Original change(commit dfa3daebbc8dbe3ccc8e72400359dfce29053222) to fix
LP0 error is already merged but the error is still there
due to porting issue to main branch.
This change fixes LP0 problem caused by porting to main.
Change-Id: I925407dc6c7fe0caca5ea33e3830a857b26e151c
Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com>
Reviewed-on: http://git-master/r/109376
GVS: Gerrit_Virtual_Submit
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Bug 1000789
Bug 1003730
Change-Id: I7fbd703dde2044f2790e6a9b356ef8dca89ad8f3
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/110146
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
During programming of a frame or at frame end, force the use of the new EMC
bandwidth instead of the previous frame's bandwidth.
Moved copy of new_bandwidth out of tegra_dc_set_latency_allowance() to match
the semantics of the rest of tegra_dc_program_bandwidth().
bug 949015
Change-Id: I881f3a2c75f3438e3bbb3208b518f15a4574bc91
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/110149
Tested-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Update wiphy (wireless hardware description) to
support 5 GHz scan.
Bug 1000888
Change-Id: I1a7a99f97f69dd8f1790f81ee0fb21e209e8d10e
Signed-off-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-on: http://git-master/r/109556
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Compile power management suspend and resume functions only when
CONFIG_PM is enabled.
Change-Id: If349984d62ed002594ba60ac25cd4dddd956aa6c
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/109425
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Change-Id: I2a5f0c9305bd53c42df181556d97efa5d6792ad7
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/106500
Reviewed-by: Bo Yan <byan@nvidia.com>
Distributions may wish to provide different defaults for PCIE ASPM
depending on their target audience. Provide a configuration option for
choosing the default policy.
Bug 815499
(cherry picked from commit ad71c96213a68dfe6d761e3ff7ac7ac267fd612a
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;
a=commitdiff;h=ad71c96213a68dfe6d761e3ff7ac7ac267fd612a)
Change-Id: I36bd72517af0cf8d637552e66b18afe576e72c20
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Vidya Sagar <vidyas@nvidia.com>
Reviewed-on: http://git-master/r/109739
Check for valid entry on the message queue before
reading the transfer list from queue. If queue is
empty then do not start transfer.
Change-Id: If51a816780ab76700a7a1d7d8a025a3544590ad1
Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com>
Reviewed-on: http://git-master/r/109469
Reviewed-by: Simone Willett <swillett@nvidia.com>
When any error occurs in spi communication,
dump the spi registers for debug purpose
Change-Id: I5cf226d4b504c95a6abb8dcf5b8c0ba1ef44271c
Reviewed-on: http://git-master/r/109466
When computing required words for a transfer,
limit this to max possible size on given
sub transfer
Change-Id: Ia1a9290ae389e36ecb5a8d03be2982885a544a33
Reviewed-on: http://git-master/r/109462
Bug 995706
During device shutdown/rebooting, runtime PM is disabled. SPI bus
driver will fail to call tegra_spi_runtime_resume() to resume the
clock needed by tranferring. In this case, do not start transferring.
Change-Id: I42cc0763f55b6c90df00fbad68794939e903199a
Signed-off-by: Johnny Qiu <joqiu@nvidia.com>
Reviewed-on: http://git-master/r/109458
When a DC window is being released, a NULL flip is used to indicate
that the window should be disabled. To disable a window, 0 is
written to WIN_OPTIONS.
The MC_DECERR on window shutdown is a symptom of forgetting step 2)
below when disabling windows, leaving no indication that there is
anything to wait for. This causes DC to erroneously unpin the
scanout buffer while the buffer is still actively being used.
Summary of flip (window update) synchronization in DC:
1) program some window registers
2) set win->dirty=1
3) schedule the activation of the registers
4) request VBLANK or HBLANK interrupts
5) wait for win->dirty==0
In the trigger_windows ISR (every VBLANK or HBLANK):
1) if there is no window update pending in HW, clear dirty flag to
indicate that ACTIVE registers are up-to-date.
bug 991572
bug 995614
bug 989119
bug 983251
bug 960424
bug 866711
Change-Id: I8b710aac874b202838c3989608b7e0bd15425382
Signed-off-by: Adam Cheney <acheney@nvidia.com>
Reviewed-on: http://git-master/r/109370
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Get rid of maybe-uninitialized warning when using 4.6 toolchain.
Bug 999222
Change-Id: Ic8e944eaba281cdea45950b61f93093ff0e59f20
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/109553
Tested-by: Stefan Becker <stefanb@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Make all chip specific functions static. Include the chip specific
functions in SoC files after including the hardware headers. This
makes the chip specific functions to be compiled per SoC, and with
the correct hardware definitions.
Bug 982965
Change-Id: I4774d4dc351951cb886d9d4da66cf021f3f0121e
Reviewed-on: http://git-master/r/107581
Adding new sysfs entry for product revision which is needed by
mNAND health and status user space tool.
Bug 974823.
Change-Id: I4a07a5e6c1c81e2b7a4c1ed024e987e06f9f87c8
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/103366
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
Reviewed-by: Luis Dib <ldib@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Give names to the structures inside nvhost_chip_support. This way
they can be referred to individually.
Change-Id: I9b727bfc232d11957a8bd3e3570583d47cff778e
Reviewed-on: http://git-master/r/109103
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
Remove unused functions in CDMA and debug. They were left unused
when debug dump started using sync queue instead of channel
registers for detecting current position.
Change-Id: Ib1f0bc8f702667d0453079e6d5f5d8ca08f8db09
Reviewed-on: http://git-master/r/109102
Call drain fifo and save context functions via nvhost_chip_support.
Earlier client drivers called into host1x code directly, which
makes each client driver SoC specific.
Change-Id: I4f805abad21012e59e11bf6a98fa46441c71c51a
Reviewed-on: http://git-master/r/109101
this commit exposes following power management parameter through
sysfs:
- clockgate_delay: delay after which module is clock gated after
it goes idle. this read/write attribute & unit is ms.
- powergate_delay: delay after which module is power gated after
it is clock gated. this is read/write attribute & unit is ms.
- refcount: current reference count on the module. this is
read-only attribute.
path is: /sys/devices/host1x/<device-name>/acm/ where
<device-name> = name of device node like gr2d or gr3d etc
Bug 845598
Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/108827
Reviewed-by: Francis Hart <fhart@nvidia.com>
Becasue of a previous workaround, suspend/resume pair is implemented as
suspend/complete pair in the driver's dev_pm_ops field.
If any driver suspend routine (which is called before otg suspend)
failed, then tegra_otg_resume() will be called even tegra_otg_suspend()
is not called. This will cause disable the OTG clock, and OTG will not
generate any more IRQ.
Ideal fix would be use suspend/resume pair to implement the dev_pm_ops,
but this might break previous workaround. This patch check suspend()
routine is called or not in the resume routine; even we use suspend/
resume pair in the future, it will not cause bad behaviour.
BUG 999759
Change-Id: I88f9c28bb76c5ff9e32917904017f291456cb933
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/108444
(cherry picked from commit c751aeea65f126d8e2df7f8a9ba02a631f958dc1)
Reviewed-on: http://git-master/r/108945
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Change-Id: I34748241728bb0bab1861f8abacffdfe2939740f
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/109158
Host support should be disabled only when there is platform
data specifying proper setting.
Bug 998001
Change-Id: I99ff534074dd7ebbf12b53dcf53d6286925965d2
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/108760
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
promotion_build
Two threads race for two resources when baseband_usb_close()
get called from a user process
Bug 988188
Change-Id: Ic962640b6414e576d34b7ff6870b21b644837434
Signed-off-by: pyu <pyu@nvidia.com>
Reviewed-on: http://git-master/r/107088
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Bug 999876
Change-Id: I83a139e6c0dd42cf095fa2ac1376732075a15434
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
- ETIMEDOUT is interpreted as FW is not responding,
so return EINTR instead
- Deauth frame from p2p GO to client doesn't go from firmware
if we do del_virtual_iface immediately. Putting a delay after
sending deauth frame to allowed FW to send out deauth frame.
- IF_DEL operation was timing out due to wrong status check.
Fixed it and added few debug prints.
- Sending Provision Discovery directly to GO instead of doing
an internal scan. Also put the internal scan count to 3 to have
better timings for GO-NEG.
- Increase beacon timeout only for concurrent mode. For STA only
operation, use the default beacon timeout value (4).
- If scan abort is due to timeout, aborting the scan in FW is not
required. Moreover, as this scan_timeout call is coming in timer
interrupt context, all blocking calls such as fw scan abort will
result in kernel panic : don’t call abort in Firmware.
- Add p2p_cancel_listen routine. Fix p2p_listen_complete related
kernel crash seen while turning off WiFi.
- Add retry to wl_cfg80211_mgmt_tx() for P2P
- Change singal pending return value from -512 to -110
- Minor cleaning
- Reduce IOCTL responce timeout to 2 sec (from 20)
- Fix pending status in case of timeout
- Pass error code from dhd_is_associated() call
- Call cfg80211_disconnected() if no timeout detected
- Fix WEXT compilation
- Start SoftAP in G-band only
- Fix IF_DEL timeout due to wrong status check
- Fix P2P to pass certification
- Enable arpoe in concurrent mode by default
- Fail to start sched scan in P2P GO
