007-10-19ide: set drive->autotune in ide_pci_setup_ports()Bartlomiej Zolnierkiewicz
Majority of host drivers using IDE PCI layer set drive->autotune, the only exceptions are: generic.c ns87415.c rz1000.c trm290.c * no ->set_pio_mode method it821x.c: * if memory allocation fails drive->autotune won't be set (but there also won't be ->set_pio_mode method in such case) piix.c: * MPIIX controller (no ->init_hwif method so also no ->set_pio_mode method) However if there is no ->set_pio_mode method there are no changes in behavior w.r.t. PIO tuning so always set drive->autotune in ide_pci_setup_ports(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19triflex: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19opti621: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19cy82c693: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19cs5520: always tune PIOBartlomiej Zolnierkiewicz
Since cs5520 uses VDMA best PIO mode was tuned anyway by ide_dma_check() but only if DMA was successfully initialized. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19alim15x3: always tune PIOBartlomiej Zolnierkiewicz
2007-10-19ide: add IDE_HFLAG_LEGACY_IRQS host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_LEGACY_IRQS host flag to tell ide_pci_setup_ports() to set hwif->irq to legacy IRQ 14/15 (iff hwif->irq is not already set) and convert atiixp, piix, serverworks, sis5513 and slc90e66 host drivers to use it. While at it: * In piix.c add IDE_HFLAGS_PIIX define and don't use ->init_hwif for MPIIX. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_SERIALIZE host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_SERIALIZE host flag to tell ide_pci_setup_ports() to set hwif/mate->serialized and convert aec62xx, cs5530 and sc1200 host drivers to use it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_ERROR_STOPS_FIFO host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_ERROR_STOPS_FIFO host flag and use it instead of hwif->err_stops_fifo. As a side-effect this change fixes hwif->err_stops_fifo not being restored by ide_hwif_restore(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19piix: add DECLARE_ICH_DEV() macroBartlomiej Zolnierkiewicz
Add DECLARE_ICH_DEV() macro. While at it: * Add init_hwif_ich() (->init_hwif method) for ICH controllers. * Rename init_chipset_piix() to init_chipset_ich() and use it only for ICH controllers. * Remove no longer needed piix_is_ichx() helper. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19pdc202xx_old: add DECLARE_PDC2026X_DEV() macroBartlomiej Zolnierkiewicz
2007-10-19pdc202xx_new: add DECLARE_PDCNEW_DEV() macroBartlomiej Zolnierkiewicz
2007-10-19aec62xx: no need to disable UDMA in ->init_hwif method for ATP850UFBartlomiej Zolnierkiewicz
* No need to disable UDMA in ->init_hwif method for ATP850UF (and since we now always tune PIO it will be disabled by ->set_pio_mode calls anyway). * Bump driver version. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19serverworks: remove ->init_setupBartlomiej Zolnierkiewicz
Merge init_setup_{svwks,csb6}() into svwks_init_one(). While at it: * Remove redundant dev->device checks. * Operate on a local copy of serverworks_chipsets[] entry. * Use pci_resource_start(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19scc_pata: remove ->init_setupBartlomiej Zolnierkiewicz
2007-10-19pdc202xx_old: remove ->init_setupBartlomiej Zolnierkiewicz
* Split off pdc202ata4_fixup_irq() helper from init_setup_pdc202ata4(). * Merge init_setup_{pdc202ata4,pdc20265,pdc202xx}() into pdc202xx_init_one(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19pdc202xx_new: remove ->init_setupBartlomiej Zolnierkiewicz
* Split off pdc20270_get_dev2() helper from init_setup_pdc20270(). * Merge init_setup_{pdcnew,pdc20270,pdc20276}() into pdc202new_init_one(). While at it: * Change KERN_ level of interrupt fixup message from KERN_WARNING to KERN_INFO. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
