path: root/drivers
2009-01-08rtc-ds1307: remove legacy probe() checksJüri Reitel
Remove RTC register value checks from the rtc-ds1307 probe() function. They were left over from the legacy style I2C driver, which had to defend against finding a non-RTC chip when the driver was probed. Also fix a minor glitch in the alarm support: DS1307 chips don't have alarms, so name those methods after one of the chips which actually *do* have alarms (DS1337). Signed-off-by: Jüri Reitel <juri.reitel@liewenthal.ee> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Sebastien Barre <sbarre@sdelcc.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08rtc-ds1307: SMBus compatibilityBARRE Sebastien
Change i2c access functions to SMBus access functions in order to use the ds1307 with SMBus adapter. Signed-off-by: Sebastien Barre <sbarre@sdelcc.com> Acked-by: David Brownell <david-b@pacbell.net> Tested-by: David Brownell <david-b@pacbell.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Rodolfo Giometti <giometti@enneenne.com> Tested-by: Sebastien Barre <sbarre@sdelcc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08xen: add xenfs to allow usermode <-> Xen interactionAlex Zeffertt
The xenfs filesystem exports various interfaces to usermode. Initially this exports a file to allow usermode to interact with xenbus/xenstore. Traditionally this appeared in /proc/xen. Rather than extending procfs, this patch adds a backward-compat mountpoint on /proc/xen, and provides a xenfs filesystem which can be mounted there. Signed-off-by: Alex Zeffertt <alex.zeffertt@eu.citrix.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08drivers/xen/xenbus/xenbus_client.c: cleanup kerneldocQinghuang Feng
no argument named @xbt in xenbus_switch_state(), remove it. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Work around branch tracer warning. sparc64: Fix unsigned long long warnings in drivers. sparc64: Use unsigned long long for u64. sparc: refactor code in fault_32.c sparc64: refactor code in init_64.c sparc64: refactor code in viohs.c sparc: make proces_ver_nack a bit more readable
2009-01-07Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: V4L/DVB (10191a): Update MAINTAINERS entries on media drivers V4L/DVB (10190): cx88: Fix some Kbuild troubles V4L/DVB (10189): dm1105: Fix build with INPUT=m and DVB_DM1105=y V4L/DVB (10185): Use negated usb_endpoint_xfer_control, etc V4L/DVB (10182): tda8290: fix TDA8290 + TDA18271 initialization V4L/DVB (10181): v4l2-device: Fix some sparse warnings V4L/DVB (10180): drivers/media: Fix a number of sparse warnings V4L/DVB (10179): tda8290: Fix two sparse warnings V4L/DVB (10178): dvb_frontend: Fix some sparse warnings due to static symbols V4L/DVB (10177): Fix sparse warnings on em28xx V4L/DVB (10176b): pxa-camera: fix redefinition warnings and missing DMA definitions V4L/DVB (10176a): Switch remaining clear_user_page users over to clear_user_highpage
2009-01-07V4L/DVB (10190): cx88: Fix some Kbuild troublesMauro Carvalho Chehab
As Randy Dunlap <randy.dunlap@oracle.com> reported, cx88 has some compilation issues: drivers/built-in.o: In function `cx88_call_i2c_clients': (.text+0x20af17): undefined reference to `videobuf_dvb_get_frontend' drivers/built-in.o: In function `cx8802_probe': cx88-mpeg.c:(.devinit.text+0x268c4): undefined reference to `videobuf_dvb_alloc_frontend' cx88-mpeg.c:(.devinit.text+0x268ea): undefined reference to `videobuf_dvb_dealloc_frontends' With those configs: CONFIG_VIDEO_CX88=y CONFIG_VIDEO_CX88_BLACKBIRD=y CONFIG_VIDEO_CX88_DVB=m CONFIG_DVB_CORE=m After carefully examining the code, with the current code, several cx88 drivers (cx8800, cx8802, cx88_dvb and cx88_blackbird) should be compiled as a module, if one of them is marked as such. Just fixing Kconfig could create a very complex set of rules. Also, this hides a problem with the current approach where the dvb functionality weren't confined inside dvb module. What happens is that: - cx88-i2c (part of cx8800) has some special rules if DVB; - cx88-mpeg (cx8802 module) has also part of DVB init code; - cx88-dvb has the rest of the dvb code; - cx88-blackbird can be used with cx88-mpeg, having cx88-dvb or not. So, instead of doing some tricks at Kconfig and wait for a next breakage, this patch moves the dvb code inside cx88-i2c and cx88-mpeg into cx88-dvb. Another problem is that cx8802 were being compiled, even without cx88-dvb and cx88-blackbird modules. While on this code, let's fix also a reported problem: http://www.linuxtv.org/pipermail/linux-dvb/2009-January/031225.html A solution for the issue were proposed here: http://www.mail-archive.com/linux-media@vger.kernel.org/msg00021.html Thanks to Randy, Andy, Gregoire and Thomas for helping us to detect and solve the issues. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10189): dm1105: Fix build with INPUT=m and DVB_DM1105=yMauro Carvalho Chehab
As reported by Randy Dunlap <randy.dunlap@oracle.com>: With CONFIG_INPUT=m and CONFIG_DVB_DM1105=y: drivers/built-in.o: In function `input_sync': dm1105.c:(.text+0x120c33): undefined reference to `input_event' drivers/built-in.o: In function `dm1105_emit_key': dm1105.c:(.text+0x120c6c): undefined reference to `input_event' dm1105.c:(.text+0x120c82): undefined reference to `input_event' dm1105.c:(.text+0x120cb2): undefined reference to `input_event' dm1105.c:(.text+0x120cd1): undefined reference to `input_event' drivers/built-in.o: In function `dm1105_ir_init': (.devinit.text+0xd8ae): undefined reference to `input_allocate_device' drivers/built-in.o: In function `dm1105_ir_init': (.devinit.text+0xd9f6): undefined reference to `input_register_device' drivers/built-in.o: In function `dm1105_ir_init': (.devinit.text+0xda09): undefined reference to `input_free_device' drivers/built-in.o: In function `dm1105_ir_exit': (.devexit.text+0xcde): undefined reference to `input_unregister_device' This is due to the lack of a dependency between dm1105 and CONFIG_INPUT Cc: Igor M. Liplianin <liplianin@me.by> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10185): Use negated usb_endpoint_xfer_control, etcJulia Lawall
This patch extends 134179823b3ca9c8b98e0631906459dbb022ff9b by using usb_endpoint_xfer_control, usb_endpoint_xfer_isoc, usb_endpoint_xfer_bulk, and usb_endpoint_xfer_int in the negated case as well. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_CONTROL\|0\)) + !usb_endpoint_xfer_control(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_ISOC\|1\)) + !usb_endpoint_xfer_isoc(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_BULK\|2\)) + !usb_endpoint_xfer_bulk(epd) @@ struct usb_endpoint_descriptor *epd; @@ - (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_INT\|3\)) + !usb_endpoint_xfer_int(epd) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10182): tda8290: fix TDA8290 + TDA18271 initializationMichael Krufky
Don't call tda8290_init_tuner unless we have either a TDA8275 or TDA8275A present. Calling this function will cause a TDA18271 to get sick, so we should only call it when needed. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10181): v4l2-device: Fix some sparse warningsMauro Carvalho Chehab
/home/v4l/master/v4l/v4l2-device.c:32:2: warning: Using plain integer as NULL pointer /home/v4l/master/v4l/v4l2-device.c:64:2: warning: Using plain integer as NULL pointer Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10180): drivers/media: Fix a number of sparse warningsMauro Carvalho Chehab
anysee.c:44:5: warning: symbol 'dvb_usb_anysee_delsys' was not declared. Should it be static? cx24116.c:378:3: warning: symbol 'CX24116_MODFEC_MODES' was not declared. Should it be static? stb0899_algo.c:57:5: warning: symbol 'stb0899_get_srate' was not declared. Should it be static? stb0899_algo.c:766:6: warning: symbol 'Log2Int' was not declared. Should it be static? stb0899_drv.c:137:20: warning: symbol 'stb0899_quant_tab' was not declared. Should it be static? stb0899_drv.c:180:20: warning: symbol 'stb0899_est_tab' was not declared. Should it be static? stb0899_drv.c:220:5: warning: symbol '_stb0899_read_reg' was not declared. Should it be static? budget-ci.c:1348:23: warning: symbol 'tt3200_stb6100_config' was not declared. Should it be static? /home/v4l/master/v4l/cx25840-core.c:190:6: warning: symbol 'cx25840_work_handler' was not declared. Should it be static? /home/v4l/master/v4l/m5602_s5k83a.c:116:6: warning: symbol 's5k83a_dump_registers' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10179): tda8290: Fix two sparse warningsMauro Carvalho Chehab
/home/v4l/master/v4l/tda8290.c:233:7: warning: symbol 'i' shadows an earlier one /home/v4l/master/v4l/tda8290.c:178:3: warning: symbol 'fm_mode' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10178): dvb_frontend: Fix some sparse warnings due to static symbolsMauro Carvalho Chehab
/home/v4l/master/v4l/dvb_frontend.c:838:19: warning: symbol 'dtv_cmds' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1035:6: warning: symbol 'dtv_property_dump' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1066:5: warning: symbol 'is_legacy_delivery_system' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1080:6: warning: symbol 'dtv_property_cache_sync' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1132:6: warning: symbol 'dtv_property_legacy_params_sync' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1187:6: warning: symbol 'dtv_property_adv_params_sync' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1222:6: warning: symbol 'dtv_property_cache_submit' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1253:5: warning: symbol 'dtv_property_process_get' was not declared. Should it be static? /home/v4l/master/v4l/dvb_frontend.c:1362:5: warning: symbol 'dtv_property_process_set' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10177): Fix sparse warnings on em28xxMauro Carvalho Chehab
/home/v4l/master/v4l/em28xx-core.c:396:25: warning: symbol 'outputs' was not declared. Should it be static? /home/v4l/master/v4l/em28xx-input.c:324:6: warning: symbol 'em28xx_ir_start' was not declared. Should it be static? /home/v4l/master/v4l/em28xx-cards.c:1925:5: warning: symbol 'em28xx_init_dev' was not declared. Should it be static? Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10176b): pxa-camera: fix redefinition warnings and missing DMA ↵Eric Miao
definitions 1. now pxa_camera.c uses ioremap() for register access, pxa_camera.h is totally useless. Remove it. 2. <asm/dma.h> does no longer include <mach/dma.h>, include the latter file explicitly delete mode 100644 drivers/media/video/pxa_camera.h Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07V4L/DVB (10176a): Switch remaining clear_user_page users over to ↵Guennadi Liakhovetski
clear_user_highpage Not all architectures provide clear_user_page(), but clear_user_highpage() is available everywhere at least via the compatibility inline function. Is this the "trivial patch" that's required for these two drivers? Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-07staging: __FUNCTION__ is gcc-specific, use __func__Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07trivial: replace last usages of __FUNCTION__ in kernelHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (98 commits) PCI PM: Put PM callbacks in the order of execution PCI PM: Run default PM callbacks for all devices using new framework PCI PM: Register power state of devices during initialization PCI PM: Call pci_fixup_device from legacy routines PCI PM: Rearrange code in pci-driver.c PCI PM: Avoid touching devices behind bridges in unknown state PCI PM: Move pci_has_legacy_pm_support PCI PM: Power-manage devices without drivers during suspend-resume PCI PM: Add suspend counterpart of pci_reenable_device PCI PM: Fix poweroff and restore callbacks PCI: Use msleep instead of cpu_relax during ASPM link retraining PCI: PCIe portdrv: Add kerneldoc comments to remining core funtions PCI: PCIe portdrv: Rearrange code so that related things are together PCI: PCIe portdrv: Fix suspend and resume of PCI Express port services PCI: PCIe portdrv: Add kerneldoc comments to some core functions x86/PCI: Do not use interrupt links for devices using MSI-X net: sfc: Use pci_clear_master() to disable bus mastering PCI: Add pci_clear_master() as opposite of pci_set_master() PCI hotplug: remove redundant test in cpq hotplug PCI: pciehp: cleanup register and field definitions ...
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (123 commits) wimax/i2400m: add CREDITS and MAINTAINERS entries wimax: export linux/wimax.h and linux/wimax/i2400m.h with headers_install i2400m: Makefile and Kconfig i2400m/SDIO: TX and RX path backends i2400m/SDIO: firmware upload backend i2400m/SDIO: probe/disconnect, dev init/shutdown and reset backends i2400m/SDIO: header for the SDIO subdriver i2400m/USB: TX and RX path backends i2400m/USB: firmware upload backend i2400m/USB: probe/disconnect, dev init/shutdown and reset backends i2400m/USB: header for the USB bus driver i2400m: debugfs controls i2400m: various functions for device management i2400m: RX and TX data/control paths i2400m: firmware loading and bootrom initialization i2400m: linkage to the networking stack i2400m: Generic probe/disconnect, reset and message passing i2400m: host/device procotol and core driver definitions i2400m: documentation and instructions for usage wimax: Makefile, Kconfig and docbook linkage for the stack ...
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-asyncLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-async: async: don't do the initcall stuff post boot bootchart: improve output based on Dave Jones' feedback async: make the final inode deletion an asynchronous event fastboot: Make libata initialization even more async fastboot: make the libata port scan asynchronous fastboot: make scsi probes asynchronous async: Asynchronous function calls to speed up kernel boot
2009-01-07topology: Fix sparc64 build.David Miller
Due to changeset ba84be2338d3a2b6020d39279335bb06fcd332e1 ("remove linux/hardirq.h from asm-generic/local.h") the sparc64 build started failing on drivers/base/topology.c: drivers/base/topology.c: In function ‘show_physical_package_id’: drivers/base/topology.c:103: error: implicit declaration of function ‘cpu_data’ drivers/base/topology.c:103: error: request for member ‘proc_id’ in something not a structure or union drivers/base/topology.c: In function ‘show_core_id’: drivers/base/topology.c:106: error: request for member ‘core_id’ in something not a structure or union Adding the obvious fix of including asm/cpudata.h into asm/topology.h on sparc64 doesn't fix it, in fact it makes things worse because of the header file dependency chain: linux/gfp.h --> linux/mmzone.h --> linux/topology.h --> asm/topology.h --> asm/cpudata.h --> linux/percpu.h --> linux/slab.h which results in: include/linux/slub_def.h: In function ‘kmalloc_large’: include/linux/slub_def.h:209: error: implicit declaration of function ‘__get_free_pages’ include/linux/slub_def.h:209: error: ‘__GFP_COMP’ undeclared (first use in this function) include/linux/slub_def.h:209: error: (Each undeclared identifier is reported only once include/linux/slub_def.h:209: error: for each function it appears in.) include/linux/slub_def.h:209: warning: cast to pointer from integer of different size The simplest thing to do is to add yet another one-off hack like parts of the guilty changeset did, by putting an explicit linux/hardirq.h include into drivers/base/topology.c Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: reorder struct fw_card for better cache efficiency firewire: fix resetting of bus manager retry counter firewire: improve refcounting of fw_card firewire: typo in comment firewire: fix small memory leak at module removal firewire: fw-sbp2: remove unnecessary locking ieee1934: dv1394: interrupt enabling/disabling broken on big-endian ieee1394: dv1394: annotate frame input/output structs as little endian ieee1394: eth1394: trivial sparse annotations ieee1394: mark bus_info_data as a __be32 array ieee1394: replace CSR_SET_BUS_INFO_GENERATION macro ieee1394: pcilynx: trivial endian annotation ieee1394: ignore nonzero Bus_Info_Block.max_rom, fetch config ROM in quadlets ieee1394: consolidate uses of IEEE1934_BUSID_MAGIC ieee1394: ohci1394: flush MMIO writes before delay in initialization ieee1394: ohci1394: pass error codes from request_irq through ieee1394: ohci1394: don't leave interrupts enabled during suspend/resume ieee1394: mark all hpsb_address_ops instances as const ieee1394: replace a GFP_ATOMIC by GFP_KERNEL allocation
2009-01-07Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: (29 commits) hwmon: Fix various typos hwmon: Check for ACPI resource conflicts hwmon: (lm70) Add TI TMP121 support hwmon: (lm70) Code streamlining and cleanup hwmon: Deprecate the fscher and fscpos drivers hwmon: (fschmd) Add watchdog support hwmon: (fschmd) Cleanups for watchdog support hwmon: (i5k_amb) Load automatically on all 5000/5400 chipsets hwmon: (it87) Add support for the ITE IT8720F hwmon: Don't overuse I2C_CLIENT_MODULE_PARM hwmon: Add LTC4245 driver hwmon: (f71882fg) Fix fan_to/from_reg prototypes hwmon: (f71882fg) Printout fan modes hwmon: (f71882fg) Add documentation hwmon: (f71882fg) Fix auto_channels_temp temp numbering with f8000 hwmon: (f71882fg) Add missing pwm3 attr for f71862fg hwmon: (f71882fg) Add F8000 support hwmon: (f71882fg) Remove the fan_mode module option hwmon: (f71882fg) Separate max and crit alarm and beep hwmon: (f71882fg) Check for hwmon powerdown state ...
2009-01-07Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Use snprintf to set adapter names Input: apanel - convert to new i2c binding i2c: Drop I2C_CLASS_CAM_DIGITAL i2c: Drop I2C_CLASS_CAM_ANALOG and I2C_CLASS_SOUND i2c: Drop I2C_CLASS_ALL i2c: Get rid of remaining bus_id access i2c: Replace bus_id with dev_name(), dev_set_name()
2009-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: avr32: Move syscalls.h under arch/avr32/include/asm/ avr32: Define DIE_OOPS avr32: Remove DMATEST from defconfigs arch/avr32: Eliminate NULL test and memset after alloc_bootmem avr32: data param to at32_add_device_mci() must be non-NULL atmel-mci: move atmel-mci.h file to include/linux avr32: Hammerhead board support avr32: Allow reserving multiple pins at once favr-32: Remove deprecated call MIMC200: Remove deprecated call avr: struct device - replace bus_id with dev_name(), dev_set_name() avr32: Introducing asm/syscalls.h
2009-01-07touchscreen: Fix build of da9034Alan Cox
Missing an include and thus breaks the x86-64 build. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-07HID: fix hid->hiddev initialization in hiddev_connect()Jiri Kosina
Commit 079034073fa ("HID: hiddev cleanup -- handle all error conditions properly") by mistake removed proper initialization of hid->hiddev pointer in hiddev_connect() in case usb_register_dev() succeeds for the hiddev node. Put it properly back in place. Reported-and-tested-by: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07PCI PM: Put PM callbacks in the order of executionRafael J. Wysocki
Put PM callbacks in drivers/pci/pci-driver.c in the order in which they are executed which makes it much easier to follow the code. No functional changes should result from this. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Run default PM callbacks for all devices using new frameworkRafael J. Wysocki
It should be quite clear that it generally makes sense to execute the default PM callbacks (ie. the callbacks used for handling suspend, hibernation and resume of PCI devices without drivers) for all devices. Of course, the drivers that provide legacy PCI PM support (ie. the ->suspend, ->suspend_late, ->resume_early or ->resume hooks in the pci_driver structure), carry out these operations too, so we can't do it for devices with such drivers. Still, we can make the default PM callbacks run for devices with drivers using the new framework (ie. implement the pm object), since there are no such drivers at the moment. This also simplifies the code and makes it smaller. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Register power state of devices during initializationRafael J. Wysocki
Use the observation that the power state of a PCI device can be loaded into its pci_dev structure as soon as pci_pm_init() is run for it and make that happen. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Call pci_fixup_device from legacy routinesRafael J. Wysocki
The size of drivers/pci/pci-driver.c can be reduced quite a bit if pci_fixup_device() is called from the legacy PM callbacks, so make it happen. No functional changes should result from this. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Rearrange code in pci-driver.cRafael J. Wysocki
Rename two functions and rearrange code in drivers/pci/pci-driver.c so that it's easier to follow. In particular, separate invocations of the legacy callbacks from the rest of the new callbacks' code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Avoid touching devices behind bridges in unknown stateRafael J. Wysocki
It generally is better to avoid accessing devices behind bridges that may not be in the D0 power state, because in that case the bridges' secondary buses may not be accessible. For this reason, during the early phase of resume (ie. with interrupts disabled), before restoring the standard config registers of a device, check the power state of the bridge the device is behind and postpone the restoration of the device's config space, as well as any other operations that would involve accessing the device, if that state is not D0. In such cases the restoration of the device's config space will be retried during the "normal" phase of resume (ie. with interrupts enabled), so that the bridge can be put into D0 before that happens. Also, save standard configuration registers of PCI devices during the "normal" phase of suspend (ie. with interrupts enabled), so that the bridges the devices are behind can be put into low power states (we don't put bridges into low power states at the moment, but we may want to do it in the future and it seems reasonable to design for that). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Move pci_has_legacy_pm_supportRafael J. Wysocki
Move pci_has_legacy_pm_support() closer to the functions that call it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Power-manage devices without drivers during suspend-resumeRafael J. Wysocki
PCI devices without drivers can be put into low power states during suspend with the help of pci_prepare_to_sleep() and prevented from generating wake-up events during resume with the help of pci_enable_wake(). However, it's better not to put bridges into low power states during suspend, because that might result in entire bus segments being powered off. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Add suspend counterpart of pci_reenable_deviceRafael J. Wysocki
PCI devices without drivers are not disabled during suspend and hibernation, but they are enabled during resume, with the help of pci_reenable_device(), so there is an unbalanced execution of pcibios_enable_device() in the resume code path. To correct this introduce function pci_disable_enabled_device() that will disable the argument device, if it is enabled when the function is being run, without updating the device's pci_dev structure and use it in the suspend code path to balance the pci_reenable_device() executed during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI PM: Fix poweroff and restore callbacksRafael J. Wysocki
pci_fixup_device() is called too early in pci_pm_poweroff() and too late in pci_pm_restore(). Moreover, pci_pm_restore_noirq() calls pci_fixup_device() twice and in a wrong way. Fix that. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: Use msleep instead of cpu_relax during ASPM link retrainingAndrew Patterson
The cpu_relax() function can be a noop on certain architectures like IA-64 when CPU threads are disabled, so use msleep instead during link retraining busy/wait loop. Introduce define LINK_RETRAIN_TIMEOUT instead of hard-coding timeout in pcie_aspm_configure_common_clock. Use time_after() to avoid jiffy wraparound when checking for expired timeout. After timeout expires, recheck link status register link training bit instead of checking for expired timeout to avoid possible false positive. Note that Matthew Wilcox came up with the first rough version of this patch. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: PCIe portdrv: Add kerneldoc comments to remining core funtionsRafael J. Wysocki
Add kerneldoc comments to the reamining functions in drivers/pci/pcie/portdrv_core.c . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: PCIe portdrv: Rearrange code so that related things are togetherRafael J. Wysocki
Rearrange code in drivers/pci/pcie/portdrv_bus.c and drivers/pci/pcie/portdrv_core.c so that related functions and data structures are closer together. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: PCIe portdrv: Fix suspend and resume of PCI Express port servicesRafael J. Wysocki
There is a problem with the suspend and resume of PCI Express port service devices that the ->suspend() and ->resume() routines of each service device are called twice in each suspend-resume cycle, which is obviously wrong. The scenario is that first, the PCI Express port driver calls suspend and resume routines of each port service driver from its pcie_portdrv_suspend() and pcie_portdrv_resume() callbacks, respectively (which is correct), and second, the pcie_port_bus_type driver calls them from its ->suspend() and ->resume() callbacks (which is not correct, because it doesn't happen at the right time). The solution is to remove the ->suspend() and ->resume() callbacks from pcie_port_bus_type and the associated functions. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: PCIe portdrv: Add kerneldoc comments to some core functionsRafael J. Wysocki
Add kerneldoc comments to some functions in drivers/pci/pcie/portdrv_core.c, since the code in there is not easy to follow without any additional description. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07net: sfc: Use pci_clear_master() to disable bus masteringBen Hutchings
pci_disable_device() disables many features, like MSI-X, which we never reenable in efx_reset(). Further, calls to pci_enable_device() and pci_disable_device() must be matched since the nesting count was introduced, so switch to using pci_clear_master() instead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: Add pci_clear_master() as opposite of pci_set_master()Ben Hutchings
During an online device reset it may be useful to disable bus-mastering. pci_disable_device() does that, and far more besides, so is not suitable for an online reset. Add pci_clear_master() which does just this. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI hotplug: remove redundant test in cpq hotplugJulia Lawall
func is checked not to be NULL a few lines before. A simplified version of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; expression E; position p1,p2; @@ if (x@p1 == NULL || ...) { ... when forall return ...; } ... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\) ( x@p2 == NULL | x@p2 != NULL ) // another path to the test that is not through p1? @s exists@ local idexpression r.x; position r.p1,r.p2; @@ ... when != x@p1 ( x@p2 == NULL | x@p2 != NULL ) @fix depends on !s@ position r.p1,r.p2; expression x,E; statement S1,S2; @@ ( - if ((x@p2 != NULL) || ...) S1 | - if ((x@p2 == NULL) && ...) S1 | - BUG_ON(x@p2 == NULL); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: pciehp: cleanup register and field definitionsKenji Kaneshige
Clean up register definitions related to PCI Express Hot plug. - Add register definitions into include/linux/pci_regs.h, and use them instead of pciehp's locally definied register definitions. - Remove pciehp's locally defined register definitions - Remove unused register definitions in pciehp. - Some minor cleanups. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: pciehp: ignore undefined bit in link status registerKenji Kaneshige
Bit 10 in Link Status register used to be defined as Training Error in the PCI Express 1.0a specification. But it was removed by Training Error ECN and is no longer defined. So pciehp must ignore the value read from it. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
